Objective: Utilize 2 external monitors with this laptop
Problem: Cannot display on any external monitors, though when this computer is in Windows 10 mode (dual booted), there is no issue.
Dell Latitude G5 5590
CPU: Intel i7-9750H @ 2.6MHz (turboboost disabled)
Two GPUS:
- Intel 630 (CFL GT2)
- TU106M [GeForce RTX 2060 Mobile]
Ubuntu Studio 20.05
Kernel: 5.4.0-66-lowlatency
Previous threads examined, similar but not resolving the issue;
nvidia-smi shows;
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce RTX 2060 On | 00000000:01:00.0 Off | N/A |
| N/A 56C P8 7W / N/A | 1MiB / 5934MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
sudo lshw -c video shows:
*-display
description: VGA compatible controller
product: TU106M [GeForce RTX 2060 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:169 memory:ec000000-ecffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:4000(size=128) memory:ed000000-ed07ffff
*-display
product: UHD Graphics 630 (Mobile)
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:167 memory:eb000000-ebffffff memory:80000000-8fffffff ioport:5000(size=64) memory:c0000-dffff
inxi -G shows the driver has been loaded (though the version may be too recent?);
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] driver: nvidia v: 460.32.03
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa tty: N/A
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.6
nvidia-settings only show the following;
ERROR: Unable to load info from any available system
(nvidia-settings:62511): GLib-GObject-CRITICAL **: 09:00:50.606: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 09:00:50.609: PRIME: Requires offloading
** Message: 09:00:50.609: PRIME: is it supported? yes
** Message: 09:00:50.649: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 09:00:50.649: PRIME: on-demand mode: "1"
** Message: 09:00:50.649: PRIME: is "on-demand" mode supported? yes
Secure boot is disabled: mokutil --sb-state
SecureBoot disabled
Platform is in Setup Mode
Output of dpkg -l | grep nvidia :
ii libnvidia-cfg1-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-460 460.32.03-0ubuntu1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-450:amd64 450.51.05-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA libcompute package
rc libnvidia-compute-460-server:amd64 460.32.03-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-460:amd64 460.32.03-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-460:amd64 460.32.03-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-460:amd64 460.32.03-0ubuntu1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ml-dev 10.1.243-3 amd64 NVIDIA Management Library (NVML) development files
rc nvidia-compute-utils-450 450.51.05-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-460 460.32.03-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-cuda-dev 10.1.243-3 amd64 NVIDIA CUDA development files
ii nvidia-cuda-doc 10.1.243-3 all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb 10.1.243-3 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 10.1.243-3 amd64 NVIDIA CUDA development toolkit
rc nvidia-dkms-450 450.51.05-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-dkms-460 460.32.03-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-driver-460 460.32.03-0ubuntu1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-450 450.51.05-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-460 460.32.03-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-460 460.32.03-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-opencl-dev:amd64 10.1.243-3 amd64 NVIDIA OpenCL development files
ii nvidia-prime 0.8.15.3~0.20.04.1 all Tools to enable NVIDIA's Prime
ii nvidia-profiler 10.1.243-3 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings 460.32.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-460 460.32.03-0ubuntu1 amd64 NVIDIA driver support binaries
ii nvidia-visual-profiler 10.1.243-3 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-460 460.32.03-0ubuntu1 amd64 NVIDIA binary Xorg driver
There is no output from lsmod | grep nvidia
/etc/X11/xorg.conf contains;
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 460.32.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Output from sudo nvidia-bug-report.sh is attached;
nvidia-bug-report.log.gz (10.7 MB)
xrandr --listproviders shows;
Providers: number : 1
Provider 0: id: 0x47 cap: 0x9, Source Output, Sink Offload crtcs: 3 outputs: 5 associated providers: 0 name:modesetting
I had upgraded the NVIDIA drivers to 460, though that didn’t work, and for some reason I’m having difficulty reverting the version to something earlier, such as 450
Am I missing anything obvious?
