Issue when calling cublasDdot from within kernel
Hello everyone,
I have made an initial port of a C code to the GPU (K40, CUDA 9.0), which works as expected. The kernel I created receives as input a vector of doubles of size n (u_d) and a 2D matrix of doubles of size nxn (sigma_d). Part of the code executed in the kernel is a dot product between a row of sigma_d and the vector u_d. I create a 1D grid containing >= n threads in total and each thread performs one such dot product.
Now I want to use cublasDdot within each thread to perform the dot product, with the hope that it will perform faster. Although I have managed to modify the code, compile it and execute it, I am stuck as I have issues: either I cannot copy back the results from the device to the host, or the results are incorrect.
I have reduced the code to the smallest working example that exhibits the same behavior as the original application. For testing purposes, I store and copy back to the host the results of the dot products. In the real application only the updated vector u_d needs to be copied back. This is why I left the second cudaMemcpy. The code consists of the following two files:
kernel.cu
#include <cuda.h>
#include <cublas_v2.h>
#include <stdio.h>
#include <math.h>
#include <getopt.h>
#include <stdlib.h>
#include <sys/time.h>
__constant__ long	n_d;
__global__ void do_timestep(double *u_d, double *sigma_d, double *res_d)
	long	i = blockIdx.x * blockDim.x + threadIdx.x;
	if (i < n_d) {
#if 0
		long	j;
		res_d[i] = 0.0;
		for (j = 0; j < n_d; j++) {
			res_d[i] += sigma_d[i * n_d + j] * u_d[j];
#else
		cublasHandle_t	cnpHandle;
		cublasStatus_t	status = cublasCreate(&cnpHandle);
		status = cublasDdot(cnpHandle, n_d, &sigma_d[i * n_d], 1, u_d, 1, &res_d[i]);
		cublasDestroy(cnpHandle);
#endif
extern "C" void invoke_do_timestep(double *u_d, double *sigma_d, double *res_d, long n)
	cudaError_t	err;
	do_timestep<<<(n - 1) / 32 + 1, 32>>>(u_d, sigma_d, res_d);
	err = cudaGetLastError();
	if (err != cudaSuccess) {
		printf("CUDA error: %s\n", cudaGetErrorString(err));
		exit(1);
extern "C" void copy_to_constant_memory(long n)
	cudaError_t	err;
	err = cudaMemcpyToSymbol(n_d, &n, sizeof(long));
		printf("Could not copy \"n\" to constant memory.\n");
		exit(1);
main.c
#include <cuda_runtime.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#define DEF_N	(100L)
void copy_to_constant_memory(long n);
void invoke_do_timestep(double *u_d, double *sigma_d, double *res_d, long n);
int main(int argc, char *argv[])
	long		n, i, j;
	double		*u_h, *u_d, *sigma_h, *sigma_d, *res_h, *res_d, *res_from_d;
	cudaError_t	err;
	n = DEF_N;
	u_h = (double *)calloc(n, sizeof(double));
	if (u_h == NULL) {
		printf("Could not allocate memory for \"u_h\".\n");
		exit(1);
	sigma_h = (double *)calloc(n * n, sizeof(double));
	if (sigma_h == NULL) {
		printf("Could not allocate memory for \"sigma_h\".\n");
		exit(1);
	res_h = (double *)calloc(n, sizeof(double));
	if (res_h == NULL) {
		printf("Could not allocate memory for \"res_h\".\n");
		exit(1);
	res_from_d = (double *)calloc(n, sizeof(double));
	if (res_from_d == NULL) {
		printf("Could not allocate memory for \"res_from_d\".\n");
		exit(1);
	err = cudaMalloc((void **)&u_d, n * sizeof(double));
		printf("Could not allocate memory for \"u_d\".\n");
		exit(1);
	err = cudaMalloc((void **)&sigma_d, n * n * sizeof(double));
		printf("Could not allocate memory for \"sigma_d\".\n");
		exit(1);
	err = cudaMalloc((void **)&res_d, n * sizeof(double));
		printf("Could not allocate memory for \"res_d\".\n");
		exit(1);
	 * Initialize arrays with random numbers.
	for (i = 0; i < n; i++ ) {
		u_h[i] = drand48();
#if defined(PRINT)
		printf("%ld\t%f\n", i, u_h[i]);
#endif
	for (i = 0; i < n; i++) {
		for (j = 0; j < n; j++) {
			sigma_h[i * n + j] = drand48();
#if defined(PRINT)
			printf("%4.1f", sigma[i * n + j]);
		printf("\n");
#endif
	err = cudaMemcpy(u_d, u_h, n * sizeof(double), cudaMemcpyHostToDevice);
		printf("Could not copy \"u_h\" to \"u_d\".\n");
		exit(1);
	err = cudaMemcpy(sigma_d, sigma_h, n * n * sizeof(double), cudaMemcpyHostToDevice);
		printf("Could not copy \"sigma_h\" to \"sigma_d\".\n");
		exit(1);
	copy_to_constant_memory(n);
	 * Perform operation on CPU.
			res_h[i] += sigma_h[i * n + j] * u_h[j];
	 * Perform operation on GPU using cuBLAS.
	invoke_do_timestep(u_d, sigma_d, res_d, n);
	err = cudaMemcpy(res_from_d, res_d, n * sizeof(double), cudaMemcpyDeviceToHost);
		printf("Could not copy \"res_d\" to \"res_from_d\".\n");
		exit(1);
	 * This is required in the original application, but fails when
	 * cublasDestroy() is called within the kernel.
	err = cudaMemcpy(u_h, u_d, n * sizeof(double), cudaMemcpyDeviceToHost);
		printf("Could not copy \"u_d\" to \"u_h\".\n");
		exit(1);
		if (fabs(res_h[i] - res_from_d[i]) > 10e-10) {
			printf("Diff at position %ld (%f, %f)\n", i, res_h[i], res_from_d[i]);
	return 0;
The compilation and linking is performed with the following commands:
nvcc -dc -O3 --ptxas-options=-v --compiler-options -O3,-Wall --gpu-architecture compute_35 --gpu-code sm_35 --maxrregcount 32 -o kernel.o kernel.cu
nvcc -dc -O3 --ptxas-options=-v --compiler-options -O3,-Wall --gpu-architecture compute_35 --gpu-code sm_35 --maxrregcount 32 -o main.o -c main.c
nvcc -O3 --ptxas-options=-v --compiler-options -O3,-Wall --gpu-architecture compute_35 --gpu-code sm_35 --maxrregcount 32 -o main kernel.o main.o -lcublas_device
Notice that I perform the same dot products on the CPU and save the results in the vector res_h for comparison.
  1. In the file kernel.cu, if the dot product is performed manually (what is now in the #if 0 part), the results copied back top the host are the same as in res_h.
  2. If the code is run as is (using the cuBLAS function call), I get an error that res_d cannot be copied back to the host to the vector res_from_d.
  3. If I comment out the cublasDestroy(cnpHandle); instruction the code runs, the copy from the device to the host succeeds, but the results are wrong.
Could someone shed some light and help me figure out where the error(s) is?
Thank you!
start by doing proper error checking in the kernel on the CUBLAS calls.
Test the return value, and if it is not CUBLAS_STATUS_SUCCESS, do not proceed with any further CUBLAS calls.
Feel free to print out an error report, just as you do in the error checking in host code.
Thanks for your suggestion. I modified the code of the kernel as follows:
	if (i < n_d) {
#if 0
		long	j;
		res_d[i] = 0.0;
#else
		if (status == CUBLAS_STATUS_NOT_INITIALIZED) {
			printf("Thread %ld: Could not initialize handle.\n", i);
			return;
		} else if (status == CUBLAS_STATUS_ALLOC_FAILED) {
			printf("Thread %ld: Could not allocate resources for handle.\n", i);
			return;
		if (status != CUBLAS_STATUS_SUCCESS) {
			printf("Thread %ld: Call to cublasDdot failed.\n", i);
#endif
Indeed some threads return CUBLAS_STATUS_ALLOC_FAILED when trying to create the handle. I don’t know if it is relevant, but for the 100 threads that run, always 18 seem to fail (but not always the same threads).
How can I investigate this further and correct the problem?
After reading again Chapter 2 of the cuBLAS documentation (cuBLAS :: CUDA Toolkit Documentation) and a comment I found (https://www.linuxquestions.org/questions/showthread.php?p=5437515), I actually managed to make it work.
I present here my solution for completeness, in case someone else needs to do something similar and encounters problems.
The detail that seems to make everything work is that there is only one handle required for all threads. Therefore, I declare a global variable on the device (handle_d) and create a new kernel that is invoked on a single thread on the GPU and initializes the handle.
kernel.cu
#include <cuda.h>
#include <stdio.h>
#include <math.h>
#include <getopt.h>
#include <stdlib.h>
__device__ cublasHandle_t	handle_d;
__global__ void init_handle(cublasStatus_t *status_d)
	*status_d = cublasCreate(&handle_d);
extern "C" void invoke_init_handle()
	cudaError_t	err;
	cublasStatus_t	status_h, *status_d;
	err = cudaMalloc((void **)&status_d, sizeof(cublasStatus_t));
		printf("Could not allocate \"status_d\".\n");
		exit(1);
	init_handle<<<1, 1>>>(status_d);
		exit(1);
	err = cudaMemcpy(&status_h, status_d, sizeof(cublasStatus_t), cudaMemcpyDeviceToHost);
		printf("Could not copy \"status_d\" to \"status_h\".\n");
		exit(1);
	if (status_h == CUBLAS_STATUS_NOT_INITIALIZED) {
		printf("Could not initialize handle.\n");
		exit(1);
	} else if (status_h == CUBLAS_STATUS_ALLOC_FAILED) {
		printf("Could not allocate resources for handle.\n");
		exit(1);
	err = cudaFree(status_d);
		printf("Could not free \"status_d\".\n");
		exit(1);
	if (i < n_d) {
		cublasStatus_t	status = cublasDdot(handle_d, n_d, &sigma_d[i * n_d], 1, u_d, 1, &res_d[i]);
			return;
	cudaError_t	err;
		exit(1);
	cudaError_t	err;
		exit(1);
main.c
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
void invoke_init_handle(void);
	long		n, i, j;
	cudaError_t	err;
	n = DEF_N;
	if (u_h == NULL) {
		exit(1);
		exit(1);
		exit(1);
		exit(1);
		exit(1);
		exit(1);
		exit(1);
		u_h[i] = drand48();
#if defined(PRINT)
#endif
#if defined(PRINT)
		printf("\n");
#endif
		exit(1);
		exit(1);
	invoke_init_handle();
		exit(1);
		exit(1);
	return 0;
Compilation:
I am going to incorporate this solution to my application and will report back whether I will see any change in performance.
I incorporated the above solution into my original application, which repeatedly calls invoke_do_timestep() in a time-step loop. The results are correct now, but the application is ~16x slower with cuBLAS than using my own implementation of the dot product.
Is this expected? Or is there anything else I have to pay attention to when calling cuBLAS routines from within a kernel? For example, I am a bit puzzled about the size of the grid that the calls to cublasDdot use. Is the call executed on a single thread or more threads, e.g., the same size of grid as the one used when calling the original kernel?
Any hints about what might be going on and performance is so bad?
Any ideas about the performance issue when using cuBLAS?
Due to some issues with my account, my previous messages were hidden. It seems that this issue has now been resolved. As I have no idea who could see my previous messages, I am writing this message to bump this thread up, in the hope that more people will see it and provide their ideas with respect to the performance issue I experience.
Thank you.
To answer questions about performance, it’s usually recommended to use a profiler.
A dot-product is a fairly “lightweight” operation, and it is possible for an average (i.e. not expert) CUDA programmer to write code that is approximately optimal for this operation.
Using CUBLAS from within a kernel often involves a CDP (CUDA Dynamic Parallelism) child kernel launch. A kernel launch is a fairly heavyweight operation which has significant overheads and launch latencies associated with it. CUBLAS itself has significant start-up overheads, so if this is the only thing you use it for, and you run a short, simple test, it may be that the CUBLAS initialization overhead is also a factor.
I haven’t studied your code carefully, or run it through a profiler, but for these reasons it doesn’t surprise me that replacing a hand-written dot-product in kernel code with a call to CUBLAS might not be a win, from a performance perspective.
