I have an issue when I install Linux drivers.
Description:
- Black screen after install driver 418 with packages and 430 with downloading script.
- Only HDMI port work (LG Electronics LG TV), not the notebook screen
- xrandr return “Can’t open display”
Here my configuration:
Notebook Asus GL704GW with RTX 2070
Ubuntu 18.04 Kernel 4.19.0
I allready made multiple reinstall.
Please found here some command return:
nvidia-smi
| NVIDIA-SMI 418.67 Driver Version: 418.67 CUDA Version: 10.1 |
| 0 GeForce RTX 2070 Off | 00000000:01:00.0 Off | N/A |
| N/A 45C P8 5W / N/A | 18MiB / 7952MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1088 G /usr/lib/xorg/Xorg 7MiB |
| 0 1263 G /usr/bin/gnome-shell 9MiB |
parse-edid returns:
Section "Monitor"
Identifier "J"
ModelName "J"
VendorName "AUO"
# Monitor Manufactured week 16 of 2018
# EDID version 1.4
# Digital Display
DisplaySize 380 220
Gamma 2.20
Option "DPMS" "false"
Modeline "Mode 0" 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync
Modeline "Mode 1" 368.14 1920 1968 2000 2102 1080 1090 1095 2918 -hsync -vsync
EndSection
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 418.67
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 430.14
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG Electronics LG TV"
HorizSync 30.0 - 83.0
VertRefresh 58.0 - 62.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce RTX 2070"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
[code]
My xorg log:
[ 6.742] (–) Log file renamed from “/var/log/Xorg.pid-1055.log” to “/var/log/Xorg.0.log”
[ 6.743]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 6.743] X Protocol Version 11, Revision 0
[ 6.743] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 6.743] Current Operating System: Linux Deep42 4.19.0-041900-generic #201810221809 SMP Mon Oct 22 22:11:45 UTC 2018 x86_64
[ 6.743] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-041900-generic root=UUID=7f446104-ecf9-4f03-88d6-b8c325fb1de2 ro quiet splash vt.handoff=1
[ 6.743] Build Date: 25 October 2018 04:11:27PM
[ 6.743] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see Enterprise open source support | Ubuntu)
[ 6.743] Current version of pixman: 0.34.0
[ 6.743] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 6.743] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 6.743] (==) Log file: “/var/log/Xorg.0.log”, Time: Sat May 25 14:01:06 2019
[ 6.744] (==) Using config file: “/etc/X11/xorg.conf”
[ 6.744] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 6.744] (==) ServerLayout “Layout0”
[ 6.744] () |–>Screen “Screen0” (0)
[ 6.744] () | |–>Monitor “Monitor0”
[ 6.745] () | |–>Device “Device0”
[ 6.745] () |–>Input Device “Keyboard0”
[ 6.745] () |–>Input Device “Mouse0”
[ 6.745] (==) Automatically adding devices
[ 6.745] (==) Automatically enabling devices
[ 6.745] (==) Automatically adding GPU devices
[ 6.745] (==) Automatically binding GPU devices
[ 6.745] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.745] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 6.745] Entry deleted from font path.
[ 6.745] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 6.745] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 6.745] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 6.745] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 6.745] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 6.745] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 6.745] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 6.745] (WW) Disabling Keyboard0
[ 6.745] (WW) Disabling Mouse0
[ 6.745] (II) Loader magic: 0x55e26a7af020
[ 6.745] (II) Module ABI versions:
[ 6.745] X.Org ANSI C Emulation: 0.4
[ 6.745] X.Org Video Driver: 23.0
[ 6.745] X.Org XInput driver : 24.1
[ 6.745] X.Org Server Extension : 10.0
[ 6.746] (++) using VT number 1
[ 6.746] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 6.747] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.747] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 6.747] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.747] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 6.748] () OutputClass “nvidia” ModulePath extended to “/usr/lib/x86_64-linux-gnu/xorg,/usr/lib/xorg/modules”
[ 6.748] () OutputClass “Nvidia Prime” ModulePath extended to “/x86_64-linux-gnu/nvidia/xorg,/usr/lib/x86_64-linux-gnu/xorg,/usr/lib/xorg/modules”
[ 6.748] () OutputClass “Nvidia Prime” setting /dev/dri/card1 as PrimaryGPU
[ 6.749] (–) PCI: (0:0:2:0) 8086:3e9b:1043:1321 rev 0, Mem @ 0xa3000000/16777216, 0x80000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x???/131072
[ 6.749] (–) PCI:*(0:1:0:0) 10de:1f10:1043:1321 rev 161, Mem @ 0xa4000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/524288
[ 6.749] (II) LoadModule: “glx”
[ 6.750] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.754] (II) Module glx: vendor=“X.Org Foundation”
[ 6.754] compiled for 1.19.6, module version = 1.0.0
[ 6.754] ABI class: X.Org Server Extension, version 10.0
[ 6.754] (II) LoadModule: “nvidia”
[ 6.754] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/nvidia_drv.so
[ 6.756] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 6.756] compiled for 4.0.2, module version = 1.0.0
[ 6.756] Module class: X.Org Video Driver
[ 6.757] (II) NVIDIA dlloader X Driver 418.67 Sat Apr 6 02:51:17 CDT 2019
[ 6.757] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.757] (II) systemd-logind: releasing fd for 226:1
[ 6.758] (II) Loading sub module “fb”
[ 6.758] (II) LoadModule: “fb”
[ 6.758] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.759] (II) Module fb: vendor=“X.Org Foundation”
[ 6.759] compiled for 1.19.6, module version = 1.0.0
[ 6.759] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.759] (II) Loading sub module “wfb”
[ 6.759] (II) LoadModule: “wfb”
[ 6.759] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 6.759] (II) Module wfb: vendor=“X.Org Foundation”
[ 6.759] (II) Loading sub module “ramdac”
[ 6.759] (II) LoadModule: “ramdac”
[ 6.759] (II) Module “ramdac” already built-in
[ 6.760] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 6.760] (==) NVIDIA(0): RGB weight 888
[ 6.760] (==) NVIDIA(0): Default visual is TrueColor
[ 6.760] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.761] (II) Applying OutputClass “nvidia” options to /dev/dri/card1
[ 6.761] (II) Applying OutputClass “Nvidia Prime” options to /dev/dri/card1
[ 6.761] () NVIDIA(0): Option “AllowEmptyInitialConfiguration”
[ 6.761] () NVIDIA(0): Option “IgnoreDisplayDevices” “CRT”
[ 6.761] () NVIDIA(0): Enabling 2D acceleration
[ 6.761] (II) Loading sub module “glxserver_nvidia”
[ 6.761] (II) LoadModule: “glxserver_nvidia”
[ 6.761] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/libglxserver_nvidia.so
[ 6.780] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 6.780] compiled for 4.0.2, module version = 1.0.0
[ 6.780] Module class: X.Org Server Extension
[ 6.780] (II) NVIDIA GLX Module 418.67 Sat Apr 6 02:49:59 CDT 2019
[ 7.242] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 7.242] (–) NVIDIA(0): DFP-0
[ 7.242] (–) NVIDIA(0): DFP-1
[ 7.242] (–) NVIDIA(0): DFP-2
[ 7.244] (II) NVIDIA(0): NVIDIA GPU GeForce RTX 2070 (TU106-A) at PCI:1:0:0 (GPU-0)
[ 7.244] (–) NVIDIA(0): Memory: 8388608 kBytes
[ 7.244] (–) NVIDIA(0): VideoBIOS: 90.06.2d.00.94
[ 7.244] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 7.244] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.244] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.244] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.245] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.245] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.245] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.245] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.245] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.245] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 7.245] (==) NVIDIA(0):
[ 7.245] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 7.245] (==) NVIDIA(0): will be used as the requested mode.
[ 7.245] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 7.245] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 7.245] (II) NVIDIA(0): Validated MetaModes:
[ 7.245] (II) NVIDIA(0): “NULL”
[ 7.245] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 7.245] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 7.245] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 7.245] (–) Depth 24 pixmap format is 32 bpp
[ 7.245] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 7.245] (II) NVIDIA: access.
[ 7.268] (II) NVIDIA(0): Setting mode “NULL”
[ 7.280] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 7.280] (==) NVIDIA(0): Backing store enabled
[ 7.280] (==) NVIDIA(0): Silken mouse enabled
[ 7.280] () NVIDIA(0): DPMS enabled
[ 7.281] (WW) NVIDIA(0): Option “PrimaryGPU” is not used
[ 7.281] (II) Loading sub module “dri2”
[ 7.281] (II) LoadModule: “dri2”
[ 7.281] (II) Module “dri2” already built-in
[ 7.281] (II) NVIDIA(0): [DRI2] Setup complete
[ 7.281] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 7.281] (–) RandR disabled
[ 7.283] (II) SELinux: Disabled on system
[ 7.283] (II) Initializing extension GLX
[ 7.283] (II) Indirect GLX disabled.
[ 7.313] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 7.313] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 7.313] (II) LoadModule: “libinput”
[ 7.313] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.315] (II) Module libinput: vendor=“X.Org Foundation”
[ 7.315] compiled for 1.19.6, module version = 0.27.1
[ 7.315] Module class: X.Org XInput Driver
[ 7.315] ABI class: X.Org XInput driver, version 24.1
[ 7.315] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 7.316] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 40 paused 0
[ 7.316] () Power Button: always reports core events
[ 7.316] () Option “Device” “/dev/input/event3”
[ 7.316] () Option “_source” “server/udev”
[ 7.316] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.316] (II) event3 - Power Button: device is a keyboard
[ 7.316] (II) event3 - Power Button: device removed
[ 7.316] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
[ 7.316] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 7.316] () Option “xkb_model” “pc105”
[ 7.316] () Option “xkb_layout” “fr”
[ 7.316] () Option “xkb_variant” “latin9”
[ 7.325] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.325] (II) event3 - Power Button: device is a keyboard
[ 7.325] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event13)
[ 7.325] () Asus Wireless Radio Control: Applying InputClass “libinput keyboard catchall”
[ 7.325] (II) Using input driver ‘libinput’ for ‘Asus Wireless Radio Control’
[ 7.326] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 43 paused 0
[ 7.326] () Asus Wireless Radio Control: always reports core events
[ 7.326] () Option “Device” “/dev/input/event13”
[ 7.326] () Option “_source” “server/udev”
[ 7.326] (II) event13 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 7.326] (II) event13 - Asus Wireless Radio Control: device is a keyboard
[ 7.326] (II) event13 - Asus Wireless Radio Control: device removed
[ 7.326] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input17/event13”
[ 7.326] (II) XINPUT: Adding extended input device “Asus Wireless Radio Control” (type: KEYBOARD, id 7)
[ 7.326] () Option “xkb_model” “pc105”
[ 7.326] () Option “xkb_layout” “fr”
[ 7.326] () Option “xkb_variant” “latin9”
[ 7.327] (II) config/udev: Adding input device Video Bus (/dev/input/event16)
[ 7.327] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 7.327] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 7.327] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 44 paused 0
[ 7.327] () Video Bus: always reports core events
[ 7.327] () Option “Device” “/dev/input/event16”
[ 7.327] () Option “_source” “server/udev”
[ 7.327] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 7.327] (II) event16 - Video Bus: device is a keyboard
[ 7.327] (II) event16 - Video Bus: device removed
[ 7.327] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20/event16”
[ 7.327] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 7.327] () Option “xkb_model” “pc105”
[ 7.327] () Option “xkb_layout” “fr”
[ 7.327] () Option “xkb_variant” “latin9”
[ 7.328] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 7.328] (II) event16 - Video Bus: device is a keyboard
[ 7.328] (II) config/udev: Adding input device Video Bus (/dev/input/event17)
[ 7.328] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 7.328] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 7.328] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 45 paused 0
[ 7.328] () Video Bus: always reports core events
[ 7.328] () Option “Device” “/dev/input/event17”
[ 7.328] () Option “_source” “server/udev”
[ 7.329] (II) event17 - Video Bus: is tagged by udev as: Keyboard
[ 7.329] (II) event17 - Video Bus: device is a keyboard
[ 7.329] (II) event17 - Video Bus: device removed
[ 7.329] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input21/event17”
[ 7.329] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 9)
[ 7.329] () Option “xkb_model” “pc105”
[ 7.329] () Option “xkb_layout” “fr”
[ 7.329] () Option “xkb_variant” “latin9”
[ 7.329] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 7.329] (II) No input driver specified, ignoring this device.
[ 7.329] (II) This device may have been added with another device file.
[ 7.329] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.329] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 7.329] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 7.330] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 46 paused 0
[ 7.330] () Power Button: always reports core events
[ 7.330] () Option “Device” “/dev/input/event2”
[ 7.330] () Option “_source” “server/udev”
[ 7.330] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.330] (II) event2 - Power Button: device is a keyboard
[ 7.330] (II) event2 - Power Button: device removed
[ 7.330] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2”
[ 7.330] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 10)
[ 7.330] () Option “xkb_model” “pc105”
[ 7.330] () Option “xkb_layout” “fr”
[ 7.330] () Option “xkb_variant” “latin9”
[ 7.331] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 7.331] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 7.331] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 7.331] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 47 paused 0
[ 7.331] () Sleep Button: always reports core events
[ 7.331] () Option “Device” “/dev/input/event1”
[ 7.331] () Option “_source” “server/udev”
[ 7.331] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 7.331] (II) event1 - Sleep Button: device is a keyboard
[ 7.331] (II) event1 - Sleep Button: device removed
[ 7.331] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1”
[ 7.331] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 11)
[ 7.331] () Option “xkb_model” “pc105”
[ 7.331] () Option “xkb_layout” “fr”
[ 7.331] () Option “xkb_variant” “latin9”
[ 7.332] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 7.332] (II) event1 - Sleep Button: device is a keyboard
[ 7.332] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event19)
[ 7.332] (II) No input driver specified, ignoring this device.
[ 7.332] (II) This device may have been added with another device file.
[ 7.332] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event26)
[ 7.332] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device (/dev/input/event5)
[ 7.332] () ASUSTeK Computer Inc. N-KEY Device: Applying InputClass “libinput keyboard catchall”
[ 7.332] (II) Using input driver ‘libinput’ for ‘ASUSTeK Computer Inc. N-KEY Device’
[ 7.333] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 48 paused 0
[ 7.333] () ASUSTeK Computer Inc. N-KEY Device: always reports core events
[ 7.333] () Option “Device” “/dev/input/event5”
[ 7.333] () Option “_source” “server/udev”
[ 7.333] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: is tagged by udev as: Keyboard
[ 7.333] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: device is a keyboard
[ 7.333] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: device removed
[ 7.333] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/0003:0B05:1866.0004/input/input5/event5”
[ 7.333] (II) XINPUT: Adding extended input device “ASUSTeK Computer Inc. N-KEY Device” (type: KEYBOARD, id 12)
[ 7.333] () Option “xkb_model” “pc105”
[ 7.333] () Option “xkb_layout” “fr”
[ 7.333] () Option “xkb_variant” “latin9”
[ 7.334] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: is tagged by udev as: Keyboard
[ 7.334] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: device is a keyboard
[ 7.334] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device (/dev/input/event6)
[ 7.334] () ASUSTeK Computer Inc. N-KEY Device: Applying InputClass “libinput keyboard catchall”
[ 7.334] (II) Using input driver ‘libinput’ for ‘ASUSTeK Computer Inc. N-KEY Device’
[ 7.334] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 49 paused 0
[ 7.334] () ASUSTeK Computer Inc. N-KEY Device: always reports core events
[ 7.334] () Option “Device” “/dev/input/event6”
[ 7.334] () Option “_source” “server/udev”
[ 7.335] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: is tagged by udev as: Keyboard
[ 7.335] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: device is a keyboard
[ 7.335] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: device removed
[ 7.335] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.1/0003:0B05:1866.0005/input/input6/event6”
[ 7.335] (II) XINPUT: Adding extended input device “ASUSTeK Computer Inc. N-KEY Device” (type: KEYBOARD, id 13)
[ 7.335] () Option “xkb_model” “pc105”
[ 7.335] () Option “xkb_layout” “fr”
[ 7.335] () Option “xkb_variant” “latin9”
[ 7.335] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device (/dev/input/event10)
[ 7.335] (II) No input driver specified, ignoring this device.
[ 7.335] (II) This device may have been added with another device file.
[ 7.336] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device (/dev/input/event7)
[ 7.336] (II) No input driver specified, ignoring this device.
[ 7.336] (II) This device may have been added with another device file.
[ 7.336] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device Consumer Control (/dev/input/event8)
[ 7.336] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 7.336] (II) Using input driver ‘libinput’ for ‘ASUSTeK Computer Inc. N-KEY Device Consumer Control’
[ 7.336] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 50 paused 0
[ 7.336] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: always reports core events
[ 7.336] () Option “Device” “/dev/input/event8”
[ 7.336] () Option “_source” “server/udev”
[ 7.337] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: is tagged by udev as: Keyboard
[ 7.337] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: device is a keyboard
[ 7.337] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: device removed
[ 7.337] (II) libinput: ASUSTeK Computer Inc. N-KEY Device Consumer Control: needs a virtual subdevice
[ 7.337] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.2/0003:0B05:1866.0006/input/input8/event8”
[ 7.337] (II) XINPUT: Adding extended input device “ASUSTeK Computer Inc. N-KEY Device Consumer Control” (type: MOUSE, id 14)
[ 7.337] () Option “AccelerationScheme” “none”
[ 7.337] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: (accel) selected scheme none/0
[ 7.337] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: (accel) acceleration factor: 2.000
[ 7.337] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: (accel) acceleration threshold: 4
[ 7.337] (II) config/udev: Adding input device ASUSTeK Computer Inc. N-KEY Device (/dev/input/event9)
[ 7.337] (II) No input driver specified, ignoring this device.
[ 7.337] (II) This device may have been added with another device file.
[ 7.338] (II) config/udev: Adding input device Logitech K330 (/dev/input/event11)
[ 7.338] () Logitech K330: Applying InputClass “libinput keyboard catchall”
[ 7.338] (II) Using input driver ‘libinput’ for ‘Logitech K330’
[ 7.338] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 51 paused 0
[ 7.338] () Logitech K330: always reports core events
[ 7.338] () Option “Device” “/dev/input/event11”
[ 7.338] () Option “_source” “server/udev”
[ 7.339] (II) event11 - Logitech K330: is tagged by udev as: Keyboard
[ 7.339] (II) event11 - Logitech K330: device is a keyboard
[ 7.339] (II) event11 - Logitech K330: device removed
[ 7.339] (II) libinput: Logitech K330: needs a virtual subdevice
[ 7.339] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4016.0008/input/input15/event11”
[ 7.339] (II) XINPUT: Adding extended input device “Logitech K330” (type: MOUSE, id 15)
[ 7.339] () Option “AccelerationScheme” “none”
[ 7.339] () Logitech K330: (accel) selected scheme none/0
[ 7.339] () Logitech K330: (accel) acceleration factor: 2.000
[ 7.339] () Logitech K330: (accel) acceleration threshold: 4
[ 7.339] (II) config/udev: Adding input device Logitech M215 2nd Gen (/dev/input/event12)
[ 7.339] () Logitech M215 2nd Gen: Applying InputClass “libinput pointer catchall”
[ 7.339] (II) Using input driver ‘libinput’ for ‘Logitech M215 2nd Gen’
[ 7.340] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 52 paused 0
[ 7.340] () Logitech M215 2nd Gen: always reports core events
[ 7.340] () Option “Device” “/dev/input/event12”
[ 7.340] () Option “_source” “server/udev”
[ 7.340] (II) event12 - Logitech M215 2nd Gen: is tagged by udev as: Mouse
[ 7.340] (II) event12 - Logitech M215 2nd Gen: device is a pointer
[ 7.340] (II) event12 - Logitech M215 2nd Gen: device removed
[ 7.340] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:401B.0007/input/input16/event12”
[ 7.340] (II) XINPUT: Adding extended input device “Logitech M215 2nd Gen” (type: MOUSE, id 16)
[ 7.340] () Option “AccelerationScheme” “none”
[ 7.340] () Logitech M215 2nd Gen: (accel) selected scheme none/0
[ 7.340] () Logitech M215 2nd Gen: (accel) acceleration factor: 2.000
[ 7.340] () Logitech M215 2nd Gen: (accel) acceleration threshold: 4
[ 7.341] (II) config/udev: Adding input device Logitech M215 2nd Gen (/dev/input/mouse0)
[ 7.341] (II) No input driver specified, ignoring this device.
[ 7.341] (II) This device may have been added with another device file.
[ 7.341] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event14)
[ 7.341] () USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass “libinput keyboard catchall”
[ 7.341] (II) Using input driver ‘libinput’ for ‘USB2.0 HD UVC WebCam: USB2.0 HD’
[ 7.341] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 53 paused 0
[ 7.341] () USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events
[ 7.341] () Option “Device” “/dev/input/event14”
[ 7.341] () Option “_source” “server/udev”
[ 7.342] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 7.342] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 7.342] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[ 7.342] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input18/event14”
[ 7.342] (II) XINPUT: Adding extended input device “USB2.0 HD UVC WebCam: USB2.0 HD” (type: KEYBOARD, id 17)
[ 7.342] () Option “xkb_model” “pc105”
[ 7.342] () Option “xkb_layout” “fr”
[ 7.342] () Option “xkb_variant” “latin9”
[ 7.342] (II) config/udev: Adding input device ELAN1200:00 04F3:307A Touchpad (/dev/input/event18)
[ 7.342] () ELAN1200:00 04F3:307A Touchpad: Applying InputClass “libinput touchpad catchall”
[ 7.342] (II) Using input driver ‘libinput’ for ‘ELAN1200:00 04F3:307A Touchpad’
[ 7.343] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 54 paused 0
[ 7.343] () ELAN1200:00 04F3:307A Touchpad: always reports core events
[ 7.343] () Option “Device” “/dev/input/event18”
[ 7.343] () Option “_source” “server/udev”
[ 7.343] (II) event18 - ELAN1200:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
[ 7.343] (II) event18 - ELAN1200:00 04F3:307A Touchpad: device is a touchpad
[ 7.343] (II) event18 - ELAN1200:00 04F3:307A Touchpad: device removed
[ 7.343] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN1200:00/0018:04F3:307A.0009/input/input31/event18”
[ 7.344] (II) XINPUT: Adding extended input device “ELAN1200:00 04F3:307A Touchpad” (type: TOUCHPAD, id 18)
[ 7.344] () Option “AccelerationScheme” “none”
[ 7.344] () ELAN1200:00 04F3:307A Touchpad: (accel) selected scheme none/0
[ 7.344] () ELAN1200:00 04F3:307A Touchpad: (accel) acceleration factor: 2.000
[ 7.344] () ELAN1200:00 04F3:307A Touchpad: (accel) acceleration threshold: 4
[ 7.344] (II) event18 - ELAN1200:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
[ 7.344] (II) event18 - ELAN1200:00 04F3:307A Touchpad: device is a touchpad
[ 7.344] (II) config/udev: Adding input device ELAN1200:00 04F3:307A Touchpad (/dev/input/mouse1)
[ 7.344] (II) No input driver specified, ignoring this device.
[ 7.344] (II) This device may have been added with another device file.
[ 7.344] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event20)
[ 7.344] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event21)
[ 7.345] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event22)
[ 7.345] (II) No input driver specified, ignoring this device.
[ 7.345] (II) This device may have been added with another device file.
[ 7.345] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event23)
[ 7.345] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event24)
[ 7.345] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event25)
[ 7.345] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event15)
[ 7.345] () Asus WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 7.345] (II) Using input driver ‘libinput’ for ‘Asus WMI hotkeys’
[ 7.346] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 55 paused 0
[ 7.346] () Asus WMI hotkeys: always reports core events
[ 7.346] () Option “Device” “/dev/input/event15”
[ 7.346] () Option “_source” “server/udev”
[ 7.346] (II) event15 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 7.346] (II) event15 - Asus WMI hotkeys: device is a keyboard
[ 7.346] (II) event15 - Asus WMI hotkeys: device removed
[ 7.346] () Option “config_info” “udev:/sys/devices/platform/asus-nb-wmi/input/input19/event15”
[ 7.346] (II) XINPUT: Adding extended input device “Asus WMI hotkeys” (type: KEYBOARD, id 19)
[ 7.346] () Option “xkb_model” “pc105”
[ 7.346] () Option “xkb_layout” “fr”
[ 7.346] () Option “xkb_variant” “latin9”
[ 7.347] (II) event15 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 7.347] (II) event15 - Asus WMI hotkeys: device is a keyboard
[ 7.347] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 7.347] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 7.347] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 7.347] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 56 paused 0
[ 7.347] () AT Translated Set 2 keyboard: always reports core events
[ 7.347] () Option “Device” “/dev/input/event4”
[ 7.347] () Option “_source” “server/udev”
[ 7.347] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.347] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.347] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 7.347] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input4/event4”
[ 7.347] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 20)
[ 7.347] () Option “xkb_model” “pc105”
[ 7.347] () Option “xkb_layout” “fr”
[ 7.347] () Option “xkb_variant” “latin9”
[ 7.348] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.348] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.351] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 7.351] (II) Using input driver ‘libinput’ for ‘ASUSTeK Computer Inc. N-KEY Device Consumer Control’
[ 7.351] (II) systemd-logind: returning pre-existing fd for /dev/input/event8 13:72
[ 7.351] () ASUSTeK Computer Inc. N-KEY Device Consumer Control: always reports core events
[ 7.351] () Option “Device” “/dev/input/event8”
[ 7.351] () Option “_source” “_driver/libinput”
[ 7.351] (II) libinput: ASUSTeK Computer Inc. N-KEY Device Consumer Control: is a virtual subdevice
[ 7.351] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.2/0003:0B05:1866.0006/input/input8/event8”
[ 7.351] (II) XINPUT: Adding extended input device “ASUSTeK Computer Inc. N-KEY Device Consumer Control” (type: KEYBOARD, id 21)
[ 7.351] () Option “xkb_model” “pc105”
[ 7.351] () Option “xkb_layout” “fr”
[ 7.351] () Option “xkb_variant” “latin9”
[ 7.351] () Logitech K330: Applying InputClass “libinput keyboard catchall”
[ 7.351] (II) Using input driver ‘libinput’ for ‘Logitech K330’
[ 7.351] (II) systemd-logind: returning pre-existing fd for /dev/input/event11 13:75
[ 7.351] () Logitech K330: always reports core events
[ 7.351] () Option “Device” “/dev/input/event11”
[ 7.351] (II) libinput: Logitech K330: is a virtual subdevice
[ 7.351] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4016.0008/input/input15/event11”
[ 7.351] (II) XINPUT: Adding extended input device “Logitech K330” (type: KEYBOARD, id 22)
[ 7.366] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.366] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.366] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.366] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.366] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.366] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.366] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.366] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.366] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 7.370] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.370] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.370] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.370] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.370] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.370] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.370] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.370] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.370] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 7.376] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.376] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.376] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.376] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.376] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.376] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.376] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.376] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.376] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 7.745] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.745] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.745] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.745] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.745] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.745] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.745] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.745] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.745] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 94.580] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 94.580] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 94.580] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 94.590] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1920x1080 +0+0 {AllowGSYNC=Off, ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
[ 94.685] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 94.685] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 94.685] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 94.685] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 94.685] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 94.685] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 94.716] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 94.716] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 94.716] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 106.952] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 106.952] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 106.952] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 106.981] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 106.981] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 106.981] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 115.826] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 115.826] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 115.826] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 115.857] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 115.857] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 115.857] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 118.533] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 118.533] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 118.533] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 118.563] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 118.563] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 118.563] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 121.184] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 121.184] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 121.184] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 121.214] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 121.214] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 121.214] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 133.875] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 133.875] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 133.875] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 133.906] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 133.906] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 133.906] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 351.650] () Option “fd” “40”
[ 351.650] (II) event3 - Power Button: device removed
[ 351.651] () Option “fd” “43”
[ 351.651] (II) event13 - Asus Wireless Radio Control: device removed
[ 351.651] () Option “fd” “44”
[ 351.651] (II) event16 - Video Bus: device removed
[ 351.652] () Option “fd” “45”
[ 351.652] (II) event17 - Video Bus: device removed
[ 351.652] () Option “fd” “46”
[ 351.652] (II) event2 - Power Button: device removed
[ 351.652] () Option “fd” “47”
[ 351.652] (II) event1 - Sleep Button: device removed
[ 351.653] () Option “fd” “48”
[ 351.653] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: device removed
[ 351.653] () Option “fd” “49”
[ 351.653] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: device removed
[ 351.654] () Option “fd” “50”
[ 351.654] () Option “fd” “51”
[ 351.654] () Option “fd” “52”
[ 351.654] (II) event12 - Logitech M215 2nd Gen: device removed
[ 351.655] () Option “fd” “53”
[ 351.655] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[ 351.655] () Option “fd” “54”
[ 351.655] (II) event18 - ELAN1200:00 04F3:307A Touchpad: device removed
[ 351.656] () Option “fd” “55”
[ 351.656] (II) event15 - Asus WMI hotkeys: device removed
[ 351.656] () Option “fd” “56”
[ 351.656] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 351.656] () Option “fd” “50”
[ 351.656] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: device removed
[ 351.656] (**) Option “fd” “51”
[ 351.656] (II) event11 - Logitech K330: device removed
[ 351.980] (II) systemd-logind: got pause for 13:72
[ 351.980] (II) systemd-logind: got pause for 13:65
[ 351.980] (II) systemd-logind: got pause for 226:0
[ 351.980] (II) systemd-logind: got pause for 13:75
[ 351.980] (II) systemd-logind: got pause for 13:76
[ 351.980] (II) systemd-logind: got pause for 13:69
[ 351.980] (II) systemd-logind: got pause for 13:82
[ 351.980] (II) systemd-logind: got pause for 13:80
[ 351.980] (II) systemd-logind: got pause for 13:68
[ 351.980] (II) systemd-logind: got pause for 13:79
[ 351.980] (II) systemd-logind: got pause for 13:81
[ 351.980] (II) systemd-logind: got pause for 13:67
[ 351.980] (II) systemd-logind: got pause for 13:70
[ 351.980] (II) systemd-logind: got pause for 13:66
[ 351.980] (II) systemd-logind: got pause for 13:77
[ 351.981] (II) systemd-logind: got pause for 13:78
[ 557.146] (II) systemd-logind: got resume for 13:72
[ 557.163] (II) systemd-logind: got resume for 13:65
[ 557.163] (II) systemd-logind: got resume for 226:0
[ 557.163] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 557.163] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 557.163] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 557.374] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 557.374] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 557.374] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 557.434] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.434] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.434] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.449] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1920x1080 +0+0 {AllowGSYNC=Off, ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
[ 557.522] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 557.522] (II) event1 - Sleep Button: device is a keyboard
[ 557.522] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: is tagged by udev as: Keyboard
[ 557.522] (II) event8 - ASUSTeK Computer Inc. N-KEY Device Consumer Control: device is a keyboard
[ 557.523] (II) systemd-logind: got resume for 13:75
[ 557.523] (II) event11 - Logitech K330: is tagged by udev as: Keyboard
[ 557.523] (II) event11 - Logitech K330: device is a keyboard
[ 557.523] (II) systemd-logind: got resume for 13:76
[ 557.523] (II) event12 - Logitech M215 2nd Gen: is tagged by udev as: Mouse
[ 557.523] (II) event12 - Logitech M215 2nd Gen: device is a pointer
[ 557.524] (II) systemd-logind: got resume for 13:69
[ 557.524] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: is tagged by udev as: Keyboard
[ 557.524] (II) event5 - ASUSTeK Computer Inc. N-KEY Device: device is a keyboard
[ 557.524] (II) systemd-logind: got resume for 13:82
[ 557.524] (II) event18 - ELAN1200:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
[ 557.524] (II) event18 - ELAN1200:00 04F3:307A Touchpad: device is a touchpad
[ 557.560] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.560] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.560] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.591] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.591] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.591] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.621] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.621] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.621] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.652] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.652] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.652] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.682] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.682] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.682] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.713] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.713] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.713] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.743] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.743] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.743] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.774] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.774] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.774] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.804] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.804] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.804] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.834] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.834] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.834] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.865] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.865] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.865] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.895] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.895] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.895] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.925] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.925] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.925] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.956] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.956] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.956] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 557.987] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 557.987] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 557.987] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.017] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.017] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.017] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.048] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.048] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.048] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.077] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.077] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.077] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.078] (–) NVIDIA(GPU-0):
[ 558.108] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.108] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.108] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.138] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.138] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.138] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.170] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 558.170] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 558.170] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 558.170] (II) systemd-logind: got resume for 13:80
[ 558.170] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 558.170] (II) event16 - Video Bus: device is a keyboard
[ 558.171] (II) systemd-logind: got resume for 13:68
[ 558.171] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 558.171] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 558.171] (II) systemd-logind: got resume for 13:79
[ 558.171] (II) event15 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 558.171] (II) event15 - Asus WMI hotkeys: device is a keyboard
[ 558.171] (II) systemd-logind: got resume for 13:81
[ 558.172] (II) event17 - Video Bus: is tagged by udev as: Keyboard
[ 558.172] (II) event17 - Video Bus: device is a keyboard
[ 558.172] (II) systemd-logind: got resume for 13:67
[ 558.172] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 558.172] (II) event3 - Power Button: device is a keyboard
[ 558.172] (II) systemd-logind: got resume for 13:70
[ 558.172] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: is tagged by udev as: Keyboard
[ 558.172] (II) event6 - ASUSTeK Computer Inc. N-KEY Device: device is a keyboard
[ 558.172] (II) systemd-logind: got resume for 13:66
[ 558.173] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 558.173] (II) event2 - Power Button: device is a keyboard
[ 558.173] (II) systemd-logind: got resume for 13:77
[ 558.173] (II) event13 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 558.173] (II) event13 - Asus Wireless Radio Control: device is a keyboard
[ 558.173] (II) systemd-logind: got resume for 13:78
[ 558.173] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 558.173] (II) event14 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 596.214] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 596.214] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 596.214] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 596.425] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 596.426] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 596.426] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 596.457] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 596.457] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 596.458] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 836.167] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 836.167] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 836.167] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 836.379] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 836.379] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 836.379] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 836.409] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 836.409] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 836.409] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 1010.264] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1010.264] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1010.264] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 1010.476] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1010.476] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 1010.476] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 1010.505] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): connected
[ 1010.505] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): Internal TMDS
[ 1010.505] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-2): 600.0 MHz maximum pixel clock
[ 1010.507] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 1010.507] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 1010.507] (–) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 1010.719] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 1010.719] (–) NVIDIA(GPU-0): DFP-1: I
