Thank you!
Tried that. Same problem. Below is my Xorg.1.log
[rassolov@phe ~]$ more /var/log/Xorg.1.log
[145446.755] _XSERVTransSocketUNIXCreateListener: …SocketCreateListener() failed
[145446.755] _XSERVTransMakeAllCOTSServerListeners: server already running
[145446.767] (–) Log file renamed from “/var/log/Xorg.pid-21325.log” to “/var/log/Xorg.1.log”
[145446.768]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[145446.768] X Protocol Version 11, Revision 0
[145446.768] Build Operating System: 4.15.3-300.fc27.x86_64
[145446.768] Current Operating System: Linux phe.chem.sc.edu 4.17.14-202.fc28.x86_64 #1 SMP Wed Aug 15 12:29:25 UTC 2018 x86_64
[145446.768] Kernel command line: BOOT_IMAGE=/vmlinuz-4.17.14-202.fc28.x86_64 root=UUID=9a2a6004-94ec-436e-9b1f-371237b07716 ro rhgb quiet LANG=en_US.UTF-8 rd.driver.blacklist=nouveau
[145446.768] Build Date: 23 April 2018 06:16:50PM
[145446.768] Build ID: xorg-x11-server 1.19.6-8.fc28
[145446.768] Current version of pixman: 0.34.0
[145446.768] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[145446.768] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[145446.768] (==) Log file: “/var/log/Xorg.1.log”, Time: Fri Aug 24 09:18:04 2018
[145446.768] (==) Using config directory: “/etc/X11/xorg.conf.d”
[145446.768] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[145446.768] (==) No Layout section. Using the first Screen section.
[145446.768] (==) No screen section available. Using defaults.
[145446.769] () |–>Screen “Default Screen Section” (0)
[145446.769] () | |–>Monitor “”
[145446.769] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[145446.769] () Option “IndirectGLX” “on”
[145446.769] (==) Automatically adding devices
[145446.769] (==) Automatically enabling devices
[145446.769] (==) Automatically adding GPU devices
[145446.769] (==) Automatically binding GPU devices
[145446.769] (==) Max clients allowed: 256, resource mask: 0x1fffff
[145446.769] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[145446.769] (==) ModulePath set to “/usr/lib64/xorg/modules”
[145446.769] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[145446.769] (II) Loader magic: 0x825e00
[145446.769] (II) Module ABI versions:
[145446.769] X.Org ANSI C Emulation: 0.4
[145446.769] X.Org Video Driver: 23.0
[145446.769] X.Org XInput driver : 24.1
[145446.769] X.Org Server Extension : 10.0
[145446.770] (++) using VT number 2
[145446.773] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_322
[145446.773] (II) xfree86: Adding drm device (/dev/dri/card0)
[145446.774] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[145446.777] () OutputClass “nvidia” ModulePath extended to “/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules”
[145446.777] () OutputClass “nvidia” setting /dev/dri/card0 as PrimaryGPU
[145446.781] (–) PCI:*(0:101:0:0) 10de:1c30:10de:11b3 rev 161, Mem @ 0xd7000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x???/131072
[145446.781] (II) LoadModule: “glx”
[145446.781] (II) Loading /usr/lib64/nvidia/xorg/libglx.so
[145446.787] (II) Module glx: vendor=“NVIDIA Corporation”
[145446.787] compiled for 4.0.2, module version = 1.0.0
[145446.787] Module class: X.Org Server Extension
[145446.787] (II) NVIDIA GLX Module 396.54 Tue Aug 14 22:37:05 PDT 2018
[145446.787] (II) Applying OutputClass “nvidia” to /dev/dri/card0
[145446.787] loading driver: nvidia
[145447.019] (==) Matched nvidia as autoconfigured driver 0
[145447.020] (==) Matched nouveau as autoconfigured driver 1
[145447.020] (==) Matched nv as autoconfigured driver 2
[145447.020] (==) Matched nouveau as autoconfigured driver 3
[145447.020] (==) Matched nv as autoconfigured driver 4
[145447.020] (==) Matched modesetting as autoconfigured driver 5
[145447.020] (==) Matched fbdev as autoconfigured driver 6
[145447.020] (==) Matched vesa as autoconfigured driver 7
[145447.020] (==) Assigned the driver to the xf86ConfigLayout
[145447.020] (II) LoadModule: “nvidia”
[145447.020] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[145447.021] (II) Module nvidia: vendor=“NVIDIA Corporation”
[145447.021] compiled for 4.0.2, module version = 1.0.0
[145447.021] Module class: X.Org Video Driver
[145447.021] (II) LoadModule: “nouveau”
[145447.021] (II) Loading /usr/lib64/xorg/modules/drivers/nouveau_drv.so
[145447.021] (II) Module nouveau: vendor=“X.Org Foundation”
[145447.021] compiled for 1.19.6, module version = 1.0.15
[145447.021] ABI class: X.Org Video Driver, version 23.0
[145447.021] (II) LoadModule: “nv”
[145447.022] (WW) Warning, couldn’t open module nv
[145447.022] (II) UnloadModule: “nv”
[145447.022] (II) Unloading nv
[145447.022] (EE) Failed to load module “nv” (module does not exist, 0)
[145447.022] (II) LoadModule: “modesetting”
[145447.022] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[145447.022] (II) Module modesetting: vendor=“X.Org Foundation”
[145447.022] compiled for 1.19.6, module version = 1.19.6
[145447.022] Module class: X.Org Video Driver
[145447.022] ABI class: X.Org Video Driver, version 23.0
[145447.022] (II) LoadModule: “fbdev”
[145447.022] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[145447.022] (II) Module fbdev: vendor=“X.Org Foundation”
[145447.022] compiled for 1.19.6, module version = 0.4.3
[145447.022] (II) LoadModule: “vesa”
[145447.023] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[145447.023] (II) Module vesa: vendor=“X.Org Foundation”
[145447.023] compiled for 1.19.6, module version = 2.4.0
[145447.023] Module class: X.Org Video Driver
[145447.023] ABI class: X.Org Video Driver, version 23.0
[145447.023] (II) NVIDIA dlloader X Driver 396.54 Tue Aug 14 22:15:03 PDT 2018
[145447.023] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[145447.023] (II) NOUVEAU driver
[145447.023] (II) NOUVEAU driver for NVIDIA chipset families :
[145447.023] RIVA TNT (NV04)
[145447.023] RIVA TNT2 (NV05)
[145447.023] GeForce 256 (NV10)
[145447.023] GeForce 2 (NV11, NV15)
[145447.023] GeForce 4MX (NV17, NV18)
[145447.023] GeForce 3 (NV20)
[145447.023] GeForce 4Ti (NV25, NV28)
[145447.023] GeForce FX (NV3x)
[145447.023] GeForce 6 (NV4x)
[145447.023] GeForce 7 (G7x)
[145447.023] GeForce 8 (G8x)
[145447.023] GeForce GTX 200 (NVA0)
[145447.023] GeForce GTX 400 (NVC0)
[145447.023] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[145447.024] (II) FBDEV: driver for framebuffer: fbdev
[145447.024] (II) VESA: driver for VESA chipsets: vesa
[145447.024] (II) systemd-logind: releasing fd for 226:0
[145447.025] (II) Loading sub module “fb”
[145447.025] (II) LoadModule: “fb”
[145447.025] (II) Loading /usr/lib64/xorg/modules/libfb.so
[145447.025] (II) Module fb: vendor=“X.Org Foundation”
[145447.025] compiled for 1.19.6, module version = 1.0.0
[145447.025] ABI class: X.Org ANSI C Emulation, version 0.4
[145447.025] (II) Loading sub module “wfb”
[145447.025] (II) LoadModule: “wfb”
[145447.026] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[145447.026] (II) Module wfb: vendor=“X.Org Foundation”
[145447.026] compiled for 1.19.6, module version = 1.0.0
[145447.026] ABI class: X.Org ANSI C Emulation, version 0.4
[145447.026] (II) Loading sub module “ramdac”
[145447.026] (II) LoadModule: “ramdac”
[145447.026] (II) Module “ramdac” already built-in
[145447.027] (WW) Falling back to old probe method for modesetting
[145447.027] (WW) Falling back to old probe method for fbdev
[145447.027] (II) Loading sub module “fbdevhw”
[145447.027] (II) LoadModule: “fbdevhw”
[145447.027] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[145447.027] (II) Module fbdevhw: vendor=“X.Org Foundation”
[145447.027] compiled for 1.19.6, module version = 0.0.2
[145447.027] ABI class: X.Org Video Driver, version 23.0
[145447.027] (EE) open /dev/fb0: No such file or directory
[145447.027] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[145447.027] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[145447.027] (==) NVIDIA(0): RGB weight 888
[145447.027] (==) NVIDIA(0): Default visual is TrueColor
[145447.027] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[145447.027] (II) Applying OutputClass “nvidia” options to /dev/dri/card0
[145447.028] () NVIDIA(0): Option “SLI” “Auto”
[145447.028] () NVIDIA(0): Option “BaseMosaic” “on”
[145447.028] () NVIDIA(0): Option “AllowEmptyInitialConfiguration”
[145447.028] () NVIDIA(0): NVIDIA SLI auto-select rendering option.
[145447.028] () NVIDIA(0): Enabling 2D acceleration
[145447.028] (WW) NVIDIA(0): Failed to initialize Base Mosaic! Reason: Only one GPU
[145447.028] (WW) NVIDIA(0): detected. Only one GPU will be used for this X screen.
[145447.030] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:101:0:0
[145447.030] (–) NVIDIA(0): DFP-0
[145447.030] (–) NVIDIA(0): DFP-1
[145447.030] (–) NVIDIA(0): DFP-2
[145447.030] (–) NVIDIA(0): DFP-3
[145447.030] (–) NVIDIA(0): DFP-4
[145447.030] (–) NVIDIA(0): DFP-5
[145447.030] (–) NVIDIA(0): DFP-6
[145447.030] (–) NVIDIA(0): DFP-7 (boot)
[145447.032] (II) NVIDIA(0): NVIDIA GPU Quadro P2000 (GP106GL-A) at PCI:101:0:0 (GPU-0)
[145447.032] (–) NVIDIA(0): Memory: 5242880 kBytes
[145447.032] (–) NVIDIA(0): VideoBIOS: 86.06.3f.00.0d
[145447.032] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[145447.032] (–) NVIDIA(GPU-0): DFP-0: disconnected
[145447.032] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[145447.032] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-1: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[145447.033] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-2: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[145447.033] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-3: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[145447.033] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-4: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[145447.033] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-5: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[145447.033] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[145447.033] (–) NVIDIA(GPU-0): DFP-6: disconnected
[145447.033] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[145447.033] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[145447.095] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): connected
[145447.095] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): Internal TMDS
[145447.095] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): 165.0 MHz maximum pixel clock
[145447.098] (==) NVIDIA(0):
[145447.098] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[145447.098] (==) NVIDIA(0): will be used as the requested mode.
[145447.098] (II) NVIDIA(0): Validated MetaModes:
[145447.098] (II) NVIDIA(0): “DFP-7:nvidia-auto-select”
[145447.098] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1200
[145447.101] (–) NVIDIA(0): DPI set to (93, 95); computed from “UseEdidDpi” X config
[145447.101] (–) NVIDIA(0): option
[145447.101] (II) UnloadModule: “nouveau”
[145447.101] (II) Unloading nouveau
[145447.101] (II) UnloadModule: “modesetting”
[145447.101] (II) Unloading modesetting
[145447.101] (II) UnloadModule: “fbdev”
[145447.101] (II) Unloading fbdev
[145447.101] (II) UnloadSubModule: “fbdevhw”
[145447.101] (II) Unloading fbdevhw
[145447.102] (II) UnloadModule: “vesa”
[145447.102] (II) Unloading vesa
[145447.102] (–) Depth 24 pixmap format is 32 bpp
[145447.102] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[145447.102] (II) NVIDIA: access.
[145447.104] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[145447.104] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[145447.104] (II) NVIDIA(0): configuration option may not be set correctly. When the
[145447.104] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[145447.104] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[145447.104] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[145447.104] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[145447.104] (II) NVIDIA(0): Config Options in the README.
[145447.124] (II) NVIDIA(0): Setting mode “DFP-7:nvidia-auto-select”
[145447.173] (==) NVIDIA(0): Disabling shared memory pixmaps
[145447.173] (==) NVIDIA(0): Backing store enabled
[145447.173] (==) NVIDIA(0): Silken mouse enabled
[145447.173] (==) NVIDIA(0): DPMS enabled
[145447.173] (WW) NVIDIA(0): Option “PrimaryGPU” is not used
[145447.173] (II) Loading sub module “dri2”
[145447.173] (II) LoadModule: “dri2”
[145447.173] (II) Module “dri2” already built-in
[145447.173] (II) NVIDIA(0): [DRI2] Setup complete
[145447.173] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[145447.173] (–) RandR disabled
[145447.174] (II) SELinux: Disabled on system
[145447.174] (II) Initializing extension GLX
[145447.213] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[145447.213] () Power Button: Applying InputClass “evdev keyboard catchall”
[145447.213] () Power Button: Applying InputClass “libinput keyboard catchall”
[145447.213] () Power Button: Applying InputClass “system-keyboard”
[145447.213] (II) LoadModule: “libinput”
[145447.213] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[145447.215] (II) Module libinput: vendor=“X.Org Foundation”
[145447.215] compiled for 1.19.6, module version = 0.27.1
[145447.215] Module class: X.Org XInput Driver
[145447.215] ABI class: X.Org XInput driver, version 24.1
[145447.215] (II) Using input driver ‘libinput’ for ‘Power Button’
[145447.216] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 39 paused 0
[145447.216] () Power Button: always reports core events
[145447.216] () Option “Device” “/dev/input/event1”
[145447.216] () Option “_source” “server/udev”
[145447.217] (II) event1 - Power Button: is tagged by udev as: Keyboard
[145447.217] (II) event1 - Power Button: device is a keyboard
[145447.217] (II) event1 - Power Button: device removed
[145447.217] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/INT3510:00/PNP0C0C:00/input/input1/event1”
[145447.217] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[145447.217] () Option “xkb_layout” “us”
[145447.217] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[145447.217] () Sleep Button: Applying InputClass “evdev keyboard catchall”
[145447.217] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[145447.217] () Sleep Button: Applying InputClass “system-keyboard”
[145447.217] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[145447.218] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 42 paused 0
[145447.218] () Sleep Button: always reports core events
[145447.218] () Option “Device” “/dev/input/event0”
[145447.218] () Option “_source” “server/udev”
[145447.218] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[145447.218] (II) event0 - Sleep Button: device is a keyboard
[145447.218] (II) event0 - Sleep Button: device removed
[145447.218] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/INT3510:00/PNP0C0E:00/input/input0/event0”
[145447.218] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 7)
[145447.218] () Option “xkb_layout” “us”
[145447.219] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[145447.219] (II) event0 - Sleep Button: device is a keyboard
[145447.219] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[145447.219] () Power Button: Applying InputClass “evdev keyboard catchall”
[145447.219] () Power Button: Applying InputClass “libinput keyboard catchall”
[145447.219] () Power Button: Applying InputClass “system-keyboard”
[145447.219] (II) Using input driver ‘libinput’ for ‘Power Button’
[145447.219] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 43 paused 0
[145447.219] () Power Button: always reports core events
[145447.219] () Option “Device” “/dev/input/event2”
[145447.219] () Option “_source” “server/udev”
[145447.220] (II) event2 - Power Button: is tagged by udev as: Keyboard
[145447.220] (II) event2 - Power Button: device is a keyboard
[145447.220] (II) event2 - Power Button: device removed
[145447.220] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[145447.220] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 8)
[145447.220] () Option “xkb_layout” “us”
[145447.220] (II) config/udev: Adding input device Microsoft Wired Keyboard 600 (/dev/input/event4)
[145447.220] () Microsoft Wired Keyboard 600: Applying InputClass “evdev keyboard catchall”
[145447.220] () Microsoft Wired Keyboard 600: Applying InputClass “libinput keyboard catchall”
[145447.220] () Microsoft Wired Keyboard 600: Applying InputClass “system-keyboard”
[145447.220] (II) Using input driver ‘libinput’ for ‘Microsoft Wired Keyboard 600’
[145447.221] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
[145447.221] () Microsoft Wired Keyboard 600: always reports core events
[145447.221] () Option “Device” “/dev/input/event4”
[145447.221] () Option “_source” “server/udev”
[145447.221] (II) event4 - Microsoft Wired Keyboard 600: is tagged by udev as: Keyboard
[145447.221] (II) event4 - Microsoft Wired Keyboard 600: device is a keyboard
[145447.221] (II) event4 - Microsoft Wired Keyboard 600: device removed
[145447.221] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:045E:07F8.0002/input/input4/event4”
[145447.221] (II) XINPUT: Adding extended input device “Microsoft Wired Keyboard 600” (type: KEYBOARD, id 9)
[145447.221] () Option “xkb_layout” “us”
[145447.222] (II) event4 - Microsoft Wired Keyboard 600: is tagged by udev as: Keyboard
[145447.222] (II) event4 - Microsoft Wired Keyboard 600: device is a keyboard
[145447.222] (II) config/udev: Adding input device Microsoft Wired Keyboard 600 (/dev/input/event5)
[145447.222] () Microsoft Wired Keyboard 600: Applying InputClass “evdev keyboard catchall”
[145447.222] () Microsoft Wired Keyboard 600: Applying InputClass “libinput keyboard catchall”
[145447.222] () Microsoft Wired Keyboard 600: Applying InputClass “system-keyboard”
[145447.222] (II) Using input driver ‘libinput’ for ‘Microsoft Wired Keyboard 600’
[145447.223] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 45 paused 0
[145447.223] () Microsoft Wired Keyboard 600: always reports core events
[145447.223] () Option “Device” “/dev/input/event5”
[145447.223] () Option “_source” “server/udev”
[145447.223] (II) event5 - Microsoft Wired Keyboard 600: is tagged by udev as: Keyboard
[145447.223] (II) event5 - Microsoft Wired Keyboard 600: device is a keyboard
[145447.223] (II) event5 - Microsoft Wired Keyboard 600: device removed
[145447.223] (II) libinput: Microsoft Wired Keyboard 600: needs a virtual subdevice
[145447.223] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:045E:07F8.0003/input/input5/event5”
[145447.223] (II) XINPUT: Adding extended input device “Microsoft Wired Keyboard 600” (type: MOUSE, id 10)
[145447.223] () Option “AccelerationScheme” “none”
[145447.223] () Microsoft Wired Keyboard 600: (accel) selected scheme none/0
[145447.223] () Microsoft Wired Keyboard 600: (accel) acceleration factor: 2.000
[145447.223] () Microsoft Wired Keyboard 600: (accel) acceleration threshold: 4
[145447.224] (II) event5 - Microsoft Wired Keyboard 600: is tagged by udev as: Keyboard
[145447.224] (II) event5 - Microsoft Wired Keyboard 600: device is a keyboard
[145447.224] (II) config/udev: Adding input device Microsoft Microsoft 3-Button Mouse with IntelliEye™ (/dev/input/event3)
[145447.224] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: Applying InputClass “evdev pointer catchall”
[145447.224] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: Applying InputClass “libinput pointer catchall”
[145447.224] (II) Using input driver ‘libinput’ for ‘Microsoft Microsoft 3-Button Mouse with IntelliEye™’
[145447.225] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 46 paused 0
[145447.225] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: always reports core events
[145447.225] () Option “Device” “/dev/input/event3”
[145447.225] () Option “_source” “server/udev”
[145447.225] (II) event3 - Microsoft Microsoft 3-Button Mouse with IntelliEye™: is tagged by udev as: Mouse
[145447.225] (II) event3 - Microsoft Microsoft 3-Button Mouse with IntelliEye™: device is a pointer
[145447.225] (II) event3 - Microsoft Microsoft 3-Button Mouse with IntelliEye™: device removed
[145447.225] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:045E:0040.0001/input/input3/event3”
[145447.225] (II) XINPUT: Adding extended input device “Microsoft Microsoft 3-Button Mouse with IntelliEye™” (type: MOUSE, id 11)
[145447.225] () Option “AccelerationScheme” “none”
[145447.225] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) selected scheme none/0
[145447.225] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) acceleration factor: 2.000
[145447.225] () Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) acceleration threshold: 4
[145447.225] (II) config/udev: Adding input device Microsoft Microsoft 3-Button Mouse with IntelliEye™ (/dev/input/mouse0)
[145447.225] (II) No input driver specified, ignoring this device.
[145447.225] (II) This device may have been added with another device file.
[145447.226] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event10)
[145447.226] (II) No input driver specified, ignoring this device.
[145447.226] (II) This device may have been added with another device file.
[145447.226] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event11)
[145447.226] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event12)
[145447.226] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[145447.226] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event7)
[145447.227] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event8)
[145447.227] (II) No input driver specified, ignoring this device.
[145447.227] (II) This device may have been added with another device file.
[145447.227] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event9)
[145447.227] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[145447.227] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[145447.227] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[145447.227] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[145447.228] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event6)
[145447.228] () Eee PC WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[145447.228] () Eee PC WMI hotkeys: Applying InputClass “libinput keyboard catchall”
[145447.228] () Eee PC WMI hotkeys: Applying InputClass “system-keyboard”
[145447.228] (II) Using input driver ‘libinput’ for ‘Eee PC WMI hotkeys’
[145447.228] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 47 paused 0
[145447.228] () Eee PC WMI hotkeys: always reports core events
[145447.228] () Option “Device” “/dev/input/event6”
[145447.228] () Option “_source” “server/udev”
[145447.229] (II) event6 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[145447.229] (II) event6 - Eee PC WMI hotkeys: device is a keyboard
[145447.229] (II) event6 - Eee PC WMI hotkeys: device removed
[145447.229] () Option “config_info” “udev:/sys/devices/platform/eeepc-wmi/input/input6/event6”
[145447.229] (II) XINPUT: Adding extended input device “Eee PC WMI hotkeys” (type: KEYBOARD, id 12)
[145447.229] () Option “xkb_layout” “us”
[145447.232] () Microsoft Wired Keyboard 600: Applying InputClass “evdev keyboard catchall”
[145447.232] () Microsoft Wired Keyboard 600: Applying InputClass “libinput keyboard catchall”
[145447.232] () Microsoft Wired Keyboard 600: Applying InputClass “system-keyboard”
[145447.232] (II) Using input driver ‘libinput’ for ‘Microsoft Wired Keyboard 600’
[145447.232] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[145447.232] () Microsoft Wired Keyboard 600: always reports core events
[145447.232] () Option “Device” “/dev/input/event5”
[145447.232] () Option “_source” “_driver/libinput”
[145447.232] (II) libinput: Microsoft Wired Keyboard 600: is a virtual subdevice
[145447.232] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:045E:07F8.0003/input/input5/event5”
[145447.232] (II) XINPUT: Adding extended input device “Microsoft Wired Keyboard 600” (type: KEYBOARD, id 13)
[145447.232] () Option “xkb_layout” “us”
[145448.228] (–) NVIDIA(GPU-0): DFP-0: disconnected
[145448.228] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[145448.228] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-1: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[145448.229] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-2: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[145448.229] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-3: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[145448.229] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-4: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[145448.229] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-5: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[145448.229] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[145448.229] (–) NVIDIA(GPU-0): DFP-6: disconnected
[145448.229] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[145448.229] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[145448.290] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): connected
[145448.290] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): Internal TMDS
[145448.290] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): 165.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-0: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[145448.557] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-1: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[145448.557] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-2: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[145448.557] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-3: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[145448.557] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-4: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[145448.557] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-5: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[145448.557] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[145448.557] (–) NVIDIA(GPU-0): DFP-6: disconnected
[145448.557] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[145448.557] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[145448.618] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): connected
[145448.618] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): Internal TMDS
[145448.618] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): 165.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-0: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[145449.004] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-1: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[145449.004] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-2: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[145449.004] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-3: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[145449.004] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-4: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[145449.004] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-5: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[145449.004] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[145449.004] (–) NVIDIA(GPU-0): DFP-6: disconnected
[145449.004] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[145449.005] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[145449.066] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): connected
[145449.066] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): Internal TMDS
[145449.066] (–) NVIDIA(GPU-0): Samsung SyncMaster (DFP-7): 165.0 MHz maximum pixel clock
