I changed my gtx750 card to brand new gtx960 with hdmi 2.0.
it runs 3840x2160@60hz per hdmi connection in windows 7 but only 30hz in linux.
i installed newest x86_64 driver today but only 24, 25, 30 hz.
how to get this work ?
xorg.conf: driver default
Xorg.0.log:
[ 11.602] X.Org X Server 1.16.2.901 (1.16.3 RC 1)
Release Date: 2014-12-09
[ 11.602] X Protocol Version 11, Revision 0
[ 11.602] Build Operating System: Linux 3.2.0-4-amd64 x86_64 Debian
[ 11.602] Current Operating System: Linux i7 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt2-1 (2014-12-08) x86_64
[ 11.602] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=52635f4d-482c-4d7c-8526-ab86e125647b ro quiet
[ 11.602] Build Date: 09 December 2014 10:15:28PM
[ 11.602] xorg-server 2:1.16.2.901-1 (http://www.debian.org/support)
[ 11.602] Current version of pixman: 0.32.6
[ 11.602] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 11.602] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 11.602] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Jan 28 21:57:10 2015
[ 11.603] (==) Using config file: “/etc/X11/xorg.conf”
[ 11.603] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 11.605] (==) ServerLayout “Layout0”
[ 11.605] () |–>Screen “Screen0” (0)
[ 11.605] () | |–>Monitor “Monitor0”
[ 11.606] () | |–>Device “Device0”
[ 11.606] () |–>Input Device “Keyboard0”
[ 11.606] () |–>Input Device “Mouse0”
[ 11.606] (==) Automatically adding devices
[ 11.606] (==) Automatically enabling devices
[ 11.606] (==) Automatically adding GPU devices
[ 11.608] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 11.608] Entry deleted from font path.
[ 11.613] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 11.613] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 11.613] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 11.613] (WW) Disabling Keyboard0
[ 11.613] (WW) Disabling Mouse0
[ 11.614] (II) Loader magic: 0x7f250c66ad80
[ 11.614] (II) Module ABI versions:
[ 11.614] X.Org ANSI C Emulation: 0.4
[ 11.614] X.Org Video Driver: 18.0
[ 11.614] X.Org XInput driver : 21.0
[ 11.614] X.Org Server Extension : 8.0
[ 11.614] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.615] (–) PCI:*(0:3:0:0) 10de:1401:10de:1138 rev 161, Mem @ 0xfa000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000cc00/128, BIOS @ 0x???/524288
[ 11.616] (II) LoadModule: “glx”
[ 11.624] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.828] (II) Module glx: vendor=“NVIDIA Corporation”
[ 11.828] compiled for 4.0.2, module version = 1.0.0
[ 11.828] Module class: X.Org Server Extension
[ 11.828] (II) NVIDIA GLX Module 346.35 Sat Jan 10 20:53:39 PST 2015
[ 11.829] (II) LoadModule: “nvidia”
[ 11.829] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 11.844] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 11.844] compiled for 4.0.2, module version = 1.0.0
[ 11.844] Module class: X.Org Video Driver
[ 11.844] (II) NVIDIA dlloader X Driver 346.35 Sat Jan 10 20:32:18 PST 2015
[ 11.844] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 11.845] (++) using VT number 7
[ 11.850] (II) Loading sub module “fb”
[ 11.850] (II) LoadModule: “fb”
[ 11.850] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.851] (II) Module fb: vendor=“X.Org Foundation”
[ 11.851] compiled for 1.16.2.901, module version = 1.0.0
[ 11.851] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.851] (II) Loading sub module “wfb”
[ 11.851] (II) LoadModule: “wfb”
[ 11.851] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 11.853] (II) Module wfb: vendor=“X.Org Foundation”
[ 11.853] compiled for 1.16.2.901, module version = 1.0.0
[ 11.853] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.853] (II) Loading sub module “ramdac”
[ 11.853] (II) LoadModule: “ramdac”
[ 11.853] (II) Module “ramdac” already built-in
[ 11.855] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 11.855] (==) NVIDIA(0): RGB weight 888
[ 11.855] (==) NVIDIA(0): Default visual is TrueColor
[ 11.855] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.856] () NVIDIA(0): Enabling 2D acceleration
[ 12.829] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[ 12.830] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 960 (GM206-A) at PCI:3:0:0 (GPU-0)
[ 12.830] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 12.830] (–) NVIDIA(0): VideoBIOS: 84.06.0d.00.1c
[ 12.830] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 12.865] (–) NVIDIA(0): Valid display device(s) on GeForce GTX 960 at PCI:3:0:0
[ 12.865] (–) NVIDIA(0): CRT-0
[ 12.865] (–) NVIDIA(0): Philips 278G4 (DFP-0) (boot, connected)
[ 12.865] (–) NVIDIA(0): LG Electronics LG TV (DFP-1) (connected)
[ 12.865] (–) NVIDIA(0): DFP-2
[ 12.865] (–) NVIDIA(0): DFP-3
[ 12.865] (–) NVIDIA(0): DFP-4
[ 12.865] (–) NVIDIA(0): DFP-5
[ 12.865] (–) NVIDIA(0): DFP-6
[ 12.865] (–) NVIDIA(0): DFP-7
[ 12.865] (–) NVIDIA(0): DFP-8
[ 12.865] (–) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): Philips 278G4 (DFP-0): Internal TMDS
[ 12.865] (–) NVIDIA(GPU-0): Philips 278G4 (DFP-0): 600.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): LG Electronics LG TV (DFP-1): Internal TMDS
[ 12.865] (–) NVIDIA(GPU-0): LG Electronics LG TV (DFP-1): 600.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 12.865] (–) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-3: Internal TMDS
[ 12.865] (–) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-4: Internal DisplayPort
[ 12.865] (–) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-5: Internal TMDS
[ 12.865] (–) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-6: Internal DisplayPort
[ 12.865] (–) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-7: Internal TMDS
[ 12.865] (–) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 12.865] (–) NVIDIA(0): DFP-8: External LVDS
[ 12.865] (–) NVIDIA(GPU-0): DFP-8: 165.0 MHz maximum pixel clock
[ 12.865] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 12.865] () NVIDIA(0): device Philips 278G4 (DFP-0) (Using EDID frequencies has
[ 12.865] () NVIDIA(0): been enabled on all display devices.)
[ 12.866] (WW) NVIDIA(GPU-0): The EDID for Philips 278G4 (DFP-0) contradicts itself: mode
[ 12.866] (WW) NVIDIA(GPU-0): “720x480” is specified in the EDID; however, the EDID’s
[ 12.866] (WW) NVIDIA(GPU-0): valid HorizSync range (26.000-83.000 kHz) would exclude
[ 12.866] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.7 kHz); ignoring HorizSync check
[ 12.866] (WW) NVIDIA(GPU-0): for mode “720x480”.
[ 12.866] (WW) NVIDIA(GPU-0): “720x576” is specified in the EDID; however, the EDID’s
[ 12.866] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.6 kHz); ignoring HorizSync check
[ 12.866] (WW) NVIDIA(GPU-0): for mode “720x576”.
[ 12.867] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 12.867] () NVIDIA(0): device LG Electronics LG TV (DFP-1) (Using EDID
[ 12.867] () NVIDIA(0): frequencies has been enabled on all display devices.)
[ 12.867] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 12.867] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 12.867] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 12.867] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 12.867] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 12.867] (WW) NVIDIA(GPU-0): mode “1280x720” is specified in the EDID; however, the
[ 12.867] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1280x720”.
[ 12.868] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 12.868] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 12.868] (WW) NVIDIA(GPU-0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): HorizSync check for mode “1920x1080”.
[ 12.868] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 12.868] (WW) NVIDIA(GPU-0): mode “720x576” is specified in the EDID; however, the
[ 12.868] (WW) NVIDIA(GPU-0): VertRefresh check for mode “720x576”.
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (27.0 kHz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (15.6 kHz); ignoring
[ 12.868] (WW) NVIDIA(GPU-0): HorizSync check for mode “720x576”.
[ 12.868] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 12.868] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 12.869] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 12.869] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 12.869] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 12.869] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 12.869] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 12.869] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 12.869] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 12.869] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 12.869] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 12.870] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 12.870] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 12.870] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 12.870] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 12.870] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 12.870] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 12.872] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 12.872] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 12.872] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 12.872] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 12.872] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 12.872] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 12.872] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 12.872] (==) NVIDIA(0):
[ 12.872] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 12.872] (==) NVIDIA(0): will be used as the requested mode.
[ 12.872] (II) NVIDIA(0): Validated MetaModes:
[ 12.872] (II) NVIDIA(0): “DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select”
[ 12.872] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1080
[ 12.901] (–) NVIDIA(0): DPI set to (81, 80); computed from “UseEdidDpi” X config
[ 12.901] (–) NVIDIA(0): option
[ 12.901] (–) Depth 24 pixmap format is 32 bpp
[ 12.901] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 12.901] (II) NVIDIA: access.
[ 12.939] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select”
[ 13.118] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 13.118] (==) NVIDIA(0): Backing store enabled
[ 13.118] (==) NVIDIA(0): Silken mouse enabled
[ 13.122] () NVIDIA(0): DPMS enabled
[ 13.122] (II) Loading sub module “dri2”
[ 13.122] (II) LoadModule: “dri2”
[ 13.122] (II) Module “dri2” already built-in
[ 13.122] (II) NVIDIA(0): [DRI2] Setup complete
[ 13.122] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 13.122] (–) RandR disabled
[ 13.126] (II) SELinux: Disabled on system
[ 13.128] (II) Initializing extension GLX
[ 13.128] (II) Indirect GLX disabled.(II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 13.195] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 13.195] (II) LoadModule: “evdev”
[ 13.195] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 13.197] (II) Module evdev: vendor=“X.Org Foundation”
[ 13.197] compiled for 1.16.0, module version = 2.9.0
[ 13.197] Module class: X.Org XInput Driver
[ 13.197] ABI class: X.Org XInput driver, version 21.0
[ 13.197] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 13.197] () Power Button: always reports core events
[ 13.197] () evdev: Power Button: Device: “/dev/input/event4”
[ 13.197] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 13.197] (–) evdev: Power Button: Found keys
[ 13.197] (II) evdev: Power Button: Configuring as keyboard
[ 13.197] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event4”
[ 13.197] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 13.197] () Option “xkb_rules” “evdev”
[ 13.197] () Option “xkb_model” “pc105”
[ 13.197] () Option “xkb_layout” “de”
[ 13.214] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 13.214] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 13.214] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 13.214] () Power Button: always reports core events
[ 13.214] () evdev: Power Button: Device: “/dev/input/event3”
[ 13.214] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 13.214] (–) evdev: Power Button: Found keys
[ 13.214] (II) evdev: Power Button: Configuring as keyboard
[ 13.214] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5/event3”
[ 13.214] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 13.214] () Option “xkb_rules” “evdev”
[ 13.214] () Option “xkb_model” “pc105”
[ 13.214] () Option “xkb_layout” “de”
[ 13.214] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 13.214] (II) No input driver specified, ignoring this device.
[ 13.214] (II) This device may have been added with another device file.
[ 13.214] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 13.214] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 13.214] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 13.215] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event7)
[ 13.215] (II) No input driver specified, ignoring this device.
[ 13.215] (II) This device may have been added with another device file.
[ 13.215] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event8)
[ 13.215] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event9)
[ 13.215] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event10)
[ 13.215] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event11)
[ 13.215] (II) config/udev: Adding input device HDA Intel Line Out Side (/dev/input/event12)
[ 13.215] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event13)
[ 13.215] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event6)
[ 13.216] (II) config/udev: Adding input device NOVATEK Wired Keyboard (/dev/input/event0)
[ 13.216] () NOVATEK Wired Keyboard: Applying InputClass “evdev keyboard catchall”
[ 13.216] (II) Using input driver ‘evdev’ for ‘NOVATEK Wired Keyboard’
[ 13.216] () NOVATEK Wired Keyboard: always reports core events
[ 13.216] () evdev: NOVATEK Wired Keyboard: Device: “/dev/input/event0”
[ 13.216] (–) evdev: NOVATEK Wired Keyboard: Vendor 0x46a Product 0x801
[ 13.216] (–) evdev: NOVATEK Wired Keyboard: Found keys
[ 13.216] (II) evdev: NOVATEK Wired Keyboard: Configuring as keyboard
[ 13.216] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb8/8-1/8-1:1.0/0003:046A:0801.0001/input/input2/event0”
[ 13.216] (II) XINPUT: Adding extended input device “NOVATEK Wired Keyboard” (type: KEYBOARD, id 8)
[ 13.216] () Option “xkb_rules” “evdev”
[ 13.216] () Option “xkb_model” “pc105”
[ 13.216] () Option “xkb_layout” “de”
[ 13.216] (II) config/udev: Adding input device NOVATEK Wired Keyboard (/dev/input/event1)
[ 13.216] () evdev: NOVATEK Wired Keyboard: Device: “/dev/input/event1”
[ 13.216] (–) evdev: NOVATEK Wired Keyboard: Found 12 mouse buttons
[ 13.216] (II) evdev: NOVATEK Wired Keyboard: Forcing relative x/y axes to exist.
[ 13.216] (II) evdev: NOVATEK Wired Keyboard: Configuring as mouse
[ 13.216] () evdev: NOVATEK Wired Keyboard: YAxisMapping: buttons 4 and 5
[ 13.216] () evdev: NOVATEK Wired Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 13.216] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb8/8-1/8-1:1.1/0003:046A:0801.0002/input/input3/event1”
[ 13.216] (II) XINPUT: Adding extended input device “NOVATEK Wired Keyboard” (type: KEYBOARD, id 9)
[ 13.216] (II) config/udev: Adding input device Microsoft Microsoft Trackball Optical® (/dev/input/event2)
[ 13.216] () Microsoft Microsoft Trackball Optical®: Applying InputClass “evdev pointer catchall”
[ 13.216] (II) Using input driver ‘evdev’ for ‘Microsoft Microsoft Trackball Optical®’
[ 13.216] () Microsoft Microsoft Trackball Optical®: always reports core events
[ 13.216] () evdev: Microsoft Microsoft Trackball Optical®: Device: “/dev/input/event2”
[ 13.217] (–) evdev: Microsoft Microsoft Trackball Optical®: Vendor 0x45e Product 0x23
[ 13.217] (–) evdev: Microsoft Microsoft Trackball Optical®: Found 9 mouse buttons
[ 13.217] (–) evdev: Microsoft Microsoft Trackball Optical®: Found scroll wheel(s)
[ 13.217] (–) evdev: Microsoft Microsoft Trackball Optical®: Found relative axes
[ 13.217] (–) evdev: Microsoft Microsoft Trackball Optical®: Found x and y relative axes
[ 13.217] (II) evdev: Microsoft Microsoft Trackball Optical®: Configuring as mouse
[ 13.217] (II) evdev: Microsoft Microsoft Trackball Optical®: Adding scrollwheel support
[ 13.217] () evdev: Microsoft Microsoft Trackball Optical®: YAxisMapping: buttons 4 and 5
[ 13.217] () evdev: Microsoft Microsoft Trackball Optical®: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 13.217] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.1/usb9/9-2/9-2:1.0/0003:045E:0023.0003/input/input4/event2”
[ 13.217] (II) XINPUT: Adding extended input device “Microsoft Microsoft Trackball Optical®” (type: MOUSE, id 10)
[ 13.217] (II) evdev: Microsoft Microsoft Trackball Optical®: initialized for relative axes.
[ 13.217] () Microsoft Microsoft Trackball Optical®: (accel) keeping acceleration scheme 1
[ 13.217] () Microsoft Microsoft Trackball Optical®: (accel) acceleration profile 0
[ 13.217] () Microsoft Microsoft Trackball Optical®: (accel) acceleration factor: 2.000
[ 13.217] () Microsoft Microsoft Trackball Optical®: (accel) acceleration threshold: 4
[ 13.217] (II) config/udev: Adding input device Microsoft Microsoft Trackball Optical® (/dev/input/mouse0)
[ 13.217] (II) No input driver specified, ignoring this device.
[ 13.217] (II) This device may have been added with another device file.
[ 13.217] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 21.703] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 21.703] () NVIDIA(0): device LG Electronics LG TV (DFP-1) (Using EDID
[ 21.703] () NVIDIA(0): frequencies has been enabled on all display devices.)
[ 21.703] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 21.703] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 21.703] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 21.703] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 21.703] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 21.704] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 21.704] (WW) NVIDIA(GPU-0): mode “1280x720” is specified in the EDID; however, the
[ 21.704] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1280x720”.
[ 21.704] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 21.704] (WW) NVIDIA(GPU-0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): HorizSync check for mode “1920x1080”.
[ 21.704] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 21.704] (WW) NVIDIA(GPU-0): mode “720x576” is specified in the EDID; however, the
[ 21.704] (WW) NVIDIA(GPU-0): VertRefresh check for mode “720x576”.
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (27.0 kHz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (15.6 kHz); ignoring
[ 21.704] (WW) NVIDIA(GPU-0): HorizSync check for mode “720x576”.
[ 21.704] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 21.704] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 21.705] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 21.705] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 21.705] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 21.705] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 21.705] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 21.705] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 21.705] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 21.705] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 21.705] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 21.706] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 21.706] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 21.706] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 21.706] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 21.706] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 21.706] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 21.706] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 21.706] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 21.706] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 21.736] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 21.736] () NVIDIA(0): device Philips 278G4 (DFP-0) (Using EDID frequencies has
[ 21.736] () NVIDIA(0): been enabled on all display devices.)
[ 21.737] (WW) NVIDIA(GPU-0): The EDID for Philips 278G4 (DFP-0) contradicts itself: mode
[ 21.737] (WW) NVIDIA(GPU-0): “720x480” is specified in the EDID; however, the EDID’s
[ 21.737] (WW) NVIDIA(GPU-0): valid HorizSync range (26.000-83.000 kHz) would exclude
[ 21.737] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.7 kHz); ignoring HorizSync check
[ 21.737] (WW) NVIDIA(GPU-0): for mode “720x480”.
[ 21.738] (WW) NVIDIA(GPU-0): The EDID for Philips 278G4 (DFP-0) contradicts itself: mode
[ 21.738] (WW) NVIDIA(GPU-0): “720x480” is specified in the EDID; however, the EDID’s
[ 21.738] (WW) NVIDIA(GPU-0): valid HorizSync range (26.000-83.000 kHz) would exclude
[ 21.738] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.7 kHz); ignoring HorizSync check
[ 21.738] (WW) NVIDIA(GPU-0): for mode “720x480”.
[ 21.738] (WW) NVIDIA(GPU-0): “720x576” is specified in the EDID; however, the EDID’s
[ 21.738] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.6 kHz); ignoring HorizSync check
[ 21.738] (WW) NVIDIA(GPU-0): for mode “720x576”.
[ 22.058] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 22.058] () NVIDIA(0): device LG Electronics LG TV (DFP-1) (Using EDID
[ 22.058] () NVIDIA(0): frequencies has been enabled on all display devices.)
[ 22.059] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 22.059] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 22.059] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 22.059] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 22.059] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 22.059] (WW) NVIDIA(GPU-0): mode “1280x720” is specified in the EDID; however, the
[ 22.059] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1280x720”.
[ 22.059] (WW) NVIDIA(GPU-0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 22.059] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 22.059] (WW) NVIDIA(GPU-0): HorizSync check for mode “1920x1080”.
[ 22.059] (WW) NVIDIA(GPU-0): mode “720x576” is specified in the EDID; however, the
[ 22.059] (WW) NVIDIA(GPU-0): VertRefresh check for mode “720x576”.
[ 22.060] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 22.060] (WW) NVIDIA(GPU-0): mode “1920x1080” is specified in the EDID; however, the
[ 22.060] (WW) NVIDIA(GPU-0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (27.0 kHz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): HorizSync check for mode “1920x1080”.
[ 22.060] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): VertRefresh check for mode “1920x1080”.
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): mode “720x576” is specified in the EDID; however, the
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s HorizSync (15.6 kHz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): HorizSync check for mode “720x576”.
[ 22.060] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 22.060] (WW) NVIDIA(GPU-0): VertRefresh check for mode “720x576”.
[ 22.060] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 22.060] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 22.061] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 22.061] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 22.061] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 22.061] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 22.061] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 22.061] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 22.061] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 22.062] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 22.062] (WW) NVIDIA(GPU-0): mode “3840x2160” is specified in the EDID; however, the
[ 22.062] (WW) NVIDIA(GPU-0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 22.062] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 22.062] (WW) NVIDIA(GPU-0): VertRefresh check for mode “3840x2160”.
[ 22.062] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 22.062] (WW) NVIDIA(GPU-0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 22.062] (WW) NVIDIA(GPU-0): mode “4096x2160” is specified in the EDID; however, the
[ 22.062] (WW) NVIDIA(GPU-0): VertRefresh check for mode “4096x2160”.
[ 22.091] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 22.091] () NVIDIA(0): device Philips 278G4 (DFP-0) (Using EDID frequencies has
[ 22.091] (**) NVIDIA(0): been enabled on all display devices.)
[ 22.092] (WW) NVIDIA(GPU-0): The EDID for Philips 278G4 (DFP-0) contradicts itself: mode
[ 22.092] (WW) NVIDIA(GPU-0): “720x480” is specified in the EDID; however, the EDID’s
[ 22.092] (WW) NVIDIA(GPU-0): valid HorizSync range (26.000-83.000 kHz) would exclude
[ 22.092] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.7 kHz); ignoring HorizSync check
[ 22.092] (WW) NVIDIA(GPU-0): for mode “720x480”.
[ 22.092] (WW) NVIDIA(GPU-0): “720x576” is specified in the EDID; however, the EDID’s
[ 22.092] (WW) NVIDIA(GPU-0): this mode’s HorizSync (15.6 kHz); ignoring HorizSync check
[ 22.092] (WW) NVIDIA(GPU-0): for mode “720x576”.
[ 22.545] (II) NVIDIA(0): Setting mode “DVI-I-1: 1920x1080_50 @1920x1080 +3840+540 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
[ 22.829] (II) NVIDIA(0): Setting mode “DVI-I-1: 1920x1080_50 @1920x1080 +3840+540 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, HDMI-0: 3840x2160 @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}”
Can you please try starting X with the “-logverbose 6” option or use “nvidia-xconfig --mode-debug” to turn on mode validation debugging? My hunch is that these modes require YUV 4:2:0 compression, which is not yet supported. You can tell if the driver prints the following to the log when verbose mode logging is enabled:
Mode requires YUV 4:2:0 compression
