Hello, I am trying to work out how to set up this machine and get nvidia-settings to work, I get the following error
# nvidia-settings -query all
ERROR: Unable to load info from any available system
I’m not sure what is wrong with my setup, I have attached a bug report below. Thanks!!
nvidia-smi output:
Fri Sep 18 08:26:09 2020
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| 0 P106-100 Off | 00000000:01:00.0 Off | N/A |
| 52% 53C P0 104W / 120W | 4017MiB / 6080MiB | 100% Default |
| 1 P106-100 Off | 00000000:02:00.0 Off | N/A |
| 49% 51C P0 102W / 120W | 4011MiB / 6080MiB | 100% Default |
| 2 P106-100 Off | 00000000:03:00.0 Off | N/A |
| 51% 53C P0 104W / 120W | 4011MiB / 6080MiB | 100% Default |
| 3 P106-100 Off | 00000000:04:00.0 Off | N/A |
| 50% 51C P0 105W / 120W | 4011MiB / 6080MiB | 100% Default |
| 4 P106-100 Off | 00000000:05:00.0 Off | N/A |
| 51% 53C P0 103W / 120W | 4011MiB / 6080MiB | 100% Default |
| 5 P106-100 Off | 00000000:06:00.0 Off | N/A |
| 52% 53C P0 102W / 120W | 4011MiB / 6080MiB | 100% Default |
| 6 P106-100 Off | 00000000:07:00.0 Off | N/A |
| 54% 58C P0 103W / 120W | 4011MiB / 6080MiB | 100% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 22518 G /usr/lib/xorg/Xorg 5MiB |
| 0 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 1 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 2 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 3 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 4 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 5 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
| 6 24302 C ...66a322fda5b9a311003f5ad3f6/PhoenixMiner 4001MiB |
xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 440.82
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "P106-100"
EndSection
Section "Screen"
Option "SecurityTypes" "VncAuth"
Option "PasswordFile" "/root/.vnc/passwd"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "NoPowerConnectorCheck" "True"
Option "ThermalConfigurationCheck" "False"
Option "AllowEmptyInitialConfiguration" "True"
Option "UseDisplayDevice" "none"
Option "Coolbits" "28"
# SubSection "Display"
# Virtual 1664 936
# Depth 24
# EndSubSection
EndSection
nvidia-bug-report.log.gz (1.5 MB)
