It is not possible to launch the settings application because of this error.
~ $ nvidia-settings
ERROR: Unable to load info from any available system
Also, the device appears to be Off when executing this command
~ $ nvidia-smi
Wed Jan 29 23:15:36 2020
| NVIDIA-SMI 440.44 Driver Version: 440.44 CUDA Version: 10.2 |
| 0 GeForce GTX 960M Off | 00000000:01:00.0 Off | N/A |
| N/A 56C P0 N/A / N/A | 0MiB / 4043MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
I have fully upgraded all packages as you can see here:
pacman -Qs libgl
local/lib32-libglvnd 1.3.0-2
The GL Vendor-Neutral Dispatch library
local/lib32-mesa 19.3.2-1
An open-source implementation of the OpenGL specification (32-bit)
local/lib32-nvidia-utils 440.44-1
NVIDIA drivers utilities (32-bit)
local/libglade 2.6.4-6
Allows you to load glade interface files in a program at runtime
local/libglvnd 1.3.0-2
local/mesa 19.3.2-2
local/nvidia-utils 440.44-3
~ $ pacman -Qs nvidia
local/libvdpau 1.3-1
Nvidia VDPAU library
local/libxnvctrl 440.44-1
NVIDIA NV-CONTROL X extension
local/nvidia 440.44-15
NVIDIA drivers for linux
local/nvidia-settings 440.44-1
Tool for configuring the NVIDIA graphics driver
Please advise. Here is some more info on my system:
~ $ uname -a
Linux NICO 5.4.15-arch1-1 #1 SMP PREEMPT Sun, 26 Jan 2020 09:48:50 +0000 x86_64 GNU/Linux
~ $ lspci -k | grep -A 2 -E "(VGA|3D)"
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
DeviceName: Intel Skylake HD Graphics ULT GT2
Subsystem: Hewlett-Packard Company HD Graphics 530
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev a2)
DeviceName: NVIDIA N16P-GX
Subsystem: Hewlett-Packard Company GM107M [GeForce GTX 960M]
I will also include the tar file with logs
Thanks in advance.
nvidia-bug-report.log.gz (295 KB)
