Nvidia GPU functioning but not used by OpenGL
I have purchased a server with RTX 6000 and installed Nvidia Driver. I am using SSH to the server and using GUI apps via X11, everything works properly. However, the command “nvidia-settings” shows " ERROR: Unable to load info from any available system". And the OpenGL seems still using the Intel one. I though it was bacuase the GPU was not set as primary one, after reading many posts on the internet, I made changes under /etc/X11/xorg.conf.d
ls
10-nvidia-prime.conf  nvidia.conf  nvidia-drm-outputclass.conf
These files are set to content :
# This xorg.conf.d configuration snippet configures the X server to
# automatically load the nvidia X driver when it detects a device driven by the
# nvidia-drm.ko kernel module.  Please note that this only works on Linux kernels
# version 3.9 or higher with CONFIG_DRM enabled, and only if the nvidia-drm.ko
# kernel module is loaded before the X server is started.
Section "OutputClass"
    Identifier     "nvidia"
    MatchDriver    "nvidia-drm"
    Driver         "nvidia"
    Option         "PrimaryGPU" "yes"
EndSection
This did not work, after reboot, the OpenGL still not showing Nvidia
[root@server ~]# glxinfo|grep OpenGL
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 1.4 (2.1 Mesa 10.5.4)
OpenGL extensions:
[root@server ~]# nvidia-smi
| NVIDIA-SMI 465.31       Driver Version: 465.31       CUDA Version: 11.3     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA Quadro R...  Off  | 00000000:3B:00.0 Off |                    0 |
| N/A   36C    P0    56W / 250W |      0MiB / 22698MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
The xorg.conf as bollow:
[root@server]# cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 465.31
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
[root@server ~]# lshw -c display
  *-display
       description: VGA compatible controller
       product: Integrated Matrox G200eW3 Graphics Controller
       vendor: Matrox Electronics Systems Ltd.
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 04
       width: 32 bits
       clock: 66MHz
       capabilities: pm vga_controller bus_master cap_list rom
       configuration: driver=mgag200 latency=64 maxlatency=32 mingnt=16
       resources: irq:16 memory:91000000-91ffffff memory:92808000-9280bfff memory:92000000-927fffff
       description: 3D controller
       product: TU102GL [Quadro RTX 6000/8000]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:3b:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=nvidia latency=0
       resources: iomemory:38b00-38aff iomemory:38b80-38b7f irq:77 memory:ab000000-abffffff memory:38b000000000-38b7ffffffff memory:38b800000000-38b801ffffff
Bug report is attached:
nvidia-bug-report.log.gz (1.3 MB)
I hope someone can have a look at this and help me. Much appreciated!!!
Maybe this helps:
Or this:
