I’m going to dump two big logs here.
In both cases, the HDMI output Jack of the Nano is connected to an Optoma ML550 projector via HDMI-HDMI cable. The second jack (DisplayPort output) is what I’m having trouble with and ultimately I’d like to connect it to another Optoma ML550, but for now I’ve just connected it to a monitor that I have lying around (Acer XB252Q)
LOG #1 “directly via DisplayPort-DisplayPort cable”:
Nano (DisplayPort output Jack) ==> DisplayPort-to-DisplayPort-cable ==> Monitor (DisplayPort input jack)
LOG #2 “via dongle”:
Nano (DisplayPort output Jack) ==> DisplayPort-to-DVI dongle ==> DVI-to-HDMI-cable ==> Monitor (HDMI input jack)
(I’ve tried so many different kinds of DisplayPort-to-DVI dongles my desk is cluttered with them now - active/passive/doesn’t seem to matter.)
Here comes LOG #1 of direct DisplayPort connection (which works correctly)
[ 16.132] (–) Log file renamed from “/var/log/Xorg.pid-5501.log” to “/var/log/Xorg.0.log”
[ 16.135]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 16.135] X Protocol Version 11, Revision 0
[ 16.135] Build Operating System: Linux 4.4.0-148-generic aarch64 Ubuntu
[ 16.135] Current Operating System: Linux chad-mib4 4.9.140-tegra #1 SMP PREEMPT Mon Aug 12 21:16:23 PDT 2019 aarch64
[ 16.135] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 16.135] Build Date: 03 June 2019 08:11:53AM
[ 16.135] xorg-server 2:1.19.6-1ubuntu4.3 (For technical support please see http://www.ubuntu.com/support)
[ 16.135] Current version of pixman: 0.34.0
[ 16.135] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 16.135] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 16.135] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Nov 7 09:59:22 2019
[ 16.137] (==) Using config file: “/etc/X11/xorg.conf”
[ 16.137] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 16.140] (==) No Layout section. Using the first Screen section.
[ 16.141] (==) No screen section available. Using defaults.
[ 16.141] () |–>Screen “Default Screen Section” (0)
[ 16.141] () | |–>Monitor “”
[ 16.141] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 16.141] () | |–>Device “Tegra0”
[ 16.141] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 16.141] (==) Automatically adding devices
[ 16.141] (==) Automatically enabling devices
[ 16.142] (==) Automatically adding GPU devices
[ 16.142] (==) Automatically binding GPU devices
[ 16.142] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 16.149] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 16.149] Entry deleted from font path.
[ 16.149] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 16.149] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 16.150] Entry deleted from font path.
[ 16.150] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 16.150] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 16.150] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 16.150] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 16.150] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 16.150] (II) Loader magic: 0x558d10d010
[ 16.150] (II) Module ABI versions:
[ 16.150] X.Org ANSI C Emulation: 0.4
[ 16.150] X.Org Video Driver: 23.0
[ 16.150] X.Org XInput driver : 24.1
[ 16.150] X.Org Server Extension : 10.0
[ 16.152] (++) using VT number 1
[ 16.156] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 16.158] (II) no primary bus or device found
[ 16.158] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 16.158] (II) “glx” will be loaded by default.
[ 16.158] (II) LoadModule: “extmod”
[ 16.158] (II) Module “extmod” already built-in
[ 16.158] (II) LoadModule: “glx”
[ 16.160] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 16.199] (II) Module glx: vendor=“X.Org Foundation”
[ 16.199] compiled for 1.19.6, module version = 1.0.0
[ 16.199] ABI class: X.Org Server Extension, version 10.0
[ 16.199] (II) LoadModule: “nvidia”
[ 16.201] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 16.243] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 16.243] compiled for 4.0.2, module version = 1.0.0
[ 16.243] Module class: X.Org Video Driver
[ 16.251] (II) NVIDIA dlloader X Driver 32.2.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3561) Mon Aug 12 21:17:27 PDT 2019
[ 16.251] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 16.251] (WW) Falling back to old probe method for NVIDIA
[ 16.251] (II) Loading sub module “fb”
[ 16.251] (II) LoadModule: “fb”
[ 16.252] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 16.256] (II) Module fb: vendor=“X.Org Foundation”
[ 16.256] compiled for 1.19.6, module version = 1.0.0
[ 16.256] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.256] (II) Loading sub module “wfb”
[ 16.256] (II) LoadModule: “wfb”
[ 16.256] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 16.260] (II) Module wfb: vendor=“X.Org Foundation”
[ 16.260] compiled for 1.19.6, module version = 1.0.0
[ 16.260] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.260] (II) Loading sub module “ramdac”
[ 16.260] (II) LoadModule: “ramdac”
[ 16.260] (II) Module “ramdac” already built-in
[ 16.262] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 16.262] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 16.262] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 16.262] (==) NVIDIA(0): RGB weight 888
[ 16.262] (==) NVIDIA(0): Default visual is TrueColor
[ 16.262] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 16.262] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 16.262] () NVIDIA(0): Option “ModeDebug”
[ 16.262] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 16.262] (**) NVIDIA(0): Enabling 2D acceleration
[ 16.263] (II) Loading sub module “glxserver_nvidia”
[ 16.263] (II) LoadModule: “glxserver_nvidia”
[ 16.263] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 16.533] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 16.534] compiled for 4.0.2, module version = 1.0.0
[ 16.534] Module class: X.Org Server Extension
[ 16.534] (II) NVIDIA GLX Module 32.2.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3561) Mon Aug 12 21:15:45 PDT 2019
[ 16.584] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 16.584] (–) NVIDIA(0): DFP-0
[ 16.584] (–) NVIDIA(0): DFP-1
[ 16.584] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 16.584] (–) NVIDIA(0): Memory: 4051312 kBytes
[ 16.584] (–) NVIDIA(0): VideoBIOS:
[ 16.585] (–) NVIDIA(GPU-0): OTM Optoma WXGA (DFP-0): connected
[ 16.585] (–) NVIDIA(GPU-0): OTM Optoma WXGA (DFP-0): External TMDS
[ 16.585] (–) NVIDIA(GPU-0): OTM Optoma WXGA (DFP-0) Name Aliases:
[ 16.585] (–) NVIDIA(GPU-0): DFP
[ 16.585] (–) NVIDIA(GPU-0): DFP-0
[ 16.585] (–) NVIDIA(GPU-0): DPY-0
[ 16.585] (–) NVIDIA(GPU-0): HDMI-0
[ 16.585] (–) NVIDIA(GPU-0): DPY-EDID-9f9eb270-57ca-9108-c9a0-49882806d390
[ 16.585] (–) NVIDIA(GPU-0): Acer XB252Q (DFP-1): connected
[ 16.585] (–) NVIDIA(GPU-0): Acer XB252Q (DFP-1): External TMDS
[ 16.585] (–) NVIDIA(GPU-0): Acer XB252Q (DFP-1) Name Aliases:
[ 16.585] (–) NVIDIA(GPU-0): DFP-1
[ 16.585] (–) NVIDIA(GPU-0): DPY-1
[ 16.585] (–) NVIDIA(GPU-0): DP-0
[ 16.585] (–) NVIDIA(GPU-0): DPY-EDID-70ff6efd-00af-5d2d-5d0f-666d7ca5c317
[ 16.585] (II) NVIDIA(GPU-0):
[ 16.585] (II) NVIDIA(GPU-0): — Building ModePool for OTM Optoma WXGA (DFP-0) —
[ 16.586] (II) NVIDIA(GPU-0): Validating Mode “1280x800_60”:
[ 16.586] (II) NVIDIA(GPU-0): Mode Sources: EDID, Detailed
[ 16.586] (II) NVIDIA(GPU-0): 1280 x 800 @ 60 Hz
[ 16.586] (II) NVIDIA(GPU-0): Pixel Clock : 83.50 MHz
[ 16.586] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1352
[ 16.586] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1480, 1680
[ 16.586] (II) NVIDIA(GPU-0): VRes, VSyncStart : 800, 803
[ 16.586] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 809, 831
[ 16.586] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.586] (II) NVIDIA(GPU-0): Mode “1280x800_60” is valid.
[ 16.586] (II) NVIDIA(GPU-0): Validating Mode “720x400_70”:
[ 16.586] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.586] (II) NVIDIA(GPU-0): 720 x 400 @ 70 Hz
[ 16.586] (II) NVIDIA(GPU-0): Pixel Clock : 26.17 MHz
[ 16.586] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 737
[ 16.586] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 808, 896
[ 16.586] (II) NVIDIA(GPU-0): VRes, VSyncStart : 400, 402
[ 16.586] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 405, 417
[ 16.586] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.586] (II) NVIDIA(GPU-0): Mode “720x400_70” is valid.
[ 16.586] (II) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[ 16.586] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 16.586] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 16.586] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 16.586] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 16.586] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 16.586] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 16.587] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.587] (II) NVIDIA(GPU-0): Mode “640x480_60” is valid.
[ 16.587] (II) NVIDIA(GPU-0): Validating Mode “640x480_67”:
[ 16.587] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.587] (II) NVIDIA(GPU-0): 640 x 480 @ 67 Hz
[ 16.587] (II) NVIDIA(GPU-0): Pixel Clock : 27.11 MHz
[ 16.587] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 661
[ 16.587] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 725, 810
[ 16.587] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 482
[ 16.587] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 485, 499
[ 16.587] (II) NVIDIA(GPU-0): Mode “640x480_67” is valid.
[ 16.587] (II) NVIDIA(GPU-0): Validating Mode “640x480_73”:
[ 16.587] (II) NVIDIA(GPU-0): 640 x 480 @ 73 Hz
[ 16.587] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 16.587] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 664
[ 16.587] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 704, 832
[ 16.587] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 16.587] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 491, 520
[ 16.587] (II) NVIDIA(GPU-0): Mode “640x480_73” is valid.
[ 16.587] (II) NVIDIA(GPU-0): Validating Mode “640x480_75”:
[ 16.587] (II) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[ 16.587] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 16.587] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 720, 840
[ 16.587] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 485, 500
[ 16.588] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.588] (II) NVIDIA(GPU-0): Mode “640x480_75” is valid.
[ 16.588] (II) NVIDIA(GPU-0): Validating Mode “800x600_56”:
[ 16.588] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.588] (II) NVIDIA(GPU-0): 800 x 600 @ 56 Hz
[ 16.588] (II) NVIDIA(GPU-0): Pixel Clock : 36.00 MHz
[ 16.588] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 824
[ 16.588] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1024
[ 16.588] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 602
[ 16.588] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 625
[ 16.588] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.588] (II) NVIDIA(GPU-0): Mode “800x600_56” is valid.
[ 16.588] (II) NVIDIA(GPU-0): Validating Mode “800x600_60”:
[ 16.588] (II) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[ 16.588] (II) NVIDIA(GPU-0): Pixel Clock : 40.00 MHz
[ 16.588] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 840
[ 16.588] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 968, 1056
[ 16.588] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 606, 628
[ 16.588] (II) NVIDIA(GPU-0): Mode “800x600_60” is valid.
[ 16.588] (II) NVIDIA(GPU-0): Validating Mode “800x600_72”:
[ 16.588] (II) NVIDIA(GPU-0): 800 x 600 @ 72 Hz
[ 16.588] (II) NVIDIA(GPU-0): Pixel Clock : 50.00 MHz
[ 16.588] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 856
[ 16.588] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 976, 1040
[ 16.588] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 637
[ 16.588] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 643, 666
[ 16.588] (II) NVIDIA(GPU-0): Mode “800x600_72” is valid.
[ 16.589] (II) NVIDIA(GPU-0):
[ 16.589] (II) NVIDIA(GPU-0): Validating Mode “800x600_75”:
[ 16.589] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.589] (II) NVIDIA(GPU-0): 800 x 600 @ 75 Hz
[ 16.589] (II) NVIDIA(GPU-0): Pixel Clock : 49.50 MHz
[ 16.589] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 816
[ 16.589] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1056
[ 16.589] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 602
[ 16.589] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 605, 625
[ 16.589] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.589] (II) NVIDIA(GPU-0): Mode “800x600_75” is valid.
[ 16.589] (II) NVIDIA(GPU-0): Validating Mode “832x624_75”:
[ 16.589] (II) NVIDIA(GPU-0): 832 x 624 @ 75 Hz
[ 16.589] (II) NVIDIA(GPU-0): Pixel Clock : 53.43 MHz
[ 16.589] (II) NVIDIA(GPU-0): HRes, HSyncStart : 832, 875
[ 16.589] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 962, 1092
[ 16.589] (II) NVIDIA(GPU-0): VRes, VSyncStart : 624, 626
[ 16.589] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 629, 652
[ 16.589] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.589] (II) NVIDIA(GPU-0): Mode “832x624_75” is valid.
[ 16.589] (II) NVIDIA(GPU-0): Validating Mode “1024x768_60”:
[ 16.589] (II) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[ 16.589] (II) NVIDIA(GPU-0): Pixel Clock : 65.00 MHz
[ 16.589] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[ 16.589] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1344
[ 16.589] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[ 16.589] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 806
[ 16.589] (II) NVIDIA(GPU-0): Mode “1024x768_60” is valid.
[ 16.589] (II) NVIDIA(GPU-0): Validating Mode “1024x768_70”:
[ 16.589] (II) NVIDIA(GPU-0): 1024 x 768 @ 70 Hz
[ 16.590] (II) NVIDIA(GPU-0): Pixel Clock : 75.00 MHz
[ 16.590] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[ 16.590] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1328
[ 16.590] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[ 16.590] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 806
[ 16.590] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.590] (II) NVIDIA(GPU-0): Mode “1024x768_70” is valid.
[ 16.590] (II) NVIDIA(GPU-0): Validating Mode “1024x768_75”:
[ 16.590] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.590] (II) NVIDIA(GPU-0): 1024 x 768 @ 75 Hz
[ 16.590] (II) NVIDIA(GPU-0): Pixel Clock : 78.75 MHz
[ 16.590] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1040
[ 16.590] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1136, 1312
[ 16.590] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 770
[ 16.590] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 773, 800
[ 16.590] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.590] (II) NVIDIA(GPU-0): Mode “1024x768_75” is valid.
[ 16.590] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_75”:
[ 16.590] (II) NVIDIA(GPU-0): 1280 x 1024 @ 75 Hz
[ 16.590] (II) NVIDIA(GPU-0): Pixel Clock : 135.01 MHz
[ 16.590] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1296
[ 16.590] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1440, 1688
[ 16.590] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1024, 1026
[ 16.590] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1029, 1066
[ 16.590] (II) NVIDIA(GPU-0): Mode “1280x1024_75” is valid.
[ 16.590] (II) NVIDIA(GPU-0): Validating Mode “1152x864_75”:
[ 16.590] (II) NVIDIA(GPU-0): 1152 x 864 @ 75 Hz
[ 16.590] (II) NVIDIA(GPU-0): Pixel Clock : 108.00 MHz
[ 16.590] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1152, 1216
[ 16.590] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1344, 1600
[ 16.590] (II) NVIDIA(GPU-0): VRes, VSyncStart : 864, 866
[ 16.591] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 869, 900
[ 16.591] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.591] (II) NVIDIA(GPU-0): Mode “1152x864_75” is valid.
[ 16.591] (II) NVIDIA(GPU-0): Validating Mode “800x600_120”:
[ 16.591] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.591] (II) NVIDIA(GPU-0): 800 x 600 @ 120 Hz
[ 16.591] (II) NVIDIA(GPU-0): Pixel Clock : 83.55 MHz
[ 16.591] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 855
[ 16.591] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 941, 1082
[ 16.591] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 602
[ 16.591] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 605, 643
[ 16.591] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.591] (II) NVIDIA(GPU-0): Mode “800x600_120” is valid.
[ 16.591] (II) NVIDIA(GPU-0): Validating Mode “1024x768_120”:
[ 16.591] (II) NVIDIA(GPU-0): 1024 x 768 @ 120 Hz
[ 16.591] (II) NVIDIA(GPU-0): Pixel Clock : 138.52 MHz
[ 16.591] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1101
[ 16.591] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1213, 1402
[ 16.591] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 770
[ 16.591] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 773, 823
[ 16.591] (II) NVIDIA(GPU-0): Mode “1024x768_120” is valid.
[ 16.591] (II) NVIDIA(GPU-0): Validating Mode “1280x800_60”:
[ 16.591] (II) NVIDIA(GPU-0): 1280 x 800 @ 60 Hz
[ 16.591] (II) NVIDIA(GPU-0): Pixel Clock : 83.50 MHz
[ 16.591] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1352
[ 16.591] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1480, 1680
[ 16.591] (II) NVIDIA(GPU-0): VRes, VSyncStart : 800, 803
[ 16.591] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 809, 831
[ 16.591] (II) NVIDIA(GPU-0): H/V Polarity : -/+
[ 16.591] (II) NVIDIA(GPU-0): Mode “1280x800_60” is valid.
[ 16.592] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_60”:
[ 16.592] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 16.592] (II) NVIDIA(GPU-0): 1280 x 1024 @ 60 Hz
[ 16.592] (II) NVIDIA(GPU-0): Pixel Clock : 107.97 MHz
[ 16.592] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1328
[ 16.592] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1440, 1688
[ 16.592] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1024, 1026
[ 16.592] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1029, 1066
[ 16.592] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.592] (II) NVIDIA(GPU-0): Mode “1280x1024_60” is valid.
[ 16.592] (II) NVIDIA(GPU-0): Validating Mode “1680x1050_60”:
[ 16.592] (II) NVIDIA(GPU-0): 1680 x 1050 @ 60 Hz
[ 16.592] (II) NVIDIA(GPU-0): Pixel Clock : 146.26 MHz
[ 16.592] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1680, 1784
[ 16.592] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1960, 2240
[ 16.592] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1050, 1053
[ 16.592] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1059, 1089
[ 16.592] (II) NVIDIA(GPU-0): H/V Polarity : -/+
[ 16.592] (II) NVIDIA(GPU-0): Mode “1680x1050_60” is valid.
[ 16.592] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 16.592] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 16.592] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 16.592] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 16.592] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 16.592] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 16.592] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 16.592] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 16.592] (II) NVIDIA(GPU-0): Validating Mode “1280x960_60”:
[ 16.593] (II) NVIDIA(GPU-0): 1280 x 960 @ 60 Hz
[ 16.593] (II) NVIDIA(GPU-0): Pixel Clock : 108.00 MHz
[ 16.593] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1376
[ 16.593] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1488, 1800
[ 16.593] (II) NVIDIA(GPU-0): VRes, VSyncStart : 960, 962
[ 16.593] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 965, 1000
[ 16.593] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.593] (II) NVIDIA(GPU-0): Mode “1280x960_60” is valid.
[ 16.593] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 16.593] (II) NVIDIA(GPU-0): Mode Sources: EDID, CEA, Detailed
[ 16.593] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 16.593] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 16.593] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 16.593] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 16.593] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 16.593] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 16.593] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 16.593] (II) NVIDIA(GPU-0): Validating Mode “1366x768_60”:
[ 16.593] (II) NVIDIA(GPU-0): Mode Sources: EDID, Detailed
[ 16.593] (II) NVIDIA(GPU-0): 1366 x 768 @ 60 Hz
[ 16.593] (II) NVIDIA(GPU-0): Pixel Clock : 85.51 MHz
[ 16.593] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1366, 1436
[ 16.593] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1579, 1792
[ 16.593] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[ 16.593] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 774, 798
[ 16.593] (II) NVIDIA(GPU-0): Mode “1366x768_60” is valid.
[ 16.593] (II) NVIDIA(GPU-0): Validating Mode “720x480_60”:
[ 16.593] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 16.593] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 16.594] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 16.594] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 16.594] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 16.594] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 16.594] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.594] (II) NVIDIA(GPU-0): Mode “720x480_60” is valid.
[ 16.594] (II) NVIDIA(GPU-0): Validating Mode “720x480_60”:
[ 16.594] (II) NVIDIA(GPU-0): Mode Sources: EDID, CEA
[ 16.594] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 16.594] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 16.594] (II) NVIDIA(GPU-0): Validating Mode “720x576_50”:
[ 16.594] (II) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[ 16.594] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[ 16.594] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[ 16.594] (II) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[ 16.594] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[ 16.594] (II) NVIDIA(GPU-0): Mode “720x576_50” is valid.
[ 16.594] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 16.594] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 16.594] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 16.594] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 16.594] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 16.594] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 16.594] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 16.595] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.595] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 16.595] (II) NVIDIA(GPU-0): Validating Mode “1280x720_50”:
[ 16.595] (II) NVIDIA(GPU-0): Mode Sources: EDID, CEA
[ 16.595] (II) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[ 16.595] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 16.595] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[ 16.595] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[ 16.595] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 16.595] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 16.595] (II) NVIDIA(GPU-0): Mode “1280x720_50” is valid.
[ 16.595] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_60”:
[ 16.595] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 16.595] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 16.595] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 16.595] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 16.595] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 16.595] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 16.595] (II) NVIDIA(GPU-0): Mode “1920x1080_60” is valid.
[ 16.595] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_50”:
[ 16.595] (II) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[ 16.595] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[ 16.595] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[ 16.595] (II) NVIDIA(GPU-0): Mode “1920x1080_50” is valid.
[ 16.596] (II) NVIDIA(GPU-0):
[ 16.596] (II) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[ 16.596] (II) NVIDIA(GPU-0): Mode Sources: EDID, CEA
[ 16.596] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 16.596] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 16.596] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 16.596] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 16.596] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 16.596] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 16.596] (II) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.596] (II) NVIDIA(GPU-0): Mode “640x480_60” is valid.
[ 16.596] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_24”:
[ 16.596] (II) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[ 16.596] (II) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[ 16.596] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[ 16.596] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[ 16.596] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 16.596] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 16.596] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.596] (II) NVIDIA(GPU-0): Mode “1920x1080_24” is valid.
[ 16.596] (II) NVIDIA(GPU-0): Validating Mode “1280x720_60”:
[ 16.596] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 16.596] (II) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 16.596] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 16.596] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 16.596] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 16.596] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 16.596] (II) NVIDIA(GPU-0): Mode “1280x720_60” is valid.
[ 16.596] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_60”:
[ 16.597] (II) NVIDIA(GPU-0): Mode Sources: EDID, CEA
[ 16.597] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 16.597] (II) NVIDIA(GPU-0): Pixel Clock : 148.37 MHz
[ 16.597] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 16.597] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 16.597] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 16.597] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 16.597] (II) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.597] (II) NVIDIA(GPU-0): Mode “1920x1080_60” is valid.
[ 16.597] (II) NVIDIA(GPU-0): Validating Mode “1920x1080_24”:
[ 16.597] (II) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[ 16.597] (II) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 16.597] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[ 16.597] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[ 16.597] (II) NVIDIA(GPU-0): Mode “1920x1080_24” is valid.
[ 16.597] (WW) NVIDIA(GPU-0): Validating Mode “640x350_85”:
[ 16.597] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.597] (WW) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[ 16.597] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 16.597] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[ 16.597] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[ 16.597] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 350, 382
[ 16.597] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 385, 445
[ 16.597] (WW) NVIDIA(GPU-0): H/V Polarity : +/-
[ 16.597] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.597] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.597] (WW) NVIDIA(GPU-0): Mode “640x350_85” is invalid.
[ 16.597] (WW) NVIDIA(GPU-0): Validating Mode “320x175d85”:
[ 16.598] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.598] (WW) NVIDIA(GPU-0): 320 x 175 @ 85 Hz
[ 16.598] (WW) NVIDIA(GPU-0): Pixel Clock : 15.75 MHz
[ 16.598] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 336
[ 16.598] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 368, 416
[ 16.598] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 175, 191
[ 16.598] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 192, 222
[ 16.598] (WW) NVIDIA(GPU-0): H/V Polarity : +/-
[ 16.598] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.598] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.598] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.598] (WW) NVIDIA(GPU-0): Mode “320x175d85” is invalid.
[ 16.598] (WW) NVIDIA(GPU-0): Validating Mode “640x400_85”:
[ 16.598] (WW) NVIDIA(GPU-0): 640 x 400 @ 85 Hz
[ 16.598] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 16.598] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[ 16.598] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[ 16.598] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[ 16.598] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 445
[ 16.598] (WW) NVIDIA(GPU-0): H/V Polarity : -/+
[ 16.598] (WW) NVIDIA(GPU-0): Mode “640x400_85” is invalid.
[ 16.598] (WW) NVIDIA(GPU-0): Validating Mode “320x200d85”:
[ 16.598] (WW) NVIDIA(GPU-0): 320 x 200 @ 85 Hz
[ 16.598] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 200, 200
[ 16.598] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 202, 222
[ 16.599] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.599] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.599] (WW) NVIDIA(GPU-0): Mode “320x200d85” is invalid.
[ 16.599] (WW) NVIDIA(GPU-0): Validating Mode “720x400_85”:
[ 16.599] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.599] (WW) NVIDIA(GPU-0): 720 x 400 @ 85 Hz
[ 16.599] (WW) NVIDIA(GPU-0): Pixel Clock : 35.50 MHz
[ 16.599] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 720, 756
[ 16.599] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 828, 936
[ 16.599] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[ 16.599] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 446
[ 16.599] (WW) NVIDIA(GPU-0): H/V Polarity : -/+
[ 16.599] (WW) NVIDIA(GPU-0): Mode “720x400_85” is invalid.
[ 16.599] (WW) NVIDIA(GPU-0): Validating Mode “360x200d85”:
[ 16.599] (WW) NVIDIA(GPU-0): 360 x 200 @ 85 Hz
[ 16.599] (WW) NVIDIA(GPU-0): Pixel Clock : 17.75 MHz
[ 16.599] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 360, 378
[ 16.599] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 414, 468
[ 16.599] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 200, 200
[ 16.599] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 202, 223
[ 16.599] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.599] (WW) NVIDIA(GPU-0): Mode “360x200d85” is invalid.
[ 16.599] (WW) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[ 16.599] (WW) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 16.599] (WW) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 16.599] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 16.599] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 16.599] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 16.600] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 16.600] (WW) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.600] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.600] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.600] (WW) NVIDIA(GPU-0): Mode “640x480_60” is invalid.
[ 16.600] (WW) NVIDIA(GPU-0): Validating Mode “320x240d60”:
[ 16.600] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.600] (WW) NVIDIA(GPU-0): 320 x 240 @ 60 Hz
[ 16.600] (WW) NVIDIA(GPU-0): Pixel Clock : 12.59 MHz
[ 16.600] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 328
[ 16.600] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 376, 400
[ 16.600] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 240, 245
[ 16.600] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 246, 262
[ 16.600] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.600] (WW) NVIDIA(GPU-0): Mode “320x240d60” is invalid.
[ 16.600] (WW) NVIDIA(GPU-0): Validating Mode “640x480_73”:
[ 16.600] (WW) NVIDIA(GPU-0): 640 x 480 @ 73 Hz
[ 16.600] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 16.600] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 664
[ 16.600] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 704, 832
[ 16.600] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 16.600] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 520
[ 16.600] (WW) NVIDIA(GPU-0): Mode “640x480_73” is invalid.
[ 16.600] (WW) NVIDIA(GPU-0): Validating Mode “320x240d73”:
[ 16.600] (WW) NVIDIA(GPU-0): 320 x 240 @ 73 Hz
[ 16.600] (WW) NVIDIA(GPU-0): Pixel Clock : 15.75 MHz
[ 16.600] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 332
[ 16.601] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 352, 416
[ 16.601] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 240, 244
[ 16.601] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 246, 260
[ 16.601] (WW) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.601] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.601] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.601] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.601] (WW) NVIDIA(GPU-0): Mode “320x240d73” is invalid.
[ 16.601] (WW) NVIDIA(GPU-0): Validating Mode “640x480_75”:
[ 16.601] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.601] (WW) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[ 16.601] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 16.601] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 16.601] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 720, 840
[ 16.601] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[ 16.601] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 500
[ 16.601] (WW) NVIDIA(GPU-0): Mode “640x480_75” is invalid.
[ 16.601] (WW) NVIDIA(GPU-0): Validating Mode “320x240d75”:
[ 16.601] (WW) NVIDIA(GPU-0): 320 x 240 @ 75 Hz
[ 16.601] (WW) NVIDIA(GPU-0): Pixel Clock : 15.75 MHz
[ 16.601] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 328
[ 16.601] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 360, 420
[ 16.601] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 240, 240
[ 16.601] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 242, 250
[ 16.601] (WW) NVIDIA(GPU-0): Mode “320x240d75” is invalid.
[ 16.601] (WW) NVIDIA(GPU-0): Validating Mode “640x480_85”:
[ 16.601] (WW) NVIDIA(GPU-0): 640 x 480 @ 85 Hz
[ 16.602] (WW) NVIDIA(GPU-0): Pixel Clock : 36.00 MHz
[ 16.602] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 640, 696
[ 16.602] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 832
[ 16.602] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[ 16.602] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 509
[ 16.602] (WW) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.602] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.602] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.602] (WW) NVIDIA(GPU-0): Mode “640x480_85” is invalid.
[ 16.602] (WW) NVIDIA(GPU-0): Validating Mode “320x240d85”:
[ 16.602] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.602] (WW) NVIDIA(GPU-0): 320 x 240 @ 85 Hz
[ 16.602] (WW) NVIDIA(GPU-0): Pixel Clock : 18.00 MHz
[ 16.602] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 348
[ 16.602] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 376, 416
[ 16.602] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 240, 240
[ 16.602] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 242, 254
[ 16.602] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.602] (WW) NVIDIA(GPU-0): Mode “320x240d85” is invalid.
[ 16.602] (WW) NVIDIA(GPU-0): Validating Mode “800x600_56”:
[ 16.602] (WW) NVIDIA(GPU-0): 800 x 600 @ 56 Hz
[ 16.602] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 800, 824
[ 16.602] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1024
[ 16.602] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 16.602] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 603, 625
[ 16.602] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.602] (WW) NVIDIA(GPU-0): Mode “800x600_56” is invalid.
[ 16.602] (WW) NVIDIA(GPU-0): Validating Mode “400x300d56”:
[ 16.603] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.603] (WW) NVIDIA(GPU-0): 400 x 300 @ 56 Hz
[ 16.603] (WW) NVIDIA(GPU-0): Pixel Clock : 18.00 MHz
[ 16.603] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 400, 412
[ 16.603] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 448, 512
[ 16.603] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 300, 300
[ 16.603] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 301, 312
[ 16.603] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.603] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.603] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.603] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.603] (WW) NVIDIA(GPU-0): Mode “400x300d56” is invalid.
[ 16.603] (WW) NVIDIA(GPU-0): Validating Mode “800x600_60”:
[ 16.603] (WW) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[ 16.603] (WW) NVIDIA(GPU-0): Pixel Clock : 40.00 MHz
[ 16.603] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 800, 840
[ 16.603] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 968, 1056
[ 16.603] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 16.603] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 605, 628
[ 16.603] (WW) NVIDIA(GPU-0): Mode “800x600_60” is invalid.
[ 16.603] (WW) NVIDIA(GPU-0): Validating Mode “400x300d60”:
[ 16.603] (WW) NVIDIA(GPU-0): 400 x 300 @ 60 Hz
[ 16.603] (WW) NVIDIA(GPU-0): Pixel Clock : 20.00 MHz
[ 16.603] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 400, 420
[ 16.603] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 484, 528
[ 16.603] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 302, 314
[ 16.604] (WW) NVIDIA(GPU-0): Mode “400x300d60” is invalid.
[ 16.604] (WW) NVIDIA(GPU-0): Validating Mode “800x600_72”:
[ 16.604] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.604] (WW) NVIDIA(GPU-0): 800 x 600 @ 72 Hz
[ 16.604] (WW) NVIDIA(GPU-0): Pixel Clock : 50.00 MHz
[ 16.604] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 800, 856
[ 16.604] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 976, 1040
[ 16.604] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 600, 637
[ 16.604] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 643, 666
[ 16.604] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.604] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.604] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.604] (WW) NVIDIA(GPU-0): Mode “800x600_72” is invalid.
[ 16.604] (WW) NVIDIA(GPU-0): Validating Mode “400x300d72”:
[ 16.604] (WW) NVIDIA(GPU-0): 400 x 300 @ 72 Hz
[ 16.604] (WW) NVIDIA(GPU-0): Pixel Clock : 25.00 MHz
[ 16.604] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 400, 428
[ 16.604] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 488, 520
[ 16.604] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 300, 318
[ 16.656] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 321, 333
[ 16.656] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.656] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.656] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.656] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.656] (WW) NVIDIA(GPU-0): Mode “400x300d72” is invalid.
[ 16.656] (WW) NVIDIA(GPU-0): Validating Mode “800x600_75”:
[ 16.656] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.656] (WW) NVIDIA(GPU-0): 800 x 600 @ 75 Hz
[ 16.656] (WW) NVIDIA(GPU-0): Pixel Clock : 49.50 MHz
[ 16.657] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 800, 816
[ 16.657] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1056
[ 16.657] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 16.657] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 625
[ 16.657] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.657] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.657] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.657] (WW) NVIDIA(GPU-0): Mode “800x600_75” is invalid.
[ 16.657] (WW) NVIDIA(GPU-0): Validating Mode “400x300d75”:
[ 16.657] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.657] (WW) NVIDIA(GPU-0): 400 x 300 @ 75 Hz
[ 16.657] (WW) NVIDIA(GPU-0): Pixel Clock : 24.75 MHz
[ 16.657] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 400, 408
[ 16.657] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 448, 528
[ 16.657] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 300, 300
[ 16.657] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 302, 312
[ 16.657] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.657] (WW) NVIDIA(GPU-0): Mode “400x300d75” is invalid.
[ 16.657] (WW) NVIDIA(GPU-0): Validating Mode “800x600_85”:
[ 16.657] (WW) NVIDIA(GPU-0): 800 x 600 @ 85 Hz
[ 16.657] (WW) NVIDIA(GPU-0): Pixel Clock : 56.30 MHz
[ 16.657] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 800, 832
[ 16.657] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1048
[ 16.657] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 631
[ 16.657] (WW) NVIDIA(GPU-0): Mode “800x600_85” is invalid.
[ 16.657] (WW) NVIDIA(GPU-0): Validating Mode “400x300d85”:
[ 16.657] (WW) NVIDIA(GPU-0): 400 x 300 @ 85 Hz
[ 16.658] (WW) NVIDIA(GPU-0): Pixel Clock : 28.15 MHz
[ 16.658] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 400, 416
[ 16.658] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 448, 524
[ 16.658] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 300, 300
[ 16.658] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 302, 315
[ 16.658] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.658] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.658] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.658] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.658] (WW) NVIDIA(GPU-0): Mode “400x300d85” is invalid.
[ 16.658] (WW) NVIDIA(GPU-0): Validating Mode “1024x768_87i”:
[ 16.658] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.658] (WW) NVIDIA(GPU-0): 1024 x 768 @ 87 Hz
[ 16.658] (WW) NVIDIA(GPU-0): Pixel Clock : 44.90 MHz
[ 16.658] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1032
[ 16.658] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1208, 1264
[ 16.658] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 768, 768
[ 16.658] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 776, 817
[ 16.658] (WW) NVIDIA(GPU-0): Extra : Interlace
[ 16.658] (WW) NVIDIA(GPU-0): Mode “1024x768_87i” is invalid.
[ 16.658] (WW) NVIDIA(GPU-0): Validating Mode “512x384d87i”:
[ 16.658] (WW) NVIDIA(GPU-0): 512 x 384 @ 87 Hz
[ 16.658] (WW) NVIDIA(GPU-0): Pixel Clock : 22.45 MHz
[ 16.658] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 512, 516
[ 16.658] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 604, 632
[ 16.658] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 384, 384
[ 16.658] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 388, 408
[ 16.658] (WW) NVIDIA(GPU-0): Extra : Interlace DoubleScan
[ 16.658] (WW) NVIDIA(GPU-0): Mode “512x384d87i” is invalid.
[ 16.658] (WW) NVIDIA(GPU-0): Validating Mode “1024x768_60”:
[ 16.659] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.659] (WW) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[ 16.659] (WW) NVIDIA(GPU-0): Pixel Clock : 65.00 MHz
[ 16.659] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[ 16.659] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1344
[ 16.659] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[ 16.659] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 806
[ 16.659] (WW) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.659] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.659] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.659] (WW) NVIDIA(GPU-0): Mode “1024x768_60” is invalid.
[ 16.659] (WW) NVIDIA(GPU-0): Validating Mode “512x384d60”:
[ 16.659] (WW) NVIDIA(GPU-0): 512 x 384 @ 60 Hz
[ 16.659] (WW) NVIDIA(GPU-0): Pixel Clock : 32.50 MHz
[ 16.659] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 512, 524
[ 16.659] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 592, 672
[ 16.659] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 384, 385
[ 16.659] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 388, 403
[ 16.659] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.659] (WW) NVIDIA(GPU-0): Mode “512x384d60” is invalid.
[ 16.659] (WW) NVIDIA(GPU-0): Validating Mode “1024x768_70”:
[ 16.659] (WW) NVIDIA(GPU-0): 1024 x 768 @ 70 Hz
[ 16.659] (WW) NVIDIA(GPU-0): Pixel Clock : 75.00 MHz
[ 16.659] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1328
[ 16.660] (WW) NVIDIA(GPU-0): Mode “1024x768_70” is invalid.
[ 16.660] (WW) NVIDIA(GPU-0): Validating Mode “512x384d70”:
[ 16.660] (WW) NVIDIA(GPU-0): Mode Source: X Server
[ 16.660] (WW) NVIDIA(GPU-0): 512 x 384 @ 70 Hz
[ 16.660] (WW) NVIDIA(GPU-0): Pixel Clock : 37.50 MHz
[ 16.660] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 512, 524
[ 16.660] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 592, 664
[ 16.660] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 384, 385
[ 16.660] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 388, 403
[ 16.660] (WW) NVIDIA(GPU-0): H/V Polarity : -/-
[ 16.660] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[ 16.660] (WW) NVIDIA(GPU-0): Mode is rejected: Only modes from the NVIDIA X driver’s
[ 16.660] (WW) NVIDIA(GPU-0): predefined list and modes from the EDID are allowed
[ 16.660] (WW) NVIDIA(GPU-0): Mode “512x384d70” is invalid.
[ 16.660] (WW) NVIDIA(GPU-0): Validating Mode “1024x768_75”:
[ 16.660] (WW) NVIDIA(GPU-0): 1024 x 768 @ 75 Hz
[ 16.660] (WW) NVIDIA(GPU-0): Pixel Clock : 78.75 MHz
[ 16.660] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1040
[ 16.660] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1136, 1312
[ 16.660] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 768, 769
[ 16.660] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 772, 800
[ 16.660] (WW) NVIDIA(GPU-0): H/V Polarity : +/+
[ 16.660] (WW) NVIDIA(GPU-0): Mode “1024x768_75” is invalid.
