I want to run the CuSolver Sparse on fortran. I am no stranger to writing it in C but I seen to have problems interfacing it with Fortran. I’ve been trying to modify the attached CuSolverDn Fortran as a starting point.
Please provide me some guidance on this matter. Thank you.
Attached: CuSolverDn fortran
!Interface to cusolverDn and CUDA C functions
module cuda_cusolver
interface
! cudaMalloc
integer (c_int) function cudaMalloc ( buffer, size ) bind (C, name="cudaMalloc" )
use iso_c_binding
implicit none
type (c_ptr) :: buffer
integer (c_size_t), value :: size
end function cudaMalloc
! cudaMemcpy
integer (c_int) function cudaMemcpy ( dst, src, count, kind ) bind (C, name="cudaMemcpy" )
! note: cudaMemcpyHostToDevice = 1
! note: cudaMemcpyDeviceToHost = 2
use iso_c_binding
type (C_PTR), value :: dst, src
integer (c_size_t), value :: count, kind
end function cudaMemcpy
! cudaFree
integer (c_int) function cudaFree(buffer) bind(C, name="cudaFree")
use iso_c_binding
implicit none
type (C_PTR), value :: buffer
end function cudaFree
integer (c_int) function cudaMemGetInfo(fre, tot) bind(C, name="cudaMemGetInfo")
use iso_c_binding
implicit none
type(c_ptr),value :: fre
type(c_ptr),value :: tot
end function cudaMemGetInfo
integer(c_int) function cusolverDnCreate(cusolver_Hndl) bind(C,name="cusolverDnCreate")
use iso_c_binding
implicit none
type(c_ptr)::cusolver_Hndl
end function
integer(c_int) function cusolverDnDestroy(cusolver_Hndl) bind(C,name="cusolverDnDestroy")
use iso_c_binding
implicit none
type(c_ptr),value::cusolver_Hndl
end function
integer(c_int) function cusolverDnSgetrf_bufferSize(cusolver_Hndl,m,n,d_A,lda,Lwork) bind(C,name="cusolverDnSgetrf_bufferSize")
use iso_c_binding
implicit none
integer(c_int),value::m
integer(c_int),value::n
type(c_ptr),value::d_A
integer(c_int),value::lda
type(c_ptr),value::Lwork
end function
integer(c_int) function cusolverDnSgetrf(cusolver_Hndl,m,n,d_A,lda,d_WS,d_Ipiv,d_devInfo) bind(C, name="cusolverDnSgetrf")
use iso_c_binding
implicit none
type(c_ptr),value::d_WS
type(c_ptr),value::d_Ipiv
type(c_ptr),value::d_devInfo
end function
integer (c_int) function cusolverDnSgetrs(cusolver_Hndl,trans,n,nrhs,d_A,lda,d_Ipiv,d_B,ldb,d_devInfo) bind(C, name="cusolverDnSgetrs")
use iso_c_binding
implicit none
integer(c_int), value::trans
integer(c_int), value::n
integer(c_int), value::nrhs
integer(c_int), value::lda
type(c_ptr),value::d_B
integer(c_int),value::ldb
end function
end interface
end module
program main
! The purpose of this routine is to provide for GPU based solution of
! large dense systems of equations in legacy FORTRAN Applications.
! This is the development version of the routine which does not yet work ...
!cudaGetDeviceCount(nDevices)
use iso_c_binding
use cuda_cusolver
! ------------- matrix definition & host CPU storage variables
integer(c_int) m,n,lda,ldb
real, allocatable :: A(:,:)!,ATest(:,:)
real, allocatable :: B(:,:)
real, allocatable :: X(:,:)
integer, allocatable::Ipiv(:)
integer, target::Lwork
real, allocatable :: IRN(:), JCN(:), val(:)
!-------------------- CPU equivalents of device variables
integer devInfo
integer(c_int) nrhs
integer X_size
integer*8 Ipiv_size,devInfo_size,Lwork_size
integer*8 A_size,B_size,Workspace
! -------------------- handle to device
type(c_ptr) :: cusolver_Hndl
! -------------------- pointers to device memory
type(c_ptr)::d_A
type(c_ptr)::d_B
type(c_ptr)::d_Lwork
type(c_ptr)::d_WS
type(c_ptr)::d_Ipiv
type(c_ptr)::d_devInfo
! --------------------- function result variables
integer cusolver_stat
integer A_mem_stat
integer B_mem_stat
integer X_mem_stat
integer Ipiv_mem_stat
integer WS_mem_stat
integer devInfo_mem_stat
integer Lwork_mem_stat
! -------------------- pointers to host CPU memory
type(c_ptr)::CPU_A_ptr
! type(c_ptr)::CPU_ATest_ptr
type(c_ptr)::CPU_B_ptr
type(c_ptr)::CPU_X_ptr
type(c_ptr)::CPU_Lwork_ptr
target A,B,X,Ipiv !,ATest
type(c_ptr)::cpfre,cptot
integer*8,target::free,total
integer res
integer*8 cudaMemcpyDeviceToHost, cudaMemcpyHostToDevice
integer*4 CUBLAS_OP_N, CUBLAS_OP_T
parameter (cudaMemcpyHostToDevice=1)
parameter (cudaMemcpyDeviceToHost=2)
parameter (CUBLAS_OP_N=0)
parameter (CUBLAS_OP_T=1)
free = 0
total = 0
res = 1
cpfre = c_loc(free)
cptot = c_loc(total)
res = cudaMemGetInfo(cpfre,cptot)
if (res .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMemGetInfo error: ", res
write (*,*)
stop
end if
write (*, '(A, I12)') " free mem: ", free
write (*, '(A, I12)') " total mem: ", total
! open(121, file='Input.dat')
! read(121, *) lda, ldb, nnz
lda = 3
ldb = 3
m=lda
n=ldb
nrhs = 1
allocate(A(lda,ldb))
! allocate(ATest(lda,ldb))
allocate(B(n,1))
allocate(X(n,1))
allocate(Ipiv(lda))
allocate(IRN(nnz))
allocate(JCN(nnz))
allocate(val(nnz))
! allocate(Lwork)
A_size = SIZEOF(A)
B_size = SIZEOF(B)
X_size = SIZEOF(X)
Ipiv_size = SIZEOF(Ipiv)
devInfo_size = SIZEOF(devInfo)
Lwork_size = SIZEOF(Lwork)
print*, val(nnz)
! "QR FACTORIZATION DENSE LINEAR SOLVER"
! -------------- DEFINE [A] AND [B] --------------------------
! [A] [x] = [B]
! | 1.0 2.0 3.0 | |1.0| | 6.0|
! | 4.0 5.0 6.0 | |1.0| = |15.0|
! | 2.0 1.0 1.0 | |1.0| | 4.0|
A(1,1) = 1.0; A(1,2) = 2.0; A(1,3) = 3.0
A(2,1) = 4.0; A(2,2) = 5.0; A(2,3) = 6.0
A(3,1) = 2.0; A(3,2) = 1.0; A(3,3) = 1.0
B(1,1) = 6.0
B(2,1) = 15.0
B(3,1) = 4.0
! A(:,:) = 0
! print *, A(1,7962)
! Define [A]
! do i=1, nnz
! read(121, *) IRN(i), JCN(i), val(i)
! col = IRN(i)
! row = JCN(i)
! A(row,col) = val(i)
! print *, row," ",col, " ", val(i)
! enddo
! close(121)
! Define [B]
! open(122, file='b.dat')
! do j=1, lda
! read(122, *) B(j,1)
! enddo
! close(122)
CPU_A_ptr = C_LOC(A)
! CPU_ATest_ptr = C_LOC(ATest)
CPU_B_ptr = C_LOC(B)
CPU_X_ptr = C_LOC(X)
CPU_Lwork_ptr = C_Loc(Lwork)
A_size = SIZEOF(A)
B_size = SIZEOF(B)
X_size = SIZEOF(X)
! Step 1: Create cudense handle ---------------
cusolver_stat = cusolverDnCreate(cusolver_Hndl)
if (cusolver_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cusolverDnCreate error: ", cusolver_stat
write (*,*)
stop
end if
! Step 2: copy A and B to Device
A_mem_stat = cudaMalloc(d_A,A_size)
if (A_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 1 error: ", A_mem_stat
write (*,*)
stop
end if
B_mem_stat = cudaMalloc(d_B,B_size)
if (B_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 2 error: ", B_mem_stat
write (*,*)
stop
end if
! ---------- also allocate space for other device based variables
Ipiv_mem_stat = cudaMalloc(d_Ipiv,Ipiv_size)
if (Ipiv_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 3 error: ", Ipiv_mem_stat
write (*,*)
stop
end if
devInfo_mem_stat = cudaMalloc(d_devInfo,devInfo_size)
if (devInfo_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 4 error: ", devInfo_mem_stat
write (*,*)
stop
end if
Lwork_mem_stat = cudaMalloc(d_Lwork,Lwork_size)
if (Lwork_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 5 error: ", Lwork_mem_stat
write (*,*)
stop
end if
! ---------- copy A and B to Device
A_mem_stat = cudaMemcpy(d_A,CPU_A_ptr,A_size,cudaMemcpyHostToDevice)
write (*,*)
write (*, '(A, I2)') " cudaMemcpy 1 error: ", A_mem_stat
write (*,*)
! stop
end if
B_mem_stat = cudaMemcpy(d_B,CPU_B_ptr,B_size,cudaMemcpyHostToDevice)
write (*,*)
write (*, '(A, I2)') " cudaMemcpy 2 error: ", B_mem_stat
write (*,*)
! stop
end if
!! ---------- check transfer of A matrix by copy back to [ATest]
! A_mem_stat = cudaMemcpy(CPU_ATest_ptr,d_A,A_size,cudaMemcpyDeviceToHost) ! Test A matrix memory copy
! if (A_mem_stat .ne. 0 ) then
! write (*,*)
! write (*, '(A, I2)') " cudaMemcpy 3 error: ", A_mem_stat
! write (*,*)
! stop
! end if
! Step 3: query working space of Sgetrf (and allocate memory on device)
Lwork = 5
cusolver_stat = cusolverDnSgetrf_bufferSize(cusolver_Hndl,m,n,d_A,lda,CPU_Lwork_ptr)
write (*,*)
write (*, '(A, I2)') " DnSgetrf_bufferSize error: ", cusolver_stat
write (*,*)
! stop
end if
write (*,*)
write (*, '(A, I12)') " Lwork: ", Lwork
write (*,*)
Workspace = 4*Lwork
WS_mem_stat = cudaMalloc(d_WS,Workspace)
if (WS_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMalloc 6 error: ", WS_mem_stat
write (*,*)
! stop
end if
! Step 4: compute LU factorization of [A]
cusolver_stat = cusolverDnSgetrf(cusolver_Hndl,m,n,d_A,lda,d_WS,d_Ipiv,d_devInfo)
write (*,*)
write (*, '(A, I2)') " cusolverDnSgetrf error: ", WS_mem_stat
write (*,*)
! stop
end if
! Step 5: compute solution vector [X] for Right hand side [B]
cusolver_stat = cusolverDnSgetrs(cusolver_Hndl,CUBLAS_OP_N,n,nrhs,d_A,lda,d_Ipiv,d_B,ldb,d_devInfo)
write (*,*)
write (*, '(A, I2)') " cusolverDnSgetrs error: ", WS_mem_stat
write (*,*)
! stop
end if
! Step 6: copy solution vector stored in [B] on device into [X] vector on host
X_mem_stat = cudaMemcpy(CPU_X_ptr,d_B,B_size,cudaMemcpyDeviceToHost)
if (X_mem_stat .ne. 0 ) then
write (*,*)
write (*, '(A, I2)') " cudaMemcpy 4 error: ", WS_mem_stat
write (*,*)
! stop
end if
do i = 1, n
print *, X(i,1)
enddo
! step 7: free memory on device and release CPU-side resources
A_mem_Stat = cudafree(d_A)
B_mem_Stat = cudafree(d_B)
Ipiv_mem_stat = cudafree(d_Ipiv)
WS_mem_stat = cudafree(d_WS)
Lwork_mem_stat = cudafree(d_Lwork)
cusolver_stat = cusolverDnDestroy(cusolver_Hndl)
! Step 8: deallocate memory on host before exit
deallocate(A)
! deallocate(ATest)
deallocate(B)
deallocate(X)
deallocate(Ipiv)
End Program
