used sdkmanager cli 1 1 0 63 43
32 gb sdcard got to two 14 gb partitions
why?
the complication here is that after installing cuda components;
the space at the system partition exhausts completely
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 13G 366M 98% /
none 3.5G 0 3.5G 0% /dev
tmpfs 3.8G 4.0K 3.8G 1% /dev/shm
tmpfs 3.8G 29M 3.8G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
tmpfs 777M 12K 777M 1% /run/user/120
tmpfs 777M 0 777M 0% /run/user/1000
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mtdblock0 31:0 0 32M 0 disk
mmcblk0 179:0 0 28.8G 0 disk
├─mmcblk0p1 179:1 0 14G 0 part /
├─mmcblk0p2 179:2 0 64M 0 part
├─mmcblk0p3 179:3 0 64M 0 part
├─mmcblk0p4 179:4 0 448K 0 part
├─mmcblk0p5 179:5 0 448K 0 part
├─mmcblk0p6 179:6 0 63M 0 part
├─mmcblk0p7 179:7 0 512K 0 part
├─mmcblk0p8 179:8 0 256K 0 part
├─mmcblk0p9 179:9 0 256K 0 part
├─mmcblk0p10 179:10 0 100M 0 part
└─mmcblk0p11 179:11 0 14.6G 0 part
zram0 252:0 0 1.9G 0 disk [SWAP]
zram1 252:1 0 1.9G 0 disk [SWAP]
tried applying modified resize.sh script
–after modifying all numbers
14 to
10 on the file—and deleting the mmcblk0p11 partition—
but due to internet abruption [ working remotely ], it seems that only one partition has moved to the end of the unallocated space. May be the cause is that script requires more modification though;
However, recovering on-the-fly from booted NX OS presumably messed by the attached script from network with
ssh user@remoteip dd if=/mnt/nxdevkit.raw | dd status=progress of=/dev/mmcblk0
resizenx.sh.log (4.1 KB)
The dd allowed to rewrite-on-the-fly the entire sdkdisk to previous state.
30953963520 bytes (31 GB, 29 GiB) copied, 4670.26 s, 6.6 MB/s
trying the resize script once again;
this time using
screen
├─mmcblk0p1 179:1 0 28.6G 0 part /
└─mmcblk0p10 179:10 0 100M 0 part
sudo fdisk /dev/mmcblk0
Device Start End Sectors Size Type
/dev/mmcblk0p1 40 59857111 59857072 28.6G Linux filesystem
/dev/mmcblk0p2 59857112 59988183 131072 64M Microsoft basic data
/dev/mmcblk0p3 59988184 60119255 131072 64M Microsoft basic data
/dev/mmcblk0p4 60119256 60120151 896 448K Microsoft basic data
/dev/mmcblk0p5 60120152 60121047 896 448K Microsoft basic data
/dev/mmcblk0p6 60121048 60250071 129024 63M Microsoft basic data
/dev/mmcblk0p7 60250072 60251095 1024 512K Microsoft basic data
/dev/mmcblk0p8 60251096 60251607 512 256K Microsoft basic data
/dev/mmcblk0p9 60251608 60252119 512 256K Microsoft basic data
/dev/mmcblk0p10 60252120 60456920 204801 100M Microsoft basic data
However, there still seems something missed; resize2fs will throw out permission error. probably force unmount might resolve
