Graphic issue with GTX970M and all Nvidia drivers
Hi guys,
Since i bought my laptop, a MSI GT72-2QD Dominator, i have a big problem when i launch Linux with Nvidia driver. I’m French so i don’t know how to explain correctly in English the issue so i took a video with my mobile. My issue on Youtube :
I tried differents drivers versions and only one driver works without this problem (Nvidia driver bêta 346.22 and 346.16). Others driver like 343.36, 346.35, 346.47, 346.53 and 349.12 have this issue.
I don’t know where come from the problem and how resolv it. To help you, i post the both “nvidia-bug-reports” from 346.22 (driver version which works) and 349.12 (latest version which does not work).
Thanks,
Maxime
nvidia-bug-report.346.22.log.gz (82.2 KB)
nvidia-bug-report.349.12.log.gz (81.8 KB)
I add that the Nvidia 346.22 is the only one which find a freshrate to 75Hz for my Screen. Others drivers which don’t work find only 60Hz … Same thing for xrandr command.
I forgot to mention that if i use a HDMI cable to use my screen TV instead of the screen’s laptop, this problem disappear.
I discuss with Arthur Huillet from Nvidia and for him and my tests, it’s probably a problem when DisplayPort.
There is a workaround to fix this issue while waiting for a new driver ?
I, and a few others, have reported similar issues on the msi forums:
I have exactly the same problem with my msi gt72 2qd notebook. Running Windows 8.1 all is fine.
But when i use my Linux OS the screen shivers as seen in the video above(linked by OdelPasso).
I tried all of the newest drivers which support the gforce gtx 970m graphic card. All drivers showed the same shivering screen.
I already contacted the Nvidia support and explained my problem.
I hope there will be soon a driver which solves this problem.
io
nvidia-bug-report.log.gz (85.7 KB)
I’m also having the exact same problem, I have a Gigabyte P37x with a 980m and intel 4600HD.
I also hope there’s some fix for this.
Just wanted to say that I installed ubuntu 15 and it’s working properly. I even installed the restricted drivers and they’re good.
What is your kernel version? Nvidia driver version? Modeline for the laptop display (output of xrandr)?
I have the same problem.
Hardware: MSI GT72-2QD Dominator with GTX970m
Operating System: Ubuntu 15.04
I tried so far:
  • 346.59
  • 349.16
Furthermore I tried to install 346.22 as the thread-author mentioned using the .run-file from the nvidia website. But I had no luck with that one on Ubuntu 15.04.
Here are the modlines of the currently running Gallium 0.4 on llvmpipe (LLVM 3.6, 256 bits) driver:
[     4.323] (II) modeset(0): Printing probed modes for output eDP-0
[     4.323] (II) modeset(0): Modeline "1920x1080"x60.0  138.00  1920 1968 2000 2070  1080 1083 1088 1111 +hsync -vsync (66.7 kHz eP)
[     4.323] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz e)
[     4.323] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[     4.323] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     4.323] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[     4.323] (II) modeset(0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[     4.323] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[     4.323] (II) modeset(0): Modeline "1400x1050"x60.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[     4.323] (II) modeset(0): Modeline "1280x1024"x59.9  109.00  1280 1368 1496 1712  1024 1027 1034 1063 -hsync +vsync (63.7 kHz e)
[     4.323] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[     4.323] (II) modeset(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[     4.323] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[     4.323] (II) modeset(0): Modeline "1280x960"x59.9  101.25  1280 1360 1488 1696  960 963 967 996 -hsync +vsync (59.7 kHz e)
[     4.323] (II) modeset(0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[     4.323] (II) modeset(0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[     4.323] (II) modeset(0): Modeline "1152x864"x60.0   81.75  1152 1216 1336 1520  864 867 871 897 -hsync +vsync (53.8 kHz e)
[     4.323] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[     4.323] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[     4.323] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[     4.323] (II) modeset(0): Modeline "1024x768"x59.9   63.50  1024 1072 1176 1328  768 771 775 798 -hsync +vsync (47.8 kHz e)
[     4.323] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[     4.323] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[     4.323] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[     4.323] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[     4.323] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[     4.323] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[     4.323] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[     4.323] (II) modeset(0): Modeline "800x600"x59.9   38.25  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz e)
[     4.323] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[     4.323] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[     4.323] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[     4.323] (II) modeset(0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[     4.323] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[     4.323] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[     4.323] (II) modeset(0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[     4.323] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[     4.323] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[     4.323] (II) modeset(0): Modeline "640x480"x59.4   23.75  640 664 720 800  480 483 487 500 -hsync +vsync (29.7 kHz e)
[     4.323] (II) modeset(0): Modeline "720x400"x59.6   22.25  720 744 808 896  400 403 413 417 -hsync +vsync (24.8 kHz e)
[     4.323] (II) modeset(0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[     4.323] (II) modeset(0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[     4.323] (II) modeset(0): Modeline "640x400"x60.0   20.00  640 664 720 800  400 403 409 417 -hsync +vsync (25.0 kHz e)
[     4.323] (II) modeset(0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[     4.323] (II) modeset(0): Modeline "640x350"x59.8   17.50  640 664 720 800  350 353 363 366 -hsync +vsync (21.9 kHz e)
[     4.323] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[     4.323] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[     4.323] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[     4.323] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
If you need any information just let me know.
Quite odd bug I had to say. First things first, does adding
Option “ModeValidation” “DP-0:AllowNonEdidModes”
to your /etc/X11/xorg.conf file give you more usable modelines?
Edid that drivers reads from the monitor differs a bit between the two:
346.22
$ parse-edid edid346.bin
parse-edid: parse-edid version 2.0.0
parse-edid: EDID checksum passed.
        # EDID version 1 revision 4
Section "Monitor"
        # Block type: 2:0 3:0
        # Block type: 2:0 3:fe
        Identifier "LGD:6904"
        VendorName "LGD"
        ModelName "LGD:6904"
        # DPMS capabilities: Active off:no  Suspend:no  Standby:no
        Mode    "1920x1080"     # vfreq 75.002Hz, hfreq 83.327kHz
                DotClock        173.320000
                HTimings        1920 1968 2000 2080
                VTimings        1080 1083 1088 1111
                Flags   "-HSync" "+VSync"
        EndMode
EndSection
$ edid-decode edid346.bin
Extracted contents:
header:          00 ff ff ff ff ff ff 00
serial number:   30 e4 69 04 00 00 00 00 00 18
version:         01 04
basic params:    95 26 15 78 0a
chroma info:     0b b5 a3 59 55 a0 27 0c 50 54
established:     00 00 00
standard:        01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01
descriptor 1:    b4 43 80 a0 70 38 1f 40 30 20 35 00 7e d7 10 00 00 1a
descriptor 2:    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
descriptor 3:    00 00 00 fe 00 4c 47 20 44 69 73 70 6c 61 79 0a 20 20
descriptor 4:    00 00 00 fe 00 4c 50 31 37 33 57 46 34 2d 53 50 46 31
extensions:      00
checksum:        3e
Manufacturer: LGD Model 469 Serial Number 0
Made week 0 of 2014
EDID version: 1.4
Digital display
6 bits per primary color channel
DisplayPort interface
Maximum image size: 38 cm x 21 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4, YCrCb 4:2:2
First detailed timing is preferred timing
Established timings supported:
Standard timings supported:
Detailed mode: Clock 173.320 MHz, 382 mm x 215 mm
               1920 1968 2000 2080 hborder 0
               1080 1083 1088 1111 vborder 0
               +hsync -vsync
Manufacturer-specified data, tag 0
ASCII string: LG Display
  ASCII string: LP173WF4-SPF1Checksum: 0x3e
EDID block does NOT conform to EDID 1.3!
        Missing name descriptor
        Missing monitor ranges
349.12
$ parse-edid edid349.bin
Section "Monitor"
        VendorName "LGD"
        Mode    "1920x1080"     # vfreq 60.006Hz, hfreq 66.667kHz
                DotClock        138.000000
                HTimings        1920 1968 2000 2070
        EndMode
EndSection
$ edid-decode edid349.bin
Extracted contents:
version:         01 04
descriptor 1:    e8 35 80 96 70 38 1f 40 30 20 35 00 7e d7 10 00 00 1a
extensions:      00
checksum:        22
Made week 0 of 2014
EDID version: 1.4
Digital display
Gamma: 2.20
Detailed mode: Clock 138.000 MHz, 382 mm x 215 mm
               1920 1968 2000 2070 hborder 0
               +hsync -vsync
  ASCII string: LP173WF4-SPF1Checksum: 0x22
For short term solution, one could use that modeline or use custom edid constructed from 346.22 edid.
This seems to work, although I had to use the new pixel clock of 138.
For me these changes do not change a thing. My screen still flickers. In nvidia-settings i do not have more options or modes when i add Option “ModeValidation” “DP-0:AllowNonEdidModes” to my xorg.conf.
With ubuntu 15.04 and the default nouveau-driver i reached a reslolution of 1280x1080 without flickering screen but for some reasons i need the working nvidia-driver.
my section “monitor” looks like this now:
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “LGD”
HorizSync 66.0 - 66.0
VertRefresh 60.0
ModeLine “1920x1080” 173.320000 1920 1968 2000 2080 1080 1083 1088 1111 -hsync +vsync
Option “DPMS”
EndSection
But my problem still exists.
Hi guys,
Sorry for the delay. I contacted the “Linux bugs” support from Nvidia and after to find a solution, Arthur Huillet (from Nvidia) explained me that the Linux Nvidia driver does not find the correct EDID for the screen’s laptop.
This is the workaround that i found to fix the problem :
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
#    HorizSync       28.0 - 33.0
#    VertRefresh     43.0 - 72.0
    Modeline "1920x1080_60.00" 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -HSync +Vsync
    Modeline "1920x1080_75.00" 220.64 1920 2056 2264 2608 1080 1081 1084 1128 -HSync +Vsync
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BusID "PCI:1:0:0"
    Option "IgnoreEdidChecksum" "DFP-1"
    Option "ModeValidation" "AllowNonEdidModes, NoHorizSyncCheck, NoVertRefreshCheck, NoMaxPClkCheck, NoEdidMaxPClkCheck, NoVesaModes, NoXServerModes, NoEdidModes"
    Option "MetaModes" "DFP-1: 1920x1080_75"
EndSection
Io, can you try my Xorg.conf’s options ?
Thanks,
Max
Yes! That workaround from OdelPasso works for me. Nice, thank you OdelPasso.
Anyway, i hope there will be a driver soon which recognizes the monitor correct.
Thanks guys!
Wow guys you are so great! You did it!
Here is my full xorg.conf (in case someone needs it):
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BusID "PCI:1:0:0"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-1"
    Option         "metamodes" "nvidia-auto-select +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Note: I’m using the 346.59 driver.
And yes I hope that future driver versions won’t need this hack anymore too.
I must add something, i dont have Linux(I have Windows 8.1), although i recently got a MSI GE72 2QF and it seems to want to run on my dedicated graphics instead of the graphics card 970m, and when i deactivate the integrated graphics driver it runs other games not even with 10 fps. And it doesnt run CS GO at all (Which i play the most).
So, it seems like its not only Linux users who has problems with this patch or laptop, or whatever…
Yes, i´ve tried reinstalling drivers etc.
Think you have better luck in the GeForce forums since this is Linux part of the woods also since you dont have the same issue a new thread would be appropriate.
