Hello, I am trying to implement an iterative solver using incomplete LU factorization with sparse matrices. My code works perfectly for a 1000x1000 system with 3750 non zero elements. But when the input is a 31287x31287 system with 2467643 non zero elements, the code stalls after the call to cusparseScsrilu02. What I mean by that is
- I can not copy any data from device to host
- Code stalls at SpSvanalysis and seems to run for ever
- Calling cudaDeviceSynchronize after cusparseScsrilu02 freezes the program
I have used a text-difference programm (that incluced in VSCode) to check that I read the csr matrices correctly. Bellow is the function I am using.
SparseMatrix contains these elements:
typedef struct
- double *values; // element values
- int *row_idx; // cumulative elements of each row → last elements equals NNZ
- int *col_idx; // column indices of the elements
- int size; // Matrix size (assuming square matrices only)
and Vector struct:
- int size; // Vector size
Bellow is my function:
void solveSystemSparseIterative(SparseMatrix *mat, Vector *B, double *X, double tolerance)
int n = mat->size;
int nnz = mat->row_idx[n];
int maxIters = 5000;
// create float copy of system elements
float * host_float_values = (float *)malloc(nnz * sizeof(float));
float *host_float_rhs = (float *)malloc(n * sizeof(float));
double *zeros = (double *)malloc(n * sizeof(double));
float *tempf = (float *)malloc(nnz * sizeof(float));
double *tempd = (double *)malloc(nnz * sizeof(double));
int maxThreads, blocks, threads;
threads = 256;
if (nnz > threads)
maxThreads = threads;
blocks = nnz / maxThreads + 1;
else
blocks = 1;
maxThreads = nnz;
blocks = 1;
for (int i = 0; i < n; i++)
host_float_rhs[i] = B->values[i];
zeros[i] = 0.0;
for (int i = 0; i < nnz; i++)
host_float_values[i] = mat->values[i];
// INITIALIZE CUSOLVER
cusparseHandle_t sparseHandle = NULL;
cublasHandle_t blasHandle;
cudaStream_t stream = NULL;
// cusparseStatus_t status;
cusparseCreate(&sparseHandle);
cublasCreate(&blasHandle);
cudaStreamCreate(&stream);
// ALLOCATE MEMORY
double *Xcalculated = (double *)malloc(n * sizeof(double));
double *temp = (double *)malloc(nnz * sizeof(double));
double *Lvalues, *Uvalues, *Avalues, *solution, *rhs, *rhsCopy, *temp_solutionX, *temp_solutionY;
float *f_values;
int *rowPtr, *colIdx, *rowPtrCopy, *colIdxCopy;
checkCudaErrors(cudaMalloc((void **)&Uvalues, nnz * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&Lvalues, nnz * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&Avalues, nnz * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&rhs, n * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&rhsCopy, n * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&solution, n * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&temp_solutionX, n * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&temp_solutionY, n * sizeof(double)));
checkCudaErrors(cudaMalloc((void **)&f_values, nnz * sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&rowPtr, (n + 1) * sizeof(int)));
checkCudaErrors(cudaMalloc((void **)&rowPtrCopy, (n + 1) * sizeof(int)));
checkCudaErrors(cudaMalloc((void **)&colIdx, nnz * sizeof(int)));
checkCudaErrors(cudaMalloc((void **)&colIdxCopy, nnz * sizeof(int)));
// COPY MATRIX A TO DEVICE MEMORY
checkCudaErrors(cudaMemcpy(rowPtr, mat->row_idx, (n + 1) * sizeof(int), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(colIdx, mat->col_idx, nnz * sizeof(int), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(rowPtrCopy, rowPtr, (n + 1) * sizeof(int), cudaMemcpyDeviceToDevice));
checkCudaErrors(cudaMemcpy(colIdxCopy, colIdx, nnz * sizeof(int), cudaMemcpyDeviceToDevice));
// COPY FLOAT MATRIX ELEMENTS
checkCudaErrors(cudaMemcpy(f_values, host_float_values, nnz * sizeof(float), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(Avalues, mat->values, nnz * sizeof(double), cudaMemcpyHostToDevice));
// COPY FLOAT B ELEMENTS
// cudaMemcpy(rhs, B->values, n, cudaMemcpyHostToDevice);
checkCudaErrors(cudaMemcpy(rhs, B->values, n * sizeof(double), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(rhsCopy, rhs, n * sizeof(double), cudaMemcpyDeviceToDevice));
// INIT EMPTY VECTOR
checkCudaErrors(cudaMemcpy(temp_solutionX, zeros, n * sizeof(double), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(temp_solutionY, temp_solutionX, n * sizeof(double), cudaMemcpyDeviceToDevice));
// SETUP MATRIX DESCRIPTOR
cusparseMatDescr_t descrA;
cusparseCreateMatDescr(&descrA);
cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ZERO);
// INITIALIZE VARIABLES FOR LU FACTORIZATION
int pBufferSize;
size_t spSvBufferSizeL, spSvBufferSizeU;
void *pBuffer, *spSvBufferL, *spSvBufferU;
// int structural_zero, numerical_zero;
cusparseSolvePolicy_t policy = CUSPARSE_SOLVE_POLICY_NO_LEVEL;
csrilu02Info_t LUinfo;
cusparseCreateCsrilu02Info(&LUinfo);
double tole = 0;
float boost = 1e-8;
checkCudaErrors(cusparseScsrilu02_numericBoost(sparseHandle, LUinfo, 1, &tole, &boost));
printf("Buffer size..\n");
// CALCULATE LU FACTORIZATION BUFFER SIZE
checkCudaErrors(cusparseScsrilu02_bufferSize(sparseHandle, n, nnz, descrA,f_values, rowPtr, colIdx, LUinfo,&pBufferSize));
checkCudaErrors(cudaMalloc(&pBuffer, pBufferSize));
// pBuffer returned by cudaMalloc is automatically aligned to 128 bytes
printf("Buffer size for LU is %d\n",pBufferSize);
printf("Analysis..\n");
// LU FACTORIZATION ANALYSIS
checkCudaErrors(cusparseScsrilu02_analysis(sparseHandle, n, nnz, descrA,f_values, rowPtr, colIdx, LUinfo, policy, pBuffer));
int structural_zero;
status = cusparseXcsrilu02_zeroPivot(sparseHandle, LUinfo, &structural_zero);
if (CUSPARSE_STATUS_ZERO_PIVOT == status)
printf("A(%d,%d) is missing\n", structural_zero, structural_zero);
printf("Factorization..\n");
// A = L * U
checkCudaErrors(cusparseScsrilu02(sparseHandle, n, nnz, descrA, f_values, rowPtr, colIdx, LUinfo, policy, pBuffer));
f_values now contain L U matrices
cusparseDestroyMatDescr(descrA);
cudaFree(pBuffer);
cusparseDestroyCsrilu02Info(LUinfo);
cudaError_t err;
printf("Convert to double..\n");
//DEVICE TYPECAST
floatToDoubleVector<<<blocks, maxThreads>>>(f_values, Lvalues, nnz);
checkCudaErrors(cudaMemcpy(Uvalues, Lvalues, nnz * sizeof(double), cudaMemcpyDeviceToDevice));
printf("\ndone converting..\n");
cusparseSpMatDescr_t descrL, descrU, descrACopy;
// Create a copy of A to calculate residual r = b - Ax
cusparseCreateCsr(&descrACopy, n, n, nnz, rowPtrCopy, colIdxCopy, Avalues, CUSPARSE_INDEX_32I,
CUSPARSE_INDEX_32I, CUSPARSE_INDEX_BASE_ZERO, CUDA_R_64F);
cusparseCreateCsr(&descrL, n, n, nnz, rowPtr, colIdx, Lvalues, CUSPARSE_INDEX_32I,
cusparseCreateCsr(&descrU, n, n, nnz, rowPtr, colIdx, Uvalues, CUSPARSE_INDEX_32I,
printf("Set attributes..\n");
cusparseFillMode_t lower = CUSPARSE_FILL_MODE_LOWER;
cusparseDiagType_t unit = CUSPARSE_DIAG_TYPE_UNIT;
cusparseFillMode_t upper = CUSPARSE_FILL_MODE_UPPER;
cusparseDiagType_t nonUnit = CUSPARSE_DIAG_TYPE_NON_UNIT;
cusparseSpMatSetAttribute(descrL, CUSPARSE_SPMAT_FILL_MODE, (void *)&lower, sizeof(lower));
cusparseSpMatSetAttribute(descrL, CUSPARSE_SPMAT_DIAG_TYPE, (void *)&unit, sizeof(unit));
cusparseSpMatSetAttribute(descrU, CUSPARSE_SPMAT_FILL_MODE, (void *)&upper, sizeof(upper));
cusparseSpMatSetAttribute(descrU, CUSPARSE_SPMAT_DIAG_TYPE, (void *)&nonUnit, sizeof(nonUnit));
// INITIALIZE B,X,Y VECTOR DESCRIPTORS
cusparseDnVecDescr_t descrX, descrY, descrB;
cusparseCreateDnVec(&descrB, n, rhs, CUDA_R_64F);
cusparseCreateDnVec(&descrY, n, temp_solutionY, CUDA_R_64F);
cusparseCreateDnVec(&descrX, n, temp_solutionX, CUDA_R_64F);
// SETUP TRIANGULAR SOLVER DESCRIPTOR
cusparseSpSVDescr_t spsvDescrL, spsvDescrU;
cusparseSpSV_createDescr(&spsvDescrL);
cusparseSpSV_createDescr(&spsvDescrU);
double plusOne = 1.0;
printf("SpSv analysisL.. \n");
checkCudaErrors(cusparseSpSV_bufferSize(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrL, descrB,descrY, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrL, &spSvBufferSizeL));
cudaMalloc((void **)&spSvBufferL, spSvBufferSizeL);
printf("spSvBufferSizeL: %ld\n", spSvBufferSizeL);
checkCudaErrors(cusparseSpSV_analysis(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrL, descrB,descrY, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrL, spSvBufferL));
printf("SpSv analysisU.. \n");
checkCudaErrors(cusparseSpSV_bufferSize(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrU, descrY, descrX, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrU, &spSvBufferSizeU));
cudaMalloc((void **)&spSvBufferU, spSvBufferSizeU);
printf("spSvBufferSizeU: %ld\n", spSvBufferSizeU);
checkCudaErrors(cusparseSpSV_analysis(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrU, descrY, descrX, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrU, spSvBufferU));
printf("SpSv solve L.. \n");
// solve L*y = b
checkCudaErrors(cusparseSpSV_solve(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrL, descrB,descrY, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrL));
printf("SpSv solve U.. \n");
// solve U*x = y
checkCudaErrors(cusparseSpSV_solve(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrU, descrY, descrX, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrU));
printf("enter loop\n");
for (int i = 0; i < maxIters; i++)
double minusOne = -1.0;
double one = 1.0;
size_t spMvBufferSize = 0;
void *spMvBuffer;
// CALCULATE RESIDUAL and store it on B vector
cusparseSpMV_bufferSize(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &minusOne, descrACopy, descrX, &one, descrB, CUDA_R_64F, CUSPARSE_SPMV_CSR_ALG2, &spMvBufferSize);
cudaMalloc(&spMvBuffer, spMvBufferSize);
cusparseSpMV(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &minusOne, descrACopy, descrX, &one, descrB, CUDA_R_64F, CUSPARSE_SPMV_CSR_ALG2, spMvBuffer);
// CUBLAS NORM
double resNormm, bNorm;
cublasDnrm2(blasHandle, n, rhs, 1, &resNormm);
cublasDnrm2(blasHandle, n, rhsCopy, 1, &bNorm);
if ((resNormm / bNorm) < tolerance)
printf("Iters: %d\n", i);
break;
// solve L*y = r : B contains the residual
// solve U*c = y
checkCudaErrors(cusparseSpSV_solve(sparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, &plusOne, descrU, descrY,descrX, CUDA_R_64F, CUSPARSE_SPSV_ALG_DEFAULT, spsvDescrU));
// Xn+1 = Xn + Cn
cublasDaxpy(blasHandle, n, &one, temp_solutionX, 1, solution, 1);
cudaMemcpy(temp_solutionX, solution, n * sizeof(double), cudaMemcpyDeviceToDevice);
// restore B values
cudaMemcpy(rhs, rhsCopy, n * sizeof(double), cudaMemcpyDeviceToDevice);
// TRANSFER SOLUTION TO X VECTOR
cudaMemcpy(X, temp_solutionX, n * sizeof(double), cudaMemcpyHostToDevice);
cusparseDestroyDnVec(descrX);
cusparseDestroyDnVec(descrY);
cusparseDestroyDnVec(descrB);
cusparseSpSV_destroyDescr(spsvDescrL);
cusparseSpSV_destroyDescr(spsvDescrU);
cusparseDestroy(sparseHandle);
cudaMemcpy(X, solution, n * sizeof(double), cudaMemcpyDeviceToHost);
// FREE RESOURCES
