cuBLAS convolution does not use Tensor Cores
I would like to operate a matrix mutiplication on Tensor Cores using cuBLAS.
According to the documentation, Tensor Cores supported the following matrix sizes.
Matrix 1 Matrix B Accumulator Matrix Size (m-n-k)
_half _half float 16x16x16
_half _half float 32x8x16
_half _half float 8x32x16
To be sure Tensor Cores could be used, I started performing a 16x16x16 (m-n-k) matrix multiplication.
For this purpose, I adapted the “matrixMulCUBLAS” sample code provided by NVIDIA.
I did the following modifications :
  1. Matrix sizes
matrix_size.uiWA = 3 * block_size * iSizeMultiple;matrix_size.uiWA = 16;
matrix_size.uiHA = 4 * block_size * iSizeMultiple;matrix_size.uiHA = 16;
matrix_size.uiWB = 2 * block_size * iSizeMultiple;matrix_size.uiWB = 16;
matrix_size.uiHB = 3 * block_size * iSizeMultiple;matrix_size.uiHB = 16;
matrix_size.uiWC = 2 * block_size * iSizeMultiple;matrix_size.uiWC = 16;
matrix_size.uiHC = 4 * block_size * iSizeMultiple;matrix_size.uiHC = 16;
  1. Math mode
checkCudaErrors(cublasSetMathMode(handle, CUBLAS_TENSOR_OP_MATH));
  1. Convolution function
checkCudaErrors(cublasSgemm(
handle,
CUBLAS_OP_N,
CUBALS_OP_N,
matrix_size.uiWB,
matrix_size.uiHA,
matrix_size.uiWA,
&alpha,
d_B,
matrix_size.uiWB,
d_A,
matrix_size.uiWA,
&beta,
d_C,
matrix_size.uiWB)) ;
became :
checkCudaErrors(cublasGemmEx(
handle,
CUBLAS_OP_N,
CUBLAS_OP_N,
matrix_size.uiWB,
matrix_size.uiHA,
matrix_size.uiWA,
&alpha,
d_B,
CUDA_R_32F,
matrix_size.uiWB,
d_A,
CUDA_R_32F,
matrix_size.uiWA,
&beta,
d_C,
CUDA_R_32F,
matrix_size.uiWB,
CUBLAS_COMPUTE_32F_FAST_16F,
CUBLAS_GEMM_DEFAULT_TENSOR_OP));
CUBLAS_COMPUTE_32F_FAST_16F : Allows the library to use Tensor Cores with automatic down-conversion and 16-bit half-precision compute for 32-bit input and output matrices.
CUBLAS_GEMM_DEFAULT_TENSOR_OP : Apply Heuristics to select the GEMM algorithm while allowing the use of Tensor Core operations if possible.
But in the end, the convolution kernel does not use Tensor Cores. cuBLAS does not choose the Tensor Cores option. I don’t understand why. 16x16x16 (m-n-k) fits perfectly Tensor Cores layout.
Thanks in advance for your help.
Can you provide a small reproducer?
Hi @mnicely , Sure.
// Copyright 1993-2015 NVIDIA Corporation.  All rights reserved.
// Please refer to the NVIDIA end user license agreement (EULA) associated
// with this source code for terms and conditions that govern your use of
// this software. Any use, reproduction, disclosure, or distribution of
// this software and related documentation outside the terms of the EULA
// is strictly prohibited.
// Matrix multiplication: C = A * B.
// Host code.
// This sample implements matrix multiplication as described in Chapter 3
// of the programming guide and uses the CUBLAS library to demonstrate
// the best performance.
// SOME PRECAUTIONS:
// IF WE WANT TO CALCULATE ROW-MAJOR MATRIX MULTIPLY C = A * B,
// WE JUST NEED CALL CUBLAS API IN A REVERSE ORDER: cublasSegemm(B, A)!
// The reason is explained as follows:
// CUBLAS library uses column-major storage, but C/C++ use row-major storage.
// When passing the matrix pointer to CUBLAS, the memory layout alters from
// row-major to column-major, which is equivalent to an implicit transpose.
// In the case of row-major C/C++ matrix A, B, and a simple matrix multiplication
// C = A * B, we can't use the input order like cublasSgemm(A, B)  because of
// implicit transpose. The actual result of cublasSegemm(A, B) is A(T) * B(T).
// If col(A(T)) != row(B(T)), equal to row(A) != col(B), A(T) and B(T) are not
// multipliable. Moreover, even if A(T) and B(T) are multipliable, the result C
// is a column-based cublas matrix, which means C(T) in C/C++, we need extra
// transpose code to convert it to a row-based C/C++ matrix.
// To solve the problem, let's consider our desired result C, a row-major matrix.
// In cublas format, it is C(T) actually (because of the implicit transpose).
// C = A * B, so C(T) = (A * B) (T) = B(T) * A(T). Cublas matrice B(T) and A(T)
// happen to be C/C++ matrice B and A (still because of the implicit transpose)!
// We don't need extra transpose code, we only need alter the input order!
// CUBLAS provides high-performance matrix multiplication.
// See also:
// V. Volkov and J. Demmel, "Benchmarking GPUs to tune dense linear algebra,"
// in Proc. 2008 ACM/IEEE Conf. on Supercomputing (SC '08),
// Piscataway, NJ: IEEE Press, 2008, pp. Art. 31:1-11.
// Utilities and system includes
#include <assert.h>
#include <helper_string.h>  // helper for shared functions common to CUDA Samples
// CUDA runtime
#include <cuda_runtime.h>
#include <cublas_v2.h>
// CUDA and CUBLAS functions
#include <helper_functions.h>
#include <helper_cuda.h>
#ifndef min
#define min(a,b) ((a < b) ? a : b)
#endif
#ifndef max
#define max(a,b) ((a > b) ? a : b)
#endif
typedef struct _matrixSize      // Optional Command-line multiplier for matrix sizes
    unsigned int uiWA, uiHA, uiWB, uiHB, uiWC, uiHC;
} sMatrixSize;
//! Compute reference data set matrix multiply on CPU
//! C = A * B
//! @param C          reference data, computed but preallocated
//! @param A          matrix A as provided to device
//! @param B          matrix B as provided to device
//! @param hA         height of matrix A
//! @param wB         width of matrix B
void
matrixMulCPU(float *C, const float *A, const float *B, unsigned int hA, unsigned int wA, unsigned int wB)
    for (unsigned int i = 0; i < hA; ++i)
        for (unsigned int j = 0; j < wB; ++j)
            double sum = 0;
            for (unsigned int k = 0; k < wA; ++k)
                double a = A[i * wA + k];
                double b = B[k * wB + j];
                sum += a * b;
            C[i * wB + j] = (float)sum;
// Allocates a matrix with random float entries.
void randomInit(float *data, int size)
    for (int i = 0; i < size; ++i)
        data[i] = rand() / (float)RAND_MAX;
void printDiff(float *data1, float *data2, int width, int height, int iListLength, float fListTol)
    printf("Listing first %d Differences > %.6f...\n", iListLength, fListTol);
    int i,j,k;
    int error_count=0;
    for (j = 0; j < height; j++)
        if (error_count < iListLength)
            printf("\n  Row %d:\n", j);
        for (i = 0; i < width; i++)
            k = j * width + i;
            float fDiff = fabs(data1[k] - data2[k]);
            if (fDiff > fListTol)
                    printf("    Loc(%d,%d)\tCPU=%.5f\tGPU=%.5f\tDiff=%.6f\n", i, j, data1[k], data2[k], fDiff);
                error_count++;
    printf(" \n  Total Errors = %d\n", error_count);
void initializeCUDA(int argc, char **argv, int &devID, int &iSizeMultiple, sMatrixSize &matrix_size)
    // By default, we use device 0, otherwise we override the device ID based on what is provided at the command line
    cudaError_t error;
    devID = 0;
    devID = findCudaDevice(argc, (const char **)argv);
    if (checkCmdLineFlag(argc, (const char **)argv, "sizemult"))
        iSizeMultiple = getCmdLineArgumentInt(argc, (const char **)argv, "sizemult");
    iSizeMultiple = min(iSizeMultiple, 10);
    iSizeMultiple = max(iSizeMultiple, 1);
    cudaDeviceProp deviceProp;
    error = cudaGetDeviceProperties(&deviceProp, devID);
    if (error != cudaSuccess)
        printf("cudaGetDeviceProperties returned error code %d, line(%d)\n", error, __LINE__);
        exit(EXIT_FAILURE);
    printf("GPU Device %d: \"%s\" with compute capability %d.%d\n\n", devID, deviceProp.name, deviceProp.major, deviceProp.minor);
    // int block_size = 32;
    // matrix_size.uiWA = 3 * block_size * iSizeMultiple;
    // matrix_size.uiHA = 4 * block_size * iSizeMultiple;
    // matrix_size.uiWB = 2 * block_size * iSizeMultiple;
    // matrix_size.uiHB = 3 * block_size * iSizeMultiple;
    // matrix_size.uiWC = 2 * block_size * iSizeMultiple;
    // matrix_size.uiHC = 4 * block_size * iSizeMultiple;
    printf("MatrixA(%u,%u), MatrixB(%u,%u), MatrixC(%u,%u)\n",
           matrix_size.uiHA, matrix_size.uiWA,
           matrix_size.uiHB, matrix_size.uiWB,
           matrix_size.uiHC, matrix_size.uiWC);
    if( matrix_size.uiWA != matrix_size.uiHB ||
        matrix_size.uiHA != matrix_size.uiHC ||
        matrix_size.uiWB != matrix_size.uiWC)
       printf("ERROR: Matrix sizes do not match!\n");
       exit(-1);
//! Run a simple test matrix multiply using CUBLAS
int matrixMultiply(int argc, char **argv, int devID, sMatrixSize &matrix_size)
    checkCudaErrors(cudaGetDeviceProperties(&deviceProp, devID));
    // set seed for rand()
    srand(2006);
    // allocate host memory for matrices A and B
    unsigned int size_A = matrix_size.uiWA * matrix_size.uiHA;
    unsigned int mem_size_A = sizeof(float) * size_A;
    float *h_A = (float *)malloc(mem_size_A);
    unsigned int size_B = matrix_size.uiWB * matrix_size.uiHB;
    unsigned int mem_size_B = sizeof(float) * size_B;
    float *h_B = (float *)malloc(mem_size_B);
    srand(2006);
    // initialize host memory
    randomInit(h_A, size_A);
    randomInit(h_B, size_B);
    // allocate device memory
    float *d_A, *d_B, *d_C;
    unsigned int size_C = matrix_size.uiWC * matrix_size.uiHC;
    unsigned int mem_size_C = sizeof(float) * size_C;
    // allocate host memory for the result
    float *h_C      = (float *) malloc(mem_size_C);
    float *h_CUBLAS = (float *) malloc(mem_size_C);
    checkCudaErrors(cudaMalloc((void **) &d_A, mem_size_A));
    checkCudaErrors(cudaMalloc((void **) &d_B, mem_size_B));
    checkCudaErrors(cudaMemcpy(d_A, h_A, mem_size_A, cudaMemcpyHostToDevice));
    checkCudaErrors(cudaMemcpy(d_B, h_B, mem_size_B, cudaMemcpyHostToDevice));
    checkCudaErrors(cudaMalloc((void **) &d_C, mem_size_C));
    // setup execution parameters
    dim3 threads(block_size, block_size);
    dim3 grid(matrix_size.uiWC / threads.x, matrix_size.uiHC / threads.y);
    // create and start timer
    printf("Computing result using CUBLAS...");
    // execute the kernel
    int nIter = 30;
    // CUBLAS version 2.0
        const float alpha = 1.0f;
        const float beta  = 0.0f;
        cublasHandle_t handle;
        cudaEvent_t start, stop;
        checkCudaErrors(cublasCreate(&handle));
        //Perform warmup operation with cublas
        checkCudaErrors(cublasSgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N, matrix_size.uiWB, matrix_size.uiHA, matrix_size.uiWA, &alpha, d_B, matrix_size.uiWB, d_A, matrix_size.uiWA, &beta, d_C, matrix_size.uiWB));
        // Allocate CUDA events that we'll use for timing
        checkCudaErrors(cudaEventCreate(&start));
        checkCudaErrors(cudaEventCreate(&stop));
        // Record the start event
        checkCudaErrors(cudaEventRecord(start, NULL));
        for (int j = 0; j < nIter; j++)
            //note cublas is column primary!
            //need to transpose the order
            // checkCudaErrors(cublasSgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N, matrix_size.uiWB, matrix_size.uiHA, matrix_size.uiWA, &alpha, d_B, matrix_size.uiWB, d_A, matrix_size.uiWA, &beta, d_C, matrix_size.uiWB));
            checkCudaErrors(cublasGemmEx(handle,
                                        CUBLAS_OP_N,
                                        CUBLAS_OP_N,
                                        matrix_size.uiWB,
                                        matrix_size.uiHA,
                                        matrix_size.uiWA,
                                        &alpha,
                                        d_B,
                                        CUDA_R_32F,
                                        matrix_size.uiWB,
                                        d_A,
                                        CUDA_R_32F,
                                        matrix_size.uiWA,
                                        &beta,
                                        d_C,
                                        CUDA_R_32F,
                                        matrix_size.uiWB,
                                        CUBLAS_COMPUTE_32F_FAST_16F, /* Allows the library to use Tensor Cores with automatic down-conversion and 16-bit half-precision compute for 32-bit input and output matrices. */
                                        CUBLAS_GEMM_DEFAULT_TENSOR_OP)); /* Apply Heuristics to select the GEMM algorithm while allowing the use of Tensor Core operations if possible. */
        printf("done.\n");
        // Record the stop event
        checkCudaErrors(cudaEventRecord(stop, NULL));
        // Wait for the stop event to complete
        checkCudaErrors(cudaEventSynchronize(stop));
        float msecTotal = 0.0f;
        checkCudaErrors(cudaEventElapsedTime(&msecTotal, start, stop));
        // Compute and print the performance
        float msecPerMatrixMul = msecTotal / nIter;
        double flopsPerMatrixMul = 2.0 * (double)matrix_size.uiHC * (double)matrix_size.uiWC * (double)matrix_size.uiHB;
        double gigaFlops = (flopsPerMatrixMul * 1.0e-9f) / (msecPerMatrixMul / 1000.0f);
        printf(
            "Performance= %.2f GFlop/s, Time= %.3f msec, Size= %.0f Ops\n",
            gigaFlops,
            msecPerMatrixMul,
            flopsPerMatrixMul);
        // copy result from device to host
        checkCudaErrors(cudaMemcpy(h_CUBLAS, d_C, mem_size_C, cudaMemcpyDeviceToHost));
        // Destroy the handle
        checkCudaErrors(cublasDestroy(handle));
    // compute reference solution
    printf("Computing result using host CPU...");
    float *reference = (float *)malloc(mem_size_C);
    matrixMulCPU(reference, h_A, h_B, matrix_size.uiHA, matrix_size.uiWA, matrix_size.uiWB);
    printf("done.\n");
    // check result (CUBLAS)
    bool resCUBLAS = sdkCompareL2fe(reference, h_CUBLAS, size_C, 1.0e-6f);
    if (resCUBLAS != true)
        printDiff(reference, h_CUBLAS, matrix_size.uiWC, matrix_size.uiHC, 100, 1.0e-5f);
    printf("Comparing CUBLAS Matrix Multiply with CPU results: %s\n", (true == resCUBLAS) ? "PASS" : "FAIL");
    printf("\nNOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.\n");
    // clean up memory
    free(h_A);
    free(h_B);
    free(h_C);
    free(reference);
    checkCudaErrors(cudaFree(d_A));
    checkCudaErrors(cudaFree(d_B));
    checkCudaErrors(cudaFree(d_C));
    if (resCUBLAS == true)
        return EXIT_SUCCESS;    // return value = 1
    else
        return EXIT_FAILURE;     // return value = 0
// Program main
int main(int argc, char **argv)
    printf("[Matrix Multiply CUBLAS] - Starting...\n");
    int devID = 0, sizeMult = 1;
    sMatrixSize matrix_size;
    initializeCUDA(argc, argv, devID, sizeMult, matrix_size);
    int matrix_result = matrixMultiply(argc, argv, devID, matrix_size);
    return matrix_result;
Hi @mnicely,
Any news ?
which GPU are you running on? What CUDA Version are you using?
Hi @Robert_Crovella,
I work on a RTX4000 mobile with CUDA 11.3.
CUBLAS (cublasGemmEx) will use a heuristic to determine which algorithm to use, based on unspecified factors. The objective is to make the operation run as fast as possible.
One of these unspecified factors appears to be the matrix size (dimensions). For a 16x16 matrix size it appears that cublas will not use tensor core. For a 256x256 matrix size according to my test, it will also not use tensorcore. But for a matrix size of 512x512 according to my testing on CUDA 11.1 on Tesla V100, it will use tensor core.
So you need to increase your matrix size, substantially. When you do so, you will eventually find that the code you have presented no longer presents a PASS result, because the result of performing the matrix multiply by down-converting 32-bit float quantities to 16-bit float quantities eventually does not pass a threshold comparison test, when comparing against host code doing the arithmetic entirely in 32-bit float.
Questions revolving around the exact algorithm break-points for use of tensor core I won’t be able to answer. I’m pretty sure these are unpublished for a reason: they might vary based on CUDA version, GPU used, and so forth.
Here is a full test case, showing a slightly modified version of your code:
$ cat t55.cu
// Host code.
// See also:
#include <assert.h>
// CUDA runtime
#ifndef min
#endif
#ifndef max
#endif
} sMatrixSize;
//! C = A * B
void
            double sum = 0;
                sum += a * b;
    int i,j,k;
    int error_count=0;
            k = j * width + i;
                error_count++;
    cudaError_t error;
    devID = 0;
        exit(EXIT_FAILURE);
    int szm = 16*16*2;
    matrix_size.uiWA = szm;
    matrix_size.uiHA = szm;
    matrix_size.uiWB = szm;
    matrix_size.uiHB = szm;
    matrix_size.uiWC = szm;
    matrix_size.uiHC = szm;
       exit(-1);
    srand(2006);
    srand(2006);
    int nIter = 1;
//        checkCudaErrors(cublasSetMathMode(handle, CUBLAS_TENSOR_OP_MATH));
                                        CUBLAS_OP_N,
                                        CUBLAS_OP_N,
                                        matrix_size.uiWB,
                                        matrix_size.uiHA,
                                        matrix_size.uiWA,
                                        &alpha,
                                        d_B,
                                        CUDA_R_32F,
                                        matrix_size.uiWB,
                                        d_A,
                                        CUDA_R_32F,
                                        matrix_size.uiWA,
                                        &beta,
                                        d_C,
                                        CUDA_R_32F,
                                        matrix_size.uiWB,
        printf("done.\n");
        printf(
            gigaFlops,
            msecPerMatrixMul,
            flopsPerMatrixMul);
    printf("done.\n");
    bool resCUBLAS = sdkCompareL2fe(reference, h_CUBLAS, size_C, 1.0e-1f);
    // clean up memory
    free(h_A);
    free(h_B);
    free(h_C);
    free(reference);
    else
// Program main
$ nvcc -o t55 t55.cu -lcublas -I/usr/local/cuda/samples/common/inc
$ nvprof --print-gpu-trace ./t55
==58472== NVPROF is profiling process 58472, command: ./t55
GPU Device 0: "Volta" with compute capability 7.0
GPU Device 0: "Tesla V100-SXM2-32GB" with compute capability 7.0
MatrixA(512,512), MatrixB(512,512), MatrixC(512,512)
Computing result using CUBLAS...done.
Performance= 1362.89 GFlop/s, Time= 0.197 msec, Size= 268435456 Ops
Computing result using host CPU...done.
Comparing CUBLAS Matrix Multiply with CPU results: PASS
==58472== Profiling application: ./t55
==58472== Profiling result:
   Start  Duration            Grid Size      Block Size     Regs*    SSMem*    DSMem*      Size  Throughput  SrcMemType  DstMemType           Device   Context    Stream  Name
638.78ms  87.773us                    -               -         -         -         -  1.0000MB  11.126GB/s    Pageable      Device  Tesla V100-SXM2         1         7  [CUDA memcpy HtoD]
639.10ms  87.740us                    -               -         -         -         -  1.0000MB  11.130GB/s    Pageable      Device  Tesla V100-SXM2         1         7  [CUDA memcpy HtoD]
1.37535s  1.7920us                    -               -         -         -         -      112B  59.605MB/s    Pageable      Device  Tesla V100-SXM2         1         7  [CUDA memcpy HtoD]
1.37768s  1.4080us                    -               -         -         -         -       64B  43.349MB/s      Device           -  Tesla V100-SXM2         1         7  [CUDA memset]
1.37773s  44.735us              (4 4 5)       (128 1 1)       250  32.250KB        0B         -           -           -           -  Tesla V100-SXM2         1         7  volta_s884gemm_128x128_ldg8_f2f_nn [2715]
1.37781s  81.053us                    -               -         -         -         -  1.0000MB  12.048GB/s      Device    Pageable  Tesla V100-SXM2         1         7  [CUDA memcpy DtoH]
Regs: Number of registers used per CUDA thread. This number includes registers used internally by the CUDA driver and/or tools and can be more than what the compiler shows.
SSMem: Static shared memory allocated per CUDA block.
DSMem: Dynamic shared memory allocated per CUDA block.
SrcMemType: The type of source memory accessed by memory operation/copy
DstMemType: The type of destination memory accessed by memory operation/copy
Notes:
  1. The modifications I’ve made are as follows: A. get rid of unnecessary cublas calls, and reduce nIter to 1, to make profiling less cluttered B. Change the matrix side dimension (to 512) C. Change the threshold of comparison to 0.1 instead of 0.000001. This allows a passing result to be reported. You can modify this to see what the comparison looks like with a tighter threshold.
  2. As mentioned, the side dimension of 512 is where I first saw a tensor core kernel being used (the kernel has 884 in the name).
  3. I don’t have a RTX 4000m to use. You will need to use one of the newer profilers (e.g. nsight compute, nsight systems) to see the kernels being launched.
  4. If you make the dimensions large enough, it should eventually be evident simply from the reported performance, that tensorcore is being used. For example, in my case, if I make the side dimension 4096, I get a reported performance of ~50TF. This is only possible via tensorcore. If you run with such a large side dimension, the CPU comparison will take a very long time (and will probably fail the threshold test, due to 16-bit calculations).
