I’m having issues calling cuBLAS API functions from kernels in CUDA 10.0.
Here is the piece of sample code I’m using to try to debug:
* Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
* This example demonstrates how to call CUBLAS library
* functions both from the HOST code and from the DEVICE code
* running on the GPU (the latter is available only for the compute
* capability >= 3.5). The single-precision matrix-matrix
* multiplication operation, SGEMM, will be performed 3 times:
* 1) once by calling a method defined in this file (simple_sgemm),
* 2) once by calling the cublasSgemm library routine from the HOST code
* 3) and once by calling the cublasSgemm library routine from
* the DEVICE code.
/* Includes, system */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* Includes, cuda */
#include <cuda_runtime.h>
#include <cublas_v2.h>
/* Includes, cuda helper functions */
#include <helper_cuda.h>
/* Matrix size */
#define N (275)
/* Host implementation of a simple version of sgemm */
static void simple_sgemm(int n, float alpha, const float *A, const float *B,
float beta, float *C)
int i;
int j;
int k;
for (i = 0; i < n; ++i)
for (j = 0; j < n; ++j)
float prod = 0;
for (k = 0; k < n; ++k)
prod += A[k * n + i] * B[j * n + k];
C[j * n + i] = alpha * prod + beta * C[j * n + i];
/* Checks result against reference and returns relative error */
static float check_result(const float *result,
const float *reference,
int size)
float error_norm = 0.0f;
float ref_norm = 0.0f;
for (int i = 0; i < size; ++i)
float diff = reference[i] - result[i];
error_norm += diff * diff;
ref_norm += reference[i] * reference[i];
error_norm = (float) sqrt((double) error_norm);
ref_norm = (float) sqrt((double) ref_norm);
if (fabs(ref_norm) < 1e-7)
fprintf(stderr, "!!!! Result check failed: reference norm is 0\n");
exit(EXIT_FAILURE);
return error_norm / ref_norm;
/* Declaration of the function that computes sgemm using CUBLAS device API */
extern "C" void device_cublas_sgemm(int n,
float alpha,
const float *d_A, const float *d_B,
float beta,
float *d_C);
/* Main */
int main(int argc, char **argv)
cublasStatus_t status;
float *h_A;
float *h_B;
float *h_C;
float *h_C_rnd;
float *h_C_ref;
float *d_A = 0;
float *d_B = 0;
float *d_C = 0;
float alpha = 1.0f;
float beta = 0.0f;
int n2 = N * N;
int i;
cublasHandle_t handle;
int dev_id;
cudaDeviceProp device_prop;
bool do_device_api_test = false;
float host_api_test_ratio, device_api_test_ratio;
/* Initialize CUBLAS */
printf("simpleDevLibCUBLAS test running...\n");
dev_id = findCudaDevice(argc, (const char **) argv);
checkCudaErrors(cudaGetDeviceProperties(&device_prop, dev_id));
if ((device_prop.major << 4) + device_prop.minor >= 0x35)
printf("Host and device APIs will be tested.\n");
do_device_api_test = true;
/* else if ((device_prop.major << 4) + device_prop.minor >= 0x20)
printf("Host API will be tested.\n");
else
fprintf(stderr, "simpleDevLibCUBLAS examples requires Compute Capability of SM 3.5 or higher\n");
return EXIT_WAIVED;
status = cublasCreate(&handle);
if (status != CUBLAS_STATUS_SUCCESS)
fprintf(stderr, "!!!! CUBLAS initialization error\n");
return EXIT_FAILURE;
/* Allocate host memory for the matrices */
h_A = (float *)malloc(n2 * sizeof(h_A[0]));
if (h_A == 0)
fprintf(stderr, "!!!! host memory allocation error (A)\n");
h_B = (float *)malloc(n2 * sizeof(h_B[0]));
if (h_B == 0)
fprintf(stderr, "!!!! host memory allocation error (B)\n");
h_C_rnd = (float *)malloc(n2 * sizeof(h_C_rnd[0]));
if (h_C_rnd == 0)
fprintf(stderr, "!!!! host memory allocation error (C_rnd)\n");
h_C = (float *)malloc(n2 * sizeof(h_C_ref[0]));
if (h_C == 0)
fprintf(stderr, "!!!! host memory allocation error (C)\n");
/* Fill the matrices with test data */
for (i = 0; i < n2; i++)
h_A[i] = rand() / (float)RAND_MAX;
h_B[i] = rand() / (float)RAND_MAX;
h_C_rnd[i] = rand() / (float)RAND_MAX;
h_C[i] = h_C_rnd[i];
/* Allocate device memory for the matrices */
if (cudaMalloc((void **)&d_A, n2 * sizeof(d_A[0])) != cudaSuccess)
fprintf(stderr, "!!!! device memory allocation error (allocate A)\n");
if (cudaMalloc((void **)&d_B, n2 * sizeof(d_B[0])) != cudaSuccess)
fprintf(stderr, "!!!! device memory allocation error (allocate B)\n");
if (cudaMalloc((void **)&d_C, n2 * sizeof(d_C[0])) != cudaSuccess)
fprintf(stderr, "!!!! device memory allocation error (allocate C)\n");
/* Initialize the device matrices with the host matrices */
status = cublasSetVector(n2, sizeof(h_A[0]), h_A, 1, d_A, 1);
fprintf(stderr, "!!!! device access error (write A)\n");
status = cublasSetVector(n2, sizeof(h_B[0]), h_B, 1, d_B, 1);
fprintf(stderr, "!!!! device access error (write B)\n");
status = cublasSetVector(n2, sizeof(h_C_rnd[0]), h_C_rnd, 1, d_C, 1);
fprintf(stderr, "!!!! device access error (write C)\n");
* Performs operation using plain C code
simple_sgemm(N, alpha, h_A, h_B, beta, h_C);
h_C_ref = h_C;
* Performs operation using cublas
status = cublasSgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N, N, N, N, &alpha, d_A, N, d_B, N, &beta, d_C, N);
fprintf(stderr, "!!!! kernel execution error\n");
/* Allocate host memory for reading back the result from device memory */
h_C = (float *)malloc(n2 * sizeof(h_C[0]));
if (h_C == 0)
/* Read the result back */
status = cublasGetVector(n2, sizeof(h_C[0]), d_C, 1, h_C, 1);
fprintf(stderr, "!!!! device access error (read C)\n");
/* Check result against reference */
host_api_test_ratio = check_result(h_C, h_C_ref, n2);
if (do_device_api_test)
/* Reset device resident C matrix */
* Performs operation using the device API of CUBLAS library
device_cublas_sgemm(N, alpha, d_A, d_B, beta, d_C);
device_api_test_ratio = check_result(h_C, h_C_ref, n2);
/* Memory clean up */
free(h_A);
free(h_B);
free(h_C);
free(h_C_rnd);
free(h_C_ref);
if (cudaFree(d_A) != cudaSuccess)
fprintf(stderr, "!!!! memory free error (A)\n");
if (cudaFree(d_B) != cudaSuccess)
fprintf(stderr, "!!!! memory free error (B)\n");
if (cudaFree(d_C) != cudaSuccess)
fprintf(stderr, "!!!! memory free error (C)\n");
/* Shutdown */
status = cublasDestroy(handle);
fprintf(stderr, "!!!! shutdown error (A)\n");
bool test_result = do_device_api_test ?
host_api_test_ratio < 1e-6 &&
device_api_test_ratio < 1e-6 :
host_api_test_ratio < 1e-6;
printf("simpleDevLibCUBLAS completed, returned %s\n",
test_result ? "OK" : "ERROR!");
exit(test_result ? EXIT_SUCCESS : EXIT_FAILURE);
And the associated kernels:
* Routines for testing the device API of CUBLAS.
#include <stdio.h>
#include <stdlib.h>
__global__ void invokeDeviceCublasSgemm(cublasStatus_t *returnValue,
int n,
const float *d_alpha,
const float *d_A,
const float *d_B,
const float *d_beta,
float *d_C)
cublasHandle_t cnpHandle;
cublasStatus_t status = cublasCreate(&cnpHandle);
*returnValue = status;
return;
/* Perform operation using cublas */
status =
cublasSgemm(cnpHandle,
n, n, n,
d_alpha,
d_A, n,
d_B, n,
d_beta,
d_C, n);
cublasDestroy(cnpHandle);
struct SGEMMScalarParams
float alpha, beta;
float alpha,
float beta,
float *d_C)
cublasStatus_t *d_status;
if (cudaMalloc((void **) &d_status, sizeof(cublasStatus_t)) != cudaSuccess)
fprintf(stderr,
"!!!! device memory allocation error (allocate d_status)\n");
exit(EXIT_FAILURE);
// Device API requires scalar arguments (alpha and beta)
// to be allocated in the device memory.
SGEMMScalarParams h_params = {alpha, beta};
SGEMMScalarParams *d_params;
if (cudaMalloc((void **) &d_params, sizeof(SGEMMScalarParams)) !=
cudaSuccess)
fprintf(stderr,
"!!!! device memory allocation error (allocate d_params)\n");
exit(EXIT_FAILURE);
if (cudaMemcpy(d_params,
&h_params,
sizeof(SGEMMScalarParams),
cudaMemcpyHostToDevice) != cudaSuccess)
fprintf(stderr,
"!!!! host to device memory copy error\n");
exit(EXIT_FAILURE);
// Launch cublasSgemm wrapper kernel.
invokeDeviceCublasSgemm<<<1, 1>>>
(d_status, n, &d_params->alpha, d_A, d_B, &d_params->beta, d_C);
cudaError_t error;
if ((error = cudaGetLastError()) != cudaSuccess)
fprintf(stderr,
"!!!! kernel execution error: %s\n", cudaGetErrorString(error));
exit(EXIT_FAILURE);
if (cudaMemcpy(&status,
d_status,
sizeof(cublasStatus_t),
cudaMemcpyDeviceToHost) != cudaSuccess)
fprintf(stderr,
"!!!! device to host memory copy error\n");
exit(EXIT_FAILURE);
fprintf(stderr,
"!!!! CUBLAS Device API call failed with code %d\n",
status);
exit(EXIT_FAILURE);
// Free allocated device memory.
if (cudaFree(d_status) != cudaSuccess)
fprintf(stderr, "!!!! memory free error (d_status)\n");
exit(EXIT_FAILURE);
if (cudaFree(d_params) != cudaSuccess)
fprintf(stderr, "!!!! memory free error (d_params)\n");
exit(EXIT_FAILURE);
And here’s the errors I’m getting:
nvcc cublas_test.cu -arch=sm_75 -rdc=true -lcublas -lcublas_device -lcudadevrt
nvlink error : Undefined reference to 'cublasCreate_v2' in '/tmp/tmpxft_00001feb_00000000-10_cublas_test.o'
nvlink error : Undefined reference to 'cublasSgemm_v2' in '/tmp/tmpxft_00001feb_00000000-10_cublas_test.o'
The source code can be found on Github at https://github.com/tpn/cuda-samples/tree/master/v9.0/7_CUDALibraries/simpleDevLibCUBLAS
Any help would be greatly appreciated!
