Trying to get Quadro RTX 4000 to work. Drivers installed but won’t load.
I installed Windows 10 on a separate partition. It finds and installs NVIDIA drivers. The problem is not faulty hardware.
Topics read:
nvidia-bug-report.log (140.6 KB)
Program outputs:
nvidia-detector:
nvidia-driver-440
nvidia-settings:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
inxi -G:
Graphics: Device-1: NVIDIA TU104GL [Quadro RTX 4000] driver: N/A
Display: x11 server: X.Org 1.20.8 driver: fbdev,nouveau unloaded: modesetting,vesa resolution: 1920x1080~77Hz
OpenGL: renderer: llvmpipe (LLVM 9.0.1 256 bits) v: 3.3 Mesa 20.0.4
mokutil --sb-state:
SecureBoot disabled
lsmod | grep nvidia:
i2c_nvidia_gpu 16384 0
lshw -c video:
*-display UNCLAIMED
description: VGA compatible controller
product: TU104GL [Quadro RTX 4000]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:18:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:5000(size=128) memory:b4000000-b407ffff
nvidia-smi:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
more /usr/share/X11/xorg.conf.d/10-amdgpu.conf:
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “modesetting”
Option “PrimaryGPU” “Yes”
EndSection
ls /lib/modprobe.d/blacklist-nvidia.conf:
ls: cannot access ‘/lib/modprobe.d/blacklist-nvidia.conf’: No such file or directory
dpkg -l | grep nvidia:
ii libnvidia-cfg1-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-440 440.82-0ubuntu0~0.19.10.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-418:amd64 430.50-0ubuntu2 amd64 Transitional package for libnvidia-compute-430
rc libnvidia-compute-430:amd64 430.64-0ubuntu0~gpu19.10.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-435:amd64 435.21-0ubuntu2 amd64 NVIDIA libcompute package
ii libnvidia-compute-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVIDIA libcompute package
ii libnvidia-decode-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-440:amd64 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-440:i386 440.82-0ubuntu0~0.19.10.1 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
rc nvidia-compute-utils-430 430.64-0ubuntu0~gpu19.10.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-435 435.21-0ubuntu2 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA compute utilities
rc nvidia-cuda-toolkit 10.1.168-1build1 amd64 NVIDIA CUDA development toolkit
rc nvidia-dkms-430 430.64-0ubuntu0~gpu19.10.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-435 435.21-0ubuntu2 amd64 NVIDIA DKMS package
ii nvidia-dkms-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA DKMS package
ii nvidia-driver-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-430 430.64-0ubuntu0~gpu19.10.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-435 435.21-0ubuntu2 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-440 440.82-0ubuntu0~0.19.10.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.14 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 440.64-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-440 440.82-0ubuntu0~0.19.10.1 amd64 NVIDIA binary Xorg driver
