Only 5 monitors working on dual gpu setup in ArchLinux with the 'GeForce RTX 4070 SUPER' But monitors work fine with legacy driver and older GPU
Would like to add I also have tried Wayland instead of Xorg as well, just to try if that works better, but that one cannot boot at all. It just jump back to sddm after login.
So it seems the monitor connected to the displayport on the second gpu doesn’t work. Did you try switching a diferent monitor/cable to a different connector on that gpu to rule out whether it’s a connector/cable/monitor issue?
Thanks for reply, will give it a try… will come back with more information once it is done.
Hi, it was no difference, I tried with different display cables as well as outputs on the card,
I made sure the monitor is on and the correct output is set for the display port.
Interesting as well that this monitor and port and cable worked when connected all the cables to the 1080 ti card before. So this monitor and port have been working, just not together with 4070 card.
Wait… I typed this and now the monitor popped up, but it is still black but its available.
$ xrandr --setprovideroutputsource NVIDIA-G0 NVIDIA-0 && xrandr --auto
Feels like it may be very close now.
[nighter@desktop X11]$ xrandr
Screen 0: minimum 8 x 8, current 7680 x 2880, maximum 32767 x 32767
HDMI-0 connected 2560x1440+5120+1440 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     74.60*+  59.95
   1920x1080     60.00    59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1440x576      50.00
   1440x480      59.94
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    59.94    59.93
DP-0 connected primary 2560x1440+2560+1440 (normal left inverted right x axis y axis) 600mm x 340mm
   3840x2160     60.00 + 160.00   144.00   119.88    59.94    50.00
   2560x1440    144.00*
   1920x1080    119.93   119.88    60.00    59.94    50.00
   1680x1050    119.99    59.95
   1600x900      60.00
   1440x900      60.00    59.89
   1280x720      59.94    50.00
   1152x864      75.00
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     74.92*+  59.95
   1680x1050     59.95
   1440x900      59.89
   1440x576      50.00
   1440x480      59.94
   1280x960      60.00
   1280x800      59.81
   1152x864      75.00
   720x576       50.00
   720x480       59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 2560x1440+0+1440 (normal left inverted right x axis y axis) 597mm x 336mm
   1680x1050     59.95
   1440x900      59.89
   1440x576      50.00
   1440x480      59.94
   1280x960      60.00
   1280x800      59.81
   1152x864      75.00
   720x576       50.00
   720x480       59.94
DP-5 disconnected (normal left inverted right x axis y axis)
DVI-D-1-0 connected 2560x1440+5120+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95*+
   1920x1080     60.00
   1680x1050     59.95
   1440x900      59.89
   1280x960      60.00
   1280x800      59.81
   1280x720      60.00
   1152x864      75.00
   640x480       75.00    59.94
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
DP-1-4 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95*+
   1680x1050     59.95
   1440x900      59.89
   1440x576      50.00
   1440x480      59.94
   1280x960      60.00
   1280x800      59.81
   1152x864      75.00
   720x576       50.00
   720x480       59.94
DP-1-5 disconnected (normal left inverted right x axis y axis)
  2560x1440 (0x1be) 241.500MHz +HSync -VSync
        h: width  2560 start 2608 end 2640 total 2720 skew    0 clock  88.79KHz
        v: height 1440 start 1443 end 1448 total 1481           clock  59.95Hz
  1920x1080 (0x1bf) 148.500MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1680x1050 (0x1c2) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1440x900 (0x1c3) 106.500MHz -HSync +VSync
        h: width  1440 start 1520 end 1672 total 1904 skew    0 clock  55.93KHz
        v: height  900 start  903 end  909 total  934           clock  59.89Hz
  1280x1024 (0x1c6) 135.000MHz +HSync +VSync
        h: width  1280 start 1296 end 1440 total 1688 skew    0 clock  79.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  75.02Hz
  1280x1024 (0x1c7) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1280x960 (0x1c8) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1280x800 (0x1c9) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1280x720 (0x1ca) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1152x864 (0x1cd) 108.000MHz +HSync +VSync
        h: width  1152 start 1216 end 1344 total 1600 skew    0 clock  67.50KHz
        v: height  864 start  865 end  868 total  900           clock  75.00Hz
  1024x768 (0x1ce) 78.750MHz +HSync +VSync
        h: width  1024 start 1040 end 1136 total 1312 skew    0 clock  60.02KHz
        v: height  768 start  769 end  772 total  800           clock  75.03Hz
  1024x768 (0x1cf) 75.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1328 skew    0 clock  56.48KHz
        v: height  768 start  771 end  777 total  806           clock  70.07Hz
  1024x768 (0x1d0) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x1d1) 49.500MHz +HSync +VSync
        h: width   800 start  816 end  896 total 1056 skew    0 clock  46.88KHz
        v: height  600 start  601 end  604 total  625           clock  75.00Hz
  800x600 (0x1d2) 50.000MHz +HSync +VSync
        h: width   800 start  856 end  976 total 1040 skew    0 clock  48.08KHz
        v: height  600 start  637 end  643 total  666           clock  72.19Hz
  800x600 (0x1d3) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x1d4) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  640x480 (0x1d7) 31.500MHz -HSync -VSync
        h: width   640 start  656 end  720 total  840 skew    0 clock  37.50KHz
        v: height  480 start  481 end  484 total  500           clock  75.00Hz
  640x480 (0x1d8) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  1920x1080 (0x1c0) 148.350MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1920x1080 (0x1c1) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1440x576 (0x1c4) 54.000MHz -HSync +VSync
        h: width  1440 start 1464 end 1592 total 1728 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  1440x480 (0x1c5) 54.000MHz -HSync -VSync
        h: width  1440 start 1472 end 1596 total 1716 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  1280x720 (0x1cb) 74.180MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  1280x720 (0x1cc) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  720x576 (0x1d5) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
  720x480 (0x1d6) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
  640x480 (0x1d9) 25.170MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.46KHz
        v: height  480 start  490 end  492 total  525           clock  59.93Hz
I just turned off and on one monitor and it all started started to working… super thanks.
However I have this strange screen tearing on one of the monitors still, like matrix its blinking… maybe can get it to stop to change more cables to a different card.
Which monitor has the strange output? Did you already try to just set it to a different refresh rate? There’s quite a mixed setup now, 144Hz,75Hz,60Hz.
Wow, you are amazing I hope someone pays you for spending time helping people like this, you don’t understand how happy I am.
I changed from 75hz to 60hz on the monitor that was flickering and it resolved it all, as well as all monitors work right now.
Guess, the kernel parameter was the issue, in windows not sure whether I work now or not. But to be fair I don’t care about Windows, I use Linux for work, so here is where I need all the monitors. Windows is just gaming so it is fine with only 1 monitor working. So from my point of view, everything is working now. Super super thanks for your help and time.
I hope your good Karma for helping people like this gives you the world because, this was the best thing that could happen, I was so sad I could not get this to work as I’m relly depending on it. Thanks for all help and we can close this issue.
Remember, you will have to set your login manager to run the xrandr commands on boot, e.g. for lightdm:
https://wiki.archlinux.org/title/NVIDIA_Optimus#LightDM
Of course with the changed command you already ran.
