I think everything is in the title, on Windows I get 4k@60Hz but on linux I’m stuck with 30Hz .
My GPU is a Laptop RTX4090
My computer is a Dell Precision 7680
My monitor is a Samsung TV (a few years old) : 42.5" Samsung UE43TU7125 - Specifications
Connected with USB-C DP / HDMI
Here is the xrandr output:
xrandr ✔
Screen 0: minimum 8 x 8, current 4480 x 1440, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected 1920x1200+0+240 (normal left inverted right x axis y axis) 345mm x 215mm
1920x1200 60.00*+ 48.00
DP-1 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 30.00 + 29.97 25.00 23.98
4096x2160 29.97 24.00 23.98
2560x1440 59.95*
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
strange think, when I acquire EDID I get this : Details - EDID.tv
When you decode this EDID you get this info (EDID Conformity FAIL) :
edid-decode (hex):
00 ff ff ff ff ff ff 00 4c 2d 17 70 00 0e 00 01
01 1e 01 03 80 5f 36 78 0a a8 33 ab 50 45 a5 27
0d 48 48 bd ef 80 71 4f 81 c0 81 00 81 80 95 00
a9 c0 b3 00 d1 c0 08 e8 00 30 f2 70 5a 80 b0 58
8a 00 50 1d 74 00 00 1e 56 5e 00 a0 a0 a0 29 50
30 20 35 00 50 1d 74 00 00 1a 00 00 00 fd 00 18
4b 0f 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc
00 53 41 4d 53 55 4e 47 0a 20 20 20 20 20 01 8d
02 03 59 f0 56 61 10 1f 04 13 05 14 20 21 22 5d
5e 5f 60 65 66 62 64 07 16 03 12 2c 09 07 07 15
07 50 57 07 00 67 54 00 83 01 00 00 e2 00 4f e3
05 c3 01 6e 03 0c 00 10 00 b8 3c 28 00 80 01 02
03 04 68 d8 5d c4 01 78 80 09 02 e3 06 0d 01 e3
0f 01 e0 e5 01 8b 84 90 01 02 3a 80 18 71 38 2d
40 58 2c 45 00 50 1d 74 00 00 1e 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: SAM
Model: 28695
Serial Number: 16780800
Made in: week 1 of 2020
Basic Display Parameters & Features:
Digital display
Maximum image size: 95 cm x 54 cm
Gamma: 2.20
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6699, 0.3144
Green: 0.2714, 0.6445
Blue : 0.1523, 0.0537
White: 0.2812, 0.2841
Established Timings I & II:
IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz
DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
Apple : 640x480 66.666667 Hz 4:3 35.000 kHz 30.240000 MHz
DMT 0x05: 640x480 72.808802 Hz 4:3 37.861 kHz 31.500000 MHz
DMT 0x06: 640x480 75.000000 Hz 4:3 37.500 kHz 31.500000 MHz
DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz
DMT 0x0a: 800x600 72.187572 Hz 4:3 48.077 kHz 50.000000 MHz
DMT 0x0b: 800x600 75.000000 Hz 4:3 46.875 kHz 49.500000 MHz
Apple : 832x624 74.551266 Hz 4:3 49.726 kHz 57.284000 MHz
DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz
DMT 0x11: 1024x768 70.069359 Hz 4:3 56.476 kHz 75.000000 MHz
DMT 0x12: 1024x768 75.028582 Hz 4:3 60.023 kHz 78.750000 MHz
DMT 0x24: 1280x1024 75.024675 Hz 5:4 79.976 kHz 135.000000 MHz
Apple : 1152x870 75.061550 Hz 192:145 68.681 kHz 100.000000 MHz
Standard Timings:
DMT 0x15: 1152x864 75.000000 Hz 4:3 67.500 kHz 108.000000 MHz
DMT 0x55: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
DMT 0x1c: 1280x800 59.810326 Hz 16:10 49.702 kHz 83.500000 MHz
DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz
DMT 0x2f: 1440x900 59.887445 Hz 16:10 55.935 kHz 106.500000 MHz
DMT 0x53: 1600x900 60.000000 Hz 16:9 60.000 kHz 108.000000 MHz (RB)
DMT 0x3a: 1680x1050 59.954250 Hz 16:10 65.290 kHz 146.250000 MHz
DMT 0x52: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
Detailed Timing Descriptors:
DTD 1: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz (1872 mm x 1053 mm)
Hfront 176 Hsync 88 Hback 296 Hpol P
Vfront 8 Vsync 10 Vback 72 Vpol P
DTD 2: 2560x1440 59.950550 Hz 16:9 88.787 kHz 241.500000 MHz (1872 mm x 1053 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 5 Vback 33 Vpol N
Display Range Limits:
Monitor ranges (GTF): 24-75 Hz V, 15-135 kHz H, max dotclock 600 MHz
Display Product Name: 'SAMSUNG'
Extension blocks: 1
Checksum: 0x8d
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 0
Video Data Block:
VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz
VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz
VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz
VIC 5: 1920x1080i 60.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 20: 1920x1080i 50.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 32: 1920x1080 24.000000 Hz 16:9 27.000 kHz 74.250000 MHz
VIC 33: 1920x1080 25.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 34: 1920x1080 30.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 93: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
VIC 94: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
VIC 95: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz
VIC 101: 4096x2160 50.000000 Hz 256:135 112.500 kHz 594.000000 MHz
VIC 102: 4096x2160 60.000000 Hz 256:135 135.000 kHz 594.000000 MHz
VIC 98: 4096x2160 24.000000 Hz 256:135 54.000 kHz 297.000000 MHz
VIC 100: 4096x2160 30.000000 Hz 256:135 67.500 kHz 297.000000 MHz
VIC 7: 1440x480i 59.940060 Hz 16:9 15.734 kHz 27.000000 MHz
VIC 22: 1440x576i 50.000000 Hz 16:9 15.625 kHz 27.000000 MHz
VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz
VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
AC-3:
Max channels: 6
Maximum bit rate: 640 kb/s
Enhanced AC-3 (DD+):
Max channels: 8
MAT (MLP):
Max channels: 8
Supported sample rates (kHz): 192 96 48
Supports only Dolby TrueHD
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Video Capability Data Block:
YCbCr quantization: No Data
RGB quantization: Selectable (via AVI Q)
PT scan behavior: No Data
IT scan behavior: Supports both over- and underscan
CE scan behavior: Supports both over- and underscan
Colorimetry Data Block:
xvYCC601
xvYCC709
BT2020YCC
BT2020RGB
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 300 MHz
Supported Content Types:
Game
Extended HDMI video details:
HDMI VICs:
HDMI VIC 1: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
HDMI VIC 2: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
HDMI VIC 3: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
HDMI VIC 4: 4096x2160 24.000000 Hz 256:135 54.000 kHz 297.000000 MHz
Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8:
Version: 1
Maximum TMDS Character Rate: 600 MHz
SCDC Present
Supports UHD VIC
Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding
Supports Auto Low-Latency Mode
HDR Static Metadata Data Block:
Electro optical transfer functions:
Traditional gamma - SDR luminance range
SMPTE ST2084
Hybrid Log-Gamma
Supported static metadata descriptors:
Static metadata type 1
YCbCr 4:2:0 Capability Map Data Block:
Vendor-Specific Video Data Block (HDR10+), OUI 90-84-8B:
Application Version: 1
DTD 3: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (1872 mm x 1053 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
Checksum: 0x39
Preferred Video Timing if only Block 0 is parsed:
Preferred Video Timings if Block 0 and CTA-861 Blocks are parsed:
Native Video Resolution:
3840x2160
edid-decode SHA: 84ddf9155376 2021-10-03 10:37:45
Warnings:
Video Data Block: For improved preferred timing interoperability, set 'Native detailed modes' to 1.
Video Capability Data Block: Set Selectable YCbCr Quantization to avoid interop issues.
Failures:
Block 0, Base EDID:
Detailed Timing Descriptor #1: Mismatch of image size 1872x1053 mm vs display size 950x540 mm.
Detailed Timing Descriptor #2: Mismatch of image size 1872x1053 mm vs display size 950x540 mm.
Detailed Timing Descriptor #3: Mismatch of image size 1872x1053 mm vs display size 950x540 mm.
EDID conformity: FAIL
last this this is my xorg log when I launch with X11
cat /var/log/Xorg.0.log ✔
[ 130.453] (--) Log file renamed from "/var/log/Xorg.pid-1701.log" to "/var/log/Xorg.0.log"
[ 130.453]
X.Org X Server 1.21.1.15
X Protocol Version 11, Revision 0
[ 130.453] Current Operating System: Linux linuxdell 6.12.9-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 09 Jan 2025 18:40:22 +0000 x86_64
[ 130.453] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=1106ae7f-99bc-4d29-affb-aef4f1eacec6 rw quiet splash resume=UUID=0d61f5b9-c4a3-4a31-a37f-e71feebc97e8 udev.log_priority=3 nomodeset nvidia-drm.modeset=1 nvidia_drm.fbdev=1 nvidia.NVreg_EnableGpuFirmware=0
[ 130.453]
[ 130.453] Current version of pixman: 0.44.2
[ 130.453] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 130.453] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 130.453] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan 14 03:13:56 2025
[ 130.454] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 130.454] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 130.454] (==) ServerLayout "Layout0"
[ 130.454] (**) |-->Screen "Screen0" (0)
[ 130.454] (**) | |-->Monitor "Monitor0"
[ 130.454] (**) | |-->Device "Device0"
[ 130.454] (**) |-->Input Device "Keyboard0"
[ 130.454] (**) |-->Input Device "Mouse0"
[ 130.454] (**) Allowing byte-swapped clients
[ 130.454] (==) Automatically adding devices
[ 130.454] (==) Automatically enabling devices
[ 130.454] (==) Automatically adding GPU devices
[ 130.454] (==) Automatically binding GPU devices
[ 130.454] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 130.454] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 130.454] Entry deleted from font path.
[ 130.454] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 130.454] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 130.454] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 130.454] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 130.454] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 130.454] (**) Extension "COMPOSITE" is enabled
[ 130.454] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 130.454] (WW) Disabling Keyboard0
[ 130.454] (WW) Disabling Mouse0
[ 130.454] (II) Module ABI versions:
[ 130.454] X.Org ANSI C Emulation: 0.4
[ 130.454] X.Org Video Driver: 25.2
[ 130.454] X.Org XInput driver : 24.4
[ 130.454] X.Org Server Extension : 10.0
[ 130.454] (++) using VT number 2
[ 130.454] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 130.455] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 130.455] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 130.478] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 130.480] (--) PCI:*(1@0:0:0) 10de:2717:1028:0c41 rev 161, Mem @ 0x92000000/16777216, 0x4000000000/17179869184, 0x4400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 130.480] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 130.480] (II) LoadModule: "glx"
[ 130.480] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 130.482] (II) Module glx: vendor="X.Org Foundation"
[ 130.482] compiled for 1.21.1.15, module version = 1.0.0
[ 130.482] ABI class: X.Org Server Extension, version 10.0
[ 130.482] (II) LoadModule: "nvidia"
[ 130.482] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 130.482] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 130.482] compiled for 1.6.99.901, module version = 1.0.0
[ 130.482] Module class: X.Org Video Driver
[ 130.482] (II) NVIDIA dlloader X Driver 565.77 Wed Nov 27 22:57:27 UTC 2024
[ 130.482] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 130.483] (II) Loading sub module "fb"
[ 130.483] (II) LoadModule: "fb"
[ 130.483] (II) Module "fb" already built-in
[ 130.483] (II) Loading sub module "wfb"
[ 130.483] (II) LoadModule: "wfb"
[ 130.483] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 130.483] (II) Module wfb: vendor="X.Org Foundation"
[ 130.483] compiled for 1.21.1.15, module version = 1.0.0
[ 130.483] ABI class: X.Org ANSI C Emulation, version 0.4
[ 130.483] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 130.483] (==) NVIDIA(0): RGB weight 888
[ 130.483] (==) NVIDIA(0): Default visual is TrueColor
[ 130.483] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 130.483] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 130.483] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 130.483] (**) NVIDIA(0): Enabling 2D acceleration
[ 130.483] (II) Loading sub module "glxserver_nvidia"
[ 130.483] (II) LoadModule: "glxserver_nvidia"
[ 130.483] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 130.492] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 130.492] compiled for 1.6.99.901, module version = 1.0.0
[ 130.492] Module class: X.Org Server Extension
[ 130.492] (II) NVIDIA GLX Module 565.77 Wed Nov 27 22:58:37 UTC 2024
[ 130.492] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 130.492] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 130.492] (--) NVIDIA(0): DFP-0
[ 130.492] (--) NVIDIA(0): DFP-1 (boot)
[ 130.492] (--) NVIDIA(0): DFP-2
[ 130.492] (--) NVIDIA(0): DFP-3
[ 130.492] (--) NVIDIA(0): DFP-4
[ 130.492] (--) NVIDIA(0): DFP-5
[ 130.492] (--) NVIDIA(0): DFP-6
[ 130.492] (--) NVIDIA(0): DFP-7
[ 130.509] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 4090 Laptop GPU (AD103-A) at
[ 130.509] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 130.509] (--) NVIDIA(0): Memory: 16769024 kBytes
[ 130.509] (--) NVIDIA(0): VideoBIOS: 95.03.2f.00.06
[ 130.509] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 130.781] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 130.781] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 130.781] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 130.781] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): connected
[ 130.781] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): Internal DisplayPort
[ 130.781] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): 2670.0 MHz maximum pixel clock
[ 130.781] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): connected
[ 130.781] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): Internal DisplayPort
[ 130.781] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): 2670.0 MHz maximum pixel clock
[ 130.783] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 130.783] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 130.783] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 130.783] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 130.783] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 130.783] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 130.784] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 130.784] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 130.784] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 130.784] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 130.784] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 130.784] (--) NVIDIA(GPU-0): DFP-6: 2670.0 MHz maximum pixel clock
[ 130.784] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 130.784] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 130.784] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 130.812] (==) NVIDIA(0):
[ 130.812] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 130.812] (==) NVIDIA(0): will be used as the requested mode.
[ 130.816] (II) NVIDIA(0): Validated MetaModes:
[ 130.816] (II) NVIDIA(0): "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select"
[ 130.816] (II) NVIDIA(0): Virtual screen size determined to be 5760 x 2160
[ 130.909] (--) NVIDIA(0): DPI set to (143, 138); computed from "UseEdidDpi" X config
[ 130.909] (--) NVIDIA(0): option
[ 130.909] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 130.909] (II) NVIDIA: access.
[ 130.932] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 130.932] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 130.932] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 130.932] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 130.932] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 130.932] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 130.932] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 130.932] (II) NVIDIA(0): Config Options in the README.
[ 130.948] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select"
[ 131.801] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 131.801] (==) NVIDIA(0): Backing store enabled
[ 131.801] (==) NVIDIA(0): Silken mouse enabled
[ 131.801] (**) NVIDIA(0): DPMS enabled
[ 131.801] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 131.801] (II) Loading sub module "dri2"
[ 131.801] (II) LoadModule: "dri2"
[ 131.801] (II) Module "dri2" already built-in
[ 131.801] (II) NVIDIA(0): [DRI2] Setup complete
[ 131.801] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 131.801] (II) Initializing extension Generic Event Extension
[ 131.801] (II) Initializing extension SHAPE
[ 131.801] (II) Initializing extension MIT-SHM
[ 131.801] (II) Initializing extension XInputExtension
[ 131.801] (II) Initializing extension XTEST
[ 131.801] (II) Initializing extension BIG-REQUESTS
[ 131.801] (II) Initializing extension SYNC
[ 131.802] (II) Initializing extension XKEYBOARD
[ 131.802] (II) Initializing extension XC-MISC
[ 131.802] (II) Initializing extension SECURITY
[ 131.802] (II) Initializing extension XFIXES
[ 131.802] (II) Initializing extension RENDER
[ 131.802] (II) Initializing extension RANDR
[ 131.802] (II) Initializing extension COMPOSITE
[ 131.802] (II) Initializing extension DAMAGE
[ 131.802] (II) Initializing extension MIT-SCREEN-SAVER
[ 131.802] (II) Initializing extension DOUBLE-BUFFER
[ 131.802] (II) Initializing extension RECORD
[ 131.802] (II) Initializing extension DPMS
[ 131.802] (II) Initializing extension Present
[ 131.802] (II) Initializing extension DRI3
[ 131.802] (II) Initializing extension X-Resource
[ 131.802] (II) Initializing extension XVideo
[ 131.802] (II) Initializing extension XVideo-MotionCompensation
[ 131.802] (II) Initializing extension GLX
[ 131.802] (II) Indirect GLX disabled.
[ 131.802] (II) GLX: Another vendor is already registered for screen 0
[ 131.802] (II) Initializing extension XFree86-VidModeExtension
[ 131.802] (II) Initializing extension XFree86-DGA
[ 131.803] (II) Initializing extension XFree86-DRI
[ 131.803] (II) Initializing extension DRI2
[ 131.803] (II) Initializing extension NV-GLX
[ 131.803] (II) Initializing extension NV-CONTROL
[ 131.803] (II) Initializing extension XINERAMA
[ 131.836] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 131.836] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 131.836] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 131.836] (**) Video Bus: Applying InputClass "system-keyboard"
[ 131.836] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 131.836] (II) LoadModule: "libinput"
[ 131.836] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 131.837] (II) Module libinput: vendor="X.Org Foundation"
[ 131.837] compiled for 1.21.1.13, module version = 1.5.0
[ 131.837] Module class: X.Org XInput Driver
[ 131.837] ABI class: X.Org XInput driver, version 24.4
[ 131.837] (II) Using input driver 'libinput' for 'Video Bus'
[ 131.837] (**) Video Bus: always reports core events
[ 131.837] (**) Option "Device" "/dev/input/event3"
[ 131.838] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 131.838] (II) event3 - Video Bus: device is a keyboard
[ 131.838] (II) event3 - Video Bus: device removed
[ 131.920] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/LNXVIDEO:00/input/input3/event3"
[ 131.920] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 131.920] (**) Option "xkb_layout" "fr"
[ 131.920] (WW) Option "xkb_variant" requires a string value
[ 131.920] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 131.942] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 131.942] (II) event3 - Video Bus: device is a keyboard
[ 131.942] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 131.942] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 131.942] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 131.942] (**) Power Button: Applying InputClass "system-keyboard"
[ 131.942] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 131.942] (II) Using input driver 'libinput' for 'Power Button'
[ 131.942] (**) Power Button: always reports core events
[ 131.942] (**) Option "Device" "/dev/input/event1"
[ 131.942] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 131.942] (II) event1 - Power Button: device is a keyboard
[ 131.942] (II) event1 - Power Button: device removed
[ 131.986] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 131.986] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 131.986] (**) Option "xkb_layout" "fr"
[ 131.987] (WW) Option "xkb_variant" requires a string value
[ 131.987] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 131.988] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 131.988] (II) event1 - Power Button: device is a keyboard
[ 131.989] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 131.989] (II) No input driver specified, ignoring this device.
[ 131.989] (II) This device may have been added with another device file.
[ 131.989] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 131.989] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 131.989] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 131.989] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 131.989] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[ 131.989] (II) Using input driver 'libinput' for 'Sleep Button'
[ 131.989] (**) Sleep Button: always reports core events
[ 131.989] (**) Option "Device" "/dev/input/event2"
[ 131.990] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 131.990] (II) event2 - Sleep Button: device is a keyboard
[ 131.990] (II) event2 - Sleep Button: device removed
[ 132.030] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 132.030] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 132.030] (**) Option "xkb_layout" "fr"
[ 132.030] (WW) Option "xkb_variant" requires a string value
[ 132.030] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.031] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 132.031] (II) event2 - Sleep Button: device is a keyboard
[ 132.032] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 132.032] (II) No input driver specified, ignoring this device.
[ 132.032] (II) This device may have been added with another device file.
[ 132.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 132.033] (II) No input driver specified, ignoring this device.
[ 132.033] (II) This device may have been added with another device file.
[ 132.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 132.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 132.034] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event4)
[ 132.034] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 132.034] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 132.034] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 132.034] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[ 132.034] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 132.034] (**) Logitech USB Receiver: always reports core events
[ 132.034] (**) Option "Device" "/dev/input/event4"
[ 132.036] (II) event4 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 132.036] (II) event4 - Logitech USB Receiver: device is a keyboard
[ 132.036] (II) event4 - Logitech USB Receiver: device removed
[ 132.060] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.0/0003:046D:C548.0001/input/input4/event4"
[ 132.060] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[ 132.060] (**) Option "xkb_layout" "fr"
[ 132.060] (WW) Option "xkb_variant" requires a string value
[ 132.060] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.062] (II) event4 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 132.062] (II) event4 - Logitech USB Receiver: device is a keyboard
[ 132.064] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event5)
[ 132.064] (**) Logitech USB Receiver Mouse: Applying InputClass "evdev pointer catchall"
[ 132.064] (**) Logitech USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 132.064] (II) Using input driver 'libinput' for 'Logitech USB Receiver Mouse'
[ 132.064] (**) Logitech USB Receiver Mouse: always reports core events
[ 132.064] (**) Option "Device" "/dev/input/event5"
[ 132.065] (II) event5 - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[ 132.065] (II) event5 - Logitech USB Receiver Mouse: device set to 1000 DPI
[ 132.065] (II) event5 - Logitech USB Receiver Mouse: device is a pointer
[ 132.065] (II) event5 - Logitech USB Receiver Mouse: device removed
[ 132.146] (II) libinput: Logitech USB Receiver Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 132.146] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.1/0003:046D:C548.0002/input/input5/event5"
[ 132.146] (II) XINPUT: Adding extended input device "Logitech USB Receiver Mouse" (type: MOUSE, id 10)
[ 132.147] (**) Option "AccelerationScheme" "none"
[ 132.147] (**) Logitech USB Receiver Mouse: (accel) selected scheme none/0
[ 132.147] (**) Logitech USB Receiver Mouse: (accel) acceleration factor: 2.000
[ 132.147] (**) Logitech USB Receiver Mouse: (accel) acceleration threshold: 4
[ 132.149] (II) event5 - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[ 132.149] (II) event5 - Logitech USB Receiver Mouse: device set to 1000 DPI
[ 132.149] (II) event5 - Logitech USB Receiver Mouse: device is a pointer
[ 132.150] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/mouse0)
[ 132.150] (II) No input driver specified, ignoring this device.
[ 132.150] (II) This device may have been added with another device file.
[ 132.151] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event6)
[ 132.151] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 132.151] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 132.151] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 132.151] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 132.151] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 132.151] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 132.151] (**) Option "Device" "/dev/input/event6"
[ 132.152] (II) event6 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 132.152] (II) event6 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 132.153] (II) event6 - Logitech USB Receiver Consumer Control: device removed
[ 132.186] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[ 132.187] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.1/0003:046D:C548.0002/input/input6/event6"
[ 132.187] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: MOUSE, id 11)
[ 132.187] (**) Option "AccelerationScheme" "none"
[ 132.187] (**) Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[ 132.187] (**) Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 132.187] (**) Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 132.190] (II) event6 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 132.190] (II) event6 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 132.191] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event7)
[ 132.191] (**) Logitech USB Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 132.191] (**) Logitech USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 132.191] (**) Logitech USB Receiver System Control: Applying InputClass "system-keyboard"
[ 132.191] (**) Logitech USB Receiver System Control: Applying InputClass "Keyboard Defaults"
[ 132.191] (II) Using input driver 'libinput' for 'Logitech USB Receiver System Control'
[ 132.191] (**) Logitech USB Receiver System Control: always reports core events
[ 132.191] (**) Option "Device" "/dev/input/event7"
[ 132.193] (II) event7 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 132.193] (II) event7 - Logitech USB Receiver System Control: device is a keyboard
[ 132.193] (II) event7 - Logitech USB Receiver System Control: device removed
[ 132.233] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.1/0003:046D:C548.0002/input/input7/event7"
[ 132.233] (II) XINPUT: Adding extended input device "Logitech USB Receiver System Control" (type: KEYBOARD, id 12)
[ 132.233] (**) Option "xkb_layout" "fr"
[ 132.233] (WW) Option "xkb_variant" requires a string value
[ 132.233] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.236] (II) event7 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 132.236] (II) event7 - Logitech USB Receiver System Control: device is a keyboard
[ 132.237] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event8)
[ 132.237] (II) No input driver specified, ignoring this device.
[ 132.237] (II) This device may have been added with another device file.
[ 132.238] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event9)
[ 132.238] (**) Logitech USB Receiver: Applying InputClass "evdev touchpad catchall"
[ 132.238] (**) Logitech USB Receiver: Applying InputClass "libinput touchpad catchall"
[ 132.238] (**) Logitech USB Receiver: Applying InputClass "touchpad"
[ 132.238] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 132.238] (**) Logitech USB Receiver: always reports core events
[ 132.238] (**) Option "Device" "/dev/input/event9"
[ 132.292] (II) event9 - Logitech USB Receiver: is tagged by udev as: Touchpad
[ 132.294] (II) event9 - Logitech USB Receiver: device is a touchpad
[ 132.294] (II) event9 - Logitech USB Receiver: device removed
[ 132.363] (**) Option "Tapping" "on"
[ 132.363] (II) libinput: Logitech USB Receiver: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 132.364] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.3/0003:046D:C548.0004/input/input10/event9"
[ 132.364] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: TOUCHPAD, id 13)
[ 132.366] (**) Option "AccelerationScheme" "none"
[ 132.366] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 132.366] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 132.366] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 132.422] (II) event9 - Logitech USB Receiver: is tagged by udev as: Touchpad
[ 132.425] (II) event9 - Logitech USB Receiver: device is a touchpad
[ 132.426] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse1)
[ 132.426] (**) Logitech USB Receiver: Applying InputClass "touchpad"
[ 132.426] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 132.426] (**) Logitech USB Receiver: always reports core events
[ 132.426] (**) Option "Device" "/dev/input/mouse1"
[ 132.493] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 132.493] (EE) libinput: Logitech USB Receiver: Failed to create a device for /dev/input/mouse1
[ 132.493] (EE) PreInit returned 2 for "Logitech USB Receiver"
[ 132.493] (II) UnloadModule: "libinput"
[ 132.494] (II) config/udev: Adding input device VEN_0488:00 0488:1036 Mouse (/dev/input/event15)
[ 132.494] (**) VEN_0488:00 0488:1036 Mouse: Applying InputClass "evdev pointer catchall"
[ 132.494] (**) VEN_0488:00 0488:1036 Mouse: Applying InputClass "libinput pointer catchall"
[ 132.494] (II) Using input driver 'libinput' for 'VEN_0488:00 0488:1036 Mouse'
[ 132.494] (**) VEN_0488:00 0488:1036 Mouse: always reports core events
[ 132.494] (**) Option "Device" "/dev/input/event15"
[ 132.496] (II) event15 - VEN_0488:00 0488:1036 Mouse: is tagged by udev as: Mouse Pointingstick
[ 132.497] (II) event15 - VEN_0488:00 0488:1036 Mouse: device is a pointer
[ 132.498] (II) event15 - VEN_0488:00 0488:1036 Mouse: device removed
[ 132.566] (II) libinput: VEN_0488:00 0488:1036 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 132.566] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-8/i2c-VEN_0488:00/0018:0488:1036.0005/input/input17/event15"
[ 132.566] (II) XINPUT: Adding extended input device "VEN_0488:00 0488:1036 Mouse" (type: MOUSE, id 14)
[ 132.567] (**) Option "AccelerationScheme" "none"
[ 132.567] (**) VEN_0488:00 0488:1036 Mouse: (accel) selected scheme none/0
[ 132.567] (**) VEN_0488:00 0488:1036 Mouse: (accel) acceleration factor: 2.000
[ 132.567] (**) VEN_0488:00 0488:1036 Mouse: (accel) acceleration threshold: 4
[ 132.569] (II) event15 - VEN_0488:00 0488:1036 Mouse: is tagged by udev as: Mouse Pointingstick
[ 132.569] (II) event15 - VEN_0488:00 0488:1036 Mouse: device is a pointer
[ 132.571] (II) config/udev: Adding input device VEN_0488:00 0488:1036 Mouse (/dev/input/mouse3)
[ 132.572] (II) No input driver specified, ignoring this device.
[ 132.572] (II) This device may have been added with another device file.
[ 132.572] (II) config/udev: Adding input device VEN_0488:00 0488:1036 Touchpad (/dev/input/event16)
[ 132.572] (**) VEN_0488:00 0488:1036 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 132.572] (**) VEN_0488:00 0488:1036 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 132.572] (**) VEN_0488:00 0488:1036 Touchpad: Applying InputClass "touchpad"
[ 132.572] (II) Using input driver 'libinput' for 'VEN_0488:00 0488:1036 Touchpad'
[ 132.572] (**) VEN_0488:00 0488:1036 Touchpad: always reports core events
[ 132.572] (**) Option "Device" "/dev/input/event16"
[ 132.573] (II) event16 - VEN_0488:00 0488:1036 Touchpad: is tagged by udev as: Touchpad
[ 132.575] (II) event16 - VEN_0488:00 0488:1036 Touchpad: device is a touchpad
[ 132.575] (II) event16 - VEN_0488:00 0488:1036 Touchpad: device removed
[ 132.640] (**) Option "Tapping" "on"
[ 132.640] (II) libinput: VEN_0488:00 0488:1036 Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 132.641] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-8/i2c-VEN_0488:00/0018:0488:1036.0005/input/input18/event16"
[ 132.641] (II) XINPUT: Adding extended input device "VEN_0488:00 0488:1036 Touchpad" (type: TOUCHPAD, id 15)
[ 132.644] (**) Option "AccelerationScheme" "none"
[ 132.644] (**) VEN_0488:00 0488:1036 Touchpad: (accel) selected scheme none/0
[ 132.644] (**) VEN_0488:00 0488:1036 Touchpad: (accel) acceleration factor: 2.000
[ 132.644] (**) VEN_0488:00 0488:1036 Touchpad: (accel) acceleration threshold: 4
[ 132.645] (II) event16 - VEN_0488:00 0488:1036 Touchpad: is tagged by udev as: Touchpad
[ 132.648] (II) event16 - VEN_0488:00 0488:1036 Touchpad: device is a touchpad
[ 132.649] (II) config/udev: Adding input device VEN_0488:00 0488:1036 Touchpad (/dev/input/mouse4)
[ 132.649] (**) VEN_0488:00 0488:1036 Touchpad: Applying InputClass "touchpad"
[ 132.649] (II) Using input driver 'libinput' for 'VEN_0488:00 0488:1036 Touchpad'
[ 132.649] (**) VEN_0488:00 0488:1036 Touchpad: always reports core events
[ 132.649] (**) Option "Device" "/dev/input/mouse4"
[ 132.713] (II) mouse4 - not using input device '/dev/input/mouse4'.
[ 132.713] (EE) libinput: VEN_0488:00 0488:1036 Touchpad: Failed to create a device for /dev/input/mouse4
[ 132.713] (EE) PreInit returned 2 for "VEN_0488:00 0488:1036 Touchpad"
[ 132.713] (II) UnloadModule: "libinput"
[ 132.714] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event23)
[ 132.714] (II) No input driver specified, ignoring this device.
[ 132.714] (II) This device may have been added with another device file.
[ 132.715] (II) config/udev: Adding input device Intel HID events (/dev/input/event11)
[ 132.715] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 132.715] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 132.715] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 132.715] (**) Intel HID events: Applying InputClass "Keyboard Defaults"
[ 132.715] (II) Using input driver 'libinput' for 'Intel HID events'
[ 132.715] (**) Intel HID events: always reports core events
[ 132.715] (**) Option "Device" "/dev/input/event11"
[ 132.716] (II) event11 - Intel HID events: is tagged by udev as: Keyboard
[ 132.716] (II) event11 - Intel HID events: device is a keyboard
[ 132.716] (II) event11 - Intel HID events: device removed
[ 132.740] (**) Option "config_info" "udev:/sys/devices/platform/INTC1078:00/input/input13/event11"
[ 132.740] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 16)
[ 132.740] (**) Option "xkb_layout" "fr"
[ 132.740] (WW) Option "xkb_variant" requires a string value
[ 132.740] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.741] (II) event11 - Intel HID events: is tagged by udev as: Keyboard
[ 132.741] (II) event11 - Intel HID events: device is a keyboard
[ 132.742] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event12)
[ 132.742] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 132.742] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 132.742] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 132.742] (**) Intel HID 5 button array: Applying InputClass "Keyboard Defaults"
[ 132.742] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 132.742] (**) Intel HID 5 button array: always reports core events
[ 132.742] (**) Option "Device" "/dev/input/event12"
[ 132.743] (II) event12 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 132.743] (II) event12 - Intel HID 5 button array: device is a keyboard
[ 132.744] (II) event12 - Intel HID 5 button array: device removed
[ 132.786] (**) Option "config_info" "udev:/sys/devices/platform/INTC1078:00/input/input14/event12"
[ 132.786] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 17)
[ 132.786] (**) Option "xkb_layout" "fr"
[ 132.786] (WW) Option "xkb_variant" requires a string value
[ 132.786] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.788] (II) event12 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 132.788] (II) event12 - Intel HID 5 button array: device is a keyboard
[ 132.789] (II) config/udev: Adding input device Dell Privacy Driver (/dev/input/event21)
[ 132.789] (**) Dell Privacy Driver: Applying InputClass "evdev keyboard catchall"
[ 132.789] (**) Dell Privacy Driver: Applying InputClass "libinput keyboard catchall"
[ 132.789] (**) Dell Privacy Driver: Applying InputClass "system-keyboard"
[ 132.789] (**) Dell Privacy Driver: Applying InputClass "Keyboard Defaults"
[ 132.789] (II) Using input driver 'libinput' for 'Dell Privacy Driver'
[ 132.789] (**) Dell Privacy Driver: always reports core events
[ 132.789] (**) Option "Device" "/dev/input/event21"
[ 132.791] (II) event21 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 132.791] (II) event21 - Dell Privacy Driver: device is a keyboard
[ 132.791] (II) event21 - Dell Privacy Driver: device removed
[ 132.873] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/6932965F-1671-4CEB-B988-D3AB0A901919/input/input24/event21"
[ 132.873] (II) XINPUT: Adding extended input device "Dell Privacy Driver" (type: KEYBOARD, id 18)
[ 132.873] (**) Option "xkb_layout" "fr"
[ 132.873] (WW) Option "xkb_variant" requires a string value
[ 132.873] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.875] (II) event21 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 132.875] (II) event21 - Dell Privacy Driver: device is a keyboard
[ 132.877] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event22)
[ 132.877] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 132.877] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 132.877] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 132.877] (**) Dell WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 132.877] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 132.877] (**) Dell WMI hotkeys: always reports core events
[ 132.877] (**) Option "Device" "/dev/input/event22"
[ 132.878] (II) event22 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 132.878] (II) event22 - Dell WMI hotkeys: device is a keyboard
[ 132.878] (II) event22 - Dell WMI hotkeys: device removed
[ 132.946] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input25/event22"
[ 132.946] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 19)
[ 132.946] (**) Option "xkb_layout" "fr"
[ 132.946] (WW) Option "xkb_variant" requires a string value
[ 132.946] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.948] (II) event22 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 132.949] (II) event22 - Dell WMI hotkeys: device is a keyboard
[ 132.950] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event10)
[ 132.950] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 132.950] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 132.950] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 132.950] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[ 132.950] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 132.950] (**) AT Translated Set 2 keyboard: always reports core events
[ 132.950] (**) Option "Device" "/dev/input/event10"
[ 132.951] (II) event10 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 132.951] (II) event10 - AT Translated Set 2 keyboard: device is a keyboard
[ 132.953] (II) event10 - AT Translated Set 2 keyboard: device removed
[ 132.993] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input11/event10"
[ 132.993] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 20)
[ 132.993] (**) Option "xkb_layout" "fr"
[ 132.993] (WW) Option "xkb_variant" requires a string value
[ 132.993] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 132.995] (II) event10 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 132.995] (II) event10 - AT Translated Set 2 keyboard: device is a keyboard
[ 132.998] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event14)
[ 132.998] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[ 132.998] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[ 132.998] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 132.998] (**) PS/2 Generic Mouse: always reports core events
[ 132.998] (**) Option "Device" "/dev/input/event14"
[ 132.999] (II) event14 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 133.000] (II) event14 - PS/2 Generic Mouse: device is a pointer
[ 133.000] (II) event14 - PS/2 Generic Mouse: device removed
[ 133.066] (II) libinput: PS/2 Generic Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 133.066] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input16/event14"
[ 133.067] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 21)
[ 133.067] (**) Option "AccelerationScheme" "none"
[ 133.067] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[ 133.067] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 133.067] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 133.068] (II) event14 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 133.069] (II) event14 - PS/2 Generic Mouse: device is a pointer
[ 133.070] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse2)
[ 133.070] (II) No input driver specified, ignoring this device.
[ 133.070] (II) This device may have been added with another device file.
[ 133.070] (II) config/udev: Adding input device PC Speaker (/dev/input/event13)
[ 133.077] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 133.077] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 133.077] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 133.077] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[ 133.077] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 133.077] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 133.077] (**) Option "Device" "/dev/input/event6"
[ 133.077] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[ 133.077] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.3/1-9.3:1.1/0003:046D:C548.0002/input/input6/event6"
[ 133.077] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: KEYBOARD, id 22)
[ 133.077] (**) Option "xkb_layout" "fr"
[ 133.077] (WW) Option "xkb_variant" requires a string value
[ 133.077] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 145.015] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 145.015] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 145.015] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 145.015] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): connected
[ 145.015] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): Internal DisplayPort
[ 145.015] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): 2670.0 MHz maximum pixel clock
[ 145.015] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): connected
[ 145.015] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): Internal DisplayPort
[ 145.015] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): 2670.0 MHz maximum pixel clock
[ 145.017] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 145.017] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 145.017] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 145.017] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 145.017] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 145.017] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 145.017] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 145.017] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 145.017] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 145.017] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 145.017] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 145.017] (--) NVIDIA(GPU-0): DFP-6: 2670.0 MHz maximum pixel clock
[ 145.017] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 145.017] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 145.017] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 145.545] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 145.545] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 145.545] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 145.545] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): connected
[ 145.545] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): Internal DisplayPort
[ 145.545] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): 2670.0 MHz maximum pixel clock
[ 145.545] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): connected
[ 145.545] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): Internal DisplayPort
[ 145.545] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): 2670.0 MHz maximum pixel clock
[ 145.547] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 145.547] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 145.547] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 145.547] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 145.547] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 145.547] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 145.547] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 145.547] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 145.547] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 145.547] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 145.547] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 145.547] (--) NVIDIA(GPU-0): DFP-6: 2670.0 MHz maximum pixel clock
[ 145.547] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 145.547] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 145.547] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 147.667] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +971+2160 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: nvidia-auto-select @3840x2160 +1920+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 148.811] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +971+2160 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 243.155] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +971+1440 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 244.373] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +971+1440 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: 2560x1440 @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 256.502] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +0+240 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: 2560x1440 @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 257.622] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @1920x1200 +0+240 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, DP-1: 2560x1440 @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 907.838] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 907.838] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 907.838] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 907.838] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): connected
[ 907.838] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): Internal DisplayPort
[ 907.838] (--) NVIDIA(GPU-0): BOE Technology Group Co., Ltd (DFP-1): 2670.0 MHz maximum pixel clock
[ 907.839] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): connected
[ 907.839] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): Internal DisplayPort
[ 907.839] (--) NVIDIA(GPU-0): SAMSUNG (DFP-2): 2670.0 MHz maximum pixel clock
[ 907.841] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 907.841] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 907.841] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 907.841] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 907.841] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 907.841] (--) NVIDIA(GPU-0): DFP-4: 2670.0 MHz maximum pixel clock
[ 907.842] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 907.842] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 907.842] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 907.842] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 907.842] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 907.842] (--) NVIDIA(GPU-0): DFP-6: 2670.0 MHz maximum pixel clock
[ 907.842] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 907.842] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 907.842] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
any help ? Thank you !!
