Booting takes so long
My GPU is NVIDIA - GeForce RTX 3090 Ti, and the OS is Ubuntu 18.04.
As my code didn’t work, I checked the versions of python, pytorch, cuda, and cudnn.
  • Python: 3.6
  • torch. version : 1.4.0
  • torch.version.cuda : 10.1 (nvidia-smi shows CUDA version 11.3)
  • cudnn: 7.6.3
These are not compatible with 3090 Ti, I successfully upgraded Python to 3.9, and Pytorch to 1.12.1+cu102.
However, “pip3 install cuda-python” and “pip install nvidia-cudnn” did not work for me. So I followed the steps on the website.
For cuda (tried version 11.8): CUDA Toolkit 11.8 Downloads | NVIDIA Developer
For cudnn (tried version 8.6.0, tar file installation): Installation Guide :: NVIDIA Deep Learning cuDNN Documentation
After the installation steps, nvidia-smi shows “Failed to initialize NVML: Driver/library version mismatch”.
I found that rebooting would work, but the system is stuck at the rebooting step.
dpkg -l |grep nvidia
iU libnvidia-cfg1-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-465 465.19.01-0ubuntu1 all Shared files used by the NVIDIA libraries
iU libnvidia-common-520 520.61.05-0ubuntu1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-465:amd64 465.19.01-0ubuntu1 amd64 NVIDIA libcompute package
iU libnvidia-compute-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA libcompute package
iU libnvidia-compute-520:i386 520.61.05-0ubuntu1 i386 NVIDIA libcompute package
ii libnvidia-container-tools 1.11.0-1 amd64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container1:amd64 1.11.0-1 amd64 NVIDIA container runtime library
iU libnvidia-decode-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
iU libnvidia-decode-520:i386 520.61.05-0ubuntu1 i386 NVIDIA Video Decoding runtime libraries
iU libnvidia-encode-520:amd64 520.61.05-0ubuntu1 amd64 NVENC Video Encoding runtime library
iU libnvidia-encode-520:i386 520.61.05-0ubuntu1 i386 NVENC Video Encoding runtime library
iU libnvidia-extra-520:amd64 520.61.05-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
iU libnvidia-fbc1-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
iU libnvidia-fbc1-520:i386 520.61.05-0ubuntu1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
iU libnvidia-gl-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
iU libnvidia-gl-520:i386 520.61.05-0ubuntu1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc nvidia-compute-utils-465 465.19.01-0ubuntu1 amd64 NVIDIA compute utilities
iU nvidia-compute-utils-520 520.61.05-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-container-toolkit 1.11.0-1 amd64 NVIDIA Container toolkit
ii nvidia-container-toolkit-base 1.11.0-1 amd64 NVIDIA Container Toolkit Base
rc nvidia-dkms-465 465.19.01-0ubuntu1 amd64 NVIDIA DKMS package
iU nvidia-dkms-520 520.61.05-0ubuntu1 amd64 NVIDIA DKMS package
iU nvidia-driver-520 520.61.05-0ubuntu1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-465 465.19.01-0ubuntu1 amd64 Shared files used with the kernel module
iU nvidia-kernel-common-520 520.61.05-0ubuntu1 amd64 Shared files used with the kernel module
iU nvidia-kernel-source-520 520.61.05-0ubuntu1 amd64 NVIDIA kernel source package
iU nvidia-modprobe 520.61.05-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-opencl-dev:amd64 9.1.85-3ubuntu1 amd64 NVIDIA OpenCL development files
ii nvidia-prime 0.8.16~0.18.04.1 all Tools to enable NVIDIA’s Prime
iU nvidia-settings 520.61.05-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
iU nvidia-utils-520 520.61.05-0ubuntu1 amd64 NVIDIA driver support binaries
iU xserver-xorg-video-nvidia-520 520.61.05-0ubuntu1 amd64 NVIDIA binary Xorg driver
ls -l /usr/lib/x86_64-linux-gnu/libcuda*
lrwxrwxrwx 1 root root 28 Sep 29 05:22 /usr/lib/x86_64-linux-gnu/libcudadebugger.so.1 → libcudadebugger.so.520.61.05
-rw-r–r-- 1 root root 10934360 Sep 29 01:20 /usr/lib/x86_64-linux-gnu/libcudadebugger.so.520.61.05
lrwxrwxrwx 1 root root 12 Sep 29 05:22 /usr/lib/x86_64-linux-gnu/libcuda.so → libcuda.so.1
lrwxrwxrwx 1 root root 20 Sep 29 05:22 /usr/lib/x86_64-linux-gnu/libcuda.so.1 → libcuda.so.520.61.05
-rw-r–r-- 1 root root 26284256 Sep 29 01:56 /usr/lib/x86_64-linux-gnu/libcuda.so.520.61.05
dkms status
virtualbox, 5.2.42, 5.4.0-126-generic, x86_64: installed
virtualbox, 5.2.42, 5.4.0-72-generic, x86_64: installed
