Hii,
How can I reduce a 2D sparse matrix into a 1D array of just the non-zero items in serial order using numba CUDA.
From
[[0 0 1 0 0]
[0 2 0 0 0]
[0 0 0 0 3]]
to
[1 2 3]
Thanks,
Hii,
From
[[0 0 1 0 0]
[0 2 0 0 0]
[0 0 0 0 3]]
to
[1 2 3]
Thanks,
hint: it is a reduction problem
hint2: it is a stream-compaction problem
parallel stream compaction is described in various forum posts. It could use a parallel prefix sum, followed by an indexed copy.
Thanks,
Is the code given in the link to forum post actually a working example or does it require any modification. I am getting errors. Is there a working example of the algorithm in numba CUDA elsewhere. Couldn’t find one for numba CUDA.
Thanks,
That was the closest I could find for numba cuda.
I ran a few small simple tests on that code, it seemed to work correctly.
FWIW cupy should be interoperable with numba cuda.
The following code should remove the hazards I mentioned in the comments to that numba cuda example:
import numpy as np
from numba import cuda, int32
BSP2 = 3
BLOCK_SIZE = 2**BSP2
#CUDA kernel to calculate prefix sum of each block of input array
@cuda.jit('void(int32[:], int32[:], int32[:], int32)')
def prefix_sum_nzmask_block(a, b, s, length):
ab = cuda.shared.array(shape=(BLOCK_SIZE), dtype=int32)
tid = cuda.blockIdx.x * cuda.blockDim.x + cuda.threadIdx.x;
if tid < length:
ab[cuda.threadIdx.x] = int32(a[tid] != 0); #Load mask of input data into shared memory
for j in range(0,BSP2):
i = 2**j
cuda.syncthreads()
if i <= cuda.threadIdx.x:
temp = ab[cuda.threadIdx.x]
temp += ab[cuda.threadIdx.x - i] #Perform scan on shared memory
cuda.syncthreads()
ab[cuda.threadIdx.x] = temp
b[tid] = ab[cuda.threadIdx.x]; #Write scanned blocks to global memory
if(cuda.threadIdx.x == cuda.blockDim.x-1): #Last thread of block
s[cuda.blockIdx.x] = ab[cuda.threadIdx.x]; #Write last element of shared memory into global memory
(the remainder of the code there is unchanged)
This somewhat larger test case seems to work correctly for me:
$ cat t70.py
import numpy as np
BSP2 = 9
if tid < length:
i = 2**j
cuda.syncthreads()
cuda.syncthreads()
#CUDA kernel to merge the prefix sums of individual blocks
@cuda.jit('void(int32[:], int32[:], int32)')
def prefix_sum_merge_blocks(b, s, length):
tid = (cuda.blockIdx.x + 1) * cuda.blockDim.x + cuda.threadIdx.x; #Skip first block
if tid<length:
i = 0
while i<=cuda.blockIdx.x:
b[tid] += s[i] #Accumulate last elements of all previous blocks
i += 1
#CUDA kernel to copy non-zero entries to the correct index of the output array
def map_non_zeros(a, prefix_sum, nz, length):
if tid < length:
input_value = a[tid]
if input_value != 0:
index = prefix_sum[tid] #The correct output index is the value at current index of prefix sum array
nz[index-1] = input_value
#Apply stream compaction algorithm to get only the non-zero entries from the input array
def get_non_zeros(a):
length = a.shape[0]
block = BLOCK_SIZE
grid = int((length + block - 1)/block)
#Create auxiliary array to hold the sum of each block
block_sum = cuda.device_array(shape=(grid), dtype=np.int32)
#Copy input array from host to device
ad = cuda.to_device(a)
#Create prefix sum output array
bd = cuda.device_array_like(ad)
#Perform partial scan of each block. Store block sum in auxillary array named block_sum.
prefix_sum_nzmask_block[grid, block](ad, bd, block_sum, length)
#Add block sum to the output
prefix_sum_merge_blocks[grid, block](bd,block_sum,length);
#The last element of prefix sum contains the total number of non-zero elements
non_zero_count = int(bd[bd.shape[0]-1])
#Create device output array to hold ONLY the non-zero entries
non_zeros = cuda.device_array(shape=(non_zero_count), dtype=np.int32)
#Copy ONLY the non-zero entries
map_non_zeros[grid, block](a, bd, non_zeros, length)
#Return to host
return non_zeros.copy_to_host()
if __name__ == '__main__':
arr = np.zeros(10000000, dtype=np.int32)
for i in range(32,65000,1024):
arr[i] = i
nz = get_non_zeros(arr)
print(nz)
$ python t70.py
[ 32 1056 2080 3104 4128 5152 6176 7200 8224 9248 10272 11296
12320 13344 14368 15392 16416 17440 18464 19488 20512 21536 22560 23584
24608 25632 26656 27680 28704 29728 30752 31776 32800 33824 34848 35872
36896 37920 38944 39968 40992 42016 43040 44064 45088 46112 47136 48160
49184 50208 51232 52256 53280 54304 55328 56352 57376 58400 59424 60448
61472 62496 63520 64544]
File "pynvrebel.py", line 2712, in <module>
main()
File "pynvrebel.py", line 122, in main
nz=get_non_zeros(arr)
File "pynvrebel.py", line 169, in get_non_zeros
non_zero_count=int(bd[bd.shape[0]-1])
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/devicearray.py", line 332, in __getitem__
return self._do_getitem(item)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/devicearray.py", line 353, in _do_getitem
stream=stream)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 1597, in device_to_host
fn(host_pointer(dst), device_pointer(src), size, *varargs)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 288, in safe_cuda_api_call
self._check_error(fname, retcode)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 323, in _check_error
raise CudaAPIError(retcode, msg)
numba.cuda.cudadrv.driver.CudaAPIError: [702] Call to cuMemcpyDtoH results in CUDA_ERROR_LAUNCH_TIMEOUT
This is the error i get now.
The kernel is taking long enough to hit the kernel timeout. It doesn’t mean the code is broken. With a bit of google searching you can find some suggestions. Jetson nano has a kernel timeout mechanism that is special (<- click link), and I’m not sure how to turn it off, but you may want to check that forum thread. You may want to ask about that on the jetson nano forum I have also verified that the kernel takes at least several seconds for a large enough array - 10,000,000 elements or more, on a relatively slow GPU. Actually, on a Quadro K1000, the previous code I posted (10,000,000 elements) takes about 3 minutes to run. nvprof
gives the following timings:
==6124== Profiling application: python t70.py
==6124== Profiling result:
Type Time(%) Time Calls Avg Min Max Name
GPU activities: 99.75% 172.220s 1 172.220s 172.220s 172.220s cudapy::__main__::prefix_sum_merge_blocks$243(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int)
0.12% 202.44ms 1 202.44ms 202.44ms 202.44ms cudapy::__main__::prefix_sum_nzmask_block$241(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int)
0.06% 110.47ms 3 36.822ms 1.8560us 110.46ms [CUDA memcpy DtoH]
0.06% 106.88ms 2 53.439ms 47.109ms 59.769ms [CUDA memcpy HtoD]
0.01% 12.712ms 1 12.712ms 12.712ms 12.712ms cudapy::__main__::map_non_zeros$244(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int)
API calls: 99.90% 172.546s 3 57.5154s 30.074us 172.422s cuMemcpyDtoH
0.06% 107.02ms 2 53.508ms 47.174ms 59.842ms cuMemcpyHtoD
so the heavy hitter is the prefix sum merge blocks kernel. It is probably ripe for optimization. Part of that kernel is a second stage prefix sum, but it is implemented in a naive fashion.
I have seen pseudo code for work efficient prefix sum algorithm on the internet. But not sure how to port it to numba cuda. In my case the input is a 1D sparse array of length around 3 million.
Here is an improved version.
On my quadro K2000, for 50,000,000 elements, the overall program executes in a few seconds, and the longest duration kernel call is less than 300ms :
$ cat t71.py
import numpy as np
BSP2 = 9
@cuda.jit('void(int32[:], int32[:], int32[:], int32, int32)')
def prefix_sum_nzmask_block(a, b, s, nzm, length):
ab[cuda.threadIdx.x] = 0
if tid < length:
if nzm == 1:
else:
ab[cuda.threadIdx.x] = int32(a[tid]); #Load input data into shared memory
i = 2**j
cuda.syncthreads()
cuda.syncthreads()
if tid < length:
def pref_sum_update(b, s, length):
if tid<length:
b[tid] += s[cuda.blockIdx.x] #Accumulate last elements of all previous blocks
if tid < length:
def pref_sum(a, asum, nzm):
block = BLOCK_SIZE
length = a.shape[0]
grid = int((length + block -1)/block)
bs = cuda.device_array(shape=(grid), dtype=np.int32)
prefix_sum_nzmask_block[grid, block](a, asum, bs, nzm, length)
if grid > 1:
bssum = cuda.device_array(shape=(grid), dtype=np.int32)
pref_sum(bs, bssum, 0)
pref_sum_update[grid-1, block](asum, bssum, length)
pref_sum(ad, bd, int(1))
block = BLOCK_SIZE
length = a.shape[0]
map_non_zeros[grid, block](ad, bd, non_zeros, length)
#Return to host
arr = np.zeros(50000000, dtype=np.int32)
for i in range(32,65000, 1024):
arr[i] = i
print(nz)
$ cuda-memcheck python t71.py
========= CUDA-MEMCHECK
========= ERROR SUMMARY: 0 errors
$ nvprof python t71.py
==7940== NVPROF is profiling process 7940, command: python t71.py
==7940== Profiling application: python t71.py
==7940== Profiling result:
GPU activities: 47.58% 225.56ms 3 75.187ms 10.304us 225.11ms cudapy::__main__::prefix_sum_nzmask_block$241(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int, int)
23.40% 110.92ms 3 36.975ms 1.8880us 110.92ms [CUDA memcpy DtoH]
22.84% 108.26ms 2 54.131ms 48.212ms 60.049ms [CUDA memcpy HtoD]
3.49% 16.543ms 2 8.2716ms 34.432us 16.509ms cudapy::__main__::pref_sum_update$243(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int)
2.69% 12.731ms 1 12.731ms 12.731ms 12.731ms cudapy::__main__::map_non_zeros$244(Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, Array<int, int=1, A, mutable, aligned>, int)
API calls: 68.68% 364.85ms 3 121.62ms 30.500us 240.35ms cuMemcpyDtoH
20.39% 108.35ms 2 54.173ms 48.223ms 60.123ms cuMemcpyHtoD
9.83% 52.205ms 1 52.205ms 52.205ms 52.205ms cuDevicePrimaryCtxRetain
0.34% 1.8180ms 3 605.99us 532.71us 745.07us cuModuleLoadDataEx
0.27% 1.4492ms 9 161.03us 12.127us 486.82us cuMemAlloc
0.17% 900.11us 8 112.51us 6.9130us 329.48us cuMemFree
0.11% 601.80us 3 200.60us 60.972us 477.62us cuLinkCreate
0.09% 467.57us 3 155.86us 127.86us 205.38us cuLinkAddData
0.07% 394.45us 3 131.48us 120.79us 151.99us cuLinkComplete
0.02% 120.57us 6 20.094us 14.765us 40.249us cuLaunchKernel
0.01% 36.027us 1 36.027us 36.027us 36.027us cuMemGetInfo
0.01% 28.882us 1 28.882us 28.882us 28.882us cuDeviceGetName
0.00% 8.5660us 15 571ns 369ns 1.3050us cuFuncGetAttribute
0.00% 5.4590us 3 1.8190us 1.6790us 1.9680us cuModuleGetFunction
0.00% 3.7140us 3 1.2380us 1.1560us 1.3180us cuLinkDestroy
0.00% 3.2680us 1 3.2680us 3.2680us 3.2680us cuDeviceGetPCIBusId
0.00% 2.0330us 3 677ns 315ns 910ns cuDeviceGetCount
0.00% 1.9580us 1 1.9580us 1.9580us 1.9580us cuCtxPushCurrent
0.00% 1.1630us 2 581ns 571ns 592ns cuDeviceGet
0.00% 964ns 3 321ns 262ns 426ns cuDeviceGetAttribute
0.00% 868ns 1 868ns 868ns 868ns cuDeviceComputeCapability
Thanks! Now it works quickly.
In my program after processing few image frames the program crashes with the following error. How can i fix it? I am using a jetson nano.
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 656, in _attempt_allocation
allocator()
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 671, in allocator
driver.cuMemAlloc(byref(ptr), bytesize)
numba.cuda.cudadrv.driver.CudaAPIError: [2] Call to cuMemAlloc results in CUDA_ERROR_OUT_OF_MEMORY
During handling of the above exception, another exception occurred:
File "pynvrebel.py", line 3042, in <module>
main()
File "pynvrebel.py", line 141, in main
nz_ba_h=get_non_zeros(bound_abstract_h)
File "pynvrebel.py", line 467, in get_non_zeros
non_zeros=cuda.device_array(shape=(non_zero_count),dtype=np.int32)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/devices.py", line 212, in _require_cuda_context
return fn(*args, **kws)
File "/usr/lib/python3/dist-packages/numba/cuda/api.py", line 74, in device_array
stream=stream)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/devicearray.py", line 96, in __init__
gpu_data = devices.get_context().memalloc(self.alloc_size)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 673, in memalloc
self._attempt_allocation(allocator)
File "/usr/lib/python3/dist-packages/numba/cuda/cudadrv/driver.py", line 663, in _attempt_allocation
allocator()
You’re running out of memory. If/since this is happening during a processing loop, its possible that you are creating allocations without releasing them. See here.
Yes the processing takes place inside a while loop. The out of memory occurs every time in the 15th iteration. Also at the time of crash there is around 1.5GB of free ram space according to ‘top’ utility. Any recommended value for NUMBA_CUDA_MAX_PENDING_DEALLOCS_COUNT or NUMBA_CUDA_MAX_PENDING_DEALLOCS_RATIO.
Thanks,
If I understand this parameter correctly, it seems like setting this to zero should be the first thing to try, as this should force all deallocations to occur immediately. Allowing no deallocations to be queued and thus pending should maximize the amount of free memory available at all times. The trade-off is likely lower performance, but before worrying about performance one would want to worry about functionality. You may also want to try increasing values for this configuration parameter step-by-step to see whether any interesting observations can be made.
What confuses me at the moment is that the documentation claims:
The deallocation queue is flushed automatically as soon as the following events occur:
An allocation failed due to out-of-memory error. Allocation is retried after flushing all deallocations.
Which to me means that the lazy flushing of the deallocation queue should be harmless from a functionality perspective, but could cause jittery performance, similar to garbage collection kicking in every now and then in other environments.
As this really seems to be a NUMBA design issue, that is, how NUMBA is using CUDA, I would suggest asking for advice on the NUMBA support platform.
Thanks! I set NUMBA_CUDA_MAX_PENDING_DEALLOCS_COUNT to zero. Now the program doesn’t crash.
Depending on the sparsity of your matrix, different approaches could run faster. E.g. if from 50 million elements only 3 elements are non-zero, calculating a prefix sum would be inefficient. If from 50 million elements just 3 elements are zero, there would also be faster ways. If you want a solution with predictable execution speed, which is currently fast enough (and would be for any other data), then you do not have to bother any further.
Still facing issues related to CUDA_ERROR_OUT_OF_MEMORY error. I have set NUMBA_CUDA_MAX_PENDING_DEALLOCS_COUNT to zero. But the program crashes after some iterations.
For example
a=np.array([1000000],dtype=np.int)
a_d=cuda.to_device(a)
Is device memory cleared as soon as i run
a_h=a_d.copy_to_host()
According to docs "When the last reference to a device memory is dropped, the underlying memory is scheduled to be deallocated. What does that mean?
Or have i reached the limits of my hardware?
Perhaps reassign the a_d = None
variable or del a_d
. But it would probably be dropped at the next iteration anyway …
