I’m the owner of a new Asus TUF Gaming A15 FA506IV laptop, and I’m facing some issues.
I’m using Ubuntu 20.04 with 5.5 kernel:
5.5.0-050500-generic
nvidia-smi shows:
| NVIDIA-SMI 440.64 Driver Version: 440.64 CUDA Version: 10.2 |
| 0 GeForce GTX 166... Off | 00000000:01:00.0 Off | N/A |
| N/A 45C P8 1W / N/A | 0MiB / 5944MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
lshw -c video also shows that the display is allocated:
*-display
description: VGA compatible controller
product: TU116M [GeForce GTX 1660 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:75 memory:fb000000-fbffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:f000(size=128) memory:fc000000-fc07ffff
*-display
product: Renoir
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:05:00.0
version: c6
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: driver=amdgpu latency=0
resources: irq:42 memory:d0000000-dfffffff memory:e0000000-e01fffff ioport:c000(size=256) memory:fc500000-fc57ffff
inxi -G also indicates that the driver has been properly loaded, as it’s showing the version (440.64):
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: nvidia v: 440.64
Device-2: AMD Renoir driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.8 driver: ati,fbdev
unloaded: modesetting,nouveau,nvidia,radeon,vesa
resolution: 1920x1080~144Hz, 2560x1440~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.36.0 5.5.0-050500-generic LLVM 9.0.1)
v: 4.6 Mesa 20.0.4
But then nvidia-settings fails:
ERROR: Unable to load info from any available system
Secure boot is disabled (mokutil --sb-state):
SecureBoot disabled
Platform is in Setup Mode
I’ve also tried to set the nvidia-drm.modeset=1 to GRUB_CMDLINE_LINUX_DEFAULT option in the grub config.
Output of dpkg -l | grep nvidia:
ii libnvidia-cfg1-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-440 440.82+really.440.64-0ubuntu6 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA libcompute package
ii libnvidia-compute-440:i386 440.82+really.440.64-0ubuntu6 i386 NVIDIA libcompute package
ii libnvidia-decode-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-440:i386 440.82+really.440.64-0ubuntu6 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-440:i386 440.82+really.440.64-0ubuntu6 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-440:amd64 440.82+really.440.64-0ubuntu6 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-440:i386 440.82+really.440.64-0ubuntu6 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-440:i386 440.82+really.440.64-0ubuntu6 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-440:amd64 440.82+really.440.64-0ubuntu6 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-440:i386 440.82+really.440.64-0ubuntu6 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA compute utilities
ii nvidia-dkms-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA DKMS package
ii nvidia-driver-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-440 440.82+really.440.64-0ubuntu6 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.14 all Tools to enable NVIDIA's Prime
ii nvidia-settings 440.64-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-440 440.82+really.440.64-0ubuntu6 amd64 NVIDIA binary Xorg driver
lsmod | grep nvidia:
nvidia_uvm 970752 0
nvidia_drm 45056 0
nvidia_modeset 1114112 1 nvidia_drm
nvidia 20434944 9 nvidia_uvm,nvidia_modeset
drm_kms_helper 200704 2 amdgpu,nvidia_drm
ipmi_msghandler 110592 2 ipmi_devintf,nvidia
drm 528384 13 gpu_sched,drm_kms_helper,amdgpu,nvidia_drm,ttm
i2c_nvidia_gpu 16384 0
Finally, I leave the output of nvidia-bug-report.sh:
nvidia-bug-report.log (1.5 MB)
