I have been happily running Nvidia drivers on my computers for years. A couple days ago I upgraded to 465.27 from 465.24.02 on my Lenovo P15 gen 1 running Fedora 34 x86_64. There was no kernel oops. Mostly just NVRM: Xid errors. The Gnome GUI would regularly freeze for a second, and it seemed to correspond to when the Xid errors occurred.
I downgraded back to 465.24.02 and it has been running without issue.
Graphics card: Quadro RTX 3000 Mobile / Max-Q
Dedicated graphic mode in the BIOS
01:00.0 VGA compatible controller: NVIDIA Corporation TU106GLM [Quadro RTX 3000 Mobile / Max-Q] (rev a1)
01:00.0 0300: 10de:1f36 (rev a1)
Monitors:
ASUS PG27AQ running at 4k@60hz
ASUS PB287Q running at 4k@60hz
CPU: Intel(R) Core™ i9-10885H CPU @ 2.40GHz
Kernel: 5.11.17-300.fc34.x86_64
Kernel command line: BOOT_IMAGE=(hd0,gpt5)/vmlinuz-5.11.17-300.fc34.x86_64 root=UUID=6def3c51-3470-45f5-b213-b9a3b960b753 ro rd.luks.uuid=luks-a6da79ac-2329-7bee-b310-ac3db4c2ec23 rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1
Xorg: xorg-x11-server-Xorg-1.20.11-1.fc34.x86_64
Drivers:
xorg-x11-drv-nvidia-465.24.02-4.fc34.x86_64
xorg-x11-drv-nvidia-465.27-1.fc34.x86_64
May 07 15:39:18 higgs kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 465.27 Thu Apr 22 23:12:47 UTC 2021
May 07 15:39:36 higgs kernel: NVRM: GPU at PCI:0000:01:00: GPU-ad86061b-ba06-d9e7-dca0-bddecb493f99
May 07 15:39:36 higgs kernel: NVRM: GPU Board Serial Number:
May 07 15:39:36 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11180, Channel 00000009
May 07 15:39:44 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11208, Channel 00000010
May 07 15:39:47 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:0:0:1088
May 07 15:39:49 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:2:0:1088
May 07 15:39:51 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:4:0:1088
May 07 15:39:53 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:0:0:1088
May 07 15:39:53 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11208, Channel 00000010
May 07 15:39:55 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:2:0:1088
May 07 15:39:57 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:4:0:1088
May 07 15:40:01 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:0:0:1088
May 07 15:40:03 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:2:0:1088
May 07 15:40:05 higgs kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c57e:4:0:1088
May 07 15:40:13 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11208, Channel 00000010
May 07 15:40:21 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11180, Channel 00000008
May 07 15:40:29 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=11180, Channel 00000008
May 07 15:40:37 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000019
May 07 15:40:45 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000020
May 07 15:40:54 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:41:03 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:41:12 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000019
May 07 15:41:20 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000018
May 07 15:41:28 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:41:40 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:41:49 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:41:57 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:06 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:15 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:23 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:31 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:39 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:47 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:42:55 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:43:05 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:43:13 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:43:21 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:43:29 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:43:37 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:43:46 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:43:54 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:44:04 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:44:12 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:44:20 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:44:29 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:44:37 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:44:45 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:44:53 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:01 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:10 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:18 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:26 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:34 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:45:42 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:45:51 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=19557, Channel 00000018
May 07 15:45:59 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=19784, Channel 00000018
May 07 15:46:07 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=19994, Channel 00000018
May 07 15:46:15 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:46:23 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:46:32 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:46:40 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:46:48 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:46:56 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:04 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:13 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:21 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:29 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:37 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:45 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:47:53 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:48:02 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:48:11 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:48:19 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:48:27 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:48:35 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:48:44 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:48:52 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:00 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:49:08 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:16 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:25 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:33 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:41 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:49 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:49:57 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:06 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:15 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:23 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:31 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:39 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:48 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:50:56 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=21076, Channel 00000018
May 07 15:51:04 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:51:12 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:51:20 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:51:29 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:51:38 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:51:46 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:51:54 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:52:02 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:52:10 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:52:19 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:52:27 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:52:35 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:52:43 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:52:51 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:00 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:08 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:16 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:24 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:53:32 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:41 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:49 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:53:57 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:05 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:13 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:22 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:30 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:38 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:46 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:54:54 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:55:03 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:55:11 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:55:19 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:55:27 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
May 07 15:55:35 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:55:45 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12025, Channel 00000011
May 07 15:55:53 higgs kernel: NVRM: Xid (PCI:0000:01:00): 8, pid=12151, Channel 00000008
