[ 5.793]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 5.793] X Protocol Version 11, Revision 0
[ 5.793] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
[ 5.793] Current Operating System: Linux caper-tgs-v2 4.15.0-58-generic #64~16.04.1-Ubuntu SMP Wed Aug 7 14:10:35 UTC 2019 x86_64
[ 5.793] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-58-generic root=UUID=94114c0d-0dcd-4c17-8435-6e1f76d15c9c ro quiet splash vt.handoff=7
[ 5.793] Build Date: 25 October 2018 04:13:49PM
[ 5.793] xorg-server 2:1.19.6-1ubuntu4.1~16.04.2 (For technical support please see http://www.ubuntu.com/support)
[ 5.793] Current version of pixman: 0.33.6
[ 5.793] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 5.793] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 5.793] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 27 15:49:56 2019
[ 5.794] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.794] (==) No Layout section. Using the first Screen section.
[ 5.794] (==) No screen section available. Using defaults.
[ 5.794] (**) |-->Screen "Default Screen Section" (0)
[ 5.795] (**) | |-->Monitor "<default monitor>"
[ 5.795] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 5.795] (==) Automatically adding devices
[ 5.795] (==) Automatically enabling devices
[ 5.795] (==) Automatically adding GPU devices
[ 5.795] (==) Automatically binding GPU devices
[ 5.795] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.796] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 5.796] Entry deleted from font path.
[ 5.796] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 5.796] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 5.797] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 5.797] Entry deleted from font path.
[ 5.797] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 5.797] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 5.797] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 5.797] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 5.797] (II) Loader magic: 0x55a3eaadae00
[ 5.797] (II) Module ABI versions:
[ 5.797] X.Org ANSI C Emulation: 0.4
[ 5.797] X.Org Video Driver: 23.0
[ 5.797] X.Org XInput driver : 24.1
[ 5.797] X.Org Server Extension : 10.0
[ 5.797] (++) using VT number 7
[ 5.797] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.797] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.797] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 5.797] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 5.801] (--) PCI: (0:23:0:0) 10de:1b06:1462:3609 rev 161, Mem @ 0x95000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00007000/128, BIOS @ 0x????????/524288
[ 5.801] (--) PCI:*(0:101:0:0) 10de:1b06:1462:3609 rev 161, Mem @ 0xd7000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x????????/131072
[ 5.801] (--) PCI: (0:102:0:0) 10de:1b06:1462:3609 rev 161, Mem @ 0xd5000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x0000a000/128, BIOS @ 0x????????/524288
[ 5.801] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 5.801] (II) "glx" will be loaded by default.
[ 5.801] (II) LoadModule: "glx"
[ 5.801] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.923] (II) Module glx: vendor="X.Org Foundation"
[ 5.923] compiled for 1.19.6, module version = 1.0.0
[ 5.923] ABI class: X.Org Server Extension, version 10.0
[ 5.923] (==) Matched nvidia as autoconfigured driver 0
[ 5.923] (==) Matched nouveau as autoconfigured driver 1
[ 5.923] (==) Matched nvidia as autoconfigured driver 2
[ 5.923] (==) Matched nouveau as autoconfigured driver 3
[ 5.923] (==) Matched nvidia as autoconfigured driver 4
[ 5.923] (==) Matched nouveau as autoconfigured driver 5
[ 5.923] (==) Matched nvidia as autoconfigured driver 6
[ 5.923] (==) Matched nouveau as autoconfigured driver 7
[ 5.923] (==) Matched modesetting as autoconfigured driver 8
[ 5.923] (==) Matched fbdev as autoconfigured driver 9
[ 5.923] (==) Matched vesa as autoconfigured driver 10
[ 5.923] (==) Assigned the driver to the xf86ConfigLayout
[ 5.923] (II) LoadModule: "nvidia"
[ 5.923] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 5.927] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 5.927] compiled for 1.6.99.901, module version = 1.0.0
[ 5.927] Module class: X.Org Video Driver
[ 5.928] (II) LoadModule: "nouveau"
[ 5.928] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 5.929] (II) Module nouveau: vendor="X.Org Foundation"
[ 5.929] compiled for 1.19.5, module version = 1.0.15
[ 5.929] Module class: X.Org Video Driver
[ 5.929] ABI class: X.Org Video Driver, version 23.0
[ 5.929] (II) LoadModule: "modesetting"
[ 5.929] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 5.930] (II) Module modesetting: vendor="X.Org Foundation"
[ 5.930] compiled for 1.19.6, module version = 1.19.6
[ 5.930] Module class: X.Org Video Driver
[ 5.930] ABI class: X.Org Video Driver, version 23.0
[ 5.930] (II) LoadModule: "fbdev"
[ 5.930] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 5.931] (II) Module fbdev: vendor="X.Org Foundation"
[ 5.931] compiled for 1.19.3, module version = 0.4.4
[ 5.931] Module class: X.Org Video Driver
[ 5.931] ABI class: X.Org Video Driver, version 23.0
[ 5.931] (II) LoadModule: "vesa"
[ 5.931] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 5.932] (II) Module vesa: vendor="X.Org Foundation"
[ 5.932] compiled for 1.19.3, module version = 2.3.4
[ 5.932] Module class: X.Org Video Driver
[ 5.932] ABI class: X.Org Video Driver, version 23.0
[ 5.933] (II) NVIDIA dlloader X Driver 430.26 Tue Jun 4 17:52:10 CDT 2019
[ 5.933] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5.933] (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
[ 5.933] (II) NOUVEAU driver for NVIDIA chipset families :
[ 5.933] RIVA TNT (NV04)
[ 5.933] RIVA TNT2 (NV05)
[ 5.933] GeForce 256 (NV10)
[ 5.933] GeForce 2 (NV11, NV15)
[ 5.933] GeForce 4MX (NV17, NV18)
[ 5.933] GeForce 3 (NV20)
[ 5.933] GeForce 4Ti (NV25, NV28)
[ 5.933] GeForce FX (NV3x)
[ 5.933] GeForce 6 (NV4x)
[ 5.933] GeForce 7 (G7x)
[ 5.933] GeForce 8 (G8x)
[ 5.933] GeForce GTX 200 (NVA0)
[ 5.933] GeForce GTX 400 (NVC0)
[ 5.933] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5.933] (II) FBDEV: driver for framebuffer: fbdev
[ 5.933] (II) VESA: driver for VESA chipsets: vesa
[ 5.933] (II) Loading sub module "fb"
[ 5.934] (II) LoadModule: "fb"
[ 5.934] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 5.935] (II) Module fb: vendor="X.Org Foundation"
[ 5.935] compiled for 1.19.6, module version = 1.0.0
[ 5.935] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.935] (II) Loading sub module "wfb"
[ 5.935] (II) LoadModule: "wfb"
[ 5.935] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5.936] (II) Module wfb: vendor="X.Org Foundation"
[ 5.936] compiled for 1.19.6, module version = 1.0.0
[ 5.936] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.936] (II) Loading sub module "ramdac"
[ 5.936] (II) LoadModule: "ramdac"
[ 5.936] (II) Module "ramdac" already built-in
[ 6.728] (EE) [drm] Failed to open DRM device for (null): -2
[ 6.728] (WW) Falling back to old probe method for modesetting
[ 6.728] (WW) Falling back to old probe method for fbdev
[ 6.728] (II) Loading sub module "fbdevhw"
[ 6.728] (II) LoadModule: "fbdevhw"
[ 6.729] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 6.730] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 6.730] compiled for 1.19.6, module version = 0.0.2
[ 6.730] ABI class: X.Org Video Driver, version 23.0
[ 6.730] (WW) Falling back to old probe method for vesa
[ 6.730] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 6.730] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 6.730] (==) NVIDIA(0): RGB weight 888
[ 6.730] (==) NVIDIA(0): Default visual is TrueColor
[ 6.730] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.730] (**) NVIDIA(0): Enabling 2D acceleration
[ 6.730] (II) Loading sub module "glxserver_nvidia"
[ 6.730] (II) LoadModule: "glxserver_nvidia"
[ 6.730] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglxserver_nvidia.so
[ 6.761] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 6.761] compiled for 1.6.99.901, module version = 1.0.0
[ 6.761] Module class: X.Org Server Extension
[ 6.761] (II) NVIDIA GLX Module 430.26 Tue Jun 4 17:50:01 CDT 2019
[ 6.874] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:101:0:0
[ 6.874] (--) NVIDIA(0): DFP-0 (boot)
[ 6.874] (--) NVIDIA(0): DFP-1
[ 6.874] (--) NVIDIA(0): DFP-2
[ 6.874] (--) NVIDIA(0): DFP-3
[ 6.874] (--) NVIDIA(0): DFP-4
[ 6.874] (--) NVIDIA(0): DFP-5
[ 6.874] (--) NVIDIA(0): DFP-6
[ 6.876] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:101:0:0
[ 6.876] (II) NVIDIA(0): (GPU-0)
[ 6.876] (--) NVIDIA(0): Memory: 11534336 kBytes
[ 6.876] (--) NVIDIA(0): VideoBIOS: 86.02.39.40.63
[ 6.876] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 6.905] (--) NVIDIA(GPU-0): Acer ET241Y (DFP-0): connected
[ 6.905] (--) NVIDIA(GPU-0): Acer ET241Y (DFP-0): Internal TMDS
[ 6.905] (--) NVIDIA(GPU-0): Acer ET241Y (DFP-0): 600.0 MHz maximum pixel clock
[ 6.905] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 6.905] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 6.905] (--) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 6.905] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 6.905] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 6.905] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 6.905] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 6.905] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 6.905] (--) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 6.906] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 6.906] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 6.906] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 6.906] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 6.906] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 6.906] (--) NVIDIA(GPU-0): DFP-5: 1440.0 MHz maximum pixel clock
[ 6.906] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 6.906] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 6.906] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 6.909] (==) NVIDIA(0):
[ 6.909] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 6.909] (==) NVIDIA(0): will be used as the requested mode.
[ 6.910] (II) NVIDIA(0): Validated MetaModes:
[ 6.910] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 6.910] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 6.913] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 6.913] (--) NVIDIA(0): option
[ 6.913] (II) UnloadModule: "fbdev"
[ 6.913] (II) Unloading fbdev
[ 6.913] (II) UnloadSubModule: "fbdevhw"
[ 6.913] (II) Unloading fbdevhw
[ 6.913] (II) UnloadModule: "vesa"
[ 6.913] (II) Unloading vesa
[ 6.914] (--) Depth 24 pixmap format is 32 bpp
[ 7.286] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:23:0:0
[ 7.286] (--) NVIDIA(0): DFP-0
[ 7.286] (--) NVIDIA(0): DFP-1
[ 7.286] (--) NVIDIA(0): DFP-2
[ 7.286] (--) NVIDIA(0): DFP-3
[ 7.286] (--) NVIDIA(0): DFP-4
[ 7.286] (--) NVIDIA(0): DFP-5
[ 7.286] (--) NVIDIA(0): DFP-6
[ 7.287] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 7.287] (--) NVIDIA(GPU-1): DFP-0: Internal TMDS
[ 7.287] (--) NVIDIA(GPU-1): DFP-0: 165.0 MHz maximum pixel clock
[ 7.287] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 7.287] (--) NVIDIA(GPU-1): DFP-1: Internal DisplayPort
[ 7.287] (--) NVIDIA(GPU-1): DFP-1: 1440.0 MHz maximum pixel clock
[ 7.288] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 7.288] (--) NVIDIA(GPU-1): DFP-2: Internal TMDS
[ 7.288] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[ 7.288] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 7.288] (--) NVIDIA(GPU-1): DFP-3: Internal DisplayPort
[ 7.288] (--) NVIDIA(GPU-1): DFP-3: 1440.0 MHz maximum pixel clock
[ 7.288] (--) NVIDIA(GPU-1): DFP-4: disconnected
[ 7.288] (--) NVIDIA(GPU-1): DFP-4: Internal TMDS
[ 7.288] (--) NVIDIA(GPU-1): DFP-4: 165.0 MHz maximum pixel clock
[ 7.288] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 7.288] (--) NVIDIA(GPU-1): DFP-5: Internal DisplayPort
[ 7.288] (--) NVIDIA(GPU-1): DFP-5: 1440.0 MHz maximum pixel clock
[ 7.288] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 7.288] (--) NVIDIA(GPU-1): DFP-6: Internal TMDS
[ 7.288] (--) NVIDIA(GPU-1): DFP-6: 165.0 MHz maximum pixel clock
[ 7.302] (II) NVIDIA(GPU-1): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:23:0:0
[ 7.302] (II) NVIDIA(GPU-1): (GPU-1)
[ 7.302] (--) NVIDIA(GPU-1): Memory: 11534336 kBytes
[ 7.302] (--) NVIDIA(GPU-1): VideoBIOS: 86.02.39.40.63
[ 7.302] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[ 7.627] (--) NVIDIA(0): Valid display device(s) on GPU-2 at PCI:102:0:0
[ 7.627] (--) NVIDIA(0): DFP-0
[ 7.627] (--) NVIDIA(0): DFP-1
[ 7.627] (--) NVIDIA(0): DFP-2
[ 7.627] (--) NVIDIA(0): DFP-3
[ 7.627] (--) NVIDIA(0): DFP-4
[ 7.627] (--) NVIDIA(0): DFP-5
[ 7.627] (--) NVIDIA(0): DFP-6
[ 7.631] (--) NVIDIA(GPU-2): DFP-0: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-0: Internal TMDS
[ 7.631] (--) NVIDIA(GPU-2): DFP-0: 165.0 MHz maximum pixel clock
[ 7.631] (--) NVIDIA(GPU-2): DFP-1: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-1: Internal DisplayPort
[ 7.631] (--) NVIDIA(GPU-2): DFP-1: 1440.0 MHz maximum pixel clock
[ 7.631] (--) NVIDIA(GPU-2): DFP-2: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-2: Internal TMDS
[ 7.631] (--) NVIDIA(GPU-2): DFP-2: 165.0 MHz maximum pixel clock
[ 7.631] (--) NVIDIA(GPU-2): DFP-3: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-3: Internal DisplayPort
[ 7.631] (--) NVIDIA(GPU-2): DFP-3: 1440.0 MHz maximum pixel clock
[ 7.631] (--) NVIDIA(GPU-2): DFP-4: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-4: Internal TMDS
[ 7.631] (--) NVIDIA(GPU-2): DFP-4: 165.0 MHz maximum pixel clock
[ 7.631] (--) NVIDIA(GPU-2): DFP-5: disconnected
[ 7.631] (--) NVIDIA(GPU-2): DFP-5: Internal DisplayPort
[ 7.632] (--) NVIDIA(GPU-2): DFP-5: 1440.0 MHz maximum pixel clock
[ 7.632] (--) NVIDIA(GPU-2): DFP-6: disconnected
[ 7.632] (--) NVIDIA(GPU-2): DFP-6: Internal TMDS
[ 7.632] (--) NVIDIA(GPU-2): DFP-6: 165.0 MHz maximum pixel clock
[ 7.651] (II) NVIDIA(GPU-2): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:102:0:0
[ 7.651] (II) NVIDIA(GPU-2): (GPU-2)
[ 7.651] (--) NVIDIA(GPU-2): Memory: 11534336 kBytes
[ 7.651] (--) NVIDIA(GPU-2): VideoBIOS: 86.02.39.40.63
[ 7.651] (II) NVIDIA(GPU-2): Detected PCI Express Link width: 16X
[ 7.652] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 7.652] (II) NVIDIA: access.
[ 7.674] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 7.725] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 7.725] (==) NVIDIA(0): Backing store enabled
[ 7.725] (==) NVIDIA(0): Silken mouse enabled
[ 7.727] (==) NVIDIA(0): DPMS enabled
[ 7.727] (II) Loading sub module "dri2"
[ 7.727] (II) LoadModule: "dri2"
[ 7.727] (II) Module "dri2" already built-in
[ 7.727] (II) NVIDIA(0): [DRI2] Setup complete
[ 7.727] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 7.727] (--) RandR disabled
[ 7.730] (II) SELinux: Disabled on system
[ 7.730] (II) Initializing extension GLX
[ 7.730] (II) Indirect GLX disabled.
[ 7.737] (EE)
[ 7.737] (EE) Backtrace:
[ 7.739] (EE) 0: /usr/lib/xorg/Xorg (xorg_backtrace+0x4e) [0x55a3ea848e0e]
[ 7.739] (EE) 1: /usr/lib/xorg/Xorg (0x55a3ea697000+0x1b5b79) [0x55a3ea84cb79]
[ 7.739] (EE) 2: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7f9aee068000+0x11390) [0x7f9aee079390]
[ 7.739] (EE) 3: /lib/x86_64-linux-gnu/libc.so.6 (0x7f9aedc9e000+0x14dafa) [0x7f9aeddebafa]
[ 7.739] (EE) 4: /usr/lib/nvidia-430/libnvidia-glcore.so.430.26 (0x7f9aea2a3000+0x118b139) [0x7f9aeb42e139]
[ 7.739] (EE) 5: /usr/lib/nvidia-430/libnvidia-glcore.so.430.26 (0x7f9aea2a3000+0x118b29d) [0x7f9aeb42e29d]
[ 7.739] (EE) 6: /usr/lib/nvidia-430/libnvidia-glcore.so.430.26 (0x7f9aea2a3000+0xe74848) [0x7f9aeb117848]
[ 7.739] (EE) 7: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglxserver_nvidia.so (0x7f9ae7366000+0x8784a2) [0x7f9ae7bde4a2]
[ 7.739] (EE)
[ 7.739] (EE) Segmentation fault at address 0x7f9ae7d22000
[ 7.739] (EE)
Fatal server error:
[ 7.739] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 7.739] (EE)
[ 7.739] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 7.739] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 7.739] (EE)
[ 7.850] (EE) Server terminated with error (1). Closing log file.
After I updated the driver to 430.26, the monitor shows black screen with a blinking cursor.
I still can reach the computer over the network.
Above is the failing log ox Xorg
nvidia-bug-report.log.gz (1.96 MB)
nvidia-installer.log (992 Bytes)
