I have 2 monitors on the GeForce 210 and 4 on the Geforce GT 710. The Mint display app only sees the 4 on the 710. So I go into Nvidia Settings and the other 2 are there but disabled in yellow. I simply enable one or two of them and save changes to xorg.conf. Reload X with crtl+alt+BackSpace and they never appear in the app, and the 2 screens are still just always black. Not only that, but now I am in fall-back mode until I reestablish the xorg.conf and reload X.
System: Kernel: 5.4.0-128-generic x86_64 bits: 64 compiler: gcc v: 9.4.0 Desktop: Cinnamon 5.2.7 wm: muffin 5.2.1
dm: LightDM 1.30.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: Gigabyte model: 970A-DS3P serial: <filter> BIOS: American Megatrends v: FD date: 02/26/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K230 serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
CPU: Topology: 6-Core model: AMD Phenom II X6 1055T bits: 64 type: MCP arch: K10 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 33756
Speed: 804 MHz min/max: 800/2800 MHz boost: enabled Core speeds (MHz): 1: 804 2: 804 3: 804 4: 804 5: 804 6: 804
Graphics: Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia v: 340.108 bus ID: 01:00.0
chip ID: 10de:128b
Device-2: NVIDIA GT218 [GeForce 210] vendor: eVga.com. driver: nvidia v: 340.108 bus ID: 06:00.0 chip ID: 10de:0a65
Display: x11 server: X.Org 1.20.13 driver: none unloaded: nvidia
resolution: 1680x1050~60Hz, 1920x1080~60Hz, 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: Graphics Device/PCIe/SSE2 v: 4.4.0 NVIDIA 340.108 direct render: Yes
Audio: Device-1: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0e0f
Device-2: NVIDIA High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 06:00.1
chip ID: 10de:0be3
Sound Server: ALSA v: k5.4.0-128-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 6.17 TiB used: 12.96 GiB (0.2%)
ID-1: /dev/sda vendor: Crucial model: CT256MX100SSD1 size: 238.47 GiB speed: 6.0 Gb/s serial: <filter> rev: MU01
temp: 33 C scheme: MBR
ID-2: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB speed: 6.0 Gb/s rotation: 5425 rpm
serial: <filter> rev: 0001 temp: 35 C scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD5000AAKS-00V1A0 size: 465.76 GiB speed: 3.0 Gb/s serial: <filter>
rev: 1D05 temp: 37 C scheme: MBR
ID-4: /dev/sdd vendor: Western Digital model: WD20EARS-00MVWB0 size: 1.82 TiB speed: <unknown> serial: <filter>
rev: AB51 temp: 30 C scheme: MBR
ID-5: /dev/sde type: USB vendor: Generic model: Multi-Card size: 28.97 GiB serial: <filter> rev: 1.00 scheme: GPT
RAID: Hardware-1: VIA VT6421 IDE/SATA Controller driver: sata_via v: 2.6 port: c000 bus ID: 05:06.0 chip ID: 1106.3249
rev: 50
Partition: ID-1: / size: 42.18 GiB used: 12.96 GiB (30.7%) fs: ext4 dev: /dev/sda6
Sensors: System Temperatures: cpu: 22.5 C mobo: N/A gpu: nvidia temp: 79 C
Fan Speeds (RPM): N/A
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.list
1: deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg arch=amd64] https://brave-browser-apt-release.s3.brave.com/ stable main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http://packages.linuxmint.com una main upstream import backport #id:linuxmint_main
2: deb http://archive.ubuntu.com/ubuntu focal main restricted universe multiverse
3: deb http://archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
4: deb http://archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
5: deb http://security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
6: deb http://archive.canonical.com/ubuntu/ focal partner
Active apt repos in: /etc/apt/sources.list.d/vscode.list
1: deb [arch=amd64,arm64,armhf] http://packages.microsoft.com/repos/code stable main
Info: Processes: 340 Uptime: 16h 52m Memory: 23.46 GiB used: 3.26 GiB (13.9%) Init: systemd v: 245 runlevel: 5 Compilers:
gcc: 9.4.0 alt: 9 Shell: bash v: 5.0.17 running in: gnome-terminal inxi: 3.0.38
dmesg |grep nvidia
[ 17.019832] audit: type=1400 audit(1666572536.136:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=429 comm="apparmor_parser"
[ 17.019842] audit: type=1400 audit(1666572536.136:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=429 comm="apparmor_parser"
[ 17.436859] nvidia: loading out-of-tree module taints kernel.
[ 17.436869] nvidia: module license 'NVIDIA' taints kernel.
[ 17.452879] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 17.464967] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 17.465520] nvidia 0000:06:00.0: enabling device (0000 -> 0003)
[ 17.465587] nvidia 0000:06:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 17.466188] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 0
[ 17.466232] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:06:00.0 on minor 1
[ 18.456287] nvidia_uvm: Loaded the UVM driver, major device number 239
[ 18.808101] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[ 28.087710] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[ 3051.383049] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[ 3297.598212] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[ 3422.646208] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[ 6875.886079] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[18674.632336] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[18963.148082] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[22228.235505] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[22301.295133] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[22767.457712] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[24868.202624] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[24869.387959] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[25234.441386] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[25433.482229] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
[25434.647468] caller os_map_kernel_space+0x6d/0xb0 [nvidia] mapping multiple BARs
sudo lspci -v
+00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge (rev 02)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge
Flags: fast devsel, NUMA node 0
Capabilities: [f0] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [c4] HyperTransport: Slave or Primary Interface
Capabilities: [40] HyperTransport: Retry Mode
Capabilities: [54] HyperTransport: UnitID Clumping
Capabilities: [9c] HyperTransport: #1a
Capabilities: [70] MSI: Enable- Count=1/4 Maskable- 64bit-
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD/ATI] RD890S/RD990 I/O Memory Management Unit (IOMMU)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890S/RD990 I/O Memory Management Unit (IOMMU)
Capabilities: [40] Secure device <?>
Capabilities: [54] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [64] HyperTransport: MSI Mapping Enable+ Fixed+
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25, NUMA node 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f6000000-f70fffff [size=17M]
Prefetchable memory behind bridge: 00000000c8000000-00000000d1ffffff [size=160M]
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0)
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [190] Access Control Services
Kernel driver in use: pcieport
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26, NUMA node 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: f7500000-f75fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 0)
00:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27, NUMA node 0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: f7400000-f74fffff [size=1M]
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 1)
00:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, NUMA node 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: f7300000-f73fffff [size=1M]
Prefetchable memory behind bridge: 00000000d2100000-00000000d21fffff [size=1M]
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 4)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40) (prog-if 01 [AHCI 1.0])
Subsystem: Gigabyte Technology Co., Ltd SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 19, NUMA node 0
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f070 [size=8]
I/O ports at f060 [size=4]
I/O ports at f050 [size=16]
Memory at f5107000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [70] SATA HBA v1.0
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Subsystem: Gigabyte Technology Co., Ltd SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 18, NUMA node 0
Memory at f5106000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci-pci
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Subsystem: Gigabyte Technology Co., Ltd SB7x0/SB8x0/SB9x0 USB EHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 17, NUMA node 0
Memory at f5105000 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci-pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Memory at f5104000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Memory at f5103000 (32-bit, non-prefetchable) [size=256]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller
Flags: 66MHz, medium devsel, NUMA node 0
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 IDE Controller (rev 40) (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
Subsystem: Gigabyte Technology Co., Ltd SB7x0/SB8x0/SB9x0 IDE Controller
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at f000 [size=16]
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp, pata_acpi
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller
Flags: bus master, 66MHz, medium devsel, latency 0, NUMA node 0
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40) (prog-if 01 [Subtractive decode])
Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64, NUMA node 0
Bus: primary=00, secondary=05, subordinate=05, sec-latency=64
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: f7200000-f72fffff [size=1M]
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller (prog-if 10 [OHCI])
Subsystem: Gigabyte Technology Co., Ltd SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
Memory at f5102000 (32-bit, non-prefetchable) [size=4K]
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, NUMA node 0
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 0000b000-0000bfff [size=4K]
Memory behind bridge: f4000000-f50fffff [size=17M]
Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff [size=288M]
Capabilities: [58] Express Root Port (Slot-), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Memory at f5101000 (32-bit, non-prefetchable) [size=4K]
00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Memory at f5100000 (32-bit, non-prefetchable) [size=256]
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor HyperTransport Configuration
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Miscellaneous Control
Capabilities: [f0] Secure device <?>
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Link Control
01:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 710] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. GK208B [GeForce GT 710]
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at c8000000 (64-bit, prefetchable) [size=128M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia
01:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1)
Subsystem: ASUSTeK Computer Inc. GK208 HDMI/DP Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 36, NUMA node 0
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:00.0 USB controller: VIA Technologies, Inc. VL805 USB 3.0 Host Controller (rev 01) (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd VL805 USB 3.0 Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0
Memory at f7500000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable+ Count=1/4 Maskable- 64bit+
Capabilities: [c4] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: xhci_hcd
03:00.0 USB controller: VIA Technologies, Inc. VL805 USB 3.0 Host Controller (rev 01) (prog-if 30 [XHCI])
Subsystem: VIA Technologies, Inc. VL805 USB 3.0 Host Controller
Flags: fast devsel, IRQ 33, NUMA node 0
Memory at f7400000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [90] MSI: Enable- Count=1/4 Maskable- 64bit+
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0
I/O ports at d000 [size=256]
Memory at f7300000 (64-bit, non-prefetchable) [size=4K]
Memory at d2100000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
Capabilities: [170] Latency Tolerance Reporting
Kernel driver in use: r8169
Kernel modules: r8169
05:06.0 RAID bus controller: VIA Technologies, Inc. VT6421 IDE/SATA Controller (rev 50)
Subsystem: VIA Technologies, Inc. VT6421 IDE/SATA Controller
Flags: bus master, medium devsel, latency 32, IRQ 20, NUMA node 0
I/O ports at c150 [size=16]
I/O ports at c140 [size=16]
I/O ports at c130 [size=16]
I/O ports at c120 [size=16]
I/O ports at c100 [size=32]
I/O ports at c000 [size=256]
Expansion ROM at f7200000 [disabled] [size=64K]
Capabilities: [e0] Power Management version 2
Kernel driver in use: sata_via
Kernel modules: sata_via
06:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 210] (rev a2) (prog-if 00 [VGA controller])
Subsystem: eVga.com. Corp. GT218 [GeForce 210]
Flags: bus master, fast devsel, latency 0, IRQ 38, NUMA node 0
Memory at f4000000 (32-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
Memory at c0000000 (64-bit, prefetchable) [size=32M]
I/O ports at b000 [size=128]
Expansion ROM at f5000000 [virtual] [disabled] [size=512K]
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
06:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
Subsystem: eVga.com. Corp. High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 17, NUMA node 0
Memory at f5080000 (32-bit, non-prefetchable) [size=16K]
xrandr --verbose
Screen 0: minimum 8 x 8, current 5760 x 2130, maximum 16384 x 16384
HDMI-0 connected primary 1680x1050+2160+0 (0x27f) normal (normal left inverted right x axis y axis) 495mm x 291mm
Identifier: 0x27e
Timestamp: 26030741
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff005a63206b01010101
1b12010380311d782ee525a65444a125
145054bfef80b300a940950090408180
8140714f010121399030621a274068b0
3600ef231100001c000000ff00515242
3038323732313735360a000000fd0032
4b185211000a202020202020000000fc
00565832323430770a202020202001fb
02031b61230907078301000067030c00
2000802d43908402e2000f8c0ad08a20
e02d10103e9600a05a00000000000000
00000000000000000000000000000000
00000000000000000000000000000029
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
1680x1050 (0x27f) 146.250MHz -HSync +VSync *current +preferred
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1920x1080 (0x280) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1600x1200 (0x281) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1440x900 (0x282) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1400x1050 (0x283) 121.750MHz -HSync +VSync
h: width 1400 start 1488 end 1632 total 1864 skew 0 clock 65.32KHz
v: height 1050 start 1053 end 1057 total 1089 clock 59.98Hz
1280x1024 (0x284) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x285) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x286) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x720 (0x287) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1152x864 (0x288) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x289) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x28a) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x28b) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x28c) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x28d) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x28e) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x28f) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x480 (0x290) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x480 (0x291) 27.000MHz -HSync +VSync
640x480 (0x292) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x293) 31.500MHz -HSync -VSync
h: width 640 start 656 end 696 total 832 skew 0 clock 37.86KHz
v: height 480 start 481 end 484 total 520 clock 72.81Hz
640x480 (0x294) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
HDMI-1 connected 1920x1080+3840+450 (0x296) normal (normal left inverted right x axis y axis) 521mm x 293mm
Identifier: 0x295
Timestamp: 26030741
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 0 1 2 3
filter:
EDID:
00ffffffffffff005a633e2b01010101
2616010380341d782ea725a45751a026
105054b56b80b300a940950090408180
8140810f714f023a801871382d40582c
450009252100001e000000ff0054454e
3132333830303632320a000000fd0037
4c1d5311000a202020202020000000fc
005641323430364d2d4c45440a200065
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
1920x1080 (0x296) 148.500MHz +HSync +VSync *current +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1280x800 (0x297) 106.500MHz -HSync +VSync
h: width 1280 start 1360 end 1488 total 1696 skew 0 clock 62.79KHz
v: height 800 start 803 end 809 total 838 clock 74.93Hz
HDMI-2 connected 1920x1080+0+1050 (0x296) normal (normal left inverted right x axis y axis) 598mm x 336mm
Identifier: 0x298
Timestamp: 26030741
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 2
CRTCs: 0 1 2 3
filter:
EDID:
00ffffffffffff0009d1c37845540000
2e160103803c22782e2cc5a55554a127
0c505421080061c0810081c081408180
a9c0b300d1c0023a801871382d40582c
450056502100001e000000ff00504243
3031343837534c300a20000000fd0032
4c1e5311000a202020202020000000fc
0042656e5120475732373530480a01e9
020322f14f9005040302011112131406
0715161f2309070765030c0010008301
0000023a801871382d40582c45005650
2100001f011d8018711c1620582c2500
56502100009f011d007251d01e206e28
550056502100001e8c0ad08a20e02d10
103e9600565021000018000000000000
00000000000000000000000000000047
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
1920x1080 (0x299) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x29a) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1124 clock 60.05Hz
1920x1080 (0x29b) 74.180MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1124 clock 60.00Hz
1920x1080 (0x29c) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1124 clock 50.04Hz
1600x900 (0x29d) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x800 (0x29e) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x720 (0x29f) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x2a0) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x576 (0x2a1) 47.000MHz -HSync +VSync
h: width 1024 start 1064 end 1168 total 1312 skew 0 clock 35.82KHz
v: height 576 start 577 end 580 total 597 clock 60.01Hz
720x576 (0x2a2) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x576 (0x2a3) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 624 clock 50.08Hz
720x480 (0x2a4) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 524 clock 60.05Hz
640x480 (0x2a5) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
HDMI-3 connected 1920x1080+1920+1050 (0x296) normal (normal left inverted right x axis y axis) 598mm x 336mm
Identifier: 0x2a6
Timestamp: 26030741
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 3
CRTCs: 0 1 2 3
filter:
EDID:
3031353130534c300a20000000fd0032
0042656e5120475732373530480a01f6
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 1
_ConnectorLocation: 1
non-desktop: 0
supported: 0, 1
I would like for starters to be able to see all the monitors. And if possible I definitely want them all in a single XScreen. But I can’t make any headway so far :-(
I am sending the bug report from inside X when everything is normal (no fall-back mode) because that problem just seems to come from bad configuration from nvidia-settings.
nvidia-bug-report.log.gz (122.8 KB)
