I use CUDALibrarySamples/cuSPARSELt/matmul/matmul_example.cpp at master · NVIDIA/CUDALibrarySamples · GitHub for my experiments.
And I saw that if we select FP8, we cannot use a matrix A (the matrix which will be compressed) larger than with 2^31 - 1 elements.
However, it works using FP16.
The problem comes from cusparseLtSpMMACompressedSize. Without returning error, if the number of elems is more than 2^31 (I used m=n=k=65536), it will return compressedSize[out] = max(size_t)=2^64.
which causes an alloc of memory of 17x10^9 GB which of course, ends with a COOM
Here is the error :
compressed_size: 18446744072098938880, compressed_buffer_size: 49216
CUDA API failed at line 266 with error: out of memory (2)
Here you can see the error in the CuSparseLt log :
[2026-01-30 23:25:48][CUSPARSELT][268854][Api][cusparseLtSpMMACompressedSize] plan[in]={ptr=0x7fffffffaca0, matmul={ptr=0x7fffffffa8a0, m=65536, n=65536, k=65536, opA=NON_TRANSPOSE, opB=TRANSPOSE, matA={ptr=0x7fffffffa2a0, format=Structured, rows=65536, cols=65536, ld=65536, alignment=16, valuesType=CUDA_R_8F_E4M3}, matB={ptr=0x7fffffffa4a0, format=Dense, rows=65536, cols=65536, ld=65536, alignment=16, valuesType=CUDA_R_8F_E4M3}, matC={ptr=0x7fffffffa6a0, format=Dense, rows=65536, cols=65536, ld=65536, alignment=16, valuesType=CUDA_R_16F}, computeType=COMPUTE_32F, is_A_sparse=true, activation=NONE, GeLUScaling=1, reluThreshold=0, reluUpperBound=3.4028235e+38, hasBias=false, alphaVector=false, betaVector=false, biasPointer=0x0, biasStride=0, batchSize=1, batchStride=0}, algSel={ptr=0x7fffffffaaa0, alg=MATMUL_ALG_DEFAULT, algId=0, numAlgorithms=4, searchIters=5, splitKInfo={splitK=-1, splitKMode=CUSPARSELT_HEURISTIC, splitKNumBuffers=0}}}, compressedSize[out]=18446744072098938880
Here is the exact code I use :
* SPDX-FileCopyrightText: Copyright (c) 2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
* SPDX-License-Identifier: Apache-2.0
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include <cuda_runtime_api.h> // cudaMalloc, cudaMemcpy, etc.
#include <cusparseLt.h> // cusparseLt header
#include <cstdio> // printf
#include <cstdlib> // std::rand
#include <cuda_fp8.h>
#define FP16 1000
#define INT8 1001
#define FP8 1002
* Choose your data type for matrices A and B
// #define AB_TYPE FP16
#define AB_TYPE FP8
// #define AB_TYPE INT8
#if AB_TYPE == FP8
using AB_t = __nv_fp8_e4m3;
using C_t = __half;
using COMPUTE_t = float;
#elif AB_TYPE == FP16
using AB_t = __half;
using C_t = __half;
#elif AB_TYPE == INT8
using AB_t = int8_t;
using C_t = int8_t; // can also be __half, __nv_bfloat16, int
using COMPUTE_t = int;
#endif
template <typename value_t>
struct cuda_type { };
template <>
struct cuda_type <__half> {
static constexpr cudaDataType value = CUDA_R_16F;
template <>
struct cuda_type <__nv_bfloat16> {
static constexpr cudaDataType value = CUDA_R_16BF;
template <>
struct cuda_type <__nv_fp8_e4m3> {
static constexpr cudaDataType value = CUDA_R_8F_E4M3;
template <>
struct cuda_type <int8_t> {
static constexpr cudaDataType value = CUDA_R_8I;
template <>
struct cuda_type <int> {
static constexpr cudaDataType value = CUDA_R_32I;
struct cusparse_compute_type { };
template <>
struct cusparse_compute_type<float> {
static constexpr cusparseComputeType value = CUSPARSE_COMPUTE_32F;
template <>
struct cusparse_compute_type<int> {
static constexpr cusparseComputeType value = CUSPARSE_COMPUTE_32I;
#define CHECK_CUDA(func) \
cudaError_t status = (func); \
if (status != cudaSuccess) { \
printf("CUDA API failed at line %d with error: %s (%d)\n", \
__LINE__, cudaGetErrorString(status), status); \
return EXIT_FAILURE; \
#define CHECK_CUSPARSE(func) \
cusparseStatus_t status = (func); \
if (status != CUSPARSE_STATUS_SUCCESS) { \
printf("CUSPARSE API failed at line %d with error: %s (%d)\n", \
__LINE__, cusparseLtGetErrorString(status), status); \
constexpr int EXIT_UNSUPPORTED = 2;
int main(void) {
setenv("CUSPARSELT_LOG_LEVEL", "5", 1);
setenv("CUSPARSELT_LOG_FILE", "cusparseLt.log", 1);
int major_cc, minor_cc;
CHECK_CUDA( cudaDeviceGetAttribute(&major_cc,
cudaDevAttrComputeCapabilityMajor, 0) )
CHECK_CUDA( cudaDeviceGetAttribute(&minor_cc,
cudaDevAttrComputeCapabilityMinor, 0) )
if (!(major_cc == 8 && minor_cc == 0) &&
!(major_cc == 8 && minor_cc == 6) &&
!(major_cc == 8 && minor_cc == 7) &&
!(major_cc == 8 && minor_cc == 9) &&
!(major_cc == 9 && minor_cc == 0) &&
!(major_cc == 10 && minor_cc == 0) &&
!(major_cc == 10 && minor_cc == 1) &&
!(major_cc == 11 && minor_cc == 0) &&
!(major_cc == 12 && minor_cc == 0) &&
!(major_cc == 12 && minor_cc == 1)) {
std::printf("\ncusparseLt is supported only on GPU devices with"
" compute capability == 8.0, 8.6, 8.7, 8.9, 9.0 10.0 10.1 110 12.0 12.1 current: %d.%d\n\n",
major_cc, minor_cc);
return EXIT_UNSUPPORTED;
// Host problem definition, row-major order
// bigger sizes may require dynamic allocations
constexpr int m = 65536;
constexpr int n = 65536;
constexpr int k = 65536;
auto order = CUSPARSE_ORDER_ROW;
auto opA = CUSPARSE_OPERATION_NON_TRANSPOSE;
auto opB = CUSPARSE_OPERATION_TRANSPOSE;
auto type_AB = cuda_type<AB_t>::value;
auto type_C = cuda_type<C_t>::value;
auto compute_type = cusparse_compute_type<COMPUTE_t>::value;
bool matmul_search = true;
bool is_rowmajor = (order == CUSPARSE_ORDER_ROW);
bool isA_transposed = (opA != CUSPARSE_OPERATION_NON_TRANSPOSE);
bool isB_transposed = (opB != CUSPARSE_OPERATION_NON_TRANSPOSE);
auto num_A_rows = (isA_transposed) ? k : m;
auto num_A_cols = (isA_transposed) ? m : k;
auto num_B_rows = (isB_transposed) ? n : k;
auto num_B_cols = (isB_transposed) ? k : n;
auto num_C_rows = m;
auto num_C_cols = n;
unsigned alignment = 16;
auto lda = (is_rowmajor) ? num_A_cols : num_A_rows;
auto ldb = (is_rowmajor) ? num_B_cols : num_B_rows;
auto ldc = (is_rowmajor) ? num_C_cols : num_C_rows;
auto A_height = (is_rowmajor) ? num_A_rows : num_A_cols;
auto B_height = (is_rowmajor) ? num_B_rows : num_B_cols;
auto C_height = (is_rowmajor) ? num_C_rows : num_C_cols;
size_t A_size = (size_t)A_height * lda * sizeof(AB_t);
size_t B_size = (size_t)B_height * ldb * sizeof(AB_t);
size_t C_size = (size_t)C_height * ldc * sizeof(C_t);
auto hA = new AB_t[(size_t)A_height * lda];
auto hB = new AB_t[(size_t)B_height * ldb];
auto hC = new C_t[(size_t)C_height * ldc];
for (size_t i = 0; i < (size_t)m * k; i++)
hA[i] = static_cast<AB_t>(static_cast<float>(std::rand() % 5 - 2)); // -2 ~ 2
for (size_t i = 0; i < (size_t)k * n; i++)
hB[i] = static_cast<AB_t>(static_cast<float>(std::rand() % 5 - 2));
for (size_t i = 0; i < (size_t)m * n; i++)
hC[i] = static_cast<C_t>(static_cast<float>(std::rand() % 5 - 2));
float alpha = 1.0f;
float beta = 1.0f;
// Device memory management
AB_t* dA, *dB, *dA_compressed;
C_t* dC, *dD;
int *d_valid;
CHECK_CUDA( cudaMalloc((void**) &dA, A_size) )
CHECK_CUDA( cudaMalloc((void**) &dB, B_size) )
CHECK_CUDA( cudaMalloc((void**) &dC, C_size) )
CHECK_CUDA( cudaMalloc((void**) &d_valid, sizeof(int)) )
dD = dC;
CHECK_CUDA( cudaMemcpy(dA, hA, A_size, cudaMemcpyHostToDevice) )
CHECK_CUDA( cudaMemcpy(dB, hB, B_size, cudaMemcpyHostToDevice) )
CHECK_CUDA( cudaMemcpy(dC, hC, C_size, cudaMemcpyHostToDevice) )
cusparseLtHandle_t handle;
cusparseLtMatDescriptor_t matA, matB, matC;
cusparseLtMatmulDescriptor_t matmul;
cusparseLtMatmulAlgSelection_t alg_sel;
cusparseLtMatmulPlan_t plan;
cudaStream_t stream = nullptr;
CHECK_CUSPARSE( cusparseLtInit(&handle) )
// matrix descriptor initialization
CHECK_CUSPARSE( cusparseLtStructuredDescriptorInit(
&handle, &matA, num_A_rows,
num_A_cols, lda, alignment,
type_AB, order,
CUSPARSELT_SPARSITY_50_PERCENT) )
CHECK_CUSPARSE( cusparseLtDenseDescriptorInit(
&handle, &matB, num_B_rows,
num_B_cols, ldb, alignment,
type_AB, order) )
&handle, &matC, num_C_rows,
num_C_cols, ldc, alignment,
type_C, order) )
// matmul, algorithm selection, and plan initialization
CHECK_CUSPARSE( cusparseLtMatmulDescriptorInit(
&handle, &matmul, opA, opB,
&matA, &matB, &matC, &matC,
compute_type) )
CHECK_CUSPARSE( cusparseLtMatmulAlgSelectionInit(
&handle, &alg_sel, &matmul,
CUSPARSELT_MATMUL_ALG_DEFAULT) )
CHECK_CUSPARSE( cusparseLtMatmulPlanInit(&handle, &plan, &matmul, &alg_sel))
CHECK_CUSPARSE(cusparseLtMatmulDescSetAttribute(&handle,
&matmul,
CUSPARSELT_MATMUL_SPARSE_MAT_POINTER,
&dA,
sizeof(dA)));
// Prune the A matrix (in-place) and check the correctness
CHECK_CUSPARSE( cusparseLtSpMMAPrune(&handle, &matmul, dA, dA,
CUSPARSELT_PRUNE_SPMMA_TILE, stream) )
CHECK_CUSPARSE( cusparseLtSpMMAPruneCheck(&handle, &matmul, dA,
d_valid, stream) )
int is_valid;
CHECK_CUDA( cudaMemcpyAsync(&is_valid, d_valid, sizeof(int),
cudaMemcpyDeviceToHost, stream) )
CHECK_CUDA( cudaStreamSynchronize(stream) )
if (is_valid != 0) {
std::printf("!!!! The matrix has been pruned in a wrong way. "
"cusparseLtMatmul will not provide correct results\n");
// Compress the A matrix
size_t compressed_size, compressed_buffer_size;
void* dA_compressedBuffer;
CHECK_CUSPARSE( cusparseLtSpMMACompressedSize(&handle, &plan,
&compressed_size,
&compressed_buffer_size) )
printf("compressed_size: %zu, compressed_buffer_size: %zu\n", compressed_size, compressed_buffer_size);
CHECK_CUDA( cudaMalloc((void**) &dA_compressed, compressed_size) )
CHECK_CUDA( cudaMalloc((void**) &dA_compressedBuffer,
CHECK_CUSPARSE( cusparseLtSpMMACompress(&handle, &plan, dA, dA_compressed,
dA_compressedBuffer,stream) )
// Search the best kernel
int num_streams = 0;
cudaStream_t* streams = nullptr;
if (matmul_search) {
CHECK_CUSPARSE( cusparseLtMatmulSearch(&handle, &plan, &alpha,
dA_compressed, dB, &beta,
dC, dD, nullptr,
streams, num_streams) )
// dC accumulates so reset dC for correctness check
size_t workspace_size;
CHECK_CUSPARSE( cusparseLtMatmulGetWorkspace(&handle, &plan,
&workspace_size))
void* d_workspace;
CHECK_CUDA( cudaMalloc((void**) &d_workspace, workspace_size) )
// Perform the matrix multiplication
CHECK_CUSPARSE( cusparseLtMatmul(&handle, &plan, &alpha, dA_compressed, dB,
&beta, dC, dD, d_workspace, streams,
num_streams) )
// destroy plan and handle
CHECK_CUSPARSE( cusparseLtMatDescriptorDestroy(&matA) )
CHECK_CUSPARSE( cusparseLtMatDescriptorDestroy(&matB) )
CHECK_CUSPARSE( cusparseLtMatDescriptorDestroy(&matC) )
CHECK_CUSPARSE( cusparseLtMatmulAlgSelectionDestroy(&alg_sel) )
CHECK_CUSPARSE( cusparseLtMatmulPlanDestroy(&plan) )
CHECK_CUSPARSE( cusparseLtDestroy(&handle) )
// // device result check
// // matrix A has been pruned
// CHECK_CUDA( cudaMemcpy(hA, dA, A_size, cudaMemcpyDeviceToHost) )
// bool A_std_layout = (is_rowmajor != isA_transposed);
// bool B_std_layout = (is_rowmajor != isB_transposed);
// // host computation
// C_t* hC_result = new C_t[C_height * ldc];
// for (int i = 0; i < m; i++) {
// for (int j = 0; j < n; j++) {
// COMPUTE_t sum = static_cast<COMPUTE_t>(0);
// for (int k1 = 0; k1 < k; k1++) {
// auto posA = (A_std_layout) ? static_cast<size_t>(i) * lda + k1 : i + k1 * lda;
// auto posB = (B_std_layout) ? static_cast<size_t>(k1) * ldb + j : k1 + j * ldb;
// sum += static_cast<COMPUTE_t>(hA[posA]) * // [i][k]
// static_cast<COMPUTE_t>(hB[posB]); // [k][j]
// auto posC = (is_rowmajor) ? i * ldc + j : i + j * ldc;
// hC_result[posC] = static_cast<C_t>(alpha * sum + beta * static_cast<float>(hC[posC])); // [i][j]
// // reuse hC for device results
// CHECK_CUDA( cudaMemcpy(hC, dD, C_size, cudaMemcpyDeviceToHost) )
// // host-device comparison
// int correct = 1;
// auto pos = (is_rowmajor) ? i * ldc + j : i + j * ldc;
// auto device_value = hC[pos];
// auto host_value = hC_result[pos];
// if (device_value != host_value) {
// // direct floating point comparison is not reliable
// std::printf("(%d, %d):\t%3.0f vs. %3.0f\n",
// i, j, static_cast<float>(host_value), static_cast<float>(device_value));
// correct = 0;
// break;
// if (correct) {
// std::printf("matmul_example test PASSED\n");
// else {
// std::printf("matmul_example test FAILED: wrong result\n");
// host memory deallocation
delete[] hA;
delete[] hB;
delete[] hC;
// delete[] hC_result;
// device memory deallocation
CHECK_CUDA( cudaFree(dA_compressed) )
CHECK_CUDA( cudaFree(dA) )
CHECK_CUDA( cudaFree(dB) )
CHECK_CUDA( cudaFree(dC) )
CHECK_CUDA( cudaFree(d_valid) )
CHECK_CUDA( cudaFree(d_workspace) )
CHECK_CUDA( cudaFree(dA_compressedBuffer) )
return EXIT_SUCCESS;
I’m on Blackwell GPUs.
I use Cuda 13.1 with cusparselt 0.8.1+cu13.
Here is the compile command :
nvcc -O3 -std=c++17 \
-I.. \
matmul_example.cpp \
-lcusparseLt -lcudart -lcublas \
-arch=sm_120 \
-o gemm
As I don’t have access to the code of the function, I don’t understand how this result can be possible.
Pls let me know if it’s actually a bug or if I did something wrong.
Thank you for your answer.
