NVIDIA kernel module does not appear to be receiving interrupts generated by the NVIDIA GPU
i’ve a problem with the nvidia driver:
I have two linux systems: the systems have the same kernel version but in the second one I’ve recompiled the kernel. Graphic support modules configuration is the same in both systems.
The problem: in the first system the driver works;in the second one the server X doesn’t start.
Xorg.0.log:
[    29.755]
X.Org X Server 1.13.4
Release Date: 2013-04-17
[    29.755] X Protocol Version 11, Revision 0
[    29.755] Build Operating System: Linux 3.10.17-finx-rt12-generic x86_64 Gentoo
[    29.755] Current Operating System: Linux AW609_FINX2 3.10.17-xenomai #1 SMP PREEMPT Thu Apr 28 18:27:43 GMT 2016 x86_64
[    29.755] Kernel command line: real_root=/dev/sda3 rootfstype=ext4 vga=791  quiet
[    29.755] Build Date: 17 October 2014  11:44:06AM
[    29.755]
[    29.755] Current version of pixman: 0.28.0
[    29.755] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    29.755] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    29.755] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 29 10:24:32 2016
[    29.755] (==) Using config file: "/etc/X11/xorg.conf"
[    29.755] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    29.755] (==) ServerLayout "Layout0"
[    29.755] (**) |-->Screen "Screen0" (0)
[    29.755] (**) |   |-->Monitor "Monitor0"
[    29.755] (**) |   |-->Device "Device0"
[    29.755] (**) |-->Input Device "Keyboard0"
[    29.755] (**) |-->Input Device "Mouse0"
[    29.755] (**) Option "Xinerama" "0"
[    29.755] (==) Automatically adding devices
[    29.755] (==) Automatically enabling devices
[    29.755] (==) Automatically adding GPU devices
[    29.755] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/,
	/usr/share/fonts/OTF/,
	/usr/share/fonts/Type1/,
	/usr/share/fonts/100dpi/,
	/usr/share/fonts/75dpi/
[    29.755] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    29.755] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    29.755] (WW) Disabling Keyboard0
[    29.755] (WW) Disabling Mouse0
[    29.755] (II) Loader magic: 0x809c20
[    29.755] (II) Module ABI versions:
[    29.755] 	X.Org ANSI C Emulation: 0.4
[    29.755] 	X.Org Video Driver: 13.1
[    29.755] 	X.Org XInput driver : 18.0
[    29.755] 	X.Org Server Extension : 7.0
[    29.756] (II) config/udev: Adding drm device (/dev/dri/card0)
[    29.758] (--) PCI:*(0:2:0:0) 10de:0ff3:103c:1162 rev 161, Mem @ 0xf1000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x????????/524288
[    29.758] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    29.758] Initializing built-in extension Generic Event Extension
[    29.758] Initializing built-in extension SHAPE
[    29.758] Initializing built-in extension MIT-SHM
[    29.758] Initializing built-in extension XInputExtension
[    29.758] Initializing built-in extension XTEST
[    29.758] Initializing built-in extension BIG-REQUESTS
[    29.758] Initializing built-in extension SYNC
[    29.758] Initializing built-in extension XKEYBOARD
[    29.758] Initializing built-in extension XC-MISC
[    29.758] Initializing built-in extension XINERAMA
[    29.758] Initializing built-in extension XFIXES
[    29.758] Initializing built-in extension RENDER
[    29.758] Initializing built-in extension RANDR
[    29.758] Initializing built-in extension COMPOSITE
[    29.758] Initializing built-in extension DAMAGE
[    29.758] Initializing built-in extension MIT-SCREEN-SAVER
[    29.758] Initializing built-in extension DOUBLE-BUFFER
[    29.758] Initializing built-in extension RECORD
[    29.758] Initializing built-in extension DPMS
[    29.758] Initializing built-in extension X-Resource
[    29.758] Initializing built-in extension XVideo
[    29.758] Initializing built-in extension XVideo-MotionCompensation
[    29.758] Initializing built-in extension XFree86-VidModeExtension
[    29.758] Initializing built-in extension XFree86-DGA
[    29.758] Initializing built-in extension XFree86-DRI
[    29.758] Initializing built-in extension DRI2
[    29.758] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[    29.758] (II) LoadModule: "glx"
[    29.758] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    29.767] (II) Module glx: vendor="NVIDIA Corporation"
[    29.767] 	compiled for 4.0.2, module version = 1.0.0
[    29.767] 	Module class: X.Org Server Extension
[    29.767] (II) NVIDIA GLX Module  325.15  Wed Jul 31 18:12:00 PDT 2013
[    29.767] Loading extension GLX
[    29.767] (II) LoadModule: "nvidia"
[    29.767] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[    29.768] (II) Module nvidia: vendor="NVIDIA Corporation"
[    29.768] 	compiled for 4.0.2, module version = 1.0.0
[    29.768] 	Module class: X.Org Video Driver
[    29.768] (II) NVIDIA dlloader X Driver  325.15  Wed Jul 31 17:50:57 PDT 2013
[    29.768] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    29.768] (++) using VT number 7
[    29.811] (II) Loading sub module "fb"
[    29.811] (II) LoadModule: "fb"
[    29.811] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    29.812] (II) Module fb: vendor="X.Org Foundation"
[    29.812] 	compiled for 1.13.4, module version = 1.0.0
[    29.812] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    29.812] (WW) Unresolved symbol: fbGetGCPrivateKey
[    29.812] (II) Loading sub module "wfb"
[    29.812] (II) LoadModule: "wfb"
[    29.812] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[    29.812] (II) Module wfb: vendor="X.Org Foundation"
[    29.812] (II) Loading sub module "shadow"
[    29.812] (II) LoadModule: "shadow"
[    29.812] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[    29.812] (II) Module shadow: vendor="X.Org Foundation"
[    29.812] 	compiled for 1.13.4, module version = 1.1.0
[    29.812] (II) Loading sub module "ramdac"
[    29.812] (II) LoadModule: "ramdac"
[    29.812] (II) Module "ramdac" already built-in
[    29.812] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    29.812] (==) NVIDIA(0): RGB weight 888
[    29.812] (==) NVIDIA(0): Default visual is TrueColor
[    29.812] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    29.812] (**) NVIDIA(0): Enabling 2D acceleration
[    34.214] (EE) NVIDIA(0): The NVIDIA kernel module does not appear to be receiving
[    34.214] (EE) NVIDIA(0):     interrupts generated by the NVIDIA GPU at PCI:2:0:0.
[    34.214] (EE) NVIDIA(0):     Please see Chapter 8: Common Problems in the README for
[    34.214] (EE) NVIDIA(0):     additional information.
[    34.214] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device!
[    34.214] (EE) NVIDIA(0): Failing initialization of X screen 0
[    34.214] (II) UnloadModule: "nvidia"
[    34.214] (II) UnloadSubModule: "shadow"
[    34.214] (II) UnloadSubModule: "wfb"
[    34.214] (II) UnloadSubModule: "fb"
[    34.214] (EE) Screen(s) found, but none have a usable configuration.
[    34.214]
Fatal server error:
[    34.214] no screens found
[    34.214] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    34.214] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    34.214] (EE)
[    34.257] Server terminated with error (1). Closing log file.
xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 361.42  (buildmeister@swio-display-x64-rhel04-13)  Tue Mar 22 18:37:28 PDT 2016
Section "ServerLayout"
    #Option	   "AllowEmptyInput" "off"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    #Option	   "AutoAddDevices" "off"
EndSection
Section "Module"
#	Load	"dbe"
#	Load	"extmod"
#	Load	"type1"
#	Load	"freetype"
#	Load	"dri"
#	Load	"dri2"
#	Load	"record"
#	Load	"randr"
#       Load    "glx"
#       Load    "dri"
#       Load    "dri2"
#       Load    "glx"
    Load           "glx"
EndSection
Section "InputDevice"
    #Driver         "vmmouse"
    #Driver         "evdev"
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    #Driver         "evdev"
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "InputClass"
    Identifier         "Keyboard0_options"
    Option         "XkbLayout" "it"
EndSection
Section "Monitor"
    #HorizSync       30.0 - 83.0
    #VertRefresh     56.0 - 76.0
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Monitor"
EndSection
Section "Device"
    #Driver         "vboxvideo"
    #Driver         "vmware"
    Identifier     "Device0"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
	#Modes	    "1920x1080" "1600x1200" "1280x1024" "1024x768" "800x600" "640x480"
        Depth       24
    EndSubSection
        Depth       16
    EndSubSection
EndSection
Anyone can help me?
Thanks in advance
Maurizio
After recompiling your kernel, you have even recompiled the nvidia kernel-module?
It doesn’t seem so from your X-log.
Why don’t you see README?
It’s available at
http://http.download.nvidia.com/XFree86/Linux-x86_64/325.15/README/commonproblems.html
I have the same issue with my PCI GT610 card.
I have old motherboard with 4 PCI slots, internal videocard and external PCI Nvidia card Geforce GT610.
With 375.26 and 340 legacy drivers I have the same issue -
[1787075.089] (EE) NVIDIA(GPU-0):     interrupts generated by the NVIDIA GPU at PCI:2:0:0.
no any interrupts for nvidia card ??
here is dmesg
http://paste.ubuntu.com/23740078/
my configuration is
amibios - 08.00.09 build date 09.30.05
cpu amd sempron 2800+ 1600 MHz
in bios I have choice Primary Graphics Adapter - PCI
motheboard based on chipset VIA VT8237
In Chapter 8. Common Problems I read about some advice
  • to use “NVreg_EnableMSI=0” option for nvidia module. I created nvidia.conf file in /storage/.config/modprobe.d and added the line options nvidia NVreg_EnableMSI=0. But it didn’t help. I still have the same issue with X starting.
Next solution from Nvidia is to use several boot kernel options for grub or LILO as
pci=noacpi don’t use ACPI for PCI IRQ routing
pci=biosirq use PCI BIOS calls to retrieve the IRQ routing table
noapic don’t use I/O APICs present in the system
acpi=off disable ACPI
I also tried several options, they didn’t help
Also I have put in different PCI slots my PCI card - didn’t help - I tried so with 375 driver
Is there any other advice ? Which nvidia driver is more appropriate for my configuration with PCI GT610 ?
I could manage to start X with legacy 304.134 drivers, but why with current NON legacy drivers I have issue described above ?
