Problems with NVIDIA RTX 6000 Ada Generation/Rocky Linux 9
I have a new Dell Precision 5820 with dual RTX 6000 Ada Generation GPUs in it. I’m having a problem on a graphical login not starting up. The issue doesn’t happen if you use a non-graphical login then run ‘startx’ to start the graphics system. I have also tried multiple monitors and replaced the DP cable. The physical configuration is that one of the RTX 6000s DP outputs is connected to a monitor.
Upon authenticated login, I get a black screen and see in the message log:
[Fri Nov 3 07:17:44 2023] nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
[Fri Nov 3 07:17:44 2023] nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device DELL P2723DE (DP-6).
[Fri Nov 3 07:17:44 2023] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DELL P2723DE (DP-6)
[Fri Nov 3 07:17:44 2023] nvidia-modeset: ERROR: GPU:0: Failure reading maximum pixel clock value for display device DP-6.
[Fri Nov 3 07:17:44 2023] nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device DP-6.
[Fri Nov 3 07:17:44 2023] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-6
I have the latest dev driver 545.29.02, here is the output from nvidia-smi:
Fri Nov 3 07:26:37 2023
| NVIDIA-SMI 545.29.02 Driver Version: 545.29.02 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX 6000 Ada Gene… Off | 00000000:17:00.0 Off | Off |
| 30% 56C P0 67W / 300W | 3MiB / 49140MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX 6000 Ada Gene… Off | 00000000:65:00.0 Off | Off |
| 30% 48C P0 59W / 300W | 3MiB / 49140MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
The Xorg.0.log has:
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[ 4.107] Build Operating System: 5.4.188-104.359.amzn2.x86_64
[ 4.107] Current Operating System: Linux localhost.localdomain 5.14.0-284.30.1.el9_2.x86_64 #1 SMP PREEMPT_DYNAMIC Sat Sep 16 09:55:41 UTC 2023 x86_64
[ 4.107] Kernel command line: BOOT_IMAGE=(hd2,gpt2)/vmlinuz-5.14.0-284.30.1.el9_2.x86_64 root=/dev/mapper/rl_bllab02-root ro crashkernel=1G-4G:192M,4G-64G:256M,64G-:512M resume=/dev/mapper/rl_bllab02-swap rd.lvm.lv=rl_bllab02/root rd.lvm.lv=rl_bllab02/swap rd.driver.blacklist=nouveau
[ 4.107] Build Date: 21 February 2023 12:00:00AM
[ 4.107] Build ID: xorg-x11-server 1.20.11-17.el9
[ 4.107] Current version of pixman: 0.40.0
[ 4.107] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 4.107] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4.107] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Nov 3 07:17:17 2023
[ 4.108] (==) Using config file: “/etc/X11/xorg.conf”
[ 4.108] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 4.108] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 4.109] (==) ServerLayout “Layout0”
[ 4.109] (
) |–>Screen “Screen0” (0)
[ 4.109] () | |–>Monitor “Monitor0”
[ 4.109] (
) | |–>Device “Device0”
[ 4.109] () |–>Input Device “Keyboard0”
[ 4.109] (
) |–>Input Device “Mouse0”
[ 4.109] (==) Automatically adding devices
[ 4.109] (==) Automatically enabling devices
[ 4.109] (==) Automatically adding GPU devices
[ 4.109] (==) Automatically binding GPU devices
[ 4.109] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.109] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 4.109] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 4.109] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 4.109] (WW) Disabling Keyboard0
[ 4.109] (WW) Disabling Mouse0
[ 4.109] (II) Loader magic: 0x55f9b4437d40
[ 4.109] (II) Module ABI versions:
[ 4.109] X.Org ANSI C Emulation: 0.4
[ 4.109] X.Org Video Driver: 24.1
[ 4.109] X.Org XInput driver : 24.1
[ 4.109] X.Org Server Extension : 10.0
[ 4.109] (++) using VT number 1
[ 4.110] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 4.110] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.110] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 4.111] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 4.111] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 4.115] () OutputClass “nvidia” setting /dev/dri/card0 as PrimaryGPU
[ 4.118] (–) PCI:*(23@0:0:0) 10de:26b1:1028:16a1 rev 161, Mem @ 0xb4000000/16777216, 0x380060000000/268435456, 0x380070000000/33554432, I/O @ 0x00007000/128, BIOS @ 0x???/524288
[ 4.118] (–) PCI: (101@0:0:0) 10de:26b1:1028:16a1 rev 161, Mem @ 0xd7000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x???/524288
[ 4.118] (II) LoadModule: “glx”
[ 4.119] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 4.123] (II) Module glx: vendor=“X.Org Foundation”
[ 4.123] compiled for 1.20.11, module version = 1.0.0
[ 4.123] ABI class: X.Org Server Extension, version 10.0
[ 4.123] (II) LoadModule: “nvidia”
[ 4.123] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 4.126] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 4.126] compiled for 1.6.99.901, module version = 1.0.0
[ 4.126] Module class: X.Org Video Driver
[ 4.126] (II) NVIDIA dlloader X Driver 545.29.02 Thu Oct 26 20:56:09 UTC 2023
[ 4.126] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 4.127] (II) systemd-logind: releasing fd for 226:0
[ 4.127] (II) Loading sub module “fb”
[ 4.127] (II) LoadModule: “fb”
[ 4.127] (II) Module “fb” already built-in
[ 4.127] (II) Loading sub module “wfb”
[ 4.127] (II) LoadModule: “wfb”
[ 4.127] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 4.128] (II) Module wfb: vendor=“X.Org Foundation”
[ 4.128] compiled for 1.20.11, module version = 1.0.0
[ 4.128] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.128] (II) systemd-logind: releasing fd for 226:1
[ 4.129] (
) NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 4.129] (==) NVIDIA(0): RGB weight 888
[ 4.129] (==) NVIDIA(0): Default visual is TrueColor
[ 4.129] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.129] (II) Applying OutputClass “nvidia” options to /dev/dri/card0
[ 4.129] () NVIDIA(0): Option “SLI” “Auto”
[ 4.129] (
) NVIDIA(0): Option “BaseMosaic” “on”
[ 4.129] () NVIDIA(0): Option “AllowEmptyInitialConfiguration”
[ 4.129] (WW) NVIDIA(0): Invalid SLI option: ‘Auto’; using single GPU rendering.
[ 4.129] (
) NVIDIA(0): Enabling 2D acceleration
[ 4.129] (II) Loading sub module “glxserver_nvidia”
[ 4.129] (II) LoadModule: “glxserver_nvidia”
[ 4.129] (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[ 4.172] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 4.172] compiled for 1.6.99.901, module version = 1.0.0
[ 4.172] Module class: X.Org Server Extension
[ 4.172] (II) NVIDIA GLX Module 545.29.02 Thu Oct 26 20:59:27 UTC 2023
[ 4.172] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 7.079] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:23:0:0 bound to this Base
[ 7.079] (EE) NVIDIA(GPU-0): Mosaic X screen is not the Base Mosaic parent device.
[ 7.079] (EE) NVIDIA(GPU-0): This configuration is not currently supported. Please add
[ 7.079] (EE) NVIDIA(GPU-0): ‘BusID “PCI:101:0:0”’ to the Base Mosaic “Device” section
[ 7.079] (EE) NVIDIA(GPU-0): in the X configuration file.
[ 8.505] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[ 9.983] (–) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:101:0:0
[ 9.983] (–) NVIDIA(0): DFP-0
[ 9.983] (–) NVIDIA(0): DFP-1
[ 9.983] (–) NVIDIA(0): DFP-2
[ 9.983] (–) NVIDIA(0): DFP-3
[ 9.983] (–) NVIDIA(0): DFP-4
[ 9.983] (–) NVIDIA(0): DFP-5
[ 9.983] (–) NVIDIA(0): DFP-6 (boot)
[ 9.983] (–) NVIDIA(0): DFP-7
[ 9.983] (II) NVIDIA(0): NVIDIA GPU NVIDIA RTX 6000 Ada Generation (AD102GL-A) at
[ 9.983] (II) NVIDIA(0): PCI:101:0:0 (GPU-1)
[ 9.983] (–) NVIDIA(0): Memory: 50319360 kBytes
[ 9.983] (–) NVIDIA(0): VideoBIOS: 95.02.3a.00.08
[ 9.983] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 9.983] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 9.984] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 9.984] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 9.984] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 9.984] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 9.984] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 9.984] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 9.984] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 9.984] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): connected
[ 9.984] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): Internal DisplayPort
[ 9.984] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): 2670.0 MHz maximum pixel clock
[ 9.987] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 9.987] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 9.987] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 10.032] (==) NVIDIA(0):
[ 10.032] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 10.032] (==) NVIDIA(0): will be used as the requested mode.
[ 10.032] (II) NVIDIA(0): Validated MetaModes:
[ 10.032] (II) NVIDIA(0): “DFP-6:nvidia-auto-select”
[ 10.032] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[ 10.085] (–) NVIDIA(0): DPI set to (108, 107); computed from “UseEdidDpi” X config
[ 10.085] (–) NVIDIA(0): option
[ 10.085] (II) NVIDIA(G0): NVIDIA RTX 6000 Ada Generation (GPU-1) already has an X screen
[ 10.085] (II) NVIDIA(G0): assigned; skipping this GPU screen
[ 10.085] (EE) NVIDIA(G0): Failing initialization of X screen
[ 10.085] (II) UnloadModule: “nvidia”
[ 10.085] (II) UnloadSubModule: “wfb”
[ 10.085] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 10.085] (II) NVIDIA: access.
[ 10.087] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 10.087] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 10.087] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 10.087] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 10.087] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 10.087] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 10.087] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 10.087] (II) NVIDIA(0): Config Options in the README.
[ 10.101] (II) NVIDIA(0): Setting mode “DFP-6:nvidia-auto-select”
[ 10.224] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 10.224] (==) NVIDIA(0): Backing store enabled
[ 10.224] (==) NVIDIA(0): Silken mouse enabled
[ 10.225] () NVIDIA(0): DPMS enabled
[ 10.225] (WW) NVIDIA(0): Option “PrimaryGPU” is not used
[ 10.225] (II) Loading sub module “dri2”
[ 10.225] (II) LoadModule: “dri2”
[ 10.225] (II) Module “dri2” already built-in
[ 10.225] (II) NVIDIA(0): [DRI2] Setup complete
[ 10.225] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 10.225] (II) Initializing extension Generic Event Extension
[ 10.226] (II) Initializing extension SHAPE
[ 10.226] (II) Initializing extension MIT-SHM
[ 10.226] (II) Initializing extension XInputExtension
[ 10.226] (II) Initializing extension XTEST
[ 10.226] (II) Initializing extension BIG-REQUESTS
[ 10.226] (II) Initializing extension SYNC
[ 10.226] (II) Initializing extension XKEYBOARD
[ 10.226] (II) Initializing extension XC-MISC
[ 10.226] (II) Initializing extension SECURITY
[ 10.226] (II) Initializing extension XFIXES
[ 10.226] (II) Initializing extension RENDER
[ 10.227] (II) Initializing extension RANDR
[ 10.227] (II) Initializing extension COMPOSITE
[ 10.227] (II) Initializing extension DAMAGE
[ 10.227] (II) Initializing extension MIT-SCREEN-SAVER
[ 10.227] (II) Initializing extension DOUBLE-BUFFER
[ 10.227] (II) Initializing extension RECORD
[ 10.227] (II) Initializing extension DPMS
[ 10.227] (II) Initializing extension Present
[ 10.227] (II) Initializing extension DRI3
[ 10.227] (II) Initializing extension X-Resource
[ 10.227] (II) Initializing extension XVideo
[ 10.227] (II) Initializing extension XVideo-MotionCompensation
[ 10.227] (II) Initializing extension SELinux
[ 10.227] (II) SELinux: Disabled on system
[ 10.227] (II) Initializing extension GLX
[ 10.228] (II) Initializing extension GLX
[ 10.228] (II) Indirect GLX disabled.
[ 10.228] (II) GLX: Another vendor is already registered for screen 0
[ 10.228] (II) Initializing extension XFree86-VidModeExtension
[ 10.228] (II) Initializing extension XFree86-DGA
[ 10.228] (II) Initializing extension DRI2
[ 10.228] (II) Initializing extension NV-GLX
[ 10.228] (II) Initializing extension NV-CONTROL
[ 10.228] (II) Initializing extension XINERAMA
[ 10.279] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 10.279] (
) Power Button: Applying InputClass “libinput keyboard catchall”
[ 10.279] () Power Button: Applying InputClass “system-keyboard”
[ 10.279] (II) LoadModule: “libinput”
[ 10.279] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 10.281] (II) Module libinput: vendor=“X.Org Foundation”
[ 10.281] compiled for 1.20.11, module version = 1.0.1
[ 10.281] Module class: X.Org XInput Driver
[ 10.281] ABI class: X.Org XInput driver, version 24.1
[ 10.281] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 10.282] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 39 paused 0
[ 10.282] (
) Power Button: always reports core events
[ 10.282] () Option “Device” “/dev/input/event1”
[ 10.282] (
) Option “_source” “server/udev”
[ 10.284] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 10.285] (II) event1 - Power Button: device is a keyboard
[ 10.285] (II) event1 - Power Button: device removed
[ 10.285] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 10.285] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 10.285] (
) Option “xkb_layout” “us”
[ 10.285] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 10.285] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 10.285] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 10.285] (
) Sleep Button: Applying InputClass “system-keyboard”
[ 10.285] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 10.286] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 42 paused 0
[ 10.286] () Sleep Button: always reports core events
[ 10.286] (
) Option “Device” “/dev/input/event0”
[ 10.286] () Option “_source” “server/udev”
[ 10.286] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 10.286] (II) event0 - Sleep Button: device is a keyboard
[ 10.287] (II) event0 - Sleep Button: device removed
[ 10.287] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0”
[ 10.287] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 7)
[ 10.287] () Option “xkb_layout” “us”
[ 10.287] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 10.287] (II) event0 - Sleep Button: device is a keyboard
[ 10.287] (II) config/udev: Adding input device CASUE CASUE USB Keyboard (/dev/input/event3)
[ 10.287] (
) CASUE CASUE USB Keyboard: Applying InputClass “libinput keyboard catchall”
[ 10.287] () CASUE CASUE USB Keyboard: Applying InputClass “system-keyboard”
[ 10.287] (II) Using input driver ‘libinput’ for ‘CASUE CASUE USB Keyboard’
[ 10.288] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 43 paused 0
[ 10.288] (
) CASUE CASUE USB Keyboard: always reports core events
[ 10.288] () Option “Device” “/dev/input/event3”
[ 10.288] (
[ 10.289] (II) event3 - CASUE CASUE USB Keyboard: is tagged by udev as: Keyboard
[ 10.289] (II) event3 - CASUE CASUE USB Keyboard: device is a keyboard
[ 10.289] (II) event3 - CASUE CASUE USB Keyboard: device removed
[ 10.289] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:2A7A:6A18.0001/input/input3/event3”
[ 10.289] (II) XINPUT: Adding extended input device “CASUE CASUE USB Keyboard” (type: KEYBOARD, id 8)
[ 10.289] (
[ 10.290] (II) event3 - CASUE CASUE USB Keyboard: is tagged by udev as: Keyboard
[ 10.290] (II) event3 - CASUE CASUE USB Keyboard: device is a keyboard
[ 10.290] (II) config/udev: Adding input device CASUE CASUE USB Keyboard Consumer Control (/dev/input/event4)
[ 10.290] () CASUE CASUE USB Keyboard Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 10.290] (
) CASUE CASUE USB Keyboard Consumer Control: Applying InputClass “system-keyboard”
[ 10.290] (II) Using input driver ‘libinput’ for ‘CASUE CASUE USB Keyboard Consumer Control’
[ 10.291] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
[ 10.291] () CASUE CASUE USB Keyboard Consumer Control: always reports core events
[ 10.291] (
) Option “Device” “/dev/input/event4”
[ 10.291] () Option “_source” “server/udev”
[ 10.292] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 10.292] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: device is a keyboard
[ 10.292] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: device removed
[ 10.292] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:2A7A:6A18.0002/input/input4/event4”
[ 10.292] (II) XINPUT: Adding extended input device “CASUE CASUE USB Keyboard Consumer Control” (type: KEYBOARD, id 9)
[ 10.292] () Option “xkb_layout” “us”
[ 10.293] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 10.293] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: device is a keyboard
[ 10.293] (II) config/udev: Adding input device CASUE CASUE USB Keyboard System Control (/dev/input/event5)
[ 10.293] (
) CASUE CASUE USB Keyboard System Control: Applying InputClass “libinput keyboard catchall”
[ 10.293] () CASUE CASUE USB Keyboard System Control: Applying InputClass “system-keyboard”
[ 10.293] (II) Using input driver ‘libinput’ for ‘CASUE CASUE USB Keyboard System Control’
[ 10.294] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 45 paused 0
[ 10.294] (
) CASUE CASUE USB Keyboard System Control: always reports core events
[ 10.294] () Option “Device” “/dev/input/event5”
[ 10.294] (
[ 10.295] (II) event5 - CASUE CASUE USB Keyboard System Control: is tagged by udev as: Keyboard
[ 10.295] (II) event5 - CASUE CASUE USB Keyboard System Control: device is a keyboard
[ 10.295] (II) event5 - CASUE CASUE USB Keyboard System Control: device removed
[ 10.295] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:2A7A:6A18.0002/input/input5/event5”
[ 10.295] (II) XINPUT: Adding extended input device “CASUE CASUE USB Keyboard System Control” (type: KEYBOARD, id 10)
[ 10.295] (
[ 10.296] (II) event5 - CASUE CASUE USB Keyboard System Control: is tagged by udev as: Keyboard
[ 10.296] (II) event5 - CASUE CASUE USB Keyboard System Control: device is a keyboard
[ 10.296] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/event6)
[ 10.296] () PixArt Lenovo USB Optical Mouse: Applying InputClass “libinput pointer catchall”
[ 10.296] (II) Using input driver ‘libinput’ for ‘PixArt Lenovo USB Optical Mouse’
[ 10.297] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 46 paused 0
[ 10.297] (
) PixArt Lenovo USB Optical Mouse: always reports core events
[ 10.297] () Option “Device” “/dev/input/event6”
[ 10.297] (
[ 10.298] (II) event6 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 10.298] (II) event6 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 10.298] (II) event6 - PixArt Lenovo USB Optical Mouse: device removed
[ 10.298] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:17EF:608D.0003/input/input6/event6”
[ 10.298] (II) XINPUT: Adding extended input device “PixArt Lenovo USB Optical Mouse” (type: MOUSE, id 11)
[ 10.298] (
) Option “AccelerationScheme” “none”
[ 10.298] () PixArt Lenovo USB Optical Mouse: (accel) selected scheme none/0
[ 10.298] (
) PixArt Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
[ 10.298] () PixArt Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
[ 10.299] (II) event6 - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[ 10.299] (II) event6 - PixArt Lenovo USB Optical Mouse: device is a pointer
[ 10.299] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/mouse0)
[ 10.299] (II) No input driver specified, ignoring this device.
[ 10.299] (II) This device may have been added with another device file.
[ 10.299] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
[ 10.300] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event18)
[ 10.300] (II) No input driver specified, ignoring this device.
[ 10.300] (II) This device may have been added with another device file.
[ 10.300] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event19)
[ 10.300] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 10.300] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 10.300] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 10.300] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[ 10.301] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 10.301] (II) No input driver specified, ignoring this device.
[ 10.301] (II) This device may have been added with another device file.
[ 10.301] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 10.301] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 10.301] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 10.301] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 10.302] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 10.302] (
) Dell WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 10.302] () Dell WMI hotkeys: Applying InputClass “system-keyboard”
[ 10.302] (II) Using input driver ‘libinput’ for ‘Dell WMI hotkeys’
[ 10.303] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 47 paused 0
[ 10.303] (
) Dell WMI hotkeys: always reports core events
[ 10.303] () Option “Device” “/dev/input/event8”
[ 10.303] (
[ 10.303] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 10.303] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 10.303] (II) event8 - Dell WMI hotkeys: device removed
[ 10.303] () Option “config_info” “udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input8/event8”
[ 10.303] (II) XINPUT: Adding extended input device “Dell WMI hotkeys” (type: KEYBOARD, id 12)
[ 10.303] (
[ 10.304] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 10.304] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 10.304] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 10.304] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 10.304] (
) AT Translated Set 2 keyboard: Applying InputClass “system-keyboard”
[ 10.304] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 10.305] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 48 paused 0
[ 10.305] () AT Translated Set 2 keyboard: always reports core events
[ 10.305] (
) Option “Device” “/dev/input/event2”
[ 10.305] () Option “_source” “server/udev”
[ 10.305] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.305] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.306] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 10.306] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input2/event2”
[ 10.306] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 13)
[ 10.306] () Option “xkb_layout” “us”
[ 10.306] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.306] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.307] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 10.307] (II) No input driver specified, ignoring this device.
[ 10.307] (II) This device may have been added with another device file.
[ 10.676] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 10.676] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 10.676] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 10.676] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 10.676] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 10.676] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 10.676] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 10.676] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 10.676] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 10.676] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 10.676] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 10.676] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 10.676] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 10.677] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): connected
[ 10.677] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): Internal DisplayPort
[ 10.677] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): 2670.0 MHz maximum pixel clock
[ 10.679] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 10.679] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 10.679] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 10.739] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 10.739] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 10.739] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 10.739] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 10.739] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 10.739] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 10.739] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 10.739] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 10.740] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): connected
[ 10.740] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): Internal DisplayPort
[ 10.740] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): 2670.0 MHz maximum pixel clock
[ 10.742] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 10.742] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 10.743] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 11.482] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 11.482] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 11.482] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 11.482] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 11.482] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 11.482] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 11.482] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 11.482] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 11.483] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): connected
[ 11.483] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): Internal DisplayPort
[ 11.483] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): 2670.0 MHz maximum pixel clock
[ 11.485] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 11.485] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 11.485] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 12.485] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 12.485] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 12.485] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 12.485] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 12.485] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 12.485] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 12.485] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 12.485] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 12.486] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): connected
[ 12.486] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): Internal DisplayPort
[ 12.486] (–) NVIDIA(GPU-1): DELL P2723DE (DFP-6): 2670.0 MHz maximum pixel clock
[ 12.487] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 12.487] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 12.487] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 28.262] (
) Option “fd” “39”
[ 28.262] (II) event1 - Power Button: device removed
[ 28.262] () Option “fd” “42”
[ 28.262] (II) event0 - Sleep Button: device removed
[ 28.263] (
) Option “fd” “43”
[ 28.263] (II) event3 - CASUE CASUE USB Keyboard: device removed
[ 28.263] () Option “fd” “44”
[ 28.263] (II) event4 - CASUE CASUE USB Keyboard Consumer Control: device removed
[ 28.263] (
) Option “fd” “45”
[ 28.263] (II) event5 - CASUE CASUE USB Keyboard System Control: device removed
[ 28.263] () Option “fd” “46”
[ 28.263] (II) event6 - PixArt Lenovo USB Optical Mouse: device removed
[ 28.263] (
) Option “fd” “47”
[ 28.263] (II) event8 - Dell WMI hotkeys: device removed
[ 28.263] (**) Option “fd” “48”
[ 28.263] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 28.426] (II) systemd-logind: got pause for 13:66
[ 28.426] (II) systemd-logind: got pause for 13:65
[ 28.426] (II) systemd-logind: got pause for 13:64
[ 28.426] (II) systemd-logind: got pause for 13:67
[ 28.426] (II) systemd-logind: got pause for 13:69
[ 28.426] (II) systemd-logind: got pause for 13:68
[ 28.426] (II) systemd-logind: got pause for 13:70
[ 28.426] (II) systemd-logind: got pause for 13:72
[ 31.381] (II) systemd-logind: got resume for 13:66
[ 31.381] (WW) NVIDIA(GPU-1): Failed to enter interactive mode.
[ 31.381] (–) NVIDIA(GPU-1): DFP-0: disconnected
[ 31.381] (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 31.381] (–) NVIDIA(GPU-1): DFP-0: 2670.0 MHz maximum pixel clock
[ 31.382] (–) NVIDIA(GPU-1): DFP-1: disconnected
[ 31.382] (–) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 31.382] (–) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 31.382] (–) NVIDIA(GPU-1): DFP-2: disconnected
[ 31.382] (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 31.382] (–) NVIDIA(GPU-1): DFP-2: 2670.0 MHz maximum pixel clock
[ 31.382] (–) NVIDIA(GPU-1): DFP-3: disconnected
[ 31.382] (–) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 31.382] (–) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 31.382] (–) NVIDIA(GPU-1): DFP-4: disconnected
[ 31.382] (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 31.382] (–) NVIDIA(GPU-1): DFP-4: 2670.0 MHz maximum pixel clock
[ 31.382] (–) NVIDIA(GPU-1): DFP-5: disconnected
[ 31.382] (–) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 31.382] (–) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 31.394] (EE) NVIDIA(GPU-1): Unable to add conservative default mode “nvidia-auto-select”.
[ 31.394] (EE) NVIDIA(GPU-1): Unable to add “nvidia-auto-select” mode to ModePool.
[ 31.394] (–) NVIDIA(GPU-1): DFP-6: connected
[ 31.394] (–) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 31.394] (–) NVIDIA(GPU-1): DFP-6: 100.0 MHz maximum pixel clock
[ 31.394] (–) NVIDIA(GPU-1): DFP-7: disconnected
[ 31.394] (–) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 31.394] (–) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 31.394] (EE) NVIDIA(GPU-0): Failed to query object info.
[ 31.410] (EE) NVIDIA(GPU-0): Failed to query object info.
Once you login through the graphical login, the system is effectively hung. I tried to switch runlevels back to a multi-user target and kill the gdm daemon, which give this in the message logs :
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c77d:0:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:1:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:3:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:5:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:7:0:0x00000023
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to unmap memory
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to free DMA memory
[Fri Nov 3 07:26:18 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Here is my xorg.conf which is generated at the installation of the nvidia drivers and seems quite generic:
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 545.29.02
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "auto"
Option         "Device" "/dev/input/mice"
Option         "Emulate3Buttons" "no"
Option         "ZAxisMapping" "4 5"
EndSection
Identifier     "Keyboard0"
Driver         "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
I have made sure nouveau is blacklisted in the kernel. Anyone have an idea as to how to resolve this issue?
Thanks in Advance,
Jeff
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
I have attached the output from the bug report.
Jeff
nvidia-bug-report.log.gz (1.8 MB)
Please delete both
/etc/X11/xorg.conf.d/10-nvidia.conf
/etc/X11/xorg.conf
and connect the monitor to the other RTX.
Reboot and create a new nvidia-bug-report.log if running into issues.
There was one report that I found from the nvidia troubleshooting website that had to do with setting the acpi_osi variable to ‘Windows’ in a report with the same error message (but different situation):
https://wiki.archlinux.org/title/NVIDIA/Troubleshooting
I decided to try this and it worked now for graphical login on the first GPU. This required adding some kernel parameters to the boot line.
I then reset the kernel parameters with the acpi_osi settings and then rebooted. I could not get any output on the second GPU until I set the Dell BIOS video configuration to use the second video card. The BIOS Video was set to ‘Auto’.
After I did that, logins on the second card worked fine (wo specifying the acpi_osi to windows).
I’m attaching the nvidia-bug-report output maybe you can make some sense out of this. Fortunately, its working I just have no idea why…
nvidia-bug-report.log.gz (681.8 KB)
Jeff
/etc/X11/xorg.conf.d/10-nvidia.conf was setting some contradicting options so I guess the driver was confused. Looks fine now.
