when i run : glxinfo, i get the following errors:
X Error of failed request: GLXBadContextTag
Major opcode of failed request: 146 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 39
Current serial number in output stream: 39
system env:
window 10 ssh access to ubuntu headless server.
the server: Ubuntu 18.04, nvidia-driver : 495.44
xorg.0.log:
[ 40.039] (–) Log file renamed from “/var/log/Xorg.pid-2607.log” to “/var/log/Xorg.0.log”
[ 40.050]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 40.050] X Protocol Version 11, Revision 0
[ 40.050] Build Operating System: Linux 4.15.0-140-generic x86_64 Ubuntu
[ 40.050] Current Operating System: Linux gpu190 4.15.0-162-generic #170-Ubuntu SMP Mon Oct 18 11:38:05 UTC 2021 x86_64
[ 40.050] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-162-generic root=UUID=bebd7c8f-a0a9-44e3-9b0d-cb6f7a771fd1 ro quiet splash vt.handoff=1
[ 40.050] Build Date: 08 April 2021 01:57:21PM
[ 40.050] xorg-server 2:1.19.6-1ubuntu4.9 (For technical support please see Enterprise open source support | Ubuntu)
[ 40.050] Current version of pixman: 0.34.0
[ 40.050] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 40.050] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 40.050] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 9 15:56:30 2021
[ 40.056] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 40.096] (==) No Layout section. Using the first Screen section.
[ 40.096] (==) No screen section available. Using defaults.
[ 40.096] () |–>Screen “Default Screen Section” (0)
[ 40.096] (**) | |–>Monitor “”
[ 40.130] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 40.131] (==) Automatically adding devices
[ 40.131] (==) Automatically enabling devices
[ 40.131] (==) Automatically adding GPU devices
[ 40.131] (==) Automatically binding GPU devices
[ 40.131] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 40.131] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 40.131] Entry deleted from font path.
[ 40.131] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 40.131] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 40.156] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 40.156] Entry deleted from font path.
[ 40.156] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 40.156] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 40.156] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 40.156] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 40.164] (II) Loader magic: 0x561542385020
[ 40.164] (II) Module ABI versions:
[ 40.164] X.Org ANSI C Emulation: 0.4
[ 40.164] X.Org Video Driver: 23.0
[ 40.164] X.Org XInput driver : 24.1
[ 40.164] X.Org Server Extension : 10.0
[ 40.165] (++) using VT number 1
[ 40.168] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 40.168] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 40.169] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 40.187] (–) PCI:*(0:101:0:0) 10de:1b30:1028:11a0 rev 161, Mem @ 0xd7000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x???/131072
[ 40.187] (II) LoadModule: “glx”
[ 40.194] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 40.383] (II) Module glx: vendor=“X.Org Foundation”
[ 40.383] compiled for 1.19.6, module version = 1.0.0
[ 40.383] ABI class: X.Org Server Extension, version 10.0
[ 40.383] (II) Applying OutputClass “nvidia” to /dev/dri/card0
[ 40.383] loading driver: nvidia
[ 40.383] (==) Matched nvidia as autoconfigured driver 0
[ 40.383] (==) Matched nouveau as autoconfigured driver 1
[ 40.383] (==) Matched nouveau as autoconfigured driver 2
[ 40.383] (==) Matched modesetting as autoconfigured driver 3
[ 40.384] (==) Matched fbdev as autoconfigured driver 4
[ 40.384] (==) Matched vesa as autoconfigured driver 5
[ 40.384] (==) Assigned the driver to the xf86ConfigLayout
[ 40.384] (II) LoadModule: “nvidia”
[ 40.384] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 40.463] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 40.464] compiled for 1.6.99.901, module version = 1.0.0
[ 40.464] Module class: X.Org Video Driver
[ 40.471] (II) LoadModule: “nouveau”
[ 40.471] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 40.484] (II) Module nouveau: vendor=“X.Org Foundation”
[ 40.484] compiled for 1.19.6, module version = 1.0.16
[ 40.484] Module class: X.Org Video Driver
[ 40.484] ABI class: X.Org Video Driver, version 23.0
[ 40.484] (II) LoadModule: “modesetting”
[ 40.484] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 40.529] (II) Module modesetting: vendor=“X.Org Foundation”
[ 40.529] compiled for 1.19.6, module version = 1.19.6
[ 40.529] Module class: X.Org Video Driver
[ 40.529] ABI class: X.Org Video Driver, version 23.0
[ 40.529] (II) LoadModule: “fbdev”
[ 40.530] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 40.535] (II) Module fbdev: vendor=“X.Org Foundation”
[ 40.535] compiled for 1.19.3, module version = 0.4.4
[ 40.535] Module class: X.Org Video Driver
[ 40.535] ABI class: X.Org Video Driver, version 23.0
[ 40.535] (II) LoadModule: “vesa”
[ 40.535] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 40.542] (II) Module vesa: vendor=“X.Org Foundation”
[ 40.542] compiled for 1.19.3, module version = 2.3.4
[ 40.542] Module class: X.Org Video Driver
[ 40.542] ABI class: X.Org Video Driver, version 23.0
[ 40.542] (II) NVIDIA dlloader X Driver 495.44 Fri Oct 22 06:11:21 UTC 2021
[ 40.542] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 40.551] (II) NOUVEAU driver
[ 40.551] (II) NOUVEAU driver for NVIDIA chipset families :
[ 40.552] RIVA TNT (NV04)
[ 40.552] RIVA TNT2 (NV05)
[ 40.552] GeForce 256 (NV10)
[ 40.552] GeForce 2 (NV11, NV15)
[ 40.552] GeForce 4MX (NV17, NV18)
[ 40.552] GeForce 3 (NV20)
[ 40.552] GeForce 4Ti (NV25, NV28)
[ 40.552] GeForce FX (NV3x)
[ 40.552] GeForce 6 (NV4x)
[ 40.552] GeForce 7 (G7x)
[ 40.552] GeForce 8 (G8x)
[ 40.553] GeForce 9 (G9x)
[ 40.553] GeForce GTX 2xx/3xx (GT2xx)
[ 40.553] GeForce GTX 4xx/5xx (GFxxx)
[ 40.553] GeForce GTX 6xx/7xx (GKxxx)
[ 40.553] GeForce GTX 9xx (GMxxx)
[ 40.553] GeForce GTX 10xx (GPxxx)
[ 40.553] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 40.553] (II) FBDEV: driver for framebuffer: fbdev
[ 40.553] (II) VESA: driver for VESA chipsets: vesa
[ 40.553] (II) systemd-logind: releasing fd for 226:0
[ 40.558] (II) Loading sub module “fb”
[ 40.558] (II) LoadModule: “fb”
[ 40.558] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 40.718] (II) Module fb: vendor=“X.Org Foundation”
[ 40.718] compiled for 1.19.6, module version = 1.0.0
[ 40.718] ABI class: X.Org ANSI C Emulation, version 0.4
[ 40.718] (II) Loading sub module “wfb”
[ 40.718] (II) LoadModule: “wfb”
[ 40.718] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 40.736] (II) Module wfb: vendor=“X.Org Foundation”
[ 40.737] compiled for 1.19.6, module version = 1.0.0
[ 40.737] ABI class: X.Org ANSI C Emulation, version 0.4
[ 40.737] (II) Loading sub module “ramdac”
[ 40.737] (II) LoadModule: “ramdac”
[ 40.737] (II) Module “ramdac” already built-in
[ 40.743] (WW) Falling back to old probe method for modesetting
[ 40.743] (WW) Falling back to old probe method for fbdev
[ 40.743] (II) Loading sub module “fbdevhw”
[ 40.743] (II) LoadModule: “fbdevhw”
[ 40.744] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 40.744] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 40.744] compiled for 1.19.6, module version = 0.0.2
[ 40.744] ABI class: X.Org Video Driver, version 23.0
[ 40.744] (WW) Falling back to old probe method for vesa
[ 40.744] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 40.745] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 40.745] (==) NVIDIA(0): RGB weight 888
[ 40.745] (==) NVIDIA(0): Default visual is TrueColor
[ 40.745] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 40.752] () NVIDIA(0): Enabling 2D acceleration
[ 40.752] (II) Loading sub module “glxserver_nvidia”
[ 40.752] (II) LoadModule: “glxserver_nvidia”
[ 40.752] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 41.235] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 41.235] compiled for 1.6.99.901, module version = 1.0.0
[ 41.235] Module class: X.Org Server Extension
[ 41.235] (II) NVIDIA GLX Module 495.44 Fri Oct 22 06:08:29 UTC 2021
[ 41.250] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 42.072] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:101:0:0
[ 42.072] (–) NVIDIA(0): DFP-0
[ 42.072] (–) NVIDIA(0): DFP-1
[ 42.072] (–) NVIDIA(0): DFP-2
[ 42.072] (–) NVIDIA(0): DFP-3 (boot)
[ 42.072] (–) NVIDIA(0): DFP-4
[ 42.072] (–) NVIDIA(0): DFP-5
[ 42.072] (–) NVIDIA(0): DFP-6
[ 42.072] (–) NVIDIA(0): DFP-7
[ 42.072] (–) NVIDIA(0): DFP-8
[ 42.073] (II) NVIDIA(0): NVIDIA GPU Quadro P6000 (GP102GL-A) at PCI:101:0:0 (GPU-0)
[ 42.073] (–) NVIDIA(0): Memory: 25165824 kBytes
[ 42.073] (–) NVIDIA(0): VideoBIOS: 86.02.2d.00.05
[ 42.073] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 42.073] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 42.073] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 42.073] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 42.073] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 42.073] (–) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 42.073] (–) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 42.073] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 42.073] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 42.073] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 42.073] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): connected
[ 42.073] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): Internal DisplayPort
[ 42.073] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): 1440.0 MHz maximum pixel clock
[ 42.075] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 42.075] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 42.075] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 42.075] (–) NVIDIA(GPU-0): DFP-5: disconnected
[ 42.075] (–) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 42.075] (–) NVIDIA(GPU-0): DFP-5: 1440.0 MHz maximum pixel clock
[ 42.075] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 42.075] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 42.075] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 42.075] (–) NVIDIA(GPU-0): DFP-7: disconnected
[ 42.075] (–) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[ 42.075] (–) NVIDIA(GPU-0): DFP-7: 1440.0 MHz maximum pixel clock
[ 42.075] (–) NVIDIA(GPU-0): DFP-8: disconnected
[ 42.075] (–) NVIDIA(GPU-0): DFP-8: Internal TMDS
[ 42.075] (–) NVIDIA(GPU-0): DFP-8: 165.0 MHz maximum pixel clock
[ 42.081] (==) NVIDIA(0):
[ 42.081] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 42.081] (==) NVIDIA(0): will be used as the requested mode.
[ 42.139] (II) NVIDIA(0): Validated MetaModes:
[ 42.139] (II) NVIDIA(0): “DFP-3:nvidia-auto-select”
[ 42.139] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[ 42.151] (–) NVIDIA(0): DPI set to (162, 161); computed from “UseEdidDpi” X config
[ 42.151] (–) NVIDIA(0): option
[ 42.151] (II) UnloadModule: “nouveau”
[ 42.151] (II) Unloading nouveau
[ 42.151] (II) UnloadModule: “modesetting”
[ 42.151] (II) Unloading modesetting
[ 42.151] (II) UnloadModule: “fbdev”
[ 42.151] (II) Unloading fbdev
[ 42.151] (II) UnloadSubModule: “fbdevhw”
[ 42.151] (II) Unloading fbdevhw
[ 42.151] (II) UnloadModule: “vesa”
[ 42.151] (II) Unloading vesa
[ 42.151] (–) Depth 24 pixmap format is 32 bpp
[ 42.152] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 42.152] (II) NVIDIA: access.
[ 42.410] (II) NVIDIA(0): Setting mode “DFP-3:nvidia-auto-select”
[ 44.969] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 44.969] (==) NVIDIA(0): Backing store enabled
[ 44.969] (==) NVIDIA(0): Silken mouse enabled
[ 45.186] (==) NVIDIA(0): DPMS enabled
[ 45.186] (II) Loading sub module “dri2”
[ 45.186] (II) LoadModule: “dri2”
[ 45.186] (II) Module “dri2” already built-in
[ 45.186] (II) NVIDIA(0): [DRI2] Setup complete
[ 45.186] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 45.187] (–) RandR disabled
[ 45.192] (II) SELinux: Disabled on system
[ 45.201] (II) Initializing extension GLX
[ 45.201] (II) Indirect GLX disabled.
[ 45.772] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 45.772] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 45.772] (II) LoadModule: “libinput”
[ 45.908] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 46.176] (II) Module libinput: vendor=“X.Org Foundation”
[ 46.177] compiled for 1.19.6, module version = 0.27.1
[ 46.177] Module class: X.Org XInput Driver
[ 46.177] ABI class: X.Org XInput driver, version 24.1
[ 46.177] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 46.178] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 41 paused 0
[ 46.178] () Power Button: always reports core events
[ 46.178] () Option “Device” “/dev/input/event2”
[ 46.178] () Option “_source” “server/udev”
[ 46.179] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 46.179] (II) event2 - Power Button: device is a keyboard
[ 46.179] (II) event2 - Power Button: device removed
[ 46.179] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[ 46.180] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 46.180] () Option “xkb_model” “pc105”
[ 46.180] () Option “xkb_layout” “us”
[ 46.181] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 46.181] (II) event2 - Power Button: device is a keyboard
[ 46.181] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 46.181] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 46.181] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 46.183] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 44 paused 0
[ 46.183] () Power Button: always reports core events
[ 46.183] () Option “Device” “/dev/input/event1”
[ 46.183] () Option “_source” “server/udev”
[ 46.183] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 46.183] (II) event1 - Power Button: device is a keyboard
[ 46.183] (II) event1 - Power Button: device removed
[ 46.183] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 46.184] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 46.184] () Option “xkb_model” “pc105”
[ 46.184] () Option “xkb_layout” “us”
[ 46.185] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 46.185] (II) event1 - Power Button: device is a keyboard
[ 46.186] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 46.186] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 46.186] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 46.187] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[ 46.187] () Sleep Button: always reports core events
[ 46.187] () Option “Device” “/dev/input/event0”
[ 46.187] () Option “_source” “server/udev”
[ 46.188] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 46.188] (II) event0 - Sleep Button: device is a keyboard
[ 46.188] (II) event0 - Sleep Button: device removed
[ 46.188] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0”
[ 46.188] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 8)
[ 46.188] () Option “xkb_model” “pc105”
[ 46.188] () Option “xkb_layout” “us”
[ 46.189] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 46.189] (II) event0 - Sleep Button: device is a keyboard
[ 46.190] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event6)
[ 46.191] () Logitech USB Keyboard: Applying InputClass “libinput keyboard catchall”
[ 46.191] (II) Using input driver ‘libinput’ for ‘Logitech USB Keyboard’
[ 46.192] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 46 paused 0
[ 46.192] () Logitech USB Keyboard: always reports core events
[ 46.192] () Option “Device” “/dev/input/event6”
[ 46.192] () Option “_source” “server/udev”
[ 46.193] (II) event6 - Logitech USB Keyboard: is tagged by udev as: Keyboard
[ 46.193] (II) event6 - Logitech USB Keyboard: device is a keyboard
[ 46.193] (II) event6 - Logitech USB Keyboard: device removed
[ 46.193] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.1/1-10.1:1.0/0003:046D:C31C.0004/input/input6/event6”
[ 46.193] (II) XINPUT: Adding extended input device “Logitech USB Keyboard” (type: KEYBOARD, id 9)
[ 46.193] () Option “xkb_model” “pc105”
[ 46.193] () Option “xkb_layout” “us”
[ 46.194] (II) event6 - Logitech USB Keyboard: is tagged by udev as: Keyboard
[ 46.194] (II) event6 - Logitech USB Keyboard: device is a keyboard
[ 46.196] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event7)
[ 46.196] () Logitech USB Keyboard: Applying InputClass “libinput keyboard catchall”
[ 46.196] (II) Using input driver ‘libinput’ for ‘Logitech USB Keyboard’
[ 46.197] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 47 paused 0
[ 46.197] () Logitech USB Keyboard: always reports core events
[ 46.197] () Option “Device” “/dev/input/event7”
[ 46.197] () Option “_source” “server/udev”
[ 46.198] (II) event7 - Logitech USB Keyboard: is tagged by udev as: Keyboard
[ 46.198] (II) event7 - Logitech USB Keyboard: device is a keyboard
[ 46.198] (II) event7 - Logitech USB Keyboard: device removed
[ 46.198] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.1/1-10.1:1.1/0003:046D:C31C.0005/input/input7/event7”
[ 46.198] (II) XINPUT: Adding extended input device “Logitech USB Keyboard” (type: KEYBOARD, id 10)
[ 46.198] () Option “xkb_model” “pc105”
[ 46.199] () Option “xkb_layout” “us”
[ 46.200] (II) event7 - Logitech USB Keyboard: is tagged by udev as: Keyboard
[ 46.200] (II) event7 - Logitech USB Keyboard: device is a keyboard
[ 46.201] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event8)
[ 46.201] () Logitech USB Optical Mouse: Applying InputClass “libinput pointer catchall”
[ 46.201] (II) Using input driver ‘libinput’ for ‘Logitech USB Optical Mouse’
[ 46.202] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 48 paused 0
[ 46.202] () Logitech USB Optical Mouse: always reports core events
[ 46.202] () Option “Device” “/dev/input/event8”
[ 46.202] () Option “_source” “server/udev”
[ 46.203] (II) event8 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 46.203] (II) event8 - Logitech USB Optical Mouse: device is a pointer
[ 46.203] (II) event8 - Logitech USB Optical Mouse: device removed
[ 46.203] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2:1.0/0003:046D:C077.0006/input/input8/event8”
[ 46.203] (II) XINPUT: Adding extended input device “Logitech USB Optical Mouse” (type: MOUSE, id 11)
[ 46.204] () Option “AccelerationScheme” “none”
[ 46.204] () Logitech USB Optical Mouse: (accel) selected scheme none/0
[ 46.204] () Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[ 46.204] () Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[ 46.205] (II) event8 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[ 46.205] (II) event8 - Logitech USB Optical Mouse: device is a pointer
[ 46.206] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse1)
[ 46.206] (II) No input driver specified, ignoring this device.
[ 46.206] (II) This device may have been added with another device file.
[ 46.207] (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/event4)
[ 46.207] () Dell Dell Universal Receiver: Applying InputClass “libinput keyboard catchall”
[ 46.207] (II) Using input driver ‘libinput’ for ‘Dell Dell Universal Receiver’
[ 46.208] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 49 paused 0
[ 46.208] () Dell Dell Universal Receiver: always reports core events
[ 46.208] () Option “Device” “/dev/input/event4”
[ 46.208] () Option “_source” “server/udev”
[ 46.209] (II) event4 - Dell Dell Universal Receiver: is tagged by udev as: Keyboard
[ 46.209] (II) event4 - Dell Dell Universal Receiver: device is a keyboard
[ 46.209] (II) event4 - Dell Dell Universal Receiver: device removed
[ 46.209] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:413C:301D.0001/input/input4/event4”
[ 46.209] (II) XINPUT: Adding extended input device “Dell Dell Universal Receiver” (type: KEYBOARD, id 12)
[ 46.209] () Option “xkb_model” “pc105”
[ 46.209] () Option “xkb_layout” “us”
[ 46.210] (II) event4 - Dell Dell Universal Receiver: is tagged by udev as: Keyboard
[ 46.210] (II) event4 - Dell Dell Universal Receiver: device is a keyboard
[ 46.211] (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/event5)
[ 46.211] () Dell Dell Universal Receiver: Applying InputClass “libinput pointer catchall”
[ 46.211] () Dell Dell Universal Receiver: Applying InputClass “libinput keyboard catchall”
[ 46.211] (II) Using input driver ‘libinput’ for ‘Dell Dell Universal Receiver’
[ 46.212] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 50 paused 0
[ 46.212] () Dell Dell Universal Receiver: always reports core events
[ 46.212] () Option “Device” “/dev/input/event5”
[ 46.212] () Option “_source” “server/udev”
[ 46.213] (II) event5 - Dell Dell Universal Receiver: is tagged by udev as: Keyboard Mouse
[ 46.213] (II) event5 - Dell Dell Universal Receiver: device is a pointer
[ 46.213] (II) event5 - Dell Dell Universal Receiver: device is a keyboard
[ 46.213] (II) event5 - Dell Dell Universal Receiver: device removed
[ 46.213] (II) libinput: Dell Dell Universal Receiver: needs a virtual subdevice
[ 46.213] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:413C:301D.0002/input/input5/event5”
[ 46.213] (II) XINPUT: Adding extended input device “Dell Dell Universal Receiver” (type: MOUSE, id 13)
[ 46.213] () Option “AccelerationScheme” “none”
[ 46.213] () Dell Dell Universal Receiver: (accel) selected scheme none/0
[ 46.213] () Dell Dell Universal Receiver: (accel) acceleration factor: 2.000
[ 46.213] () Dell Dell Universal Receiver: (accel) acceleration threshold: 4
[ 46.214] (II) event5 - Dell Dell Universal Receiver: is tagged by udev as: Keyboard Mouse
[ 46.214] (II) event5 - Dell Dell Universal Receiver: device is a pointer
[ 46.214] (II) event5 - Dell Dell Universal Receiver: device is a keyboard
[ 46.215] (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/mouse0)
[ 46.215] (II) No input driver specified, ignoring this device.
[ 46.215] (II) This device may have been added with another device file.
[ 46.216] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event14)
[ 46.216] (II) No input driver specified, ignoring this device.
[ 46.216] (II) This device may have been added with another device file.
[ 46.216] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event15)
[ 46.217] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event16)
[ 46.217] (II) No input driver specified, ignoring this device.
[ 46.217] (II) This device may have been added with another device file.
[ 46.217] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[ 46.218] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 46.218] (II) No input driver specified, ignoring this device.
[ 46.218] (II) This device may have been added with another device file.
[ 46.218] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 46.219] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 46.219] (II) No input driver specified, ignoring this device.
[ 46.219] (II) This device may have been added with another device file.
[ 46.219] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 46.220] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event9)
[ 46.220] () Dell WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[ 46.220] (II) Using input driver ‘libinput’ for ‘Dell WMI hotkeys’
[ 46.221] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 51 paused 0
[ 46.221] () Dell WMI hotkeys: always reports core events
[ 46.221] () Option “Device” “/dev/input/event9”
[ 46.221] () Option “_source” “server/udev”
[ 46.222] (II) event9 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 46.222] (II) event9 - Dell WMI hotkeys: device is a keyboard
[ 46.222] (II) event9 - Dell WMI hotkeys: device removed
[ 46.222] () Option “config_info” “udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input9/event9”
[ 46.222] (II) XINPUT: Adding extended input device “Dell WMI hotkeys” (type: KEYBOARD, id 14)
[ 46.222] () Option “xkb_model” “pc105”
[ 46.222] () Option “xkb_layout” “us”
[ 46.223] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 46.223] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 46.223] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 46.224] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 52 paused 0
[ 46.224] () AT Translated Set 2 keyboard: always reports core events
[ 46.224] () Option “Device” “/dev/input/event3”
[ 46.224] () Option “_source” “server/udev”
[ 46.225] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 46.225] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 46.225] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 46.225] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input3/event3”
[ 46.225] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 15)
[ 46.225] () Option “xkb_model” “pc105”
[ 46.225] () Option “xkb_layout” “us”
[ 46.226] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 46.226] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 46.232] () Dell Dell Universal Receiver: Applying InputClass “libinput pointer catchall”
[ 46.232] () Dell Dell Universal Receiver: Applying InputClass “libinput keyboard catchall”
[ 46.232] (II) Using input driver ‘libinput’ for ‘Dell Dell Universal Receiver’
[ 46.232] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[ 46.232] () Dell Dell Universal Receiver: always reports core events
[ 46.232] () Option “Device” “/dev/input/event5”
[ 46.232] () Option “_source” “_driver/libinput”
[ 46.232] (II) libinput: Dell Dell Universal Receiver: is a virtual subdevice
[ 46.232] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:413C:301D.0002/input/input5/event5”
[ 46.232] (II) XINPUT: Adding extended input device “Dell Dell Universal Receiver” (type: KEYBOARD, id 16)
[ 46.232] () Option “xkb_model” “pc105”
[ 46.232] () Option “xkb_layout” “us”
[ 53.875] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 53.875] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 53.875] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 53.875] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 53.875] (–) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 53.875] (–) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 53.875] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 53.875] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 53.875] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 53.876] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): connected
[ 53.876] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): Internal DisplayPort
[ 53.876] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): 1440.0 MHz maximum pixel clock
[ 53.879] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 53.879] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 53.879] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 53.879] (–) NVIDIA(GPU-0): DFP-5: disconnected
[ 53.879] (–) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 53.879] (–) NVIDIA(GPU-0): DFP-5: 1440.0 MHz maximum pixel clock
[ 53.879] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 53.879] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 53.879] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 53.879] (–) NVIDIA(GPU-0): DFP-7: disconnected
[ 53.879] (–) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[ 53.879] (–) NVIDIA(GPU-0): DFP-7: 1440.0 MHz maximum pixel clock
[ 53.880] (–) NVIDIA(GPU-0): DFP-8: disconnected
[ 53.880] (–) NVIDIA(GPU-0): DFP-8: Internal TMDS
[ 53.880] (–) NVIDIA(GPU-0): DFP-8: 165.0 MHz maximum pixel clock
[ 66.487] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 66.487] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 66.487] (–) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 66.487] (–) NVIDIA(GPU-0): DFP-1: disconnected
[ 66.487] (–) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 66.487] (–) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 66.487] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 66.487] (–) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 66.487] (–) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 66.487] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): connected
[ 66.487] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): Internal DisplayPort
[ 66.487] (–) NVIDIA(GPU-0): DELL P2715Q (DFP-3): 1440.0 MHz maximum pixel clock
[ 66.490] (–) NVIDIA(GPU-0): DFP-4: disconnected
[ 66.490] (–) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 66.490] (–) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 66.490] (–) NVIDIA(GPU-0): DFP-5: disconnected
[ 66.490] (–) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 66.490] (–) NVIDIA(GPU-0): DFP-5: 1440.0 MHz maximum pixel clock
[ 66.490] (–) NVIDIA(GPU-0): DFP-6: disconnected
[ 66.490] (–) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 66.490] (–) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 66.490] (–) NVIDIA(GPU-0): DFP-7: disconnected
[ 66.490] (–) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[ 66.490] (–) NVIDIA(GPU-0): DFP-7: 1440.0 MHz maximum pixel clock
[ 66.490] (–) NVIDIA(GPU-0): DFP-8: disconnected
[ 66.490] (–) NVIDIA(GPU-0): DFP-8: Internal TMDS
[ 66.490] (–) NVIDIA(GPU-0): DFP-8: 165.0 MHz maximum pixel clock
