I am bringing up a new embedded board based on the Tegra TK1. It has a standard eMMC with 16Gb, but to conserve board space there is NO USB port for the flash cable. It DOES have a micro-SD slot… The plan is to boot from SD and install our custom L4T image from that. I have a Tegra-bootable micro SD that is 64Gb, but the standard nVidia flash/nvflash tools are hard-coded for 16Gb devices so only 16Gb of the SD card are being used. This SD card is flashed/prepared/tested on a ‘standard’ Jetson TK1 dev board, not the new board yet, until the SD card boot/prep works on a standard TK1.
What I want to do is expand the root (APP) partition on my bootable SD card to utilize the entire 64Gb available (less what the boot and hidden partitions require). Then I can put a compressed copy of our L4T image in the root partition and install it to eMMC with a script after booting from the SD card.
So far I have not had success. I have tried the following:
- I can mount the SD card on a normal Ubuntu Linux machine and see the contents of the APP partition. The idea was to use gparted to expand the APP partition, but the hidden partitions come after the APP partition, are of unknown type, so gparted does not provide an option to move them.
- Following on from 1) above, I thought I would just create an additional partition in the 48Gb of free space after the hidden partitions. Nope. gparted complains that there are too many primary partitions so I can’t create a new one.
- New approach. Modify the jetson-tk1.conf file to indicate the device and APP partition sizes and use flash/nvflash. I increased the EMMCSIZE= from 15766388736 to 47223668736 and the ROOTFSSIZE= from 15032385536 to 46489665536. The difference in both cases is +30Gb. When I run sudo ./flash.sh jetson-tk1 mmcblk1p1 it builds a system image, reporting the following:
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 47223668736
bootpart size ------------ 8388608
userpart size ------------ 47215280128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 90894335 44336.0MiB
[ DTB] UV 90894336 90902527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 90902528 91033599 64.0MiB
[ USP] UV 91033600 91041791 4.0MiB
[ TP1] UV 91041792 91049983 4.0MiB
[ TP2] UV 91049984 91058175 4.0MiB
[ TP3] UV 91058176 91066367 4.0MiB
[ WB0] UV 91066368 91070463 2.0MiB
[ UDA] UV 91070464 92213247 558.0MiB
[ GPT] UH 92213248 92217343 2.0MiB gpt.img
copying flasher(/opt/TK1/Linux_for_Tegra_tk1/bootloader/ardbeg/fastboot.bin)... done.
Existing flashapp(/opt/TK1/Linux_for_Tegra_tk1/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x34001001740de103180000000e050480
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x00000001740de103180000000e050480
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59661/59661 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 2 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
creating partition: BCT
creating partition: PPT
creating partition: PT
creating partition: EBT
creating partition: LNX
creating partition: SOS
creating partition: NVC
creating partition: MPB
creating partition: MBP
creating partition: GP1
creating partition: APP
creating partition: DTB
creating partition: EFI
creating partition: USP
creating partition: TP1
creating partition: TP2
creating partition: TP3
creating partition: WB0
creating partition: UDA
creating partition: GPT
failed executing command 17 NvError 0x120002
command failure/warning: create failed (bad data)
bootloader status: failed to create the partition (code: 10) message: nverror:0x9 (0x9) CreatePartition 1812 flags: 0
Failed flashing ardbeg.
That obviously didn’t work and then the eMMC wouldn’t boot, even with the SD card removed, so it appears it tried to flash the eMMC (mmcblk0) instead of the SD card (mmcblk1) and messed up the eMMC image. Very minor setback: I successfully reflashed the eMMC, so the TK1 is okay again.
How can I accomplish creating a bootable 64Gb SD card with ~62Gb APP partition??
