My arch linux screen display in wrong resolution since july
it’s lasted for at least 2 months, my side screen only can show up to 1920*1080@30
HMDI-A-I is directly connected to the 4070m gpu , while eDP-1 is connected to the IGPU(INTEL)
so as tried in linux/linux-zen/linux-lts + nvidia-dkms & linux-zen + nidia-open-dkms
ubuntu 24 & 25 do not show this bug
the screen is made of ipad3/4‘s screen . so the resolution is a little bit strange (2048*1536@59.9)
this is nvidia-smi result
Sun Sep 14 09:31:02 2025
| NVIDIA-SMI 580.82.09              Driver Version: 580.82.09      CUDA Version: 13.0     |
|   0  NVIDIA GeForce RTX 4070 ...    On  |   00000000:01:00.0  On |                  N/A |
| N/A   44C    P8              2W /  115W |      60MiB /   8188MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A            1669      G   /usr/bin/niri                             2MiB |
|    0   N/A  N/A            1815    C+G   .../lib/xdg-desktop-portal-gnome          6MiB |
xrandr
Screen 0: minimum 16 x 16, current 3627 x 1600, maximum 32767 x 32767
HDMI-A-1 connected 1920x1080+1707+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1920x1080     29.86*+
   1440x1080     29.86
   1400x1050     29.84
   1280x1024     29.90
   1280x960      29.82
   1152x864      29.92
   1024x768      29.89
   800x600       29.55
   640x480       29.79
   320x240       27.17
   1680x1050     29.95
   1440x900      29.91
   1280x800      29.83
   1152x720      29.72
   960x600       29.81
   928x580       29.54
   800x500       29.36
   768x480       29.46
   720x480       29.08
   640x400       29.37
   320x200       26.16
   1600x900      29.92
   1368x768      29.83
   1280x720      29.93
   1024x576      29.79
   864x486       29.38
   720x400       29.30
   640x350       28.79
eDP-1 connected primary 2560x1600+0+0 (normal left inverted right x axis y axis) 350mm x 220mm
   2560x1600    164.97*+
   2048x1536    164.95
   1920x1440    164.87
   1600x1200    164.88
   1440x1080    164.85
   1400x1050    164.77
   1280x1024    164.81
   1280x960     164.80
   1152x864     164.77
   1024x768     164.78
   800x600      164.72
   640x480      164.26
   320x240      163.69
   1920x1200    164.87
   1680x1050    164.82
   1440x900     164.74
   1280x800     164.81
   1152x720     164.77
   960x600      164.72
   928x580      164.51
   800x500      164.66
   768x480      164.47
   720x480      164.67
   640x400      164.67
   320x200      161.83
   2560x1440    164.90
   2048x1152    164.90
   1920x1080    164.83
   1600x900     164.77
   1368x768     164.98
   1280x720     164.71
   1024x576     164.94
   864x486      164.71
   720x400      164.23
   640x350      164.46
hwinfo --monitor returned these
24: None 00.0: 10002 LCD Monitor
  [Created at monitor.125]
  Unique ID: rdCR.vNMVyIg8SdD
  Parent ID: VCu0.zlaRFtqYl+B
  Hardware Class: monitor
  Model: "HDMI"
  Vendor: IPS
  Device: eisa 0x0970 "HDMI"
  Serial ID: "0"
  Resolution: 720x400@70Hz
  Resolution: 640x480@60Hz
  Resolution: 640x480@72Hz
  Resolution: 640x480@75Hz
  Resolution: 800x600@60Hz
  Resolution: 800x600@72Hz
  Resolution: 800x600@75Hz
  Resolution: 1024x768@60Hz
  Resolution: 1024x768@70Hz
  Resolution: 1024x768@75Hz
  Resolution: 1280x1024@75Hz
  Resolution: 1920x1080@60Hz
  Resolution: 1600x900@60Hz
  Resolution: 1360x768@60Hz
  Resolution: 1366x768@60Hz
  Resolution: 2048x1536@60Hz
  Year of Manufacture: 2022
  Week of Manufacture: 27
  Detailed Timings #0:
     Horizontal: 2048 2096 2128 2272 (+48 +80 +224) -hsync
       Vertical: 1536 1539 1543 1636 (+3 +7 +100) +vsync
    Frequencies: 223.00 MHz, 98.15 kHz, 59.99 Hz
  Detailed Timings #1:
     Horizontal: 1366 1436 1579 1792 (+70 +213 +426) -hsync
       Vertical:  768  771  774  798 (+3 +6 +30) +vsync
    Frequencies: 85.75 MHz, 47.85 kHz, 59.96 Hz
  Detailed Timings #2:
     Horizontal: 1360 1424 1536 1792 (+64 +176 +432) -hsync
       Vertical:  768  771  777  795 (+3 +9 +27) +vsync
    Frequencies: 85.50 MHz, 47.71 kHz, 60.02 Hz
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #10 (VGA compatible controller)
25: None 00.0: 10002 LCD Monitor
  Unique ID: rdCR.A_Vfnn0u6F2
  Parent ID: _Znp.MElTwFmXD0C
  Model: "TL160ADMP19 LCD Monitor"
  Vendor: TMA "TL160ADMP19"
  Device: eisa 0x2031
  Serial ID: "0"
  Resolution: 2560x1600@60Hz
  Year of Manufacture: 2023
  Week of Manufacture: 40
     Horizontal: 2560 2608 2640 2720 (+48 +80 +160) -hsync
       Vertical: 1600 1603 1609 1708 (+3 +9 +108) -vsync
    Frequencies: 278.75 MHz, 102.48 kHz, 60.00 Hz
  Driver Info #0:
    Max. Resolution: 2560x1600
    Vert. Sync Range: 60-165 Hz
    Hor. Sync Range: 29-29 kHz
    Bandwidth: 278 MHz
  Attached to: #20 (VGA compatible controller)
edid as it show
    cat /sys/class/drm/card0-HDMI-A-1/edid | edid-decode
edid-decode (hex):
00 ff ff ff ff ff ff 00 26 13 70 09 00 00 00 00
1b 20 01 03 80 00 00 78 ee 44 55 a9 55 4d 9d 26
0f 50 54 ad cf 00 b3 00 d1 c0 a9 c0 95 00 71 40
81 00 81 c0 81 40 1c 57 00 e0 80 00 64 60 30 20
34 00 c5 93 00 00 00 1a 7f 21 56 aa 51 00 1e 30
46 8f 33 00 c5 93 00 00 00 1a 66 21 50 b0 51 00
1b 30 40 70 36 00 c5 93 00 00 00 1a 00 00 00 fc
00 48 44 4d 49 0a 20 20 20 20 20 20 20 20 01 f9
02 03 2f f1 4f 10 05 04 03 02 07 16 01 14 1f 12
13 03 21 22 23 09 07 07 83 01 00 00 67 03 0c 00
10 00 38 3d e3 05 e3 01 e6 06 07 01 60 4f 2d 02
3a 80 18 71 38 2d 40 58 2c 25 00 c5 93 00 00 00
1e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 c5 93 00
00 00 1e 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04
Block 0, Base EDID:
  EDID Structure Version & Revision: 1.3
  Vendor & Product Identification:
    Manufacturer: IPS
    Model: 2416
    Made in: week 27 of 2022
  Basic Display Parameters & Features:
    Digital display
    Image size is variable
    Gamma: 2.20
    DPMS levels: Standby Suspend Off
    RGB color display
    Default (sRGB) color space is primary color space
    First detailed timing is the preferred timing
  Color Characteristics:
    Red  : 0.6611, 0.3320
    Green: 0.3017, 0.6132
    Blue : 0.1494, 0.0595
    White: 0.3134, 0.3291
  Established Timings I & II:
    IBM     :   720x400    70.081663 Hz   9:5     31.467 kHz     28.320000 MHz
    DMT 0x04:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
    DMT 0x05:   640x480    72.808802 Hz   4:3     37.861 kHz     31.500000 MHz
    DMT 0x06:   640x480    75.000000 Hz   4:3     37.500 kHz     31.500000 MHz
    DMT 0x09:   800x600    60.316541 Hz   4:3     37.879 kHz     40.000000 MHz
    DMT 0x0a:   800x600    72.187572 Hz   4:3     48.077 kHz     50.000000 MHz
    DMT 0x0b:   800x600    75.000000 Hz   4:3     46.875 kHz     49.500000 MHz
    DMT 0x10:  1024x768    60.003840 Hz   4:3     48.363 kHz     65.000000 MHz
    DMT 0x11:  1024x768    70.069359 Hz   4:3     56.476 kHz     75.000000 MHz
    DMT 0x12:  1024x768    75.028582 Hz   4:3     60.023 kHz     78.750000 MHz
    DMT 0x24:  1280x1024   75.024675 Hz   5:4     79.976 kHz    135.000000 MHz
  Standard Timings:
    DMT 0x3a:  1680x1050   59.954250 Hz  16:10    65.290 kHz    146.250000 MHz
    DMT 0x52:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
    DMT 0x53:  1600x900    60.000000 Hz  16:9     60.000 kHz    108.000000 MHz (RB)
    DMT 0x2f:  1440x900    59.887445 Hz  16:10    55.935 kHz    106.500000 MHz
    GTF     :  1152x864    60.000000 Hz   4:3     53.700 kHz     81.624000 MHz
    DMT 0x1c:  1280x800    59.810326 Hz  16:10    49.702 kHz     83.500000 MHz
    DMT 0x55:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
    DMT 0x20:  1280x960    60.000000 Hz   4:3     60.000 kHz    108.000000 MHz
  Detailed Timing Descriptors:
    DTD 1:  2048x1536   59.994748 Hz   4:3     98.151 kHz    223.000000 MHz (197 mm x 147 mm)
                 Hfront   48 Hsync  32 Hback  144 Hpol P
                 Vfront    3 Vsync   4 Vback   93 Vpol N
    DTD 2:  1366x768    59.964364 Hz 683:384   47.852 kHz     85.750000 MHz (197 mm x 147 mm)
                 Hfront   70 Hsync 143 Hback  213 Hpol P
                 Vfront    3 Vsync   3 Vback   24 Vpol N
    DTD 3:  1360x768    60.015162 Hz  85:48    47.712 kHz     85.500000 MHz (197 mm x 147 mm)
                 Hfront   64 Hsync 112 Hback  256 Hpol P
                 Vfront    3 Vsync   6 Vback   18 Vpol N
    Display Product Name: 'HDMI'
  Extension blocks: 1
Checksum: 0xf9
Block 1, CTA-861 Extension Block:
  Revision: 3
  Underscans IT Video Formats by default
  Basic audio support
  Supports YCbCr 4:4:4
  Supports YCbCr 4:2:2
  Native detailed modes: 1
  Video Data Block:
    VIC  16:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
    VIC   5:  1920x1080i  60.000000 Hz  16:9     33.750 kHz     74.250000 MHz
    VIC   4:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
    VIC   3:   720x480    59.940060 Hz  16:9     31.469 kHz     27.000000 MHz
    VIC   2:   720x480    59.940060 Hz   4:3     31.469 kHz     27.000000 MHz
    VIC   7:  1440x480i   59.940060 Hz  16:9     15.734 kHz     27.000000 MHz
    VIC  22:  1440x576i   50.000000 Hz  16:9     15.625 kHz     27.000000 MHz
    VIC   1:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
    VIC  20:  1920x1080i  50.000000 Hz  16:9     28.125 kHz     74.250000 MHz
    VIC  31:  1920x1080   50.000000 Hz  16:9     56.250 kHz    148.500000 MHz
    VIC  18:   720x576    50.000000 Hz  16:9     31.250 kHz     27.000000 MHz
    VIC  19:  1280x720    50.000000 Hz  16:9     37.500 kHz     74.250000 MHz
    VIC  33:  1920x1080   25.000000 Hz  16:9     28.125 kHz     74.250000 MHz
    VIC  34:  1920x1080   30.000000 Hz  16:9     33.750 kHz     74.250000 MHz
  Audio Data Block:
    Linear PCM:
      Max channels: 2
      Supported sample rates (kHz): 48 44.1 32
      Supported sample sizes (bits): 24 20 16
  Speaker Allocation Data Block:
    FL/FR - Front Left/Right
  Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
    Source physical address: 1.0.0.0
    DC_36bit
    DC_30bit
    DC_Y444
    Maximum TMDS clock: 305 MHz
  Colorimetry Data Block:
    xvYCC601
    xvYCC709
    BT2020cYCC
    BT2020YCC
    BT2020RGB
    Gamut Boundary Description Metadata Profile P0
  HDR Static Metadata Data Block:
    Electro optical transfer functions:
      Traditional gamma - SDR luminance range
      Traditional gamma - HDR luminance range
      SMPTE ST2084
    Supported static metadata descriptors:
      Static metadata type 1
    Desired content max luminance: 96 (400.000 cd/m^2)
    Desired content max frame-average luminance: 79 (276.782 cd/m^2)
    Desired content min luminance: 45 (0.125 cd/m^2)
    DTD 4:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz (197 mm x 147 mm)
                 Hfront   88 Hsync  44 Hback  148 Hpol P
                 Vfront    2 Vsync   5 Vback   38 Vpol P
    DTD 5:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz (197 mm x 147 mm)
                 Hfront  110 Hsync  40 Hback  220 Hpol P
                 Vfront    5 Vsync   5 Vback   20 Vpol P
Checksum: 0x04  Unused space in Extension Block: 44 bytes
niri shows
    niri msg outputs
Output "IPS, Inc. (Intellectual Property Solutions, Inc.) HDMI Unknown" (HDMI-A-1)
  Current mode: 1920x1080 @ 29.972 Hz
  Variable refresh rate: not supported
  Physical size: unknown
  Logical position: 1707, 0
  Logical size: 1280x720
  Scale: 1.5
  Transform: normal
  Available modes:
    1920x1080@29.972 (current)
    1920x1080@25.000
    1920x1080@25.000
    1366x768@59.964
    1360x768@60.015
    1280x800@59.810
    1152x864@59.997
    1280x720@60.000
    1280x720@60.000
    1280x720@59.943
    1280x720@50.000
    1280x720@50.000
    1024x768@60.004
    800x600@75.000
    800x600@72.188
    800x600@60.317
    720x576@50.000
    720x576@50.000
    720x480@59.940
    720x480@59.940
    720x480@59.940
    640x480@75.000
    640x480@72.809
    640x480@59.940
    640x480@59.940
    640x480@59.929
Output "Tianma Microelectronics Ltd. 0x2031 Unknown" (eDP-1)
  Current mode: 2560x1600 @ 165.002 Hz (preferred)
  Variable refresh rate: supported, disabled
  Physical size: 350x220 mm
  Logical position: 0, 0
  Logical size: 1706x1066
  Scale: 1.5
  Transform: normal
  Available modes:
    2560x1600@165.002 (current, preferred)
    2560x1600@60.001 (preferred)
pacman have there
    sudo pacman -Q
7zip 25.01-1
a52dec 0.8.0-2
aalib 1.4rc5-19
aardvark-dns 1.16.0-1
abseil-cpp 20250814.0-1
accounts-qml-module 0.7-6
accountsservice 23.13.9-2
acl 2.3.2-1
adobe-source-han-mono-cn-fonts 1.002-8
adobe-source-han-sans-cn-fonts 2.005-1
adobe-source-han-serif-cn-fonts 2.003-1
adw-gtk-theme-git 6.2.r18.g45c9983-1
adwaita-cursors 48.1-1
adwaita-fonts 49.0-2
adwaita-icon-theme 48.1-1
adwaita-icon-theme-legacy 46.2-3
aha 0.5.1-3
alembic 1.8.8-3
alsa-card-profiles 1:1.4.8-1
alsa-lib 1.2.14-1
alsa-topology-conf 1.2.5.1-4
alsa-ucm-conf 1.2.14-2
alsa-utils 1.2.14-1
aml 0.3.0-2
android-studio 2025.1.3.7-1
aom 3.13.1-1
appstream 1.0.6-1
appstream-qt 1.0.6-1
aquamarine 0.9.4-1
arch-install-scripts 29-1
archlinux-appstream-data 20250825-1
archlinux-keyring 20250807.1-1
archlinuxcn-keyring 20250531-1
asciidoc 10.2.1-2
at-spi2-core 2.56.4-1
atkmm 2.28.4-1
attica 6.17.0-1
attica5 5.116.0-1
attr 2.5.2-1
audit 4.0.5-1
aurorae 6.4.5-1
autoconf 2.72-1
autoconf-archive 1:2024.10.16-3
automake 1.18.1-1
avahi 1:0.9rc2-1
aws-c-auth 0.9.0-1
aws-c-cal 0.9.2-1
aws-c-common 0.12.4-1
aws-c-compression 0.3.1-1
aws-c-event-stream 0.5.6-1
aws-c-http 0.10.4-1
aws-c-io 0.21.4-1
aws-c-mqtt 0.13.3-1
aws-c-s3 0.8.7-1
aws-c-sdkutils 0.2.4-1
aws-checksums 0.2.7-1
aws-crt-cpp 0.33.5-1
aws-sdk-cpp-core 1.11.633-1
aws-sdk-cpp-iam 1.11.633-1
aws-sdk-cpp-s3 1.11.633-1
axel 2.17.14-1
ayatana-ido 0.10.4-1
baloo 6.17.0-1
baloo-widgets 25.08.1-1
base 3-2
base-devel 1-2
bash 5.3.3-2
bash-completion 2.16.0-1
bc 1.08.2-1
binder_linux-dkms-git r61.1434f1e-1
bindfs 1.18.1-1
bindfs-debug 1.18.1-1
binutils 2.45+r29+g2b2e51a31ec7-1
bison 3.8.2-8
blas 3.12.1-2
blender 17:4.5.3-1
blosc 1.21.6-1
bluedevil 1:6.4.5-1
bluez 5.83-1
bluez-libs 5.83-1
bluez-qt 6.17.0-1
bluez-utils 5.83-1
bolt 0.9.10-1
boost-libs 1.88.0-3
bottom 0.11.1-1
breeze 6.4.5-1
breeze-gtk 6.4.5-1
breeze-icons 6.17.0-1
breeze-plus 6.2.5-1
brightness 24.11.0-2
brightness-debug 24.11.0-2
brightnessctl 0.5.1-3
brotli 1.1.0-3
btop 1.4.4-1
btrfs-progs 6.16.1-1
bubblewrap 0.11.0-1
bun-bin 1.2.21-1
bun-bin-debug 1.2.21-1
bzip2 1.0.8-6
c-ares 1.34.5-1
ca-certificates 20240618-1
ca-certificates-mozilla 3.116-1
ca-certificates-utils 20240618-1
cabextract 1.11-2
cairo 1.18.4-1
cairomm 1.14.5-1
callaudiod 0.1.10-2
capnproto 1.2.0-1
capstone 5.0.6-1
catatonit 0.2.1-2
cava 0.10.4-3
cblas 3.12.1-2
cdparanoia 10.2-9
cdrtools 3.02a09-6
cfitsio 1:4.6.2-1
cherry-studio-bin 1.5.11-1
cherry-studio-electron-bin-debug 1.5.10-1
chromaprint 1.6.0-1
chromium 140.0.7339.127-1
cifs-utils 7.4-1
clang 20.1.8-1
cli11 2.5.0-1
clinfo 3.0.23.01.25-1
clion 1:2025.2.1-1
clion-cmake 1:2025.2.1-1
clion-gdb 1:2025.2.1-1
clion-jre 1:2025.2.1-1
clion-lldb 1:2025.2.1-1
cliphist 1:0.6.1-1
clutter 1.26.4-3
clutter-gtk 1.8.4-4
cmake 4.1.1-1
cmark 0.31.1-1
coeurl 0.3.1-4
cogl 1.22.8-3
compiler-rt 20.1.8-1
composefs 1.0.8-1
confuse 3.3-4
conmon 1:2.1.13-1
containerd 2.1.4-1
containers-common 1:0.64.1-1
convertlit 1.8-13
coreutils 9.7-1
cpio 2.15-3
cppdap 1.58.0-2
cryptsetup 2.8.1-1
ctags 1:6.2.0-1
curl 8.16.0-1
darkly-bin 0.5.22-1
dart-sass 1.92.1-1
dav1d 1.5.1-1
db5.3 5.3.28-5
dbus 1.16.2-1
dbus-broker 37-2
dbus-broker-units 37-2
dbus-glib 0.114-1
dbus-units 37-2
dconf 0.40.0-3
ddcutil 2.2.1-1
debugedit 5.2-1
debuginfod 0.193-5
default-cursors 3-1
deno 2.5.0-1
desktop-file-utils 0.28-1
device-mapper 2.03.35-1
dgop 0.1.2-2
dgop-debug 0.1.2-2
diffutils 3.12-2
discount 3.0.0.d-1
discover 6.4.5-1
dkms 3.2.1-1
dmidecode 3.6-1
dms-shell 0.0.7-1
dms-shell-debug 0.0.7-1
dnsmasq 2.91-1
docbook-xml 4.5-11
docbook-xsl 1.79.2-9
docker 1:28.3.3-1
dolphin 25.08.1-1
dolphin-meld-debug 25.04.3-1
dos2unix 7.5.2-2
dosfstools 4.2-5
double-conversion 3.3.1-1
draco 1.5.7-1
drkonqi 6.4.5-1
dtc 1.7.2-4
duktape 2.7.0-7
dvisvgm 3.5-2
dxvk-bin 2.7.1-1
e2fsprogs 1.47.3-1
ebook-tools 0.2.2-9
edid-generator-git r30.20231120.476a016-2
editline 1.17.1-4
editorconfig-core-c 0.12.9-1
edk2-aarch64 202508-1
edk2-arm 202508-1
edk2-ovmf 202508-1
edk2-shell 202508-1
efibootmgr 18-3
efitools 1.9.2-6
efivar 39-1
egl-gbm 1.1.2.1-1
egl-wayland 4:1.1.20-1
egl-x11 1.0.3-1
eglexternalplatform 1.2.1-1
electron27 27.3.11-10
electron34 34.5.8-1
electron36 36.9.0-1
electron37-bin 37.5.0-1
electron37-bin-debug 37.5.0-1
elfutils 0.193-5
ell 0.79-1
embree 4.4.0-1
enchant 2.8.12-1
exempi 2.6.6-2
exfatprogs 1.2.9-1
exiv2 0.28.7-1
expat 2.7.1-1
extra-cmake-modules 6.17.0-1
eza 0.23.2-1
faac 1.31.1-1
faad2 2.11.2-1
fakeroot 1.37.1.2-1
fastfetch 2.52.0-1
fcft 3.3.2-1
fcitx5 5.1.14-1
fcitx5-chinese-addons 5.1.9-1
fcitx5-configtool 5.1.10-1
fcitx5-gtk 5.1.4-1
fcitx5-qt 5.1.10-2
fcitx5-rime 5.1.11-1
feedbackd 0.8.4-1
feishu-bin 7.46.12-1
ffcall 2.5-1
ffmpeg 2:7.1.1-5
fftw 3.3.10-7
file 5.46-5
filesystem 2025.05.03-1
findutils 4.10.0-3
fish 4.0.2-1
flac 1.5.0-1
flashrom 1.6.0-1
flatpak 1:1.16.1-1
flatpak-xdg-utils 1.0.6-1
flex 2.6.4-5
fluffychat 2.1.1-1
fluidsynth 2.4.8-1
fmt 11.2.0-1
fnm 1.38.1-2
fontconfig 2:2.17.1-1
fontforge 20230101-6
foot 1.24.0-1
fpc 3.2.2-11
fpc-src 3.2.2-4
frameworkintegration 6.17.0-1
frameworkintegration5 5.116.0-2
freeglut 3.6.0-2
freerdp 2:3.17.1-1
freetype2 2.14.1-1
fribidi 1.0.16-2
fuse-common 3.17.1-1
fuse2 2.9.9-5
fuse3 3.17.1-1
fuzzel 1.13.1-1
fwupd 2.0.16-1
fwupd-efi 1.7-1
gammastep 2.0.11-1
gawk 5.3.2-1
gc 8.2.8-2
gcc 15.2.1+r22+gc4e96a094636-1
gcc-libs 15.2.1+r22+gc4e96a094636-1
gconf 3.2.6+11+g07808097-16
gcr 3.41.2-2
gcr-4 4.4.0.1-1
gd 2.3.3-8
gdb 16.3-1
gdb-common 16.3-1
gdbm 1.26-1
gdk-pixbuf2 2.42.12-2
geoclue 2.8.0-1
gettext 0.26-1
gflags 2.2.2-5
gfxstream 0.1.2-2
ghostscript 10.05.1-3
ghostty 1.1.3-1
ghostty-shell-integration 1.1.3-1
ghostty-terminfo 1.1.3-1
giflib 5.2.2-2
git 2.51.0-1
git-filter-repo 2.47.0-2
git-lfs 3.7.0-1
gjs 2:1.84.2-1
glew 2.2.0-7
glfw 1:3.4-1
glib-networking 1:2.80.1-1
glib2 2.84.4-2
glib2-devel 2.84.4-2
glib2-docs 2.84.4-2
glibc 2.42+r17+gd7274d718e6f-1
glibmm 2.66.8-1
glm 1.0.1-1
glslang 1:1.4.321.0-1
glu 9.0.3-2
gmp 6.3.0-2
gnome-autoar 0.4.5-1
gnome-desktop 1:44.4-1
gnome-desktop-4 1:44.4-1
gnome-desktop-common 1:44.4-1
gnome-keyring 1:48.0-1
gnome-network-displays 0.97.0-1
gnome-network-displays-debug 0.97.0-1
gnu-free-fonts 20120503-8
gnu-netcat 0.7.1-12
gnulib-l10n 20241231-1
gnupg 2.4.8-1
gnutls 3.8.10-1
go 2:1.25.1-2
gobject-introspection 1.84.0-2
gobject-introspection-runtime 1.84.0-2
gocryptfs 2.6.1-1
goland 2025.2.1.2-1
goland-jre 2025.2.1.2-1
google-breakpad v2024.02.16-1
google-breakpad-git-debug r2239.44ba5b57-1
google-glog 0.7.1-1
gperftools 2.17.2-1
gpgme 2.0.0-1
gpgmepp 2.0.0-2
gpm 1.20.7.r38.ge82d1a6-6
gptfdisk 1.0.10-1
graphene 1.10.8-2
graphite 1:1.3.14-5
graphviz 13.1.2-1
grep 3.12-2
grim 1.5.0-2
groff 1.23.0-7
grub 2:2.12.r359.g19c698d12-1
gsettings-desktop-schemas 48.0-1
gsettings-system-schemas 48.0-1
gsfonts 20200910-5
gsl 2.8-1
gsm 1.0.22-2
gsound 1.0.3-3
gssdp 1.6.4-1
gst-plugin-pipewire 1:1.4.8-1
gst-plugins-bad 1.26.5-2
gst-plugins-bad-libs 1.26.5-2
gst-plugins-base 1.26.5-2
gst-plugins-base-libs 1.26.5-2
gst-plugins-good 1.26.5-2
gst-plugins-ugly 1.26.5-2
gst-rtsp-server 1.26.5-2
gstreamer 1.26.5-2
gtest 1.17.0-1
gtk-doc 1.34.0-3
gtk-layer-shell 0.9.2-1
gtk-update-icon-cache 1:4.18.6-1
gtk-vnc 1.5.0-1
gtk3 1:3.24.50-1
gtk4 1:4.18.6-1
gtkmm3 3.24.10-1
gtksourceview4 4.8.4-2
gtksourceviewmm 1:3.91.1-1
gts 0.7.6.121130-5
guile 3.0.10-1
gupnp 1:1.6.9-1
gupnp-dlna 0.12.0-4
gupnp-igd 1.6.0-2
gvfs 1.57.2-4
gvim 9.1.1734-1
gzip 1.14-2
harfbuzz 11.5.0-1
harfbuzz-icu 11.5.0-1
hdf5 1.14.6-5
hicolor-icon-theme 0.18-1
hidapi 0.15.0-1
highway 1.3.0-1
html2markdown 2.4.0-1
html2markdown-debug 2.4.0-1
hunspell 1.7.2-2
hwdata 0.399-1
hwinfo 25.0-2
hwloc 2.12.2-1
hyphen 2.8.8-6
hyprcursor 0.1.13-1
hyprgraphics 0.1.5-2
hypridle 0.1.7-1
hyprland 0.51.0-2
hyprland-qt-support 0.1.0-7
hyprland-qtutils 0.1.5-1
hyprlang 0.6.4-1
hyprlock 0.9.1-1
hyprpicker 0.4.5-4
hyprshot 1.3.0-4
hyprsunset 0.3.2-1
hyprutils 0.8.4-1
hyprwayland-scanner 0.4.5-1
i2c-tools 4.4-2
iana-etc 20250612-1
icu 76.1-1
ijs 0.35-6
illogical-impulse-audio 1.0-1
illogical-impulse-backlight 1.0-1
illogical-impulse-basic 1.0-1
illogical-impulse-bibata-modern-classic-bin 2.0.6-1
illogical-impulse-fonts-themes 1.0-1
illogical-impulse-hyprland 1.0-1
illogical-impulse-kde 1.0-2
illogical-impulse-microtex-git r494.0e3707f-2
illogical-impulse-microtex-git-debug r494.0e3707f-2
illogical-impulse-portal 1.0-2
illogical-impulse-python 1.1-4
illogical-impulse-screencapture 1.0-1
illogical-impulse-toolkit 1.0-1
imagemagick 7.1.2.3-1
imath 3.2.1-1
imlib2 1.12.5-1
inetutils 2.6-1
iniparser 4.2.6-2
inotify-tools 4.23.9.0-2
intel-gmmlib 22.8.1-1
intel-media-driver 25.2.6-1
intel-oneapi-common 2024.1.0-1
intel-oneapi-compiler-dpcpp-cpp-runtime-libs 2025.0.4-1
intel-oneapi-compiler-shared-runtime-libs 2025.0.4-2
intel-oneapi-openmp 2025.0.4-1
intel-oneapi-tbb 2021.12.0-2
intel-oneapi-tcm 1.2.0-3
intel-ucode 20250812-1
inter-font 4.1-1
iproute2 6.16.0-2
iptables-nft 1:1.8.11-2
iputils 20250605-1
iso-codes 4.18.0-1
iw 6.17-1
iwd 3.9-1
jack2 1.9.22-1
jansson 2.14.1-1
jasper 4.2.8-1
jbig2dec 0.20-1
jbigkit 2.1-8
jemalloc 1:5.3.0-5
jetbrains-toolbox 2.8.1.52155-1
jq 1.8.1-1
js128 128.14.0-1
json-c 0.18-2
json-glib 1.10.6-1
jsoncpp 1.9.6-3
jsonrpc-glib 3.44.2-1
kaccounts-integration 25.08.1-1
kactivitymanagerd 6.4.5-1
kanshi 1.8.0-1
karchive 6.17.0-1
karchive5 5.116.0-1
kauth 6.17.0-1
kauth5 5.116.0-1
kbd 2.8.0-1
kbookmarks 6.17.0-1
kbookmarks5 5.116.0-1
kcmutils 6.17.0-1
kcmutils5 5.116.0-1
kcodecs 6.17.0-1
kcodecs5 5.116.0-1
kcolorscheme 6.17.0-1
kcompletion 6.17.0-1
kcompletion5 5.116.0-1
kconfig 6.17.0-1
kconfig5 5.116.0-1
kconfigwidgets 6.17.0-1
kconfigwidgets5 5.116.0-1
kcoreaddons 6.17.0-1
kcoreaddons5 5.116.0-1
kcrash 6.17.0-1
kcrash5 5.116.0-1
kdbusaddons 6.17.0-1
kdbusaddons5 5.116.0-1
kde-cli-tools 6.4.5-1
kde-gtk-config 6.4.5-1
kde-material-you-colors 1.10.1-1
kde-material-you-colors-debug 1.10.1-1
kdeclarative 6.17.0-1
kdeclarative5 5.116.0-1
kdecoration 6.4.5-1
kded 6.17.0-1
kded5 5.116.0-1
kdeplasma-addons 6.4.5-1
kdesu 6.17.0-1
kdialog 25.08.1-1
kdnssd 6.17.0-1
kdsingleapplication 1.2.0-1
kdsoap-qt6 2.2.0-1
kdsoap-ws-discovery-client 0.4.0-1
keyutils 1.6.3-3
kfilemetadata 6.17.0-2
kglobalaccel 6.17.0-1
kglobalaccel5 5.116.0-1
kglobalacceld 6.4.5-1
kguiaddons 6.17.0-1
kguiaddons5 5.116.0-1
kholidays 1:6.17.0-1
ki18n 6.17.0-1
ki18n5 5.116.0-1
kiconthemes 6.17.0-1
kiconthemes5 5.116.0-1
kidletime 6.17.0-1
kinfocenter 6.4.5-1
kio 6.17.0-1
kio-extras 25.08.1-1
kio-fuse 5.1.0-5
kio5 5.116.0-2
kirigami 6.17.0-1
kirigami-addons 1.9.0-1
kirigami2 5.116.0-1
kitemmodels 6.17.0-1
kitemviews 6.17.0-1
kitemviews5 5.116.0-1
kitty 0.42.2-1
kitty-shell-integration 0.42.2-1
kitty-terminfo 0.42.2-1
kjobwidgets 6.17.0-1
kjobwidgets5 5.116.0-1
kmenuedit 6.4.5-1
kmod 34.2-1
knewstuff 6.17.0-1
knewstuff5 5.116.0-3
knotifications 6.17.0-1
knotifications5 5.116.0-2
knotifyconfig 6.17.0-1
konsole 25.08.1-1
kpackage 6.17.0-1
kpackage5 5.116.0-1
kparts 6.17.0-1
kpipewire 6.4.5-1
kpmcore 25.08.1-1
kpty 6.17.0-1
kquickcharts 6.17.0-1
krb5 1.21.3-2
krdp 6.4.5-1
krunner 6.17.0-1
kscreen 6.4.5-1
kscreenlocker 6.4.5-1
kservice 6.17.0-1
kservice5 5.116.0-1
ksshaskpass 6.4.5-1
kstatusnotifieritem 6.17.0-1
ksvg 6.17.0-1
ksystemstats 6.4.5-1
ktexteditor 6.17.0-1
ktextwidgets 6.17.0-1
ktextwidgets5 5.116.0-1
kunitconversion 6.17.0-1
kuserfeedback 6.17.0-1
kwallet 6.17.0-1
kwallet-pam 6.4.5-1
kwallet5 5.116.0-3
kwalletmanager 25.08.1-1
kwayland 6.4.5-1
kwidgetsaddons 6.17.0-1
kwidgetsaddons5 5.116.0-1
kwin 6.4.5-1
kwindowsystem 6.17.0-1
kwindowsystem5 5.116.0-1
kwrited 6.4.5-1
kxmlgui 6.17.0-1
kxmlgui5 5.116.0-1
l-smash 2.14.5-4
lame 3.100-6
lapack 3.12.1-2
layer-shell-qt 6.4.5-1
lazarus 4.2-2
lcms2 2.17-1
ldb 2:4.22.4-1
leancrypto 1.5.1-1
leptonica 1.85.0-2
less 1:679-1
level-zero-loader 1.23.2-1
leveldb 1.23-4
libaccounts-glib 1.27-3
libaccounts-qt 1.17-1
libadwaita 1:1.7.7-1
libaec 1.1.4-2
libaemu 0.1.2-5
libaio 0.3.113-3
libappindicator-gtk3 12.10.0.r298-4
libarchive 3.8.1-1
libass 0.17.4-1
libassuan 3.0.0-1
libasyncns 1:0.8+r3+g68cd5af-3
libatasmart 0.19-7
libavc1394 0.5.4-7
libavif 1.3.0-1
libavtp 0.2.0-3
libayatana-appindicator 0.5.94-1
libayatana-indicator 0.9.4-1
libb2 0.98.1-3
libblake3 1.8.2-1
libblockdev 3.3.1-1
libblockdev-crypto 3.3.1-1
libblockdev-fs 3.3.1-1
libblockdev-loop 3.3.1-1
libblockdev-mdraid 3.3.1-1
libblockdev-nvme 3.3.1-1
libblockdev-part 3.3.1-1
libblockdev-swap 3.3.1-1
libbluray 1.3.4-3
libbpf 1.5.1-1
libbs2b 3.1.0-9
libbsd 0.12.2-2
libburn 1.5.6-1
libbytesize 2.11-1
libcaca 0.99.beta20-5
libcacard 2.8.1-1
libcanberra 1:0.30+r2+gc0620e4-4
libcap 2.76-1
libcap-ng 0.8.5-3
libcbor 0.12.0-1
libcdio 2.2.0-1
libcdio-paranoia 10.2+2.0.2-1
libcgif 0.5.0-1
libcloudproviders 0.3.6-2
libcmatrix 0.0.3-1
libcolord 1.4.8-1
libcpuid 0.8.1-1
libcue 2.3.0-1
libcups 2:2.4.12-2
libcurl-gnutls 8.16.0-1
libdaemon 0.14-6
libdatachannel 0.23.2-1
libdatrie 0.2.13-4
libdbusmenu-glib 16.04.0.r498-2
libdbusmenu-gtk3 16.04.0.r498-2
libdbusmenu-qt5 0.9.3+16.04.20160218-7
libdc1394 2.2.7-1
libdca 0.0.7-2
libde265 1.0.16-1
libdecor 0.2.3-1
libdeflate 1.24-1
libdex 0.10.1-1
libdisplay-info 0.2.0-2
libdmtx 0.7.8-1
libdovi 3.3.2-1
libdrm 2.4.125-1
libdv 1.0.0-11
libdvdnav 6.1.1-2
libdvdread 6.1.3-2
libebur128 1.2.6-2
libedit 20250104_3.1-1
libei 1.5.0-1
libelf 0.193-5
libepoxy 1.5.10-3
libevdev 1.13.4-1
libevent 2.1.12-4
libexif 0.6.25-1
libfabric 2.2.0-1
libfdk-aac 2.0.3-1
libffi 3.5.2-1
libfontenc 1.1.8-1
libfreeaptx 0.2.2-1
libftdi 1.5-7
libgbinder 1.1.42-1
libgcrypt 1.11.2-1
libgee 0.20.8-1
libgexiv2 0.14.6-1
libgirepository 1.84.0-2
libgit2 1:1.9.1-1
libgit2-glib 1.2.1-1
libglibutil 1.0.80-1
libglvnd 1.7.0-3
libgme 0.6.4-1
libgmobile 0.4.0-1
libgnome-games-support-2 2.0.2-1
libgovirt 2:0.3.9-2
libgpg-error 1.55-1
libgsf 1.14.53-2
libgudev 238-3
libgxps 0.3.2-5
libharu 2.4.5-1
libheif 1.20.2-1
libice 1.1.2-1
libidn 1.43-1
libidn2 2.3.7-1
libiec61883 1.2.0-9
libimagequant 4.4.0-1
libime 1.1.11-1
libimobiledevice 1.3.0-17
libimobiledevice-glue 1.3.2-1
libinih 61-1
libinput 1.29.1-1
libinstpatch 1.1.7-2
libiptcdata 1.0.5-4
libisl 0.27-1
libisoburn 1.5.6-1
libisofs 1.5.6-1
libjcat 0.2.3-2
libjpeg-turbo 3.1.2-1
libjuice 1.6.1-1
libjxl 0.11.1-4
libkexiv2 25.08.1-1
libksba 1.6.7-2
libkscreen 6.4.5-1
libksysguard 6.4.5-1
liblc3 1.1.3-1
libldac 2.0.2.3-2
libldap 2.6.10-2
libliftoff 0.5.0-1
liblqr 0.4.3-1
liblrdf 0.6.1-5
libltc 1.3.2-2
libluv 1.48.0_2-1
libmalcontent 0.13.1-1
libmanette 0.2.12-1
libmbim 1.32.0-1
libmd 1.1.0-2
libmicrodns 0.2.0-2
libmicrohttpd 1.0.2-1
libmm-glib 1.24.2-1
libmng 2.0.3-4
libmnl 1.0.5-2
libmodplug 0.8.9.0-6
libmpc 1.3.1-2
libmpcdec 1:0.1+r475-6
libmpeg2 0.5.1-11
libmtp 1.1.22-1
libmysofa 1.3.3-1
libnatpmp 20230423-3
libnautilus-extension 48.3-1
libnbd 1.22.4-1
libndp 1.9-1
libnetfilter_conntrack 1.0.9-2
libnewt 0.52.25-1
libnfnetlink 1.0.2-2
libnfs 6.0.2-5
libnftnl 1.3.0-1
libnghttp2 1.67.0-1
libnghttp3 1.11.0-1
libngtcp2 1.13.0-2
libnice 0.1.22-2
libnl 3.11.0-1
libnm 1.54.0-1
libnma 1.10.6-3
libnma-common 1.10.6-3
libnotify 0.8.6-1
libnsl 2.0.1-1
libnvme 1.15-1
libogg 1.3.6-1
libolm 3.2.16-5
libopenmpt 0.8.3-1
liboping 1.10.0-18
libosinfo 1.12.0-2
libp11-kit 0.25.7-1
libpanel 1.10.1-1
libpaper 2.2.6-1
libpcap 1.10.5-3
libpciaccess 0.18.1-2
libpeas-2 2.0.7-1
libpgm 5.3.128-3
libpipeline 1.5.8-1
libpipewire 1:1.4.8-1
libplacebo 7.351.0-2
libplasma 6.4.5-1
libplist 2.7.0-1
libpng 1.6.50-1
libportal 0.9.1-2
libportal-gtk4 0.9.1-2
libprocps 3.3.17-4
libproxy 0.5.11-1
libpsl 0.21.5-2
libpulse 17.0+r43+g3e2bb8a1e-1
libqaccessibilityclient-qt6 0.6.0-1
libqalculate 5.7.0-1
libqmi 1.36.0-1
libqrtr-glib 1.2.2-4
libraqm 0.10.3-1
libraw 0.21.4-1
libraw1394 2.1.2-4
librest 0.10.2-1
librime 1:1.12.0-4
librime-data 0.0.0.20240519-1
librsvg 2:2.61.1-1
librsync 1:2.3.4-2
libsamplerate 0.2.2-3
libsasl 2.1.28-5
libsass 3.6.6-1
libscfg 0.1.1-4
libseccomp 2.5.6-1
libsecret 0.21.7-1
libshout 1:2.4.6-5
libsigc++ 2.12.1-1
libsigsegv 2.15-1
libslirp 4.9.1-1
libsm 1.2.6-1
libsndfile 1.2.2-3
libsodium 1.0.20-1
libsoup3 3.6.5-1
libsoxr 0.1.3-4
libspiro 1:20240903-1
libspnav 1.2-1
libspng 0.7.4-2
libsrtp 1:2.7.0-1
libssh 0.11.3-1
libssh2 1.11.1-1
libstemmer 3.0.1-1
libsynctex 2025.2-2
libsysprof-capture 48.1-2
libtasn1 4.20.0-1
libteam 1.32-2
libthai 0.1.29-3
libtheora 1.2.0-1
libtiff 4.7.0-1
libtirpc 1.3.7-1
libtommath 1.3.0-1
libtool 2.5.4+r62+g6389dce8-1
libtraceevent 1:1.8.4-1
libtracefs 1.8.2-2
libunibreak 6.1-1
libuninameslist 20240910-1
libunistring 1.3-1
libunwind 1.8.2-1
liburcu 0.15.3-1
liburing 2.12-1
libusb 1.0.29-1
libusbmuxd 2.1.1-1
libutempter 1.2.3-1
libutf8proc 2.10.0-1
libuv 1.51.0-1
libva 2.22.0-1
libva-utils 2.22.0-1
libvarlink 24-1
libvdpau 1.5-3
libverto 0.3.2-5
libvips 8.17.1-1
libvirt 1:11.7.0-1
libvirt-glib 5.0.0-3
libvirt-python 1:11.7.0-1
libvlc 3.0.21-28
libvorbis 1.3.7-4
libvpl 2.15.0-1
libvpx 1.15.0-1
libvterm 0.3.3-2
libwacom 2.16.1-1
libwbclient 2:4.22.4-1
libwebp 1.6.0-1
libwireplumber 0.5.11-1
libx11 1.8.12-1
libx86 1.1-9
libx86emu 3.7-2
libxau 1.0.12-1
libxaw 1.0.16-1
libxcb 1.17.0-1
libxcomposite 0.4.6-2
libxcrypt 4.4.38-1
libxcrypt-compat 4.4.38-1
libxcursor 1.2.3-1
libxcvt 0.1.3-1
libxdamage 1.1.6-2
libxdmcp 1.1.5-1
libxdp 1.5.6-1
libxext 1.3.6-1
libxfixes 6.0.2-1
libxfont2 2.0.7-1
libxft 2.3.9-1
libxi 1.8.2-1
libxinerama 1.1.5-2
libxkbcommon 1.11.0-1
libxkbcommon-x11 1.11.0-1
libxkbfile 1.1.3-1
libxml2 2.14.6-1
libxmlb 0.3.24-1
libxmlrpc 1:1.59.03-4
libxmu 1.2.1-1
libxpm 3.5.17-2
libxrandr 1.5.4-1
libxrender 0.9.12-1
libxshmfence 1.3.3-1
libxslt 1.1.43-2
libxss 1.2.5-1
libxt 1.3.1-1
libxtst 1.2.5-1
libxv 1.0.13-1
libxxf86vm 1.1.6-1
libyaml 0.2.5-3
libyuv r2426+464c51a03-1
libzip 1.11.4-1
licenses 20240728-1
lilv 0.24.26-1
linux 6.16.7.arch1-1
linux-api-headers 6.16-2
linux-firmware 20250808-1
linux-firmware-amdgpu 20250808-1
linux-firmware-atheros 20250808-1
linux-firmware-broadcom 20250808-1
linux-firmware-cirrus 20250808-1
linux-firmware-intel 20250808-1
linux-firmware-mediatek 20250808-1
linux-firmware-nvidia 20250808-1
linux-firmware-other 20250808-1
linux-firmware-radeon 20250808-1
linux-firmware-realtek 20250808-1
linux-firmware-whence 20250808-1
linux-headers 6.16.7.arch1-1
linux-lts 6.12.47-1
linux-lts-headers 6.12.47-1
linux-zen 6.16.7.zen1-1
linux-zen-headers 6.16.7.zen1-1
linuxqq 5:3.2.19_39038-1
lldb 20.1.8-1
llhttp 9.2.1-2
llvm 20.1.8-1
llvm-libs 20.1.8-1
lm_sensors 1:3.6.2-1
lmdb 0.9.33-1
lmdbxx 1.0.0-3
lobehub 1.98.0-1
localsearch 3.9.0-3
log4cplus 2.1.0-2
lowdown 1.4.0-1
lsb-release 2.0.r55.a25a4fc-1
lshw B.02.20-1
lsof 4.99.5-2
lua 5.4.8-2
lua51-lpeg 1.1.0-4
luajit 2.1.1753364724-1
luit 20240910-1
lutris 0.5.19-6
lv2 1.18.10-1
lxc 1:6.0.5-1
lz4 1:1.10.0-2
lzo 2.10-5
m4 1.4.20-1
make 4.4.1-2
makepkg-git-lfs-proto 1-1
man-db 2.13.1-1
manifold 3.2.0-1
marisa 0.2.6-19
materialx 1.39.3-1
matugen-bin 2.4.1-1
matugen-bin-debug 2.4.1-1
mbedtls 3.6.4-1
md4c 0.5.2-1
mdadm 4.4-1
media-player-info 26-1
memtest86+-efi 7.20-2
mesa 1:25.2.2-2
mesa-utils 9.0.0-7
meson 1.9.0-1
microsoft-edge-stable-bin 140.0.3485.66-1
mihomo-bin 1.19.13-1
mihomo-bin-debug 1.19.13-1
milou 6.4.5-1
miniupnpc 2.3.3-1
minizip 1:1.3.1-2
minizip-ng 4.0.10-1
mjpegtools 2.2.1-3
mkinitcpio 39.2-3
mkinitcpio-busybox 1.36.1-1
mobile-broadband-provider-info 20250613-1
modemmanager 1.24.2-1
modemmanager-qt 6.17.0-1
mokutil 0.7.2-2
moonlight-qt-axi-appimage 6.1.0-1
mpdecimal 4.0.1-1
mpfr 4.2.2-1
mpg123 1.33.2-1
msgpack-c 6.1.0-2
mtdev 1.1.7-1
mtools 1:4.0.49-1
mtxclient 0.10.1-1
multipath-tools 0.12.0-1
nano 8.6-1
nanobind 2.8.0-1
nautilus 48.3-1
ncdu 2.8.2-3
ncurses 6.5-4
ndctl 79-1
neatvnc 0.9.5-1
neon 0.35.0-1
neovim 0.11.4-1
netavark 1.16.1-1
netpbm 10.86.47-1
nettle 3.10.2-1
networkmanager 1.54.0-1
networkmanager-qt 6.17.0-1
nftables 1:1.1.5-1
nheko-scrollfix 0.12.1-1
nheko-scrollfix-debug 0.12.1-1
ninja 1.12.1-2
niri-git 25.08.r9.gb7909db-1
nix 2.31.1-1
nix-busybox 1.36.1-2
nlohmann-json 3.12.0-2
nm-connection-editor 1.36.0-1
nmap 7.97-1
node-gyp 11.4.2-1
nodejs 24.7.0-1
nodejs-nopt 7.2.1-1
noto-fonts 1:2025.09.01-1
noto-fonts-cjk 20240730-1
noto-fonts-emoji 1:2.048-1
novnc 1.6.0-1
npm 11.6.0-1
npth 1.8-1
nspr 4.37-1
nss 3.116-1
numactl 2.0.19-1
nvidia-open-dkms 580.82.09-1
nvidia-utils 580.82.09-1
nvidia-vaapi-driver-git 0.0.14.r6.ge02b9c5-1
nwg-displays 0.3.26-1
obs-studio 31.1.2-1
obsidian 1.9.12-1
ocean-sound-theme 6.4.5-1
ocl-icd 2.3.3-1
onetbb 2022.2.0-1
oniguruma 6.9.10-1
openal 1.24.3-1
opencc 1.1.8-2
opencolorio 2.4.2-2
opencore-amr 0.1.6-2
opencv 4.12.0-4
openexr 3.3.5-2
openh264 2.6.0-1
openimagedenoise 2.3.3-2
openimageio 3.0.10.0-1
openjpeg2 2.5.3-1
openmp 20.1.8-1
openmpi 5.0.8-3
openpgl 0.7.1-1
openpmix 5.0.8-1
openshadinglanguage 1.14.7.0-2
openslide 4.0.0-5
openssh 10.0p1-4
openssl 3.5.2-1
opensubdiv 3.6.1-1
openucx 1.19.0-1
openvdb 12.1.0-2
openxr 1.1.50-1
opus 1.5.2-1
orc 0.4.41-1
osinfo-db 20250606-1
ostree 2025.6-1
otf-space-grotesk 2-2
oxygen 6.4.5-1
oxygen-sounds 6.4.5-1
p11-kit 0.25.7-1
pacman 7.0.0.r6.gc685ae6-6
pacman-mirrorlist 20250702-2
pahole 1:1.30-2
pam 1.7.1-1
pambase 20250719-1
pango 1:1.56.4-2
pangomm 2.46.4-1
parted 3.6-2
partitionmanager 25.08.1-1
paru 2.1.0-1
passim 0.1.10-1
passt 2025_08_05.309eefd-1
patch 2.8-1
pavucontrol-qt 2.2.0-1
pciutils 3.14.0-1
pcre 8.45-4
pcre2 10.46-1
pcsclite 2.3.3-1
peazip 10.6.1-1
peg 0.1.19-1
perl 5.42.0-1
perl-clone 0.47-2
perl-encode-locale 1.05-14
perl-error 0.17030-2
perl-file-listing 6.16-5
perl-html-parser 3.83-2
perl-html-tagset 3.24-3
perl-http-cookiejar 0.014-4
perl-http-cookies 6.11-3
perl-http-daemon 6.16-5
perl-http-date 6.06-4
perl-http-message 7.00-2
perl-http-negotiate 6.01-15
perl-io-html 1.004-7
perl-libwww 6.80-1
perl-lwp-mediatypes 6.04-7
perl-mailtools 2.22-2
perl-net-http 6.23-5
perl-timedate 2.33-8
perl-try-tiny 0.32-3
perl-uri 5.32-2
perl-www-robotrules 6.02-15
perl-xml-parser 2.47-3
perl-xml-writer 0.900-5
phodav 3.0-4
phonon-qt6 4.12.0-5
phonon-qt6-vlc 0.12.0-5
pinentry 1.3.2-1
pipewire 1:1.4.8-1
pipewire-audio 1:1.4.8-1
pipewire-pulse 1:1.4.8-1
pipewire-session-manager 1:1.4.8-1
pixman 0.46.4-1
pkgconf 2.5.1-1
plasma-activities 6.4.5-1
plasma-activities-stats 6.4.5-1
plasma-browser-integration 6.4.5-1
plasma-desktop 6.4.5-1
plasma-disks 6.4.5-1
plasma-firewall 6.4.5-1
plasma-integration 6.4.5-1
plasma-meta 6.4-4
plasma-nm 6.4.5-1
plasma-pa 6.4.5-1
plasma-systemmonitor 6.4.5-1
plasma-thunderbolt 6.4.5-1
plasma-vault 6.4.5-1
plasma-welcome 6.4.5-1
plasma-workspace 6.4.5-1
plasma-workspace-wallpapers 6.4.5-1
plasma5support 6.4.5-1
playerctl 2.4.1-4
pnpm 10.16.0-1
podman 5.6.1-1
polkit 126-2
polkit-kde-agent 6.4.5-1
polkit-qt5 0.200.0-1
polkit-qt6 0.200.0-1
poppler 25.09.1-1
poppler-data 0.4.12-2
poppler-glib 25.09.1-1
poppler-qt6 25.09.1-1
popt 1.19-2
portable 8.0-1
portaudio 1:19.7.0-3
potrace 1.16-4
power-profiles-daemon 0.30-1
powerdevil 6.4.5-1
ppp 2.5.2-1
print-manager 1:6.4.5-1
prison 6.17.0-1
procps-ng 4.0.5-3
protobuf 32.0-1
protobuf-c 1.5.2-5
protonup-qt 2.13.0-1
prrte 3.0.11-1
psmisc 23.7-1
ptex 2.4.3-1
pugixml 1.15-2
pulse-native-provider 1:1.4.8-1
pulseaudio-qt 1.7.0-1
purpose 6.17.0-1
pybind11 3.0.1-1
pyside6 6.9.2-1
pystring 1.1.4-2
python 3.13.7-1
python-aiofiles 24.1.0-2
python-anyio 4.10.0-1
python-autocommand 2.2.2-7
python-babel 2.17.0-1
python-beautifulsoup4 4.13.5-1
python-build 1.3.0-1
python-cachetools 6.1.0-1
python-cairo 1.28.0-1
python-certifi 2025.08.03-1
python-charset-normalizer 3.4.3-1
python-dbus 1.4.0-1
python-distro 1.9.0-3
python-docutils 1:0.21.2-3
python-evdev 1.9.2-1
python-gbinder 1.1.2-5
python-gobject 3.52.3-3
python-h11 0.16.0-1
python-html2text 2025.4.15-1
python-httpcore 1.0.9-2
python-httpx 0.28.1-3
python-i3ipc 2.2.1-8
python-idna 3.10-2
python-imagesize 1.4.1-6
python-inputs 0.5-4
python-installer 0.7.0-10
python-jaraco.collections 5.1.0-1
python-jaraco.context 6.0.1-1
python-jaraco.functools 4.1.0-1
python-jaraco.text 4.0.0-2
python-jinja 1:3.1.6-1
python-lxml 6.0.1-1
python-mako 1.3.10-1
python-markdown 3.9.0-1
python-markupsafe 3.0.2-1
python-materialyoucolor 2.0.10-1
python-materialyoucolor-debug 2.0.10-1
python-moddb 0.14.0-1
python-more-itertools 10.8.0-1
python-numpy 2.3.3-1
python-opencv 4.12.0-4
python-opengl 3.1.9-1
python-packaging 25.0-1
python-pillow 11.3.0-3
python-platformdirs 4.4.0-1
python-psutil 7.0.0-1
python-pyaml 24.12.0-1
python-pycryptodomex 3.23.0-1
python-pygdbmi 0.11.0.0-5
python-pygments 2.19.2-1
python-pyproject-hooks 1.2.0-3
python-pytz 2025.2-1
python-pywal16 1:3.8.9-3
python-pyxdg 0.28-4
python-requests 2.32.5-1
python-roman-numerals-py 3.1.0-1
python-sentry_sdk 2.37.0-1
python-setuptools 1:80.9.0-1
python-six 1.17.0-1
python-sniffio 1.3.1-4
python-snowballstemmer 2.2.0-7
python-soupsieve 2.8-1
python-sphinx 8.2.3-1
python-sphinx-alabaster-theme 1.0.0-4
python-sphinxcontrib-applehelp 2.0.0-3
python-sphinxcontrib-devhelp 2.0.0-4
python-sphinxcontrib-htmlhelp 2.1.0-3
python-sphinxcontrib-jsmath 1.0.1-19
python-sphinxcontrib-qthelp 2.0.0-3
python-sphinxcontrib-serializinghtml 2.0.0-3
python-steam 1.6.1-1
python-tqdm 4.67.1-2
python-typing_extensions 4.15.0-1
python-urllib3 2.5.0-1
python-vdf 4.0-3
python-wheel 0.45.1-1
python-xlib 0.33-4
python-yaml 6.0.2-2
python-zstandard 0.24.0-1
qca-qt5 2.3.10-3
qca-qt6 2.3.10-3
qcoro 0.12.0-1
qcustomplot 2.1.1-1
qemu-audio-alsa 10.1.0-1
qemu-audio-dbus 10.1.0-1
qemu-audio-jack 10.1.0-1
qemu-audio-oss 10.1.0-1
qemu-audio-pa 10.1.0-1
qemu-audio-pipewire 10.1.0-1
qemu-audio-sdl 10.1.0-1
qemu-audio-spice 10.1.0-1
qemu-base 10.1.0-1
qemu-block-curl 10.1.0-1
qemu-block-dmg 10.1.0-1
qemu-block-nfs 10.1.0-1
qemu-block-ssh 10.1.0-1
qemu-chardev-spice 10.1.0-1
qemu-common 10.1.0-1
qemu-desktop 10.1.0-1
qemu-emulators-full 10.1.0-1
qemu-hw-display-qxl 10.1.0-1
qemu-hw-display-virtio-gpu 10.1.0-1
qemu-hw-display-virtio-gpu-gl 10.1.0-1
qemu-hw-display-virtio-gpu-pci 10.1.0-1
qemu-hw-display-virtio-gpu-pci-gl 10.1.0-1
qemu-hw-display-virtio-gpu-pci-rutabaga 10.1.0-1
qemu-hw-display-virtio-gpu-rutabaga 10.1.0-1
qemu-hw-display-virtio-vga 10.1.0-1
qemu-hw-display-virtio-vga-gl 10.1.0-1
qemu-hw-display-virtio-vga-rutabaga 10.1.0-1
qemu-hw-uefi-vars 10.1.0-1
qemu-hw-usb-host 10.1.0-1
qemu-hw-usb-redirect 10.1.0-1
qemu-hw-usb-smartcard 10.1.0-1
qemu-img 10.1.0-1
qemu-system-aarch64 10.1.0-1
qemu-system-alpha 10.1.0-1
qemu-system-alpha-firmware 10.1.0-1
qemu-system-arm 10.1.0-1
qemu-system-arm-firmware 10.1.0-1
qemu-system-avr 10.1.0-1
qemu-system-hppa 10.1.0-1
qemu-system-hppa-firmware 10.1.0-1
qemu-system-loongarch64 10.1.0-1
qemu-system-m68k 10.1.0-1
qemu-system-microblaze 10.1.0-1
qemu-system-microblaze-firmware 10.1.0-1
qemu-system-mips 10.1.0-1
qemu-system-or1k 10.1.0-1
qemu-system-ppc 10.1.0-1
qemu-system-ppc-firmware 10.1.0-1
qemu-system-riscv 10.1.0-1
qemu-system-riscv-firmware 10.1.0-1
qemu-system-rx 10.1.0-1
qemu-system-s390x 10.1.0-1
qemu-system-s390x-firmware 10.1.0-1
qemu-system-sh4 10.1.0-1
qemu-system-sparc 10.1.0-1
qemu-system-sparc-firmware 10.1.0-1
qemu-system-tricore 10.1.0-1
qemu-system-x86 10.1.0-1
qemu-system-x86-firmware 10.1.0-1
qemu-system-xtensa 10.1.0-1
qemu-ui-curses 10.1.0-1
qemu-ui-dbus 10.1.0-1
qemu-ui-egl-headless 10.1.0-1
qemu-ui-gtk 10.1.0-1
qemu-ui-opengl 10.1.0-1
qemu-ui-sdl 10.1.0-1
qemu-ui-spice-app 10.1.0-1
qemu-ui-spice-core 10.1.0-1
qemu-user 10.1.0-1
qemu-vhost-user-gpu 10.1.0-1
qhexedit2 0.8.9-2
qqc2-breeze-style 6.4.5-1
qqc2-desktop-style 6.17.0-1
qqwing 1.3.4-7
qrencode 4.1.1-4
qscintilla-qt5 2.14.1-4
qt5-base 5.15.17+kde+r123-2
qt5-declarative 5.15.17+kde+r21-1
qt5-graphicaleffects 5.15.17-1
qt5-location 5.15.17+kde+r7-1
qt5-multimedia 5.15.17+kde+r2-1
qt5-quickcontrols 5.15.17-1
qt5-quickcontrols2 5.15.17+kde+r5-1
qt5-speech 5.15.17+kde+r1-1
qt5-svg 5.15.17+kde+r5-1
qt5-tools 5.15.17+kde+r3-2
qt5-translations 5.15.17-1
qt5-wayland 5.15.17+kde+r57-1
qt5-webchannel 5.15.17+kde+r3-1
qt5-webengine 5.15.19-2
qt5-x11extras 5.15.17-1
qt5ct 1.9-1
qt6-3d 6.9.2-1
qt6-5compat 6.9.2-1
qt6-avif-image-plugin 0.9.3-1
qt6-base 6.9.2-1
qt6-charts 6.9.2-1
qt6-connectivity 6.9.2-1
qt6-datavis3d 6.9.2-1
qt6-declarative 6.9.2-1
qt6-doc 6.9.2-1
qt6-examples 6.9.2-1
qt6-graphs 6.9.2-1
qt6-grpc 6.9.2-1
qt6-httpserver 6.9.2-1
qt6-imageformats 6.9.2-1
qt6-languageserver 6.9.2-1
qt6-location 6.9.2-1
qt6-lottie 6.9.2-1
qt6-multimedia 6.9.2-3
qt6-multimedia-ffmpeg 6.9.2-3
qt6-networkauth 6.9.2-1
qt6-positioning 6.9.2-1
qt6-quick3d 6.9.2-1
qt6-quick3dphysics 6.9.2-1
qt6-quickeffectmaker 6.9.2-1
qt6-quicktimeline 6.9.2-1
qt6-remoteobjects 6.9.2-1
qt6-scxml 6.9.2-1
qt6-sensors 6.9.2-1
qt6-serialbus 6.9.2-1
qt6-serialport 6.9.2-1
qt6-shadertools 6.9.2-1
qt6-speech 6.9.2-1
qt6-svg 6.9.2-1
qt6-tools 6.9.2-1
qt6-translations 6.9.2-1
qt6-virtualkeyboard 6.9.2-1
qt6-wayland 6.9.2-1
qt6-webchannel 6.9.2-1
qt6-webengine 6.9.2-2
qt6-websockets 6.9.2-1
qt6-webview 6.9.2-1
qt6ct 0.10-5
qt6pas 6.2.10-1
qtkeychain-qt6 0.15.0-3
quickshell 0.2.0-1
raptor 2.0.16-8
rav1e 0.7.1-1
rdma-core 59.0-1
re2 1:20240702-7
read-edid 3.0.2-5
readline 8.3.001-1
rhash 1.4.4-1
rime-bopomofo 0.0.0.20250729-1
rime-cangjie 0.0.0.20240325-1
rime-essay 0.0.0.20250121-1
rime-ice-git r824.dd050e4-1
rime-luna-pinyin 0.0.0.20240824-1
rime-prelude 0.0.0.20240519-1
rime-stroke 0.0.0.20250118-1
rime-terra-pinyin 0.0.0.20241225-1
rio 0.2.29-1
ripgrep 14.1.1-1
ripgrep-all 0.10.9-1
riscv64-linux-gnu-binutils 2.44-2
riscv64-linux-gnu-gcc 15.1.0-2
riscv64-linux-gnu-gdb 15.2-1
riscv64-linux-gnu-glibc 2.41-2
riscv64-linux-gnu-linux-api-headers 6.10-2
riscv64-unknown-elf-binutils 2.42-2
riscv64-unknown-elf-gcc 15.2.0-1
rnnoise 1:0.2-1
rsync 3.4.1-2
rtkit 0.13-3
rtl8821ce-dkms-git 1.0.5.r186.g5df613d-1
rtmpdump 1:2.4.r105.6f6bb13-1
rubberband 4.0.0-1
runc 1.3.1-1
rust 1:1.89.0-1
rustdesk 1.4.1-2
rustrover 2025.2.1-1
rustrover-jre 2025.2.1-1
rutabaga-ffi 0.1.6-2
s2n-tls 1.5.24-1
sassc 3.6.2-5
sbc 2.1-1
sbsigntools 0.9.5-3
sccache 0.10.0-2
scdoc 1.11.3-1
sdbus-cpp 2.1.0-2
sddm 0.21.0-6
sddm-kcm 6.4.5-1
sdl2-compat 2.32.56-2
sdl2_image 2.8.8-1
sdl2_ttf 2.24.0-2
sdl3 3.2.22-1
seabios 1.17.0-1
seatd 0.9.1-1
sed 4.9-3
semver 7.7.2-1
serd 0.32.4-1
shaderc 2025.3-1
shadow 4.18.0-1
shared-mime-info 2.4-2
shiboken6 6.9.2-1
signon-kwallet-extension 25.08.1-1
signon-plugin-oauth2 0.25-3
signon-ui 0.17+20231016-3
signond 8.61-3
simdjson 1:3.13.0-1
slang 2.3.3-4
slurp 1.5.0-1
smartmontools 7.5-1
smbclient 2:4.22.4-1
snappy 1.2.2-2
sndio 1.10.0-1
socat 1.8.0.3-2
sof-firmware 2025.05.1-1
sofia-sip 1.13.17-2
solid 6.17.0-1
solid5 5.116.0-1
sonnet 6.17.0-1
sonnet5 5.116.0-1
sord 0.16.18-1
sound-theme-freedesktop 0.8-6
soundtouch 2.4.0-1
source-highlight 3.1.9-15
spandsp 0.0.6-6
sparkle-bin 1.6.11-2
sparkle-bin-debug 1.6.11-2
spdlog 1.15.3-1
spectacle 1:6.4.5-1
speex 1.2.1-2
speexdsp 1.2.1-2
spice 0.16.0-2
spice-gtk 0.42-4
spice-protocol 0.14.5-1
spirv-tools 1:1.4.321.0-1
spotify 1:1.2.63.394-1
sqlcipher 4.6.1-1
sqlite 3.50.4-1
sqlitebrowser 3.13.1-1
squashfs-tools 4.7.2-1
sratom 0.6.18-1
srt 1.5.4-1
starship 1.23.0-1
stayfree-desktop 2.7.8-3
sudo 1.9.17.p1-1
svt-av1 3.1.2-1
svt-hevc 1.5.1-3
swappy 1.8.0-1
swww 0.10.3-1
syndication 6.17.0-1
syndication5 5.116.0-1
syntax-highlighting 6.17.0-1
systemd 257.9-1
systemd-boot-pacman-hook 3-1
systemd-libs 257.9-1
systemd-sysvcompat 257.9-1
systemsettings 6.4.5-1
taglib 2.1.1-1
talloc 2.4.3-1
tar 1.35-2
tcl 8.6.16-1
tdb 1.4.14-1
teamviewer 15.69.4-1
template-glib 3.36.3-1
terminus-font 4.49.1-8
tesseract 5.5.1-1
tesseract-data-eng 2:4.1.0-4
tesseract-data-osd 2:4.1.0-4
tevent 1:0.17.1-1
texinfo 7.2-1
texlive-basic 2025.2-2
texlive-bibtexextra 2025.2-2
texlive-bin 2025.2-2
texlive-binextra 2025.2-2
texlive-context 2025.2-2
texlive-fontsextra 2025.2-2
texlive-fontsrecommended 2025.2-2
texlive-fontutils 2025.2-2
texlive-formatsextra 2025.2-2
texlive-games 2025.2-2
texlive-humanities 2025.2-2
texlive-langchinese 2025.2-2
texlive-langcjk 2025.2-2
texlive-latex 2025.2-2
texlive-latexextra 2025.2-2
texlive-latexrecommended 2025.2-2
texlive-luatex 2025.2-2
texlive-mathscience 2025.2-2
texlive-metapost 2025.2-2
texlive-music 2025.2-2
texlive-pictures 2025.2-2
texlive-plaingeneric 2025.2-2
texlive-pstricks 2025.2-2
texlive-publishers 2025.2-2
texlive-xetex 2025.2-2
thunderbird-bin 142.0-1
tinysparql 3.9.2-2
tinyxml2 11.0.0-1
tmux 3.5_a-1
tomlplusplus 3.4.0-1
totem-pl-parser 3.26.6+r30+g51b8439-2
tpm2-tss 4.1.3-1
translate-shell 0.9.7.1-2
tree 2.2.1-1
tree-sitter 0.25.9-1
tree-sitter-c 0.24.1-1
tree-sitter-lua 0.4.0-1
tree-sitter-markdown 0.5.0-1
tree-sitter-query 0.7.0-1
tree-sitter-vim 0.7.0-1
tree-sitter-vimdoc 4.0.0-1
tslib 1.23-1
ttf-fira-code 6.2-2
ttf-gabarito-git v1.000.r8.g1f3fb39-1
ttf-hack 3.003-7
ttf-jetbrains-mono-nerd 3.4.0-1
ttf-liberation 2.1.5-2
ttf-material-symbols-variable-git 4.0.0.r133.g941fa95d-1
ttf-nerd-fonts-symbols 3.4.0-1
ttf-nerd-fonts-symbols-common 3.4.0-1
ttf-readex-pro 1.204-2
ttf-rubik-vf 2.3.0-3
ttf-twemoji 16.0.1-1
twolame 0.4.0-4
typescript 5.9.2-1
tzdata 2025b-1
uchardet 0.0.8-3
udisks2 2.10.2-1
ufw 0.36.2-5
unibilium 2.1.2-1
unzip 6.0-23
upower 1.90.10-1
upscayl-bin 2.15.0-6
usbredir 0.15.0-1
usbutils 018-1
usd 25.08-4
uthash 2.3.0-2
util-linux 2.41.1-1
util-linux-libs 2.41.1-1
uuid 1.6.2-20
uuid-debug 1.6.2-20
uv 0.8.17-1
v4l-utils 1.30.1-1
vala 0.56.18-4
valgrind 3.25.1-3
vapoursynth 72-1
vde2 2.3.3-8
verdict 1.4.4-1
vi 1:070224-6
vid.stab 1.1.1-2
vim-runtime 9.1.1734-1
virglrenderer 1.1.1-1
virt-install 5.1.0-1
virt-manager 5.1.0-1
virt-viewer 11.0-4
virtiofsd 1.13.2-1
visual-studio-code-bin 1.104.0-1
vk-hdr-layer-kwin6-git r47.303e0c6-1
vlc 3.0.21-28
vlc-cli 3.0.21-28
vlc-gui-qt 3.0.21-28
vlc-plugin-a52dec 3.0.21-28
vlc-plugin-alsa 3.0.21-28
vlc-plugin-archive 3.0.21-28
vlc-plugin-dav1d 3.0.21-28
vlc-plugin-dbus 3.0.21-28
vlc-plugin-dbus-screensaver 3.0.21-28
vlc-plugin-faad2 3.0.21-28
vlc-plugin-flac 3.0.21-28
vlc-plugin-gnutls 3.0.21-28
vlc-plugin-inflate 3.0.21-28
vlc-plugin-journal 3.0.21-28
vlc-plugin-jpeg 3.0.21-28
vlc-plugin-lua 3.0.21-28
vlc-plugin-mpg123 3.0.21-28
vlc-plugin-ogg 3.0.21-28
vlc-plugin-opus 3.0.21-28
vlc-plugin-png 3.0.21-28
vlc-plugin-pulse 3.0.21-28
vlc-plugin-shout 3.0.21-28
vlc-plugin-speex 3.0.21-28
vlc-plugin-tag 3.0.21-28
vlc-plugin-theora 3.0.21-28
vlc-plugin-twolame 3.0.21-28
vlc-plugin-vorbis 3.0.21-28
vlc-plugin-vpx 3.0.21-28
vlc-plugin-xml 3.0.21-28
vlc-plugins-base 3.0.21-28
vlc-plugins-video-output 3.0.21-28
vmaf 3.0.0-1
volume_key 0.3.12-11
vte-common 0.80.3-1
vte3 0.80.3-1
vtk 9.5.1-1
vulkan-icd-loader 1.4.321.0-1
vulkan-intel 1:25.2.2-2
vulkan-tools 1.4.321.0-1
wavpack 5.8.1-1
wayland 1.24.0-1
wayland-protocols 1.45-1
wayland-utils 1.2.0-2
wayvnc 0.9.1-1
webkit2gtk-4.1 2.48.6-1
webrtc-audio-processing-1 1.3-5
websockify 0.13.0-2
websockify-debug 0.13.0-2
wechat 1:6-2
wechat-bin 4.0.1.11-2
wev 1.1.0-1
wf-recorder 0.5.0-2
wget 1.25.0-2
which 2.23-1
wildmidi 0.4.6-1
wine 10.14-1
wine-stable-mono 9.4.0-1
winetricks-git 20250102.r36.g9006a366-1
wireless-regdb 2025.07.10-1
wl-clip-persist 0.4.3-2
wl-clipboard 1:2.2.1-3
wlogout 1.2.2-0
wlogout-debug 1.2.2-0
wlr-randr 0.5.0-1
woff2 1.0.2-6
wolfssl 5.8.2-1
wpa_supplicant 2:2.11-3
wtype 0.4-2
x264 3:0.164.r3108.31e19f9-3
x265 4.1-1
xbitmaps 1.1.3-2
xcb-imdkit 1.0.9-1
xcb-proto 1.17.0-3
xcb-util 0.4.1-2
xcb-util-cursor 0.1.6-1
xcb-util-errors 1.0.1-2
xcb-util-image 0.4.1-3
xcb-util-keysyms 0.4.1-5
xcb-util-renderutil 0.3.10-2
xcb-util-wm 0.4.2-2
xdg-dbus-proxy 0.1.6-1
xdg-desktop-portal 1.20.3-1
xdg-desktop-portal-gnome 48.0-2
xdg-desktop-portal-gtk 1.15.3-1
xdg-desktop-portal-hyprland 1.3.10-1
xdg-desktop-portal-kde 6.4.5-1
xdg-desktop-portal-wlr 0.7.1-1
xdg-user-dirs 0.18-2
xdg-user-dirs-gtk 0.14-1
xdg-utils 1.2.1-1
xdotool 3.20211022.1-2
xf86-input-libinput 1.5.0-1
xkeyboard-config 2.45-1
xmlstarlet 1.6.1-6
xorg-fonts-encodings 1.1.0-1
xorg-server 21.1.18-2
xorg-server-common 21.1.18-2
xorg-setxkbmap 1.3.4-2
xorg-xauth 1.1.4-1
xorg-xdpyinfo 1.4.0-1
xorg-xhost 1.0.10-1
xorg-xkbcomp 1.4.7-1
xorg-xmessage 1.0.7-1
xorg-xprop 1.2.8-1
xorg-xrandr 1.5.3-1
xorg-xrdb 1.2.2-2
xorg-xset 1.2.5-2
xorg-xwayland 24.1.8-1
xorgproto 2024.1-2
xsettingsd 1.0.2-3
xterm 401-1
xvidcore 1.3.7-3
xwayland-satellite 0.7-1
xxhash 0.8.3-1
xz 5.8.1-1
yakuake 25.08.1-1
yaml-cpp 0.8.0-2
yarn 1.22.22-2
yay 12.5.0-1
yazi 25.5.31-2
ydotool 1.0.4-2
yyjson 0.12.0-1
zbar 0.23.93-4
zed 0.203.5-1
zenity 4.1.99-2
zeromq 4.3.5-2
zerotier-one 1.16.0-2
zimg 3.0.5-1
zip 3.0-11
zix 0.6.2-1
zlib 1:1.3.1-2
zlib-ng 2.2.5-1
zsh 5.9-5
zstd 1.5.7-2
zvbi 0.2.44-1
zxing-cpp 2.3.0-5
zziplib 0.13.80-1
