And from X
[ 369.375]
X.Org X Server 1.14.5
Release Date: 2013-12-12
[ 369.376] X Protocol Version 11, Revision 0
[ 369.376] Build Operating System: Linux 3.13.0-rc2-patser+ x86_64 Debian
[ 369.376] Current Operating System: Linux mira 3.12-trunk-amd64 #1 SMP Debian 3.12-1~exp1 (2013-11-17) x86_64
[ 369.376] Kernel command line: BOOT_IMAGE=/vmlinuz-3.12-trunk-amd64 root=/dev/mapper/raid1-root ro quiet
[ 369.376] Build Date: 13 December 2013 10:12:53AM
[ 369.376] xorg-server 2:1.14.5-1 (Maarten Lankhorst <maarten.lankhorst@ubuntu.com>)
[ 369.377] Current version of pixman: 0.30.2
[ 369.377] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 369.377] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 369.378] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 21 11:35:55 2013
[ 369.378] (==) Using config file: "/etc/X11/xorg.conf"
[ 369.378] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 369.378] (==) ServerLayout "Layout0"
[ 369.378] (**) |-->Screen "Screen0" (0)
[ 369.378] (**) | |-->Monitor "Monitor0"
[ 369.379] (**) | |-->Device "Videocard0"
[ 369.379] (**) |-->Screen "Screen1" (1)
[ 369.379] (**) | |-->Monitor "<default monitor>"
[ 369.379] (**) | |-->Device "Videocard1"
[ 369.379] (==) No monitor specified for screen "Screen1".
Using a default monitor configuration.
[ 369.379] (**) |-->Input Device "Keyboard0"
[ 369.379] (**) |-->Input Device "Mouse0"
[ 369.379] (**) |-->Input Device "stylus"
[ 369.379] (**) |-->Input Device "eraser"
[ 369.379] (**) |-->Input Device "cursor"
[ 369.379] (**) Option "Xinerama" "0"
[ 369.379] (==) Automatically adding devices
[ 369.379] (==) Automatically enabling devices
[ 369.379] (==) Automatically adding GPU devices
[ 369.379] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 369.379] Entry deleted from font path.
[ 369.379] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 369.379] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 369.379] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 369.379] (WW) Disabling Keyboard0
[ 369.379] (WW) Disabling Mouse0
[ 369.379] (II) Loader magic: 0x7fd9691c8d00
[ 369.379] (II) Module ABI versions:
[ 369.379] X.Org ANSI C Emulation: 0.4
[ 369.379] X.Org Video Driver: 14.1
[ 369.379] X.Org XInput driver : 19.1
[ 369.379] X.Org Server Extension : 7.0
[ 369.380] (--) PCI:*(0:1:0:0) 10de:0fc6:1043:8428 rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000d800/128, BIOS @ 0x????????/524288
[ 369.380] (II) Open ACPI successful (/var/run/acpid.socket)
[ 369.380] Initializing built-in extension Generic Event Extension
[ 369.381] Initializing built-in extension SHAPE
[ 369.381] Initializing built-in extension MIT-SHM
[ 369.381] Initializing built-in extension XInputExtension
[ 369.381] Initializing built-in extension XTEST
[ 369.381] Initializing built-in extension BIG-REQUESTS
[ 369.381] Initializing built-in extension SYNC
[ 369.381] Initializing built-in extension XKEYBOARD
[ 369.381] Initializing built-in extension XC-MISC
[ 369.381] Initializing built-in extension SECURITY
[ 369.382] Initializing built-in extension XINERAMA
[ 369.382] Initializing built-in extension XFIXES
[ 369.382] Initializing built-in extension RENDER
[ 369.382] Initializing built-in extension RANDR
[ 369.382] Initializing built-in extension COMPOSITE
[ 369.382] Initializing built-in extension DAMAGE
[ 369.382] Initializing built-in extension MIT-SCREEN-SAVER
[ 369.382] Initializing built-in extension DOUBLE-BUFFER
[ 369.382] Initializing built-in extension RECORD
[ 369.383] Initializing built-in extension DPMS
[ 369.383] Initializing built-in extension X-Resource
[ 369.383] Initializing built-in extension XVideo
[ 369.383] Initializing built-in extension XVideo-MotionCompensation
[ 369.383] Initializing built-in extension SELinux
[ 369.383] Initializing built-in extension XFree86-VidModeExtension
[ 369.383] Initializing built-in extension XFree86-DGA
[ 369.383] Initializing built-in extension XFree86-DRI
[ 369.383] Initializing built-in extension DRI2
[ 369.383] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 369.384] (II) LoadModule: "dbe"
[ 369.384] (II) Module "dbe" already built-in
[ 369.384] (II) LoadModule: "extmod"
[ 369.384] (II) Module "extmod" already built-in
[ 369.384] (II) LoadModule: "glx"
[ 369.384] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 369.398] (II) Module glx: vendor="NVIDIA Corporation"
[ 369.398] compiled for 4.0.2, module version = 1.0.0
[ 369.398] Module class: X.Org Server Extension
[ 369.398] (II) NVIDIA GLX Module 331.20 Wed Oct 30 17:36:48 PDT 2013
[ 369.398] Loading extension GLX
[ 369.398] (II) LoadModule: "nvidia"
[ 369.398] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 369.399] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 369.399] compiled for 4.0.2, module version = 1.0.0
[ 369.399] Module class: X.Org Video Driver
[ 369.399] (II) LoadModule: "wacom"
[ 369.399] (II) Loading /usr/lib/xorg/modules/input/wacom_drv.so
[ 369.399] (II) Module wacom: vendor="X.Org Foundation"
[ 369.399] compiled for 1.14.3, module version = 0.23.0
[ 369.399] Module class: X.Org XInput Driver
[ 369.399] ABI class: X.Org XInput driver, version 19.1
[ 369.399] (II) wacom: Driver for Wacom graphics tablets: PenPartner, Graphire,
Graphire2 4x5, Graphire2 5x7, Graphire3 4x5, Graphire3 6x8,
Graphire4 4x5, Graphire4 6x8, BambooFun 4x5, BambooFun 6x8,
Bamboo1 Medium, Graphire4 6x8 BlueTooth, CTL-460, CTH-461, CTL-660,
CTL-461/S, Bamboo Touch, CTH-460/K, CTH-461/S, CTH-661/S1, CTH-461/L,
CTH-661/L, Intuos 4x5, Intuos 6x8, Intuos 9x12, Intuos 12x12,
Intuos 12x18, PTU600, PL400, PL500, PL600, PL600SX, PL550, PL800,
PL700, PL510, PL710, DTI520, DTF720, DTF720a, DTF521, DTU1931,
DTU2231, DTU1631, Intuos2 4x5, Intuos2 6x8, Intuos2 9x12,
Intuos2 12x12, Intuos2 12x18, Intuos2 6x8 , Volito, PenStation,
Volito2 4x5, Volito2 2x3, PenPartner2, Bamboo, Bamboo1, Bamboo1 4x6,
Bamboo1 5x8, Intuos3 4x5, Intuos3 6x8, Intuos3 9x12, Intuos3 12x12,
Intuos3 12x19, Intuos3 6x11, Intuos3 4x6, Intuos4 4x6, Intuos4 6x9,
Intuos4 8x13, Intuos4 12x19, Intuos4 WL USB Endpoint,
Intuos4 WL Bluetooth Endpoint, Intuos5 touch S, Intuos5 touch M,
Intuos5 touch L, Intuos5 S, Intuos5 M, Intuos Pro S, Intuos Pro M,
Intuos Pro L, Cintiq 21UX, Cintiq 20WSX, Cintiq 12WX, Cintiq 21UX2,
Cintiq 24HD, Cintiq 22HD, Cintiq 24HD touch (EMR digitizer),
Cintiq 13HD, DTK2241, DTH2242, Cintiq 22HDT, TabletPC 0x90,
TabletPC 0x93, TabletPC 0x97, TabletPC 0x9A, CapPlus 0x9F,
TabletPC 0xE2, TabletPC 0xE3, TabletPC 0xE5, TabletPC 0xE6,
TabletPC 0xEC, TabletPC 0xED, TabletPC 0xEF, TabletPC 0x100,
TabletPC 0x101, TabletPC 0x10D, TabletPC 0x4001, usb:172f:0024,
usb:172f:0025, usb:172f:0026, usb:172f:0027, usb:172f:0028,
usb:172f:0030, usb:172f:0031, usb:172f:0032, usb:172f:0033,
usb:172f:0034, usb:172f:0035, usb:172f:0036, usb:172f:0037,
usb:172f:0038, usb:172f:0039, usb:172f:0051, usb:172f:0052,
usb:172f:0053, usb:172f:0054, usb:172f:0055, usb:172f:0056,
usb:172f:0057, usb:172f:0058, usb:172f:0500, usb:172f:0501,
usb:172f:0502, usb:172f:0503, usb:1b96:0001, usb:17ef:6004
[ 369.400] (II) NVIDIA dlloader X Driver 331.20 Wed Oct 30 17:16:53 PDT 2013
[ 369.400] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 369.400] (--) using VT number 7
[ 369.402] (II) Loading sub module "fb"
[ 369.402] (II) LoadModule: "fb"
[ 369.403] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 369.403] (II) Module fb: vendor="X.Org Foundation"
[ 369.403] compiled for 1.14.5, module version = 1.0.0
[ 369.403] ABI class: X.Org ANSI C Emulation, version 0.4
[ 369.403] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 369.403] (II) Loading sub module "wfb"
[ 369.403] (II) LoadModule: "wfb"
[ 369.403] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 369.403] (II) Module wfb: vendor="X.Org Foundation"
[ 369.403] (II) Loading sub module "ramdac"
[ 369.403] (II) LoadModule: "ramdac"
[ 369.403] (II) Module "ramdac" already built-in
[ 369.433] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 369.433] (==) NVIDIA(0): RGB weight 888
[ 369.433] (==) NVIDIA(0): Default visual is TrueColor
[ 369.433] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 369.433] (**) NVIDIA(0): Option "Stereo" "0"
[ 369.433] (**) NVIDIA(0): Option "DPI" "86 x 86"
[ 369.433] (**) NVIDIA(0): Stereo disabled by request
[ 369.433] (**) NVIDIA(0): Option "UseDisplayDevice" "DFP-0"
[ 369.433] (**) NVIDIA(1): Option "UseDisplayDevice" "DFP-1,DFP-2"
[ 369.434] (**) NVIDIA(0): Enabling 2D acceleration
[ 370.212] (II) NVIDIA(0): Display (HP L1955 (DFP-1)) does not support NVIDIA 3D Vision
[ 370.212] (II) NVIDIA(0): stereo.
[ 370.218] (II) NVIDIA(0): Display (HP L1955 (DFP-2)) does not support NVIDIA 3D Vision
[ 370.218] (II) NVIDIA(0): stereo.
[ 370.286] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 650 (GK107) at PCI:1:0:0 (GPU-0)
[ 370.286] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 370.286] (--) NVIDIA(0): VideoBIOS: 80.07.35.00.38
[ 370.286] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 370.288] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 650 at PCI:1:0:0
[ 370.288] (--) NVIDIA(0): CRT-0
[ 370.288] (--) NVIDIA(0): LG Electronics LG TV (DFP-0) (connected)
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-1) (boot, connected)
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-2) (connected)
[ 370.288] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 370.288] (--) NVIDIA(0): LG Electronics LG TV (DFP-0): Internal Single Link TMDS
[ 370.288] (--) NVIDIA(0): LG Electronics LG TV (DFP-0): 165.0 MHz maximum pixel clock
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-1): Internal Dual Link TMDS
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-1): 330.0 MHz maximum pixel clock
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-2): Internal Dual Link TMDS
[ 370.288] (--) NVIDIA(0): HP L1955 (DFP-2): 330.0 MHz maximum pixel clock
[ 370.288] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 370.289] (**) NVIDIA(0): device LG Electronics LG TV (DFP-0) (Using EDID
[ 370.289] (**) NVIDIA(0): frequencies has been enabled on all display devices.)
[ 370.291] (WW) NVIDIA(GPU-0): The EDID for LG Electronics LG TV (DFP-0) contradicts itself:
[ 370.291] (WW) NVIDIA(GPU-0): mode "1920x1080" is specified in the EDID; however, the
[ 370.291] (WW) NVIDIA(GPU-0): EDID's valid HorizSync range (31.000-100.000 kHz) would
[ 370.291] (WW) NVIDIA(GPU-0): exclude this mode's HorizSync (27.0 kHz); ignoring
[ 370.291] (WW) NVIDIA(GPU-0): HorizSync check for mode "1920x1080".
[ 370.291] (WW) NVIDIA(GPU-0): EDID's valid VertRefresh range (48.000-88.000 Hz) would
[ 370.291] (WW) NVIDIA(GPU-0): exclude this mode's VertRefresh (24.0 Hz); ignoring
[ 370.291] (WW) NVIDIA(GPU-0): VertRefresh check for mode "1920x1080".
[ 370.291] (WW) NVIDIA(GPU-0): exclude this mode's VertRefresh (30.0 Hz); ignoring
[ 370.293] (==) NVIDIA(0):
[ 370.293] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 370.293] (==) NVIDIA(0): will be used as the requested mode.
[ 370.294] (II) NVIDIA(0): Validated MetaModes:
[ 370.294] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 370.294] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 370.339] (**) NVIDIA(0): DPI set to (86, 86); computed from "DPI" X config option
[ 370.339] (**) NVIDIA(1): Depth 24, (--) framebuffer bpp 32
[ 370.339] (==) NVIDIA(1): RGB weight 888
[ 370.339] (==) NVIDIA(1): Default visual is TrueColor
[ 370.339] (==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
[ 370.339] (**) NVIDIA(1): Option "Stereo" "0"
[ 370.339] (**) NVIDIA(1): Option "DPI" "86 x 86"
[ 370.339] (**) NVIDIA(1): Stereo disabled by request
[ 370.339] (II) NVIDIA(1): NVIDIA GPU GeForce GTX 650 (GK107) at PCI:1:0:0 (GPU-0)
[ 370.339] (--) NVIDIA(1): Memory: 1048576 kBytes
[ 370.339] (--) NVIDIA(1): VideoBIOS: 80.07.35.00.38
[ 370.339] (II) NVIDIA(1): Detected PCI Express Link width: 16X
[ 370.340] (--) NVIDIA(1): Valid display device(s) on GeForce GTX 650 at PCI:1:0:0
[ 370.340] (--) NVIDIA(1): CRT-0
[ 370.340] (--) NVIDIA(1): LG Electronics LG TV (DFP-0) (connected)
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-1) (boot, connected)
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-2) (connected)
[ 370.340] (--) NVIDIA(1): CRT-0: 400.0 MHz maximum pixel clock
[ 370.340] (--) NVIDIA(1): LG Electronics LG TV (DFP-0): Internal Single Link TMDS
[ 370.340] (--) NVIDIA(1): LG Electronics LG TV (DFP-0): 165.0 MHz maximum pixel clock
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-1): Internal Dual Link TMDS
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-1): 330.0 MHz maximum pixel clock
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-2): Internal Dual Link TMDS
[ 370.340] (--) NVIDIA(1): HP L1955 (DFP-2): 330.0 MHz maximum pixel clock
[ 370.340] (**) NVIDIA(1): Using HorizSync/VertRefresh ranges from the EDID for display
[ 370.340] (**) NVIDIA(1): device HP L1955 (DFP-1) (Using EDID frequencies has been
[ 370.340] (**) NVIDIA(1): enabled on all display devices.)
[ 370.341] (**) NVIDIA(1): Using HorizSync/VertRefresh ranges from the EDID for display
[ 370.341] (**) NVIDIA(1): device HP L1955 (DFP-2) (Using EDID frequencies has been
[ 370.341] (**) NVIDIA(1): enabled on all display devices.)
[ 370.341] (==) NVIDIA(1):
[ 370.341] (==) NVIDIA(1): No modes were requested; the default mode "nvidia-auto-select"
[ 370.341] (==) NVIDIA(1): will be used as the requested mode.
[ 370.342] (II) NVIDIA(1): Validated MetaModes:
[ 370.342] (II) NVIDIA(1): "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select"
[ 370.342] (II) NVIDIA(1): Virtual screen size determined to be 2560 x 1024
[ 370.343] (**) NVIDIA(1): DPI set to (86, 86); computed from "DPI" X config option
[ 370.343] (--) Depth 24 pixmap format is 32 bpp
[ 370.343] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 370.343] (II) NVIDIA: access.
[ 370.351] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 370.408] Loading extension NV-GLX
[ 370.458] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 370.458] (==) NVIDIA(0): Backing store disabled
[ 370.458] (==) NVIDIA(0): Silken mouse enabled
[ 370.460] (**) NVIDIA(0): DPMS enabled
[ 370.460] Loading extension NV-CONTROL
[ 370.461] (II) Loading sub module "dri2"
[ 370.461] (II) LoadModule: "dri2"
[ 370.461] (II) Module "dri2" already built-in
[ 370.461] (II) NVIDIA(0): [DRI2] Setup complete
[ 370.461] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 370.461] (--) RandR disabled
[ 370.465] (II) NVIDIA(1): Setting mode "DFP-1:nvidia-auto-select,DFP-2:nvidia-auto-select"
[ 370.642] (==) NVIDIA(1): Disabling shared memory pixmaps
[ 370.642] (==) NVIDIA(1): Backing store disabled
[ 370.642] (==) NVIDIA(1): Silken mouse enabled
[ 370.642] (==) NVIDIA(1): DPMS enabled
[ 370.643] (II) Loading sub module "dri2"
[ 370.643] (II) LoadModule: "dri2"
[ 370.643] (II) Module "dri2" already built-in
[ 370.643] (II) NVIDIA(1): [DRI2] Setup complete
[ 370.643] (II) NVIDIA(1): [DRI2] VDPAU driver: nvidia
[ 370.643] (--) RandR disabled
[ 370.652] (II) SELinux: Disabled on system
[ 370.654] (II) Initializing extension GLX
[ 371.111] (II) Using input driver 'wacom' for 'stylus'
[ 371.111] (**) stylus: always reports core events
[ 371.111] (**) Option "Device" "/dev/ttyS0"
[ 371.111] (**) Option "Type" "stylus"
[ 371.111] (**) Option "StopBits" "1"
[ 371.111] (**) Option "DataBits" "8"
[ 371.111] (**) Option "Parity" "None"
[ 371.111] (**) Option "Vmin" "1"
[ 371.111] (**) Option "Vtime" "10"
[ 371.111] (**) Option "FlowControl" "Xoff"
[ 374.365] (WW) stylus: Waited too long for answer (failed after 3 tries).
[ 374.365] (WW) stylus: Query failed with 19200 baud. Trying 38400.
[ 377.619] (WW) stylus: Waited too long for answer (failed after 3 tries).
[ 377.619] (II) stylus: serial tablet id 0x90.
[ 377.619] (EE) PreInit returned 8 for "stylus"
[ 377.619] (II) UnloadModule: "wacom"
[ 377.620] (II) Using input driver 'wacom' for 'eraser'
[ 377.620] (**) eraser: always reports core events
[ 377.620] (**) Option "Device" "/dev/ttyS0"
[ 377.620] (**) Option "Type" "eraser"
[ 377.620] (**) Option "StopBits" "1"
[ 377.620] (**) Option "DataBits" "8"
[ 377.620] (**) Option "Parity" "None"
[ 377.620] (**) Option "Vmin" "1"
[ 377.620] (**) Option "Vtime" "10"
[ 377.620] (**) Option "FlowControl" "Xoff"
[ 377.620] (WW) eraser: TPCButton option can only be set by stylus.
[ 380.874] (WW) eraser: Waited too long for answer (failed after 3 tries).
[ 380.874] (WW) eraser: Query failed with 19200 baud. Trying 38400.
[ 384.128] (WW) eraser: Waited too long for answer (failed after 3 tries).
[ 384.128] (II) eraser: serial tablet id 0x90.
[ 384.128] (EE) PreInit returned 8 for "eraser"
[ 384.128] (II) UnloadModule: "wacom"
[ 384.128] (II) Using input driver 'wacom' for 'cursor'
[ 384.128] (**) cursor: always reports core events
[ 384.129] (**) Option "Device" "/dev/ttyS0"
[ 384.129] (**) Option "Type" "cursor"
[ 384.129] (**) Option "StopBits" "1"
[ 384.129] (**) Option "DataBits" "8"
[ 384.129] (**) Option "Parity" "None"
[ 384.129] (**) Option "Vmin" "1"
[ 384.129] (**) Option "Vtime" "10"
[ 384.129] (**) Option "FlowControl" "Xoff"
[ 384.129] (WW) cursor: TPCButton option can only be set by stylus.
[ 387.383] (WW) cursor: Waited too long for answer (failed after 3 tries).
[ 387.383] (WW) cursor: Query failed with 19200 baud. Trying 38400.
[ 390.637] (WW) cursor: Waited too long for answer (failed after 3 tries).
[ 390.637] (II) cursor: serial tablet id 0x90.
[ 390.637] (EE) PreInit returned 8 for "cursor"
[ 390.638] (II) UnloadModule: "wacom"
[ 390.640] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 390.641] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 390.641] (II) LoadModule: "evdev"
[ 390.641] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 390.665] (II) Module evdev: vendor="X.Org Foundation"
[ 390.665] compiled for 1.14.3, module version = 2.8.2
[ 390.665] Module class: X.Org XInput Driver
[ 390.665] ABI class: X.Org XInput driver, version 19.1
[ 390.665] (II) Using input driver 'evdev' for 'Power Button'
[ 390.665] (**) Power Button: always reports core events
[ 390.665] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 390.666] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 390.666] (--) evdev: Power Button: Found keys
[ 390.666] (II) evdev: Power Button: Configuring as keyboard
[ 390.666] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 390.666] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 390.666] (**) Option "xkb_rules" "evdev"
[ 390.666] (**) Option "xkb_model" "pc105"
[ 390.666] (**) Option "xkb_layout" "us"
[ 390.667] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 390.667] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 390.667] (II) Using input driver 'evdev' for 'Power Button'
[ 390.667] (**) Power Button: always reports core events
[ 390.667] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 390.667] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 390.667] (--) evdev: Power Button: Found keys
[ 390.667] (II) evdev: Power Button: Configuring as keyboard
[ 390.667] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2"
[ 390.667] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 390.667] (**) Option "xkb_rules" "evdev"
[ 390.667] (**) Option "xkb_model" "pc105"
[ 390.667] (**) Option "xkb_layout" "us"
[ 390.668] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 390.668] (II) No input driver specified, ignoring this device.
[ 390.668] (II) This device may have been added with another device file.
[ 390.669] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 390.669] (II) No input driver specified, ignoring this device.
[ 390.669] (II) This device may have been added with another device file.
[ 390.669] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[ 390.670] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event1)
[ 390.670] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 390.670] (II) Using input driver 'evdev' for 'Logitech USB-PS/2 Optical Mouse'
[ 390.670] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[ 390.670] (**) evdev: Logitech USB-PS/2 Optical Mouse: Device: "/dev/input/event1"
[ 390.670] (--) evdev: Logitech USB-PS/2 Optical Mouse: Vendor 0x46d Product 0xc03f
[ 390.670] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found 8 mouse buttons
[ 390.670] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
[ 390.670] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found relative axes
[ 390.670] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
[ 390.670] (II) evdev: Logitech USB-PS/2 Optical Mouse: Configuring as mouse
[ 390.670] (II) evdev: Logitech USB-PS/2 Optical Mouse: Adding scrollwheel support
[ 390.670] (**) evdev: Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
[ 390.670] (**) evdev: Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 390.670] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.1/usb6/6-3/6-3:1.0/input/input1/event1"
[ 390.670] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 8)
[ 390.670] (II) evdev: Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
[ 390.671] (**) Logitech USB-PS/2 Optical Mouse: (accel) keeping acceleration scheme 1
[ 390.671] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration profile 0
[ 390.671] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[ 390.671] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[ 390.672] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[ 390.672] (II) No input driver specified, ignoring this device.
[ 390.672] (II) This device may have been added with another device file.
[ 390.672] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event9)
[ 390.673] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event8)
[ 390.673] (II) No input driver specified, ignoring this device.
[ 390.673] (II) This device may have been added with another device file.
[ 390.673] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event7)
[ 390.673] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event6)
[ 390.674] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event5)
[ 390.674] (II) No input driver specified, ignoring this device.
[ 390.674] (II) This device may have been added with another device file.
[ 390.674] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 390.674] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 390.674] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 390.675] (**) AT Translated Set 2 keyboard: always reports core events
[ 390.675] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 390.675] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 390.675] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 390.675] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 390.675] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 390.675] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
[ 390.675] (**) Option "xkb_rules" "evdev"
[ 390.675] (**) Option "xkb_model" "pc105"
[ 390.675] (**) Option "xkb_layout" "us"
[ 390.676] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 390.676] (II) No input driver specified, ignoring this device.
[ 390.676] (II) This device may have been added with another device file.
[ 390.676] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event13)
[ 390.676] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[ 390.676] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[ 390.676] (**) ACPI Virtual Keyboard Device: always reports core events
[ 390.676] (**) evdev: ACPI Virtual Keyboard Device: Device: "/dev/input/event13"
[ 390.676] (--) evdev: ACPI Virtual Keyboard Device: Vendor 0 Product 0
[ 390.676] (--) evdev: ACPI Virtual Keyboard Device: Found keys
[ 390.676] (II) evdev: ACPI Virtual Keyboard Device: Configuring as keyboard
[ 390.676] (**) Option "config_info" "udev:/sys/devices/virtual/input/input13/event13"
[ 390.676] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 10)
[ 390.676] (**) Option "xkb_rules" "evdev"
[ 390.676] (**) Option "xkb_model" "pc105"
[ 390.676] (**) Option "xkb_layout" "us"
[ 392.824] (II) NVIDIA(GPU-0): Display (HP L1955 (DFP-1)) does not support NVIDIA 3D Vision
[ 392.824] (II) NVIDIA(GPU-0): stereo.
[ 392.829] (II) NVIDIA(GPU-0): Display (HP L1955 (DFP-2)) does not support NVIDIA 3D Vision
[ 392.829] (II) NVIDIA(GPU-0): stereo.
[ 392.832] (II) NVIDIA(1): Setting mode "DVI-D-1: nvidia-auto-select @1280x1024 +1280+0 {ViewPortIn=1280x1024, ViewPortOut=1280x1024+0+0}"
[ 393.050] (II) NVIDIA(GPU-0): Display (HP L1955 (DFP-1)) does not support NVIDIA 3D Vision
[ 393.050] (II) NVIDIA(GPU-0): stereo.
[ 393.056] (II) NVIDIA(GPU-0): Display (HP L1955 (DFP-2)) does not support NVIDIA 3D Vision
[ 393.056] (II) NVIDIA(GPU-0): stereo.
[ 393.059] (II) NVIDIA(1): Setting mode "NULL"
[ 393.139] (II) NVIDIA(1): Setting mode "DVI-D-1: nvidia-auto-select @1024x1280 +1024+0 {ViewPortIn=1024x1280, ViewPortOut=1280x1024+0+0, Rotation=90}"
[ 393.240] (II) NVIDIA(1): Setting mode "DVI-D-0: nvidia-auto-select @1024x1280 +0+0 {ViewPortIn=1024x1280, ViewPortOut=1280x1024+0+0, Rotation=90}, DVI-D-1: nvidia-auto-select @1024x1280 +1024+0 {ViewPortIn=1024x1280, ViewPortOut=1280x1024+0+0, Rotation=90}"
[ 3693.697] (WW) NVIDIA(1): WAIT (2, 8, 0x8000, 0x0000d360, 0x00001dc4)
[ 3700.697] (WW) NVIDIA(1): WAIT (1, 8, 0x8000, 0x0000d360, 0x00001dc4)
[ 3739.750] (WW) NVIDIA(1): WAIT (2, 8, 0x8000, 0x00003938, 0x00003d54)
[ 3745.410] (WW) NVIDIA(1): WAIT (0, 8, 0x8000, 0x00003d54, 0x00003d54)
[ 3840.368] (WW) NVIDIA(1): WAIT (2, 8, 0x8000, 0x00008d5c, 0x00009178)
[ 3846.154] (WW) NVIDIA(1): WAIT (0, 8, 0x8000, 0x00009178, 0x00009178)
[ 3850.429] (WW) NVIDIA(1): WAIT (2, 8, 0x8000, 0x000097b4, 0x00009bd0)
[ 3857.429] (WW) NVIDIA(1): WAIT (1, 8, 0x8000, 0x000097b4, 0x00009bd0)
[ 4047.324] (WW) NVIDIA(1): WAIT (2, 8, 0x8000, 0x00008dfc, 0x00008fa0)
[ 4054.324] (WW) NVIDIA(1): WAIT (1, 8, 0x8000, 0x00008dfc, 0x00008fa0)
(EE) [mi] EQ overflowing. Additional events will be discarded until existing events are processed.
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/X (xorg_backtrace+0x3d) [0x7fd968f47ccd]
(EE) 1: /usr/bin/X (mieqEnqueue+0x22b) [0x7fd968f29c2b]
(EE) 2: /usr/bin/X (QueuePointerEvents+0x52) [0x7fd968e11802]
(EE) 3: /usr/lib/xorg/modules/input/evdev_drv.so (0x7fd95ff6b000+0x571d) [0x7fd95ff7071d]
(EE) 4: /usr/bin/X (0x7fd968da6000+0x91ab8) [0x7fd968e37ab8]
(EE) 5: /usr/bin/X (0x7fd968da6000+0xb9fb0) [0x7fd968e5ffb0]
(EE) 6: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7fd967ea5000+0xf210) [0x7fd967eb4210]
(EE) 7: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x6149b) [0x7fd96194949b]
(EE) 8: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x62115) [0x7fd96194a115]
(EE) 9: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0xd8cbf) [0x7fd9619c0cbf]
(EE) 10: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50c980) [0x7fd961df4980]
(EE) 11: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50a055) [0x7fd961df2055]
(EE) 12: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50cbbd) [0x7fd961df4bbd]
(EE) 13: /usr/bin/X (0x7fd968da6000+0x1311fc) [0x7fd968ed71fc]
(EE) 14: /usr/bin/X (0x7fd968da6000+0xed5a1) [0x7fd968e935a1]
(EE) 15: /usr/bin/X (0x7fd968da6000+0xee35d) [0x7fd968e9435d]
(EE) 16: /usr/bin/X (0x7fd968da6000+0x5500e) [0x7fd968dfb00e]
(EE) 17: /usr/bin/X (0x7fd968da6000+0x4455a) [0x7fd968dea55a]
(EE) 18: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf5) [0x7fd966afe995]
(EE) 19: /usr/bin/X (0x7fd968da6000+0x4489f) [0x7fd968dea89f]
(EE)
(EE) [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
(EE) [mi] mieq is *NOT* the cause. It is a victim.
(EE) [mi] EQ overflow continuing. 100 events have been dropped.
(EE)
(EE) Backtrace:
(EE) 1: /usr/bin/X (QueuePointerEvents+0x52) [0x7fd968e11802]
(EE) 2: /usr/lib/xorg/modules/input/evdev_drv.so (0x7fd95ff6b000+0x571d) [0x7fd95ff7071d]
(EE) 3: /usr/bin/X (0x7fd968da6000+0x91ab8) [0x7fd968e37ab8]
(EE) 4: /usr/bin/X (0x7fd968da6000+0xb9fb0) [0x7fd968e5ffb0]
(EE) 5: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7fd967ea5000+0xf210) [0x7fd967eb4210]
(EE) 6: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x6149b) [0x7fd96194949b]
(EE) 7: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x62115) [0x7fd96194a115]
(EE) 8: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0xd8cbf) [0x7fd9619c0cbf]
(EE) 9: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50c980) [0x7fd961df4980]
(EE) 10: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50a055) [0x7fd961df2055]
(EE) 11: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fd9618e8000+0x50cbbd) [0x7fd961df4bbd]
(EE) 12: /usr/bin/X (0x7fd968da6000+0x1311fc) [0x7fd968ed71fc]
(EE) 13: /usr/bin/X (0x7fd968da6000+0xed5a1) [0x7fd968e935a1]
(EE) 14: /usr/bin/X (0x7fd968da6000+0xee35d) [0x7fd968e9435d]
(EE) 15: /usr/bin/X (0x7fd968da6000+0x5500e) [0x7fd968dfb00e]
(EE) 16: /usr/bin/X (0x7fd968da6000+0x4455a) [0x7fd968dea55a]
(EE) 17: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf5) [0x7fd966afe995]
(EE) 18: /usr/bin/X (0x7fd968da6000+0x4489f) [0x7fd968dea89f]
(EE)
(EE) [mi] EQ overflow continuing. 200 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 300 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 400 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 500 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 600 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 700 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 800 events have been dropped.
(EE)
(EE) Backtrace:
(EE) 2: /usr/bin/X (xf86PostButtonEvent+0xe5) [0x7fd968e477e5]
(EE) 3: /usr/lib/xorg/modules/input/evdev_drv.so (0x7fd95ff6b000+0x548e) [0x7fd95ff7048e]
(EE)
(EE) [mi] EQ overflow continuing. 900 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 1000 events have been dropped.
(EE) [mi] No further overflow reports will be reported until the clog is cleared.
(EE)
(EE) Backtrace:
(EE)
then I had to press Power Button to actually do anything as keyboard (PS/2) was frozen. Mouse (USB) continue to move but was useless otherwise.
