Nvidia-settings: ERRORS (no display)
I ssh from one system to other system using ssh -X inside VNC.
When I run nvidia-settings command on the other system, I receive:
$ nvidia-settings
ERROR: Unable to load info from any available system
After setting $DISPLAY variable on the other system, I receive:
$ nvidia-settings
No protocol specified
Failed to connect to Mir: Failed to connect to server socket: No such file or directory
Unable to init server: Could not connect: Connection refused
When I use root privileges on the other system using sudo su, I receive:
# nvidia-settings
** (nvidia-settings:21188): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-VnEbfAnVr6: Connection refused
My aim is to modify GPUPowerMizerMode using nvidia-settings. But I am not able to get nvidia-settings display.
Other details of the system are:
$ uname -a
Linux sys23-MS-7B07 4.15.0-142-generic #146~16.04.1-Ubuntu SMP Tue Apr 13 09:27:15 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
My Nvidia graphic card is GeForce GT 730.
$ lspci | grep VGA
1f:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 730] (rev a1)
Nvidia-driver version is 470.103.01.
$ nvidia-smi
Thu Feb 17 21:20:35 2022
| NVIDIA-SMI 470.103.01   Driver Version: 470.103.01   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:1F:00.0 N/A |                  N/A |
| 30%   38C    P0    N/A /  N/A |      0MiB /  2000MiB |     N/A      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
How can I fix it? Is there any other method to set GPUPowerMizerMode?
Please help.
Thank you,
Anega
Please see this thread:
https://forums.developer.nvidia.com/t/nvidia-settings-unable-to-load-info-from-any-available-system/120192
you need to set both DISPLAY and XAUTHORITY to the correct values.
I am still getting error while trying to retrieve nvidia-settings display.
root@sys23-MS-7B07:~# DISPLAY=192.168.10.7:55 XAUTHORITY=/run/user/1032/gdm/Xauthority nvidia-settings
** (nvidia-settings:16316): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-drLUGjLBp4: Connection refused
where 192.168.10.7 is the IP of the machine I am using to access the other system and VNC running with display number-55.
Since the memory usage of the GT730 is 0MB, I guess you’re not even running an Xserver on it.
