[Nvidia 319] Conflict with RAM - Failed to initialize DMA (Ubuntu 13.10)
I’ve what I believe is a system conflict with my RAM (3GB in total: 512+512MB in bank 0 slot 1&2 + 1+1GB in bank 1 slot 3&4 - dual channel ddr 400) and my GT220 card.
  1. The 3GB is ok by itself, memtest run fine, I can boot and use VESA driver.
  2. If I install Nvidia driver X fails at boot with error:
[    34.947] (EE) NVIDIA(GPU-0): Failed to initialize DMA.
  1. If I remove 512MB from 1st slot the driver start fine and work as a charm
How can I better debug the issue? I’ve latest BIOS, Xubuntu 13.10 updated with latest 3.11 kernel (same issue with 3.10).
Here’s the logs, both when it fails (with 3GB RAM) and when it works (w/ 2.5GB RAM):
With 3GB RAM (fails with DMA issue)
Xorg Logs:
[    19.294]
X.Org X Server 1.14.3
Release Date: 2013-09-12
[    19.294] X Protocol Version 11, Revision 0
[    19.294] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[    19.294] Current Operating System: Linux drake 3.11.0-13-generic #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 x86_64
[    19.294] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-13-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro quiet splash
[    19.295] Build Date: 15 October 2013  09:23:37AM
[    19.295] xorg-server 2:1.14.3-3ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    19.295] Current version of pixman: 0.30.2
[    19.295] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    19.295] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    19.295] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 10 09:31:31 2013
[    19.307] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.307] (==) No Layout section.  Using the first Screen section.
[    19.307] (==) No screen section available. Using defaults.
[    19.307] (**) |-->Screen "Default Screen Section" (0)
[    19.307] (**) |   |-->Monitor "<default monitor>"
[    19.307] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    19.307] (==) Automatically adding devices
[    19.307] (==) Automatically enabling devices
[    19.307] (==) Automatically adding GPU devices
[    19.307] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    19.307] 	Entry deleted from font path.
[    19.307] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    19.307] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    19.307] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    19.307] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    19.307] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    19.307] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    19.307] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    19.307] (II) Loader magic: 0x7f332ffe6d20
[    19.307] (II) Module ABI versions:
[    19.308] 	X.Org ANSI C Emulation: 0.4
[    19.308] 	X.Org Video Driver: 14.1
[    19.308] 	X.Org XInput driver : 19.1
[    19.308] 	X.Org Server Extension : 7.0
[    19.308] (II) xfree86: Adding drm device (/dev/dri/card0)
[    19.309] (--) PCI:*(0:1:0:0) 10de:0a20:1462:1910 rev 162, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xdc000000/33554432, I/O @ 0x0000cc00/128, BIOS @ 0x????????/524288
[    19.309] (II) Open ACPI successful (/var/run/acpid.socket)
[    19.309] Initializing built-in extension Generic Event Extension
[    19.309] Initializing built-in extension SHAPE
[    19.309] Initializing built-in extension MIT-SHM
[    19.309] Initializing built-in extension XInputExtension
[    19.309] Initializing built-in extension XTEST
[    19.309] Initializing built-in extension BIG-REQUESTS
[    19.309] Initializing built-in extension SYNC
[    19.309] Initializing built-in extension XKEYBOARD
[    19.309] Initializing built-in extension XC-MISC
[    19.309] Initializing built-in extension SECURITY
[    19.309] Initializing built-in extension XINERAMA
[    19.309] Initializing built-in extension XFIXES
[    19.309] Initializing built-in extension RENDER
[    19.309] Initializing built-in extension RANDR
[    19.309] Initializing built-in extension COMPOSITE
[    19.309] Initializing built-in extension DAMAGE
[    19.309] Initializing built-in extension MIT-SCREEN-SAVER
[    19.309] Initializing built-in extension DOUBLE-BUFFER
[    19.309] Initializing built-in extension RECORD
[    19.309] Initializing built-in extension DPMS
[    19.309] Initializing built-in extension X-Resource
[    19.309] Initializing built-in extension XVideo
[    19.309] Initializing built-in extension XVideo-MotionCompensation
[    19.309] Initializing built-in extension SELinux
[    19.309] Initializing built-in extension XFree86-VidModeExtension
[    19.309] Initializing built-in extension XFree86-DGA
[    19.309] Initializing built-in extension XFree86-DRI
[    19.309] Initializing built-in extension DRI2
[    19.309] (II) "glx" will be loaded by default.
[    19.309] (WW) "xmir" is not to be loaded by default. Skipping.
[    19.309] (II) LoadModule: "dri2"
[    19.310] (II) Module "dri2" already built-in
[    19.310] (II) LoadModule: "glamoregl"
[    19.373] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    19.619] (EE) Failed to load /usr/lib/xorg/modules/libglamoregl.so: /usr/lib/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
[    19.619] (II) UnloadModule: "glamoregl"
[    19.619] (II) Unloading glamoregl
[    19.620] (EE) Failed to load module "glamoregl" (loader failed, 7)
[    19.620] (II) LoadModule: "glx"
[    19.620] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    19.849] (II) Module glx: vendor="NVIDIA Corporation"
[    19.849] 	compiled for 4.0.2, module version = 1.0.0
[    19.849] 	Module class: X.Org Server Extension
[    19.849] (II) NVIDIA GLX Module  319.60  Wed Sep 25 14:24:11 PDT 2013
[    19.849] Loading extension GLX
[    19.849] (==) Matched nvidia as autoconfigured driver 0
[    19.849] (==) Matched nouveau as autoconfigured driver 1
[    19.849] (==) Matched nvidia as autoconfigured driver 2
[    19.849] (==) Matched nouveau as autoconfigured driver 3
[    19.849] (==) Matched vesa as autoconfigured driver 4
[    19.849] (==) Matched modesetting as autoconfigured driver 5
[    19.849] (==) Matched fbdev as autoconfigured driver 6
[    19.849] (==) Assigned the driver to the xf86ConfigLayout
[    19.849] (II) LoadModule: "nvidia"
[    19.849] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    19.850] (II) Module nvidia: vendor="NVIDIA Corporation"
[    19.850] 	compiled for 4.0.2, module version = 1.0.0
[    19.850] 	Module class: X.Org Video Driver
[    19.850] (II) LoadModule: "nouveau"
[    19.850] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    19.948] (II) Module nouveau: vendor="X.Org Foundation"
[    19.948] 	compiled for 1.14.2.901, module version = 1.0.9
[    19.948] 	Module class: X.Org Video Driver
[    19.948] 	ABI class: X.Org Video Driver, version 14.1
[    19.948] (II) LoadModule: "vesa"
[    19.948] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    19.948] (II) Module vesa: vendor="X.Org Foundation"
[    19.948] 	compiled for 1.14.1, module version = 2.3.2
[    19.948] (II) LoadModule: "modesetting"
[    19.949] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    19.949] (II) Module modesetting: vendor="X.Org Foundation"
[    19.949] 	compiled for 1.14.1, module version = 0.8.0
[    19.949] 	Module class: X.Org Video Driver
[    19.949] 	ABI class: X.Org Video Driver, version 14.1
[    19.949] (II) LoadModule: "fbdev"
[    19.949] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    19.949] (II) Module fbdev: vendor="X.Org Foundation"
[    19.949] 	compiled for 1.14.1, module version = 0.4.3
[    19.949] (II) NVIDIA dlloader X Driver  319.60  Wed Sep 25 14:04:14 PDT 2013
[    19.949] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    19.949] (II) NOUVEAU driver Date:   Wed Jul 31 10:51:03 2013 +1000
[    19.949] (II) NOUVEAU driver for NVIDIA chipset families :
[    19.949] 	RIVA TNT        (NV04)
[    19.949] 	RIVA TNT2       (NV05)
[    19.949] 	GeForce 256     (NV10)
[    19.949] 	GeForce 2       (NV11, NV15)
[    19.949] 	GeForce 4MX     (NV17, NV18)
[    19.949] 	GeForce 3       (NV20)
[    19.949] 	GeForce 4Ti     (NV25, NV28)
[    19.949] 	GeForce FX      (NV3x)
[    19.949] 	GeForce 6       (NV4x)
[    19.949] 	GeForce 7       (G7x)
[    19.949] 	GeForce 8       (G8x)
[    19.949] 	GeForce GTX 200 (NVA0)
[    19.949] 	GeForce GTX 400 (NVC0)
[    19.949] (II) VESA: driver for VESA chipsets: vesa
[    19.949] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    19.949] (II) FBDEV: driver for framebuffer: fbdev
[    19.949] (++) using VT number 7
[    19.951] (II) Loading sub module "fb"
[    19.951] (II) LoadModule: "fb"
[    19.952] (II) Loading /usr/lib/xorg/modules/libfb.so
[    19.952] (II) Module fb: vendor="X.Org Foundation"
[    19.952] 	compiled for 1.14.3, module version = 1.0.0
[    19.952] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    19.952] (WW) Unresolved symbol: fbGetGCPrivateKey
[    19.952] (II) Loading sub module "wfb"
[    19.952] (II) LoadModule: "wfb"
[    19.952] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    19.952] (II) Module wfb: vendor="X.Org Foundation"
[    19.952] (II) Loading sub module "shadow"
[    19.952] (II) LoadModule: "shadow"
[    19.952] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    19.952] (II) Module shadow: vendor="X.Org Foundation"
[    19.952] 	compiled for 1.14.3, module version = 1.1.0
[    19.952] (II) Loading sub module "ramdac"
[    19.952] (II) LoadModule: "ramdac"
[    19.952] (II) Module "ramdac" already built-in
[    19.953] (WW) Falling back to old probe method for vesa
[    19.953] (WW) Falling back to old probe method for modesetting
[    19.953] (WW) Falling back to old probe method for fbdev
[    19.953] (II) Loading sub module "fbdevhw"
[    19.953] (II) LoadModule: "fbdevhw"
[    19.953] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    19.953] (II) Module fbdevhw: vendor="X.Org Foundation"
[    19.953] 	compiled for 1.14.3, module version = 0.0.2
[    19.953] 	ABI class: X.Org Video Driver, version 14.1
[    19.953] (EE) open /dev/fb0: No such file or directory
[    19.953] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    19.953] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    19.953] (==) NVIDIA(0): RGB weight 888
[    19.953] (==) NVIDIA(0): Default visual is TrueColor
[    19.953] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    19.953] (**) NVIDIA(0): Enabling 2D acceleration
[    28.910] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-1)) does not support NVIDIA
[    28.910] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    28.914] (II) NVIDIA(0): NVIDIA GPU GeForce GT 220 (GT216) at PCI:1:0:0 (GPU-0)
[    28.914] (--) NVIDIA(0): Memory: 1048576 kBytes
[    28.914] (--) NVIDIA(0): VideoBIOS: 70.16.1d.00.03
[    28.914] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    31.916] (--) NVIDIA(0): Valid display device(s) on GeForce GT 220 at PCI:1:0:0
[    31.916] (--) NVIDIA(0):     CRT-0
[    31.916] (--) NVIDIA(0):     Samsung SyncMaster (CRT-1) (boot, connected)
[    31.916] (--) NVIDIA(0):     DFP-0
[    31.916] (--) NVIDIA(0):     DFP-1
[    31.916] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[    31.916] (--) NVIDIA(0): Samsung SyncMaster (CRT-1): 400.0 MHz maximum pixel clock
[    31.916] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[    31.916] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    31.916] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    31.916] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    31.916] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    31.916] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-1) (Using EDID frequencies
[    31.916] (**) NVIDIA(0):     has been enabled on all display devices.)
[    31.920] (==) NVIDIA(0):
[    31.920] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    31.920] (==) NVIDIA(0):     will be used as the requested mode.
[    31.920] (II) NVIDIA(0): Validated MetaModes:
[    31.920] (II) NVIDIA(0):     "CRT-1:nvidia-auto-select{}"
[    31.920] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[    31.944] (--) NVIDIA(0): DPI set to (95, 96); computed from "UseEdidDpi" X config
[    31.944] (--) NVIDIA(0):     option
[    31.944] (II) UnloadModule: "nouveau"
[    31.944] (II) Unloading nouveau
[    31.944] (II) UnloadModule: "vesa"
[    31.944] (II) Unloading vesa
[    31.944] (II) UnloadModule: "modesetting"
[    31.944] (II) Unloading modesetting
[    31.944] (II) UnloadModule: "fbdev"
[    31.944] (II) Unloading fbdev
[    31.944] (II) UnloadSubModule: "fbdevhw"
[    31.944] (II) Unloading fbdevhw
[    31.944] (--) Depth 24 pixmap format is 32 bpp
[    31.945] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[    34.947] (EE)  *** Aborting ***
[    59.082] (EE)
Fatal server error:
[    59.082] (EE) AddScreen/ScreenInit failed for driver 0
[    59.082] (EE)
[    59.082] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    59.082] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    59.082] (EE)
[    59.083] (EE) Server terminated with error (1). Closing log file.
dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.11.0-13-generic (buildd@roseapple) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 (Ubuntu 3.11.0-13.20-generic 3.11.6)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-13-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro quiet splash
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e8000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007ffaffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007ffb0000-0x000000007ffbffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007ffc0000-0x000000007ffeffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007fff0000-0x000000007fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000013fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI:          939S56-M/939S56-M, BIOS P1.40 11/30/2005
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] No AGP bridge found
[    0.000000] e820: last_pfn = 0x140000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask FF00000000 write-back
[    0.000000]   1 base 0100000000 mask FFC0000000 write-back
[    0.000000]   2 base 0080000000 mask FF80000000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] original variable MTRRs
[    0.000000] reg 0, base: 0GB, range: 4GB, type WB
[    0.000000] reg 1, base: 4GB, range: 1GB, type WB
[    0.000000] reg 2, base: 2GB, range: 2GB, type UC
[    0.000000] total RAM covered: 3072M
[    0.000000] Found optimal setting for mtrr clean up
[    0.000000]  gran_size: 64K 	chunk_size: 64K 	num_reg: 2  	lose cover RAM: 0G
[    0.000000] New variable MTRRs
[    0.000000] reg 0, base: 0GB, range: 2GB, type WB
[    0.000000] e820: update [mem 0x80000000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0x7ffb0 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] BRK [0x01fd1000, 0x01fd1fff] PGTABLE
[    0.000000] BRK [0x01fd2000, 0x01fd2fff] PGTABLE
[    0.000000] BRK [0x01fd3000, 0x01fd3fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x13fe00000-0x13fffffff]
[    0.000000]  [mem 0x13fe00000-0x13fffffff] page 2M
[    0.000000] BRK [0x01fd4000, 0x01fd4fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x13c000000-0x13fdfffff]
[    0.000000]  [mem 0x13c000000-0x13fdfffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x100000000-0x13bffffff]
[    0.000000]  [mem 0x100000000-0x13bffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x7ffaffff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x7fdfffff] page 2M
[    0.000000]  [mem 0x7fe00000-0x7ffaffff] page 4k
[    0.000000] RAMDISK: [mem 0x35ef0000-0x36f6ffff]
[    0.000000] ACPI: RSDP 00000000000f9d10 00014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 000000007ffb0000 00034 (v01 A M I  OEMRSDT  11000530 MSFT 00000097)
[    0.000000] ACPI: FACP 000000007ffb0200 00084 (v02 A M I  OEMFACP  11000530 MSFT 00000097)
[    0.000000] ACPI: DSDT 000000007ffb0430 0395B (v01  93956 93956131 00000131 INTL 02002026)
[    0.000000] ACPI: FACS 000000007ffc0000 00040
[    0.000000] ACPI: APIC 000000007ffb0390 0005C (v01 A M I  OEMAPIC  11000530 MSFT 00000097)
[    0.000000] ACPI: MCFG 000000007ffb03f0 0003C (v01 A M I  OEMMCFG  11000530 MSFT 00000097)
[    0.000000] ACPI: OEMB 000000007ffc0040 00056 (v01 A M I  AMI_OEM  11000530 MSFT 00000097)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] Scanning NUMA topology in Northbridge 24
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000013fffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x13fffffff]
[    0.000000]   NODE_DATA [mem 0x13fff9000-0x13fffdfff]
[    0.000000]  [ffffea0000000000-ffffea0004ffffff] PMD -> [ffff88013c600000-ffff88013f5fffff] on node 0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00001000-0x00ffffff]
[    0.000000]   DMA32    [mem 0x01000000-0xffffffff]
[    0.000000]   Normal   [mem 0x100000000-0x13fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00001000-0x0009efff]
[    0.000000]   node   0: [mem 0x00100000-0x7ffaffff]
[    0.000000]   node   0: [mem 0x100000000-0x13fffffff]
[    0.000000] On node 0 totalpages: 786254
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 8127 pages used for memmap
[    0.000000]   DMA32 zone: 520112 pages, LIFO batch:31
[    0.000000]   Normal zone: 4096 pages used for memmap
[    0.000000]   Normal zone: 262144 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 20, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e7fff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e8000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7ffb0000-0x7ffbffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7ffc0000-0x7ffeffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7fff0000-0x7fffffff]
[    0.000000] PM: Registered nosave memory: [mem 0x80000000-0xfffbffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfffc0000-0xffffffff]
[    0.000000] e820: [mem 0x80000000-0xfffbffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] PERCPU: Embedded 29 pages/cpu @ffff88013fc00000 s86720 r8192 d23872 u1048576
[    0.000000] pcpu-alloc: s86720 r8192 d23872 u1048576 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 773946
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-13-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro quiet splash
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Checking aperture...
[    0.000000] Node 0: aperture @ 8e1a000000 size 32 MB
[    0.000000] Aperture beyond 4GB. Ignoring.
[    0.000000] Your BIOS doesn't leave a aperture memory hole
[    0.000000] Please enable the IOMMU option in the BIOS setup
[    0.000000] This costs you 64 MB of RAM
[    0.000000] Mapping aperture over 65536 KB of RAM @ 74000000
[    0.000000] PM: Registered nosave memory: [mem 0x74000000-0x77ffffff]
[    0.000000] Memory: 2930568K/3145016K available (7141K kernel code, 1081K rwdata, 3260K rodata, 1364K init, 1420K bss, 214448K reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Offload RCU callbacks from all CPUs
[    0.000000] 	Offload RCU callbacks from CPUs: 0-255.
[    0.000000] NR_IRQS:16640 nr_irqs:512 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 12582912 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2400.215 MHz processor
[    0.000000] tsc: Marking TSC unstable due to TSCs unsynchronized
[    0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.43 BogoMIPS (lpj=9600860)
[    0.008012] pid_max: default: 32768 minimum: 301
[    0.008051] Security Framework initialized
[    0.008086] AppArmor: AppArmor initialized
[    0.008088] Yama: becoming mindful.
[    0.008553] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.015182] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.017205] Mount-cache hash table entries: 256
[    0.017554] Initializing cgroup subsys memory
[    0.017586] Initializing cgroup subsys devices
[    0.017588] Initializing cgroup subsys freezer
[    0.017591] Initializing cgroup subsys blkio
[    0.017593] Initializing cgroup subsys perf_event
[    0.017597] Initializing cgroup subsys hugetlb
[    0.017624] tseg: 0000000000
[    0.017634] CPU: Physical Processor ID: 0
[    0.017635] CPU: Processor Core ID: 0
[    0.017638] mce: CPU supports 5 MCE banks
[    0.017651] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.017651] Last level dTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.017651] tlb_flushall_shift: 4
[    0.017787] Freeing SMP alternatives memory: 28K (ffffffff81e65000 - ffffffff81e6c000)
[    0.019658] ACPI: Core revision 20130517
[    0.021271] ACPI: All ACPI Tables successfully acquired
[    0.021377] ftrace: allocating 27803 entries in 109 pages
[    0.032510] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.072865] smpboot: CPU0: Dual Core AMD Opteron(tm) Processor 180 (fam: 0f, model: 23, stepping: 02)
[    0.076000] Performance Events: AMD PMU driver.
[    0.076000] ... version:                0
[    0.076000] ... bit width:              48
[    0.076000] ... generic registers:      4
[    0.076000] ... value mask:             0000ffffffffffff
[    0.076000] ... max period:             00007fffffffffff
[    0.076000] ... fixed-purpose events:   0
[    0.076000] ... event mask:             000000000000000f
[    0.076000] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.076000] smpboot: Booting Node   0, Processors  #1 OK
[    0.164080] Brought up 2 CPUs
[    0.164083] smpboot: Total of 2 processors activated (9600.90 BogoMIPS)
[    0.164931] devtmpfs: initialized
[    0.165793] EVM: security.selinux
[    0.165795] EVM: security.SMACK64
[    0.165797] EVM: security.capability
[    0.165848] PM: Registering ACPI NVS region [mem 0x7ffc0000-0x7ffeffff] (196608 bytes)
[    0.168503] regulator-dummy: no parameters
[    0.168537] RTC time:  8:36:03, date: 11/10/13
[    0.168591] NET: Registered protocol family 16
[    0.168742] node 0 link 0: io port [1000, ffffff]
[    0.168746] TOM: 0000000080000000 aka 2048M
[    0.168748] node 0 link 0: mmio [e0000000, efffffff]
[    0.168752] node 0 link 0: mmio [a0000, bffff]
[    0.168755] node 0 link 0: mmio [80000000, ffffffff]
[    0.168757] TOM2: 0000000140000000 aka 5120M
[    0.168760] bus: [bus 00-ff] on node 0 link 0
[    0.168762] bus: 00 [io  0x0000-0xffff]
[    0.168763] bus: 00 [mem 0x80000000-0xffffffff]
[    0.168765] bus: 00 [mem 0x000a0000-0x000bffff]
[    0.168767] bus: 00 [mem 0x140000000-0xfcffffffff]
[    0.168809] ACPI: bus type PCI registered
[    0.168813] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.168878] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.168881] PCI: not using MMCONFIG
[    0.168883] PCI: Using configuration type 1 for base access
[    0.169908] bio: create slab <bio-0> at 0
[    0.169908] ACPI: Added _OSI(Module Device)
[    0.169908] ACPI: Added _OSI(Processor Device)
[    0.169908] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.169908] ACPI: Added _OSI(Processor Aggregator Device)
[    0.169908] ACPI: EC: Look up EC in DSDT
[    0.169908] ACPI: Executed 1 blocks of module-level executable AML code
[    0.173174] ACPI: Interpreter enabled
[    0.173186] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130517/hwxface-571)
[    0.173190] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20130517/hwxface-571)
[    0.173203] ACPI: (supports S0 S1 S4 S5)
[    0.173206] ACPI: Using IOAPIC for interrupt routing
[    0.173228] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.173819] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.184833] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.184909] ACPI: No dock devices found.
[    0.190736] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.190744] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[    0.190746] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[    0.190855] acpi PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.190858] acpi PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.190861] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.190863] acpi PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[    0.190866] acpi PNP0A03:00: host bridge window [mem 0x80000000-0xffffffff] (ignored)
[    0.190869] PCI: root bus 00: hardware-probed resources
[    0.190961] PCI host bridge to bus 0000:00
[    0.190965] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.190967] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.190970] pci_bus 0000:00: root bus resource [mem 0x80000000-0xffffffff]
[    0.190972] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.190975] pci_bus 0000:00: root bus resource [mem 0x140000000-0xfcffffffff]
[    0.190992] pci 0000:00:00.0: [1039:0756] type 00 class 0x060000
[    0.191115] pci 0000:00:01.0: [1039:0004] type 01 class 0x060400
[    0.191159] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.191226] pci 0000:00:02.0: [1039:0965] type 00 class 0x060100
[    0.191324] pci 0000:00:02.5: [1039:5513] type 00 class 0x01018a
[    0.191347] pci 0000:00:02.5: reg 0x10: [io  0x01f0-0x01f7]
[    0.191354] pci 0000:00:02.5: reg 0x14: [io  0x03f4-0x03f7]
[    0.191360] pci 0000:00:02.5: reg 0x18: [io  0x0170-0x0177]
[    0.191367] pci 0000:00:02.5: reg 0x1c: [io  0x0374-0x0377]
[    0.191373] pci 0000:00:02.5: reg 0x20: [io  0xffa0-0xffaf]
[    0.191400] pci 0000:00:02.5: PME# supported from D3cold
[    0.191466] pci 0000:00:02.7: [1039:7012] type 00 class 0x040100
[    0.191477] pci 0000:00:02.7: reg 0x10: [io  0xe800-0xe8ff]
[    0.191484] pci 0000:00:02.7: reg 0x14: [io  0xec00-0xec7f]
[    0.191527] pci 0000:00:02.7: supports D1 D2
[    0.191529] pci 0000:00:02.7: PME# supported from D3hot D3cold
[    0.191562] pci 0000:00:02.7: System wakeup disabled by ACPI
[    0.191601] pci 0000:00:03.0: [1039:7001] type 00 class 0x0c0310
[    0.191610] pci 0000:00:03.0: reg 0x10: [mem 0xfebfc000-0xfebfcfff]
[    0.191669] pci 0000:00:03.0: System wakeup disabled by ACPI
[    0.191706] pci 0000:00:03.1: [1039:7001] type 00 class 0x0c0310
[    0.191716] pci 0000:00:03.1: reg 0x10: [mem 0xfebfd000-0xfebfdfff]
[    0.191774] pci 0000:00:03.1: System wakeup disabled by ACPI
[    0.191809] pci 0000:00:03.2: [1039:7001] type 00 class 0x0c0310
[    0.191819] pci 0000:00:03.2: reg 0x10: [mem 0xfebfe000-0xfebfefff]
[    0.191877] pci 0000:00:03.2: System wakeup disabled by ACPI
[    0.191922] pci 0000:00:03.3: [1039:7002] type 00 class 0x0c0320
[    0.191933] pci 0000:00:03.3: reg 0x10: [mem 0xfebff000-0xfebfffff]
[    0.191977] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[    0.192009] pci 0000:00:03.3: System wakeup disabled by ACPI
[    0.192051] pci 0000:00:04.0: [1039:0190] type 00 class 0x020000
[    0.192062] pci 0000:00:04.0: reg 0x10: [mem 0xfebfbc00-0xfebfbc7f]
[    0.192069] pci 0000:00:04.0: reg 0x14: [io  0xe480-0xe4ff]
[    0.192108] pci 0000:00:04.0: supports D1 D2
[    0.192110] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.192141] pci 0000:00:04.0: System wakeup disabled by ACPI
[    0.192182] pci 0000:00:05.0: [1039:0182] type 00 class 0x010485
[    0.192193] pci 0000:00:05.0: reg 0x10: [io  0xe400-0xe407]
[    0.192200] pci 0000:00:05.0: reg 0x14: [io  0xe080-0xe083]
[    0.192207] pci 0000:00:05.0: reg 0x18: [io  0xe000-0xe007]
[    0.192214] pci 0000:00:05.0: reg 0x1c: [io  0xdc00-0xdc03]
[    0.192220] pci 0000:00:05.0: reg 0x20: [io  0xd880-0xd88f]
[    0.192227] pci 0000:00:05.0: reg 0x24: [io  0xd800-0xd87f]
[    0.192249] pci 0000:00:05.0: PME# supported from D3cold
[    0.192321] pci 0000:00:06.0: [1039:000a] type 01 class 0x060400
[    0.192373] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[    0.192445] pci 0000:00:07.0: [1039:000a] type 01 class 0x060400
[    0.192497] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[    0.192576] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
[    0.192639] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
[    0.192697] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
[    0.192751] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
[    0.192870] pci 0000:01:00.0: [10de:0a20] type 00 class 0x030000
[    0.192880] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[    0.192890] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.192899] pci 0000:01:00.0: reg 0x1c: [mem 0xdc000000-0xddffffff 64bit pref]
[    0.192906] pci 0000:01:00.0: reg 0x24: [io  0xcc00-0xcc7f]
[    0.192913] pci 0000:01:00.0: reg 0x30: [mem 0xfea80000-0xfeafffff pref]
[    0.192990] pci 0000:01:00.1: [10de:0be2] type 00 class 0x040300
[    0.193000] pci 0000:01:00.1: reg 0x10: [mem 0xfea7c000-0xfea7ffff]
[    0.200022] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.200028] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.200031] pci 0000:00:01.0:   bridge window [mem 0xfc900000-0xfeafffff]
[    0.200037] pci 0000:00:01.0:   bridge window [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.200091] pci 0000:00:06.0: PCI bridge to [bus 02]
[    0.200153] pci 0000:00:07.0: PCI bridge to [bus 03]
[    0.200892] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 *10 11 12 14 15)
[    0.200962] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.201026] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
[    0.201091] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.201154] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.201217] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.201280] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 7 10 11 12 14 15)
[    0.201346] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.201422] ACPI: \_SB_.PCI0: notify handler is installed
[    0.201449] Found 1 acpi root devices
[    0.201561] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.201561] vgaarb: loaded
[    0.201561] vgaarb: bridge control possible 0000:01:00.0
[    0.201561] SCSI subsystem initialized
[    0.201561] ACPI: bus type ATA registered
[    0.201561] libata version 3.00 loaded.
[    0.201561] ACPI: bus type USB registered
[    0.201561] usbcore: registered new interface driver usbfs
[    0.201561] usbcore: registered new interface driver hub
[    0.201561] usbcore: registered new device driver usb
[    0.201561] PCI: Using ACPI for IRQ routing
[    0.207903] PCI: pci_cache_line_size set to 64 bytes
[    0.207949] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.207952] e820: reserve RAM buffer [mem 0x7ffb0000-0x7fffffff]
[    0.208090] NetLabel: Initializing
[    0.208092] NetLabel:  domain hash size = 128
[    0.208093] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.208107] NetLabel:  unlabeled traffic allowed by default
[    0.208127] Switched to clocksource refined-jiffies
[    0.217542] AppArmor: AppArmor Filesystem Enabled
[    0.217605] pnp: PnP ACPI init
[    0.217632] ACPI: bus type PNP registered
[    0.217694] pnp 00:00: [dma 4]
[    0.217726] pnp 00:00: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.217776] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.217802] pnp 00:02: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.217835] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.218371] pnp 00:04: [dma 3]
[    0.218486] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.218680] pnp 00:05: Plug and Play ACPI device, IDs PNPb02f (active)
[    0.218895] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.218899] system 00:06: [io  0x0295-0x0296] has been reserved
[    0.218902] system 00:06: [io  0x0480-0x048f] has been reserved
[    0.218905] system 00:06: [io  0x08d0-0x08ff] has been reserved
[    0.218909] system 00:06: [io  0x0800-0x08cf] could not be reserved
[    0.218913] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.218993] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.218997] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.219000] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.219003] system 00:07: [mem 0xfffc0000-0xffffffff] has been reserved
[    0.219006] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.219248] pnp 00:08: [dma 0 disabled]
[    0.219314] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.219504] system 00:09: [io  0x0290-0x0291] has been reserved
[    0.219507] system 00:09: [io  0x0a10-0x0a1f] has been reserved
[    0.219510] system 00:09: [io  0x0a20-0x0a2f] has been reserved
[    0.219518] system 00:09: [io  0x0a30-0x0a3f] has been reserved
[    0.219522] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.219713] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.219716] system 00:0a: [mem 0x000c0000-0x000cffff] could not be reserved
[    0.219719] system 00:0a: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.219723] system 00:0a: [mem 0x00100000-0x7fffffff] could not be reserved
[    0.219726] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.219860] pnp: PnP ACPI: found 11 devices
[    0.219861] ACPI: bus type PNP unregistered
[    0.226605] Switched to clocksource acpi_pm
[    0.226640] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.226644] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.226648] pci 0000:00:01.0:   bridge window [mem 0xfc900000-0xfeafffff]
[    0.226652] pci 0000:00:01.0:   bridge window [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.226658] pci 0000:00:06.0: PCI bridge to [bus 02]
[    0.226666] pci 0000:00:07.0: PCI bridge to [bus 03]
[    0.226686] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    0.226688] pci_bus 0000:00: resource 5 [mem 0x80000000-0xffffffff]
[    0.226691] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.226694] pci_bus 0000:00: resource 7 [mem 0x140000000-0xfcffffffff]
[    0.226697] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.226699] pci_bus 0000:01: resource 1 [mem 0xfc900000-0xfeafffff]
[    0.226702] pci_bus 0000:01: resource 2 [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.226755] NET: Registered protocol family 2
[    0.227023] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[    0.227533] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.227958] TCP: Hash tables configured (established 32768 bind 32768)
[    0.227958] TCP: reno registered
[    0.227958] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.227958] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.227958] NET: Registered protocol family 1
[    0.227958] pci 0000:01:00.0: Boot video device
[    0.227958] PCI: CLS 64 bytes, default 64
[    0.227958] Trying to unpack rootfs image as initramfs...
[    0.593661] Freeing initrd memory: 16896K (ffff880035ef0000 - ffff880036f70000)
[    0.593959] PCI-DMA: Disabling AGP.
[    0.594112] PCI-DMA: aperture base @ 74000000 size 65536 KB
[    0.594114] PCI-DMA: using GART IOMMU.
[    0.594120] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[    0.598818] Scanning for low memory corruption every 60 seconds
[    0.599154] Initialise module verification
[    0.599214] audit: initializing netlink socket (disabled)
[    0.599237] type=2000 audit(1384072562.595:1): initialized
[    0.628071] bounce pool size: 64 pages
[    0.628085] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.629762] zbud: loaded
[    0.629931] VFS: Disk quotas dquot_6.5.2
[    0.629990] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.630657] fuse init (API version 7.22)
[    0.630775] msgmni has been set to 5885
[    0.631417] Key type asymmetric registered
[    0.631421] Asymmetric key parser 'x509' registered
[    0.631464] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.631509] io scheduler noop registered
[    0.631512] io scheduler deadline registered (default)
[    0.631541] io scheduler cfq registered
[    0.631744] pcieport 0000:00:06.0: irq 40 for MSI/MSI-X
[    0.631829] pcieport 0000:00:07.0: irq 41 for MSI/MSI-X
[    0.631904] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.631926] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.632125] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    0.632133] ACPI: Power Button [PWRB]
[    0.632176] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.632179] ACPI: Power Button [PWRF]
[    0.632355] GHES: HEST is not enabled!
[    0.632472] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.652836] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.654499] Linux agpgart interface v0.103
[    0.656150] brd: module loaded
[    0.657002] loop: module loaded
[    0.657179] pata_sis 0000:00:02.5: version 0.5.2
[    0.657691] scsi0 : pata_sis
[    0.657981] scsi1 : pata_sis
[    0.658201] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    0.658203] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    0.658526] libphy: Fixed MDIO Bus: probed
[    0.658636] tun: Universal TUN/TAP device driver, 1.6
[    0.658638] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.658693] PPP generic driver version 2.4.2
[    0.658753] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.658756] ehci-pci: EHCI PCI platform driver
[    0.658867] ehci-pci 0000:00:03.3: EHCI Host Controller
[    0.658876] ehci-pci 0000:00:03.3: new USB bus registered, assigned bus number 1
[    0.658917] ehci-pci 0000:00:03.3: cache line size of 64 is not supported
[    0.658934] ehci-pci 0000:00:03.3: irq 23, io mem 0xfebff000
[    0.668014] ehci-pci 0000:00:03.3: USB 2.0 started, EHCI 1.00
[    0.668043] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.668046] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.668049] usb usb1: Product: EHCI Host Controller
[    0.668051] usb usb1: Manufacturer: Linux 3.11.0-13-generic ehci_hcd
[    0.668053] usb usb1: SerialNumber: 0000:00:03.3
[    0.668170] hub 1-0:1.0: USB hub found
[    0.668177] hub 1-0:1.0: 8 ports detected
[    0.668354] ehci-platform: EHCI generic platform driver
[    0.668367] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.668369] ohci-platform: OHCI generic platform driver
[    0.668376] uhci_hcd: USB Universal Host Controller Interface driver
[    0.668452] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.668770] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.668776] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.668940] mousedev: PS/2 mouse device common for all mice
[    0.669080] rtc_cmos 00:01: RTC can wake from S4
[    0.669212] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    0.669233] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram
[    0.669307] device-mapper: uevent: version 1.0.3
[    0.669382] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com
[    0.669391] cpuidle: using governor ladder
[    0.669393] cpuidle: using governor menu
[    0.669402] ledtrig-cpu: registered to indicate activity on CPUs
[    0.669518] TCP: cubic registered
[    0.669643] NET: Registered protocol family 10
[    0.669904] NET: Registered protocol family 17
[    0.669918] Key type dns_resolver registered
[    0.670189] PM: Hibernation image not present or could not be loaded.
[    0.670194] Loading module verification certificates
[    0.671339] MODSIGN: Loaded cert 'Magrathea: Glacier signing key: 0d2f067ae81edbe7efb6ee2c61c63d9bdcf0659d'
[    0.671356] registered taskstats version 1
[    0.674717] Key type trusted registered
[    0.676998] Key type encrypted registered
[    0.679866] AppArmor: AppArmor sha1 policy hashing enabled
[    0.680175]   Magic number: 5:210:624
[    0.680330] rtc_cmos 00:01: setting system clock to 2013-11-10 08:36:03 UTC (1384072563)
[    0.680431] [Firmware Bug]: powernow-k8: No compatible ACPI _PSS objects found.
[    0.680431] [Firmware Bug]: powernow-k8: First, make sure Cool'N'Quiet is enabled in the BIOS.
[    0.680431] [Firmware Bug]: powernow-k8: If that doesn't help, try upgrading your BIOS.
[    0.680445] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.680446] EDD information not available.
[    0.969888] Freeing unused kernel memory: 1364K (ffffffff81d10000 - ffffffff81e65000)
[    0.969897] Write protecting the kernel read-only data: 12288k
[    0.973624] Freeing unused kernel memory: 1040K (ffff8800016fc000 - ffff880001800000)
[    0.976453] Freeing unused kernel memory: 836K (ffff880001b2f000 - ffff880001c00000)
[    0.993709] systemd-udevd[101]: starting version 204
[    1.018087] mii: module verification failed: signature and/or required key missing - tainting kernel
[    1.020046] sis190: sis190 Gigabit Ethernet driver 1.4 loaded
[    1.020247] sis190 0000:00:04.0: setting latency timer to 64
[    1.020265] sis190: 0000:00:04.0: Read MAC address from EEPROM
[    1.020268] sis190: 0000:00:04.0: Error EEPROM read 0
[    1.020270] sis190: 0000:00:04.0: Read MAC address from APC
[    1.068028] sis190: 0000:00:04.0: Realtek PHY RTL8201 transceiver at address 1
[    1.564014] sis190: 0000:00:04.0: Using transceiver at address 1 as default
[    1.596231] sis190 0000:00:04.0 eth0: 0000:00:04.0: SiS 190 PCI Fast Ethernet adapter at ffffc90000632c00 (IRQ: 19), 00:13:8f:4b:f4:0a
[    1.596234] sis190 0000:00:04.0 eth0: GMII mode.
[    1.596238] sis190 0000:00:04.0 eth0: Enabling Auto-negotiation
[    1.628348] sata_sis 0000:00:05.0: version 1.0
[    1.628505] sata_sis 0000:00:05.0: Detected SiS 182/965L chipset
[    1.628858] scsi2 : sata_sis
[    1.628951] scsi3 : sata_sis
[    1.629001] ata3: SATA max UDMA/133 cmd 0xe400 ctl 0xe080 bmdma 0xd880 irq 17
[    1.629004] ata4: SATA max UDMA/133 cmd 0xe000 ctl 0xdc00 bmdma 0xd888 irq 17
[    1.948044] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.957174] ata3.00: ATA-7: Maxtor 6L250S0, BACE1G20, max UDMA/133
[    1.957181] ata3.00: 490234752 sectors, multi 0: LBA48 NCQ (depth 0/32)
[    1.973152] ata3.00: configured for UDMA/133
[    1.973352] scsi 2:0:0:0: Direct-Access     ATA      Maxtor 6L250S0   BACE PQ: 0 ANSI: 5
[    1.973627] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    1.973646] sd 2:0:0:0: [sda] 490234752 512-byte logical blocks: (251 GB/233 GiB)
[    1.973766] sd 2:0:0:0: [sda] Write Protect is off
[    1.973770] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.973809] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.049059]  sda: sda1 sda2 sda3 < sda5 sda6 sda7 > sda4
[    2.049596] sd 2:0:0:0: [sda] Attached SCSI disk
[    2.292046] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.300218] ata4.00: ATAPI: TSSTcorp CDDVDW SH-S223C, SB05, max UDMA/100
[    2.316202] ata4.00: configured for UDMA/100
[    2.320829] scsi 3:0:0:0: CD-ROM            TSSTcorp CDDVDW SH-S223C  SB05 PQ: 0 ANSI: 5
[    2.325106] sr0: scsi3-mmc drive: 52x/52x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.325109] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.325261] sr 3:0:0:0: Attached scsi CD-ROM sr0
[    2.325351] sr 3:0:0:0: Attached scsi generic sg1 type 5
[    2.702888] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[    2.702896] EXT4-fs (sda1): write access will be enabled during recovery
[    3.553886] EXT4-fs (sda1): recovery complete
[    3.560717] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   14.021376] Adding 1951860k swap on /dev/sda6.  Priority:-1 extents:1 across:1951860k FS
[   14.104677] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.228258] systemd-udevd[281]: starting version 204
[   14.369589] lp: driver loaded but no devices found
[   14.376431] w83627hf: w83627hf: Found W83697HF chip at 0x290
[   14.414470] [drm] Initialized drm 1.1.0 20060810
[   14.434664] parport_pc 00:04: reported by Plug and Play ACPI
[   14.434805] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[   14.456188] nvidia: module license 'NVIDIA' taints kernel.
[   14.456197] Disabling lock debugging due to kernel taint
[   14.507066] ohci-pci: OHCI PCI platform driver
[   14.507386] ohci-pci 0000:00:03.0: OHCI PCI host controller
[   14.507404] ohci-pci 0000:00:03.0: new USB bus registered, assigned bus number 2
[   14.507453] ohci-pci 0000:00:03.0: irq 20, io mem 0xfebfc000
[   14.509563] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   14.510834] [drm] Initialized nvidia-drm 0.0.0 20130102 for 0000:01:00.0 on minor 0
[   14.510843] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  319.60  Wed Sep 25 14:28:26 PDT 2013
[   14.535455] lp0: using parport0 (interrupt-driven).
[   14.537295] MCE: In-kernel MCE decoding enabled.
[   14.545504] EDAC MC: Ver: 3.0.0
[   14.551823] AMD64 EDAC driver v3.4.0
[   14.559378] gameport gameport0: NS558 PnP Gameport is pnp00:05/gameport0, io 0x200, speed 854kHz
[   14.564193] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[   14.564198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.564201] usb usb2: Product: OHCI PCI host controller
[   14.564203] usb usb2: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.564206] usb usb2: SerialNumber: 0000:00:03.0
[   14.564400] hub 2-0:1.0: USB hub found
[   14.564408] hub 2-0:1.0: 3 ports detected
[   14.565917] ohci-pci 0000:00:03.1: OHCI PCI host controller
[   14.565927] ohci-pci 0000:00:03.1: new USB bus registered, assigned bus number 3
[   14.565965] ohci-pci 0000:00:03.1: irq 21, io mem 0xfebfd000
[   14.613332] microcode: AMD CPU family 0xf not supported
[   14.622158] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.622166] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.622169] usb usb3: Product: OHCI PCI host controller
[   14.622171] usb usb3: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.622173] usb usb3: SerialNumber: 0000:00:03.1
[   14.622890] hub 3-0:1.0: USB hub found
[   14.622899] hub 3-0:1.0: 3 ports detected
[   14.624435] type=1400 audit(1384072577.440:2): apparmor="STATUS" operation="profile_load" parent=326 profile="unconfined" name="/sbin/dhclient" pid=333 comm="apparmor_parser"
[   14.624447] type=1400 audit(1384072577.440:3): apparmor="STATUS" operation="profile_load" parent=326 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=333 comm="apparmor_parser"
[   14.624453] type=1400 audit(1384072577.440:4): apparmor="STATUS" operation="profile_load" parent=326 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=333 comm="apparmor_parser"
[   14.624917] ohci-pci 0000:00:03.2: OHCI PCI host controller
[   14.624928] ohci-pci 0000:00:03.2: new USB bus registered, assigned bus number 4
[   14.624973] ohci-pci 0000:00:03.2: irq 22, io mem 0xfebfe000
[   14.625227] type=1400 audit(1384072577.440:5): apparmor="STATUS" operation="profile_replace" parent=326 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=333 comm="apparmor_parser"
[   14.625236] type=1400 audit(1384072577.440:6): apparmor="STATUS" operation="profile_replace" parent=326 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=333 comm="apparmor_parser"
[   14.625688] type=1400 audit(1384072577.440:7): apparmor="STATUS" operation="profile_replace" parent=326 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=333 comm="apparmor_parser"
[   14.632245] hda_intel: Disabling MSI
[   14.632265] hda-intel 0000:01:00.1: Handle VGA-switcheroo audio client
[   14.632324] hda-intel 0000:01:00.1: Disabling 64bit DMA
[   14.639301] hda-intel 0000:01:00.1: Enable delay in RIRB handling
[   14.682100] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   14.682107] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.682110] usb usb4: Product: OHCI PCI host controller
[   14.682112] usb usb4: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.682114] usb usb4: SerialNumber: 0000:00:03.2
[   14.684175] hub 4-0:1.0: USB hub found
[   14.684185] hub 4-0:1.0: 2 ports detected
[   14.685212] EDAC amd64: DRAM ECC disabled.
[   14.685221] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.685221]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[   14.685221]  (Note that use of the override may cause unknown side effects.)
[   14.762311] ppdev: user-space parallel port driver
[   14.944034] usb 2-1: new low-speed USB device number 2 using ohci-pci
[   14.988822] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   15.008056] intel8x0_measure_ac97_clock: measured 54744 usecs (2634 samples)
[   15.008063] intel8x0: clocking to 48000
[   15.148197] usb 2-1: New USB device found, idVendor=04b3, idProduct=310b
[   15.148203] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   15.324021] usb 2-2: new low-speed USB device number 3 using ohci-pci
[   15.464125] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input2
[   15.464234] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input3
[   15.464310] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input4
[   15.464380] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input5
[   15.538192] usb 2-2: New USB device found, idVendor=046d, idProduct=c315
[   15.538199] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   15.538202] usb 2-2: Product: Logitech USB Keyboard
[   15.538204] usb 2-2: Manufacturer: Logitech
[   16.217219] hidraw: raw HID events driver (C) Jiri Kosina
[   16.232361] usbcore: registered new interface driver usbhid
[   16.232367] usbhid: USB HID core driver
[   16.235134] input: HID 04b3:310b as /devices/pci0000:00/0000:00:03.0/usb2/2-1/2-1:1.0/input/input6
[   16.237431] hid-generic 0003:04B3:310B.0001: input,hidraw0: USB HID v1.00 Mouse [HID 04b3:310b] on usb-0000:00:03.0-1/input0
[   16.239732] input: Logitech Logitech USB Keyboard as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2:1.0/input/input7
[   16.239986] hid-generic 0003:046D:C315.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech Logitech USB Keyboard] on usb-0000:00:03.0-2/input0
[   16.674963] kjournald starting.  Commit interval 5 seconds
[   16.675133] EXT3-fs (sda5): using internal journal
[   16.675138] EXT3-fs (sda5): mounted filesystem with ordered data mode
[   17.261370] kjournald starting.  Commit interval 5 seconds
[   17.280904] EXT3-fs (sda4): using internal journal
[   17.280909] EXT3-fs (sda4): mounted filesystem with ordered data mode
[   17.899746] init: failsafe main process (563) killed by TERM signal
[   18.124581] init: udev-fallback-graphics main process (584) terminated with status 1
[   18.245634] Bluetooth: Core ver 2.16
[   18.245681] NET: Registered protocol family 31
[   18.245683] Bluetooth: HCI device and connection manager initialized
[   18.245703] Bluetooth: HCI socket layer initialized
[   18.245708] Bluetooth: L2CAP socket layer initialized
[   18.245716] Bluetooth: SCO socket layer initialized
[   18.269232] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.269239] Bluetooth: BNEP filters: protocol multicast
[   18.269258] Bluetooth: BNEP socket layer initialized
[   18.310958] Bluetooth: RFCOMM TTY layer initialized
[   18.310985] Bluetooth: RFCOMM socket layer initialized
[   18.310987] Bluetooth: RFCOMM ver 1.11
[   18.664774] type=1400 audit(1384072581.479:8): apparmor="STATUS" operation="profile_replace" parent=748 profile="unconfined" name="/sbin/dhclient" pid=761 comm="apparmor_parser"
[   18.664789] type=1400 audit(1384072581.479:9): apparmor="STATUS" operation="profile_replace" parent=748 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=761 comm="apparmor_parser"
[   18.664795] type=1400 audit(1384072581.479:10): apparmor="STATUS" operation="profile_replace" parent=748 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=761 comm="apparmor_parser"
[   18.665504] type=1400 audit(1384072581.479:11): apparmor="STATUS" operation="profile_replace" parent=748 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=761 comm="apparmor_parser"
[   18.716109] init: avahi-cups-reload main process (755) terminated with status 1
[   18.974154] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   18.974388] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.336553] vboxdrv: Found 2 processor cores.
[   19.342283] vboxdrv: fAsync=1 offMin=0x2302a8 offMax=0x2302a8
[   19.342471] vboxdrv: TSC mode is 'asynchronous', kernel timer mode is 'normal'.
[   19.342473] vboxdrv: Successfully loaded version 4.2.16_Ubuntu (interface 0x001a0005).
With 2.5GB RAM (works perfectly)
Xorg Log
[    19.687]
[    19.687] X Protocol Version 11, Revision 0
[    19.687] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[    19.687] Current Operating System: Linux drake 3.11.0-13-generic #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 x86_64
[    19.687] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-13-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro quiet splash
[    19.687] Build Date: 15 October 2013  09:23:37AM
[    19.687] xorg-server 2:1.14.3-3ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    19.687] Current version of pixman: 0.30.2
[    19.687] 	Before reporting problems, check http://wiki.x.org
[    19.687] Markers: (--) probed, (**) from config file, (==) default setting,
[    19.687] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 10 09:41:18 2013
[    19.717] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.718] (==) No Layout section.  Using the first Screen section.
[    19.718] (==) No screen section available. Using defaults.
[    19.718] (**) |-->Screen "Default Screen Section" (0)
[    19.718] (**) |   |-->Monitor "<default monitor>"
[    19.718] (==) No monitor specified for screen "Default Screen Section".
[    19.718] (==) Automatically adding devices
[    19.718] (==) Automatically enabling devices
[    19.718] (==) Automatically adding GPU devices
[    19.718] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    19.718] 	Entry deleted from font path.
[    19.718] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    19.718] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    19.718] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    19.718] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    19.718] (==) FontPath set to:
	built-ins
[    19.718] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    19.718] (II) The server relies on udev to provide the list of input devices.
[    19.718] (II) Loader magic: 0x7fd4a93a2d20
[    19.718] (II) Module ABI versions:
[    19.718] 	X.Org ANSI C Emulation: 0.4
[    19.718] 	X.Org Video Driver: 14.1
[    19.718] 	X.Org XInput driver : 19.1
[    19.718] 	X.Org Server Extension : 7.0
[    19.718] (II) xfree86: Adding drm device (/dev/dri/card0)
[    19.720] (--) PCI:*(0:1:0:0) 10de:0a20:1462:1910 rev 162, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xdc000000/33554432, I/O @ 0x0000cc00/128, BIOS @ 0x????????/524288
[    19.720] (II) Open ACPI successful (/var/run/acpid.socket)
[    19.720] Initializing built-in extension Generic Event Extension
[    19.720] Initializing built-in extension SHAPE
[    19.720] Initializing built-in extension MIT-SHM
[    19.720] Initializing built-in extension XInputExtension
[    19.720] Initializing built-in extension XTEST
[    19.720] Initializing built-in extension BIG-REQUESTS
[    19.720] Initializing built-in extension SYNC
[    19.720] Initializing built-in extension XKEYBOARD
[    19.720] Initializing built-in extension XC-MISC
[    19.720] Initializing built-in extension SECURITY
[    19.720] Initializing built-in extension XINERAMA
[    19.720] Initializing built-in extension XFIXES
[    19.720] Initializing built-in extension RENDER
[    19.720] Initializing built-in extension RANDR
[    19.720] Initializing built-in extension COMPOSITE
[    19.720] Initializing built-in extension DAMAGE
[    19.720] Initializing built-in extension MIT-SCREEN-SAVER
[    19.720] Initializing built-in extension DOUBLE-BUFFER
[    19.720] Initializing built-in extension RECORD
[    19.720] Initializing built-in extension DPMS
[    19.720] Initializing built-in extension X-Resource
[    19.720] Initializing built-in extension XVideo
[    19.720] Initializing built-in extension XVideo-MotionCompensation
[    19.720] Initializing built-in extension SELinux
[    19.720] Initializing built-in extension XFree86-VidModeExtension
[    19.720] Initializing built-in extension XFree86-DGA
[    19.720] Initializing built-in extension XFree86-DRI
[    19.720] Initializing built-in extension DRI2
[    19.720] (II) "glx" will be loaded by default.
[    19.720] (WW) "xmir" is not to be loaded by default. Skipping.
[    19.720] (II) LoadModule: "dri2"
[    19.720] (II) Module "dri2" already built-in
[    19.720] (II) LoadModule: "glamoregl"
[    19.775] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    20.062] (EE) Failed to load /usr/lib/xorg/modules/libglamoregl.so: /usr/lib/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
[    20.062] (II) UnloadModule: "glamoregl"
[    20.062] (II) Unloading glamoregl
[    20.062] (EE) Failed to load module "glamoregl" (loader failed, 7)
[    20.062] (II) LoadModule: "glx"
[    20.062] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    20.268] (II) Module glx: vendor="NVIDIA Corporation"
[    20.268] 	compiled for 4.0.2, module version = 1.0.0
[    20.268] 	Module class: X.Org Server Extension
[    20.268] (II) NVIDIA GLX Module  319.60  Wed Sep 25 14:24:11 PDT 2013
[    20.268] Loading extension GLX
[    20.268] (==) Matched nvidia as autoconfigured driver 0
[    20.268] (==) Matched nouveau as autoconfigured driver 1
[    20.268] (==) Matched nvidia as autoconfigured driver 2
[    20.268] (==) Matched nouveau as autoconfigured driver 3
[    20.268] (==) Matched vesa as autoconfigured driver 4
[    20.268] (==) Matched modesetting as autoconfigured driver 5
[    20.268] (==) Matched fbdev as autoconfigured driver 6
[    20.268] (==) Assigned the driver to the xf86ConfigLayout
[    20.268] (II) LoadModule: "nvidia"
[    20.268] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    20.269] (II) Module nvidia: vendor="NVIDIA Corporation"
[    20.269] 	compiled for 4.0.2, module version = 1.0.0
[    20.269] 	Module class: X.Org Video Driver
[    20.269] (II) LoadModule: "nouveau"
[    20.270] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    20.370] (II) Module nouveau: vendor="X.Org Foundation"
[    20.370] 	compiled for 1.14.2.901, module version = 1.0.9
[    20.370] 	Module class: X.Org Video Driver
[    20.370] 	ABI class: X.Org Video Driver, version 14.1
[    20.370] (II) LoadModule: "vesa"
[    20.370] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    20.371] (II) Module vesa: vendor="X.Org Foundation"
[    20.371] 	compiled for 1.14.1, module version = 2.3.2
[    20.371] 	Module class: X.Org Video Driver
[    20.371] 	ABI class: X.Org Video Driver, version 14.1
[    20.371] (II) LoadModule: "modesetting"
[    20.371] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    20.371] (II) Module modesetting: vendor="X.Org Foundation"
[    20.371] 	compiled for 1.14.1, module version = 0.8.0
[    20.371] (II) LoadModule: "fbdev"
[    20.371] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    20.371] (II) Module fbdev: vendor="X.Org Foundation"
[    20.371] 	compiled for 1.14.1, module version = 0.4.3
[    20.371] (II) NVIDIA dlloader X Driver  319.60  Wed Sep 25 14:04:14 PDT 2013
[    20.371] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    20.371] (II) NOUVEAU driver Date:   Wed Jul 31 10:51:03 2013 +1000
[    20.371] (II) NOUVEAU driver for NVIDIA chipset families :
[    20.371] 	RIVA TNT        (NV04)
[    20.371] 	RIVA TNT2       (NV05)
[    20.371] 	GeForce 256     (NV10)
[    20.371] 	GeForce 2       (NV11, NV15)
[    20.371] 	GeForce 4MX     (NV17, NV18)
[    20.371] 	GeForce 3       (NV20)
[    20.371] 	GeForce 4Ti     (NV25, NV28)
[    20.371] 	GeForce FX      (NV3x)
[    20.372] 	GeForce 6       (NV4x)
[    20.372] 	GeForce 7       (G7x)
[    20.372] 	GeForce 8       (G8x)
[    20.372] 	GeForce GTX 200 (NVA0)
[    20.372] 	GeForce GTX 400 (NVC0)
[    20.372] (II) VESA: driver for VESA chipsets: vesa
[    20.372] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    20.372] (II) FBDEV: driver for framebuffer: fbdev
[    20.372] (++) using VT number 7
[    20.374] (II) Loading sub module "fb"
[    20.374] (II) LoadModule: "fb"
[    20.374] (II) Loading /usr/lib/xorg/modules/libfb.so
[    20.374] (II) Module fb: vendor="X.Org Foundation"
[    20.374] 	compiled for 1.14.3, module version = 1.0.0
[    20.374] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    20.374] (WW) Unresolved symbol: fbGetGCPrivateKey
[    20.374] (II) Loading sub module "wfb"
[    20.374] (II) LoadModule: "wfb"
[    20.376] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    20.377] (II) Module wfb: vendor="X.Org Foundation"
[    20.377] 	compiled for 1.14.3, module version = 1.0.0
[    20.377] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    20.377] (II) Loading sub module "shadow"
[    20.377] (II) LoadModule: "shadow"
[    20.377] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    20.377] (II) Module shadow: vendor="X.Org Foundation"
[    20.377] 	compiled for 1.14.3, module version = 1.1.0
[    20.377] (II) Loading sub module "ramdac"
[    20.377] (II) LoadModule: "ramdac"
[    20.377] (II) Module "ramdac" already built-in
[    20.377] (WW) Falling back to old probe method for vesa
[    20.377] (WW) Falling back to old probe method for modesetting
[    20.377] (WW) Falling back to old probe method for fbdev
[    20.377] (II) Loading sub module "fbdevhw"
[    20.377] (II) LoadModule: "fbdevhw"
[    20.377] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    20.377] (II) Module fbdevhw: vendor="X.Org Foundation"
[    20.377] 	compiled for 1.14.3, module version = 0.0.2
[    20.377] 	ABI class: X.Org Video Driver, version 14.1
[    20.378] (EE) open /dev/fb0: No such file or directory
[    20.378] (II) NVIDIA(0): Creating default Display subsection in Screen section
[    20.378] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    20.378] (==) NVIDIA(0): RGB weight 888
[    20.378] (==) NVIDIA(0): Default visual is TrueColor
[    20.378] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    20.378] (**) NVIDIA(0): Enabling 2D acceleration
[    21.294] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-1)) does not support NVIDIA
[    21.294] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    21.298] (II) NVIDIA(0): NVIDIA GPU GeForce GT 220 (GT216) at PCI:1:0:0 (GPU-0)
[    21.298] (--) NVIDIA(0): Memory: 1048576 kBytes
[    21.298] (--) NVIDIA(0): VideoBIOS: 70.16.1d.00.03
[    21.298] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    21.300] (--) NVIDIA(0): Valid display device(s) on GeForce GT 220 at PCI:1:0:0
[    21.300] (--) NVIDIA(0):     CRT-0
[    21.300] (--) NVIDIA(0):     Samsung SyncMaster (CRT-1) (boot, connected)
[    21.300] (--) NVIDIA(0):     DFP-0
[    21.300] (--) NVIDIA(0):     DFP-1
[    21.300] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[    21.300] (--) NVIDIA(0): Samsung SyncMaster (CRT-1): 400.0 MHz maximum pixel clock
[    21.300] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[    21.300] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    21.300] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    21.300] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    21.300] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    21.300] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-1) (Using EDID frequencies
[    21.300] (**) NVIDIA(0):     has been enabled on all display devices.)
[    21.305] (==) NVIDIA(0):
[    21.305] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    21.305] (==) NVIDIA(0):     will be used as the requested mode.
[    21.305] (II) NVIDIA(0): Validated MetaModes:
[    21.305] (II) NVIDIA(0):     "CRT-1:nvidia-auto-select{}"
[    21.305] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[    21.330] (--) NVIDIA(0): DPI set to (95, 96); computed from "UseEdidDpi" X config
[    21.330] (--) NVIDIA(0):     option
[    21.330] (II) UnloadModule: "nouveau"
[    21.330] (II) Unloading nouveau
[    21.330] (II) UnloadModule: "vesa"
[    21.330] (II) Unloading vesa
[    21.330] (II) UnloadModule: "modesetting"
[    21.330] (II) Unloading modesetting
[    21.330] (II) UnloadModule: "fbdev"
[    21.330] (II) Unloading fbdev
[    21.330] (II) UnloadSubModule: "fbdevhw"
[    21.330] (II) Unloading fbdevhw
[    21.330] (--) Depth 24 pixmap format is 32 bpp
[    21.331] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[    21.336] (II) NVIDIA(0): Setting mode "CRT-1:nvidia-auto-select{}"
[    21.381] Loading extension NV-GLX
[    21.407] (==) NVIDIA(0): Disabling shared memory pixmaps
[    21.407] (==) NVIDIA(0): Backing store disabled
[    21.407] (==) NVIDIA(0): Silken mouse enabled
[    21.408] (==) NVIDIA(0): DPMS enabled
[    21.408] Loading extension NV-CONTROL
[    21.408] Loading extension XINERAMA
[    21.408] (II) Loading sub module "dri2"
[    21.408] (II) LoadModule: "dri2"
[    21.408] (II) Module "dri2" already built-in
[    21.408] (II) NVIDIA(0): [DRI2] Setup complete
[    21.408] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    21.408] (--) RandR disabled
[    21.415] (II) SELinux: Disabled on system
[    21.416] (II) Initializing extension GLX
[    21.433] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[    21.436] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    21.436] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    21.436] (II) LoadModule: "evdev"
[    21.437] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    21.467] (II) Module evdev: vendor="X.Org Foundation"
[    21.467] 	compiled for 1.14.1, module version = 2.7.3
[    21.467] 	Module class: X.Org XInput Driver
[    21.467] 	ABI class: X.Org XInput driver, version 19.1
[    21.467] (II) Using input driver 'evdev' for 'Power Button'
[    21.467] (**) Power Button: always reports core events
[    21.467] (**) evdev: Power Button: Device: "/dev/input/event1"
[    21.467] (--) evdev: Power Button: Vendor 0 Product 0x1
[    21.467] (--) evdev: Power Button: Found keys
[    21.467] (II) evdev: Power Button: Configuring as keyboard
[    21.467] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    21.467] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    21.467] (**) Option "xkb_rules" "evdev"
[    21.467] (**) Option "xkb_model" "pc105"
[    21.467] (**) Option "xkb_layout" "it"
[    21.469] (II) XKB: reuse xkmfile /var/lib/xkb/server-3781FECB9CB8D26EE03343DB2C93394EA704B98F.xkm
[    21.470] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    21.470] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    21.470] (II) Using input driver 'evdev' for 'Power Button'
[    21.470] (**) Power Button: always reports core events
[    21.470] (**) evdev: Power Button: Device: "/dev/input/event0"
[    21.470] (--) evdev: Power Button: Vendor 0 Product 0x1
[    21.470] (--) evdev: Power Button: Found keys
[    21.470] (II) evdev: Power Button: Configuring as keyboard
[    21.470] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[    21.470] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    21.470] (**) Option "xkb_rules" "evdev"
[    21.470] (**) Option "xkb_model" "pc105"
[    21.470] (**) Option "xkb_layout" "it"
[    21.470] (II) config/udev: Adding drm device (/dev/dri/card0)
[    21.470] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[    21.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event2)
[    21.471] (II) No input driver specified, ignoring this device.
[    21.471] (II) This device may have been added with another device file.
[    21.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event3)
[    21.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[    21.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event5)
[    21.472] (II) config/udev: Adding input device HID 04b3:310b (/dev/input/event6)
[    21.472] (**) HID 04b3:310b: Applying InputClass "evdev pointer catchall"
[    21.472] (II) Using input driver 'evdev' for 'HID 04b3:310b'
[    21.472] (**) HID 04b3:310b: always reports core events
[    21.472] (**) evdev: HID 04b3:310b: Device: "/dev/input/event6"
[    21.472] (--) evdev: HID 04b3:310b: Vendor 0x4b3 Product 0x310b
[    21.472] (--) evdev: HID 04b3:310b: Found 3 mouse buttons
[    21.472] (--) evdev: HID 04b3:310b: Found scroll wheel(s)
[    21.472] (--) evdev: HID 04b3:310b: Found relative axes
[    21.472] (--) evdev: HID 04b3:310b: Found x and y relative axes
[    21.472] (II) evdev: HID 04b3:310b: Configuring as mouse
[    21.472] (II) evdev: HID 04b3:310b: Adding scrollwheel support
[    21.472] (**) evdev: HID 04b3:310b: YAxisMapping: buttons 4 and 5
[    21.472] (**) evdev: HID 04b3:310b: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    21.472] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:03.0/usb2/2-1/2-1:1.0/input/input6/event6"
[    21.472] (II) XINPUT: Adding extended input device "HID 04b3:310b" (type: MOUSE, id 8)
[    21.472] (II) evdev: HID 04b3:310b: initialized for relative axes.
[    21.472] (**) HID 04b3:310b: (accel) keeping acceleration scheme 1
[    21.472] (**) HID 04b3:310b: (accel) acceleration profile 0
[    21.472] (**) HID 04b3:310b: (accel) acceleration factor: 2.000
[    21.472] (**) HID 04b3:310b: (accel) acceleration threshold: 4
[    21.472] (II) config/udev: Adding input device HID 04b3:310b (/dev/input/mouse0)
[    21.472] (II) No input driver specified, ignoring this device.
[    21.472] (II) This device may have been added with another device file.
[    21.473] (II) config/udev: Adding input device Logitech Logitech USB Keyboard (/dev/input/event7)
[    21.473] (**) Logitech Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    21.473] (II) Using input driver 'evdev' for 'Logitech Logitech USB Keyboard'
[    21.473] (**) Logitech Logitech USB Keyboard: always reports core events
[    21.473] (**) evdev: Logitech Logitech USB Keyboard: Device: "/dev/input/event7"
[    21.473] (--) evdev: Logitech Logitech USB Keyboard: Vendor 0x46d Product 0xc315
[    21.473] (--) evdev: Logitech Logitech USB Keyboard: Found keys
[    21.473] (II) evdev: Logitech Logitech USB Keyboard: Configuring as keyboard
[    21.473] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2:1.0/input/input7/event7"
[    21.473] (II) XINPUT: Adding extended input device "Logitech Logitech USB Keyboard" (type: KEYBOARD, id 9)
[    21.473] (**) Option "xkb_rules" "evdev"
[    21.473] (**) Option "xkb_model" "pc105"
[    21.473] (**) Option "xkb_layout" "it"
[    27.321] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-1)) does not support NVIDIA
[    27.321] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    27.321] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    27.321] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-1) (Using EDID frequencies
[    27.321] (**) NVIDIA(0):     has been enabled on all display devices.)
[    28.908] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-1)) does not support NVIDIA
[    28.908] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    28.908] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    28.908] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-1) (Using EDID frequencies
[    28.908] (**) NVIDIA(0):     has been enabled on all display devices.)
[    28.946] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-1)) does not support NVIDIA
[    28.946] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    28.946] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    28.946] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-1) (Using EDID frequencies
[    28.946] (**) NVIDIA(0):     has been enabled on all display devices.)
dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.11.0-13-generic (buildd@roseapple) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 (Ubuntu 3.11.0-13.20-generic 3.11.6)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-13-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro quiet splash
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e8000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000009ffaffff] usable
[    0.000000] BIOS-e820: [mem 0x000000009ffb0000-0x000000009ffbffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000009ffc0000-0x000000009ffeffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000009fff0000-0x000000009fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI:          939S56-M/939S56-M, BIOS P1.40 11/30/2005
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] No AGP bridge found
[    0.000000] e820: last_pfn = 0x9ffb0 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask FF80000000 write-back
[    0.000000]   1 base 0080000000 mask FFE0000000 write-back
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] BRK [0x01fd1000, 0x01fd1fff] PGTABLE
[    0.000000] BRK [0x01fd2000, 0x01fd2fff] PGTABLE
[    0.000000] BRK [0x01fd3000, 0x01fd3fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x9fc00000-0x9fdfffff]
[    0.000000]  [mem 0x9fc00000-0x9fdfffff] page 2M
[    0.000000] BRK [0x01fd4000, 0x01fd4fff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x9c000000-0x9fbfffff]
[    0.000000]  [mem 0x9c000000-0x9fbfffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x80000000-0x9bffffff]
[    0.000000]  [mem 0x80000000-0x9bffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x7fffffff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x7fffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x9fe00000-0x9ffaffff]
[    0.000000]  [mem 0x9fe00000-0x9ffaffff] page 4k
[    0.000000] BRK [0x01fd5000, 0x01fd5fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35ef0000-0x36f6ffff]
[    0.000000] ACPI: RSDP 00000000000f9d10 00014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 000000009ffb0000 00034 (v01 A M I  OEMRSDT  11000530 MSFT 00000097)
[    0.000000] ACPI: FACP 000000009ffb0200 00084 (v02 A M I  OEMFACP  11000530 MSFT 00000097)
[    0.000000] ACPI: DSDT 000000009ffb0430 0395B (v01  93956 93956131 00000131 INTL 02002026)
[    0.000000] ACPI: FACS 000000009ffc0000 00040
[    0.000000] ACPI: APIC 000000009ffb0390 0005C (v01 A M I  OEMAPIC  11000530 MSFT 00000097)
[    0.000000] ACPI: MCFG 000000009ffb03f0 0003C (v01 A M I  OEMMCFG  11000530 MSFT 00000097)
[    0.000000] ACPI: OEMB 000000009ffc0040 00056 (v01 A M I  AMI_OEM  11000530 MSFT 00000097)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] Scanning NUMA topology in Northbridge 24
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000009ffaffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x9ffaffff]
[    0.000000]   NODE_DATA [mem 0x9ffab000-0x9ffaffff]
[    0.000000]  [ffffea0000000000-ffffea00027fffff] PMD -> [ffff88009cc00000-ffff88009f3fffff] on node 0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00001000-0x00ffffff]
[    0.000000]   DMA32    [mem 0x01000000-0xffffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00001000-0x0009efff]
[    0.000000]   node   0: [mem 0x00100000-0x9ffaffff]
[    0.000000] On node 0 totalpages: 655182
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 10175 pages used for memmap
[    0.000000]   DMA32 zone: 651184 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 20, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e7fff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e8000-0x000fffff]
[    0.000000] e820: [mem 0xa0000000-0xfffbffff] available for PCI devices
[    0.000000] PERCPU: Embedded 29 pages/cpu @ffff88009fa00000 s86720 r8192 d23872 u1048576
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 644922
[    0.000000] Policy zone: DMA32
[    0.000000] Memory: 2546068K/2620728K available (7141K kernel code, 1081K rwdata, 3260K rodata, 1364K init, 1420K bss, 74660K reserved)
[    0.000000] allocated 10485760 bytes of page_cgroup
[    0.000000] tsc: Detected 2400.220 MHz processor
[    0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.44 BogoMIPS (lpj=9600880)
[    0.004012] pid_max: default: 32768 minimum: 301
[    0.004050] Security Framework initialized
[    0.004085] AppArmor: AppArmor initialized
[    0.004087] Yama: becoming mindful.
[    0.004548] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.011991] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.014316] Mount-cache hash table entries: 256
[    0.014677] Initializing cgroup subsys memory
[    0.014711] Initializing cgroup subsys devices
[    0.014714] Initializing cgroup subsys freezer
[    0.014716] Initializing cgroup subsys blkio
[    0.014718] Initializing cgroup subsys perf_event
[    0.014722] Initializing cgroup subsys hugetlb
[    0.014749] tseg: 0000000000
[    0.014758] CPU: Physical Processor ID: 0
[    0.014760] CPU: Processor Core ID: 0
[    0.014762] mce: CPU supports 5 MCE banks
[    0.014774] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.014774] Last level dTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.014774] tlb_flushall_shift: 4
[    0.014913] Freeing SMP alternatives memory: 28K (ffffffff81e65000 - ffffffff81e6c000)
[    0.016752] ACPI: Core revision 20130517
[    0.018304] ACPI: All ACPI Tables successfully acquired
[    0.018404] ftrace: allocating 27803 entries in 109 pages
[    0.028494] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.069302] smpboot: CPU0: Dual Core AMD Opteron(tm) Processor 180 (fam: 0f, model: 23, stepping: 02)
[    0.072000] Performance Events: AMD PMU driver.
[    0.072000] ... version:                0
[    0.072000] ... bit width:              48
[    0.072000] ... generic registers:      4
[    0.072000] ... value mask:             0000ffffffffffff
[    0.072000] ... max period:             00007fffffffffff
[    0.072000] ... fixed-purpose events:   0
[    0.072000] ... event mask:             000000000000000f
[    0.072000] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.072000] smpboot: Booting Node   0, Processors  #1 OK
[    0.160066] Brought up 2 CPUs
[    0.160069] smpboot: Total of 2 processors activated (9600.90 BogoMIPS)
[    0.160912] devtmpfs: initialized
[    0.161741] EVM: security.selinux
[    0.161743] EVM: security.SMACK64
[    0.161744] EVM: security.capability
[    0.161794] PM: Registering ACPI NVS region [mem 0x9ffc0000-0x9ffeffff] (196608 bytes)
[    0.164380] regulator-dummy: no parameters
[    0.164410] RTC time:  8:40:59, date: 11/10/13
[    0.164464] NET: Registered protocol family 16
[    0.164604] node 0 link 0: io port [1000, ffffff]
[    0.164607] TOM: 00000000a0000000 aka 2560M
[    0.164610] node 0 link 0: mmio [e0000000, efffffff]
[    0.164614] node 0 link 0: mmio [a0000, bffff]
[    0.164616] node 0 link 0: mmio [a0000000, ffffffff]
[    0.164619] bus: [bus 00-ff] on node 0 link 0
[    0.164621] bus: 00 [io  0x0000-0xffff]
[    0.164623] bus: 00 [mem 0xa0000000-0xfcffffffff]
[    0.164624] bus: 00 [mem 0x000a0000-0x000bffff]
[    0.164665] ACPI: bus type PCI registered
[    0.164668] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.164735] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.164738] PCI: not using MMCONFIG
[    0.164740] PCI: Using configuration type 1 for base access
[    0.164859] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.164860] mtrr: probably your BIOS does not setup all CPUs.
[    0.164862] mtrr: corrected configuration.
[    0.165708] bio: create slab <bio-0> at 0
[    0.165708] ACPI: Added _OSI(Module Device)
[    0.165708] ACPI: Added _OSI(Processor Device)
[    0.165708] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.165708] ACPI: Added _OSI(Processor Aggregator Device)
[    0.165708] ACPI: EC: Look up EC in DSDT
[    0.165708] ACPI: Executed 1 blocks of module-level executable AML code
[    0.168751] ACPI: Interpreter enabled
[    0.168761] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130517/hwxface-571)
[    0.168766] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20130517/hwxface-571)
[    0.168777] ACPI: (supports S0 S1 S4 S5)
[    0.168780] ACPI: Using IOAPIC for interrupt routing
[    0.168801] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.169343] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.178568] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.178641] ACPI: No dock devices found.
[    0.184061] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.184067] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[    0.184070] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[    0.184171] acpi PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.184174] acpi PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.184177] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.184179] acpi PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[    0.184182] acpi PNP0A03:00: host bridge window [mem 0xa0000000-0xffffffff] (ignored)
[    0.184184] PCI: root bus 00: hardware-probed resources
[    0.184271] PCI host bridge to bus 0000:00
[    0.184275] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.184278] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.184280] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xfcffffffff]
[    0.184283] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.184299] pci 0000:00:00.0: [1039:0756] type 00 class 0x060000
[    0.184419] pci 0000:00:01.0: [1039:0004] type 01 class 0x060400
[    0.184463] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.184525] pci 0000:00:02.0: [1039:0965] type 00 class 0x060100
[    0.184622] pci 0000:00:02.5: [1039:5513] type 00 class 0x01018a
[    0.184641] pci 0000:00:02.5: reg 0x10: [io  0x01f0-0x01f7]
[    0.184648] pci 0000:00:02.5: reg 0x14: [io  0x03f4-0x03f7]
[    0.184655] pci 0000:00:02.5: reg 0x18: [io  0x0170-0x0177]
[    0.184661] pci 0000:00:02.5: reg 0x1c: [io  0x0374-0x0377]
[    0.184668] pci 0000:00:02.5: reg 0x20: [io  0xffa0-0xffaf]
[    0.184695] pci 0000:00:02.5: PME# supported from D3cold
[    0.184758] pci 0000:00:02.7: [1039:7012] type 00 class 0x040100
[    0.184769] pci 0000:00:02.7: reg 0x10: [io  0xe800-0xe8ff]
[    0.184777] pci 0000:00:02.7: reg 0x14: [io  0xec00-0xec7f]
[    0.184819] pci 0000:00:02.7: supports D1 D2
[    0.184821] pci 0000:00:02.7: PME# supported from D3hot D3cold
[    0.184851] pci 0000:00:02.7: System wakeup disabled by ACPI
[    0.184888] pci 0000:00:03.0: [1039:7001] type 00 class 0x0c0310
[    0.184897] pci 0000:00:03.0: reg 0x10: [mem 0xfebfc000-0xfebfcfff]
[    0.184957] pci 0000:00:03.0: System wakeup disabled by ACPI
[    0.184993] pci 0000:00:03.1: [1039:7001] type 00 class 0x0c0310
[    0.185003] pci 0000:00:03.1: reg 0x10: [mem 0xfebfd000-0xfebfdfff]
[    0.185059] pci 0000:00:03.1: System wakeup disabled by ACPI
[    0.185097] pci 0000:00:03.2: [1039:7001] type 00 class 0x0c0310
[    0.185107] pci 0000:00:03.2: reg 0x10: [mem 0xfebfe000-0xfebfefff]
[    0.185163] pci 0000:00:03.2: System wakeup disabled by ACPI
[    0.185205] pci 0000:00:03.3: [1039:7002] type 00 class 0x0c0320
[    0.185217] pci 0000:00:03.3: reg 0x10: [mem 0xfebff000-0xfebfffff]
[    0.185260] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[    0.185288] pci 0000:00:03.3: System wakeup disabled by ACPI
[    0.185329] pci 0000:00:04.0: [1039:0190] type 00 class 0x020000
[    0.185340] pci 0000:00:04.0: reg 0x10: [mem 0xfebfbc00-0xfebfbc7f]
[    0.185347] pci 0000:00:04.0: reg 0x14: [io  0xe480-0xe4ff]
[    0.185385] pci 0000:00:04.0: supports D1 D2
[    0.185388] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.185416] pci 0000:00:04.0: System wakeup disabled by ACPI
[    0.185456] pci 0000:00:05.0: [1039:0182] type 00 class 0x010485
[    0.185467] pci 0000:00:05.0: reg 0x10: [io  0xe400-0xe407]
[    0.185474] pci 0000:00:05.0: reg 0x14: [io  0xe080-0xe083]
[    0.185480] pci 0000:00:05.0: reg 0x18: [io  0xe000-0xe007]
[    0.185487] pci 0000:00:05.0: reg 0x1c: [io  0xdc00-0xdc03]
[    0.185494] pci 0000:00:05.0: reg 0x20: [io  0xd880-0xd88f]
[    0.185500] pci 0000:00:05.0: reg 0x24: [io  0xd800-0xd87f]
[    0.185522] pci 0000:00:05.0: PME# supported from D3cold
[    0.185586] pci 0000:00:06.0: [1039:000a] type 01 class 0x060400
[    0.185637] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[    0.185710] pci 0000:00:07.0: [1039:000a] type 01 class 0x060400
[    0.185762] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[    0.185844] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
[    0.185903] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
[    0.185959] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
[    0.186015] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
[    0.186124] pci 0000:01:00.0: [10de:0a20] type 00 class 0x030000
[    0.186133] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[    0.186143] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.186153] pci 0000:01:00.0: reg 0x1c: [mem 0xdc000000-0xddffffff 64bit pref]
[    0.186159] pci 0000:01:00.0: reg 0x24: [io  0xcc00-0xcc7f]
[    0.186166] pci 0000:01:00.0: reg 0x30: [mem 0xfea80000-0xfeafffff pref]
[    0.186242] pci 0000:01:00.1: [10de:0be2] type 00 class 0x040300
[    0.186252] pci 0000:01:00.1: reg 0x10: [mem 0xfea7c000-0xfea7ffff]
[    0.192022] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.192028] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.192031] pci 0000:00:01.0:   bridge window [mem 0xfc900000-0xfeafffff]
[    0.192036] pci 0000:00:01.0:   bridge window [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.192093] pci 0000:00:06.0: PCI bridge to [bus 02]
[    0.192153] pci 0000:00:07.0: PCI bridge to [bus 03]
[    0.192850] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 *10 11 12 14 15)
[    0.192915] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.192975] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
[    0.193037] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.193096] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.193155] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.193214] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 7 10 11 12 14 15)
[    0.193276] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 7 10 11 12 14 15)
[    0.193349] ACPI: \_SB_.PCI0: notify handler is installed
[    0.193377] Found 1 acpi root devices
[    0.193475] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.193475] vgaarb: loaded
[    0.193475] vgaarb: bridge control possible 0000:01:00.0
[    0.193475] SCSI subsystem initialized
[    0.193475] ACPI: bus type ATA registered
[    0.193475] libata version 3.00 loaded.
[    0.193475] ACPI: bus type USB registered
[    0.193475] usbcore: registered new interface driver usbfs
[    0.193475] usbcore: registered new interface driver hub
[    0.193475] usbcore: registered new device driver usb
[    0.193475] PCI: Using ACPI for IRQ routing
[    0.199742] PCI: pci_cache_line_size set to 64 bytes
[    0.199777] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.199780] e820: reserve RAM buffer [mem 0x9ffb0000-0x9fffffff]
[    0.199903] NetLabel: Initializing
[    0.199905] NetLabel:  domain hash size = 128
[    0.199906] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.199923] NetLabel:  unlabeled traffic allowed by default
[    0.200026] Switched to clocksource refined-jiffies
[    0.209432] AppArmor: AppArmor Filesystem Enabled
[    0.209497] pnp: PnP ACPI init
[    0.209521] ACPI: bus type PNP registered
[    0.209581] pnp 00:00: [dma 4]
[    0.209622] pnp 00:00: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.209665] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.209692] pnp 00:02: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.209720] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.210200] pnp 00:04: [dma 3]
[    0.210312] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.210486] pnp 00:05: Plug and Play ACPI device, IDs PNPb02f (active)
[    0.210698] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.210702] system 00:06: [io  0x0295-0x0296] has been reserved
[    0.210704] system 00:06: [io  0x0480-0x048f] has been reserved
[    0.210707] system 00:06: [io  0x08d0-0x08ff] has been reserved
[    0.210715] system 00:06: [io  0x0800-0x08cf] could not be reserved
[    0.210720] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.210800] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.210803] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.210806] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.210810] system 00:07: [mem 0xfffc0000-0xffffffff] has been reserved
[    0.210813] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.211032] pnp 00:08: [dma 0 disabled]
[    0.211092] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.211259] system 00:09: [io  0x0290-0x0291] has been reserved
[    0.211262] system 00:09: [io  0x0a10-0x0a1f] has been reserved
[    0.211265] system 00:09: [io  0x0a20-0x0a2f] has been reserved
[    0.211268] system 00:09: [io  0x0a30-0x0a3f] has been reserved
[    0.211271] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.211444] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.211447] system 00:0a: [mem 0x000c0000-0x000cffff] could not be reserved
[    0.211451] system 00:0a: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.211453] system 00:0a: [mem 0x00100000-0x9fffffff] could not be reserved
[    0.211457] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.211578] pnp: PnP ACPI: found 11 devices
[    0.211579] ACPI: bus type PNP unregistered
[    0.218179] Switched to clocksource acpi_pm
[    0.218212] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.218216] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.218220] pci 0000:00:01.0:   bridge window [mem 0xfc900000-0xfeafffff]
[    0.218224] pci 0000:00:01.0:   bridge window [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.218229] pci 0000:00:06.0: PCI bridge to [bus 02]
[    0.218237] pci 0000:00:07.0: PCI bridge to [bus 03]
[    0.218257] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    0.218259] pci_bus 0000:00: resource 5 [mem 0xa0000000-0xfcffffffff]
[    0.218262] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.218265] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.218267] pci_bus 0000:01: resource 1 [mem 0xfc900000-0xfeafffff]
[    0.218270] pci_bus 0000:01: resource 2 [mem 0xbbf00000-0xdfefffff 64bit pref]
[    0.218322] NET: Registered protocol family 2
[    0.218577] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[    0.219130] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.219591] TCP: Hash tables configured (established 32768 bind 32768)
[    0.219747] TCP: reno registered
[    0.219759] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.219848] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.219848] NET: Registered protocol family 1
[    0.219848] pci 0000:01:00.0: Boot video device
[    0.219848] PCI: CLS 64 bytes, default 64
[    0.219848] Trying to unpack rootfs image as initramfs...
[    0.589175] Freeing initrd memory: 16896K (ffff880035ef0000 - ffff880036f70000)
[    0.589841] Scanning for low memory corruption every 60 seconds
[    0.590139] Initialise module verification
[    0.590190] audit: initializing netlink socket (disabled)
[    0.590209] type=2000 audit(1384072859.587:1): initialized
[    0.618973] bounce pool size: 64 pages
[    0.618987] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.620738] zbud: loaded
[    0.620905] VFS: Disk quotas dquot_6.5.2
[    0.620964] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.621667] fuse init (API version 7.22)
[    0.621780] msgmni has been set to 5005
[    0.622388] Key type asymmetric registered
[    0.622392] Asymmetric key parser 'x509' registered
[    0.622433] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.622477] io scheduler noop registered
[    0.622479] io scheduler deadline registered (default)
[    0.622510] io scheduler cfq registered
[    0.622693] pcieport 0000:00:06.0: irq 40 for MSI/MSI-X
[    0.622775] pcieport 0000:00:07.0: irq 41 for MSI/MSI-X
[    0.622854] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.622872] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.623033] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    0.623039] ACPI: Power Button [PWRB]
[    0.623091] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.623093] ACPI: Power Button [PWRF]
[    0.623265] GHES: HEST is not enabled!
[    0.623373] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.643731] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.645351] Linux agpgart interface v0.103
[    0.646945] brd: module loaded
[    0.647791] loop: module loaded
[    0.647957] pata_sis 0000:00:02.5: version 0.5.2
[    0.648477] scsi0 : pata_sis
[    0.648762] scsi1 : pata_sis
[    0.648983] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    0.648985] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    0.649297] libphy: Fixed MDIO Bus: probed
[    0.649397] tun: Universal TUN/TAP device driver, 1.6
[    0.649399] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.649450] PPP generic driver version 2.4.2
[    0.649506] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.649508] ehci-pci: EHCI PCI platform driver
[    0.649618] ehci-pci 0000:00:03.3: EHCI Host Controller
[    0.649627] ehci-pci 0000:00:03.3: new USB bus registered, assigned bus number 1
[    0.649671] ehci-pci 0000:00:03.3: cache line size of 64 is not supported
[    0.649687] ehci-pci 0000:00:03.3: irq 23, io mem 0xfebff000
[    0.660016] ehci-pci 0000:00:03.3: USB 2.0 started, EHCI 1.00
[    0.660044] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.660047] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.660049] usb usb1: Product: EHCI Host Controller
[    0.660051] usb usb1: Manufacturer: Linux 3.11.0-13-generic ehci_hcd
[    0.660053] usb usb1: SerialNumber: 0000:00:03.3
[    0.660164] hub 1-0:1.0: USB hub found
[    0.660170] hub 1-0:1.0: 8 ports detected
[    0.660351] ehci-platform: EHCI generic platform driver
[    0.660363] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.660365] ohci-platform: OHCI generic platform driver
[    0.660372] uhci_hcd: USB Universal Host Controller Interface driver
[    0.660446] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.660758] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.660764] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.660894] mousedev: PS/2 mouse device common for all mice
[    0.661027] rtc_cmos 00:01: RTC can wake from S4
[    0.661156] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    0.661176] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram
[    0.661249] device-mapper: uevent: version 1.0.3
[    0.661322] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com
[    0.661330] cpuidle: using governor ladder
[    0.661332] cpuidle: using governor menu
[    0.661342] ledtrig-cpu: registered to indicate activity on CPUs
[    0.661445] TCP: cubic registered
[    0.661568] NET: Registered protocol family 10
[    0.661825] NET: Registered protocol family 17
[    0.661839] Key type dns_resolver registered
[    0.662084] PM: Hibernation image not present or could not be loaded.
[    0.662089] Loading module verification certificates
[    0.663227] MODSIGN: Loaded cert 'Magrathea: Glacier signing key: 0d2f067ae81edbe7efb6ee2c61c63d9bdcf0659d'
[    0.663248] registered taskstats version 1
[    0.666230] Key type trusted registered
[    0.668353] Key type encrypted registered
[    0.670912] AppArmor: AppArmor sha1 policy hashing enabled
[    0.671183]   Magic number: 5:760:674
[    0.671316] rtc_cmos 00:01: setting system clock to 2013-11-10 08:40:59 UTC (1384072859)
[    0.671409] [Firmware Bug]: powernow-k8: No compatible ACPI _PSS objects found.
[    0.671409] [Firmware Bug]: powernow-k8: First, make sure Cool'N'Quiet is enabled in the BIOS.
[    0.671409] [Firmware Bug]: powernow-k8: If that doesn't help, try upgrading your BIOS.
[    0.671423] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.671424] EDD information not available.
[    0.961965] Freeing unused kernel memory: 1364K (ffffffff81d10000 - ffffffff81e65000)
[    0.961974] Write protecting the kernel read-only data: 12288k
[    0.965872] Freeing unused kernel memory: 1040K (ffff8800016fc000 - ffff880001800000)
[    0.968812] Freeing unused kernel memory: 836K (ffff880001b2f000 - ffff880001c00000)
[    0.984467] systemd-udevd[101]: starting version 204
[    1.004984] mii: module verification failed: signature and/or required key missing - tainting kernel
[    1.009914] sis190: sis190 Gigabit Ethernet driver 1.4 loaded
[    1.010106] sis190 0000:00:04.0: setting latency timer to 64
[    1.010123] sis190: 0000:00:04.0: Read MAC address from EEPROM
[    1.010125] sis190: 0000:00:04.0: Error EEPROM read 0
[    1.010127] sis190: 0000:00:04.0: Read MAC address from APC
[    1.056021] sis190: 0000:00:04.0: Realtek PHY RTL8201 transceiver at address 1
[    1.552013] sis190: 0000:00:04.0: Using transceiver at address 1 as default
[    1.584218] sis190 0000:00:04.0 eth0: 0000:00:04.0: SiS 190 PCI Fast Ethernet adapter at ffffc90000632c00 (IRQ: 19), 00:13:8f:4b:f4:0a
[    1.584220] sis190 0000:00:04.0 eth0: GMII mode.
[    1.584224] sis190 0000:00:04.0 eth0: Enabling Auto-negotiation
[    1.616240] sata_sis 0000:00:05.0: version 1.0
[    1.616396] sata_sis 0000:00:05.0: Detected SiS 182/965L chipset
[    1.616709] scsi2 : sata_sis
[    1.616794] scsi3 : sata_sis
[    1.616833] ata3: SATA max UDMA/133 cmd 0xe400 ctl 0xe080 bmdma 0xd880 irq 17
[    1.616836] ata4: SATA max UDMA/133 cmd 0xe000 ctl 0xdc00 bmdma 0xd888 irq 17
[    1.936044] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.945190] ata3.00: ATA-7: Maxtor 6L250S0, BACE1G20, max UDMA/133
[    1.945196] ata3.00: 490234752 sectors, multi 0: LBA48 NCQ (depth 0/32)
[    1.961174] ata3.00: configured for UDMA/133
[    1.961359] scsi 2:0:0:0: Direct-Access     ATA      Maxtor 6L250S0   BACE PQ: 0 ANSI: 5
[    1.961587] sd 2:0:0:0: [sda] 490234752 512-byte logical blocks: (251 GB/233 GiB)
[    1.961642] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    1.961679] sd 2:0:0:0: [sda] Write Protect is off
[    1.961683] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.961710] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.039953]  sda: sda1 sda2 sda3 < sda5 sda6 sda7 > sda4
[    2.040494] sd 2:0:0:0: [sda] Attached SCSI disk
[    2.280045] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.288215] ata4.00: ATAPI: TSSTcorp CDDVDW SH-S223C, SB05, max UDMA/100
[    2.304204] ata4.00: configured for UDMA/100
[    2.310272] scsi 3:0:0:0: CD-ROM            TSSTcorp CDDVDW SH-S223C  SB05 PQ: 0 ANSI: 5
[    2.313446] sr0: scsi3-mmc drive: 52x/52x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.313449] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.313585] sr 3:0:0:0: Attached scsi CD-ROM sr0
[    2.313673] sr 3:0:0:0: Attached scsi generic sg1 type 5
[    2.734693] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[    2.734699] EXT4-fs (sda1): write access will be enabled during recovery
[    3.469947] EXT4-fs (sda1): recovery complete
[    3.476810] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   13.940520] Adding 1951860k swap on /dev/sda6.  Priority:-1 extents:1 across:1951860k FS
[   14.006178] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.102265] systemd-udevd[279]: starting version 204
[   14.274324] lp: driver loaded but no devices found
[   14.283167] w83627hf: w83627hf: Found W83697HF chip at 0x290
[   14.320640] parport_pc 00:04: reported by Plug and Play ACPI
[   14.320748] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[   14.351790] [drm] Initialized drm 1.1.0 20060810
[   14.355247] ohci-pci: OHCI PCI platform driver
[   14.355523] ohci-pci 0000:00:03.0: OHCI PCI host controller
[   14.355539] ohci-pci 0000:00:03.0: new USB bus registered, assigned bus number 2
[   14.355605] ohci-pci 0000:00:03.0: irq 20, io mem 0xfebfc000
[   14.397832] MCE: In-kernel MCE decoding enabled.
[   14.403619] EDAC MC: Ver: 3.0.0
[   14.410100] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[   14.410108] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.410111] usb usb2: Product: OHCI PCI host controller
[   14.410113] usb usb2: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.410115] usb usb2: SerialNumber: 0000:00:03.0
[   14.410381] hub 2-0:1.0: USB hub found
[   14.410390] hub 2-0:1.0: 3 ports detected
[   14.410696] ohci-pci 0000:00:03.1: OHCI PCI host controller
[   14.410706] ohci-pci 0000:00:03.1: new USB bus registered, assigned bus number 3
[   14.410742] ohci-pci 0000:00:03.1: irq 21, io mem 0xfebfd000
[   14.412922] AMD64 EDAC driver v3.4.0
[   14.418803] lp0: using parport0 (interrupt-driven).
[   14.436959] gameport gameport0: NS558 PnP Gameport is pnp00:05/gameport0, io 0x200, speed 855kHz
[   14.444749] nvidia: module license 'NVIDIA' taints kernel.
[   14.444756] Disabling lock debugging due to kernel taint
[   14.476876] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.476888] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.476891] usb usb3: Product: OHCI PCI host controller
[   14.476893] usb usb3: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.476896] usb usb3: SerialNumber: 0000:00:03.1
[   14.477208] hub 3-0:1.0: USB hub found
[   14.477216] hub 3-0:1.0: 3 ports detected
[   14.488393] microcode: AMD CPU family 0xf not supported
[   14.492067] ohci-pci 0000:00:03.2: OHCI PCI host controller
[   14.492085] ohci-pci 0000:00:03.2: new USB bus registered, assigned bus number 4
[   14.492125] ohci-pci 0000:00:03.2: irq 22, io mem 0xfebfe000
[   14.494282] type=1400 audit(1384072873.317:2): apparmor="STATUS" operation="profile_load" parent=322 profile="unconfined" name="/sbin/dhclient" pid=338 comm="apparmor_parser"
[   14.494305] type=1400 audit(1384072873.317:3): apparmor="STATUS" operation="profile_load" parent=322 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=338 comm="apparmor_parser"
[   14.494312] type=1400 audit(1384072873.317:4): apparmor="STATUS" operation="profile_load" parent=322 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=338 comm="apparmor_parser"
[   14.495137] type=1400 audit(1384072873.317:5): apparmor="STATUS" operation="profile_replace" parent=322 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=338 comm="apparmor_parser"
[   14.495148] type=1400 audit(1384072873.317:6): apparmor="STATUS" operation="profile_replace" parent=322 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=338 comm="apparmor_parser"
[   14.495602] type=1400 audit(1384072873.317:7): apparmor="STATUS" operation="profile_replace" parent=322 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=338 comm="apparmor_parser"
[   14.522267] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   14.523545] [drm] Initialized nvidia-drm 0.0.0 20130102 for 0000:01:00.0 on minor 0
[   14.523555] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  319.60  Wed Sep 25 14:28:26 PDT 2013
[   14.550693] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   14.550701] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.550704] usb usb4: Product: OHCI PCI host controller
[   14.550707] usb usb4: Manufacturer: Linux 3.11.0-13-generic ohci_hcd
[   14.550710] usb usb4: SerialNumber: 0000:00:03.2
[   14.550996] hub 4-0:1.0: USB hub found
[   14.551004] hub 4-0:1.0: 2 ports detected
[   14.551459] EDAC amd64: DRAM ECC disabled.
[   14.551469] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   14.551469]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[   14.551469]  (Note that use of the override may cause unknown side effects.)
[   14.643688] ppdev: user-space parallel port driver
[   14.651737] hda_intel: Disabling MSI
[   14.651756] hda-intel 0000:01:00.1: Handle VGA-switcheroo audio client
[   14.651811] hda-intel 0000:01:00.1: Disabling 64bit DMA
[   14.662003] hda-intel 0000:01:00.1: Enable delay in RIRB handling
[   14.784055] usb 2-1: new low-speed USB device number 2 using ohci-pci
[   14.916027] intel8x0_measure_ac97_clock: measured 54670 usecs (2630 samples)
[   14.916033] intel8x0: clocking to 48000
[   14.988092] usb 2-1: New USB device found, idVendor=04b3, idProduct=310b
[   14.988098] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   15.164041] usb 2-2: new low-speed USB device number 3 using ohci-pci
[   15.338168] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   15.378085] usb 2-2: New USB device found, idVendor=046d, idProduct=c315
[   15.378092] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   15.378095] usb 2-2: Product: Logitech USB Keyboard
[   15.378097] usb 2-2: Manufacturer: Logitech
[   15.464125] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input2
[   15.464235] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input3
[   15.464297] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
[   15.464363] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5
[   16.406521] hidraw: raw HID events driver (C) Jiri Kosina
[   16.422201] usbcore: registered new interface driver usbhid
[   16.422208] usbhid: USB HID core driver
[   16.426604] input: HID 04b3:310b as /devices/pci0000:00/0000:00:03.0/usb2/2-1/2-1:1.0/input/input6
[   16.428676] hid-generic 0003:04B3:310B.0001: input,hidraw0: USB HID v1.00 Mouse [HID 04b3:310b] on usb-0000:00:03.0-1/input0
[   16.429112] input: Logitech Logitech USB Keyboard as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2:1.0/input/input7
[   16.429261] hid-generic 0003:046D:C315.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech Logitech USB Keyboard] on usb-0000:00:03.0-2/input0
[   17.109171] kjournald starting.  Commit interval 5 seconds
[   17.110527] EXT3-fs (sda5): using internal journal
[   17.110531] EXT3-fs (sda5): mounted filesystem with ordered data mode
[   17.525248] kjournald starting.  Commit interval 5 seconds
[   17.531154] EXT3-fs (sda4): using internal journal
[   17.531157] EXT3-fs (sda4): mounted filesystem with ordered data mode
[   17.560928] init: udev-fallback-graphics main process (557) terminated with status 1
[   18.290973] init: failsafe main process (619) killed by TERM signal
[   18.524481] Bluetooth: Core ver 2.16
[   18.524515] NET: Registered protocol family 31
[   18.524517] Bluetooth: HCI device and connection manager initialized
[   18.524533] Bluetooth: HCI socket layer initialized
[   18.524536] Bluetooth: L2CAP socket layer initialized
[   18.524543] Bluetooth: SCO socket layer initialized
[   18.532692] Bluetooth: RFCOMM TTY layer initialized
[   18.532722] Bluetooth: RFCOMM socket layer initialized
[   18.532725] Bluetooth: RFCOMM ver 1.11
[   18.544821] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.544828] Bluetooth: BNEP filters: protocol multicast
[   18.544844] Bluetooth: BNEP socket layer initialized
[   18.678667] type=1400 audit(1384072877.501:8): apparmor="STATUS" operation="profile_replace" parent=761 profile="unconfined" name="/sbin/dhclient" pid=767 comm="apparmor_parser"
[   18.678683] type=1400 audit(1384072877.501:9): apparmor="STATUS" operation="profile_replace" parent=761 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=767 comm="apparmor_parser"
[   18.678688] type=1400 audit(1384072877.501:10): apparmor="STATUS" operation="profile_replace" parent=761 profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=767 comm="apparmor_parser"
[   18.679395] type=1400 audit(1384072877.501:11): apparmor="STATUS" operation="profile_replace" parent=761 profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=767 comm="apparmor_parser"
[   18.790451] init: avahi-cups-reload main process (771) terminated with status 1
[   19.395405] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.395736] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
I’m trying to narrow down the possible cause of the issue, it seems with 3GB RAM some additional components gets initialized (iommu?) to allow using that amount of memory if compared with 2.5GB.
Looking at dmesg when with 3GB ram (i.e. when the card is failing) I noticed these extra lines:
142-145:
[    0.000000] Your BIOS doesn't leave a aperture memory hole
[    0.000000] Please enable the IOMMU option in the BIOS setup
[    0.000000] This costs you 64 MB of RAM
[    0.000000] Mapping aperture over 65536 KB of RAM @ 74000000
[    0.000000] PM: Registered nosave memory: [mem 0x74000000-0x77ffffff]
414-417:
[    0.593959] PCI-DMA: Disabling AGP.
[    0.594112] PCI-DMA: aperture base @ 74000000 size 65536 KB
[    0.594114] PCI-DMA: using GART IOMMU.
[    0.594120] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
I don’t have any IOMMU option on Bios. As far as I understood, this should not create issues other than stealing 64MB ram for the purpose, but maybe it coudl bring some light into the “failed to initialize DMA” error I got from the NVIDIA driver.
PS: I’ve an AMD Opteron 180 on a ASrock 939S56-M motherboard. Same issue replacing the CPU with my older AMD Athlon X2 and also with previous Nvidia driver version.
anyone, any help? I’m stuck with a 2.5GB RAM max if I want to use the Nvidia driver, while my system supports up to 4GB ram!
Folks - I’ve not been able to find a solution.
I tried with different RAM modules / different combinations but when I go above 2.5GB X does not start.
I played around kernel parameters as well (tried: nopiac, apci=off, iommu=soft, iommu=memaper=2, iommu=noaperture, iommu=allowdac, video=vesa:off, vga=normal etc in different combinations). But no results apart from my PC turn on button that starts to be loose…
Hereby I attach the nvidia bug report with the hope someone can have a look. To me all seems fine, apart of course from the “(EE) NVIDIA(GPU-0): Failed to initialize DMA.” line in xorg logs.
https://drive.google.com/file/d/0B8Y7tosHDFkAMXpvRzlSOVF3bzQ/edit?usp=sharing
This sounds like a PCI hole problem (see http://en.wikipedia.org/wiki/PCI_hole and http://en.wikipedia.org/wiki/3_GB_barrier). I’m guessing that SiS chipset only has 32-bit addressing. The 1GB of video ram counts toward the 4GB maximum along with some other buffers on PCI devices. Normally, this should map to the top of RAM and steal a little bit of that 3GB when you have it, but without the iommu remapping, it can’t. Even with the 3GB in, you wouldn’t be able to address all of that RAM.
that’s interesting - thanks a lot. If it is an hardware constraint and I can’t go above 4GB when summing system ram to video ram, is there a way to tell the nvidia driver to use only 0.5GB instead of 1GB? I would prefer an half GB available for OS rather than the video card.
thanks
stem: Linux drake 3.11.0-13-generic #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 x86_64
You shouldn’t be affected by the restriction as your using 64bit.
Have you considered updating to the latest driver (it supports kernel-3.11 without patching)
https://devtalk.nvidia.com/default/topic/533434/linux/current-graphics-driver-releases/post/4002518/#4002518
Your patched driver is more likely to be the cause of the issue IMO.
https://devtalk.nvidia.com/default/topic/628864/unix-graphics-announcements-and-news/num_physpages-and-support-for-3-11-and-later-kernels/
He can still be restricted if the chipset only can address 32-bits. Given the age of that SiS chipset, that’s likely the case.
I had the same issue with Kernel 3.10 before upgrading to 3.11 so it should not be the patched version. Thanks anyway!
Is there any way I can limit with a kernel parameter the amount of memory used by the card? Or can’t I somehow instruct to allocate the video card memory within 32bit range?
I was able to find a nvidia 8500GT card with 512MB ram, half of my gt220 but I’m getting the very same issue, if I move from 2.5 to 3GB RAM:
[    25.770] (II) NVIDIA(0): NVIDIA GPU GeForce 8500 GT (G86) at PCI:1:0:0 (GPU-0)
[    25.770] (--) NVIDIA(0): Memory: 524288 kBytes
[    25.770] (--) NVIDIA(0): VideoBIOS: 60.86.34.00.13
[    25.770] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    28.773] (--) NVIDIA(0): Valid display device(s) on GeForce 8500 GT at PCI:1:0:0
[    28.806] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[    31.808] (EE) NVIDIA(GPU-0): Failed to initialize DMA.
[    31.808] (EE)  *** Aborting ***
I was supposing that by having a card with less memory I could gain something more on system memory but it does not seem to be the case.
On the other side, other two findings:
  • if I remove the nvidia driver and start X just in vesa mode, it works. But of curse performance is not acceptable…
  • in my (older) 32-bit PAE Linux installation, I can use the video card with 3GB ram installed and nvidia driver… but I’m suffering random freezes.
I’m about to give up…
Atch— I installed Ubuntu 13.10 x86 (32-bit with PAE support).
Surprise - I can boot and use X with 3GB ram… no DMA errors, nvidia driver ok (VPDAU etc). However, after some minutes all freezes (testes three times). No message on kernel logs or X, not capable to ssh in.
Removed nvidia driver and went to nouveau. All seems fine again, but again after several minutes all freezes again. So, clearly these freezes are not linked with nvidia driver.
HOWEVER, I’m wondering how it is possible that with a 32-bit kernel I can see the 3GB RAM if it was a “hardware limitation of my SiS chip” (I tried with 3.5GB as well and I see all of them). Or better, I’m pretty convinced that I don’t get the DMA error from the nvidia driver but then some weird conflicts came up…
As suggested by leigh123linux I also tried with the latest nvidia driver but no luck, with the 64bit kernel I get “Failed to initialize DMA” error when >2.5GB ram.
I started to look for a new PC… the time has arrived, Xmas coming closer.
Hi!
I am running Gentoo Linux on the Zotac Z68ITX-B-E motherboard. It has integrated Intel GPU and NVIDIA GT 430 GPU (it is part of the motherboard - can not be removed). I had same error message in Xorg.0.log:
I have tried all possible ways to fix it which I was able to find online and error did not go away. I was not able to use NVIDIA as GPU at all - only intel GPU worked.
Finally I updated BIOS of my motherboard and video BIOS of NVDIA GPU and problem has gone. I can use NVIDIA without problem.
So if you struggling of
then there is one more way to try to resolve it - update BIOS of the motherboard and/or NVIDIA GPU.
You should be aware that updating BIOS is risky procedure. If something will go wrong - you may end up with unworkable GPU or worse. So, while I am offering this way as possible solution - you are on your own if you will decide to update BIOS.
I followed procedure taken from http://forum.techinferno.com/nvidia-video-cards/2166-%5Bguide%5D-nvidia-vbios-flashing.html
I used DOS bootable USB stick.
In my case everything went well and as result I have workable NVIDIA GPU.
My software:
NVIDIA binary driver 334.21,
X org 1.14.3,
Linux kernel - 3.13.5 with aufs patch.
64 bit system and 16GB of RAM.
All from official Gentoo portage.
Which video Bios did you use for update??
I found video BIOS here:
http://www.techpowerup.com/vgabios/index.php?architecture=NVIDIA&manufacturer=&model=&interface=&memType=&memSize=
Select your card model and also make sure you match motherboard manufacturer.
I found no Bios for the onboard GT430, nvflash said does not match, i need Bios fpr Subsystem 19DA.1186.
The Zotac Bios from your site are for Subsystem 19DA.1167
