When I plug in two monitors (HDMI and DVI) everything is working fine. When I connect a 3rd montior (my TV), X hangs and “freezes” on the screen after flashing a bit. If i unplug one of the devices, X will flash again and be unfrozen. Essentially, I can only have any TWO of these display devices connected, not all 3 at once, otherwise I freeze.
How frustrating for a new card. I’ve attached logs below…
touma@setsuna:~ $ sudo journalctl -f
-- Logs begin at Thu 2015-08-06 23:19:29 EDT. --
Sep 11 22:59:12 setsuna avahi-daemon[1583]: Invalid response packet from host 192.168.1.80.
Sep 11 23:00:01 setsuna sudo[2558]: pam_unix(sudo:session): session closed for user root
Sep 11 23:00:14 setsuna sudo[3038]: touma : TTY=pts/0 ; PWD=/home/touma ; USER=root ; COMMAND=/usr/bin/journalctl -f
Sep 11 23:00:14 setsuna sudo[3038]: pam_unix(sudo:session): session opened for user root by touma(uid=0)
Sep 11 23:01:18 setsuna sudo[3038]: pam_unix(sudo:session): session closed for user root
Sep 11 23:01:20 setsuna sudo[3088]: touma : TTY=pts/0 ; PWD=/home/touma ; USER=root ; COMMAND=/usr/bin/journalctl -f
Sep 11 23:01:20 setsuna sudo[3088]: pam_unix(sudo:session): session opened for user root by touma(uid=0)
Sep 11 23:01:22 setsuna sudo[3088]: pam_unix(sudo:session): session closed for user root
Sep 11 23:01:24 setsuna sudo[3099]: touma : TTY=pts/0 ; PWD=/home/touma ; USER=root ; COMMAND=/usr/bin/journalctl -f
Sep 11 23:01:24 setsuna sudo[3099]: pam_unix(sudo:session): session opened for user root by touma(uid=0)
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: 600.0 MHz maximum pixel clock
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:01:28 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "NULL"
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-1: 600.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:01:29 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:01:29 setsuna gnome-session[757]: (gnome-shell:831): mutter-CRITICAL **: meta_screen_get_monitor_geometry: assertion 'monitor >= 0 && monitor < screen->n_monitor_infos' failed
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): device Samsung S24D390 (DFP-1) (Using EDID frequencies has
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): been enabled on all display devices.)
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): connected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): Internal TMDS
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): 600.0 MHz maximum pixel clock
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DVI-I-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:01:57 setsuna kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 20
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:01:57 setsuna kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 22
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 11 23:01:57 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): device STD HDMI TV (DFP-3) (Using EDID frequencies has
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (**) NVIDIA(0): been enabled on all display devices.)
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): connected
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): Internal TMDS
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): 165.0 MHz maximum pixel clock
Sep 11 23:02:34 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:02:35 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-1: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:02:35 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 000001e0 00000202 00000004 00000005
Sep 11 23:02:35 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:02:35 setsuna kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 24
Sep 11 23:02:38 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:02:41 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): connected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): Internal TMDS
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): 600.0 MHz maximum pixel clock
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): connected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): Internal TMDS
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): STD HDMI TV (DFP-3): 165.0 MHz maximum pixel clock
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 11 23:02:41 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
Sep 11 23:02:44 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Sep 11 23:02:44 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000002 00000080 00000000 00000005 0000000d
Sep 11 23:02:44 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000003 00000080 00000000 00000005 0000000d
Sep 11 23:02:44 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:02:55 setsuna gnome-session[574]: (gnome-settings-daemon:590): color-plugin-WARNING **: no xrandr-STD Computer Inc-STD HDMI TV-16843009 device found: Failed to find output xrandr-STD Computer Inc-STD HDMI TV-16843009
Sep 11 23:02:55 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Sep 11 23:02:55 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000002 00000080 00000000 00000005 0000000d
Sep 11 23:02:55 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000003 00000080 00000000 00000005 0000000d
Sep 11 23:02:57 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000001 00000080 00000000 00000005 0000000d
Sep 11 23:02:57 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000002 00000080 00000000 00000005 0000000d
Sep 11 23:02:57 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000003 00000080 00000000 00000005 0000000d
Sep 11 23:03:02 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:05 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:05 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 11 23:03:05 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 11 23:03:05 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
cxSep 11 23:03:05 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:08 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): connected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): Internal TMDS
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): 600.0 MHz maximum pixel clock
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 11 23:03:10 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
Sep 11 23:03:18 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:21 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00002004
Sep 11 23:03:21 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:03:24 setsuna kernel: NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 000001e0 00000200 00000004 00000001
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:03:24 setsuna kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 36
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DVI-I-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): connected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (CRT-0): 400.0 MHz maximum pixel clock
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): connected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): Internal TMDS
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): Samsung S24D390 (DFP-1): 600.0 MHz maximum pixel clock
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: disconnected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: disconnected
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
Sep 11 23:03:24 setsuna /usr/lib/gdm/gdm-x-session[750]: (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
nvidia-smi
touma@setsuna:~ $ nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Fri Sep 11 23:04:56 2015
Driver Version : 352.41
Attached GPUs : 1
GPU 0000:01:00.0
Product Name : GeForce GTX 970
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-61444683-c054-0312-8e48-738bd3d63eea
Minor Number : 0
VBIOS Version : 84.04.36.00.6E
MultiGPU Board : No
Board ID : 0x100
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x13C210DE
Bus Id : 0000:01:00.0
Sub System Id : 0x136619DA
GPU Link Info
PCIe Generation
Max : 2
Current : 2
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 4000 KB/s
Rx Throughput : 1000 KB/s
Fan Speed : 31 %
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Unknown : Not Active
FB Memory Usage
Total : 4093 MiB
Used : 321 MiB
Free : 3772 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 50 C
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 91 C
Power Readings
Power Management : Supported
Power Draw : 48.77 W
Power Limit : 151.20 W
Default Power Limit : 151.20 W
Enforced Power Limit : 151.20 W
Min Power Limit : 100.00 W
Max Power Limit : 160.30 W
Clocks
Graphics : 1075 MHz
SM : 1075 MHz
Memory : 3505 MHz
Applications Clocks
Graphics : 1076 MHz
Memory : 3505 MHz
Default Applications Clocks
Graphics : 1076 MHz
Memory : 3505 MHz
Max Clocks
Graphics : 1417 MHz
SM : 1417 MHz
Memory : 3505 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 567
Type : G
Used GPU Memory : 0 MiB
Process ID : 752
Type : G
Used GPU Memory : 161 MiB
Process ID : 831
Type : G
Used GPU Memory : 76 MiB
Process ID : 1275
Type : G
Name : /opt/google/chrome/chrome --type=gpu-process --channel=1240.0.1580247730 --v8-natives-passed-by-fd --v8-snapshot-passed-by-fd --supports-dual-gpus=false --gpu-driver-bug-workarounds=2,29,32,45,55,57 --disable-accelerated-video-decode --gpu-vendor-id=0x10de --gpu-device-id=0x13c2 --gpu-driver-vendor=NVIDIA --gpu-driver-version=352.41 --v8-natives-passed-by-fd --v8-snapshot-passed-by-fd
Used GPU Memory : 34 MiB
Process ID : 2282
Type : G
Used GPU Memory : 20 MiB
Attached GPUs : 1
GPU 0000:01:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
Minor Number : 0
MultiGPU Board : No
Board ID : 0x100
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
GPU Link Info
PCIe Generation
Max : 2
Current : 2
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 31 %
Idle : Not Active
FB Memory Usage
Total : 4093 MiB
Used : 321 MiB
Free : 3772 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
Power Readings
Clocks
Graphics : 1075 MHz
SM : 1075 MHz
Memory : 3505 MHz
Applications Clocks
Graphics : 1076 MHz
Memory : 3505 MHz
Graphics : 1076 MHz
Memory : 3505 MHz
Max Clocks
Graphics : 1417 MHz
SM : 1417 MHz
Memory : 3505 MHz
Clock Policy
Auto Boost : N/A
Processes
Process ID : 567
Type : G
Process ID : 752
Type : G
Process ID : 831
Type : G
Process ID : 1275
Type : G
Process ID : 2282
Type : G
For the record, all 3 work on the same machine under Windows.
nvidia-bug-report.log.gz (80 KB)
