Hi guys,
My computer has randomly decided to stop running the X server for reasons that I don’t understand. I am running Fedora 20 and use the kmod-nvidia package from yum to update my graphics driver.
This problem wasn’t due to an update, or anything else I can work out. I simply started up Linux one day, and this started happening. I have since done a full yum update in which the kernel and nvidia drivers were updated, and reinstalled the kmod-nvidia and xorg-x11-drv-nvidia packages, and manually installed the latest driver from the website instead, all to no avail.
I have been quite good at solving these problems in the past, but now it seems to me that it’s well beyond my abilities to work out what’s happening. Basically, when I am in multi-user mode/runlevel 3 and run startx, the screen is black for about 3 seconds, at which point I am then returned to the command-line with no error, just messages saying that the X server has quit. Here is Xorg.0.log:
[ 35.881]
X.Org X Server 1.14.4
Release Date: 2013-10-31
[ 35.881] X Protocol Version 11, Revision 0
[ 35.881] Build Operating System: 3.10.9-200.fc19.x86_64
[ 35.881] Current Operating System: Linux localhost.home 3.12.9-301.fc20.x86_64 #1 SMP Wed Jan 29 15:56:22 UTC 2014 x86_64
[ 35.881] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.12.9-301.fc20.x86_64 root=UUID=961c959a-639d-4a78-9689-963ab6392387 ro vconsole.font=latarcyrheb-sun16 nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:off quiet 3
[ 35.883] Build Date: 21 November 2013 05:45:23AM
[ 35.883] Build ID: xorg-x11-server 1.14.4-5.fc20
[ 35.883] Current version of pixman: 0.30.0
[ 35.884] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 35.884] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 35.885] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 4 09:14:29 2014
[ 35.903] (==) Using config file: "/etc/X11/xorg.conf"
[ 35.903] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 35.904] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 35.945] (==) ServerLayout "Layout0"
[ 35.945] (**) |-->Screen "Screen0" (0)
[ 35.945] (**) | |-->Monitor "Monitor0"
[ 35.959] (**) | |-->Device "Device0"
[ 35.959] (**) |-->Input Device "Keyboard0"
[ 35.959] (**) |-->Input Device "Mouse0"
[ 35.959] (==) Automatically adding devices
[ 35.959] (==) Automatically enabling devices
[ 35.959] (==) Automatically adding GPU devices
[ 35.987] (**) FontPath set to:
/usr/share/fonts/default/Type1,
catalogue:/etc/X11/fontpath.d,
built-ins
[ 35.987] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 35.987] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 35.987] (WW) Disabling Keyboard0
[ 35.987] (WW) Disabling Mouse0
[ 35.987] (II) Loader magic: 0x80dd00
[ 35.987] (II) Module ABI versions:
[ 35.987] X.Org ANSI C Emulation: 0.4
[ 35.987] X.Org Video Driver: 14.1
[ 35.987] X.Org XInput driver : 19.2
[ 35.987] X.Org Server Extension : 7.0
[ 35.987] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 35.988] (--) PCI:*(0:6:0:0) 10de:0e22:0000:0000 rev 161, Mem @ 0xfc000000/33554432, 0xd0000000/134217728, 0xd8000000/67108864, I/O @ 0x0000c000/128, BIOS @ 0x????????/524288
[ 36.000] Initializing built-in extension Generic Event Extension
[ 36.000] Initializing built-in extension SHAPE
[ 36.000] Initializing built-in extension MIT-SHM
[ 36.000] Initializing built-in extension XInputExtension
[ 36.000] Initializing built-in extension XTEST
[ 36.001] Initializing built-in extension BIG-REQUESTS
[ 36.001] Initializing built-in extension SYNC
[ 36.001] Initializing built-in extension XKEYBOARD
[ 36.001] Initializing built-in extension XC-MISC
[ 36.002] Initializing built-in extension XINERAMA
[ 36.002] Initializing built-in extension XFIXES
[ 36.002] Initializing built-in extension RENDER
[ 36.003] Initializing built-in extension RANDR
[ 36.003] Initializing built-in extension COMPOSITE
[ 36.003] Initializing built-in extension DAMAGE
[ 36.003] Initializing built-in extension MIT-SCREEN-SAVER
[ 36.004] Initializing built-in extension DOUBLE-BUFFER
[ 36.004] Initializing built-in extension RECORD
[ 36.004] Initializing built-in extension DPMS
[ 36.005] Initializing built-in extension X-Resource
[ 36.005] Initializing built-in extension XVideo
[ 36.005] Initializing built-in extension XVideo-MotionCompensation
[ 36.005] Initializing built-in extension SELinux
[ 36.006] Initializing built-in extension XFree86-VidModeExtension
[ 36.006] Initializing built-in extension XFree86-DGA
[ 36.006] Initializing built-in extension XFree86-DRI
[ 36.006] Initializing built-in extension DRI2
[ 36.006] (II) "glx" will be loaded by default.
[ 36.006] (WW) "xwayland" is not to be loaded by default. Skipping.
[ 36.006] (II) LoadModule: "dri2"
[ 36.007] (II) Module "dri2" already built-in
[ 36.007] (II) LoadModule: "glamoregl"
[ 36.035] (WW) Warning, couldn't open module glamoregl
[ 36.035] (II) UnloadModule: "glamoregl"
[ 36.035] (II) Unloading glamoregl
[ 36.035] (EE) Failed to load module "glamoregl" (module does not exist, 0)
[ 36.035] (II) LoadModule: "glx"
[ 36.035] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 37.056] (II) Module glx: vendor="NVIDIA Corporation"
[ 37.056] compiled for 4.0.2, module version = 1.0.0
[ 37.056] Module class: X.Org Server Extension
[ 37.056] (II) NVIDIA GLX Module 331.38 Wed Jan 8 19:10:17 PST 2014
[ 37.062] Loading extension GLX
[ 37.062] (II) LoadModule: "nvidia"
[ 37.062] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 37.176] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 37.176] compiled for 4.0.2, module version = 1.0.0
[ 37.176] Module class: X.Org Video Driver
[ 37.183] (II) NVIDIA dlloader X Driver 331.38 Wed Jan 8 18:51:00 PST 2014
[ 37.183] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 37.184] (++) using VT number 1
[ 37.192] (II) Loading sub module "fb"
[ 37.192] (II) LoadModule: "fb"
[ 37.192] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 37.203] (II) Module fb: vendor="X.Org Foundation"
[ 37.203] compiled for 1.14.4, module version = 1.0.0
[ 37.203] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37.203] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 37.203] (II) Loading sub module "wfb"
[ 37.203] (II) LoadModule: "wfb"
[ 37.203] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 37.210] (II) Module wfb: vendor="X.Org Foundation"
[ 37.210] compiled for 1.14.4, module version = 1.0.0
[ 37.210] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37.210] (II) Loading sub module "ramdac"
[ 37.210] (II) LoadModule: "ramdac"
[ 37.210] (II) Module "ramdac" already built-in
[ 37.218] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 37.218] (==) NVIDIA(0): RGB weight 888
[ 37.218] (==) NVIDIA(0): Default visual is TrueColor
[ 37.218] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 37.218] (**) NVIDIA(0): Enabling 2D acceleration
[ 38.088] (II) NVIDIA(0): Display (ViewSonic VX2753 SERIES (CRT-1)) does not support
[ 38.088] (II) NVIDIA(0): NVIDIA 3D Vision stereo.
[ 38.088] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[ 38.088] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 460 (GF104) at PCI:6:0:0 (GPU-0)
[ 38.088] (--) NVIDIA(0): Memory: 786432 kBytes
[ 38.088] (--) NVIDIA(0): VideoBIOS: 70.04.0b.00.01
[ 38.088] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 38.090] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 460 at PCI:6:0:0
[ 38.090] (--) NVIDIA(0): CRT-0
[ 38.090] (--) NVIDIA(0): ViewSonic VX2753 SERIES (CRT-1) (boot, connected)
[ 38.090] (--) NVIDIA(0): DFP-0
[ 38.090] (--) NVIDIA(0): DFP-1
[ 38.090] (--) NVIDIA(0): CRT-0: 480.0 MHz maximum pixel clock
[ 38.090] (--) NVIDIA(0): ViewSonic VX2753 SERIES (CRT-1): 400.0 MHz maximum pixel clock
[ 38.090] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 38.090] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 38.090] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 38.090] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 38.090] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 38.090] (**) NVIDIA(0): device ViewSonic VX2753 SERIES (CRT-1) (Using EDID
[ 38.090] (**) NVIDIA(0): frequencies has been enabled on all display devices.)
[ 38.091] (==) NVIDIA(0):
[ 38.091] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 38.091] (==) NVIDIA(0): will be used as the requested mode.
[ 38.091] (II) NVIDIA(0): Validated MetaModes:
[ 38.091] (II) NVIDIA(0): "CRT-1:nvidia-auto-select"
[ 38.091] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 38.119] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[ 38.119] (--) NVIDIA(0): option
[ 38.119] (--) Depth 24 pixmap format is 32 bpp
[ 38.119] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 38.119] (II) NVIDIA: access.
[ 38.121] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 38.121] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 38.121] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 38.122] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 38.122] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 38.122] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 38.122] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 38.122] (II) NVIDIA(0): Config Options in the README.
[ 38.123] (II) NVIDIA(0): Setting mode "CRT-1:nvidia-auto-select"
[ 38.175] Loading extension NV-GLX
[ 38.231] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 38.231] (==) NVIDIA(0): Backing store disabled
[ 38.231] (==) NVIDIA(0): Silken mouse enabled
[ 38.232] (**) NVIDIA(0): DPMS enabled
[ 38.232] Loading extension NV-CONTROL
[ 38.232] Loading extension XINERAMA
[ 38.232] (II) Loading sub module "dri2"
[ 38.232] (II) LoadModule: "dri2"
[ 38.232] (II) Module "dri2" already built-in
[ 38.232] (II) NVIDIA(0): [DRI2] Setup complete
[ 38.232] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 38.232] (--) RandR disabled
[ 38.237] (II) SELinux: Disabled on system
[ 38.237] (II) Initializing extension GLX
[ 38.607] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 38.607] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 38.607] (**) Power Button: Applying InputClass "system-keyboard"
[ 38.607] (II) LoadModule: "evdev"
[ 38.607] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 38.632] (II) Module evdev: vendor="X.Org Foundation"
[ 38.632] compiled for 1.14.3, module version = 2.8.2
[ 38.632] Module class: X.Org XInput Driver
[ 38.632] ABI class: X.Org XInput driver, version 19.2
[ 38.632] (II) Using input driver 'evdev' for 'Power Button'
[ 38.632] (**) Power Button: always reports core events
[ 38.632] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 38.632] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 38.632] (--) evdev: Power Button: Found keys
[ 38.632] (II) evdev: Power Button: Configuring as keyboard
[ 38.632] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 38.632] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 38.632] (**) Option "xkb_rules" "evdev"
[ 38.632] (**) Option "xkb_model" "pc104"
[ 38.632] (**) Option "xkb_layout" "gb"
[ 38.658] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 38.658] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 38.658] (**) Power Button: Applying InputClass "system-keyboard"
[ 38.658] (II) Using input driver 'evdev' for 'Power Button'
[ 38.658] (**) Power Button: always reports core events
[ 38.658] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 38.658] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 38.658] (--) evdev: Power Button: Found keys
[ 38.658] (II) evdev: Power Button: Configuring as keyboard
[ 38.658] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[ 38.658] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 38.658] (**) Option "xkb_rules" "evdev"
[ 38.658] (**) Option "xkb_model" "pc104"
[ 38.658] (**) Option "xkb_layout" "gb"
[ 38.658] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 38.658] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
[ 38.658] (II) No input driver specified, ignoring this device.
[ 38.658] (II) This device may have been added with another device file.
[ 38.658] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 38.659] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 38.659] (II) No input driver specified, ignoring this device.
[ 38.659] (II) This device may have been added with another device file.
[ 38.659] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 38.659] (II) config/udev: Adding input device DATACOMP SteelS쀁̄Љ̒DATA (/dev/input/event2)
[ 38.659] (**) DATACOMP SteelS쀁̄Љ̒DATA: Applying InputClass "evdev keyboard catchall"
[ 38.659] (**) DATACOMP SteelS쀁̄Љ̒DATA: Applying InputClass "system-keyboard"
[ 38.659] (II) Using input driver 'evdev' for 'DATACOMP SteelS쀁̄Љ̒DATA'
[ 38.659] (**) DATACOMP SteelS쀁̄Љ̒DATA: always reports core events
[ 38.659] (**) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Device: "/dev/input/event2"
[ 38.659] (--) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Vendor 0x4b4 Product 0x101
[ 38.659] (--) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Found keys
[ 38.659] (II) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Configuring as keyboard
[ 38.659] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb4/4-4/4-4:1.0/input/input5/event2"
[ 38.659] (II) XINPUT: Adding extended input device "DATACOMP SteelS쀁̄Љ̒DATA" (type: KEYBOARD, id 8)
[ 38.659] (**) Option "xkb_rules" "evdev"
[ 38.659] (**) Option "xkb_model" "pc104"
[ 38.659] (**) Option "xkb_layout" "gb"
[ 38.659] (II) config/udev: Adding input device DATACOMP SteelS쀁̄Љ̒DATA (/dev/input/event3)
[ 38.659] (**) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Device: "/dev/input/event3"
[ 38.659] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb4/4-4/4-4:1.1/input/input6/event3"
[ 38.659] (II) XINPUT: Adding extended input device "DATACOMP SteelS쀁̄Љ̒DATA" (type: KEYBOARD, id 9)
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event10)
[ 38.660] (II) No input driver specified, ignoring this device.
[ 38.660] (II) This device may have been added with another device file.
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Line Out Front (/dev/input/event9)
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Line Out Surround (/dev/input/event8)
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Line Out CLFE (/dev/input/event7)
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Line Out Side (/dev/input/event6)
[ 38.660] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event5)
[ 38.661] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event12)
[ 38.661] (II) No input driver specified, ignoring this device.
[ 38.661] (II) This device may have been added with another device file.
[ 38.661] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event11)
[ 38.661] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event4)
[ 38.661] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 38.661] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 38.661] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[ 38.661] (**) Eee PC WMI hotkeys: always reports core events
[ 38.661] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event4"
[ 38.661] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 38.661] (--) evdev: Eee PC WMI hotkeys: Found keys
[ 38.661] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 38.661] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input7/event4"
[ 38.661] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 10)
[ 38.661] (**) Option "xkb_rules" "evdev"
[ 38.661] (**) Option "xkb_model" "pc104"
[ 38.661] (**) Option "xkb_layout" "gb"
[ 39.668] (II) evdev: Eee PC WMI hotkeys: Close
[ 39.668] (II) UnloadModule: "evdev"
[ 39.668] (II) evdev: DATACOMP SteelS쀁̄Љ̒DATA: Close
[ 39.668] (II) evdev: Power Button: Close
[ 39.917] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 39.919] (EE) Server terminated successfully (0). Closing log file.
The only detail of significance that I’ve found is in the tail of dmesg:
[ 17.463571] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 17.463573] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.463574] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.463575] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 17.463576] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.463578] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 19.455628] IPv6: ADDRCONF(NETDEV_UP): p32p1: link is not ready
[ 23.125215] e1000e: p32p1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 23.125533] IPv6: ADDRCONF(NETDEV_CHANGE): p32p1: link becomes ready
[ 36.958418] nvidia 0000:06:00.0: irq 93 for MSI/MSI-X
A quick Google of “IRQ 93 for MSI/MSI-X” came up with nothing at all, so I don’t know what to make of this if it isn’t a hardware error, however I’m still perfectly fine playing games on my Windows dual-boot. It seems completely stable.
If you need any more information, please let me know. Thanks!
EDIT:
There is actually something of significance that has happened that I’ve just thought of, I cleaned my computer out. Basically, I get a vacuum cleaner and a can of compressed air and remove dust from heatsinks, fans and filters. I don’t spray onto circuit boards because, AFAIK, fast-moving air can cause static to build up.
I’d be surprised if I have damaged the graphics card, as I can run a FurMark stress test and it seems stable. The temperature reaches a max of 78 Celsius. Any ideas?
nvidia-bug-report.log.gz (94.5 KB)
