Currently I am dual booting Debian 11 (with GNOME) and Windows 11 on my 2018 Razer Blade 15 Advanced, which has a discrete GPU (NVIDIA 1060M) running the newest Linux NVIDIA drivers (v515.48.07). I am trying to set up 2 external monitors in addition to the built-in laptop display. One of my displays is a Samsung LC27T55 which is hooked up with a native HDMI connection. The other display is a Achieva Shimian QH270 which natively only supports Dual Link DVI-D, but since my laptop doesn’t have a DVI connector I purchased this Apple Dual Link DVI to Mini Display port adapter. Now since my built in display seems to be only connected to the built in Intel graphics I had to offload the graphics processing of it to my GPU using this tutorial: Chapter 32. Offloading Graphics Display with RandR 1.4 of the NVIDIA Accelerated Linux Graphics Driver README and Installation Guide. The only difference from this tutorial I employed was putting:
$ xrandr --setprovideroutputsource modesetting NVIDIA-0
$ xrandr --auto
in ~/.xsessionrc as opposed to ~/.xinitrc since this is the only way I could get it to work.
However I run into two main issues:
- When I start up my laptop, my login screen only appears on my Samsung LC27T55 (and black on my built in display). Even if I disconnect all my external monitors, my built in display remains black on start up. I can still login by just pressing enter and putting in my password even though the screen is black, after which everything works perfectly, but this is still very undesirable.
- My Achieva Shimian QH270 has absolutely no output. It is detected by the system, but it will only “output” a resolution of 640x480. I say “output” because in reality the monitor is just black.
With regard to the first issue, I have tried adding the two xrandr lines above as a startup script (since I thought that maybe they were only being executed after login) but I don’t believe its the order of events that is the issue because once I login and everything is working, and then I logout, the issue persists. I have tried disabling Wayland and moving the ~/.config/monitors.xml to /var/lib/gdm3/.config/ (transferring my user display information to GNOME) but to no avail.
For the second issue I haven’t done much other than trying to add xrandr modes and set them, as well as applying a custom EDID which I found on a GitHub page (which seemed to be a bust because when I decoded the binary there was nothing of substance) and just resulted in my computer completely black-screening. I know with certainty that the monitor and adapter work because I have tried it on the Windows 11 partition and it worked with no hesitation.
I have included the log file created by nvidia-bug-report.sh as well as some standard outputs which may be useful. Any help would be awesome!!!
nvidia-smi:
| NVIDIA-SMI 515.48.07 Driver Version: 515.48.07 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 62C P5 10W / N/A | 414MiB / 6144MiB | 25% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 5373 G /usr/lib/xorg/Xorg 216MiB |
| 0 N/A N/A 5488 G /usr/bin/gnome-shell 67MiB |
| 0 N/A N/A 8469 G ...717975381964499814,131072 104MiB |
| 0 N/A N/A 10525 G /usr/bin/nvidia-settings 0MiB |
| 0 N/A N/A 12097 G gnome-control-center 21MiB |
xrandr --listproviders:
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 3 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x1ff cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 3 associated providers: 1 name:modesetting
xrandr --listmonitors:
Monitors: 3
0: +*eDP-1-1 1920/344x1080/194+0+0 eDP-1-1 // Built-in display
1: +HDMI-0 1920/522x1080/272+1920+0 HDMI-0 // Samsung LC27T55
2: +DP-0 640/169x480/127+3840+208 DP-0 // Achieva Shimian QH270
xrandr:
Screen 0: minimum 8 x 8, current 4480 x 1080, maximum 32767 x 32767
HDMI-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 522mm x 272mm
1920x1080 60.00 + 74.97* 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0 connected 640x480+3840+208 (normal left inverted right x axis y axis) 0mm x 0mm
640x480 59.94*+
DP-1 disconnected (normal left inverted right x axis y axis)
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+ 60.01 59.97 59.96 60.00 59.93
1680x1050 84.94 74.89 69.88 59.95 59.88
1600x1024 60.17
1400x1050 85.00 74.76 70.00 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 100.00 85.06 85.00 75.00 75.00 70.00 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 85.02 74.96 69.88 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 85.08 74.76 70.06 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
720x450 59.89
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98 85.08
576x432 100.11 85.15 85.09 75.00 75.00 70.00 60.06
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
1680x1050 (0x1c2) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x1c5) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c6) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x1c4) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x800 (0x1c7) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1152x864 (0x1cb) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1cc) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1cd) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1ce) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d0) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1cf) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1d1) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1d2) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x1d5) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d7) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
sudo lshw -C display:
*-display
description: VGA compatible controller
product: GP106M [GeForce GTX 1060 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:149 memory:ac000000-acffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:3000(size=128) memory:ad000000-ad07ffff
*-display
product: CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:140 memory:ab000000-abffffff memory:40000000-4fffffff ioport:4000(size=64) memory:c0000-dffff
cat /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
nvidia-bug-report.log.gz (649.0 KB)
