Good afternoon,
Fresh CentOS 7 server. Installed nvidia drivers (yes for compatibility libraries as well) and able to log into the system. OpenGL still apears to be using the integrated graphics and nvidia-setting does not open to allow me to troubleshoot further.
nvidia-smi leads me to believe the drivers are loaded/working although it seems part of the system is using integrated while nvidia is being used just for 3d rendering.
I would be fine getting it to work entirely with just the nvidia card if possible but the OpenGL is my main concern. Not understanding why nvidia-setting is failing to open unless its a result of the integrated graphics controlling the display? If so how do I change this to allow nvidia to control everything to include the opengl component?
So far I have completely reinstalled the nvidia drivers and reviewed logs/forums extensively trying to see someone similar with this issue.
General info below
# nvidia-smi
Wed Jan 27 16:08:26 2021
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Quadro P1000 Off | 00000000:01:00.0 Off | N/A |
| N/A 37C P8 N/A / N/A | 0MiB / 4042MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
# nvidia-settings
ERROR: Unable to load info from any available system
# lshw -class display
*-display
description: 3D controller
product: GP107GLM [Quadro P1000 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:515 memory:ec000000-ecffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:3000(size=128) memory:ed000000-ed07ffff
*-display
description: VGA compatible controller
product: UHD Graphics 630 (Mobile)
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:148 memory:eb000000-ebffffff memory:80000000-8fffffff ioport:4000(size=64)
# glxinfo | grep -i opengl
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 6.0, 256 bits)
OpenGL version string: 2.1 Mesa 18.0.5
OpenGL shading language version string: 1.30
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 18.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
