Hello Everyone,
I would like to ask for some help with my dual GPU setup with two identical GeForce® GTX 1650 WINDFORCE OC 4G.
I want to use them to display some static websites in six (3+3) 4k capable (Samsung) TV.
So I’m not interested in optimal performance or anything, I just want the cards to work with the 6 HDMI output.)
My specs in detail:
inxi -Fxz
System: Host: tv-mgmt Kernel: 4.15.0-54-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Console: tty 0
Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: ASUSTeK model: P7P55D v: Rev 1.xx serial: <filter> BIOS: American Megatrends v: 2101
date: 10/20/2011
CPU: Topology: Quad Core model: Intel Core i5 750 bits: 64 type: MCP arch: Nehalem rev: 5 L2 cache: 8192 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21399
Speed: 1204 MHz min/max: 1200/2668 MHz Core speeds (MHz): 1: 1204 2: 1204 3: 1204 4: 1204
Graphics: Device-1: NVIDIA vendor: Gigabyte driver: nvidia v: 430.26 bus ID: 01:00.0
Device-2: NVIDIA vendor: Gigabyte driver: nvidia v: 430.26 bus ID: 06:00.0
Display: server: X.org 1.19.6 driver: none FAILED: nvidia tty: 120x25
Message: Advanced graphics data unavailable in console for root.
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 06:00.1
Sound Server: ALSA v: k4.15.0-54-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK M4A785/P7P55
driver: r8169 v: 2.3LK-NAPI port: b800 bus ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 111.79 GiB used: 6.40 GiB (5.7%)
ID-1: /dev/sda vendor: OCZ model: VERTEX3 size: 111.79 GiB temp: 30 C
Partition: ID-1: / size: 108.56 GiB used: 6.40 GiB (5.9%) fs: ext4 dev: /dev/dm-0
ID-2: swap-1 size: 976.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 202 Uptime: 21h 19m Memory: 7.79 GiB used: 556.9 MiB (7.0%) Init: systemd runlevel: 5
Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Both VGA working flawlessly by themselves, from any of the PCI-E slot.
Both can recognize 3 HDMI connected TV (4k res) and a DP connected DELL (1920x1080) monitor.
I could even make a VNC connection and do some remote work!
The main problem:
There is no scenario where all of the connected displays (6 TV + 1 monitor) are recognized at the same time.
sudo -H nvidia-settings # only one of the GPU-s are in the list
For the sake of simplicity I took the whole PC and connected 2 FHD (LG) monitor
- instead of the 7 big screen - to test the multi GPU displaying. Sadly, without success.
I tried many distributions (Linux Mint 19.2, Manjaro 18.1.0, Ubuntu 19.04)
with different kernels (4.15, 4.19, 5.0) and desktop environments
(XFCE 4.12-, 4.14, Gnome 3.32, so lightdm and gdm were also tested).
More info:
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f82 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
06:00.0 VGA compatible controller: NVIDIA Corporation Device 1f82 (rev a1)
06:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
nvidia-smi -L
GPU 0: GeForce GTX 1650 (UUID: GPU-...4ab3)
sudo dmesg |grep NVRM
[ 13.933222] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 430.26 Tue Jun 4 17:40:52 CDT 2019
[ 15.741299] NVRM: GPU at PCI:0000:06:00: GPU-20c4e4a3-d78c-3582-bb69-07264cbe7ddf
[ 15.741302] NVRM: GPU Board Serial Number:
[ 15.741304] NVRM: Xid (PCI:0000:06:00): 61, 0cb5(2d50) 00000000 00000000
[ 68.666607] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x24:0x65:1119)
[ 68.666777] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 1
[ 74.318375] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x24:0x65:1119)
[ 74.318494] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 1
[ 681.394188] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x24:0x65:1119)
[ 681.394306] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 1
[75788.064517] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x24:0x65:1119)
[75788.064615] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 1
nvidia-xconfig --query-gpu-info
WARNING: Unable to use the nvidia-cfg library to query NVIDIA hardware.
ERROR: Unable to query GPU information
nvidia-xconfig --enable-all-gpus --separate-x-screens
Using X configuration file: "/etc/X11/xorg.conf".
ERROR: Unable to determine number of GPUs in system; cannot honor '--enable-all-gpus' option.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.nvidia-xconfig-original'
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
Test results:
- With proprietary driver installed:
(by default: 430.26, from ppa:graphics-drivers/ppa repo: 435.21, 390.77)
the second monitor is fully blank.
I tried…
… to delete displays.xml:
mv ~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml ~/.displays.xml.bak…to modify (the appropriate) xorg.conf (in /etc/X11/ or xorg.conf.d or mhwd.d):
Option "Xinerama" "1" Option "MultiGPU" "On" Option "BaseMosaic" "On"…to blacklist nouveau:
bash -c "echo blacklist nouveau > /etc/modprobe.d/blacklist-nvidia-nouveau.conf" bash -c "echo options nouveau modeset=0 >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf" rm -f /boot/initrd* update-initramfs -c -k all update-grub - Without proprietary driver: same (empty second display). Interestingly with an auto-configured xorg.conf (X --configure provided me a basic config) it kinda' works: the second monitor has a desktop, but the resolution on both monitor are 640x480 and after opening the Display settings: it freezes. I could not even change to other virtual console to open another session or something. As for the resolution: the usual gtf; xrandr --newmode; xrandr --addmode commands dropped some errors, so I gave up.
After all this, I figured, why not try to merge
the Nvidia generated xorg.conf with the kinda’ working one, like:
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" LeftOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
Option "BlankTime" "0"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG Electronics E2260"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1650"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:6:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-4"
Option "metamodes" "nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "Off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
It did not help.
Am I missing something? Should I use SLI for this kind of thing, or my xorg.conf is to blame?
Thanks in advance for any help.
nvidia-bug-report.log.gz (1.06 MB)
