Yesterday, I found a bug with the function “EOSHIFT (ARRAY, SHIFT [, BOUNDARY, DIM]” by using Fortran , when the SHIFT = 0 , the ARRAY should not be changed. However, in this edition, the values in ARRAY will be changed to 0.
Hi willkong,
Do you have a reproducing example you could post or send to PGI Customer Service (trs@pgroup.com)?
Thanks,
Mat
Yes, a example as follows
PROGRAM MAIN
IMPLICIT NONE
INTEGER :: I, A(5)
DO I =1,5
A(I) = I
ENDDO
A(1:5) = EOSHIFT(A(1:5),0)
PRINT *, A
END PROGRAM
ifort : 1 2 3 4 5
gfortran : 1 2 3 4 5
pgfortran : 0 0 0 0 0
Great, thanks!
I’ve added a problem report (TPR#26667) and sent to our compiler engineers for further investigation.
-Mat
