nvidia driver 304.108 Segmentation fault with Kernel 3.11 x86_64 & GeForce 6200
Hi… I’m getting crazy since a few days with this one, same error with debian testing (kernel 3.10) and ubuntu 13.10 (kernel 3.11).
Same with the ubuntu nvidia driver package or by downloading the driver from nvidia (to compile I had to patch it as discussed in another thread).
Here is the Xorg.0.log:
[    20.592]
X.Org X Server 1.14.3
Release Date: 2013-09-12
[    20.592] X Protocol Version 11, Revision 0
[    20.592] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[    20.592] Current Operating System: Linux drake 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64
[    20.592] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-12-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro nomodeset quiet splash vt.handoff=7
[    20.592] Build Date: 15 October 2013  09:23:37AM
[    20.592] xorg-server 2:1.14.3-3ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    20.593] Current version of pixman: 0.30.2
[    20.593] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    20.593] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    20.593] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 22 21:59:56 2013
[    20.593] (==) Using config file: "/etc/X11/xorg.conf"
[    20.593] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    20.644] (==) ServerLayout "Layout0"
[    20.644] (**) |-->Screen "Screen0" (0)
[    20.644] (**) |   |-->Monitor "Generic Monitor"
[    20.645] (==) No device specified for screen "Screen0".
	Using the first device section listed.
[    20.645] (**) |   |-->Device "Device0"
[    20.645] (**) |-->Input Device "Keyboard0"
[    20.645] (**) |-->Input Device "Mouse0"
[    20.645] (==) Automatically adding devices
[    20.645] (==) Automatically enabling devices
[    20.645] (==) Automatically adding GPU devices
[    20.645] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    20.645] 	Entry deleted from font path.
[    20.645] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    20.645] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    20.645] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    20.645] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    20.645] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    20.645] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    20.645] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    20.645] (WW) Disabling Keyboard0
[    20.645] (WW) Disabling Mouse0
[    20.645] (II) Loader magic: 0x7f7f64e85d20
[    20.645] (II) Module ABI versions:
[    20.645] 	X.Org ANSI C Emulation: 0.4
[    20.645] 	X.Org Video Driver: 14.1
[    20.645] 	X.Org XInput driver : 19.1
[    20.645] 	X.Org Server Extension : 7.0
[    20.647] (--) PCI:*(0:1:0:0) 10de:0161:1043:81ae rev 161, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xfc000000/16777216, BIOS @ 0x????????/131072
[    20.647] (II) Open ACPI successful (/var/run/acpid.socket)
[    20.647] Initializing built-in extension Generic Event Extension
[    20.647] Initializing built-in extension SHAPE
[    20.647] Initializing built-in extension MIT-SHM
[    20.647] Initializing built-in extension XInputExtension
[    20.647] Initializing built-in extension XTEST
[    20.647] Initializing built-in extension BIG-REQUESTS
[    20.647] Initializing built-in extension SYNC
[    20.647] Initializing built-in extension XKEYBOARD
[    20.647] Initializing built-in extension XC-MISC
[    20.647] Initializing built-in extension SECURITY
[    20.647] Initializing built-in extension XINERAMA
[    20.647] Initializing built-in extension XFIXES
[    20.647] Initializing built-in extension RENDER
[    20.647] Initializing built-in extension RANDR
[    20.647] Initializing built-in extension COMPOSITE
[    20.647] Initializing built-in extension DAMAGE
[    20.647] Initializing built-in extension MIT-SCREEN-SAVER
[    20.647] Initializing built-in extension DOUBLE-BUFFER
[    20.647] Initializing built-in extension RECORD
[    20.647] Initializing built-in extension DPMS
[    20.647] Initializing built-in extension X-Resource
[    20.647] Initializing built-in extension XVideo
[    20.647] Initializing built-in extension XVideo-MotionCompensation
[    20.647] Initializing built-in extension SELinux
[    20.647] Initializing built-in extension XFree86-VidModeExtension
[    20.647] Initializing built-in extension XFree86-DGA
[    20.647] Initializing built-in extension XFree86-DRI
[    20.647] Initializing built-in extension DRI2
[    20.647] (II) "glx" will be loaded by default.
[    20.647] (WW) "xmir" is not to be loaded by default. Skipping.
[    20.647] (II) LoadModule: "dri2"
[    20.647] (II) Module "dri2" already built-in
[    20.648] (II) LoadModule: "glamoregl"
[    20.670] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    21.312] (EE) Failed to load /usr/lib/xorg/modules/libglamoregl.so: /usr/lib/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
[    21.312] (II) UnloadModule: "glamoregl"
[    21.312] (II) Unloading glamoregl
[    21.312] (EE) Failed to load module "glamoregl" (loader failed, 7)
[    21.312] (II) LoadModule: "glx"
[    21.312] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    21.568] (II) Module glx: vendor="NVIDIA Corporation"
[    21.568] 	compiled for 4.0.2, module version = 1.0.0
[    21.568] 	Module class: X.Org Server Extension
[    21.568] (II) NVIDIA GLX Module  304.108  Wed Jul 31 19:56:59 PDT 2013
[    21.568] Loading extension GLX
[    21.568] (II) LoadModule: "nvidia"
[    21.568] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    21.669] (II) Module nvidia: vendor="NVIDIA Corporation"
[    21.669] 	compiled for 4.0.2, module version = 1.0.0
[    21.669] 	Module class: X.Org Video Driver
[    21.695] (II) NVIDIA dlloader X Driver  304.108  Wed Jul 31 19:36:56 PDT 2013
[    21.695] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    21.696] (++) using VT number 7
[    21.697] (II) Loading sub module "fb"
[    21.697] (II) LoadModule: "fb"
[    21.697] (II) Loading /usr/lib/xorg/modules/libfb.so
[    21.697] (II) Module fb: vendor="X.Org Foundation"
[    21.697] 	compiled for 1.14.3, module version = 1.0.0
[    21.697] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    21.697] (II) Loading sub module "wfb"
[    21.697] (II) LoadModule: "wfb"
[    21.698] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    21.711] (II) Module wfb: vendor="X.Org Foundation"
[    21.711] 	compiled for 1.14.3, module version = 1.0.0
[    21.711] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    21.711] (II) Loading sub module "ramdac"
[    21.711] (II) LoadModule: "ramdac"
[    21.711] (II) Module "ramdac" already built-in
[    21.714] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Screen0" for depth/fbbpp 24/32
[    21.714] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    21.714] (==) NVIDIA(0): RGB weight 888
[    21.714] (==) NVIDIA(0): Default visual is TrueColor
[    21.714] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    21.714] (**) NVIDIA(0): Enabling 2D acceleration
[    22.728] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (CRT-0)) does not support NVIDIA
[    22.728] (II) NVIDIA(GPU-0):     3D Vision stereo.
[    22.741] (II) NVIDIA(0): NVIDIA GPU GeForce 6200 TurboCache(TM) (NV44) at PCI:1:0:0
[    22.741] (II) NVIDIA(0):     (GPU-0)
[    22.741] (--) NVIDIA(0): Memory: 262144 kBytes
[    22.741] (--) NVIDIA(0): VideoBIOS: 05.44.02.11.00
[    22.741] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    22.741] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[    22.741] (--) NVIDIA(0): Valid display device(s) on GeForce 6200 TurboCache(TM) at PCI:1:0:0
[    22.741] (--) NVIDIA(0):     Samsung SyncMaster (CRT-0) (connected)
[    22.741] (--) NVIDIA(0):     TV-0
[    22.741] (--) NVIDIA(0):     DFP-0
[    22.741] (--) NVIDIA(0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[    22.741] (--) NVIDIA(0): TV-0: 400.0 MHz maximum pixel clock
[    22.741] (--) NVIDIA(0): TV encoder: Unknown
[    22.741] (--) NVIDIA(0): DFP-0: 155.0 MHz maximum pixel clock
[    22.741] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    22.741] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    22.741] (**) NVIDIA(0):     device Samsung SyncMaster (CRT-0) (Using EDID frequencies
[    22.741] (**) NVIDIA(0):     has been enabled on all display devices.)
[    22.742] (==) NVIDIA(0):
[    22.742] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    22.742] (==) NVIDIA(0):     will be used as the requested mode.
[    22.742] (II) NVIDIA(0): Validated MetaModes:
[    22.742] (II) NVIDIA(0):     "CRT-0:nvidia-auto-select"
[    22.742] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[    22.743] (WW) NVIDIA(0): Unable to support custom viewPortOut 1280 x 720 +0 +152
[    22.744] (--) NVIDIA(0): DPI set to (95, 96); computed from "UseEdidDpi" X config
[    22.744] (--) NVIDIA(0):     option
[    22.744] (--) Depth 24 pixmap format is 32 bpp
[    22.753] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[    22.782] (EE)
[    22.782] (EE) Backtrace:
[    22.783] (EE) 0: /usr/bin/X (xorg_backtrace+0x3d) [0x7f7f64c0502d]
[    22.783] (EE) 1: /usr/bin/X (0x7f7f64a63000+0x1a5d99) [0x7f7f64c08d99]
[    22.783] (EE) 2: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7f7f63b63000+0xfbb0) [0x7f7f63b72bb0]
[    22.783] (EE) 3: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x11641b) [0x7f7f5dc6d41b]
[    22.783] (EE) 4: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x72773) [0x7f7f5dbc9773]
[    22.783] (EE) 5: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0xea9e1) [0x7f7f5dc419e1]
[    22.783] (EE) 6: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0xe30c4) [0x7f7f5dc3a0c4]
[    22.783] (EE) 7: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0xe3800) [0x7f7f5dc3a800]
[    22.783] (EE) 8: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x9447b) [0x7f7f5dbeb47b]
[    22.783] (EE) 9: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x8fedb) [0x7f7f5dbe6edb]
[    22.784] (EE) 10: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0xde8d6) [0x7f7f5dc358d6]
[    22.784] (EE) 11: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x5c503b) [0x7f7f5e11c03b]
[    22.784] (EE) 12: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7f7f5db57000+0x5b6351) [0x7f7f5e10d351]
[    22.784] (EE) 13: /usr/bin/X (AddScreen+0x71) [0x7f7f64ab8281]
[    22.784] (EE) 14: /usr/bin/X (InitOutput+0x3f8) [0x7f7f64af8998]
[    22.784] (EE) 15: /usr/bin/X (0x7f7f64a63000+0x4437b) [0x7f7f64aa737b]
[    22.784] (EE) 16: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf5) [0x7f7f6279ede5]
[    22.784] (EE) 17: /usr/bin/X (0x7f7f64a63000+0x448af) [0x7f7f64aa78af]
[    22.784] (EE)
[    22.784] (EE) Segmentation fault at address 0x30
[    22.784] (EE)
Fatal server error:
[    22.784] (EE) Caught signal 11 (Segmentation fault). Server aborting
[    22.784] (EE)
[    22.784] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    22.784] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    22.784] (EE)
[    22.791] (EE) Server terminated with error (1). Closing log file.
… then I’m prompted with the console login.
link to the nvidia-bug-report https://docs.google.com/file/d/0B8Y7tosHDFkAdTUzR1VyOEx2NE0/edit?usp=sharing
Pls. what am I doing wrong?
gspeed
logs shows :
[ 47.353488] NVRM: Your system is not currently configured to drive a VGA console
[ 47.353496] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 47.353498] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 47.353501] NVRM: drivers including, but not limited to, vesafb, may result in
[ 47.353502] NVRM: corruption and stability problems, and is not supported.
[ 47.481879] NVRM: Xid (0000:01:00): 6, PE0000 09dc efaf716f 00000000 ffffffff 00000000
[ 47.507280] NVRM: Xid (0000:01:00): 6, PE0000 09dc efaf716f 00000000 ffffffff 00000000
Check if this help. Add kernel parameter :
video=vesa:off vga=0 rdblacklist=nouveau nouveau.modeset=0
Sandipt thanks for taking the time to go throu the logs, I tried what you suggest but it does not help.
I tried also to run with nvidia driver 173.14 (you can see this from the /var/log/Xorg.1.log in the bug report) since it should support my GeForce 6200: X does not start but instead of the segmentation fault I now get several such lines in the log:
[ 1120.651] (II) NVIDIA(0): Initialized GPU GART.
[ 1120.665] (II) NVIDIA(0): Initialized GPU GART.
[ 1120.678] (II) NVIDIA(0): Initialized GPU GART.
[ 1120.686] (EE) NVIDIA(0): Error recovery failed.
[ 1120.687] (EE) NVIDIA(0): *** Aborting ***
Here the full log with driver 173
[  1111.732]
[  1111.743] X Protocol Version 11, Revision 0
[  1111.746] Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
[  1111.750] Current Operating System: Linux drake 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64
[  1111.750] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-12-generic root=UUID=9cc30525-c462-4711-8106-cfb3e153eac2 ro nomodeset quiet splash vt.handoff=7
[  1111.758] Build Date: 15 October 2013  09:23:37AM
[  1111.762] xorg-server 2:1.14.3-3ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[  1111.766] Current version of pixman: 0.30.2
[  1111.774] 	Before reporting problems, check http://wiki.x.org
[  1111.774] Markers: (--) probed, (**) from config file, (==) default setting,
[  1111.792] (==) Log file: "/var/log/Xorg.1.log", Time: Mon Oct 21 23:10:22 2013
[  1111.797] (==) Using config file: "/etc/X11/xorg.conf"
[  1111.802] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1111.802] (==) ServerLayout "Layout0"
[  1111.802] (**) |-->Screen "Screen0" (0)
[  1111.802] (**) |   |-->Monitor "Monitor0"
[  1111.803] (**) |   |-->Device "Device0"
[  1111.803] (**) |-->Input Device "Keyboard0"
[  1111.803] (**) |-->Input Device "Mouse0"
[  1111.803] (==) Automatically adding devices
[  1111.803] (==) Automatically enabling devices
[  1111.803] (==) Automatically adding GPU devices
[  1111.803] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  1111.803] 	Entry deleted from font path.
[  1111.803] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[  1111.803] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[  1111.803] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[  1111.803] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[  1111.804] 	Entry deleted from font path.
[  1111.804] (==) FontPath set to:
	built-ins
[  1111.804] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[  1111.804] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[  1111.804] (WW) Disabling Keyboard0
[  1111.804] (WW) Disabling Mouse0
[  1111.804] (II) Loader magic: 0x7f1779dc6d20
[  1111.804] (II) Module ABI versions:
[  1111.804] 	X.Org ANSI C Emulation: 0.4
[  1111.804] 	X.Org Video Driver: 14.1
[  1111.804] 	X.Org XInput driver : 19.1
[  1111.804] 	X.Org Server Extension : 7.0
[  1111.806] (--) PCI:*(0:1:0:0) 10de:0161:1043:81ae rev 161, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xfc000000/16777216, BIOS @ 0x????????/131072
[  1111.806] (II) Open ACPI successful (/var/run/acpid.socket)
[  1111.811] Initializing built-in extension Generic Event Extension
[  1111.815] Initializing built-in extension SHAPE
[  1111.820] Initializing built-in extension MIT-SHM
[  1111.824] Initializing built-in extension XInputExtension
[  1111.829] Initializing built-in extension XTEST
[  1111.833] Initializing built-in extension BIG-REQUESTS
[  1111.838] Initializing built-in extension SYNC
[  1111.842] Initializing built-in extension XKEYBOARD
[  1111.846] Initializing built-in extension XC-MISC
[  1111.851] Initializing built-in extension SECURITY
[  1111.855] Initializing built-in extension XINERAMA
[  1111.858] Initializing built-in extension XFIXES
[  1111.860] Initializing built-in extension RENDER
[  1111.862] Initializing built-in extension RANDR
[  1111.864] Initializing built-in extension COMPOSITE
[  1111.866] Initializing built-in extension DAMAGE
[  1111.868] Initializing built-in extension MIT-SCREEN-SAVER
[  1111.870] Initializing built-in extension DOUBLE-BUFFER
[  1111.872] Initializing built-in extension RECORD
[  1111.874] Initializing built-in extension DPMS
[  1111.876] Initializing built-in extension X-Resource
[  1111.878] Initializing built-in extension XVideo
[  1111.879] Initializing built-in extension XVideo-MotionCompensation
[  1111.881] Initializing built-in extension SELinux
[  1111.883] Initializing built-in extension XFree86-VidModeExtension
[  1111.885] Initializing built-in extension XFree86-DGA
[  1111.887] Initializing built-in extension XFree86-DRI
[  1111.889] Initializing built-in extension DRI2
[  1111.889] (II) "glx" will be loaded by default.
[  1111.889] (WW) "xmir" is not to be loaded by default. Skipping.
[  1111.889] (II) LoadModule: "dri2"
[  1111.889] (II) Module "dri2" already built-in
[  1111.889] (II) LoadModule: "glamoregl"
[  1111.889] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[  1111.903] (EE) Failed to load /usr/lib/xorg/modules/libglamoregl.so: /usr/lib/xorg/modules/libglamoregl.so: undefined symbol: _glapi_tls_Context
[  1111.903] (II) UnloadModule: "glamoregl"
[  1111.903] (II) Unloading glamoregl
[  1111.903] (EE) Failed to load module "glamoregl" (loader failed, 7)
[  1111.903] (II) LoadModule: "glx"
[  1111.903] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1111.916] (II) Module glx: vendor="NVIDIA Corporation"
[  1111.916] 	compiled for 4.0.2, module version = 1.0.0
[  1111.916] 	Module class: X.Org Server Extension
[  1111.916] (II) NVIDIA GLX Module  173.14.38  Wed Aug 28 13:51:01 PDT 2013
[  1111.918] Loading extension GLX
[  1111.918] (II) LoadModule: "nvidia"
[  1111.918] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  1111.919] (II) Module nvidia: vendor="NVIDIA Corporation"
[  1111.920] 	compiled for 4.0.2, module version = 1.0.0
[  1111.920] 	Module class: X.Org Video Driver
[  1111.920] (II) NVIDIA dlloader X Driver  173.14.38  Wed Aug 28 13:41:06 PDT 2013
[  1111.920] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  1111.920] (--) using VT number 8
[  1111.927] (II) Loading sub module "fb"
[  1111.927] (II) LoadModule: "fb"
[  1111.928] (II) Loading /usr/lib/xorg/modules/libfb.so
[  1111.928] (II) Module fb: vendor="X.Org Foundation"
[  1111.928] 	compiled for 1.14.3, module version = 1.0.0
[  1111.928] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1111.928] (II) Loading sub module "wfb"
[  1111.928] (II) LoadModule: "wfb"
[  1111.928] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  1111.928] (II) Module wfb: vendor="X.Org Foundation"
[  1111.929] 	compiled for 1.14.3, module version = 1.0.0
[  1111.929] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1111.929] (II) Loading sub module "ramdac"
[  1111.929] (II) LoadModule: "ramdac"
[  1111.929] (II) Module "ramdac" already built-in
[  1111.929] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  1111.929] (==) NVIDIA(0): RGB weight 888
[  1111.929] (==) NVIDIA(0): Default visual is TrueColor
[  1111.929] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  1111.929] (**) NVIDIA(0): Enabling RENDER acceleration
[  1111.929] (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
[  1111.929] (II) NVIDIA(0):     enabled.
[  1112.025] (II) NVIDIA(0): NVIDIA GPU GeForce 6200 TurboCache(TM) (NV44) at PCI:1:0:0
[  1112.025] (II) NVIDIA(0):     (GPU-0)
[  1112.025] (--) NVIDIA(0): Memory: 262144 kBytes
[  1112.025] (--) NVIDIA(0): VideoBIOS: 05.44.02.11.00
[  1112.025] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  1112.025] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[  1112.025] (--) NVIDIA(0): Connected display device(s) on GeForce 6200 TurboCache(TM) at
[  1112.025] (--) NVIDIA(0):     PCI:1:0:0:
[  1112.025] (--) NVIDIA(0):     Samsung SyncMaster (CRT-0)
[  1112.025] (--) NVIDIA(0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
[  1112.026] (II) NVIDIA(0): Assigned Display Device: CRT-0
[  1112.026] (==) NVIDIA(0):
[  1112.026] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[  1112.026] (==) NVIDIA(0):     will be used as the requested mode.
[  1112.026] (II) NVIDIA(0): Validated modes:
[  1112.026] (II) NVIDIA(0):     "nvidia-auto-select"
[  1112.026] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[  1112.027] (--) NVIDIA(0): DPI set to (95, 96); computed from "UseEdidDpi" X config
[  1112.027] (--) NVIDIA(0):     option
[  1112.027] (==) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
[  1112.027] (--) Depth 24 pixmap format is 32 bpp
[  1112.029] (II) NVIDIA(0): Initialized GPU GART.
[  1112.039] (II) NVIDIA(0): Initialized GPU GART.
[  1112.048] (II) NVIDIA(0): Initialized GPU GART.
[  1112.056] (II) NVIDIA(0): Initialized GPU GART.
[  1112.065] (II) NVIDIA(0): Initialized GPU GART.
[  1112.074] (II) NVIDIA(0): Initialized GPU GART.
[  1112.084] (II) NVIDIA(0): Initialized GPU GART.
[  1112.093] (II) NVIDIA(0): Initialized GPU GART.
[  1112.102] (II) NVIDIA(0): Initialized GPU GART.
[  1112.108] (EE) NVIDIA(0): Error recovery failed.
[  1112.108] (EE) NVIDIA(0):  *** Aborting ***
[  1112.108] (II) NVIDIA(0): Setting mode "nvidia-auto-select"
[  1112.113] (II) NVIDIA(0): Initialized GPU GART.
[  1112.122] (II) NVIDIA(0): Initialized GPU GART.
[  1112.132] (II) NVIDIA(0): Initialized GPU GART.
[  1112.142] (II) NVIDIA(0): Initialized GPU GART.
[  1112.152] (II) NVIDIA(0): Initialized GPU GART.
[  1112.162] (II) NVIDIA(0): Initialized GPU GART.
[  1112.172] (II) NVIDIA(0): Initialized GPU GART.
[  1112.180] (WW) NVIDIA(0): The NVIDIA X driver has encountered too many errors.  Falling
[  1112.180] (WW) NVIDIA(0):     back to write-back cached memory.
[  1112.182] (II) NVIDIA(0): Initialized GPU GART.
[  1112.187] (EE) NVIDIA(0): Error recovery failed.
[  1112.187] (EE) NVIDIA(0):  *** Aborting ***
[  1112.205] Loading extension NV-GLX
[  1112.209] (II) NVIDIA(0): Initialized GPU GART.
[  1112.217] (II) NVIDIA(0): Initialized GPU GART.
[  1112.226] (II) NVIDIA(0): Initialized GPU GART.
[  1112.235] (II) NVIDIA(0): Initialized GPU GART.
[  1112.243] (II) NVIDIA(0): Initialized GPU GART.
[  1112.252] (II) NVIDIA(0): Initialized GPU GART.
[  1112.261] (II) NVIDIA(0): Initialized GPU GART.
[  1112.269] (II) NVIDIA(0): Initialized GPU GART.
[  1112.275] (EE) NVIDIA(0): Error recovery failed.
[  1112.275] (EE) NVIDIA(0):  *** Aborting ***
[  1113.087] (II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
[  1113.097] (II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
[  1113.097] (==) NVIDIA(0): Backing store disabled
[  1113.097] (==) NVIDIA(0): Silken mouse enabled
[  1113.097] (**) NVIDIA(0): DPMS enabled
[  1113.097] Loading extension NV-CONTROL
[  1113.098] (==) RandR enabled
[  1113.106] (II) SELinux: Disabled on system
[  1113.107] (II) Initializing extension GLX
[  1113.123] (II) XKB: generating xkmfile /tmp/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[  1113.282] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  1113.283] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1113.283] (II) LoadModule: "evdev"
[  1113.283] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[  1113.284] (II) Module evdev: vendor="X.Org Foundation"
[  1113.284] 	compiled for 1.14.1, module version = 2.7.3
[  1113.284] 	Module class: X.Org XInput Driver
[  1113.284] 	ABI class: X.Org XInput driver, version 19.1
[  1113.284] (II) Using input driver 'evdev' for 'Power Button'
[  1113.284] (**) Power Button: always reports core events
[  1113.284] (**) evdev: Power Button: Device: "/dev/input/event1"
[  1113.284] (--) evdev: Power Button: Vendor 0 Product 0x1
[  1113.284] (--) evdev: Power Button: Found keys
[  1113.284] (II) evdev: Power Button: Configuring as keyboard
[  1113.284] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  1113.284] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1113.284] (**) Option "xkb_rules" "evdev"
[  1113.284] (**) Option "xkb_model" "pc105"
[  1113.284] (**) Option "xkb_layout" "it"
[  1113.289] (II) XKB: generating xkmfile /tmp/server-3781FECB9CB8D26EE03343DB2C93394EA704B98F.xkm
[  1113.353] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  1113.353] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1113.353] (II) Using input driver 'evdev' for 'Power Button'
[  1113.353] (**) Power Button: always reports core events
[  1113.353] (**) evdev: Power Button: Device: "/dev/input/event0"
[  1113.353] (--) evdev: Power Button: Vendor 0 Product 0x1
[  1113.353] (--) evdev: Power Button: Found keys
[  1113.353] (II) evdev: Power Button: Configuring as keyboard
[  1113.353] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[  1113.353] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  1113.353] (**) Option "xkb_rules" "evdev"
[  1113.353] (**) Option "xkb_model" "pc105"
[  1113.354] (**) Option "xkb_layout" "it"
[  1113.355] (II) config/udev: Adding input device HID 04b3:310b (/dev/input/event2)
[  1113.355] (**) HID 04b3:310b: Applying InputClass "evdev pointer catchall"
[  1113.355] (II) Using input driver 'evdev' for 'HID 04b3:310b'
[  1113.355] (**) HID 04b3:310b: always reports core events
[  1113.355] (**) evdev: HID 04b3:310b: Device: "/dev/input/event2"
[  1113.355] (--) evdev: HID 04b3:310b: Vendor 0x4b3 Product 0x310b
[  1113.355] (--) evdev: HID 04b3:310b: Found 3 mouse buttons
[  1113.355] (--) evdev: HID 04b3:310b: Found scroll wheel(s)
[  1113.355] (--) evdev: HID 04b3:310b: Found relative axes
[  1113.355] (--) evdev: HID 04b3:310b: Found x and y relative axes
[  1113.355] (II) evdev: HID 04b3:310b: Configuring as mouse
[  1113.355] (II) evdev: HID 04b3:310b: Adding scrollwheel support
[  1113.355] (**) evdev: HID 04b3:310b: YAxisMapping: buttons 4 and 5
[  1113.356] (**) evdev: HID 04b3:310b: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[  1113.356] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:03.0/usb2/2-1/2-1:1.0/input/input2/event2"
[  1113.356] (II) XINPUT: Adding extended input device "HID 04b3:310b" (type: MOUSE, id 8)
[  1113.356] (II) evdev: HID 04b3:310b: initialized for relative axes.
[  1113.356] (**) HID 04b3:310b: (accel) keeping acceleration scheme 1
[  1113.356] (**) HID 04b3:310b: (accel) acceleration profile 0
[  1113.356] (**) HID 04b3:310b: (accel) acceleration factor: 2.000
[  1113.357] (**) HID 04b3:310b: (accel) acceleration threshold: 4
[  1113.357] (II) config/udev: Adding input device HID 04b3:310b (/dev/input/mouse0)
[  1113.357] (II) No input driver specified, ignoring this device.
[  1113.357] (II) This device may have been added with another device file.
[  1113.358] (II) config/udev: Adding input device Logitech Logitech USB Keyboard (/dev/input/event3)
[  1113.358] (**) Logitech Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[  1113.358] (II) Using input driver 'evdev' for 'Logitech Logitech USB Keyboard'
[  1113.358] (**) Logitech Logitech USB Keyboard: always reports core events
[  1113.358] (**) evdev: Logitech Logitech USB Keyboard: Device: "/dev/input/event3"
[  1113.358] (--) evdev: Logitech Logitech USB Keyboard: Vendor 0x46d Product 0xc315
[  1113.358] (--) evdev: Logitech Logitech USB Keyboard: Found keys
[  1113.358] (II) evdev: Logitech Logitech USB Keyboard: Configuring as keyboard
[  1113.358] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2:1.0/input/input3/event3"
[  1113.358] (II) XINPUT: Adding extended input device "Logitech Logitech USB Keyboard" (type: KEYBOARD, id 9)
[  1113.358] (**) Option "xkb_rules" "evdev"
[  1113.358] (**) Option "xkb_model" "pc105"
[  1113.358] (**) Option "xkb_layout" "it"
[  1120.432] (II) NVIDIA(0): Initialized GPU GART.
[  1120.445] (II) NVIDIA(0): Initialized GPU GART.
[  1120.460] (II) NVIDIA(0): Initialized GPU GART.
[  1120.474] (II) NVIDIA(0): Initialized GPU GART.
[  1120.487] (II) NVIDIA(0): Initialized GPU GART.
[  1120.501] (II) NVIDIA(0): Initialized GPU GART.
[  1120.514] (II) NVIDIA(0): Initialized GPU GART.
[  1120.527] (II) NVIDIA(0): Initialized GPU GART.
[  1120.536] (EE) NVIDIA(0): Error recovery failed.
[  1120.536] (EE) NVIDIA(0):  *** Aborting ***
[  1120.585] (II) NVIDIA(0): Initialized GPU GART.
[  1120.598] (II) NVIDIA(0): Initialized GPU GART.
[  1120.611] (II) NVIDIA(0): Initialized GPU GART.
[  1120.625] (II) NVIDIA(0): Initialized GPU GART.
[  1120.638] (II) NVIDIA(0): Initialized GPU GART.
[  1120.692] (II) NVIDIA(0): Initialized GPU GART.
[  1120.705] (II) NVIDIA(0): Initialized GPU GART.
[  1120.716] (II) NVIDIA(0): Initialized GPU GART.
[  1120.725] (II) NVIDIA(0): Initialized GPU GART.
[  1120.734] (II) NVIDIA(0): Initialized GPU GART.
[  1120.743] (II) NVIDIA(0): Initialized GPU GART.
[  1120.751] (II) NVIDIA(0): Initialized GPU GART.
[  1120.760] (II) NVIDIA(0): Initialized GPU GART.
[  1120.766] (EE) NVIDIA(0): Error recovery failed.
[  1120.766] (EE) NVIDIA(0):  *** Aborting ***
[  1120.769] (II) NVIDIA(0): Initialized GPU GART.
[  1120.778] (II) NVIDIA(0): Initialized GPU GART.
[  1120.787] (II) NVIDIA(0): Initialized GPU GART.
[  1120.795] (II) NVIDIA(0): Initialized GPU GART.
[  1120.804] (II) NVIDIA(0): Initialized GPU GART.
[  1120.813] (II) NVIDIA(0): Initialized GPU GART.
[  1120.821] (II) NVIDIA(0): Initialized GPU GART.
[  1120.830] (II) NVIDIA(0): Initialized GPU GART.
[  1120.836] (EE) NVIDIA(0): Error recovery failed.
[  1120.836] (EE) NVIDIA(0):  *** Aborting ***
[  1138.125] (II) evdev: Logitech Logitech USB Keyboard: Close
[  1138.126] (II) UnloadModule: "evdev"
[  1138.126] (II) evdev: HID 04b3:310b: Close
[  1138.126] (II) evdev: Power Button: Close
[  1138.134] (EE) Server terminated successfully (0). Closing log file.
Hope this can help to debug further.
One thing more, I’m upgrading from a debian stable where I was recently experiencing some random crashes where the screen freeze… I’m wondering if the video card is reaching his end… can I verify this somehow?
An update - I found a used GeForce GT 220 so I tried to change my video card: nouveau driver was freezing with unclear memory errors flashing on the screen. Nvidia official driver was failing with “(EE) NVIDIA(0): Failed to initialize DMA.”.
After trying anything I could (I learned a lot about kernel parameters…) I found out that by removing/swapping RAM modules I was getting erroneous behaviors: freeze at boot (before grub!), freeze at bios level (i.e. no bios screen at all), freeze during boot. Now I ended up by leaving two RAM slots free and the other two with 1 GB each. All seems to work fine, NVIDIA offical drivers included.
So… all this to say this seemed to be an HW problem with RAM not with the nvidia card.
@sadpit - thank again for having had a look at my logs
gspeed
