Before you begin, you have already done these things.
- Use JetPack 4.6.1 sd card.
- Install and setup.
I create my environment on a 32GB sd card to speed up my work.
Start here.
Logging in to Jetson
- Install sd card capacity expansion script.
- Delete apt cache.
- Delete python/jupyter history. (if you need)
- Disable problem report. (if you need)
- Disable GUI. (if you need)
- Delete user command history.
- Delete super-user command history.
- Delete system logs.
- Shutdown.
If your JetPack version is not 4.6.x, select the collect branch.
git clone https://github.com/NVIDIA-AI-IOT/jetcard
cd jetcard
git checkout 852475be56ab220283b273f7c320e74b764a3b43
sudo cp scripts/archive/nvresizefs.sh /etc/systemd/
sudo cp scripts/archive/system/nvresizefs.service /etc/systemd/system/
sudo ln -s /etc/systemd/system/nvresizefs.service /etc/systemd/system/multi-user.target.wants/nvresizefs.service
ls -l /etc/systemd/nvresizefs.sh
ls -l /etc/systemd/system/nvresizefs.service
ls -l /etc/systemd/system/multi-user.target.wants/nvresizefs.service
cd ..
rm -rf jetcard
Delete apt cache.
sudo apt-get autoremove -y
sudo apt-get clean
sudo rm -rf /var/lib/apt/lists/*
rm -rf ~/.ipynb_checkpoints/
rm -rf ~/.ipython/
rm -rf ~/.python_history
For example, you need to use pythoch pre-trained model in a jupyter notebook.
In such cases, instead of running jupyter notebook, run the python command.
In this case, no cache will be created.
Example of downloading a pre-trained model of pytorch.
python3 -c "import torchvision; \
model = torchvision.models.alexnet(pretrained=True); \
model = torchvision.models.resnet18(pretrained=True)"
sudo sed -i 's/enabled=1/enabled=0/g' /etc/default/apport
sudo systemctl set-default multi-user.target
Enable GUI (if you want to rollback)
sudo systemctl set-default graphical.target
history -c
HISTIGNORE=*;history -d `history|awk '{a=$1;}END{print a;}'`
rm -rf ~/.bash_history
sudo su
history -c
Delete system logs.
For Jetson Nano 4GB/NX JetPack 4.6.x.
rm /var/log/alternatives.log*
rm /var/log/auth.log*
rm /var/log/btmp*
rm /var/log/dpkg.log*
rm /var/log/kern.log*
rm /var/log/lastlog*
rm /var/log/oem-config.log*
rm /var/log/syslog*
rm /var/log/tallylog*
rm /var/log/wtmp*
rm /var/log/Xorg.0.log*
touch /var/log/alternatives.log
touch /var/log/auth.log
touch /var/log/btmp
touch /var/log/dpkg.log
touch /var/log/kern.log
touch /var/log/lastlog
touch /var/log/oem-config.log
touch /var/log/syslog
touch /var/log/tallylog
touch /var/log/wtmp
touch /var/log/Xorg.0.log
chown syslog:adm /var/log/auth.log
chown root:utmp /var/log/btmp
chown syslog:adm /var/log/kern.log
chown root:utmp /var/log/lastlog
chown syslog:adm /var/log/syslog
chown root:utmp /var/log/wtmp
chown root:root /var/log/Xorg.0.log
for CLEAN in $(find /var/log/ -type f)
do
cp /dev/null $CLEAN
done
Shutdown.
shutdown -h now
If you want to disable bug reports or disable the GUI, please do so before shutdown.
Ubuntu PC
- Make sd card image.
- Partition compression.
Make sd card image.
I use SONY MRW-S1 SD CARD READER.
sudo su
fdisk -l
umount /dev/sda1
dd bs=4M if=/dev/sda of=jetbot-nano-4gb-jp461-2022-04-04.img status=progress
This process sometimes fails in the process.
This is one of the reasons I use a 32GB sd card.
A smaller capacity sd card is less likely to fail.
sudo su
modprobe loop
export LOOP=`losetup -f`
losetup $LOOP jetbot-nano-4gb-jp461-2022-04-04.img
partprobe $LOOP
echo $LOOP
gparted $LOOP
Edit partition.
Good reference: partitioning - "Re-size" the .img for smaller SD-card. How to SHRINK a bootable SD card image - Ask Ubuntu
After partition have been changed, exit gparted.
Delete loop.
losetup -d $LOOP
unset LOOP
The file size has not yet been reduced.
ls -l jetbot-nano-4gb-jp461-2022-04-04.img
-rw-r--r-- 1 root root 32010928128 Apr 13 20:14 jetbot-nano-4gb-jp461-2022-04-04.img
Check the image information.
fdisk -l jetbot-nano-4gb-jp461-2022-04-04.img
Disk jetbot-nano-4gb-jp461-2022-04-04.img: 29.83 GiB, 32010928128 bytes, 62521344 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 91FC289A-1E03-495A-9DAD-732401089949
Device Start End Sectors Size Type
jetbot-nano-4gb-jp461-2022-04-04.img1 28672 60024831 59996160 28.6G Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img2 2048 2303 256 128K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img3 4096 4991 896 448K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img4 6144 7295 1152 576K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img5 8192 8319 128 64K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img6 10240 10623 384 192K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img7 12288 13055 768 384K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img8 14336 14463 128 64K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img9 16384 17279 896 448K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img10 18432 19327 896 448K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img11 20480 22015 1536 768K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img12 22528 22655 128 64K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img13 24576 24959 384 192K Linux filesystem
jetbot-nano-4gb-jp461-2022-04-04.img14 26624 26879 256 128K Linux filesystem
Partition table entries are not in disk order.
See the first line.
Reduce file size.
truncate --size=$[(60024831+1)*512] jetbot-nano-4gb-jp461-2022-04-04.img
Now the file size is smaller.
(This image has a large SWAP size. So it was able to reduce only 1.3 GB.)
-rw-r--r-- 1 root root 30732713984 Apr 13 20:17 jetbot-nano-4gb-jp461-2022-04-04.img
There may be a smarter way to do the part of deleting logs.
This is how I do it when I create a sd card image.
