The Xid errors which I thought were resolved in the 390 series arent quite fixed, in fact along with “Resume swap group failed / Suspend swap group failed” I have also started getting Xid errors, which so far have been Xid 32 and Xid 8. With the nvidia 387 series, they were Xid 31 and Xid 8.
kabir@aries:~|⇒ journalctl -b -1 | grep Xid
Feb 15 20:38:33 aries kernel: NVRM: Xid (PCI:0000:01:00): 32, Channel ID 00000000 intr 00008000
Feb 15 20:38:39 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
Feb 15 20:38:47 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
Feb 15 20:38:55 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
Feb 15 20:39:04 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
[ 20.989]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 20.989] X Protocol Version 11, Revision 0
[ 20.990] Build Operating System: Linux 4.14.12-1-ARCH x86_64
[ 20.990] Current Operating System: Linux aries 4.15.3-1-ARCH #1 SMP PREEMPT Mon Feb 12 23:01:17 UTC 2018 x86_64
[ 20.990] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=1c25165f-8c97-4d07-853c-02e0fb1bc0ab rw quiet resume=/dev/sda2 nvidia-drm.modeset=1
[ 20.990] Build Date: 26 January 2018 10:25:18AM
[ 20.990]
[ 20.990] Current version of pixman: 0.34.0
[ 20.991] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 20.991] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 20.993] (==) Log file: "/home/kabir/.local/share/xorg/Xorg.0.log", Time: Thu Feb 15 16:16:47 2018
[ 21.006] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21.006] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.031] (==) No Layout section. Using the first Screen section.
[ 21.031] (==) No screen section available. Using defaults.
[ 21.031] (**) |-->Screen "Default Screen Section" (0)
[ 21.031] (**) | |-->Monitor "<default monitor>"
[ 21.032] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 21.032] (**) | |-->Device "Nvidia0"
[ 21.032] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 21.032] (==) Automatically adding devices
[ 21.032] (==) Automatically enabling devices
[ 21.032] (==) Automatically adding GPU devices
[ 21.032] (==) Automatically binding GPU devices
[ 21.032] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21.036] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc/".
[ 21.036] Entry deleted from font path.
[ 21.036] (Run 'mkfontdir' on "/usr/share/fonts/misc/").
[ 21.038] (==) FontPath set to:
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[ 21.038] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21.038] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 21.038] (II) Loader magic: 0x55c5df2fdd60
[ 21.038] (II) Module ABI versions:
[ 21.038] X.Org ANSI C Emulation: 0.4
[ 21.038] X.Org Video Driver: 23.0
[ 21.038] X.Org XInput driver : 24.1
[ 21.038] X.Org Server Extension : 10.0
[ 21.039] (++) using VT number 1
[ 21.047] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 21.047] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21.048] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 21.048] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 21.048] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[ 21.049] (--) PCI:*(0:1:0:0) 10de:0ff3:103c:1162 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[ 21.049] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 21.049] (II) LoadModule: "glx"
[ 21.079] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 21.335] (II) Module glx: vendor="NVIDIA Corporation"
[ 21.335] compiled for 4.0.2, module version = 1.0.0
[ 21.335] Module class: X.Org Server Extension
[ 21.341] (II) NVIDIA GLX Module 390.25 Wed Jan 24 19:23:51 PST 2018
[ 21.344] (II) LoadModule: "nvidia"
[ 21.345] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 21.388] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 21.388] compiled for 4.0.2, module version = 1.0.0
[ 21.388] Module class: X.Org Video Driver
[ 21.391] (II) NVIDIA dlloader X Driver 390.25 Wed Jan 24 18:57:05 PST 2018
[ 21.391] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 21.391] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 21.391] (II) systemd-logind: releasing fd for 226:0
[ 21.626] (II) Loading sub module "fb"
[ 21.626] (II) LoadModule: "fb"
[ 21.626] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 21.634] (II) Module fb: vendor="X.Org Foundation"
[ 21.634] compiled for 1.19.6, module version = 1.0.0
[ 21.634] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.634] (II) Loading sub module "wfb"
[ 21.634] (II) LoadModule: "wfb"
[ 21.634] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 21.635] (II) Module wfb: vendor="X.Org Foundation"
[ 21.635] compiled for 1.19.6, module version = 1.0.0
[ 21.635] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.635] (II) Loading sub module "ramdac"
[ 21.635] (II) LoadModule: "ramdac"
[ 21.635] (II) Module "ramdac" already built-in
[ 21.637] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 21.637] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 21.637] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 21.637] (==) NVIDIA(0): RGB weight 888
[ 21.637] (==) NVIDIA(0): Default visual is TrueColor
[ 21.637] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21.637] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 21.637] (**) NVIDIA(0): Option "UseEdidDpi" "false"
[ 21.637] (**) NVIDIA(0): Option "DPI" "96 x 96"
[ 21.637] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 21.637] (**) NVIDIA(0): Enabling 2D acceleration
[ 21.651] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 21.651] (--) NVIDIA(0): CRT-0
[ 21.651] (--) NVIDIA(0): DFP-0
[ 21.652] (--) NVIDIA(0): DFP-1
[ 21.652] (--) NVIDIA(0): DFP-2 (boot)
[ 21.655] (II) NVIDIA(0): NVIDIA GPU Quadro K420 (GK107GL) at PCI:1:0:0 (GPU-0)
[ 21.655] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 21.655] (--) NVIDIA(0): VideoBIOS: 80.07.f0.00.02
[ 21.655] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 21.658] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 21.658] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 21.661] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 21.661] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 21.661] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 21.662] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 21.662] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 21.662] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 21.663] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): connected
[ 21.663] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): Internal DisplayPort
[ 21.663] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): 960.0 MHz maximum pixel clock
[ 21.668] (==) NVIDIA(0):
[ 21.668] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 21.668] (==) NVIDIA(0): will be used as the requested mode.
[ 21.669] (II) NVIDIA(0): Validated MetaModes:
[ 21.669] (II) NVIDIA(0): "DFP-2:nvidia-auto-select"
[ 21.669] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 21.674] (**) NVIDIA(0): DPI set to (96, 96); computed from "DPI" X config option
[ 21.674] (--) Depth 24 pixmap format is 32 bpp
[ 21.675] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 21.675] (II) NVIDIA: access.
[ 21.682] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 21.682] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 21.682] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 21.682] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 21.682] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 21.682] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 21.682] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 21.682] (II) NVIDIA(0): Config Options in the README.
[ 21.705] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[ 21.779] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 21.779] (==) NVIDIA(0): Backing store enabled
[ 21.779] (==) NVIDIA(0): Silken mouse enabled
[ 21.780] (==) NVIDIA(0): DPMS enabled
[ 21.780] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 21.780] (II) Loading sub module "dri2"
[ 21.780] (II) LoadModule: "dri2"
[ 21.780] (II) Module "dri2" already built-in
[ 21.780] (II) NVIDIA(0): [DRI2] Setup complete
[ 21.780] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 21.780] (--) RandR disabled
[ 21.782] (II) Initializing extension GLX
[ 21.782] (II) Indirect GLX disabled.
[ 22.066] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 22.066] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 22.066] (II) LoadModule: "libinput"
[ 22.066] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 22.182] (II) Module libinput: vendor="X.Org Foundation"
[ 22.182] compiled for 1.19.3, module version = 0.26.0
[ 22.182] Module class: X.Org XInput Driver
[ 22.182] ABI class: X.Org XInput driver, version 24.1
[ 22.182] (II) Using input driver 'libinput' for 'Power Button'
[ 22.184] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 33 paused 0
[ 22.184] (**) Power Button: always reports core events
[ 22.184] (**) Option "Device" "/dev/input/event2"
[ 22.184] (**) Option "_source" "server/udev"
[ 22.185] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 22.185] (II) event2 - Power Button: device is a keyboard
[ 22.185] (II) event2 - Power Button: device removed
[ 22.185] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 22.185] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 22.186] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 22.186] (II) event2 - Power Button: device is a keyboard
[ 22.187] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 22.187] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 22.187] (II) Using input driver 'libinput' for 'Power Button'
[ 22.188] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 36 paused 0
[ 22.188] (**) Power Button: always reports core events
[ 22.189] (**) Option "Device" "/dev/input/event1"
[ 22.189] (**) Option "_source" "server/udev"
[ 22.189] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 22.189] (II) event1 - Power Button: device is a keyboard
[ 22.189] (II) event1 - Power Button: device removed
[ 22.190] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 22.190] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 22.191] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 22.191] (II) event1 - Power Button: device is a keyboard
[ 22.192] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 22.192] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 22.192] (II) Using input driver 'libinput' for 'Sleep Button'
[ 22.193] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 37 paused 0
[ 22.193] (**) Sleep Button: always reports core events
[ 22.193] (**) Option "Device" "/dev/input/event0"
[ 22.193] (**) Option "_source" "server/udev"
[ 22.194] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 22.194] (II) event0 - Sleep Button: device is a keyboard
[ 22.194] (II) event0 - Sleep Button: device removed
[ 22.194] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 22.194] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 22.196] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 22.196] (II) event0 - Sleep Button: device is a keyboard
[ 22.197] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 22.197] (II) No input driver specified, ignoring this device.
[ 22.197] (II) This device may have been added with another device file.
[ 22.198] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[ 22.198] (II) No input driver specified, ignoring this device.
[ 22.198] (II) This device may have been added with another device file.
[ 22.199] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/event5)
[ 22.199] (**) PixArt HP USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 22.199] (II) Using input driver 'libinput' for 'PixArt HP USB Optical Mouse'
[ 22.201] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 38 paused 0
[ 22.201] (**) PixArt HP USB Optical Mouse: always reports core events
[ 22.201] (**) Option "Device" "/dev/input/event5"
[ 22.201] (**) Option "_source" "server/udev"
[ 22.202] (II) event5 - PixArt HP USB Optical Mouse: is tagged by udev as: Mouse
[ 22.202] (II) event5 - PixArt HP USB Optical Mouse: device is a pointer
[ 22.202] (II) event5 - PixArt HP USB Optical Mouse: device removed
[ 22.202] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.0/0003:03F0:134A.0003/input/input7/event5"
[ 22.202] (II) XINPUT: Adding extended input device "PixArt HP USB Optical Mouse" (type: MOUSE, id 9)
[ 22.202] (**) Option "AccelerationScheme" "none"
[ 22.202] (**) PixArt HP USB Optical Mouse: (accel) selected scheme none/0
[ 22.202] (**) PixArt HP USB Optical Mouse: (accel) acceleration factor: 2.000
[ 22.202] (**) PixArt HP USB Optical Mouse: (accel) acceleration threshold: 4
[ 22.203] (II) event5 - PixArt HP USB Optical Mouse: is tagged by udev as: Mouse
[ 22.203] (II) event5 - PixArt HP USB Optical Mouse: device is a pointer
[ 22.204] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/mouse0)
[ 22.204] (II) No input driver specified, ignoring this device.
[ 22.204] (II) This device may have been added with another device file.
[ 22.205] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard (/dev/input/event3)
[ 22.205] (**) Chicony HP Business Slim Keyboard: Applying InputClass "libinput keyboard catchall"
[ 22.205] (II) Using input driver 'libinput' for 'Chicony HP Business Slim Keyboard'
[ 22.207] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 39 paused 0
[ 22.207] (**) Chicony HP Business Slim Keyboard: always reports core events
[ 22.207] (**) Option "Device" "/dev/input/event3"
[ 22.207] (**) Option "_source" "server/udev"
[ 22.208] (II) event3 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 22.208] (II) event3 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 22.208] (II) event3 - Chicony HP Business Slim Keyboard: device removed
[ 22.208] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:03F0:2F4A.0001/input/input5/event3"
[ 22.208] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard" (type: KEYBOARD, id 10)
[ 22.210] (II) event3 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 22.210] (II) event3 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 22.211] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard (/dev/input/event4)
[ 22.211] (**) Chicony HP Business Slim Keyboard: Applying InputClass "libinput keyboard catchall"
[ 22.211] (II) Using input driver 'libinput' for 'Chicony HP Business Slim Keyboard'
[ 22.213] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 40 paused 0
[ 22.213] (**) Chicony HP Business Slim Keyboard: always reports core events
[ 22.213] (**) Option "Device" "/dev/input/event4"
[ 22.213] (**) Option "_source" "server/udev"
[ 22.214] (II) event4 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 22.214] (II) event4 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 22.214] (II) event4 - Chicony HP Business Slim Keyboard: device removed
[ 22.214] (II) libinput: Chicony HP Business Slim Keyboard: needs a virtual subdevice
[ 22.214] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:03F0:2F4A.0002/input/input6/event4"
[ 22.214] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard" (type: MOUSE, id 11)
[ 22.214] (**) Option "AccelerationScheme" "none"
[ 22.214] (**) Chicony HP Business Slim Keyboard: (accel) selected scheme none/0
[ 22.214] (**) Chicony HP Business Slim Keyboard: (accel) acceleration factor: 2.000
[ 22.214] (**) Chicony HP Business Slim Keyboard: (accel) acceleration threshold: 4
[ 22.215] (II) event4 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 22.215] (II) event4 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 22.216] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[ 22.216] (II) No input driver specified, ignoring this device.
[ 22.216] (II) This device may have been added with another device file.
[ 22.217] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[ 22.217] (II) No input driver specified, ignoring this device.
[ 22.217] (II) This device may have been added with another device file.
[ 22.217] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[ 22.218] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[ 22.218] (II) No input driver specified, ignoring this device.
[ 22.218] (II) This device may have been added with another device file.
[ 22.219] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event14)
[ 22.219] (II) No input driver specified, ignoring this device.
[ 22.219] (II) This device may have been added with another device file.
[ 22.219] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[ 22.220] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 22.220] (II) No input driver specified, ignoring this device.
[ 22.220] (II) This device may have been added with another device file.
[ 22.221] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event7)
[ 22.221] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 22.221] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 22.223] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 41 paused 0
[ 22.223] (**) HP WMI hotkeys: always reports core events
[ 22.223] (**) Option "Device" "/dev/input/event7"
[ 22.223] (**) Option "_source" "server/udev"
[ 22.223] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 22.223] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 22.223] (II) event7 - HP WMI hotkeys: device removed
[ 22.223] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event7"
[ 22.223] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 12)
[ 22.224] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 22.224] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 22.231] (**) Chicony HP Business Slim Keyboard: Applying InputClass "libinput keyboard catchall"
[ 22.231] (II) Using input driver 'libinput' for 'Chicony HP Business Slim Keyboard'
[ 22.231] (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
[ 22.231] (**) Chicony HP Business Slim Keyboard: always reports core events
[ 22.231] (**) Option "Device" "/dev/input/event4"
[ 22.231] (**) Option "_source" "_driver/libinput"
[ 22.232] (II) libinput: Chicony HP Business Slim Keyboard: is a virtual subdevice
[ 22.232] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:03F0:2F4A.0002/input/input6/event4"
[ 22.232] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard" (type: KEYBOARD, id 13)
[ 24.526] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 24.526] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 24.529] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.529] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 24.529] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 24.530] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 24.530] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 24.530] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 24.531] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): connected
[ 24.531] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): Internal DisplayPort
[ 24.531] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): 960.0 MHz maximum pixel clock
[ 24.534] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 24.534] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 24.537] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.537] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 24.537] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 24.538] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 24.538] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 24.538] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 24.538] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): connected
[ 24.538] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): Internal DisplayPort
[ 24.538] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): 960.0 MHz maximum pixel clock
[ 15660.857] (**) Option "fd" "33"
[ 15660.857] (II) event2 - Power Button: device removed
[ 15660.857] (**) Option "fd" "36"
[ 15660.857] (II) event1 - Power Button: device removed
[ 15660.857] (**) Option "fd" "37"
[ 15660.857] (II) event0 - Sleep Button: device removed
[ 15660.857] (**) Option "fd" "38"
[ 15660.857] (II) event5 - PixArt HP USB Optical Mouse: device removed
[ 15660.857] (**) Option "fd" "39"
[ 15660.857] (II) event3 - Chicony HP Business Slim Keyboard: device removed
[ 15660.857] (**) Option "fd" "40"
[ 15660.857] (**) Option "fd" "41"
[ 15660.857] (II) event7 - HP WMI hotkeys: device removed
[ 15660.858] (**) Option "fd" "40"
[ 15660.858] (II) event4 - Chicony HP Business Slim Keyboard: device removed
[ 15661.130] (II) systemd-logind: got pause for 13:68
[ 15661.130] (II) systemd-logind: got pause for 13:71
[ 15661.130] (II) systemd-logind: got pause for 13:66
[ 15661.130] (II) systemd-logind: got pause for 13:65
[ 15661.130] (II) systemd-logind: got pause for 13:69
[ 15661.130] (II) systemd-logind: got pause for 13:64
[ 15661.130] (II) systemd-logind: got pause for 13:67
[ 15661.150] (WW) NVIDIA(0): Suspend swap group failed.
[ 15661.151] (WW) NVIDIA(0): Resume swap group failed.
[ 15661.170] (WW) NVIDIA(0): Suspend swap group failed.
[ 15661.170] (WW) NVIDIA(0): Resume swap group failed.
[ 15663.233] (II) systemd-logind: got resume for 13:68
[ 15663.235] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 15663.235] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 15663.238] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 15663.238] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 15663.238] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 15663.239] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 15663.239] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15663.239] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15663.239] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): connected
[ 15663.239] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): Internal DisplayPort
[ 15663.239] (--) NVIDIA(GPU-0): HP Z23n (DFP-2): 960.0 MHz maximum pixel clock
[ 15663.250] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[ 15663.316] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 15663.316] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 15663.316] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 15663.316] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 15663.316] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 15663.316] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 15663.316] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 15663.316] (II) NVIDIA(0): Config Options in the README.
[ 15663.316] (WW) NVIDIA(0): Suspend swap group failed.
[ 15663.316] (WW) NVIDIA(0): Resume swap group failed.
[ 15663.319] (WW) NVIDIA(0): Suspend swap group failed.
[ 15663.319] (WW) NVIDIA(0): Resume swap group failed.
[ 15663.351] (WW) NVIDIA(0): Resume swap group failed.
[ 15663.351] (WW) NVIDIA(0): Suspend swap group failed.
[ 15663.353] (WW) NVIDIA(0): Resume swap group failed.
[ 15663.353] (WW) NVIDIA(0): Suspend swap group failed.
[ 15663.391] (II) event4 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 15663.391] (II) event4 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 15663.392] (II) systemd-logind: got resume for 13:71
[ 15663.392] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 15663.392] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 15663.392] (II) systemd-logind: got resume for 13:66
[ 15663.392] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 15663.392] (II) event2 - Power Button: device is a keyboard
[ 15663.392] (II) systemd-logind: got resume for 13:65
[ 15663.392] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 15663.392] (II) event1 - Power Button: device is a keyboard
[ 15663.392] (II) systemd-logind: got resume for 13:69
[ 15663.393] (II) event5 - PixArt HP USB Optical Mouse: is tagged by udev as: Mouse
[ 15663.393] (II) event5 - PixArt HP USB Optical Mouse: device is a pointer
[ 15663.393] (II) systemd-logind: got resume for 13:64
[ 15663.393] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 15663.393] (II) event0 - Sleep Button: device is a keyboard
[ 15663.393] (II) systemd-logind: got resume for 13:67
[ 15663.393] (II) event3 - Chicony HP Business Slim Keyboard: is tagged by udev as: Keyboard
[ 15663.393] (II) event3 - Chicony HP Business Slim Keyboard: device is a keyboard
[ 15663.395] (WW) NVIDIA(0): Suspend swap group failed.
[ 15663.395] (WW) NVIDIA(0): Resume swap group failed.
[ 15689.048] (WW) NVIDIA(0): Resume swap group failed.
[ 15689.048] (WW) NVIDIA(0): Suspend swap group failed.
[ 15689.048] (WW) NVIDIA(0): Resume swap group failed.] (WW) NVIDIA(0): Suspend swap group failed.
[ 15691.247] (WW) NVIDIA(0): Resume swap group failed.
[ 15691.247] (WW) NVIDIA(0): Suspend swap group failed.
[ 15698.841] (WW) NVIDIA(0): Resume swap group failed.
[ 15699.035] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 15699.035] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 15699.035] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[ 15699.035] (EE) systemd-logind: ReleaseControl failed: Connection was disconnected before a reply was received
[ 15699.035] (EE) Server terminated with error (1). Closing log file
nvidia-bug-report.log.gz (76.6 KB)
