Stream capture of cublas gemm
I am trying to capture graph associated with a cublas sgemm call (cuda 11.5 on Ampere). I modified the matrixMultiply function in the matrixMulCUBLAS CUDA sample as below. I get an error cudaErrorInvalidDeviceFunction for the function captured by stream capture, see line tagged as FAILURE. What am I doing wrong?
//! Run a simple test matrix multiply using CUBLAS
int matrixMultiply(int argc, char **argv, int devID, sMatrixSize &matrix_size) {
  cudaDeviceProp deviceProp;
  checkCudaErrors(cudaGetDeviceProperties(&deviceProp, devID));
  int block_size = 32;
  // set seed for rand()
  srand(2006);
  // allocate host memory for matrices A and B
  unsigned int size_A = matrix_size.uiWA * matrix_size.uiHA;
  unsigned int mem_size_A = sizeof(float) * size_A;
  float *h_A = (float *)malloc(mem_size_A);
  unsigned int size_B = matrix_size.uiWB * matrix_size.uiHB;
  unsigned int mem_size_B = sizeof(float) * size_B;
  float *h_B = (float *)malloc(mem_size_B);
  srand(2006);
  // initialize host memory
  randomInit(h_A, size_A);
  randomInit(h_B, size_B);
  // allocate device memory
  float *d_A, *d_B, *d_C;
  unsigned int size_C = matrix_size.uiWC * matrix_size.uiHC;
  unsigned int mem_size_C = sizeof(float) * size_C;
  // allocate host memory for the result
  float *h_C = (float *)malloc(mem_size_C);
  float *h_CUBLAS = (float *)malloc(mem_size_C);
  checkCudaErrors(cudaMalloc((void **)&d_A, mem_size_A));
  checkCudaErrors(cudaMalloc((void **)&d_B, mem_size_B));
  checkCudaErrors(cudaMemcpy(d_A, h_A, mem_size_A, cudaMemcpyHostToDevice));
  checkCudaErrors(cudaMemcpy(d_B, h_B, mem_size_B, cudaMemcpyHostToDevice));
  checkCudaErrors(cudaMalloc((void **)&d_C, mem_size_C));
  // setup execution parameters
  dim3 threads(block_size, block_size);
  dim3 grid(matrix_size.uiWC / threads.x, matrix_size.uiHC / threads.y);
  // create and start timer
  printf("Computing result using CUBLAS...");
  // execute the kernel
  int nIter = 30;
  // CUBLAS version 2.0
    const float alpha = 1.0f;
    const float beta = 0.0f;
    cublasHandle_t handle;
    cudaStream_t stream;
    cudaEvent_t start, stop;
    cudaGraph_t graph;
    cudaGraphExec_t graphExec = NULL;
    cudaKernelNodeParams NodeParams;
    cudaMemsetParams MemsetParams;
    std::vector<cudaGraphNode_t> vnodes;
    checkCudaErrors(cublasCreate(&handle));
    checkCudaErrors(cublasSetPointerMode(handle, CUBLAS_POINTER_MODE_DEVICE));
    checkCudaErrors(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
    cublasSetStream(handle,stream);
    checkCudaErrors(cudaStreamBeginCapture(stream, cudaStreamCaptureModeGlobal));
    // Perform warmup operation with cublas
    checkCudaErrors(cublasSgemm(
        handle, CUBLAS_OP_N, CUBLAS_OP_N, matrix_size.uiWB, matrix_size.uiHA,
        matrix_size.uiWA, &alpha, d_B, matrix_size.uiWB, d_A, matrix_size.uiWA,
        &beta, d_C, matrix_size.uiWB));
    checkCudaErrors(cudaStreamEndCapture(stream, &graph));
    size_t numNodes;
    checkCudaErrors(cudaGraphGetNodes(graph, NULL, &numNodes));
    vnodes.resize(numNodes);
    checkCudaErrors(cudaGraphGetNodes(graph, vnodes.data(), &numNodes));
    std::vector<cudaGraphNodeType> nodeType(numNodes);
    for(size_t i=0; i<numNodes; i++) {
      checkCudaErrors(cudaGraphNodeGetType (vnodes[i], &nodeType[i]));
      switch(nodeType[i]) {
         case cudaGraphNodeTypeMemset:
           checkCudaErrors(cudaGraphMemsetNodeGetParams (vnodes[i], &MemsetParams));
           break;
         case cudaGraphNodeTypeKernel:
	   checkCudaErrors(cudaGraphKernelNodeGetParams(vnodes[i], &NodeParams));
          // FAILURE  code=98 (cudaErrorInvalidDeviceFunction)
	   break;
    cudaGraphExecUpdateResult updateResult_out;
    checkCudaErrors(cudaGraphExecUpdate(graphExec, graph, NULL, &updateResult_out));
    if (updateResult_out != cudaGraphExecUpdateSuccess) {
        if (graphExec != NULL) {
          checkCudaErrors(cudaGraphExecDestroy(graphExec));
        printf("graph update failed with error - %d\n", updateResult_out);
        checkCudaErrors(cudaGraphInstantiate(&graphExec, graph, NULL, NULL, 0));
    checkCudaErrors(cudaGraphLaunch(graphExec, stream));
    checkCudaErrors(cudaStreamSynchronize(stream));
    // Allocate CUDA events that we'll use for timing
    checkCudaErrors(cudaEventCreate(&start));
    checkCudaErrors(cudaEventCreate(&stop));
    // Record the start event
    checkCudaErrors(cudaEventRecord(start, NULL));
    for (int j = 0; j < nIter; j++) {
      // note cublas is column primary!
      // need to transpose the order
    printf("done.\n");
    // Record the stop event
    checkCudaErrors(cudaEventRecord(stop, NULL));
    // Wait for the stop event to complete
    checkCudaErrors(cudaEventSynchronize(stop));
    float msecTotal = 0.0f;
    checkCudaErrors(cudaEventElapsedTime(&msecTotal, start, stop));
    // Compute and print the performance
    float msecPerMatrixMul = msecTotal / nIter;
    double flopsPerMatrixMul = 2.0 * (double)matrix_size.uiHC *
                               (double)matrix_size.uiWC *
                               (double)matrix_size.uiHB;
    double gigaFlops =
        (flopsPerMatrixMul * 1.0e-9f) / (msecPerMatrixMul / 1000.0f);
    printf("Performance= %.2f GFlop/s, Time= %.3f msec, Size= %.0f Ops\n",
           gigaFlops, msecPerMatrixMul, flopsPerMatrixMul);
    // copy result from device to host
    checkCudaErrors(
        cudaMemcpy(h_CUBLAS, d_C, mem_size_C, cudaMemcpyDeviceToHost));
    // Destroy the handle
    checkCudaErrors(cublasDestroy(handle));
    checkCudaErrors(cudaStreamDestroy(stream));
  // compute reference solution
  printf("Computing result using host CPU...");
  float *reference = (float *)malloc(mem_size_C);
  matrixMulCPU(reference, h_A, h_B, matrix_size.uiHA, matrix_size.uiWA,
               matrix_size.uiWB);
  printf("done.\n");
  // check result (CUBLAS)
  bool resCUBLAS = sdkCompareL2fe(reference, h_CUBLAS, size_C, 1.0e-6f);
  if (resCUBLAS != true) {
    printDiff(reference, h_CUBLAS, matrix_size.uiWC, matrix_size.uiHC, 100,
              1.0e-5f);
  printf("Comparing CUBLAS Matrix Multiply with CPU results: %s\n",
         (true == resCUBLAS) ? "PASS" : "FAIL");
  printf(
      "\nNOTE: The CUDA Samples are not meant for performance measurements. "
      "Results may vary when GPU Boost is enabled.\n");
  // clean up memory
  free(h_A);
  free(h_B);
  free(h_C);
  free(reference);
  checkCudaErrors(cudaFree(d_A));
  checkCudaErrors(cudaFree(d_B));
  checkCudaErrors(cudaFree(d_C));
  if (resCUBLAS == true) {
    return EXIT_SUCCESS;  // return value = 1
  } else {
    return EXIT_FAILURE;  // return value = 0
please format your code correctly
a possible set of steps:
  • edit your post, by clicking on the pencil icon below it
  • select the code
  • press the </> button at the top of the edit window
  • save your changes
  1. Your usage of CUBLAS_POINTER_MODE is incorrect.
  2. I’m not sure what you are doing with all of the node lookup. I don’t typically expect to see that when using stream capture.
  3. Your instantiation call sequence after the capture is not correct.
This throws no errors for me:
$ cat t2029.cu
#include <cublas_v2.h>
#include <cstdio>
#include <helper_cuda.h>
#include <vector>
int main(int argc, char *argv[]){
  int devID = 0;
  int WA, HA, WB, HB, WC, HC;
  WA = HA = WB = HB = WC = HC = 512;
  srand(2006);
  unsigned int size_A = WA * HA;
  unsigned int size_B = WB * HB;
  srand(2006);
  unsigned int size_C = WC * HC;
  dim3 grid(WC / threads.x, HC / threads.y);
  int nIter = 30;
    cudaGraph_t graph;
    //checkCudaErrors(cublasSetPointerMode(handle, CUBLAS_POINTER_MODE_DEVICE));
        handle, CUBLAS_OP_N, CUBLAS_OP_N, WB, HA,
        WA, &alpha, d_B, WB, d_A, WA,
        &beta, d_C, WB));
//    checkCudaErrors(cudaDeviceSynchronize());
//    return 0;
#if 0
    size_t numNodes;
           break;
           break;
#endif
#if 0
#endif
    printf("done.\n");
    double flopsPerMatrixMul = 2.0 * (double)HC *
                               (double)WC *
                               (double)HB;
    double gigaFlops =
    checkCudaErrors(
  printf("done.\n");
  printf(
  // clean up memory
  free(h_A);
  free(h_B);
  free(h_C);
  free(reference);
$ nvcc -o t2029 t2029.cu -lcublas -I/usr/local/cuda/samples/common/inc
t2029.cu(72): warning: variable "MemsetParams" was declared but never referenced
$ ./t2029
Computing result using CUBLAS...done.
Performance= 6471.19 GFlop/s, Time= 0.041 msec, Size= 268435456 Ops
Computing result using host CPU...done.
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
My intended code has some graph restructuring logic. The example I shared is just a reproducer, not my intended full code. I need to capture the graph node and restructure dependencies.
The example I shared show where failure occurs.
In Robert’s code, I do not have a chance to restructure the graph dependencies.
Could some of cublas kernel execute eagerly? and as such graph capture is not effectual?
Is it technically illegal to access a kernelNodeParam of a stream-captured CUDAGraph?
I face the following situation:
CASE 1: CudaGraph only has cuBLAS kernel (stream captured):
In the above situation, trying to do cudaGraphKernelNodeGetParams on the kernel node gives
Cuda error in function 'cudaGraphKernelNodeGetParams(kernelNode[i], &kernelNodeParams[i])' file 'cublas-matmul-cudagraph-stream-capture-post.cu' in line 140 : invalid device function.
that @cudevelop mentions in his code.
CASE 2: Same old code, but added a synthetic vecAdd kernel just before the cuBLAS matrix multiply call (stream captured):
In this case, cudaGraphKernelNodeGetParams is successful on the first vecAdd kernel node. But, when I try to do the same for the volta_sgemm_.. kernel node added by cuBLAS, I get the same error:
While the exact same line of code passes for the vecAdd kernel node. Does it have something to do with the fact that the implementation of cuBLAS is closed-source?
Example Code:
#include <iostream>
#include <cuda_runtime.h>
#include <vector>
#define CUDA_SAFECALL(call)                                                 \
        call;                                                               \
        cudaError err = cudaGetLastError();                                 \
        if (cudaSuccess != err) {                                           \
            fprintf(                                                        \
                stderr,                                                     \
                "Cuda error in function '%s' file '%s' in line %i : %s.\n", \
                #call, __FILE__, __LINE__, cudaGetErrorString(err));        \
            fflush(stderr);                                                 \
            exit(EXIT_FAILURE);                                             \
#define CUBLAS_CALL(func)                                                      \
    cublasStatus_t s = (func);                                                 \
    if(s != CUBLAS_STATUS_SUCCESS) {                                           \
        std::cerr << "cuBLAS Error: " << s << " at line " << __LINE__ << std::endl; \
const int N = 1024;  // Dimension of the square matrix (N x N)
// Helper function to initialize matrices
void initializeMatrix(float* matrix, int n, float value) {
    for (int i = 0; i < n * n; ++i) {
        matrix[i] = value;
void printMatrix(float* matrix, int n) {
    for (int i = 0; i < n; ++i) {
        for (int j = 0; j < n; ++j) {
            std::cout << matrix[i * n + j] << " ";
        std::cout << std::endl;
// CUDA kernel that adds two vectors, each thread handles one element of c
__global__ void vecAdd(float *a, float *b, float *c, int n) {
    int id = blockIdx.x * blockDim.x + threadIdx.x;
    if (id < n) c[id] = a[id] + b[id];
int main() {
    // Initialize cuBLAS
    CUBLAS_CALL(cublasCreate(&handle));
    // Create a CUDA stream
    CUDA_SAFECALL(cudaStreamCreate(&stream));
    // Set cuBLAS to use the created stream
    CUBLAS_CALL(cublasSetStream(handle, stream));
    // Allocate memory for input and output matrices on host
    // A * B = C
    float* h_A = (float*) malloc(N * N * sizeof(float));
    float* h_B = (float*) malloc(N * N * sizeof(float));
    float* h_C = (float*) malloc(N * N * sizeof(float));
    initializeMatrix(h_A, N, 1.0f);  // Matrix A with all elements 1.0
    initializeMatrix(h_B, N, 2.0f);  // Matrix B with all elements 2.0
    // Allocate memory on device
    CUDA_SAFECALL(cudaMalloc((void**)&d_A, N * N * sizeof(float)));
    CUDA_SAFECALL(cudaMalloc((void**)&d_B, N * N * sizeof(float)));
    CUDA_SAFECALL(cudaMalloc((void**)&d_C, N * N * sizeof(float)));
    // Copy data from host to device (Async using stream)
    CUDA_SAFECALL(cudaMemcpyAsync(d_A, h_A, N * N * sizeof(float), cudaMemcpyHostToDevice, stream));
    CUDA_SAFECALL(cudaMemcpyAsync(d_B, h_B, N * N * sizeof(float), cudaMemcpyHostToDevice, stream));
    // Create CUDA Graph
    cudaGraph_t graph;
    cudaGraphExec_t instance;
    // Begin CUDA Graph capture
    cudaStreamBeginCapture(stream, cudaStreamCaptureModeGlobal);
# if 0
    //testing a vecAdd kernel
    int blockSize, gridSize;
    blockSize = 1024;
    gridSize = (int)ceil((float)N / blockSize);
    vecAdd<<<gridSize, blockSize, 0, stream>>>(d_A, d_B, d_C, N);
#endif
    // Set up GEMM (Matrix Multiplication)
    float alpha = 1.0f, beta = 0.0f;
    // cublasSgemm performs matrix multiplication C = alpha * A * B + beta * C
    // where A, B, C are NxN matrices in column-major order.
    CUBLAS_CALL(cublasSgemm(handle,
                            N, N, N,
                            &alpha,
                            d_A, N,
                            d_B, N,
                            &beta,
                            d_C, N));
    // End CUDA Graph capture
    cudaStreamEndCapture(stream, &graph);
    // Instantiate the graph
    cudaGraphInstantiate(&instance, graph, NULL, NULL, 0);
    // Get the number of nodes to allocate an array of nodes
    cudaGraphNode_t* nodes=NULL;
    size_t numNodes=0;
    CUDA_SAFECALL((cudaGraphGetNodes(graph, nodes, &numNodes)));
    nodes = (cudaGraphNode_t*)malloc(numNodes*sizeof(cudaGraphNode_t));
    std::vector<cudaGraphNode_t> kernelNode;
    printf("Number of nodes: %lu\n", numNodes);
    for(int i = 0; i < numNodes; i++){
        cudaGraphNodeType type;
        cudaGraphNodeGetType(nodes[i], &type);
        if (type == cudaGraphNodeTypeKernel){
            printf("Node %d is kernel Node\n", i+1);
            kernelNode.push_back(nodes[i]);
    cudaKernelNodeParams kernelNodeParams[kernelNode.size()] = {0};
    // Get the kernel node parameters
    for (int i = 0; i < kernelNode.size(); i++){
        CUDA_SAFECALL(cudaGraphKernelNodeGetParams(kernelNode[i], &kernelNodeParams[i]));
    // Launch the instantiated graph
    cudaGraphLaunch(instance, stream);
    // Copy result from device to host (Async using stream)
    CUDA_SAFECALL(cudaMemcpyAsync(h_C, d_C, N * N * sizeof(float), cudaMemcpyDeviceToHost, stream));
    // Wait for the stream to finish all operations
    CUDA_SAFECALL(cudaStreamSynchronize(stream));
    // // Print the result matrix C
    // std::cout << "Matrix C (Result of A * B):" << std::endl;
    // printMatrix(h_C, N);
    // Cleanup
    CUBLAS_CALL(cublasDestroy(handle));
    CUDA_SAFECALL(cudaFree(d_A));
    CUDA_SAFECALL(cudaFree(d_B));
    CUDA_SAFECALL(cudaFree(d_C));
    free(h_A);
    free(h_B);
    free(h_C);
    // Destroy the stream
    CUDA_SAFECALL(cudaStreamDestroy(stream));
    return 0;
@Robert_Crovella, do you have any insight as to why that specific behavior is with cuBLAS kernels?
As we can see, vecAdd shows its entire function signature (as a C++ mangled name), but the volta_sgemm_128x64_nn does not show its signature.
If volta_sgemm_128x64_nn is a C kernel, it does not have a mangled name.
Simple example
__global__
void kernel_cpp(int a, int b, int c){
extern "C"{
    __global__
    void kernel_c(int a, int b, int c){
cuobjdump shows the following two kernel names:
Function : kernel_c
Function : _Z10kernel_cppiii
CUBLAS as initally designed was decreed to provide a C-callable API, mostly for straightforward interoperability with Fortran (ISO_C_BINDING) but also because C++ at that time did not have a single universally agreed upon calling convention. Last I checked some years ago, that was still the case, preventing a mix&match approach to linking binary objects from multiple arbitrarily chosen compilers.
  • I don’t know the reason that a kernel from within a cublas routine, captured via stream capture, cannot have its parameters accessed via cudaGraphKernelNodeGetParams
  • It’s not obvious to me that C++ mangled vs. not has any bearing on that (the item I mention in the previous point). A simple test can be constructed with an extern "C" kernel showing that it does not throw an error on the CUDA runtime API call cudaGraphKernelNodeGetParams
  • I generally recommend that CUBLAS questions (for example, the one I pointed out in my first point above) be asked on the library forum that is explicitly referenced for CUBLAS questions. From time to time, cublas engineers have made a showing there. I offer no guarantees. It’s just a suggestion.
  • since CUBLAS is closed source, but perhaps more importantly, since you don’t know the signature of the kernel call parameters, it seems to me rather reckless to go modifying the argument pack yourself. A CUBLAS call is a host-code routine, which has a fairly arbitrary host-code sequence that includes also a fairly arbitrary device processing sequence. That doesn’t seem controversial to me to describe it that way. Given that preamble, imagining that you can safely go in and modify the arguments to a particular device activity step, with no knowledge of the surrounding host code or device code activity inherent in the CUBLAS call, seems curious to me.
I think it is unlikely that I would be able to make any further comments on the topic of accessing CUBLAS kernel parameters/arguments via graph API.
