Hi community,
We have several issues with the drivers 396.24 under CentOS 7. I have to admit that I’m not a Linux specialist, so forgive my detailed explanations below.
I have a Dell server, running CentOS 7/Linux kernel 3.10.0-693.17.1.el7.x86_64. It came with an onboard graphic chip. There is no screen connecteded, and I only connect remote (from Wndows via MobaXTerm) to the machine. I run a lot of MatLAB, and what to make use of GLX/direct rendering. That’s why we bought a Quadro M2000, more than one year ago. We never got it to work with the NVIDIA drivers, nouveau, or elrepo driver way back then. Recently we gave it another shot with the 396.24 drivers. This was installed by a part time sysadmin.I also think that all elrepo-stuff was removed.
Additionally, I updated the xorg.conf file to direct it to the correct card (via BusID option), and blacklisted (via install […] /bin/false) both the nouveau and mgag200 modules (the latter one is for the onboard chip). After these changes, the following issues persist:
- nvidia-settings does not come up, but reports “ERROR: Unable to load info from any available system”
- nvidia-smi seems to show that that the card is up and running (output attached). The installer log file (attached) reports that “libGLX” cannot be found, although the files (.so, .so.0) are in /usr/lib and /usr/lib64.
- glxinfo says “direct rendering: NO” (output attached), and no nvidia vendor string for the server side. Also, when I start matlab it tells me “Software OpenGL is used”. The client parts of glxinfo show my local (Windows) configuration.
- The machine comes up in runlevel 3, but can be manually switched to 5
In essence, it is confusing since I’m not even 100% sure that the drivers are working (nvidia-smi seems to show so, but why is nvidia-settings not working?), and I never know for sure how much I’m influenced by the remote connection. I just want to get GLX/direct rendering to work.
Any comments and advice is highly appreciated. I attach a couple of log and config files.
Thank you very much,
Michael
- nvidia-installer log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Aug 17 15:12:48 2018
installer version: 396.24
PATH: /sbin:/bin:/usr/sbin:/usr/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 112 CPUs online; setting concurrency level to 32.
-> Installing NVIDIA driver version 396.24.
-> Performing CC sanity check with CC="/bin/cc".
-> Kernel source path: '/lib/modules/3.10.0-693.17.1.el7.x86_64/source'
-> Kernel output path: '/lib/modules/3.10.0-693.17.1.el7.x86_64/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-693.17.1.el7.x86_64/source" SYSOUT="/lib/modules/3.10.0-693.17.1.el7.x86_64/build"'...
rm -f -r conftest
make[1]: Entering directory `/usr/src/kernels/3.10.0-693.17.1.el7.x86_64'
make[1]: Leaving directory `/usr/src/kernels/3.10.0-693.17.1.el7.x86_64'
-> Building kernel modules
executing: 'cd ./kernel; /bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-693.17.1.el7.x86_64/source" SYSOUT="/lib/modules/3.10.0-693.17.1.el7.x86_64/build"'...
SYMLINK /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset/nv-modeset-kernel.o
SYMLINK /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: console_lock
CONFTEST: acquire_console_sem
CONFTEST: kmem_cache_create
CONFTEST: acpi_evaluate_integer
CONFTEST: on_each_cpu
CONFTEST: ioremap_cache
CONFTEST: smp_call_function
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_remove_bus_device
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: timer_setup
CONFTEST: register_acpi_notifier
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_free
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_disable_all
CONFTEST: drm_atomic_helper_set_config
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_old_atomic_state_iterators_present
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nvlink_linux.o
ld -r -o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia.o
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-interface.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-frontend.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-instance.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/ke
rnel/nvidia/nv.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-acpi.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-chrdev.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-cray.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-dma.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-gvi.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-i2c.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-mempool.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-mmap.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-p2p.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-pat.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-procfs.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-usermap.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-vm.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-vtophys.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kerne
l/nvidia/os-interface.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-mlock.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-pci.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-registry.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/os-usermap.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-pci-table.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-kthread-q.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-memdbg.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-report-err.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv-rsync.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/n
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm.mod.o
CC /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia.mod.o
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz71430/NVIDIA-Linux-x86_64-396.24/kernel/nvidia.ko
-> done.
-> Kernel module compilation complete.
-> Unable to determine if Secure Boot is enabled: No such file or directory
-> Kernel messages:
[ 27.279031] socperf2_0: SocPerf Driver about to register chrdev...
[ 27.279034] socperf2_0: SocPerf Driver: result of alloc_chrdev_region is 0
[ 27.279035] socperf2_0: SocPerf Driver: major number is 239
[ 27.279037] socperf2_0: SocPerf Driver: detected 112 CPUs in lwpmudrv_Load
[ 27.279040] socperf2_0: SocPerf Driver v2.0.0 has been loaded.
[ 28.300925] sep4_0: PMU collection driver v4.0.0 has been loaded.
[ 28.300930] sep4_0: Chipset support is enabled.
[ 28.300931] sep4_0: Graphics support is enabled.
[ 28.300933] sep4_0: IDT vector 0x21 will be used for handling PMU interrupts.
[ 31.806505] vtss++ kernel module ("v1.8.73-486011 Intel(R) VTune(TM) Amplifier") registered
[ 446.852663] nvidia 0000:41:00.0: irq 160 for MSI/MSI-X
[ 1306.287227] [drm] [nvidia-drm] [GPU ID 0x00004100] Unloading driver
[ 1306.305521] nvidia-modeset: Unloading
[ 1306.320076] nvidia-nvlink: Unregistered the Nvlink Core, major device number 243
[ 1318.399021] VFIO - User Level meta-driver version: 0.3
[ 1318.462023] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 1318.462827] vgaarb: device changed decodes: PCI:0000:41:00.0,olddecodes=none,decodes=none:owns=none
[ 1318.463141] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 396.24 Thu Apr 26 00:10:09 PDT 2018 (using threaded interrupts)
[ 1318.486364] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 234
[ 1318.491755] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 396.24 Wed Apr 25 23:54:18 PDT 2018
[ 1318.495712] [drm] [nvidia-drm] [GPU ID 0x00004100] Loading driver
[ 1318.499470] [drm] [nvidia-drm] [GPU ID 0x00004100] Unloading driver
[ 1318.504633] nvidia-modeset: Unloading
[ 1318.510305] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 1318.514632] nvidia-nvlink: Unregistered the Nvlink Core, major device number 235
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: "libGL.so.396.24"
-> Skipping GLX non-GLVND file: "libGL.so.1"
-> Skipping GLX non-GLVND file: "libGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.396.24"
-> Skipping EGL non-GLVND file: "libEGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.1"
-> Skipping GLX non-GLVND file: "./32/libGL.so.396.24"
-> Skipping EGL non-GLVND file: "./32/libEGL.so.396.24"
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Checking for libglvnd installation.
Checking libGLdispatch...
Checking libGLdispatch dispatch table
Checking call through libGLdispatch
All OK
libGLdispatch is OK
Checking for libGLX
Can't load libGLX from libGLX.so.0: libGLX.so.0: cannot open shared object file: No such file or directory
Checking for libEGL
eglInitialize failed
Checking entrypoint library libOpenGL.so.0
Checking call through library libOpenGL.so.0
All OK
Entrypoint library libOpenGL.so.0 is OK
Checking entrypoint library libGL.so.1
Checking call through library libGL.so.1
glGetString was not called
Found libglvnd libraries: libOpenGL.so.0 libGLdispatch.so.0
Missing libglvnd libraries: libGL.so.1 libEGL.so.1 libGLX.so.0
-> An incomplete installation of libglvnd was found. Do you want to install a full copy of libglvnd? This will overwrite any existing libglvnd libraries. (Answer: Install and overwrite existing files)
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (396.24):
executing: '/sbin/ldconfig'...
executing: '/sbin/depmod -a '...
-> done.
-> Driver file installation is complete.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
-> Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 396.24) is now complete.
- xorg.conf file
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 396.24 (buildmeister@swio-display-x64-rhel04-13) Thu Apr 26 01:13:52 PDT 2018
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
FontPath "/usr/share/fonts/default/Type1"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
BusID "PCI:65:0:0"
Option "AllowEmptyInitialConfiguration" "on"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
- xorg.5.log file
[ 84068.099]
X.Org X Server 1.17.2
Release Date: 2015-06-16
[ 84068.099] X Protocol Version 11, Revision 0
[ 84068.099] Build Operating System: 2.6.32-573.18.1.el6.x86_64
[ 84068.099] Current Operating System: Linux vienna.ou.edu 3.10.0-693.17.1.el7.x86_64 #1 SMP Thu Jan 25 20:13:58 UTC 2018 x86_64
[ 84068.099] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0-693.17.1.el7.x86_64 root=/dev/mapper/centos-root ro crashkernel=auto rd.lvm.lv=centos/root rd.lvm.lv=centos/swap rhgb quiet LANG=en_US.UTF-8
[ 84068.099] Build Date: 06 November 2016 12:43:39AM
[ 84068.099] Build ID: xorg-x11-server 1.17.2-22.el7
[ 84068.099] Current version of pixman: 0.34.0
[ 84068.099] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 84068.099] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 84068.099] (==) Log file: "/var/log/Xorg.5.log", Time: Sat Aug 18 14:38:14 2018
[ 84068.099] (==) Using config file: "/etc/X11/xorg.conf"
[ 84068.099] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 84068.099] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 84068.099] (==) ServerLayout "Layout0"
[ 84068.099] (**) |-->Screen "Screen0" (0)
[ 84068.099] (**) | |-->Monitor "Monitor0"
[ 84068.099] (**) | |-->Device "Device0"
[ 84068.099] (**) |-->Input Device "Keyboard0"
[ 84068.099] (**) |-->Input Device "Mouse0"
[ 84068.099] (==) Automatically adding devices
[ 84068.099] (==) Automatically enabling devices
[ 84068.099] (==) Automatically adding GPU devices
[ 84068.099] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 84068.099] (**) FontPath set to:
/usr/share/fonts/default/Type1,
catalogue:/etc/X11/fontpath.d,
built-ins
[ 84068.099] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 84068.099] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 84068.099] (WW) Disabling Keyboard0
[ 84068.099] (WW) Disabling Mouse0
[ 84068.099] (II) Loader magic: 0x560cc5f1c020
[ 84068.099] (II) Module ABI versions:
[ 84068.099] X.Org ANSI C Emulation: 0.4
[ 84068.099] X.Org Video Driver: 19.0
[ 84068.099] X.Org XInput driver : 21.0
[ 84068.099] X.Org Server Extension : 9.0
[ 84068.100] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 84068.100] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 84068.119] (--) PCI:*(0:9:0:0) 102b:0534:1028:06bc rev 0, Mem @ 0x90000000/16777216, 0x91800000/16384, 0x91000000/8388608, BIOS @ 0x????????/131072
[ 84068.119] (--) PCI: (0:65:0:0) 10de:1430:10de:1190 rev 161, Mem @ 0xac000000/16777216, 0xdffe0000000/268435456, 0xdfff0000000/33554432, I/O @ 0x00008000/128, BIOS @ 0x????????/524288
[ 84068.119] (II) LoadModule: "glx"
[ 84068.119] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 84068.124] (II) Module glx: vendor="NVIDIA Corporation"
[ 84068.124] compiled for 4.0.2, module version = 1.0.0
[ 84068.124] Module class: X.Org Server Extension
[ 84068.124] (II) NVIDIA GLX Module 396.24 Wed Apr 25 23:17:01 PDT 2018
[ 84068.124] (II) LoadModule: "nvidia"
[ 84068.124] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 84068.124] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 84068.124] Module class: X.Org Video Driver
[ 84068.125] (II) NVIDIA dlloader X Driver 396.24 Wed Apr 25 22:53:34 PDT 2018
[ 84068.125] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 84068.125] (++) using VT number 1
[ 84068.126] (EE) No devices detected.
[ 84068.126] (EE)
Fatal server error:
[ 84068.126] (EE) no screens found(EE)
[ 84068.126] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 84068.126] (EE) Please also check the log file at "/var/log/Xorg.5.log" for additional information.
[ 84068.126] (EE)
- Outputs of lspci for the two GPUs:
09:00.0 VGA compatible controller [0300]: Matrox Electronics Systems Ltd. G200eR2 [102b:0534] (prog-if 00 [VGA controller])
41:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM206GL [Quadro M2000] [10de:1430] (rev a1) (prog-if 00 [VGA controller])
41:00.0 VGA compatible controller: NVIDIA Corporation GM206GL [Quadro M2000] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1190
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 149
NUMA node: 1
Region 0: Memory at ac000000 (32-bit, non-prefetchable)
Region 1: Memory at dffe0000000 (64-bit, prefetchable)
Region 3: Memory at dfff0000000 (64-bit, prefetchable)
Region 5: I/O ports at 8000
[virtual] Expansion ROM at ad080000 [disabled]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
09:00.0 VGA compatible controller: Matrox Electronics Systems Ltd. G200eR2 (prog-if 00 [VGA controller])
Subsystem: Dell Device 06bc
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 64 (4000ns min, 8000ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 18
NUMA node: 0
Region 0: Memory at 90000000 (32-bit, prefetchable)
Region 1: Memory at 91800000 (32-bit, non-prefetchable)
Region 2: Memory at 91000000 (32-bit, non-prefetchable)
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: mgag200
Kernel modules: mgag200
- Outputs of glxinfo:
name of display: localhost:10.0
display: localhost:10 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multisample_coverage, GLX_NV_present_video,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_NV_video_capture, GLX_NV_video_out, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
OpenGL vendor string: Intel
OpenGL renderer string: Intel(R) HD Graphics 620
OpenGL version string: 1.4 (4.4.0 - Build 21.20.16.4550)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_transpose_matrix,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object,
GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_texture3D, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_IBM_texture_mirrored_repeat,
GL_NV_blend_square, GL_NV_texgen_reflection, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod
58 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
0x07c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x07d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 None
0x07e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
0x07f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x080 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x081 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 None
0x082 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 None
0x083 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 None
0x084 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x085 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 2 1 None
0x086 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x087 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 2 1 None
0x088 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x089 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 2 1 None
0x08a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x08b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 2 1 None
0x08c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x08d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 2 1 None
0x08e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x08f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 2 1 None
0x090 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x091 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 4 1 None
0x092 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x093 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 4 1 None
0x094 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x095 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x096 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x097 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 4 1 None
0x098 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 4 1 None
0x09a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x09c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x09d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x09e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 8 1 None
0x09f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x0a0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 8 1 None
0x0a1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x0a2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 8 1 None
0x0a3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x0a4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 8 1 None
0x0a5 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x0a6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 8 1 None
0x0a7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x0a8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 8 1 None
0x0a9 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x0aa 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 16 1 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x0ac 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 16 1 None
0x0ad 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x0ae 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 16 1 None
0x0af 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x0b0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 16 1 None
0x0b1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x0b2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 16 1 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x041 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
58 GLXFBConfigs:
0x042 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x043 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 None
0x044 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
0x045 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x046 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
0x047 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x048 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 None
0x049 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 None
0x04a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 None
0x04b 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 None
0x04c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x04d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 2 1 None
0x04e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x04f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 2 1 None
0x050 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x051 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 2 1 None
0x052 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 2 1 None
0x053 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 2 1 None
0x054 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 2 1 None
0x055 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 2 1 None
0x056 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 2 1 None
0x057 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 2 1 None
0x058 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x059 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 4 1 None
0x05a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x05b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 4 1 None
0x05c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x05d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x05e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 None
0x05f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 4 1 None
0x060 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 None
0x061 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 4 1 None
0x062 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 None
0x063 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x064 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 4 1 None
0x065 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x066 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 8 1 None
0x067 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x068 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 8 1 None
0x069 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x06a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 8 1 None
0x06b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x06c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 8 1 None
0x06d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x06e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 8 1 None
0x06f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x070 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 8 1 None
0x071 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x072 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 16 1 None
0x073 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x074 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 16 1 None
0x075 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x076 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 16 1 None
0x077 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x078 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 16 1 None
0x079 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x07a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 16 1 None
0x07b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
- Output of nvidia-smi
Mon Aug 20 15:28:35 2018
| NVIDIA-SMI 396.24 Driver Version: 396.24 |
| 0 Quadro M2000 Off | 00000000:41:00.0 Off | N/A |
| 56% 30C P8 7W / 75W | 24MiB / 4043MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 28266 G /usr/bin/Xorg 12MiB |
| 0 28354 G gnome-shell 9MiB |
