Yes, I know, that there are already some CUDA-based MD5 crackers, but I want to show you mine. It can crack only one hash at a time, and the strings’ length is limited to a maximum of 16.
I wanted to minimize memcopies between the host and the gpu, so the strings are generated on the gpu, too (from a unique id, calculated from block/thread-ids… more details in the source code).
On a 8800GTX, it can compute 150-240 million hashes per second. In my solution speed heaviliy depends on string length, that is why the huge gap between those numbers exist (240 million is for string length 4-5, 150 million is for length 16).
You can find the source code (VS2005, and Linux), and binaries (XP32, Vista32, Linux32) on my page (at the bottom): HERE
I have VS2005 Professional, so I haven’t tried to buid the project with Express… I will download it, and try to figure out, what the problem is… besides, I don’t even know what that “D:/Bld/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/lower_name.c” is, in the error message…
about the environment variable: I thought, that it has been set by the CUDA SDK/Toolkit, but this appears to be wrong… I am using the CUDA VS2005 Wizard… this wizard adds two environment variables, $(CUDA_COMMON_LIB_PATH) and $(CUDA_COMMON_INC_PATH)… the first is common/lib directory in the CUDA SDK folder, and the second is the common/inc… you either have to install the wizard, or have to set these environment variables manually in order to successfully build the source…
as I’ve said, I am using the CUDA VS2005 Wizard… I suggest, that you install it, it has the proper build rule file… if you don’t want to install it, you can still extract the build rule from the installer…
I have the CUDA 2.0 BETA2 too, so this should not be a problem…
I am sorry, but I don’t have a clue, what can couse the error… I’ve tried
to build the project on one of my friends computer, and it succeded…
Do you know, what that “D:/Bld/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/lower_name.c” in the error message, you posted? That source file has nothing to do with with my project (I don’t even have a lower_name.c on my machine), so I don’t understand, how it can appear in the error message…
There is no “D:/Bld/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/lower_name.c” at all in my computer. I also don"t know why it appears this error message.
There is additional dialog box that shows “cudafe.exe has some problem and is closed” when I compile the code.
Therefore, I think it is the reasion of cudafe.exe from CUDA Toolkit.
Could you please provide me your cudafe.exe? Thanks!
cuMD5.cpp: In constructor ‘cuMD5::cuMD5(int, char**)’:
cuMD5.cpp:28: error: ‘memset’ was not declared in this scope
cuMD5.cpp: In member function ‘void cuMD5::Crack()’:
cuMD5.cpp:142: error: ‘memset’ was not declared in this scope
make: *** [obj/release/cuMD5.cpp_o] Error 1
I’m using openSUSE 11.0 and tried various g++ from repositories but nothing helped.
Adding #include in cuMD5.h leads to other errors like “__builtin_memchr is undefined” etc.
I was trying to add some STL code in a .cu file and bumped on this crazy problem!
Installing VS2005 SP1 solves the problem! Thanks to this thread! I was able to fix it.
APart from this, to avoid linker problems with (libcmt.lib and the likes), one needs to give proper host-compiler options to NVCC. Especially the /MDd, /MD options and the likes…
The best way is to find out what VC++ uses ( from the prperty pages) for the “build configuration (debug/release)” and use them as they are in host-compiler option of nvcc… The only exception is the /TC and /TP options – NVCC uses /TC to call for C compilation and /TP for C++ compilation. So, stay away from that option. Conflicting options passed to CL can cause your compile to break. I have seen it happen.
./cuMD5 -verbose --start=6 --stop=6 456a1da80bc4e241f239d111c10ecc21
Using GeForce 8600 GTS as CUDA device
Actual length is 6.
Total time: 602.236ms - 33554432 keys have been tried in this pass.
Total time: 1206.24ms - 67108864 keys have been tried in this pass.
blablabla
Total time: 647353ms - 35970351104 keys have been tried in this pass.
Total time: 647957ms - 36003905536 keys have been tried in this pass.
Total time: 648561ms - 36037459968 keys have been tried in this pass.
### cuMD5 test ###
First test. Parameters: -verbose --start=1 --stop=5 832e8f2cbdf84ecbe56c354b2c2be6d1
Actual length is 1.
Total time: 432.746ms - 33554432 keys have been tried in this pass.
Actual length is 2.
Total time: 899.18ms - 33554432 keys have been tried in this pass.
Actual length is 3.
Total time: 1399.85ms - 33554432 keys have been tried in this pass.
Actual length is 4.
Total time: 1932.19ms - 33554432 keys have been tried in this pass.
Actual length is 5.
Total time: 2500.39ms - 33554432 keys have been tried in this pass.
Total time: 3070.65ms - 67108864 keys have been tried in this pass.
Total time: 3639.81ms - 100663296 keys have been tried in this pass.
Total time: 4210.26ms - 134217728 keys have been tried in this pass.
Total time: 4778.57ms - 167772160 keys have been tried in this pass.
Total time: 5349.28ms - 201326592 keys have been tried in this pass.
Total time: 5918.89ms - 234881024 keys have been tried in this pass.
Total time: 6489.84ms - 268435456 keys have been tried in this pass.
Total time: 7058.59ms - 301989888 keys have been tried in this pass.
Total time: 7628.6ms - 335544320 keys have been tried in this pass.
Total time: 8198.68ms - 369098752 keys have been tried in this pass.
Total time: 8770.16ms - 402653184 keys have been tried in this pass.
Total time: 9339.38ms - 436207616 keys have been tried in this pass.
Total time: 9909.87ms - 469762048 keys have been tried in this pass.
Total time: 10479.3ms - 503316480 keys have been tried in this pass.
Total time: 11050.1ms - 536870912 keys have been tried in this pass.
Total time: 11619.8ms - 570425344 keys have been tried in this pass.
Total time: 12190.7ms - 603979776 keys have been tried in this pass.
Total time: 12760.6ms - 637534208 keys have been tried in this pass.
Total time: 13330.7ms - 671088640 keys have been tried in this pass.
Total time: 13900.9ms - 704643072 keys have been tried in this pass.
Total time: 14472.3ms - 738197504 keys have been tried in this pass.
Total time: 15042.7ms - 771751936 keys have been tried in this pass.
Total time: 15613.2ms - 805306368 keys have been tried in this pass.
Total time: 16183.9ms - 838860800 keys have been tried in this pass.
Total time: 16754.6ms - 872415232 keys have been tried in this pass.
Total time: 17323.2ms - 905969664 keys have been tried in this pass.
Total time: 17893.6ms - 939524096 keys have been tried in this pass.
Hash has been cracked! Keyword is: t0M49
Second test. Parameters: -verbose --start=8 --stop=8 9a2a6d9b9f2564a56c3e5b0b79a73a22
Actual length is 8.
Total time: 668.347ms - 33554432 keys have been tried in this pass.
Hash has been cracked! Keyword is: abbaaaaa
Third test. Parameters: -verbose --start=16 --stop=16 c208d39194fcac5bbec375e58d603c2a
Actual length is 16.
Total time: 971.638ms - 33554432 keys have been tried in this pass.
Hash has been cracked! Keyword is: abbaaaaaaaaaaaaa
and
start_crack = vineri 1 ianuarie 2010, 10:04:02 +0200
pwd_to_crack = t1st
md5_pwd = 2d0e79a978805814f5e6cd56bd5dd2bf -
./cuMD5 -verbose --start=4 --stop=4 2d0e79a978805814f5e6cd56bd5dd2bf - | tee -a ../cuMD5_set_002_log
Actual length is 4.
Total time: 532.442ms - 33554432 keys have been tried in this pass.
Hash has been cracked! Keyword is: t1st
stop_crack = vineri 1 ianuarie 2010, 10:04:03 +0200
start_crack = vineri 1 ianuarie 2010, 10:04:19 +0200
pwd_to_crack = round
md5_pwd = 9bbd993d9da7df60b3fd4a4ed721b082 -
./cuMD5 -verbose --start=5 --stop=5 9bbd993d9da7df60b3fd4a4ed721b082 - | tee -a ../cuMD5_set_002_log
Actual length is 5.
Total time: 568.306ms - 33554432 keys have been tried in this pass.
Total time: 1138.57ms - 67108864 keys have been tried in this pass.
Hash has been cracked! Keyword is: round
stop_crack = vineri 1 ianuarie 2010, 10:04:21 +0200
start_crack = vineri 1 ianuarie 2010, 10:07:09 +0200
pwd_to_crack = HaX0r
md5_pwd = 94698ac65d1aa7f5bb0f99a602fc5346 -
./cuMD5 -verbose --start=5 --stop=5 94698ac65d1aa7f5bb0f99a602fc5346 - | tee -a ../cuMD5_set_002_log
Actual length is 5.
Total time: 568.287ms - 33554432 keys have been tried in this pass.
Total time: 1707.75ms - 100663296 keys have been tried in this pass.
Total time: 2278.19ms - 134217728 keys have been tried in this pass.
Total time: 2846.47ms - 167772160 keys have been tried in this pass.
Total time: 3417.18ms - 201326592 keys have been tried in this pass.
Total time: 3986.82ms - 234881024 keys have been tried in this pass.
Total time: 4557.78ms - 268435456 keys have been tried in this pass.
Hash has been cracked! Keyword is: HaX0r
stop_crack = vineri 1 ianuarie 2010, 10:07:14 +0200
and so on …
until now only HaX_0r bring an error response … External Image
anyone else can confirm this error with HaX_0r password test?
