Hi guys, I’ve just faced with a problem of distorted and flickered display image in ubuntu 17.04 with the latest nvidia drivers 384.59 with 4k@60hz resolution. 4k@30hz works just fine. 4k@60hz works fine on the same computer under windows 10 and macos 10.12.5 and macos 10.11.6 I extracted edid of the monitor, it is here:
Monitor Asset Manager Report, generated 01.08.2017
Copyright (c) 1995-2016, EnTech Taiwan.
Monitor #1 [Real-time 0x0071]
Model name............... SE42UMS
Manufacturer............. Seiki
Plug and Play ID......... SEK0030
Serial number............
Manufacture date......... 2015, ISO week 22
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 930 x 520 mm (41,9 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,640 - Ry 0,340
Green chromaticity....... Gx 0,300 - Gy 0,690
Blue chromaticity........ Bx 0,138 - By 0,038
White point (default).... Wx 0,282 - Wy 0,297
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-80kHz
Vertical scan range...... 50-75Hz
Video bandwidth.......... 230MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 3840x2160p at 30Hz (16:9)
Modeline............... "3840x2160" 297,000 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
800 x 600p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #3....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 2-channel, 640k max. bit rate at 32/44/48/96 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 300MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. Yes
EDID screen size......... No additional info
3D formats supported..... Not supported
Data payload............. 030C001000B83C200060010203
Reserved video related data
Data payload............. 0E6061
Report information
Date generated........... 01.08.2017
Software revision........ 2.90.0.1020
Data source.............. Real-time 0x0071
Operating system......... 10.0.15063.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,AB,30,00,01,00,00,00,16,19,01,03,80,5D,34,78,0A,CF,74,A3,57,4C,B0,23,
09,48,4C,21,08,00,81,80,45,40,61,40,95,00,01,01,01,01,01,01,01,01,04,74,00,30,F2,70,5A,80,B0,58,
8A,00,BA,89,21,00,00,1E,00,00,00,FF,00,0A,20,20,20,20,20,20,20,20,20,20,20,20,00,00,00,FC,00,53,
45,34,32,55,4D,53,0A,20,20,20,20,20,00,00,00,FD,00,32,4B,1E,50,17,00,0A,20,20,20,20,20,20,01,4E,
02,03,2F,F2,4D,01,03,04,05,07,90,12,13,14,16,9F,20,22,26,09,07,07,11,17,50,83,01,00,00,6D,03,0C,
00,10,00,B8,3C,20,00,60,01,02,03,E3,0E,60,61,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,
18,8C,0A,D0,90,20,40,31,20,0C,40,55,00,C4,8E,21,00,00,18,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,C4,
8E,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,19
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI00018.PCI0001C
00000000 = 2F008086.00100400.06000001.00000010.00000000.00000000.00000000.00000000
00000008 = 2F028086.00100404.06040001.00010010.00000000.00000000.00010100.000000F0
00000018 = 2F088086.00100407.06040001.00010010.00000000.00000000.00020200.2000E0E0
00000028 = 2F288086.00100000.08800001.00800010.00000000.00000000.00000000.00000000
00000029 = 2F298086.00100000.08800001.00000010.00000000.00000000.00000000.00000000
0000002A = 2F2A8086.00100000.08800001.00800010.00000000.00000000.00000000.00000000
0000002C = 2F2C8086.00100006.08002001.00800010.FB33E000.00000000.00000000.00000000
00000088 = 8D7C8086.00100000.FF000005.00800010.00000000.00000000.00000000.00000000
0000008C = 8D628086.02B00407.01060105.00000000.0000F131.0000F121.0000F111.0000F101
000000A0 = 8D318086.02900006.0C033005.00000000.FB320004.00000000.00000000.00000000
000000B0 = 8D3A8086.00100406.07800005.00800000.FB33C004.00000000.00000000.00000000
000000C8 = 15A18086.00100406.02000005.00000000.FB300000.FB339000.00000001.00000000
000000D0 = 8D2D8086.02900006.0C032005.00000000.FB338000.00000000.00000000.00000000
000000D8 = 8D208086.00100006.04030005.00000010.FBFF8004.00000000.00000000.00000000
000000E0 = 8D108086.00100404.060400D5.00810010.00000000.00000000.00030300.200000F0
000000E8 = 8D268086.02900006.0C032005.00000000.FB337000.00000000.00000000.00000000
000000F8 = 8D478086.02100007.06010005.00800000.00000000.00000000.00000000.00000000
000000FA = 8D028086.02B00407.01060105.00000000.0000F091.0000F081.0000F071.0000F061
000000FB = 8D228086.02800001.0C050005.00000000.FB335004.00000000.00000000.00000000
00000200 = 140210DE.00100007.030000A1.00800010.FA000000.E000000C.00000000.F000000C
00000201 = 0FBA10DE.00100006.040300A1.00800010.FB080000.00000000.00000000.00000000
00000400 = 34831106.00180400.0C033001.00000010.FB200004.00000000.00000000.00000000
00000500 = 12421B21.00100400.0C033000.00000010.FB100004.00000000.00000000.00000000
0000FF58 = 2F818086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF59 = 2F368086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF5A = 2F378086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF60 = 2FE08086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF61 = 2FE18086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF62 = 2FE28086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF63 = 2FE38086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF64 = 2FE48086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF65 = 2FE58086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF66 = 2FE68086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF67 = 2FE78086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF78 = 2FF88086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF79 = 2FF98086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF7A = 2FFA8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF7B = 2FFB8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF7C = 2FFC8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF7D = 2FFD8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF7E = 2FFE8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF80 = 2F1D8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF81 = 2F348086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF85 = 2F1E8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF86 = 2F7D8086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF87 = 2F1F8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF90 = 2FA08086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF91 = 2F308086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF94 = 2F608086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF95 = 2F388086.00000000.11010001.00800000.00000000.00000000.00000000.00000000
0000FF98 = 2FA88086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF99 = 2F718086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF9A = 2FAA8086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF9B = 2FAB8086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF9E = 2FAE8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FF9F = 2FAF8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA0 = 2FB08086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA1 = 2FB18086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA2 = 2FB28086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA3 = 2FB38086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA4 = 2FBC8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA5 = 2FBD8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA6 = 2FBE8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFA7 = 2FBF8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB0 = 2F688086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB1 = 2F798086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB2 = 2F6A8086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB3 = 2F6B8086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB6 = 2F6E8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB7 = 2F6F8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB8 = 2FD08086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFB9 = 2FD18086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBA = 2FD28086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBB = 2FD38086.00100000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBC = 2FB88086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBD = 2FB98086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBE = 2FBA8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFBF = 2FBB8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFF0 = 2F988086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFF1 = 2F998086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFF2 = 2F9A8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFF3 = 2FC08086.00000000.08800001.00800000.00000012.00000000.00000000.00000000
0000FFF4 = 2F9C8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFF8 = 2F888086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
0000FFFA = 2F8A8086.00000000.08800001.00800000.00000000.00000000.00000000.00000000
01070000 = 00FFFFFF.FFFFFF00.4CAB3000.01000000.16190103.805D3478.0ACF74A3.574CB023
00000020 = 09484C21.08008180.45406140.95000101.01010101.01010474.0030F270.5A80B058
00000040 = 8A00BA89.2100001E.000000FF.000A2020.20202020.20202020.20200000.00FC0053
00000060 = 45343255.4D530A20.20202020.000000FD.00324B1E.5017000A.20202020.2020014E
01070100 = 02032FF2.4D010304.05079012.1314169F.20222609.07071117.50830100.006D030C
00000020 = 001000B8.3C200060.010203E3.0E60618C.0AD08A20.E02D1010.3E9600C4.8E210000
00000040 = 188C0AD0.90204031.200C4055.00C48E21.00001801.1D00BC52.D01E20B8.285540C4
00000060 = 8E210000.1E000000.00000000.00000000.00000000.00000000.00000000.00000019
I also made a picture of the screen, but don’t know how to attach it. It doubles the image in upper part of the screen and flickers in the bottom. Also the colors are strange. I tried the workaround from here https://devtalk.nvidia.com/default/topic/939971/linux/4k-60hz-works-in-windows-not-in-linux-workaround-found-/3 but it does not work for me.
How to fix this problem?
Thank you, Dmitry
