Hi all!
I have installed the last linux driver 410.73 at this time and I am having problems, I can’t get the laptop display on main screen. Display on HDMI port works perfectly!
I have two graphic cards on this laptop :
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b
01:00.0 3D controller: NVIDIA Corporation Device 1c8c (rev a1)
Here is the content of my /usr/share/X11/xorg.conf.d/20-nvidia.conf :
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “Nvidia Corporation”
Option “ConnectedMonitor” “DFP-0”
BusID “PCI:1:0:0”
EndSection
And the content of /usr/share/X11/xorg.conf.d/10-monitor.conf
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/psaux”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
I have also blacklisted the i915 module.
Here is the content of the Xorg.0.log :
[ 5.415] (–) Log file renamed from “/var/log/Xorg.pid-883.log” to “/var/log/Xorg.0.log”
[ 5.416]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[ 5.416] X Protocol Version 11, Revision 0
[ 5.416] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[ 5.416] Current Operating System: Linux dell-g3 4.18.0-0.bpo.1-amd64 #1 SMP Debian 4.18.6-1~bpo9+1 (2018-09-13) x86_64
[ 5.416] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.18.0-0.bpo.1-amd64 root=UUID=b4601364-8b93-4df2-a059-3bcd5c1d2ff6 ro quiet
[ 5.416] Build Date: 03 November 2018 03:09:11AM
[ 5.416] xorg-server 2:1.19.2-1+deb9u5 (Debian -- User Support)
[ 5.416] Current version of pixman: 0.34.0
[ 5.416] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 5.416] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 5.416] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 13 10:07:02 2018
[ 5.419] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 5.421] (==) ServerLayout “Layout0”
[ 5.421] () |–>Screen “Screen0” (0)
[ 5.421] () | |–>Monitor “Monitor0”
[ 5.421] () | |–>Device “Device0”
[ 5.421] () |–>Input Device “Keyboard0”
[ 5.421] () |–>Input Device “Mouse0”
[ 5.421] (==) Automatically adding devices
[ 5.421] (==) Automatically enabling devices
[ 5.421] (==) Automatically adding GPU devices
[ 5.421] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.424] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 5.424] Entry deleted from font path.
[ 5.429] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 5.429] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 5.429] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 5.429] (WW) Disabling Keyboard0
[ 5.429] (WW) Disabling Mouse0
[ 5.429] (II) Loader magic: 0x55985218ae00
[ 5.429] (II) Module ABI versions:
[ 5.429] X.Org ANSI C Emulation: 0.4
[ 5.429] X.Org Video Driver: 23.0
[ 5.429] X.Org XInput driver : 24.1
[ 5.429] X.Org Server Extension : 10.0
[ 5.431] (++) using VT number 1
[ 5.435] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 5.437] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 5.438] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 5.438] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.439] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 5.443] (–) PCI:*(0:0:2:0) 8086:3e9b:1028:086f rev 0, Mem @ 0xa2000000/16777216, 0x80000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x???/131072
[ 5.443] (–) PCI: (0:1:0:0) 10de:1c8c:1028:086f rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/524288
[ 5.443] (II) LoadModule: “glx”
[ 5.444] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.446] (II) Module glx: vendor=“X.Org Foundation”
[ 5.446] compiled for 1.19.2, module version = 1.0.0
[ 5.447] ABI class: X.Org Server Extension, version 10.0
[ 5.447] (II) LoadModule: “nvidia”
[ 5.447] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 5.450] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 5.450] compiled for 4.0.2, module version = 1.0.0
[ 5.450] Module class: X.Org Video Driver
[ 5.450] (II) NVIDIA dlloader X Driver 410.73 Sat Oct 20 22:19:41 CDT 2018
[ 5.450] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5.451] (II) systemd-logind: releasing fd for 226:1
[ 5.452] (II) Loading sub module “fb”
[ 5.452] (II) LoadModule: “fb”
[ 5.452] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 5.453] (II) Module fb: vendor=“X.Org Foundation”
[ 5.453] compiled for 1.19.2, module version = 1.0.0
[ 5.453] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.453] (II) Loading sub module “wfb”
[ 5.453] (II) LoadModule: “wfb”
[ 5.453] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5.454] (II) Module wfb: vendor=“X.Org Foundation”
[ 5.454] compiled for 1.19.2, module version = 1.0.0
[ 5.454] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.454] (II) Loading sub module “ramdac”
[ 5.454] (II) LoadModule: “ramdac”
[ 5.454] (II) Module “ramdac” already built-in
[ 5.455] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 5.455] (==) NVIDIA(0): RGB weight 888
[ 5.455] (==) NVIDIA(0): Default visual is TrueColor
[ 5.455] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.455] () NVIDIA(0): Option “ConnectedMonitor” “DFP-0”
[ 5.455] () NVIDIA(0): Enabling 2D acceleration
[ 5.455] () NVIDIA(0): ConnectedMonitor string: “DFP-0”
[ 5.455] (II) Loading sub module “glxserver_nvidia”
[ 5.455] (II) LoadModule: “glxserver_nvidia”
[ 5.456] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 5.478] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 5.478] compiled for 4.0.2, module version = 1.0.0
[ 5.478] Module class: X.Org Server Extension
[ 5.478] (II) NVIDIA GLX Module 410.73 Sat Oct 20 22:16:49 CDT 2018
[ 5.718] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 5.718] (–) NVIDIA(0): DFP-0 (boot)
[ 5.718] () NVIDIA(0): Using ConnectedMonitor string “DFP-0”.
[ 5.720] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:1:0:0 (GPU-0)
[ 5.720] (–) NVIDIA(0): Memory: 4194304 kBytes
[ 5.720] (–) NVIDIA(0): VideoBIOS: 86.07.4b.00.1b
[ 5.720] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 5.749] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): connected
[ 5.749] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): Internal TMDS
[ 5.749] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): 600.0 MHz maximum pixel clock
[ 5.753] (==) NVIDIA(0):
[ 5.753] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 5.753] (==) NVIDIA(0): will be used as the requested mode.
[ 5.753] (II) NVIDIA(0): Validated MetaModes:
[ 5.753] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 5.753] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 5.758] (–) NVIDIA(0): DPI set to (92, 91); computed from “UseEdidDpi” X config
[ 5.758] (–) NVIDIA(0): option
[ 5.758] (–) Depth 24 pixmap format is 32 bpp
[ 5.758] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 5.758] (II) NVIDIA: access.
[ 5.777] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 5.804] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 5.804] (==) NVIDIA(0): Backing store enabled
[ 5.804] (==) NVIDIA(0): Silken mouse enabled
[ 5.805] () NVIDIA(0): DPMS enabled
[ 5.805] (II) Loading sub module “dri2”
[ 5.805] (II) LoadModule: “dri2”
[ 5.805] (II) Module “dri2” already built-in
[ 5.805] (II) NVIDIA(0): [DRI2] Setup complete
[ 5.805] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 5.805] (–) RandR disabled
[ 5.807] (II) SELinux: Disabled on system
[ 5.808] (II) Initializing extension GLX
[ 5.808] (II) Indirect GLX disabled.
[ 5.846] (II) config/udev: Adding input device Power Button (/dev/input/event9)
[ 5.846] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 5.846] (II) LoadModule: “libinput”
[ 5.846] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 5.847] (II) Module libinput: vendor=“X.Org Foundation”
[ 5.847] compiled for 1.19.0, module version = 0.23.0
[ 5.847] Module class: X.Org XInput Driver
[ 5.847] ABI class: X.Org XInput driver, version 24.1
[ 5.847] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 5.848] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 40 paused 0
[ 5.848] () Power Button: always reports core events
[ 5.848] () Option “Device” “/dev/input/event9”
[ 5.848] () Option “_source” “server/udev”
[ 5.848] (II) input device ‘Power Button’, /dev/input/event9 is tagged by udev as: Keyboard
[ 5.848] (II) input device ‘Power Button’, /dev/input/event9 is a keyboard
[ 5.848] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input14/event9”
[ 5.848] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 5.848] () Option “xkb_model” “pc105”
[ 5.848] () Option “xkb_layout” “us”
[ 5.849] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[ 5.849] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 5.849] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 5.849] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 43 paused 0
[ 5.849] () Video Bus: always reports core events
[ 5.849] () Option “Device” “/dev/input/event14”
[ 5.849] () Option “_source” “server/udev”
[ 5.849] (II) input device ‘Video Bus’, /dev/input/event14 is tagged by udev as: Keyboard
[ 5.849] (II) input device ‘Video Bus’, /dev/input/event14 is a keyboard
[ 5.849] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input19/event14”
[ 5.849] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 5.849] () Option “xkb_model” “pc105”
[ 5.849] () Option “xkb_layout” “us”
[ 5.850] (II) input device ‘Video Bus’, /dev/input/event14 is tagged by udev as: Keyboard
[ 5.850] (II) input device ‘Video Bus’, /dev/input/event14 is a keyboard
[ 5.850] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 5.850] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 5.850] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 5.850] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 44 paused 0
[ 5.850] () Video Bus: always reports core events
[ 5.850] () Option “Device” “/dev/input/event15”
[ 5.850] () Option “_source” “server/udev”
[ 5.850] (II) input device ‘Video Bus’, /dev/input/event15 is tagged by udev as: Keyboard
[ 5.850] (II) input device ‘Video Bus’, /dev/input/event15 is a keyboard
[ 5.850] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input20/event15”
[ 5.850] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 5.850] () Option “xkb_model” “pc105”
[ 5.850] () Option “xkb_layout” “us”
[ 5.851] (II) input device ‘Video Bus’, /dev/input/event15 is tagged by udev as: Keyboard
[ 5.851] (II) input device ‘Video Bus’, /dev/input/event15 is a keyboard
[ 5.851] (II) config/udev: Adding input device Power Button (/dev/input/event7)
[ 5.851] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 5.851] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 5.851] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[ 5.851] () Power Button: always reports core events
[ 5.851] () Option “Device” “/dev/input/event7”
[ 5.851] () Option “_source” “server/udev”
[ 5.851] (II) input device ‘Power Button’, /dev/input/event7 is tagged by udev as: Keyboard
[ 5.851] (II) input device ‘Power Button’, /dev/input/event7 is a keyboard
[ 5.852] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input12/event7”
[ 5.852] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 9)
[ 5.852] () Option “xkb_model” “pc105”
[ 5.852] () Option “xkb_layout” “us”
[ 5.852] (II) input device ‘Power Button’, /dev/input/event7 is tagged by udev as: Keyboard
[ 5.852] (II) input device ‘Power Button’, /dev/input/event7 is a keyboard
[ 5.852] (II) config/udev: Adding input device Lid Switch (/dev/input/event6)
[ 5.852] (II) No input driver specified, ignoring this device.
[ 5.852] (II) This device may have been added with another device file.
[ 5.852] (II) config/udev: Adding input device Sleep Button (/dev/input/event8)
[ 5.852] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 5.852] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 5.853] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 46 paused 0
[ 5.853] () Sleep Button: always reports core events
[ 5.853] () Option “Device” “/dev/input/event8”
[ 5.853] () Option “_source” “server/udev”
[ 5.853] (II) input device ‘Sleep Button’, /dev/input/event8 is tagged by udev as: Keyboard
[ 5.853] (II) input device ‘Sleep Button’, /dev/input/event8 is a keyboard
[ 5.853] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input13/event8”
[ 5.853] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 10)
[ 5.853] () Option “xkb_model” “pc105”
[ 5.853] () Option “xkb_layout” “us”
[ 5.853] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event18)
[ 5.853] (II) No input driver specified, ignoring this device.
[ 5.853] (II) This device may have been added with another device file.
[ 5.854] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 5.854] () Logitech USB Receiver: Applying InputClass “libinput keyboard catchall”
[ 5.854] (II) Using input driver ‘libinput’ for ‘Logitech USB Receiver’
[ 5.854] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 47 paused 0
[ 5.854] () Logitech USB Receiver: always reports core events
[ 5.854] () Option “Device” “/dev/input/event1”
[ 5.854] () Option “_source” “server/udev”
[ 5.854] (II) input device ‘Logitech USB Receiver’, /dev/input/event1 is tagged by udev as: Keyboard
[ 5.854] (II) input device ‘Logitech USB Receiver’, /dev/input/event1 is a keyboard
[ 5.854] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C534.0001/input/input3/event1”
[ 5.854] (II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: KEYBOARD, id 11)
[ 5.854] () Option “xkb_model” “pc105”
[ 5.854] () Option “xkb_layout” “us”
[ 5.855] (II) input device ‘Logitech USB Receiver’, /dev/input/event1 is tagged by udev as: Keyboard
[ 5.855] (II) input device ‘Logitech USB Receiver’, /dev/input/event1 is a keyboard
[ 5.855] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event2)
[ 5.855] () Logitech USB Receiver Mouse: Applying InputClass “libinput pointer catchall”
[ 5.855] (II) Using input driver ‘libinput’ for ‘Logitech USB Receiver Mouse’
[ 5.855] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 48 paused 0
[ 5.855] () Logitech USB Receiver Mouse: always reports core events
[ 5.855] () Option “Device” “/dev/input/event2”
[ 5.855] () Option “_source” “server/udev”
[ 5.856] (II) input device ‘Logitech USB Receiver Mouse’, /dev/input/event2 is tagged by udev as: Mouse
[ 5.856] (II) input device ‘Logitech USB Receiver Mouse’, /dev/input/event2 is a pointer caps
[ 5.856] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0002/input/input4/event2”
[ 5.856] (II) XINPUT: Adding extended input device “Logitech USB Receiver Mouse” (type: MOUSE, id 12)
[ 5.856] () Option “AccelerationScheme” “none”
[ 5.856] () Logitech USB Receiver Mouse: (accel) selected scheme none/0
[ 5.856] () Logitech USB Receiver Mouse: (accel) acceleration factor: 2.000
[ 5.856] () Logitech USB Receiver Mouse: (accel) acceleration threshold: 4
[ 5.856] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/mouse0)
[ 5.856] (II) No input driver specified, ignoring this device.
[ 5.856] (II) This device may have been added with another device file.
[ 5.857] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event3)
[ 5.857] () Logitech USB Receiver Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 5.857] (II) Using input driver ‘libinput’ for ‘Logitech USB Receiver Consumer Control’
[ 5.857] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 49 paused 0
[ 5.857] () Logitech USB Receiver Consumer Control: always reports core events
[ 5.857] () Option “Device” “/dev/input/event3”
[ 5.857] () Option “_source” “server/udev”
[ 5.857] (II) input device ‘Logitech USB Receiver Consumer Control’, /dev/input/event3 is tagged by udev as: Keyboard
[ 5.857] (II) input device ‘Logitech USB Receiver Consumer Control’, /dev/input/event3 is a keyboard
[ 5.857] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[ 5.857] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0002/input/input5/event3”
[ 5.857] (II) XINPUT: Adding extended input device “Logitech USB Receiver Consumer Control” (type: MOUSE, id 13)
[ 5.857] () Option “AccelerationScheme” “none”
[ 5.857] () Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[ 5.857] () Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 5.857] () Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 5.858] (II) input device ‘Logitech USB Receiver Consumer Control’, /dev/input/event3 is tagged by udev as: Keyboard
[ 5.858] (II) input device ‘Logitech USB Receiver Consumer Control’, /dev/input/event3 is a keyboard
[ 5.858] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event4)
[ 5.858] () Logitech USB Receiver System Control: Applying InputClass “libinput keyboard catchall”
[ 5.858] (II) Using input driver ‘libinput’ for ‘Logitech USB Receiver System Control’
[ 5.858] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 50 paused 0
[ 5.858] () Logitech USB Receiver System Control: always reports core events
[ 5.858] () Option “Device” “/dev/input/event4”
[ 5.858] () Option “_source” “server/udev”
[ 5.859] (II) input device ‘Logitech USB Receiver System Control’, /dev/input/event4 is tagged by udev as: Keyboard
[ 5.859] (II) input device ‘Logitech USB Receiver System Control’, /dev/input/event4 is a keyboard
[ 5.859] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0002/input/input6/event4”
[ 5.859] (II) XINPUT: Adding extended input device “Logitech USB Receiver System Control” (type: KEYBOARD, id 14)
[ 5.859] () Option “xkb_model” “pc105”
[ 5.859] () Option “xkb_layout” “us”
[ 5.859] (II) config/udev: Adding input device Integrated Webcam: Integrated W (/dev/input/event16)
[ 5.859] () Integrated Webcam: Integrated W: Applying InputClass “libinput keyboard catchall”
[ 5.859] (II) Using input driver ‘libinput’ for ‘Integrated Webcam: Integrated W’
[ 5.860] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 51 paused 0
[ 5.860] () Integrated Webcam: Integrated W: always reports core events
[ 5.860] () Option “Device” “/dev/input/event16”
[ 5.860] () Option “_source” “server/udev”
[ 5.860] (II) input device ‘Integrated Webcam: Integrated W’, /dev/input/event16 is tagged by udev as: Keyboard
[ 5.860] (II) input device ‘Integrated Webcam: Integrated W’, /dev/input/event16 is a keyboard
[ 5.860] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input21/event16”
[ 5.860] (II) XINPUT: Adding extended input device “Integrated Webcam: Integrated W” (type: KEYBOARD, id 15)
[ 5.860] () Option “xkb_model” “pc105”
[ 5.860] () Option “xkb_layout” “us”
[ 5.861] (II) config/udev: Adding input device DELL086F:00 06CB:7E92 Touchpad (/dev/input/event17)
[ 5.861] () DELL086F:00 06CB:7E92 Touchpad: Applying InputClass “libinput touchpad catchall”
[ 5.861] (II) Using input driver ‘libinput’ for ‘DELL086F:00 06CB:7E92 Touchpad’
[ 5.969] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 52 paused 0
[ 5.969] () DELL086F:00 06CB:7E92 Touchpad: always reports core events
[ 5.969] () Option “Device” “/dev/input/event17”
[ 5.969] () Option “_source” “server/udev”
[ 5.970] (II) input device ‘DELL086F:00 06CB:7E92 Touchpad’, /dev/input/event17 is tagged by udev as: Touchpad
[ 5.970] (II) input device ‘DELL086F:00 06CB:7E92 Touchpad’, /dev/input/event17 is a touchpad
[ 5.970] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-3/i2c-DELL086F:00/0018:06CB:7E92.0003/input/input29/event17”
[ 5.970] (II) XINPUT: Adding extended input device “DELL086F:00 06CB:7E92 Touchpad” (type: TOUCHPAD, id 16)
[ 5.970] () Option “AccelerationScheme” “none”
[ 5.971] () DELL086F:00 06CB:7E92 Touchpad: (accel) selected scheme none/0
[ 5.971] () DELL086F:00 06CB:7E92 Touchpad: (accel) acceleration factor: 2.000
[ 5.971] () DELL086F:00 06CB:7E92 Touchpad: (accel) acceleration threshold: 4
[ 5.971] (II) input device ‘DELL086F:00 06CB:7E92 Touchpad’, /dev/input/event17 is tagged by udev as: Touchpad
[ 5.971] (II) input device ‘DELL086F:00 06CB:7E92 Touchpad’, /dev/input/event17 is a touchpad
[ 5.972] (II) config/udev: Adding input device DELL086F:00 06CB:7E92 Touchpad (/dev/input/mouse2)
[ 5.972] (II) No input driver specified, ignoring this device.
[ 5.972] (II) This device may have been added with another device file.
[ 5.973] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event19)
[ 5.973] (II) No input driver specified, ignoring this device.
[ 5.973] (II) This device may have been added with another device file.
[ 5.974] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event20)
[ 5.974] (II) No input driver specified, ignoring this device.
[ 5.974] (II) This device may have been added with another device file.
[ 5.974] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event21)
[ 5.974] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event22)
[ 5.975] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event23)
[ 5.975] (II) No input driver specified, ignoring this device.
[ 5.975] (II) This device may have been added with another device file.
[ 5.975] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event24)
[ 5.975] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event25)
[ 5.975] (II) config/udev: Adding input device Intel HID events (/dev/input/event10)
[ 5.975] () Intel HID events: Applying InputClass “libinput keyboard catchall”
[ 5.975] (II) Using input driver ‘libinput’ for ‘Intel HID events’
[ 5.975] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 53 paused 0
[ 5.975] () Intel HID events: always reports core events
[ 5.975] () Option “Device” “/dev/input/event10”
[ 5.975] () Option “_source” “server/udev”
[ 5.976] (II) input device ‘Intel HID events’, /dev/input/event10 is tagged by udev as: Keyboard
[ 5.976] (II) input device ‘Intel HID events’, /dev/input/event10 is a keyboard
[ 5.976] () Option “config_info” “udev:/sys/devices/platform/INT33D5:00/input/input15/event10”
[ 5.976] (II) XINPUT: Adding extended input device “Intel HID events” (type: KEYBOARD, id 17)
[ 5.976] () Option “xkb_model” “pc105”
[ 5.976] () Option “xkb_layout” “us”
[ 5.976] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event11)
[ 5.976] () Intel HID 5 button array: Applying InputClass “libinput keyboard catchall”
[ 5.976] (II) Using input driver ‘libinput’ for ‘Intel HID 5 button array’
[ 5.977] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 54 paused 0
[ 5.977] () Intel HID 5 button array: always reports core events
[ 5.977] () Option “Device” “/dev/input/event11”
[ 5.977] () Option “_source” “server/udev”
[ 5.977] (II) input device ‘Intel HID 5 button array’, /dev/input/event11 is tagged by udev as: Keyboard
[ 5.977] (II) input device ‘Intel HID 5 button array’, /dev/input/event11 is a keyboard
[ 5.977] () Option “config_info” “udev:/sys/devices/platform/INT33D5:00/input/input16/event11”
[ 5.977] (II) XINPUT: Adding extended input device “Intel HID 5 button array” (type: KEYBOARD, id 18)
[ 5.977] () Option “xkb_model” “pc105”
[ 5.977] () Option “xkb_layout” “us”
[ 5.977] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event13)
[ 5.977] () Dell WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 5.977] (II) Using input driver ‘libinput’ for ‘Dell WMI hotkeys’
[ 5.978] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 55 paused 0
[ 5.978] () Dell WMI hotkeys: always reports core events
[ 5.978] () Option “Device” “/dev/input/event13”
[ 5.978] () Option “_source” “server/udev”
[ 5.978] (II) input device ‘Dell WMI hotkeys’, /dev/input/event13 is tagged by udev as: Keyboard
[ 5.978] (II) input device ‘Dell WMI hotkeys’, /dev/input/event13 is a keyboard
[ 5.978] () Option “config_info” “udev:/sys/devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input18/event13”
[ 5.978] (II) XINPUT: Adding extended input device “Dell WMI hotkeys” (type: KEYBOARD, id 19)
[ 5.978] () Option “xkb_model” “pc105”
[ 5.978] () Option “xkb_layout” “us”
[ 5.979] (II) input device ‘Dell WMI hotkeys’, /dev/input/event13 is tagged by udev as: Keyboard
[ 5.979] (II) input device ‘Dell WMI hotkeys’, /dev/input/event13 is a keyboard
[ 5.979] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 5.979] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 5.979] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 5.979] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 56 paused 0
[ 5.979] () AT Translated Set 2 keyboard: always reports core events
[ 5.979] () Option “Device” “/dev/input/event0”
[ 5.979] () Option “_source” “server/udev”
[ 5.980] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event0 is tagged by udev as: Keyboard
[ 5.980] (II) input device ‘AT Translated Set 2 keyboard’, /dev/input/event0 is a keyboard
[ 5.980] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 5.980] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 20)
[ 5.980] () Option “xkb_model” “pc105”
[ 5.980] () Option “xkb_layout” “us”
[ 5.980] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
[ 5.980] () SynPS/2 Synaptics TouchPad: Applying InputClass “libinput touchpad catchall”
[ 5.980] (II) Using input driver ‘libinput’ for ‘SynPS/2 Synaptics TouchPad’
[ 5.981] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 57 paused 0
[ 5.981] () SynPS/2 Synaptics TouchPad: always reports core events
[ 5.981] () Option “Device” “/dev/input/event5”
[ 5.981] () Option “_source” “server/udev”
[ 5.981] (II) input device ‘SynPS/2 Synaptics TouchPad’, /dev/input/event5 is tagged by udev as: Touchpad
[ 5.981] (II) SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 5.981] (II) input device ‘SynPS/2 Synaptics TouchPad’, /dev/input/event5 is a touchpad
[ 5.981] () Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input2/event5”
[ 5.981] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 21)
[ 5.981] () Option “AccelerationScheme” “none”
[ 5.981] () SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 5.981] () SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 5.981] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 5.981] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 5.981] (II) No input driver specified, ignoring this device.
[ 5.981] (II) This device may have been added with another device file.
[ 5.982] (II) config/udev: Adding input device PC Speaker (/dev/input/event12)
[ 5.982] (II) No input driver specified, ignoring this device.
[ 5.982] (II) This device may have been added with another device file.
[ 5.984] () Logitech USB Receiver Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 5.984] (II) Using input driver ‘libinput’ for ‘Logitech USB Receiver Consumer Control’
[ 5.984] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 5.984] () Logitech USB Receiver Consumer Control: always reports core events
[ 5.984] () Option “Device” “/dev/input/event3”
[ 5.984] () Option “_source” “_driver/libinput”
[ 5.984] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[ 5.984] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C534.0002/input/input5/event3”
[ 5.984] (II) XINPUT: Adding extended input device “Logitech USB Receiver Consumer Control” (type: KEYBOARD, id 22)
[ 5.984] () Option “xkb_model” “pc105”
[ 5.984] () Option “xkb_layout” “us”
[ 6.148] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): connected
[ 6.148] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): Internal TMDS
[ 6.148] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): 600.0 MHz maximum pixel clock
[ 9.921] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): connected
[ 9.921] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): Internal TMDS
[ 9.921] (–) NVIDIA(GPU-0): DELL U2414H (DFP-0): 600.0 MHz maximum pixel clock
[ 14.981] () Option “fd” “40”
[ 14.981] () Option “fd” “43”
[ 14.981] () Option “fd” “44”
[ 14.981] () Option “fd” “45”
[ 14.981] () Option “fd” “46”
[ 14.981] () Option “fd” “47”
[ 14.981] () Option “fd” “48”
[ 14.981] () Option “fd” “49”
[ 14.981] () Option “fd” “50”
[ 14.981] () Option “fd” “51”
[ 14.982] () Option “fd” “52”
[ 14.982] () Option “fd” “53”
[ 14.982] () Option “fd” “54”
[ 14.982] () Option “fd” “55”
[ 14.982] () Option “fd” “56”
[ 14.982] () Option “fd” “57”
[ 14.982] () Option “fd” “49”
[ 15.040] (II) systemd-logind: got pause for 13:73
[ 15.040] (II) systemd-logind: got pause for 13:69
[ 15.040] (II) systemd-logind: got pause for 13:74
[ 15.040] (II) systemd-logind: got pause for 13:67
[ 15.040] (II) systemd-logind: got pause for 13:72
[ 15.040] (II) systemd-logind: got pause for 226:0
[ 15.040] (II) systemd-logind: got pause for 13:68
[ 15.040] (II) systemd-logind: got pause for 13:78
[ 15.040] (II) systemd-logind: got pause for 13:75
[ 15.040] (II) systemd-logind: got pause for 13:77
[ 15.040] (II) systemd-logind: got pause for 13:64
[ 15.040] (II) systemd-logind: got pause for 13:66
[ 15.040] (II) systemd-logind: got pause for 13:79
[ 15.040] (II) systemd-logind: got pause for 13:81
[ 15.040] (II) systemd-logind: got pause for 13:71
[ 15.040] (II) systemd-logind: got pause for 13:80
[ 15.040] (II) systemd-logind: got pause for 13:65
As you can see here there is only one valid display detected :
And this always displays on HDMI and not on main screen…
Here is the result of xrandr --listproviders :
Provider 0: id: 0x1b9 cap: 0x1, Source Output crtcs: 4 outputs: 1 associated providers: 0 name:NVIDIA-0
Many thanks for any help provided!
