I installed the JetPack and followed the stpes for installation and evrything went well till the flashing of the target. When it doing the target installation, after I put it in the reovery mode(lsusb detected Nvida corp), it shows the bootrom communication failed.
What will be causing this issue? even I tried the following steps, there also it failed with the same issue
Download the latest L4T release package and sample file system for your
Jetson Developer Kit from Jetson Linux Archive | NVIDIA Developer.If NVIDIA does not yet provide a public release for the Jetson Developer Kit
you have, please contact your NVIDIA support representative to obtain the
latest L4T release package for use with the Jetson Developer Kit. -
Untar the files and assemble the rootfs with the following commands:
sudo tar xpf ${L4T_RELEASE_PACKAGE}
cd Linux_for_Tegra/rootfs/
sudo tar xpf …/…/${SAMPLE_FS_PACKAGE}
cd …
sudo ./apply_binaries.sh -
Flash the rootfs onto the system’s internal eMMC.
a) Ensure your Linux host system is connected to the Jetson Developer Kit’s
micro-USB port using a USB cable.b) Put your Jetson Developer Kit into “USB Recovery Mode” (RCM). In all
cases, press and hold the “REC” (force recovery) button for the duration
of this step. Then, if your Jetson Developer Kit is powered off, press
and release the “POWERBTN” button, or if your Jetson Developer Kit is
already powered on, press and release the “RST” (reset) button. Finally,
release the “REC” button.c) Install (flash) the L4T release onto the Jetson Developer Kit, by
executing the following command on your Linux host system:sudo ./flash.sh ${BOARD} mmcblk0p1
Please help me to resolve this
Regards
–Liju
