I am new to CUDA programming and I have written a code under c# which brute forces passwords using SHA256.
Basically what I want to create in CUDA is :
- User will input the SHA256 hashed version of the string.
- The program will generate a random string based from a set of characters [A-C] and Numbers [0-9], and the user will also get to dictate the length of the string to be generated (ex, length 8).
- The program will then hash the randomly generated string and compare it with the provided hashed string before until it finds the correct unhashed version.
- The program should also display the amount of hashes per second and how many strings have been tested.
Is there an existing or a library for this? Thanks!
