Thank you for the fast answer!
I should have posted my xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.87 (buildmeister@swio-display-x64-rhel04-14) Tue Aug 21 17:33:38 PDT 2018
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 410.73
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Ancor Communications Inc ASUS VG278HR"
HorizSync 24.0 - 159.0
VertRefresh 50.0 - 144.0
# Option "DPMS" "FALSE"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro M4000"
# Option "RegistryDwords" "PerfLevelSrc=0x2222"
# Option "TripleBuffer" "True"
EndSection
Section "Screen"
# Removed Option "metamodes" "1920x1080_120 +0+0"
# Removed Option "metamodes" "1920x1080_120 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
# Removed Option "metamodes" "1920x1080_120 +0+0 {ForceCompositionPipeline=On}"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "AllowDFPStereo" "yes"
Option "Stereo" "10"
Option "nvidiaXineramaInfoOrder" "DFP-6.2"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
# Option "ForceStereoFlipping" "True"
# Option "FlatPanelProperties" "Dithering=Disabled"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
# Removed Option "Composite" "disable"
Option "Composite" "Disable"
EndSection
Whatever starts with #, I tried.
The remaining xorg.conf is what worked on all our Computers since 2014, Ubuntu 14.04 with KDE, I don’t understand everything, but it worked magically.
This is my /var/log/Xorg.0.log for one Boot to Desktop and one try to StereoFlipping:
[ 45.425] (--) Log file renamed from "/var/log/Xorg.pid-1860.log" to "/var/log/Xorg.0.log"
[ 45.425]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 45.425] X Protocol Version 11, Revision 0
[ 45.425] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 45.425] Current Operating System: Linux diaz 4.15.0-39-generic #42-Ubuntu SMP Tue Oct 23 15:48:01 UTC 2018 x86_64
[ 45.425] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-39-generic root=UUID=3cf7e2ba-e32e-11e8-b348-901b0e2e6edc ro maybe-ubiquity
[ 45.425] Build Date: 25 October 2018 04:11:27PM
[ 45.425] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support)
[ 45.425] Current version of pixman: 0.34.0
[ 45.425] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 45.425] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 45.425] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 20 17:17:30 2018
[ 45.425] (==) Using config file: "/etc/X11/xorg.conf"
[ 45.425] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 45.425] (==) ServerLayout "Layout0"
[ 45.425] (**) |-->Screen "Screen0" (0)
[ 45.425] (**) | |-->Monitor "Monitor0"
[ 45.425] (**) | |-->Device "Device0"
[ 45.425] (**) |-->Input Device "Keyboard0"
[ 45.425] (**) |-->Input Device "Mouse0"
[ 45.425] (**) Option "Xinerama" "0"
[ 45.425] (==) Automatically adding devices
[ 45.425] (==) Automatically enabling devices
[ 45.425] (==) Automatically adding GPU devices
[ 45.425] (==) Automatically binding GPU devices
[ 45.425] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 45.425] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 45.425] Entry deleted from font path.
[ 45.426] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 45.426] Entry deleted from font path.
[ 45.426] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 45.426] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 45.426] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 45.426] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 45.426] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 45.426] (**) Extension "Composite" is disabled
[ 45.426] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 45.426] (WW) Disabling Keyboard0
[ 45.426] (WW) Disabling Mouse0
[ 45.426] (II) Loader magic: 0x56280cbfa020
[ 45.426] (II) Module ABI versions:
[ 45.426] X.Org ANSI C Emulation: 0.4
[ 45.426] X.Org Video Driver: 23.0
[ 45.426] X.Org XInput driver : 24.1
[ 45.426] X.Org Server Extension : 10.0
[ 45.426] (++) using VT number 1
[ 45.426] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 45.426] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 45.427] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 45.427] (--) PCI:*(0:1:0:0) 10de:13f1:10de:1153 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 45.427] (II) LoadModule: "glx"
[ 45.427] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglx.so
[ 45.870] (II) Module glx: vendor="NVIDIA Corporation"
[ 45.870] compiled for 4.0.2, module version = 1.0.0
[ 45.870] Module class: X.Org Server Extension
[ 45.870] (II) NVIDIA GLX Module 396.54 Tue Aug 14 22:37:05 PDT 2018
[ 45.870] (II) LoadModule: "nvidia"
[ 45.870] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 45.870] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 45.870] Module class: X.Org Video Driver
[ 45.870] (II) NVIDIA dlloader X Driver 396.54 Tue Aug 14 22:15:03 PDT 2018
[ 45.870] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 45.876] (II) Loading sub module "fb"
[ 45.876] (II) LoadModule: "fb"
[ 45.876] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 45.876] (II) Module fb: vendor="X.Org Foundation"
[ 45.876] compiled for 1.19.6, module version = 1.0.0
[ 45.876] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.876] (II) Loading sub module "wfb"
[ 45.876] (II) LoadModule: "wfb"
[ 45.876] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 45.876] (II) Module wfb: vendor="X.Org Foundation"
[ 45.876] (II) Loading sub module "ramdac"
[ 45.876] (II) LoadModule: "ramdac"
[ 45.876] (II) Module "ramdac" already built-in
[ 45.877] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 45.877] (==) NVIDIA(0): RGB weight 888
[ 45.877] (==) NVIDIA(0): Default visual is TrueColor
[ 45.877] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 45.877] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 45.877] (**) NVIDIA(0): Option "Stereo" "10"
[ 45.877] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-6.2"
[ 45.877] (**) NVIDIA(0): Option "SLI" "Off"
[ 45.877] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 45.877] (**) NVIDIA(0): Option "TripleBuffer" "True"
[ 45.877] (**) NVIDIA(0): Option "FlatPanelProperties" "Dithering=Disabled"
[ 45.877] (**) NVIDIA(0): Option "BaseMosaic" "off"
[ 45.877] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 45.877] (**) NVIDIA(0): USB IR emitter stereo requested
[ 45.877] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 45.877] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 45.877] (**) NVIDIA(0): Option "MetaModes" "1920x1080_120 +0+0"
[ 45.877] (**) NVIDIA(0): Option "RegistryDwords" "PerfLevelSrc=0x2222"
[ 45.877] (**) NVIDIA(0): Enabling 2D acceleration
[ 50.507] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 50.507] (--) NVIDIA(0): DFP-2.2
[ 50.507] (--) NVIDIA(0): DFP-0
[ 50.507] (--) NVIDIA(0): DFP-1
[ 50.507] (--) NVIDIA(0): DFP-2 (boot)
[ 50.507] (--) NVIDIA(0): DFP-3
[ 50.507] (--) NVIDIA(0): DFP-4
[ 50.507] (--) NVIDIA(0): DFP-5
[ 50.507] (--) NVIDIA(0): DFP-6
[ 50.507] (--) NVIDIA(0): DFP-7
[ 50.508] (II) NVIDIA(0): NVIDIA GPU Quadro M4000 (GM204GL-A) at PCI:1:0:0 (GPU-0)
[ 50.508] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 50.508] (--) NVIDIA(0): VideoBIOS: 84.04.88.00.5d
[ 50.508] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 50.508] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): connected
[ 50.508] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): Internal DisplayPort
[ 50.508] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): 960.0 MHz maximum pixel clock
[ 50.508] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): supports NVIDIA 3D Vision stereo.
[ 50.508] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 50.508] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 50.508] (--) NVIDIA(GPU-0): DFP-0: 960.0 MHz maximum pixel clock
[ 50.508] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 50.508] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 50.508] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 50.508] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 50.508] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 50.508] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 50.509] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 50.509] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 50.509] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 50.509] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 50.509] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 50.509] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 50.510] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 50.510] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 50.510] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 50.510] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 50.510] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 50.510] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 50.510] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 50.510] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 50.510] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 50.523] (II) NVIDIA(0): Validated MetaModes:
[ 50.523] (II) NVIDIA(0): "1920x1080_120+0+0"
[ 50.523] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 50.526] (WW) NVIDIA(0): Unable to match display device name "DFP-6.2" from
[ 50.526] (WW) NVIDIA(0): nvidiaXineramaInfoOrder
[ 50.526] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[ 50.526] (--) NVIDIA(0): option
[ 50.526] (--) Depth 24 pixmap format is 32 bpp
[ 50.526] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 50.526] (II) NVIDIA: access.
[ 50.541] (II) NVIDIA(0): Setting mode "1920x1080_120+0+0"
[ 62.786] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 62.786] (==) NVIDIA(0): Backing store disabled
[ 62.786] (==) NVIDIA(0): Silken mouse enabled
[ 62.786] (WW) NVIDIA(0): Option "AllowDFPStereo" is not used
[ 62.786] (II) Loading sub module "dri2"
[ 62.786] (II) LoadModule: "dri2"
[ 62.786] (II) Module "dri2" already built-in
[ 62.786] (II) NVIDIA(0): [DRI2] Setup complete
[ 62.786] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 62.786] (--) RandR disabled
[ 62.793] (II) SELinux: Disabled on system
[ 62.793] (II) Initializing extension GLX
[ 62.794] (II) Indirect GLX disabled.
[ 62.869] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 62.869] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 62.869] (II) LoadModule: "libinput"
[ 62.869] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 62.912] (II) Module libinput: vendor="X.Org Foundation"
[ 62.912] compiled for 1.19.6, module version = 0.27.1
[ 62.912] Module class: X.Org XInput Driver
[ 62.912] ABI class: X.Org XInput driver, version 24.1
[ 62.912] (II) Using input driver 'libinput' for 'Power Button'
[ 62.912] (**) Power Button: always reports core events
[ 62.912] (**) Option "Device" "/dev/input/event1"
[ 62.912] (**) Option "_source" "server/udev"
[ 62.912] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 62.912] (II) event1 - Power Button: device is a keyboard
[ 62.912] (II) event1 - Power Button: device removed
[ 62.952] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 62.952] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 62.952] (**) Option "xkb_model" "pc105"
[ 62.952] (**) Option "xkb_layout" "de"
[ 62.952] (**) Option "xkb_variant" "nodeadkeys"
[ 62.964] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 62.964] (II) event1 - Power Button: device is a keyboard
[ 62.964] (II) config/udev: Adding input device Fujitsu FUJ02E3 (/dev/input/event4)
[ 62.964] (**) Fujitsu FUJ02E3: Applying InputClass "libinput keyboard catchall"
[ 62.964] (II) Using input driver 'libinput' for 'Fujitsu FUJ02E3'
[ 62.964] (**) Fujitsu FUJ02E3: always reports core events
[ 62.964] (**) Option "Device" "/dev/input/event4"
[ 62.964] (**) Option "_source" "server/udev"
[ 62.964] (II) event4 - Fujitsu FUJ02E3: is tagged by udev as: Keyboard
[ 62.964] (II) event4 - Fujitsu FUJ02E3: device is a keyboard
[ 62.964] (II) event4 - Fujitsu FUJ02E3: device removed
[ 62.984] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/FUJ02E3:00/input/input4/event4"
[ 62.984] (II) XINPUT: Adding extended input device "Fujitsu FUJ02E3" (type: KEYBOARD, id 7)
[ 62.984] (**) Option "xkb_model" "pc105"
[ 62.984] (**) Option "xkb_layout" "de"
[ 62.984] (**) Option "xkb_variant" "nodeadkeys"
[ 62.984] (II) event4 - Fujitsu FUJ02E3: is tagged by udev as: Keyboard
[ 62.984] (II) event4 - Fujitsu FUJ02E3: device is a keyboard
[ 62.985] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 62.985] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 62.985] (II) Using input driver 'libinput' for 'Power Button'
[ 62.985] (**) Power Button: always reports core events
[ 62.985] (**) Option "Device" "/dev/input/event0"
[ 62.985] (**) Option "_source" "server/udev"
[ 62.985] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 62.985] (II) event0 - Power Button: device is a keyboard
[ 62.985] (II) event0 - Power Button: device removed
[ 63.012] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 63.012] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 63.012] (**) Option "xkb_model" "pc105"
[ 63.012] (**) Option "xkb_layout" "de"
[ 63.012] (**) Option "xkb_variant" "nodeadkeys"
[ 63.012] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 63.012] (II) event0 - Power Button: device is a keyboard
[ 63.013] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 63.013] (II) No input driver specified, ignoring this device.
[ 63.013] (II) This device may have been added with another device file.
[ 63.013] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 63.013] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 63.014] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 63.014] (II) No input driver specified, ignoring this device.
[ 63.014] (II) This device may have been added with another device file.
[ 63.014] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event2)
[ 63.014] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 63.014] (II) Using input driver 'libinput' for 'Logitech USB-PS/2 Optical Mouse'
[ 63.014] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[ 63.014] (**) Option "Device" "/dev/input/event2"
[ 63.014] (**) Option "_source" "server/udev"
[ 63.072] (II) event2 - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[ 63.072] (II) event2 - Logitech USB-PS/2 Optical Mouse: device set to 1000 DPI
[ 63.072] (II) event2 - Logitech USB-PS/2 Optical Mouse: device is a pointer
[ 63.072] (II) event2 - Logitech USB-PS/2 Optical Mouse: device removed
[ 63.104] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/0003:046D:C050.0001/input/input2/event2"
[ 63.104] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 9)
[ 63.104] (**) Option "AccelerationScheme" "none"
[ 63.104] (**) Logitech USB-PS/2 Optical Mouse: (accel) selected scheme none/0
[ 63.104] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[ 63.104] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[ 63.164] (II) event2 - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[ 63.164] (II) event2 - Logitech USB-PS/2 Optical Mouse: device set to 1000 DPI
[ 63.164] (II) event2 - Logitech USB-PS/2 Optical Mouse: device is a pointer
[ 63.165] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[ 63.165] (II) No input driver specified, ignoring this device.
[ 63.165] (II) This device may have been added with another device file.
[ 63.165] (II) config/udev: Adding input device HID 046a:0011 (/dev/input/event3)
[ 63.165] (**) HID 046a:0011: Applying InputClass "libinput keyboard catchall"
[ 63.165] (II) Using input driver 'libinput' for 'HID 046a:0011'
[ 63.165] (**) HID 046a:0011: always reports core events
[ 63.166] (**) Option "Device" "/dev/input/event3"
[ 63.166] (**) Option "_source" "server/udev"
[ 63.166] (II) event3 - HID 046a:0011: is tagged by udev as: Keyboard
[ 63.166] (II) event3 - HID 046a:0011: device is a keyboard
[ 63.166] (II) event3 - HID 046a:0011: device removed
[ 63.180] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.0/0003:046A:0011.0002/input/input3/event3"
[ 63.180] (II) XINPUT: Adding extended input device "HID 046a:0011" (type: KEYBOARD, id 10)
[ 63.180] (**) Option "xkb_model" "pc105"
[ 63.180] (**) Option "xkb_layout" "de"
[ 63.180] (**) Option "xkb_variant" "nodeadkeys"
[ 63.181] (II) event3 - HID 046a:0011: is tagged by udev as: Keyboard
[ 63.181] (II) event3 - HID 046a:0011: device is a keyboard
[ 63.181] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event5)
[ 63.181] (II) No input driver specified, ignoring this device.
[ 63.181] (II) This device may have been added with another device file.
[ 63.181] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[ 63.182] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 63.182] (II) No input driver specified, ignoring this device.
[ 63.182] (II) This device may have been added with another device file.
[ 63.182] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event8)
[ 63.182] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event9)
[ 63.188] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): connected
[ 63.188] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): Internal DisplayPort
[ 63.188] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): 960.0 MHz maximum pixel clock
[ 63.188] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): supports NVIDIA 3D Vision stereo.
[ 165.138] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): connected
[ 165.138] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): Internal DisplayPort
[ 165.138] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): 960.0 MHz maximum pixel clock
[ 165.138] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): supports NVIDIA 3D Vision stereo.
[ 165.138] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 165.138] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 165.138] (--) NVIDIA(GPU-0): DFP-0: 960.0 MHz maximum pixel clock
[ 165.138] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 165.138] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 165.138] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 165.138] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 165.138] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 165.138] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 165.139] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 165.139] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 165.139] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 165.139] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 165.139] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 165.139] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 165.139] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 165.139] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 165.139] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 165.139] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 165.139] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 165.139] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 165.139] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 165.139] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 165.139] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 165.765] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): connected
[ 165.765] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): Internal DisplayPort
[ 165.765] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): 960.0 MHz maximum pixel clock
[ 165.765] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VG278HR (DFP-2.2): supports NVIDIA 3D Vision stereo.
[ 165.765] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 165.765] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 165.765] (--) NVIDIA(GPU-0): DFP-0: 960.0 MHz maximum pixel clock
[ 165.765] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 165.765] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 165.766] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 165.766] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 165.766] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 165.766] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 165.766] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 165.766] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 165.766] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 165.767] (--) NVIDIA(GPU-0):
[ 165.767] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 165.767] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 165.767] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 165.767] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 165.767] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 165.767] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 165.767] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 165.767] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 165.767] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 165.767] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 165.767] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 165.767] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
We use KDE for historical reasons, if needed, I try to bribe my collegues to use something different.
Would be as easy as bathing the cat…
Kind regards,
Nicolai
